[petsc-users] Slepc eigenvectors not orthonormalized
Peetz, Darin T peetz2 at illinois.edu
Thu Oct 13 17:32:32 CDT 2016
I've come across an irregularity when extracting the eigenvectors when using the CISS method to solve the eigenvalue problem.  I'm solving a generalized hermitian problem, and it looks like the resulting eigenvectors are M-orthogonalized with each other (the M-inner products of different eigenvectors are approximately 0, as expected), but are normalized using the L2-inner product, not the M-inner product.  Basically, the matrix V'*M*V (V being a matrix composed of the extracted eigenvectors) is diagonal, but the diagonals are much larger than 1, and the matrix V'*V has non-zero diagonals, but the diagonal elements are exactly equal to 1.
This only happens if I use the CISS method.  If I use the Arnoldi method for example, the eigenvectors are normalized as expected.  Is there any particular reason for this, or is this an error in the implementation?
Darin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161013/1a111036/attachment.html>
