[petsc-users] Algorithms to remove null spaces in a singular system
Kong, Fande
fande.kong at inl.gov
Thu Oct 13 17:20:11 CDT 2016
One more question.
Suppose that we are solving the singular linear system Ax = b. N(A) is the
null space of A, and N(A^T) is the null space of the transpose of A.
The linear system is solved using SNES, that is, F(x) = Ax-b = Ax -b_r -
b_n. Here b_n in N(A^T), and b_r in R(A). During each nonlinear
iteration, a linear system A \delta x = F(x) is solved. N(A) is applied to
Krylov space during the linear iterating. Before the actual solve
"(*ksp->ops->solve)(ksp)" for \delta x, a temporary copy of F(x) is made,
F_tmp. N(A^T) is applied to F_tmp. We will get a \delta x. F(x+\delta x )
= A(x+\delta x)-b_r - b_n.
F(x+\delta x ) always contain the vector b_n, and then the algorithm never
converges because the normal of F is at least 1.
Should we apply N(A^T) to F instead of F_tmp so that b_n can be removed
from F?
MatGetTransposeNullSpace(pmat,&nullsp);
if (nullsp) {
VecDuplicate(ksp->vec_rhs,&btmp);
VecCopy(ksp->vec_rhs,btmp);
MatNullSpaceRemove(nullsp,btmp);
vec_rhs = ksp->vec_rhs;
ksp->vec_rhs = btmp;
should be changed to
if (nullsp) {
MatNullSpaceRemove(nullsp,ksp->vec_rhs);
Or other solutions to this issue?
Fande Kong,
On Thu, Oct 13, 2016 at 8:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 13, 2016 at 9:06 AM, Kong, Fande <fande.kong at inl.gov> wrote:
>> On Wed, Oct 12, 2016 at 10:21 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> > I would make that a separate routine that the users would call first.
>>> We have VecMDot and VecMAXPY. I would propose adding
>>> VecQR(PetscInt nvecs,Vec *vecs,PetscScalar *R);
>>> (where R can be NULL).
>> What does R mean here?
> It means the coefficients of the old basis vectors in the new basis.
> Matt
>> If nobody working on this, I will be going to take a try.
>> Fande,
>>> Does anyone use the "Vecs" type?
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161013/0fd010fc/attachment.html>
