[petsc-users] Algorithms to remove null spaces in a singular system
Kong, Fande fande.kong at inl.gov
Tue Oct 11 09:33:22 CDT 2016
Barry, Thanks so much for your explanation. It helps me a lot.
On Mon, Oct 10, 2016 at 4:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Oct 10, 2016, at 4:01 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> > Hi All,
> > I know how to remove the null spaces from a singular system using
> creating a MatNullSpace and attaching it to Mat.
> > I was really wondering what is the philosophy behind this? The exact
> algorithms we are using in PETSc right now?  Where we are dealing with
> this, preconditioner, linear solver, or nonlinear solver?
>    It is in the Krylov solver.
>    The idea is very simple. Say you have   a singular A with null space N
> (that all values Ny are in the null space of A. So N is tall and skinny)
> and you want to solve A x = b where b is in the range of A. This problem
> has an infinite number of solutions     Ny + x*  since A (Ny + x*) = ANy +
> Ax* = Ax* = b where x* is the "minimum norm solution; that is Ax* = b and
> x* has the smallest norm of all solutions.
>       With left preconditioning   B A x = B b GMRES, for example, normally
> computes the solution in the as alpha_1 Bb   + alpha_2 BABb + alpha_3
> BABABAb + ....  but the B operator will likely introduce some component
> into the direction of the null space so as GMRES continues the "solution"
> computed will grow larger and larger with a large component in the null
> space of A. Hence we simply modify GMRES a tiny bit by building the
> solution from alpha_1 (I-N)Bb   + alpha_2 (I-N)BABb + alpha_3
 Does "I" mean an identity matrix? Could you possibly send me a link for
this GMRES implementation, that is, how PETSc does this in the actual code?
> (I-N)BABABAb + ....  that is we remove from each new direction anything in
> the direction of the null space. Hence the null space doesn't directly
> appear in the preconditioner, just in the KSP method.   If you attach a
> null space to the matrix, the KSP just automatically uses it to do the
> removal above.
>     With right preconditioning the solution is built from alpha_1 b   +
> alpha_2 ABb + alpha_3 ABABb + .... and again we apply (I-N) to each term to
> remove any part that is in the null space of A.
>    Now consider the case   A y = b where b is NOT in the range of A. So
> the problem has no "true" solution, but one can find a least squares
> solution by rewriting b = b_par + b_perp where b_par is in the range of A
> and b_perp is orthogonal to the range of A and solve instead    A x =
> b_perp. If you provide a MatSetTransposeNullSpace() then KSP automatically
> uses it to remove b_perp from the right hand side before starting the KSP
> iterations.
>   The manual pages for MatNullSpaceAttach() and
> MatTranposeNullSpaceAttach() discuss this an explain how it relates to the
> fundamental theorem of linear algebra.
>   Note that for symmetric matrices the two null spaces are the same.
>   Barry
>    A different note: This "trick" is not a "cure all" for a totally
> inappropriate preconditioner. For example if one uses for a preconditioner
> a direct (sparse or dense) solver or an ILU(k) one can end up with a very
> bad solver because the direct solver will likely produce a very small pivot
> at some point thus the triangular solver applied in the precondition can
> produce HUGE changes in the solution (that are not physical) and so the
> preconditioner basically produces garbage. On the other hand sometimes it
> works out ok.
What preconditioners  are appropriate? asm, bjacobi, amg? I have an example
which shows  lu and ilu indeed work, but asm and bjacobi do not at all.
That is why I am asking questions about algorithms. I am trying to figure
out a default preconditioner for several singular systems.
Thanks again.
Fande Kong,
> > Fande Kong,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161011/ed9379e6/attachment.html>
