[petsc-users] SuperLU_dist issue in 3.7.4
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 7 13:01:55 CDT 2016
Fande,
If you can reproduce the problem with PETSc 3.7.4 please send us sample code that produces it so we can work with Sherry to get it fixed ASAP.
Barry
> On Oct 7, 2016, at 10:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 7 Oct 2016, Kong, Fande wrote:
>> On Fri, Oct 7, 2016 at 9:04 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Fri, 7 Oct 2016, Anton Popov wrote:
>>>> Hi guys,
>>>> are there any news about fixing buggy behavior of SuperLU_DIST, exactly
>>> what
>>>> is described here:
>>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
>>> mcs.anl.gov_pipermail_petsc-2Dusers_2015-2DAugust_026802.html&d=CwIBAg&c=
>>> 54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_
>>> JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=RwruX6ckX0t9H89Z6LXKBfJBOAM2vG
>>> 1sQHw2tIsSQtA&s=bbB62oGLm582JebVs8xsUej_OX0eUwibAKsRRWKafos&e= ?
>>>> I'm using 3.7.4 and still get SEGV in pdgssvx routine. Everything works
>>> fine
>>>> with 3.5.4.
>>>> Do I still have to stick to maint branch, and what are the chances for
>>> these
>>>> fixes to be included in 3.7.5?
>>> 3.7.4. is off maint branch [as of a week ago]. So if you are seeing
>>> issues with it - its best to debug and figure out the cause.
>> This bug is indeed inside of superlu_dist, and we started having this issue
>> from PETSc-3.6.x. I think superlu_dist developers should have fixed this
>> bug. We forgot to update superlu_dist?? This is not a thing users could
>> debug and fix.
>> I have many people in INL suffering from this issue, and they have to stay
>> with PETSc-3.5.4 to use superlu_dist.
> To verify if the bug is fixed in latest superlu_dist - you can try
> [assuming you have git - either from petsc-3.7/maint/master]:
> --download-superlu_dist --download-superlu_dist-commit=origin/maint
> Satish
