[petsc-users] Using Petsc with Finite Elements Domain Decomposition
Thu Oct 6 10:45:39 CDT 2016
It is almost surely some subtle memory corruption somewhere use http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind to track it down.
> On Oct 6, 2016, at 4:22 AM, Ivano Barletta <ibarletta at inogs.it> wrote:
> Hello everyone
> Recently I resumed the task of nesting Petsc into
> this fem ocean model, for the solution of a linear system
> I followed your suggestions and "almost" everything works.
> The problem raised during a run with 4 CPUs, when i got this
> error
>    3:[3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>    3:[3]PETSC ERROR: Petsc has generated inconsistent data
>    3:[3]PETSC ERROR: Negative MPI source!
>    3:[3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>    3:[3]PETSC ERROR: Petsc Release Version 3.7.1, May, 15, 2016
>    3:[3]PETSC ERROR: /users/home/ib04116/shympi_last4/fem3d/shympi        ^A on a linux-gnu-intel named n243.cluster.net by ib04116 Thu Oct  6 10:37:01 2016
>    3:[3]PETSC ERROR: Configure options CFLAGS=-I/users/home/opt/netcdf/netcdf-4.2.1.1/include -I/users/home/opt/szip/szip-2.1/include -I/users/home/opt/hdf5/hdf5-1.8.10-patch1/include -I/usr/include -I/users/home/opt/netcdf/netcdf-4.3/include -I/users/home/opt/hdf5/hdf5-1.8.11/include FFLAGS=-xHost -no-prec-div -O3 -I/users/home/opt/netcdf/netcdf-4.2.1.1/include -I/users/home/opt/netcdf/netcdf-4.3/include LDFLAGS=-L/users/home/opt/netcdf/netcdf-4.2.1.1/lib -lnetcdff -L/users/home/opt/szip/szip-2.1/lib -L/users/home/opt/hdf5/hdf5-1.8.10-patch1/lib -L/users/home/opt/netcdf/netcdf-4.2.1.1/lib -L/usr/lib64/ -lz -lnetcdf -lnetcdf -lgpfs -L/users/home/opt/netcdf/netcdf-4.3/lib -L/users/home/opt/hdf5/hdf5-1.8.11/lib -L/users/home/opt/netcdf/netcdf-4.3/lib -lcurl --PETSC_ARCH=linux-gnu-intel --with-cc=mpiicc --with-fc=mpiifort --with-cxx=mpiicpc --with-mpiexec=mpirun --with-blas-lapack-dir=/users/home/opt/intel/composer_xe_2013/mkl --with-scalapack-lib="-L/users/home/opt/intel/composer_xe_2013/mkl//lib/intel64 -lmkl_scalapack_ilp64 -lmkl_blacs_intelmpi_ilp64" --with-scalapack-include=/users/home/opt/intel/composer_xe_2013/mkl/include --download-metis --download-parmetis --download-mumps --download-superlu
>    3:[3]PETSC ERROR: #1 MatStashScatterGetMesg_Ref() line 692 in /users/home/sco116/petsc/petsc-3.7.1/src/mat/utils/matstash.c
>    3:[3]PETSC ERROR: #2 MatStashScatterGetMesg_Private() line 663 in /users/home/sco116/petsc/petsc-3.7.1/src/mat/utils/matstash.c
>    3:[3]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 713 in /users/home/sco116/petsc/petsc-3.7.1/src/mat/impls/aij/mpi/mpiaij.c
>    3:[3]PETSC ERROR: #4 MatAssemblyEnd() line 5187 in /users/home/sco116/petsc/petsc-3.7.1/src/mat/interface/matrix.c
> The code is in fortran and the Petsc version is 3.7.1
> This error looks quite strange to me, because it doesn't happen always in the same
> situation. The model goes through several time steps, but this error is not
> raised always at the same time. It has happened at the fourth, for example, at
> the fifth time step. What is even more odd is that once the run of the model (720 time steps)
> was completed without any error.
> What I do to solve the linear system for each time step is the following:
> call petsc_solve( ..arguments..)
> subroutine petsc_solve(..args)
> call PetscInitialize(PETSC_NULL_CHARACTER)
> call MatCreate
> call KSPSolve(...)
> call XXXDestroy()
> call PetscFinalize
> end subroutine
> Do you think that calling PetscInitialize and PetscFinalize
> several times might cause problems? I guess Petsc use
> the same communicator of the model, which is MPI_COMM_WORLD
> It don't have hints to troubleshoot this, since is not a
> reproducible error and I don't know where to look to
> sort it out.
> Have you got any suggestion?
> Thanks in advance
> Ivano
> 2016-07-13 5:16 GMT+02:00 Barry Smith <bsmith at mcs.anl.gov>:
> > On Jul 12, 2016, at 4:13 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Jul 12, 2016 at 3:35 AM, Ivano Barletta <ibarletta at inogs.it> wrote:
> > Dear Petsc users
> > my aim is to parallelize the solution of a linear
> > system into a finite elements
> > ocean model.
> > The model has been almost entirely parallelized, with
> > a partitioning of the domain made element-wise through
> > the use of Zoltan libraries, so the subdomains
> > share the nodes lying on the edges.
> > The linear system includes node-to-node dependencies
> > so my guess is that I need to create an halo surrounding
> > each subdomain, to allow connections of edge nodes with
> > neighbour subdomains ones
> > Apart from that, my question is if Petsc accept a
> > previously made partitioning (maybe taking into account of halo)
> > using the data structures coming out of it
> > Has anybody of you ever faced a similar problem?
> > If all you want to do is construct a PETSc Mat and Vec for the linear system,
> > just give PETSc the non-overlapping partition to create those objects. You
> > can input values on off-process partitions automatically using MatSetValues()
> > and VecSetValues().
>   Note that by just using the VecSetValues() and MatSetValues() PETSc will manage all the halo business needed by the linear algebra system solver automatically. You don't need to provide any halo information to PETSc. It is really straightforward.
>   Barry
> >   Thanks,
> >     Matt
> > Thanks in advance
> > Ivano
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
