[petsc-users] petsc init in class constructor
Stefano Zampini stefano.zampini at gmail.com
Thu Oct 6 03:44:38 CDT 2016
Sorry,
I realized I replied to Feng and not to the list. Below is my previous email.
Feng,
Your class is fine as long as the constructor of your solver is called AFTER MPI_Init, and the destructor BEFORE MPI_Finalize.
This means that you cannot have something like
int main (int argc, char**argv)
 MPI_Init();
 solverpetsc S(argc,argv);
 MPI_Finalize();
 return 0;
as the destructor for S will be called after MPI_Finalize().
If you call PetscInitialize before MPI_Init, PETSc will call it for you. But then, it will also call MPI_Finalize during PetscFinalize().
so, the following code will abort at any_MPI_call()
 solverpetsc *S;
 S = new solverpetsc(argc,argv);
 <here you can use MPI>
 delete S;
 any_MPI_call();
 return 0;
On Oct 6, 2016, at 11:42 AM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
>> Long story short: I'd encourage you not to initialize PETSc in a constructor, unless you know exactly what you are doing and can control the possible side effects.
> completely agree on that.
