[petsc-users] large PetscCommDuplicate overhead
Wed Oct 5 14:44:16 CDT 2016
On Wed, Oct 5, 2016 at 2:30 PM, Matthew Overholt <overholt at capesim.com>
wrote:
> Hi Petsc-Users,
> I am trying to understand an issue where PetscCommDuplicate() calls are
> taking an increasing percentage of time as I run a fixed-sized problem on
> more processes.
> I am using the FEM to solve the steady-state heat transfer equation (K.x =
> q) using a PC direct solver, like MUMPS.
> I am running on the NERSC Cray X30, which has two Xeon's per node with 12
> cores each, and profiling the code using CrayPat sampling.
> On a typical problem (1E+6 finite elements), running on a single node:
> -for 2 cores (1 on each Xeon), about 1% of time is PetscCommDuplicate (on
> process 1, but on the root it is less), and (for reference) 9% of total
> time is for MUMPS.
> -for 8 cores (4 on each Xeon), over 6% of time is PetscCommDuplicate (on
> every process except the root, where it is <1%), and 9-10% of total time is
> for MUMPS.
> What is the large PetscCommDuplicate time connected to, an increasing
> number of messages (tags)?  Would using fewer MatSetValues() and
> VecSetValues() calls (with longer message lengths) alleviate this?
1) I am skeptical of the result. Can you do a run with direct measurement
rather than sampling?
2) Can we see the output of -log_view ?
3) Are you sure you configured with --with-debugging=0 ?
4) If this result is true, it could be coming from bad behavior with
PetscSpinlock on this machine. We need to see configure.log
     Matt
> For reference, the PETSc calling sequence in the code is as follows.
>     // Create the solution and RHS vectors
>     ierr = VecCreate(petscData->mpicomm,&mesh->hpx);
>    ierr = PetscObjectSetName((PetscObject) mesh->hpx, "Solution");
>     ierr = VecSetSizes(mesh->hpx,mesh->lxN,mesh->neqns); // size = # of
> equations; distribution to match mesh
>     ierr = VecSetFromOptions(mesh->hpx);    // allow run time options
>     ierr = VecDuplicate(mesh->hpx,&q);      // create the RHS vector
>     // Create the stiffnexx matrix
>     ierr = MatCreate(petscData->mpicomm,&K);
>     ierr = MatSetSizes(K,mesh->lxN,mesh->lxN,mesh->neqns,mesh->neqns);
>     ierr = MatSetType(K,MATAIJ);  // default sparse type
>     // Do preallocation
>     ierr = MatMPIAIJSetPreallocation(K,d_nz,NULL,o_nz,NULL);
>     ierr = MatSeqAIJSetPreallocation(K,d_nz,NULL);
>     ierr = MatSetOption(K,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);
>     ierr = MatSetUp(K);
>     // Create and set up the KSP context as a PreConditioner Only (Direct)
> Solution
>     ierr = KSPCreate(petscData->mpicomm,&ksp);
>     ierr = KSPSetOperators(ksp,K,K);
>     ierr = KSPSetType(ksp,KSPPREONLY);
>     // Set the temperature vector
>     ierr = VecSet(mesh->hpx,mesh->Tmin);
>     // Set the default PC method as MUMPS
>     ierr = KSPGetPC(ksp,&pc);     // extract the preconditioner
>     ierr = PCSetType(pc,PCLU);    // set pc options
>     ierr = PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS);
>     ierr = KSPSetFromOptions(ksp);
>     // Set the values for the K matrix and q vector
>         // which involves a lot of these calls
>         ierr = MatSetValues(K,mrows,idxm,ncols,idxn,pKe,ADD_VALUES);
> // 1 call per matrix row (equation)
>         ierr = VecSetValues(q,nqe,ixn,pqe,ADD_VALUES);      // 1 call per
> element
>     ierr = VecAssemblyBegin(q);
>     ierr = MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);
>     ierr = VecAssemblyEnd(q);
>     ierr = MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);
>     // Solve //////////////////////////////////////
>     ierr = KSPSolve(ksp,q,mesh->hpx);
> *Note that the code evenly divides the finite elements over the total
> number of processors, and I am using ghosting of the FE vertices vector to
> handle the vertices that are needed on more than 1 process.
> Thanks in advance for your help,
> Matt Overholt
> CapeSym, Inc.
> <https://www.avast.com/en-us/lp-safe-emailing-2270-b?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=oa-2270-b> Virus-free.
> www.avast.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161005/107d411b/attachment.html>
