[petsc-users] error with libpetsc.so.3.7.4 during make test
    Satish Balay
    balay at mcs.anl.gov
    Mon Nov 28 00:15:06 CST 2016
On windows - you need to setup PATH to the location of dll. i.e
PATH=$PATH:/home/Elaine/petsc-3.7.4/arch-mswin-c-debug/lib make PETSC_DIR=/home/Elaine/petsc-3.7.4 PETSC_ARCH=arch-mswin-c-debug test
However fortran examples will fail with a dll build. In this case -
its best to rebuild using configure option --with-shared-libraries=0
Satish
On Sun, 27 Nov 2016, Elaine Tang wrote:
> I finish configured and make petsc on Cygwin.
> Here are the last few lines of the make output:
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/impls/owarmijo/owarmijo.o
>           CC arch-mswin-c-debug/obj/src/tao/constrained/impls/ipm/ipm.o
>           CC arch-mswin-c-debug/obj/src/tao/linesearch/impls/unit/unit.o
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/impls/gpcglinesearch/gpcglinesearch.o
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/interface/dlregis_taolinesearch.o
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/interface/ftn-auto/taolinesearchf.o
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/interface/taolinesearch.o
>           CC
> arch-mswin-c-debug/obj/src/tao/linesearch/interface/ftn-custom/ztaolinesearchf.o
>           CC
> arch-mswin-c-debug/obj/src/tao/leastsquares/impls/pounders/gqt.o
>           CC
> arch-mswin-c-debug/obj/src/tao/leastsquares/impls/pounders/pounders.o
>      CLINKER
> /home/Elaine/petsc-3.7.4/arch-mswin-c-debug/lib/libpetsc.so.3.7.4
> make[2]: Leaving directory '/home/Elaine/petsc-3.7.4'
> make[1]: Leaving directory '/home/Elaine/petsc-3.7.4'
> Now to check if the libraries are working do:
> Then I did:
> $ make PETSC_DIR=/home/Elaine/petsc-3.7.4 PETSC_ARCH=arch-mswin-c-debug test
> Output is:
> Running test examples to verify correct installation
> Using PETSC_DIR=/home/Elaine/petsc-3.7.4 and PETSC_ARCH=arch-mswin-c-debug
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
> process
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> C:/cygwin64/home/Elaine/petsc-3.7.4/src/snes/examples/tutorials/ex19.exe:
> error while loading shared libraries: libpetsc.so.3.7.4: cannot open shared
> object file: No such file or directory
> Primary job  terminated normally, but 1 process returned
> a non-zero exit code.. Per user-direction, the job has been aborted.
> mpiexec detected that one or more processes exited with non-zero status,
> thus causing
> the job to be terminated. The first process to do so was:
>   Process name: [[46069,1],0]
>   Exit code:    127
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI
> processes
> Possible error running Fortran example src/snes/examples/tutorials/ex5f
> with 1 MPI process
> C:/cygwin64/home/Elaine/petsc-3.7.4/src/snes/examples/tutorials/ex5f.exe:
> thus causing
>   Process name: [[38897,1],0]
>   Exit code:    127
> Completed test examples
> Now to evaluate the computer systems you plan use - do:
> streams
> When I navigate to /home/Elaine/petsc-3.7.4/arch-mswin-c-debug/lib/ I did
> find libpetsc.so.3.7.4
> Why is make not able to locate it?
> Thanks!
> Elaine
