[petsc-users] Error with MatView on multiple processors
Fri May 27 20:43:49 CDT 2016
On Fri, May 27, 2016 at 8:38 PM, Paul Urbanczyk <gomer at stanford.edu> wrote:
> On 05/27/2016 05:44 PM, Matthew Knepley wrote:
> On Fri, May 27, 2016 at 6:34 PM, Paul Urbanczyk <gomer at stanford.edu>
> wrote:
>> Hello,
>> I'm having trouble with the MatView function drawing the matrix
>> structure(s) when I execute my code on multiple processors.
>> When I run on a single processor, the code runs fine, and the graphics
>> window displays cleanly.
> Lets start with an example. I do this
>   cd $PETSC_DIR/src/snes/examples/tutorials
>   make ex19
> Make sure it runs
>   ./ex19 -snes_monitor
> Make sure it runs in parallel (maybe you need
> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec)
>   mpiexec -n 2 ./ex19 -snes_monitor
> Make sure it can draw
>   mpiexec -n 2 ./ex19 -snes_monitor -mat_view draw -draw_pause 1
> This runs fine for me. Can you try it?
>   Thanks,
>      Matt
> Hello Matt,
> Yes, this example seems to run just fine. How should I proceed?
I am not sure what you are doing in your code. Can you try and change one
of these examples
to do something like what you do? SNEX ex19 seems like it does things
mostly the way you
describe.
  Matt
> -Paul
> When I run with multiple processors, I get error messages (see below).
>> The matrices are constructed with DMCreateMatrix(da, &A_matrix).
>> I then set the values with
>> MatSetValuesStencil(A_matrix,1,&row,2,col_A,value_A,INSERT_VALUES).
>> Finally, I call MatAssemblyBegin(A_matrix,MAT_FINAL_ASSEMBLY) and
>> MatAssemblyEnd(A_matrix,MAT_FINAL_ASSEMBLY).
>> I also test that the matrices are assembled with MatAssembled(A_matrix,
>> &is_assembled_bool), and it appears they are successfully assembled.
>> Any help/advice is greatly appreciated.
>> Thanks in advance!
>> -Paul Urbanczyk
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Wrong type of object: Parameter # 1
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.1, unknown
>> [0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by
>> gomer Fri May 27 16:29:01 2016
>> [0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
>> --with-fc=mpif90
>> [0]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
>> /home/gomer/local/petsc/src/vec/is/ao/interface/ao.c
>> [0]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
>> /home/gomer/local/petsc/src/dm/impls/da/fdda.c
>> [0]PETSC ERROR: #3 MatView() line 901 in
>> /home/gomer/local/petsc/src/mat/interface/matrix.c
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Invalid argument
>> [1]PETSC ERROR: Wrong type of object: Parameter # 1
>> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> [1]PETSC ERROR: Petsc Release Version 3.7.1, unknown
>> [1]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by
>> [1]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
>> --with-fc=mpif90
>> [1]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
>> [1]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
>> [1]PETSC ERROR: #3 MatView() line 901 in
>> --with-fc=mpif90
>> [1]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
>> [1]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
>> [1]PETSC ERROR: #6 MatView() line 901 in
>> --with-fc=mpif90
>> [0]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
>> [0]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
>> [0]PETSC ERROR: #6 MatView() line 901 in
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160527/c87be582/attachment-0001.html>
