[petsc-users] Error with MatView on multiple processors
Paul Urbanczyk
gomer at stanford.edu
Fri May 27 18:34:21 CDT 2016
Hello,
I'm having trouble with the MatView function drawing the matrix
structure(s) when I execute my code on multiple processors.
When I run on a single processor, the code runs fine, and the graphics
window displays cleanly.
When I run with multiple processors, I get error messages (see below).
The matrices are constructed with DMCreateMatrix(da, &A_matrix).
I then set the values with
MatSetValuesStencil(A_matrix,1,&row,2,col_A,value_A,INSERT_VALUES).
Finally, I call MatAssemblyBegin(A_matrix,MAT_FINAL_ASSEMBLY) and
MatAssemblyEnd(A_matrix,MAT_FINAL_ASSEMBLY).
I also test that the matrices are assembled with MatAssembled(A_matrix,
&is_assembled_bool), and it appears they are successfully assembled.
Any help/advice is greatly appreciated.
Thanks in advance!
-Paul Urbanczyk
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.1, unknown
[0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by
gomer Fri May 27 16:29:01 2016
[0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
--with-fc=mpif90
[0]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
/home/gomer/local/petsc/src/vec/is/ao/interface/ao.c
[0]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
/home/gomer/local/petsc/src/dm/impls/da/fdda.c
[0]PETSC ERROR: #3 MatView() line 901 in
/home/gomer/local/petsc/src/mat/interface/matrix.c
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Invalid argument
[1]PETSC ERROR: Wrong type of object: Parameter # 1
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
[1]PETSC ERROR: Petsc Release Version 3.7.1, unknown
[1]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by
[1]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
--with-fc=mpif90
[1]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
[1]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
[1]PETSC ERROR: #3 MatView() line 901 in
--with-fc=mpif90
[1]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
[1]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
[1]PETSC ERROR: #6 MatView() line 901 in
--with-fc=mpif90
[0]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
[0]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
[0]PETSC ERROR: #6 MatView() line 901 in
