[petsc-users] KSPSetUp with PETSc/MUMPS
Hong hzhang at mcs.anl.gov
Thu May 26 13:52:10 CDT 2016
I'll investigate this - had a day off since yesterday.
Hong
On Thu, May 26, 2016 at 12:04 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Hong needs to run with this matrix and add appropriate error checkers in
> the matrix routines to detect "incomplete" matrices and likely just error
> out.
>    Barry
> > On May 26, 2016, at 11:23 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Mat Object: 1 MPI processes
> >  type: mpiaij
> > row 0: (0, 0.)  (1, 0.486111)
> > row 1: (0, 0.486111)  (1, 0.)
> > row 2: (2, 0.)  (3, 0.486111)
> > row 3: (4, 0.486111)  (5, -0.486111)
> > row 4:
> > row 5:
> > The matrix created is funny (empty rows at the end) - so perhaps its
> > exposing bugs in Mat code? [is that a valid matrix for this code?]
> > ==21091== Use of uninitialised value of size 8
> > ==21091==    at 0x57CA16B: MatGetRowIJ_SeqAIJ_Inode_Symmetric
> (inode.c:101)
> > ==21091==    by 0x57CBA1C: MatGetRowIJ_SeqAIJ_Inode (inode.c:241)
> > ==21091==    by 0x537C0B5: MatGetRowIJ (matrix.c:7274)
> > ==21091==    by 0x53072FD: MatGetOrdering_ND (spnd.c:18)
> > ==21091==    by 0x530BC39: MatGetOrdering (sorder.c:260)
> > ==21091==    by 0x530A72D: MatGetOrdering (sorder.c:202)
> > ==21091==    by 0x5DDD764: PCSetUp_LU (lu.c:124)
> > ==21091==    by 0x5EBFE60: PCSetUp (precon.c:968)
> > ==21091==    by 0x5FDA1B3: KSPSetUp (itfunc.c:390)
> > ==21091==    by 0x601C17D: kspsetup_ (itfuncf.c:252)
> > ==21091==    by 0x4028B9: MAIN__ (ex1f.F90:104)
> > ==21091==    by 0x403535: main (ex1f.F90:185)
> > This goes away if  I add:
> >   call PCFactorSetMatOrderingType(pc,MATORDERINGNATURAL,ierr)
> > And then there is also:
> > ==21275== Invalid read of size 8
> > ==21275==    at 0x584DE93: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:4734)
> > ==21275==    by 0x58970A8: MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable
> (mpimatmatmult.c:198)
> > ==21275==    by 0x5894A54: MatMatMult_MPIAIJ_MPIAIJ (mpimatmatmult.c:34)
> > ==21275==    by 0x539664E: MatMatMult (matrix.c:9510)
> > ==21275==    by 0x53B3201: matmatmult_ (matrixf.c:1157)
> > ==21275==    by 0x402FC9: MAIN__ (ex1f.F90:149)
> > ==21275==    by 0x4035B9: main (ex1f.F90:186)
> > ==21275==  Address 0xa3d20f0 is 0 bytes after a block of size 48 alloc'd
> > ==21275==    at 0x4C2DF93: memalign (vg_replace_malloc.c:858)
> > ==21275==    by 0x4FDE05E: PetscMallocAlign (mal.c:28)
> > ==21275==    by 0x5240240: VecScatterCreate (vscat.c:1220)
> > ==21275==    by 0x5857708: MatSetUpMultiply_MPIAIJ (mmaij.c:116)
> > ==21275==    by 0x581C31E: MatAssemblyEnd_MPIAIJ (mpiaij.c:747)
> > ==21275==    by 0x53680F2: MatAssemblyEnd (matrix.c:5187)
> > ==21275==    by 0x53B24D2: matassemblyend_ (matrixf.c:926)
> > ==21275==    by 0x40262C: MAIN__ (ex1f.F90:60)
> > Satish
> > $ diff build_nullbasis_petsc_mumps.F90 ex1f.F90
> > 3,7c3
> > < #include <petsc/finclude/petscsys.h>
> > < #include "petsc/finclude/petscvec.h"
> > < #include "petsc/finclude/petscmat.h"
> > < #include "petsc/finclude/petscpc.h"
> > < #include "petsc/finclude/petscksp.h"
> >> #include "petsc/finclude/petsc.h"
> > 40,41c36,37
> > <    call PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat_c_bin.txt", 0,
> viewer, ierr)
> > <    call MatLoad(mat_c, viewer)
> FILE_MODE_READ, viewer, ierr)
> >>   call MatLoad(mat_c, viewer,ierr)
> > 75a72
> > 150c147
> > <    call MatConvert(x, MATMPIAIJ, MAT_REUSE_MATRIX, x, ierr)
> >>   call MatConvert(x, MATMPIAIJ, MAT_INPLACE_MATRIX, x, ierr)
> > On Thu, 26 May 2016, Matthew Knepley wrote:
> >> Usually this means you have an uninitialized variable that is causing
> you
> >> to overwrite memory. Fortran
> >> is so lax in checking this, its one reason to switch to C.
> >>  Thanks,
> >>    Matt
> >> On Thu, May 26, 2016 at 1:46 AM, Constantin Nguyen Van <
> >> constantin.nguyen.van at openmailbox.org> wrote:
> >>> Thanks for all your answers.
> >>> I'm sorry for the syntax mistake in MatLoad, it was done afterwards.
> >>> I recompile PETSC --with-debugging=yes and run my code again.
> >>> Now, I also have this strange behaviour. When I run the code without
> >>> valgrind and with one proc, I have this error message:
> >>> BEGIN PROC           0
> >>> ITERATION           1
> >>> ECHO 1
> >>> ECHO 2
> >>> INFOG(28):           2
> >>> BASIS OK           0
> >>> END PROC             0
> >>> BEGIN PROC           0
> >>> ITERATION           2
> >>> ECHO 1
> >>> ECHO 2
> >>> INFOG(28):           2
> >>> BASIS OK           0
> >>> END PROC             0
> >>> BEGIN PROC           0
> >>> ITERATION           3
> >>> ECHO 1
> >>> [0]PETSC ERROR:
> >>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> >>> probably memory access out of range
> >>> [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> >>> [0]PETSC ERROR: or see
> >>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> >>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS
> >>> X to find memory corruption errors
> >>> [0]PETSC ERROR: likely location of problem given in stack below
> >>> [0]PETSC ERROR: ---------------------  Stack Frames
> >>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> >>> available,
> >>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >>> [0]PETSC ERROR:       is given.
> >>> [0]PETSC ERROR: [0] MatGetRowIJ_SeqAIJ_Inode_Symmetric line 69
> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/impls/aij/seq/inode.c
> >>> [0]PETSC ERROR: [0] MatGetRowIJ_SeqAIJ_Inode line 235
> >>> [0]PETSC ERROR: [0] MatGetRowIJ line 7099
> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/interface/matrix.c
> >>> [0]PETSC ERROR: [0] MatGetOrdering_ND line 17
> >>> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/order/spnd.c
> >>> [0]PETSC ERROR: [0] MatGetOrdering line 185
> >>> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/order/sorder.c
> >>> [0]PETSC ERROR: [0] PCSetUp_LU line 99
> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/pc/impls/factor/lu/lu.c
> >>> [0]PETSC ERROR: [0] PCSetUp line 945
> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/pc/interface/precon.c
> >>> [0]PETSC ERROR: [0] KSPSetUp line 247
> /home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/ksp/interface/itfunc.c
> >>> But when I run it with valgrind, it does work well.
> >>> Le 2016-05-25 20:04, Barry Smith a écrit :
> >>>> First run with valgrind
> >>>> On May 25, 2016, at 2:35 AM, Constantin Nguyen Van
> >>>>> <constantin.nguyen.van at openmailbox.org> wrote:
> >>>>> Hi,
> >>>>> I'm a new user of PETSc and I try to use it with MUMPS
> >>>>> functionalities to compute a nullbasis.
> >>>>> I wrote a code where I compute 4 times the same nullbasis. It does
> >>>>> work well when I run it with several procs but with only one
> >>>>> processor I get an error on the 2nd iteration when KSPSetUp is
> >>>>> called. Furthermore when it is run with a debugger (
> >>>>> --with-debugging=yes), it works fine with one or several processors.
> >>>>> Have you got any idea about why it doesn't work with one processor
> >>>>> and no debugger?
> >>>>> Thanks.
> >>>>> Constantin.
> >>>>> PS: You can find the code and the files required to run it enclosed.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160526/ea0f58cb/attachment.html>
