[petsc-users] KSPSetUp with PETSc/MUMPS
Constantin Nguyen Van constantin.nguyen.van at openmailbox.org
Thu May 26 01:46:17 CDT 2016
Thanks for all your answers.
I'm sorry for the syntax mistake in MatLoad, it was done afterwards.
I recompile PETSC --with-debugging=yes and run my code again.
Now, I also have this strange behaviour. When I run the code without
valgrind and with one proc, I have this error message:
  BEGIN PROC           0
  ITERATION           1
  ECHO 1
  ECHO 2
  INFOG(28):           2
  BASIS OK           0
  END PROC             0
  BEGIN PROC           0
  ITERATION           2
  ECHO 1
  ECHO 2
  INFOG(28):           2
  BASIS OK           0
  END PROC             0
  BEGIN PROC           0
  ITERATION           3
  ECHO 1
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
X to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the
function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatGetRowIJ_SeqAIJ_Inode_Symmetric line 69
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/impls/aij/seq/inode.c
[0]PETSC ERROR: [0] MatGetRowIJ_SeqAIJ_Inode line 235
[0]PETSC ERROR: [0] MatGetRowIJ line 7099
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/interface/matrix.c
[0]PETSC ERROR: [0] MatGetOrdering_ND line 17
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/order/spnd.c
[0]PETSC ERROR: [0] MatGetOrdering line 185
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/mat/order/sorder.c
[0]PETSC ERROR: [0] PCSetUp_LU line 99
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/pc/impls/factor/lu/lu.c
[0]PETSC ERROR: [0] PCSetUp line 945
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: [0] KSPSetUp line 247
/home/j10077/librairie/petsc-mumps/petsc-3.6.4/src/ksp/ksp/interface/itfunc.c
But when I run it with valgrind, it does work well.
Le 2016-05-25 20:04, Barry Smith a écrit :
> First run with valgrind
>> On May 25, 2016, at 2:35 AM, Constantin Nguyen Van
>> <constantin.nguyen.van at openmailbox.org> wrote:
>> Hi,
>> I'm a new user of PETSc and I try to use it with MUMPS
>> functionalities to compute a nullbasis.
>> I wrote a code where I compute 4 times the same nullbasis. It does
>> work well when I run it with several procs but with only one
>> processor I get an error on the 2nd iteration when KSPSetUp is
>> called. Furthermore when it is run with a debugger (
>> --with-debugging=yes), it works fine with one or several processors.
>> Have you got any idea about why it doesn't work with one processor
>> and no debugger?
>> Thanks.
>> Constantin.
>> PS: You can find the code and the files required to run it enclosed.
