[petsc-users] GAMG Indefinite
Sanjay Govindjee s_g at berkeley.edu
Sun May 22 16:38:48 CDT 2016
Mark,
   Can you give me the full option line that you want me to use?  I
currently have:
-ksp_type cg -ksp_monitor -ksp_chebyshev_esteig_random -log_view
-pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -options_left
-sanjay
On 5/22/16 2:29 PM, Mark Adams wrote:
> Humm, maybe we have version mixup:
> src/ksp/ksp/impls/cheby/cheby.c:    ierr =
> PetscOptionsBool("-ksp_chebyshev_esteig_random","Use random right hand
> side for
> estimate","KSPChebyshevEstEigSetUseRandom",cheb->userandom,&cheb->userandom
> Also, you should use CG. These other options are the defaults but CG
> is not:
> -mg_levels_esteig_ksp_type cg
> -mg_levels_esteig_ksp_max_it 10
> -mg_levels_ksp_chebyshev_esteig 0,0.05,0,1.05
> Anyway. you can also run with -info, which will be very noisy, but
> just grep for GAMG and send me that.
> Mark
> On Sat, May 21, 2016 at 6:03 PM, Sanjay Govindjee <s_g at berkeley.edu
> <mailto:s_g at berkeley.edu>> wrote:
>     Mark,
>       I added the option you mentioned but it seems not to use it;
>     -options_left reports:
>     #PETSc Option Table entries:
>     -ksp_monitor
>     -ksp_type cg
>     -log_view
>     -options_left
>     -pc_gamg_type agg
>     -pc_type gamg
>     #End of PETSc Option Table entries
>     There is one unused database option. It is:
>     Option left: name:-ksp_chebyshev_esteig_random (no value)
>     On 5/21/16 12:36 PM, Mark Adams wrote:
>>     Barry, this is probably the Chebyshev problem.
>>     Sanjay, this is fixed but has not yet been moved to the master
>>     branch.  You can fix this now with with
>>     -ksp_chebyshev_esteig_random. This should recover v3.5 semantics.
>>     Mark
>>     On Thu, May 19, 2016 at 2:42 PM, Barry Smith <bsmith at mcs.anl.gov
>>     <mailto:bsmith at mcs.anl.gov>> wrote:
>>            We see this occasionally, there is nothing in the
>>         definition of GAMG that guarantees a positive definite
>>         preconditioner even if the operator was positive definite so
>>         we don't think this is a bug in the code. We've found using a
>>         slightly stronger smoother, like one more smoothing step
>>         seems to remove the problem.
>>            Barry
>>         > On May 19, 2016, at 1:07 PM, Sanjay Govindjee
>>         <s_g at berkeley.edu <mailto:s_g at berkeley.edu>> wrote:
>>         > I am trying to solve a very ordinary nonlinear elasticity
>>         problem
>>         > using -ksp_type cg -pc_type gamg in PETSc 3.7.0, which
>>         worked fine
>>         > in PETSc 3.5.3.
>>         > The problem I am seeing is on my first Newton iteration,
>>         the Ax=b
>>         > solve returns with and Indefinite Preconditioner error
>>         (KSPGetConvergedReason == -8):
>>         > (log_view.txt output also attached)
>>         >   0 KSP Residual norm 8.411630828687e-02
>>         >   1 KSP Residual norm 2.852209578900e-02
>>         >   NO CONVERGENCE REASON: Indefinite Preconditioner
>>         > On the next and subsequent Newton iterations, I see
>>         perfectly normal
>>         > behavior and the problem converges quadratically.  The
>>         results look fine.
>>         > I tried the same problem with -pc_type jacobi as well as
>>         super-lu, and mumps
>>         > and they all work without complaint.
>>         > My run line for GAMG is:
>>         > -ksp_type cg -ksp_monitor -log_view -pc_type gamg
>>         > The code flow looks like:
>>         > ! If no matrix allocation yet
>>         > if(Kmat.eq.0) then
>>         >   call MatCreate(PETSC_COMM_WORLD,Kmat,ierr)
>>         >   call
>>         MatSetSizes(Kmat,numpeq,numpeq,PETSC_DETERMINE,PETSC_DETERMINE,ierr)
>>         >   call MatSetBlockSize(Kmat,nsbk,ierr)
>>         >   call MatSetFromOptions(Kmat, ierr)
>>         >   call MatSetType(Kmat,MATAIJ,ierr)
>>         >   call
>>         MatMPIAIJSetPreallocation(Kmat,PETSC_NULL_INTEGER,mr(np(246)),PETSC_NULL_INTEGER,mr(np(247)),ierr)
>>         >   call
>>         MatSeqAIJSetPreallocation(Kmat,PETSC_NULL_INTEGER,mr(np(246)),ierr)
>>         > endif
>>         > call MatZeroEntries(Kmat,ierr)
>>         > ! Code to set values in matrix
>>         > call MatAssemblyBegin(Kmat, MAT_FINAL_ASSEMBLY, ierr)
>>         > call MatAssemblyEnd(Kmat, MAT_FINAL_ASSEMBLY, ierr)
>>         > call
>>         MatSetOption(Kmat,MAT_NEW_NONZERO_LOCATIONS,PETSC_TRUE,ierr)
>>         > ! If no rhs allocation yet
>>         > if(rhs.eq.0) then
>>         >   call VecCreate (PETSC_COMM_WORLD, rhs, ierr)
>>         >   call VecSetSizes      (rhs, numpeq, PETSC_DECIDE, ierr)
>>         >   call VecSetFromOptions(rhs, ierr)
>>         > endif
>>         > ! Code to set values in RHS
>>         > call VecAssemblyBegin(rhs, ierr)
>>         > call VecAssemblyEnd(rhs, ierr)
>>         > if(kspsol_exists) then
>>         >   call KSPDestroy(kspsol,ierr)
>>         > endif
>>         > call KSPCreate(PETSC_COMM_WORLD, kspsol   ,ierr)
>>         > call KSPSetOperators(kspsol, Kmat, Kmat, ierr)
>>         > call KSPSetFromOptions(kspsol,ierr)
>>         > call KSPGetPC(kspsol, pc , ierr)
>>         > call PCSetCoordinates(pc,ndm,numpn,hr(np(43)),ierr)
>>         > call KSPSolve(kspsol, rhs, sol, ierr)
>>         > call KSPGetConvergedReason(kspsol,reason,ierr)
>>         > ! update solution, go back to the top
>>         > reason is coming back as -8 on my first Ax=b solve and 2 or
>>         3 after that
>>         > (with gamg).  With the other solvers it is coming back as 2
>>         or 3 for
>>         > iterative options and 4 if I use one of the direct solvers.
>>         > Any ideas on what is causing the Indefinite PC on the first
>>         iteration with GAMG?
>>         > Thanks in advance,
>>         > -sanjay
>>         > Sanjay Govindjee, PhD, PE
>>         > Professor of Civil Engineering
>>         > 779 Davis Hall
>>         > University of California
>>         > Berkeley, CA 94720-1710
>>         > Voice: +1 510 642 6060 <tel:%2B1%20510%20642%206060>
>>         > FAX: +1 510 643 5264 <tel:%2B1%20510%20643%205264>
>>         > http://www.ce.berkeley.edu/~sanjay
>>         <http://www.ce.berkeley.edu/%7Esanjay>
>>         > Books:
>>         > Engineering Mechanics of Deformable
>>         > Solids: A Presentation with Exercises
>>         http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>>         > http://ukcatalogue.oup.com/product/9780199651641.do
>>         > http://amzn.com/0199651647
>>         > Engineering Mechanics 3 (Dynamics) 2nd Edition
>>         > http://www.springer.com/978-3-642-53711-0
>>         > http://amzn.com/3642537111
>>         > Engineering Mechanics 3, Supplementary Problems: Dynamics
>>         > http://www.amzn.com/B00SOXN8JU
>>         > <log_view.txt>
>     779 Davis Hall
>     Voice:+1 510 642 6060 <tel:%2B1%20510%20642%206060>
>     FAX:+1 510 643 5264 <tel:%2B1%20510%20643%205264>
>     Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160522/11c3b6e4/attachment-0001.html>
