[petsc-users] GAMG Indefinite
Sanjay Govindjee s_g at berkeley.edu
Sat May 21 17:03:16 CDT 2016
Mark,
   I added the option you mentioned but it seems not to use it;
-options_left reports:
#PETSc Option Table entries:
-ksp_chebyshev_esteig_random
-ksp_monitor
-ksp_type cg
-log_view
-options_left
-pc_gamg_agg_nsmooths 1
-pc_gamg_type agg
-pc_type gamg
#End of PETSc Option Table entries
There is one unused database option. It is:
Option left: name:-ksp_chebyshev_esteig_random (no value)
On 5/21/16 12:36 PM, Mark Adams wrote:
> Barry, this is probably the Chebyshev problem.
> Sanjay, this is fixed but has not yet been moved to the master
> branch.  You can fix this now with with -ksp_chebyshev_esteig_random.
> This should recover v3.5 semantics.
> Mark
> On Thu, May 19, 2016 at 2:42 PM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>        We see this occasionally, there is nothing in the definition of
>     GAMG that guarantees a positive definite preconditioner even if
>     the operator was positive definite so we don't think this is a bug
>     in the code. We've found using a slightly stronger smoother, like
>     one more smoothing step seems to remove the problem.
>        Barry
>     > On May 19, 2016, at 1:07 PM, Sanjay Govindjee <s_g at berkeley.edu
>     <mailto:s_g at berkeley.edu>> wrote:
>     > I am trying to solve a very ordinary nonlinear elasticity problem
>     > using -ksp_type cg -pc_type gamg in PETSc 3.7.0, which worked fine
>     > in PETSc 3.5.3.
>     > The problem I am seeing is on my first Newton iteration, the Ax=b
>     > solve returns with and Indefinite Preconditioner error
>     (KSPGetConvergedReason == -8):
>     > (log_view.txt output also attached)
>     >   0 KSP Residual norm 8.411630828687e-02
>     >   1 KSP Residual norm 2.852209578900e-02
>     >   NO CONVERGENCE REASON:  Indefinite Preconditioner
>     > On the next and subsequent Newton iterations, I see perfectly normal
>     > behavior and the problem converges quadratically.  The results
>     look fine.
>     > I tried the same problem with -pc_type jacobi as well as
>     super-lu, and mumps
>     > and they all work without complaint.
>     > My run line for GAMG is:
>     > -ksp_type cg -ksp_monitor -log_view -pc_type gamg -pc_gamg_type
>     agg -pc_gamg_agg_nsmooths 1 -options_left
>     > The code flow looks like:
>     > ! If no matrix allocation yet
>     > if(Kmat.eq.0) then
>     >   call MatCreate(PETSC_COMM_WORLD,Kmat,ierr)
>     >   call
>     MatSetSizes(Kmat,numpeq,numpeq,PETSC_DETERMINE,PETSC_DETERMINE,ierr)
>     >   call MatSetBlockSize(Kmat,nsbk,ierr)
>     >   call MatSetFromOptions(Kmat, ierr)
>     >   call MatSetType(Kmat,MATAIJ,ierr)
>     >   call
>     MatMPIAIJSetPreallocation(Kmat,PETSC_NULL_INTEGER,mr(np(246)),PETSC_NULL_INTEGER,mr(np(247)),ierr)
>     >   call
>     MatSeqAIJSetPreallocation(Kmat,PETSC_NULL_INTEGER,mr(np(246)),ierr)
>     > endif
>     > call MatZeroEntries(Kmat,ierr)
>     > ! Code to set values in matrix
>     > call MatAssemblyBegin(Kmat, MAT_FINAL_ASSEMBLY, ierr)
>     > call MatAssemblyEnd(Kmat, MAT_FINAL_ASSEMBLY, ierr)
>     > call MatSetOption(Kmat,MAT_NEW_NONZERO_LOCATIONS,PETSC_TRUE,ierr)
>     > ! If no rhs allocation yet
>     > if(rhs.eq.0) then
>     >   call VecCreate        (PETSC_COMM_WORLD, rhs, ierr)
>     >   call VecSetSizes      (rhs, numpeq, PETSC_DECIDE, ierr)
>     >   call VecSetFromOptions(rhs, ierr)
>     > endif
>     > ! Code to set values in RHS
>     > call VecAssemblyBegin(rhs, ierr)
>     > call VecAssemblyEnd(rhs, ierr)
>     > if(kspsol_exists) then
>     >   call KSPDestroy(kspsol,ierr)
>     > endif
>     > call KSPCreate(PETSC_COMM_WORLD, kspsol   ,ierr)
>     > call KSPSetOperators(kspsol, Kmat, Kmat, ierr)
>     > call KSPSetFromOptions(kspsol,ierr)
>     > call KSPGetPC(kspsol, pc ,      ierr)
>     > call PCSetCoordinates(pc,ndm,numpn,hr(np(43)),ierr)
>     > call KSPSolve(kspsol, rhs, sol, ierr)
>     > call KSPGetConvergedReason(kspsol,reason,ierr)
>     > ! update solution, go back to the top
>     > reason is coming back as -8 on my first Ax=b solve and 2 or 3
>     after that
>     > (with gamg).  With the other solvers it is coming back as 2 or 3 for
>     > iterative options and 4 if I use one of the direct solvers.
>     > Any ideas on what is causing the Indefinite PC on the first
>     iteration with GAMG?
>     > Thanks in advance,
>     > -sanjay
>     > Sanjay Govindjee, PhD, PE
>     > Professor of Civil Engineering
>     > 779 Davis Hall
>     > University of California
>     > Berkeley, CA 94720-1710
>     > Voice: +1 510 642 6060 <tel:%2B1%20510%20642%206060>
>     > FAX: +1 510 643 5264 <tel:%2B1%20510%20643%205264>
>     > s_g at berkeley.edu <mailto:s_g at berkeley.edu>
>     > http://www.ce.berkeley.edu/~sanjay
>     <http://www.ce.berkeley.edu/%7Esanjay>
>     > Books:
>     > Engineering Mechanics of Deformable
>     > Solids: A Presentation with Exercises
>     http://www.oup.com/us/catalog/general/subject/Physics/MaterialsScience/?view=usa&ci=9780199651641
>     > http://ukcatalogue.oup.com/product/9780199651641.do
>     > http://amzn.com/0199651647
>     > Engineering Mechanics 3 (Dynamics) 2nd Edition
>     > http://www.springer.com/978-3-642-53711-0
>     > http://amzn.com/3642537111
>     > Engineering Mechanics 3, Supplementary Problems: Dynamics
>     > http://www.amzn.com/B00SOXN8JU
>     > <log_view.txt>
779 Davis Hall
s_g at berkeley.edu
Books:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160521/0162dcf2/attachment-0001.html>
