[petsc-users] SLEPc spectrum slicing
    Jeff Steward
    jeffsteward at gmail.com
    Thu May 19 18:24:14 CDT 2016
Hi Jose,
Follow up question: is it possible to call EPSKrylovSchurSetSubintervals
from fortran? I don't see it in
src/eps/impls/krylov/krylovschur/ftn-auto/krylovschurf.c.
Best wishes,
Jeff
On Thu, May 19, 2016 at 2:44 PM, Jeff Steward <jeffsteward at gmail.com> wrote:
> Thank you very much for your quick response Jose. I really appreciate it.
> Your point about load balancing even with the same number of pairs in the
> interval is well taken.
> For now I can provide hints with EPSKrylovSchurSetSubintervals and that
> should work fine. However, my problem is reaching the upper limits of
> memory with plans to increase the size, so I'd like to work on an approach
> to spectrum slicing with iterative/shell methods for the long run.
> The idea for spectrum slicing as I discussed in my previous message is
> based on the paper of Aktulga et al (2014):
> https://math.berkeley.edu/~linlin/publications/ParallelEig.pdf
> They address the issues involved with computing the (very expensive)
> matrix inertia. These experiments use PARPACK and FEAST to do a parallel
> spectrum slicing method. Of course PARPACK and FEAST have their own issues,
> and SLEPc is much easier to use and more flexible, extensible, etc. I think
> the MSIL approach they outline might be beneficial for my relatively large
> eigenproblem where I need many eigenpairs.
> Computing the matrix inertia for such an approach is likely to be the
> bottleneck at least in terms of memory. How far do you think the incomplete
> Cholesky with MUMPS would scale?
> I will send a separate e-mail to slepc-maint regarding my problem.
> Thank you again!
> Best wishes,
> Jeff
> On Thu, May 19, 2016 at 2:19 PM, Jose E. Roman <jroman at dsic.upv.es> wrote:
>> > El 19 may 2016, a las 22:28, Jeff Steward <jeffsteward at gmail.com>
>> escribió:
>> > I have some questions regarding spectrum slicing in SLEPc, especially
>> in the new version 3.7, as I see a line in the Change Notes that I don't
>> quite understand ("in spectrum slicing in multi-communicator mode now it is
>> possible to update the problem matrices directly on the sub-communicators".)
>> This is intended for applications that require solving a sequence of
>> eigenproblems, where the problem matrices in a given problem are a
>> modification of the previous ones. Instead of updating the matrices in the
>> parent communicator it is now possible to do the update in the partitioned
>> communicators. This avoids lots of communication required for moving data
>> to/from the parent communicator. This is certainly an "advanced feature".
>> > 1) In light of this statement, how should I divide my Mat to best work
>> with eps_krylovschur_partitions? Let's say I have 384 processors and
>> eps_krylovschur_partitions=48, so there will be 8 processors in each group.
>> Should I distribute the matrix over all 384 processors (so let's say this
>> gives 32 rows per processor) and have the entire communicator call EPS
>> solve, or should I (can I?) distribute the matrix over each of the 8 groups
>> (giving say 1536 rows per processor) and have the 48 subcommunicators call
>> EPSSolve? Am I correct in thinking that distributing over all 384
>> processors requires collecting and duplicating the matrix to the 48
>> different groups?
>> The idea is that you create the matrix in the initial communicator
>> (typically PETSC_COMM_WORLD) and then EPS will automatically create the
>> partitioned sub-communicators and replicate the matrices via
>> MatCreateRedundantMatrix(). You have to choose the number of partitions and
>> the number of processes in the original communicator that are best suited
>> for you application. If your matrix is relatively small but you need to
>> compute many eigenvalues, then you can consider setting as many partitions
>> as processes in the original communicator (hence the size of each partition
>> is 1). But it will be necessary to communicate a lot for setting up data in
>> the sub-communicators. The main point of sub-communicators is to workaround
>> the limited scalability of parallel direct linear solvers (e.g. MUMPS) when
>> one wants to use may processes.
>> > 2) If I'm understanding it correctly, the approach for Krylov-Schur
>> spectrum slicing described in the manual for SLEPc seems like a wasteful
>> default method. From what I gather, regions are divided by equal distance,
>> and different regions are bound to end up with different (and potentially
>> vastly different) numbers of eigenpairs. I understand the user can provide
>> their own region intervals, but wouldn't it be better for SLEPc to first
>> compute the matrix inertias at some given first guess regions, interpolate,
>> then fix the spectra endpoints so they contain approximately the same
>> number in each region? An option for logarithmically spaced points rather
>> than linearly spaced points would be helpful as well, as for the problem I
>> am looking at the spectrum decays in this way (few large eigenvalues with
>> an exponential decay down to many smaller eigenvalues). I require
>> eigenpairs with eigenvalues that vary by several orders of magnitude (1e-3
>> to 1e3), so the linear equidistant strategy is hopeless.
>> If you have an a priori knowledge of eigenvalue distribution then you can
>> use EPSKrylovSchurSetSubintervals() to give hints. We do not compute
>> inertia to get a rough estimation of the distribution because in the
>> general case computing inertia is very costly (it requires a factorization
>> in our implementation). The main intention of
>> EPSKrylovSchurSetSubintervals() is also the case where a sequence of
>> eigenproblems must be solved, so the solution of one problem provides an
>> estimation of eigenvalue distribution for the next problem.
>> Anyway, giving subintervals that roughly contain the same number of
>> eigenvalues does not guarantee that the workload will be balanced, since
>> convergence may be quite different from one subinterval to the other.
>> > 3) The example given for spectrum slicing in the user manual is
>> >  mpiexec -n 20 ./ex25 -eps_interval 0.4,0.8 -eps_krylovschur_partitions
>> 4
>> >                   -st_type sinvert -st_ksp_type preonly -st_pc_type
>> cholesky
>> >                   -st_pc_factor_mat_solver_package mumps
>> -mat_mumps_icntl_13 1
>> > which requires a direct solver. If I can compute the matrix inertias
>> myself and come up with spectral regions and subcommunicators as described
>> above, is there a way to efficiently use SLEPc with an iterative solver?
>> How about with a matrix shell? (I'm getting greedy now ^_^).
>> I don't know how you can possibly compute the "exact" inertia cheaply. In
>> that case yes, it would be worth using a shell matrix but the solver is
>> probably not prepared for this case. If you want us to have a look at this
>> possibility, send more details to slepc-maint.
>> Jose
>> > I would really appreciate any help on these questions. Thank you for
>> your time.
>> > Best wishes,
>> > Jeff
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160519/ba68e317/attachment.html>
