[petsc-users] User defined solver for PCMG
Jed Brown
jed at jedbrown.org
Tue May 17 13:26:44 CDT 2016
"Pratapa, Phanisri P" <ppratapa at gatech.edu> writes:
> What I mean is that: I want to implement multigrid preconditioning on
> a new Krylov method that is not currently in PETSc.
Sure, implement it as a KSP. It's not difficult.
> For this, I was hoping that I could replace the KSPFGMRES smoother
> (default)
I don't understand this statement. FGMRES is not the default, nor is it
typically used as a smoother. Do you want to change the smoother
(Chebyshev/SOR by default) or the Krylov accelerator?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160517/dbba21fe/attachment.pgp>
