[petsc-users] User defined solver for PCMG
Tue May 17 12:28:31 CDT 2016
On Tue, May 17, 2016 at 12:21 PM, Pratapa, Phanisri P <ppratapa at gatech.edu>
wrote:
> Hi,
> I am trying to find out if one can use a user defined linear solver
> function in PCMG (instead of the default GMRES). According to the petsc
> manual, I can change the solver/smoother through the KSP context and the
> available solvers, but I am interested in using my own function (solver).
> You can do this the Right Way:
  1) Implement your solver as a PETSc KSP (see any of the implementations,
like KSPCG)
  2) Then just use -pc_mg_levels_ksp_type mysolver
or the Hard Way
  1) Pull out each level KSP (
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCMGGetSmoother.html
  2) Set the type to KSPREPONLY
  3) Set the preconditioner to PCSHELL
  4) Set your solver to the apply function for the PCSHELL
    Matt
> Thank you,
> Regards,
> Pradeep
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160517/11b85cc1/attachment.html>
