[petsc-users] accessing DMDA Vec ghost values
    Matthew Knepley
    knepley at gmail.com
    Thu May 12 10:55:53 CDT 2016
On Thu, May 12, 2016 at 10:50 AM, Sean Dettrick <
sdettrick at trialphaenergy.com> wrote:
> From: <petsc-users-bounces at mcs.anl.gov> on behalf of Dave May <
> dave.mayhem23 at gmail.com>
> Date: Thursday, May 12, 2016 at 2:48 AM
> To: Sean Dettrick <sdettrick at trialphaenergy.com>
> Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] accessing DMDA Vec ghost values
> On 12 May 2016 at 10:42, Sean Dettrick <sdettrick at trialphaenergy.com>
> wrote:
>> Hi,
>> When discussing DMDAVecGetArrayDOF etc in section 2.4.4,  the PETSc 3.7
>> manual says "The array is accessed using the usual global indexing on
>> the entire grid, but the user may only refer to the local and ghost
>> entries of this array as all other entries are undefined”.
>> OK so far.  But how to access the ghost entries?
>> With a 2D DMDA, I can do this OK:
>>         PetscInt    xs,xm,ys,ym;
>>         ierr=DMDAGetCorners(da,&xs,&ys,0,&xm,&ym,0);CHKERRQ(ierr);
>>         PetscScalar ***es;
>>         ierr=DMDAVecGetArrayDOF(da,Es,&es);CHKERRQ(ierr);
>>         for (int j=ys; j < ys+ym; j++) {
>>             for (int i=xs; i < xs+xm;i++) {
>> es[j][i][0]=1.;
>>                 es[j][i][1]=1.;
>>         ierr=DMDAVecRestoreArrayDOF(da,Es,&es);CHKERRQ(ierr);
>> But if I replace DMDAGetCorners with DMDAGetGhostCorners, then the code
>> crashes with a seg fault, presumably due to out of bounds memory access.
>> Is that supposed to happen?
> If you created the vector Es using
> the function DM{Get,Create}GlobalVector(), then the answer is yes.
>> What’s the remedy?
> If you want to access the ghost entries, you need to create the vector
> using the function DM{Get,Create}LocalVector().
> Thanks!  Somehow I missed DM{Get,Create}LocalVector().  BTW what is the
> difference between the Get and Create versions?  It is not obvious from the
> documentation.
Create gives back a vector that you own and need to VecDestroy(). Get gives
back a vector we own and you need to call Restore.
> Also, can you explain the difference between DMDAVecGetArrayDOF and
> DMDAVecGetArrayDOFRead?
One allows writing into the storage, whereas the other does not.
  Matt
> Thanks again,
> Sean
> Thanks,
>   Dave
>> Thanks very much!
>> Sean Dettrick
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160512/020a8dd3/attachment-0001.html>
