[petsc-users] petsc and slepc incompatibility
Dominic Steinitz dominic at steinitz.org
Sun May 8 16:17:27 CDT 2016
Ah ok - thanks - there isn't an actual tag marked V3.7 which confused
me. I won't be able to do much now until next weekend. Hopefully by then
there will be a release (and a tag :-)).
On 08/05/2016 15:30, Hong wrote:
> Dominic :
>     Hi Hong,
>     I too am having compatibility issues. I looked at the git repos.
>           v3.7                       PETSc 3.7
>           v3.6.4                    PETSc 3.6.4
>           v3.6.3                    PETSc 3.6.3
>           v3.6.2                    PETSc 3.6.2
>           v3.6.1                    PETSc 3.6.1
>     and
>           v3.6.3                    SLEPc 3.6.3
>           v3.6.2                    SLEPc 3.6.2
>           v3.6.1                    SLEPc 3.6.1
>     If I just checkout master on both repos, won't I get PETSc 3.7 and
>     SLEPc 3.6.3?
> If you  checkout master on both repos, you get PETSc 3.7 and SLEPc 3.7.
> I did it few days ago, works well. Jose will release SLEPc 3.7 soon.
> Hong
>     BTW I checked https://listas.upv.es/pipermail/slepc-announce/ for
>     announcements on new versions but nothing has been posted since
>     June 2015.
>         Marco:
>         You may use petsc-master and slepc-master.
>         Hong
>         Dear All,
>         >   first, let me congratulate and thank the PETSc team and all
>         > contributors for release 3.7 .
>         > I just noticed that the changes in Options handling
>         introduced in 3.7
>         > broke the build of the latest SLEPc (3.6.1, since 3.6.3 is
>         flagged as
>         > incompatible with 3.7).
>         > Is there already a time estimate for a compatible release of
>         SLEPc ?
>         > Thank you and kind regards,
>         > Marco Zocca
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160508/35cad34f/attachment.html>
