[petsc-users] EPSSolve finds eigensolutions in deflation space
Giacomo Mulas giacomo.mulas84 at gmail.com
Sun May 8 06:20:49 CDT 2016
I found a problem in the default iterative eigensystem solver of SLEPC,
namely the Krilov-Schur one: it does not respect the deflation space that it
is given.  This makes it very inefficient even in a case in which it should
be extremely effective.
The problem I want to solve: I have a symmetric operator (an approximated
vibrational Hamiltonian, but that's unimportant) and I want to selectively
find a subset of eigenvectors so that some predefined vectors (which I call
"target" vectors) are very nearly contained in the eigenvector subspace.
I therefore have both a well defined selection criterion (find eigenstates
which have maximum projection on the subspace of "target" vectors) and a
well defined condition for stopping (say, >99% of each of the "target"
vectors is contained in the subspace of the eigenstates found).
The first one can be explicitly cast in a function and given to SLEPC via
EPSSetArbitrarySelection and EPSSetWhichEigenpairs, so that the solver is
guided to the solutions I am most interested in.  I also make use of
EPSSetInitialSpace to have the solver start from a guess which is "rich" in
the "target" vectors (just the "target" vector which has the smallest
projection on the eigenstate space so far).
As to stopping when I found just enough eigenstates, unfortunately it is
thus far impossible to give a custom function to slepc so that it will keep
finding eigenvectors until all are found or the user-defined function tells
it it's enough.  Therefore, my second best solution was to repeatedly run
EPSSolve, aiming at a small number of eigensolutions in each call, putting
previously found solutions in the deflation space and passing it to the
solver via EPSSetDeflationSpace.  Unfortunately, this did not simply work
out of the box.
The first problem is that after the first few, easiest to find
eigensolutions are found, EPSSolve frequently does not find any solutions,
if run with a very conservative EPSSetDimensions (e.g.  like "find me just
one eigensolution").  I thus wrote my code so that the number of requested
solutions in EPSSolve are increased if no new solutions are found by an
EPSSolve call, and decreased if too many were found in just one call.
Inefficient as it may be, due to many useless EPSSolve calls, it works.
However, when trying to use this on real cases, another problem arose, the
big one: frequently, EPSSolve would find and return eigenvectors that were
in the deflation space!  Some eigensolutions would therefore appear more
than once in the set of solutions, of course breaking everything down the
road of my physics calculation before I figured out why.
When I found out, I set up a check in my code that explicitly computes the
projection of newly found eigenstates on previously found ones, and discards
them if they are duplicates.  But this is ineffective for several reasons:
first, such a check is a waste of time and should not be necessary,
otherwise what is the point in setting up a deflation space?  second, and
most important, I have to run EPSSolve looking for lots of solutions to only
find one or two really new ones, because all the first ones are duplicates.
Even if the initial guess is rich in the solution I actually want, and poor
in the duplicate ones. As a result, even if I would just need to find a
(relatively) small subset of the eigenvectors, lapack turns out to be always
much faster, which should not be the case.
I am attaching a test code that shows this behaviour, in the hope that it
will help the SLEPC developers in finding why the deflation space is not
respected and, if possible, correct it.  I know that being able to reproduce
a problem is the first, sometimes actually the most important, step to
attempt to solve it, so there it goes.  Of course I also have a tiny hope
that they might actually include support for a user-defined check for
"enough solutions" in EPSSolve...  There is in fact something not too
different already implemented, for EPSSolve can find all solutions with
eigenvalues in a given interval, without knowing in advance how many they
will be, without the user having to loop over many tentative EPSSolve calls
and finding lots of unneeded additional solutions in the process.
To run the test code, just compile the source, and run it in the same
directory of the two data files.  This is a small test case, so that it runs
fast enough, but I have much larger ones and can produce them more or less
as large as wanted on request.  Upon running the code, you will see that
lots of tentative EPSSolve calls are made, many times finding no solutions
or only solutions already in the deflation space (which contains previously
found eigenvectors).
In this code I privileged clarity over efficiency, no attempt was made to
overoptimise anything.  I put lots of comments in it, so that hopefully it
is self-explanatory.  But of course I am more than willing to explain
whatever is not clear in it.  Just ignore the part that reads the input
files, that's irrelevant.
Of course, I would also very much appreciate it if I could get some clever
suggestions, from SLEPC developers or anyone else on the list, as to how to
solve my problem more efficiently.  And of course I am perfectly willing
to thank them and/or to include them as authors in the scientific publication
describing my molecular spectroscopy code, if some substantial contribution
is offered.
Best regards
Giacomo Mulas
_________________________________________________________________
Giacomo Mulas <gmulas at oa-cagliari.inaf.it>
INAF - Osservatorio Astronomico di Cagliari
via della scienza 5 - 09047 Selargius (CA)
tel.   +39 070 71180244
mob. : +39 329  6603810
"When the storms are raging around you, stay right where you are"
                          (Freddy Mercury)
  0
  1
  2
  3
  4
  5
  6
  7
  8
  9
 10
 14
 16
 18
 45
 47
 48
 61
 66
 69
148
155
160
161
HAM   0   0     12516.8876204415
HAM   1   1     13410.9293803757
HAM   2   2     13807.5567671758
HAM   3   3     14698.8366742206
HAM   4   4     14753.0617782369
HAM   5   5     14757.9145234170
HAM   6   6     14809.1609207543
HAM   7   7     14810.0757294660
HAM   8   8     15100.0588048543
HAM   9   9     15102.7817280683
HAM  10  10     15137.3811319279
HAM  11  11     15243.3001396945
HAM  12  12     15284.1340445604
HAM  13  13     15284.7228408509
HAM  14  14     15451.0139708461
HAM  15  15     15504.4709255707
HAM  16  16     15527.0152178136
HAM  17  17     15573.0506618348
HAM  18  18     15574.8214425670
HAM  19  19     15582.9446947084
HAM  20  20     15590.8951482988
HAM  21  21     15611.0089737759
HAM  22  22     15680.2092849840
HAM  23  23     15923.5787984769
HAM  24  24     15927.0174397958
HAM  25  25     15936.8464025645
HAM  26  26     15965.8797858165
HAM  27  27     15988.5768590098
HAM  28  28     16041.4311998079
HAM  29  29     16045.7065204739
HAM  30  30     16100.1122082759
HAM  31  31     16104.3359210613
HAM  32  32     16287.9024011335
HAM  33  33     16319.8035615461
HAM  34  34     16322.5348221563
HAM  35  35     16324.9835593526
HAM  36  36     16344.7824008626
HAM  37  37     16391.2048758267
HAM  38  38     16393.3008862604
HAM  39  39     16394.3937334770
HAM  40  40     16413.7122559834
HAM  41  41     16414.2595382767
HAM  42  42     16417.4265159137
HAM  43  43     16417.6863055096
HAM  44  44     16425.8737164011
HAM  45  45     16441.9151641324
HAM  46  46     16444.1091050699
HAM  47  47     16452.1638258817
HAM  48  48     16467.2594512397
HAM  49  49     16467.8663099893
HAM  50  50     16476.7249957566
HAM  51  51     16480.0117378381
HAM  52  52     16506.7380265919
HAM  53  53     16566.6039349395
HAM  54  54     16740.0682693060
HAM  55  55     16753.0287119098
HAM  56  56     16762.2016076720
HAM  57  57     16763.1212920437
HAM  58  58     16768.8529472219
HAM  59  59     16774.5378641760
HAM  60  60     16796.0942403925
HAM  61  61     16811.1805111980
HAM  62  62     16815.6309651891
HAM  63  63     16817.3809553770
HAM  64  64     16818.6060255670
HAM  65  65     16829.0042630660
HAM  66  66     16829.1850491025
HAM  67  67     16831.4949524414
HAM  68  68     16861.6227077302
HAM  69  69     16861.6622996356
HAM  70  70     16873.0002930315
HAM  71  71     16876.6960129012
HAM  72  72     16902.9341416102
HAM  73  73     16965.2920426159
HAM  74  74     17703.2804103999
HAM  75  75     17725.8568090435
HAM  76  76     17736.4537444393
HAM  77  77     17738.2907118694
HAM  78  78     17739.4515080188
HAM  79  79     17751.3384554190
HAM  80  80     17753.6765029955
HAM  81  81     17760.0975196187
HAM  82  82     17764.0192890905
HAM  83  83     17764.7035547386
HAM  84  84     17767.8137217453
HAM  85  85     17769.6504967120
HAM  86  86     17770.7805455661
HAM  87  87     17772.5850490916
HAM  88  88     17783.9828778954
HAM  89  89     17787.0640808685
HAM  90  90     17821.3479459743
HAM  91  91     17821.4831757131
HAM  92  92     17824.8727674663
HAM  93  93     17837.9743850425
HAM  94  94     17841.9570507233
HAM  95  95     18045.3149924429
HAM  96  96     18097.1936269259
HAM  97  97     18104.2632016335
HAM  98  98     18104.7174306744
HAM  99  99     18106.0796035088
HAM 100 100     18108.4253438466
HAM 101 101     18117.3911507863
HAM 102 102     18117.5842976362
HAM 103 103     18129.9788096614
HAM 104 104     18131.4896287809
HAM 105 105     18148.4300336527
HAM 106 106     18150.0941242732
HAM 107 107     18150.3360476484
HAM 108 108     18152.0276445699
HAM 109 109     18153.9689360235
HAM 110 110     18169.2813863607
HAM 111 111     18255.0755475688
HAM 112 112     18267.4468851782
HAM 113 113     18288.8465516023
HAM 114 114     18290.7443967233
HAM 115 115     18311.7169112045
HAM 116 116     18393.4603217746
HAM 117 117     18447.1878866549
HAM 118 118     18456.1964367292
HAM 119 119     18468.4968429871
HAM 120 120     18492.4503767861
HAM 121 121     18507.9502732381
HAM 122 122     18523.2637358933
HAM 123 123     18530.6121231785
HAM 124 124     18534.3610777548
HAM 125 125     18536.8355751369
HAM 126 126     18544.1256331562
HAM 127 127     18545.4054611225
HAM 128 128     18549.4978233929
HAM 129 129     18550.0320591621
HAM 130 130     18550.9285947826
HAM 131 131     18555.9564704252
HAM 132 132     18562.1044030372
HAM 133 133     18563.2542429370
HAM 134 134     18573.7057418605
HAM 135 135     18573.9678957932
HAM 136 136     18576.1607050182
HAM 137 137     18577.1296030692
HAM 138 138     18578.0260614922
HAM 139 139     18591.7494116898
HAM 140 140     18595.6921481048
HAM 141 141     18598.0799370839
HAM 142 142     18598.2785327553
HAM 143 143     18599.6992666258
HAM 144 144     18600.1228252272
HAM 145 145     18604.9996902989
HAM 146 146     18606.0901062519
HAM 147 147     18609.4148938941
HAM 148 148     18659.2166308585
HAM 149 149     18728.5718471405
HAM 150 150     18734.1113901197
HAM 151 151     18736.9897484506
HAM 152 152     18740.8432135816
HAM 153 153     18740.8666440240
HAM 154 154     18742.2157209945
HAM 155 155     18747.9752288105
HAM 156 156     18748.5130448142
HAM 157 157     18749.2935997743
HAM 158 158     18800.7438670903
HAM 159 159     18808.8171303531
HAM 160 160     18925.8092509898
HAM 161 161     18956.1339944998
HAM 162 162     19423.1686245934
HAM 163 163     19466.1329128885
HAM 164 164     19466.2920981702
HAM 165 165     19466.7334519793
HAM 166 166     19469.3726019113
HAM 167 167     19470.6499907136
HAM 168 168     19482.9345980102
HAM 169 169     19483.3015255160
HAM 170 170     19483.6523658172
HAM 171 171     19483.7646604604
HAM 172 172     19484.7615710927
HAM 173 173     19487.0508238989
HAM 174 174     19487.2121049035
HAM 175 175     19488.7624382063
HAM 176 176     19491.4440057366
HAM 177 177     19496.9161994805
HAM 178 178     19513.5260939871
HAM 179 179     19541.0115872168
HAM 180 180     19550.0508882697
HAM 181 181     19778.6166549916
HAM 182 182     19819.1485354647
HAM 183 183     19860.9044612480
HAM 184 184     19861.9203299807
HAM 185 185     19862.2159286241
HAM 186 186     19863.1131674915
HAM 187 187     19863.9227149606
HAM 188 188     19865.0093530808
HAM 189 189     19865.3921742370
HAM 190 190     19866.1601775665
HAM 191 191     19866.6558170521
HAM 192 192     19878.2680582264
HAM 193 193     19881.9708545530
HAM 194 194     19940.1603566770
HAM 195 195     19942.2291982614
HAM 196 196     19954.5939947703
HAM 197 197     20029.7490613213
HAM 198 198     20207.7990036358
HAM 199 199     20237.7574912601
HAM 200 200     21770.0731853158
HAM 201 201     21836.5117389223
HAM 202 202     22018.2671173297
HAM 203 203     22049.5185801807
HAM 204 204     22154.0594201432
HAM   0  18      -300.4188662192
HAM  18   0      -300.4188662192
HAM   0   2      -170.7952171627
HAM   2   0      -170.7952171627
HAM   1  48      -300.4188662192
HAM  48   1      -300.4188662192
HAM   1  48        10.1816057936
HAM  48   1        10.1816057936
HAM   1   3      -170.7952171627
HAM   3   1      -170.7952171627
HAM   1   3       -57.7341762039
HAM   3   1       -57.7341762039
HAM   2  69      -300.4188662192
HAM  69   2      -300.4188662192
HAM   2  69        22.6009747399
HAM  69   2        22.6009747399
HAM   2   8      -241.5409125000
HAM   8   2      -241.5409125000
HAM   2   8       -57.1844450000
HAM   8   2       -57.1844450000
HAM   3  79      -300.4188662192
HAM  79   3      -300.4188662192
HAM   3  79        22.6009747399
HAM  79   3        22.6009747399
HAM   3  79        10.1816057936
HAM  79   3        10.1816057936
HAM   3  27      -241.5409125000
HAM  27   3      -241.5409125000
HAM   3  27       -57.1844450000
HAM  27   3       -57.1844450000
HAM   3  27       -81.6484550000
HAM  27   3       -81.6484550000
HAM   4  84      -300.4188662192
HAM  84   4      -300.4188662192
HAM   4  84       205.5464024205
HAM  84   4       205.5464024205
HAM   4  28      -170.7952171627
HAM  28   4      -170.7952171627
HAM   4  28       -38.7471181566
HAM  28   4       -38.7471181566
HAM   4   7        -4.2398725677
HAM   7   4        -4.2398725677
HAM   4   5        -3.7169879872
HAM   5   4        -3.7169879872
HAM   4   6        -3.4841136458
HAM   6   4        -3.4841136458
HAM   5  82      -300.4188662192
HAM  82   5      -300.4188662192
HAM   5  82       209.0512549631
HAM  82   5       209.0512549631
HAM   5  29      -170.7952171627
HAM  29   5      -170.7952171627
HAM   5  29       -23.3926338144
HAM  29   5       -23.3926338144
HAM   6  90      -300.4188662192
HAM  90   6      -300.4188662192
HAM   6  90       163.5191926826
HAM  90   6       163.5191926826
HAM   6  31      -170.7952171627
HAM  31   6      -170.7952171627
HAM   6  31       -48.7127063641
HAM  31   6       -48.7127063641
HAM   6   7        -2.0797773582
HAM   7   6        -2.0797773582
HAM   7  91      -300.4188662192
HAM  91   7      -300.4188662192
HAM   7  91       158.5140080426
HAM  91   7       158.5140080426
HAM   7  30      -170.7952171627
HAM  30   7      -170.7952171627
HAM   7  30       -35.0505901788
HAM  30   7       -35.0505901788
HAM   8 107      -300.4188662192
HAM 107   8      -300.4188662192
HAM   8 107        45.2019494798
HAM 107   8        45.2019494798
HAM   8  39      -295.8259938156
HAM  39   8      -295.8259938156
HAM   8  39      -140.0727114742
HAM  39   8      -140.0727114742
HAM   9 100      -300.4188662192
HAM 100   9      -300.4188662192
HAM   9 100        48.5711365154
HAM 100   9        48.5711365154
HAM   9 100       104.5256274816
HAM 100   9       104.5256274816
HAM   9  37      -170.7952171627
HAM  37   9      -170.7952171627
HAM   9  37        -2.2151039159
HAM  37   9        -2.2151039159
HAM   9  37       -11.6963169072
HAM  37   9       -11.6963169072
HAM   9  10        -5.3789536266
HAM  10   9        -5.3789536266
HAM  10 105      -300.4188662192
HAM 105  10      -300.4188662192
HAM  10 105        53.1892049414
HAM 105  10        53.1892049414
HAM  10 105       102.7732012102
HAM 105  10       102.7732012102
HAM  10  13       -19.7957050000
HAM  13  10       -19.7957050000
HAM  10  11        16.9736775000
HAM  11  10        16.9736775000
HAM  10  44      -170.7952171627
HAM  44  10      -170.7952171627
HAM  10  44       -19.7004227235
HAM  44  10       -19.7004227235
HAM  10  44       -19.3735590783
HAM  44  10       -19.3735590783
HAM  12  13        -5.2250954574
HAM  13  12        -5.2250954574
HAM  14 118      -300.4188662192
HAM 118  14      -300.4188662192
HAM  14 118        97.1422730309
HAM 118  14        97.1422730309
HAM  14  18        34.3449800000
HAM  18  14        34.3449800000
HAM  14  54      -170.7952171627
HAM  54  14      -170.7952171627
HAM  14  54        -4.4302078319
HAM  54  14        -4.4302078319
HAM  15 121      -300.4188662192
HAM 121  15      -300.4188662192
HAM  15 121       113.9080258357
HAM 121  15       113.9080258357
HAM  15 121         8.7967583758
HAM 121  15         8.7967583758
HAM  15 121        81.7595963413
HAM 121  15        81.7595963413
HAM  15  60      -170.7952171627
HAM  60  15      -170.7952171627
HAM  15  60       -17.9209708309
HAM  60  15       -17.9209708309
HAM  15  60       -42.3469492822
HAM  60  15       -42.3469492822
HAM  15  60       -24.3563531820
HAM  60  15       -24.3563531820
HAM  15  18         7.0230418611
HAM  18  15         7.0230418611
HAM  16 124      -300.4188662192
HAM 124  16      -300.4188662192
HAM  16 124       106.3784098828
HAM 124  16       106.3784098828
HAM  16  18        37.6104475000
HAM  18  16        37.6104475000
HAM  16  22       -27.9953544877
HAM  22  16       -27.9953544877
HAM  16  21        24.0044049238
HAM  21  16        24.0044049238
HAM  16  62      -170.7952171627
HAM  62  16      -170.7952171627
HAM  16  62       -39.4008454469
HAM  62  16       -39.4008454469
HAM  17 136      -300.4188662192
HAM 136  17      -300.4188662192
HAM  17 136        10.1816057936
HAM 136  17        10.1816057936
HAM  17 136        79.2570040213
HAM 136  17        79.2570040213
HAM  17 136       113.9080258357
HAM 136  17       113.9080258357
HAM  17  68      -170.7952171627
HAM  68  17      -170.7952171627
HAM  17  68       -57.7341762039
HAM  68  17       -57.7341762039
HAM  17  68       -17.5252950894
HAM  68  17       -17.5252950894
HAM  17  68       -17.9209708309
HAM  68  17       -17.9209708309
HAM  17  18         4.0418029756
HAM  18  17         4.0418029756
HAM  17  19         4.2461309736
HAM  19  17         4.2461309736
HAM  18 148      -238.8224875000
HAM 148  18      -238.8224875000
HAM  18 148      -424.8564350000
HAM 148  18      -424.8564350000
HAM  18  69      -170.7952171627
HAM  69  18      -170.7952171627
HAM  18  69        -8.6375497485
HAM  69  18        -8.6375497485
HAM  18  20        -7.1130613178
HAM  20  18        -7.1130613178
HAM  18  19        -3.8549362026
HAM  19  18        -3.8549362026
HAM  19 130      -300.4188662192
HAM 130  19      -300.4188662192
HAM  19 130        79.2570040213
HAM 130  19        79.2570040213
HAM  19 130       104.5256274816
HAM 130  19       104.5256274816
HAM  19 130       164.8004772412
HAM 130  19       164.8004772412
HAM  19  70      -170.7952171627
HAM  70  19      -170.7952171627
HAM  19  70       -17.5252950894
HAM  70  19       -17.5252950894
HAM  19  70       -11.6963169072
HAM  70  19       -11.6963169072
HAM  19  70        -9.9286949111
HAM  70  19        -9.9286949111
HAM  19  21        11.8807505823
HAM  21  19        11.8807505823
HAM  19  20        -3.6947004303
HAM  20  19        -3.6947004303
HAM  20 143      -300.4188662192
HAM 143  20      -300.4188662192
HAM  20 143       102.7732012102
HAM 143  20       102.7732012102
HAM  20 143       104.5256274816
HAM 143  20       104.5256274816
HAM  20 143         8.7967583758
HAM 143  20         8.7967583758
HAM  20  71      -170.7952171627
HAM  71  20      -170.7952171627
HAM  20  71       -19.3735590783
HAM  71  20       -19.3735590783
HAM  20  71       -11.6963169072
HAM  71  20       -11.6963169072
HAM  20  71       -42.3469492822
HAM  71  20       -42.3469492822
HAM  20  45      -101.2430327423
HAM  45  20      -101.2430327423
HAM  21 132      -300.4188662192
HAM 132  21      -300.4188662192
HAM  21 132        53.1892049414
HAM 132  21        53.1892049414
HAM  21 132       329.6009544823
HAM 132  21       329.6009544823
HAM  21  72      -170.7952171627
HAM  72  21      -170.7952171627
HAM  21  72       -19.7004227235
HAM  72  21       -19.7004227235
HAM  21  72       -19.8573898223
HAM  72  21       -19.8573898223
HAM  22  73      -170.7952171627
HAM  73  22      -170.7952171627
HAM  22  73       -19.7004227235
HAM  73  22       -19.7004227235
HAM  22  73       -84.6938985644
HAM  73  22       -84.6938985644
HAM  23  47        68.0216641669
HAM  47  23        68.0216641669
HAM  23  26        -4.7701024864
HAM  26  23        -4.7701024864
HAM  23  25        13.1422604482
HAM  25  23        13.1422604482
HAM  23  24        -3.6947004303
HAM  24  23        -3.6947004303
HAM  26  47        58.3507132130
HAM  47  26        58.3507132130
HAM  28  30        -4.2398725677
HAM  30  28        -4.2398725677
HAM  28  29        -3.7169879872
HAM  29  28        -3.7169879872
HAM  28  31        -3.4841136458
HAM  31  28        -3.4841136458
HAM  30  31        -2.0797773582
HAM  31  30        -2.0797773582
HAM  32  61       -58.3274140446
HAM  61  32       -58.3274140446
HAM  32  66        68.0216641669
HAM  66  32        68.0216641669
HAM  32  35        -6.9666076100
HAM  35  32        -6.9666076100
HAM  32  34        -6.7459436302
HAM  34  32        -6.7459436302
HAM  33  45       -49.1071906307
HAM  45  33       -49.1071906307
HAM  34  66        82.5203700000
HAM  66  34        82.5203700000
HAM  34  35        -2.0797773582
HAM  35  34        -2.0797773582
HAM  35  43        16.9736775000
HAM  43  35        16.9736775000
HAM  35  61      -100.1932350000
HAM  61  35      -100.1932350000
HAM  36  48        34.3449800000
HAM  48  36        34.3449800000
HAM  37  44        -5.3789536266
HAM  44  37        -5.3789536266
HAM  38  48         7.0230418611
HAM  48  38         7.0230418611
HAM  38  45        -3.7926138140
HAM  45  38        -3.7926138140
HAM  38  40         4.2461309736
HAM  40  38         4.2461309736
HAM  40  47         4.3345762837
HAM  47  40         4.3345762837
HAM  40  46         8.3491699926
HAM  46  40         8.3491699926
HAM  40  41         2.1168581056
HAM  41  40         2.1168581056
HAM  41  46        -3.4577939437
HAM  46  41        -3.4577939437
HAM  41  43        -7.3894008606
HAM  43  41        -7.3894008606
HAM  42 162      -300.4188662192
HAM 162  42      -300.4188662192
HAM  42 162       106.3784098828
HAM 162  42       106.3784098828
HAM  42 162        10.1816057936
HAM 162  42        10.1816057936
HAM  42  48        37.6104475000
HAM  48  42        37.6104475000
HAM  42  53       -27.9953544877
HAM  53  42       -27.9953544877
HAM  42  52        24.0044049238
HAM  52  42        24.0044049238
HAM  42  74      -170.7952171627
HAM  74  42      -170.7952171627
HAM  42  74       -39.4008454469
HAM  74  42       -39.4008454469
HAM  42  74       -57.7341762039
HAM  74  42       -57.7341762039
HAM  42  44         4.1766372747
HAM  44  42         4.1766372747
HAM  45 178      -300.4188662192
HAM 178  45      -300.4188662192
HAM  45 178      -339.0077727691
HAM 178  45      -339.0077727691
HAM  45 178         8.7967583758
HAM 178  45         8.7967583758
HAM  45  75      -170.7952171627
HAM  75  45      -170.7952171627
HAM  45  75        -7.6813044996
HAM  75  45        -7.6813044996
HAM  45  75       -42.3469492822
HAM  75  45       -42.3469492822
HAM  45 181      -357.0126665684
HAM 181  45      -357.0126665684
HAM  46  76      -241.5409125000
HAM  76  46      -241.5409125000
HAM  46  76       -57.1844450000
HAM  76  46       -57.1844450000
HAM  46  76       -25.3440800000
HAM  76  46       -25.3440800000
HAM  46  76       -59.8876300000
HAM  76  46       -59.8876300000
HAM  46  76       -14.0412950000
HAM  76  46       -14.0412950000
HAM  46  47        -4.4558933975
HAM  47  46        -4.4558933975
HAM  47 173      -300.4188662192
HAM 173  47      -300.4188662192
HAM  47 173      -355.2935556330
HAM 173  47      -355.2935556330
HAM  47 173       164.8004772412
HAM 173  47       164.8004772412
HAM  47  78      -170.7952171627
HAM  78  47      -170.7952171627
HAM  47  78       -11.6484528492
HAM  78  47       -11.6484528492
HAM  47  78        -9.9286949111
HAM  78  47        -9.9286949111
HAM  47 179      -357.0126665684
HAM 179  47      -357.0126665684
HAM  47  48        -4.9463631074
HAM  48  47        -4.9463631074
HAM  48 180      -238.8224875000
HAM 180  48      -238.8224875000
HAM  48 180      -424.8564350000
HAM 180  48      -424.8564350000
HAM  48 180        14.3989650000
HAM 180  48        14.3989650000
HAM  48  79      -170.7952171627
HAM  79  48      -170.7952171627
HAM  48  79        -8.6375497485
HAM  79  48        -8.6375497485
HAM  48  79       -57.7341762039
HAM  79  48       -57.7341762039
HAM  48  51        -7.1130613178
HAM  51  48        -7.1130613178
HAM  48  49         5.7159725845
HAM  49  48         5.7159725845
HAM  48  50        -3.8549362026
HAM  50  48        -3.8549362026
HAM  49 166      -300.4188662192
HAM 166  49      -300.4188662192
HAM  49 166        20.3632115871
HAM 166  49        20.3632115871
HAM  49 166        79.2570040213
HAM 166  49        79.2570040213
HAM  49 166       113.9080258357
HAM 166  49       113.9080258357
HAM  49  80      -170.7952171627
HAM  80  49      -170.7952171627
HAM  49  80      -115.4683524078
HAM  80  49      -115.4683524078
HAM  49  80       -17.5252950894
HAM  80  49       -17.5252950894
HAM  49  80       -17.9209708309
HAM  80  49       -17.9209708309
HAM  49  50         6.0049360104
HAM  50  49         6.0049360104
HAM  50  52        11.8807505823
HAM  52  50        11.8807505823
HAM  50  51        -3.6947004303
HAM  51  50        -3.6947004303
HAM  51 174      -300.4188662192
HAM 174  51      -300.4188662192
HAM  51 174       102.7732012102
HAM 174  51       102.7732012102
HAM  51 174        10.1816057936
HAM 174  51        10.1816057936
HAM  51 174       104.5256274816
HAM 174  51       104.5256274816
HAM  51 174         8.7967583758
HAM 174  51         8.7967583758
HAM  54  69        34.3449800000
HAM  69  54        34.3449800000
HAM  55  60         3.3831146002
HAM  60  55         3.3831146002
HAM  55  57         9.2929814831
HAM  57  55         9.2929814831
HAM  55  56        -3.3383856767
HAM  56  55        -3.3383856767
HAM  56  66         6.1300165675
HAM  66  56         6.1300165675
HAM  56  60        11.8075094380
HAM  60  56        11.8075094380
HAM  56  57         2.9936894426
HAM  57  56         2.9936894426
HAM  56  59        -2.0797773582
HAM  59  56        -2.0797773582
HAM  57  61        -5.0238491605
HAM  61  57        -5.0238491605
HAM  57  60        -3.4577939437
HAM  60  57        -3.4577939437
HAM  57  58        -5.2250954574
HAM  58  57        -5.2250954574
HAM  57  59         2.9046405511
HAM  59  57         2.9046405511
HAM  59  61         3.1263451552
HAM  61  59         3.1263451552
HAM  60  69         7.0230418611
HAM  69  60         7.0230418611
HAM  60  66        -4.4558933975
HAM  66  60        -4.4558933975
HAM  61 186      -300.4188662192
HAM 186  61      -300.4188662192
HAM  61 186      -359.1540157115
HAM 186  61      -359.1540157115
HAM  61 186        79.2570040213
HAM 186  61        79.2570040213
HAM  61  96      -170.7952171627
HAM  96  61      -170.7952171627
HAM  61  96        -9.9542674279
HAM  96  61        -9.9542674279
HAM  61  96       -17.5252950894
HAM  96  61       -17.5252950894
HAM  61 196      -357.0126665684
HAM 196  61      -357.0126665684
HAM  61  66         2.8175646831
HAM  66  61         2.8175646831
HAM  62 182      -300.4188662192
HAM 182  62      -300.4188662192
HAM  62 182       106.3784098828
HAM 182  62       106.3784098828
HAM  62 182        22.6009747399
HAM 182  62        22.6009747399
HAM  62  69        37.6104475000
HAM  69  62        37.6104475000
HAM  62  73       -27.9953544877
HAM  73  62       -27.9953544877
HAM  62  72        24.0044049238
HAM  72  62        24.0044049238
HAM  62  99      -241.5409125000
HAM  99  62      -241.5409125000
HAM  62  99       -55.7212100000
HAM  99  62       -55.7212100000
HAM  62  99       -57.1844450000
HAM  99  62       -57.1844450000
HAM  63  64        -3.6947004303
HAM  64  63        -3.6947004303
HAM  64  68         3.3831146002
HAM  68  64         3.3831146002
HAM  64  65        13.1422604482
HAM  65  64        13.1422604482
HAM  64  67        -2.3605951502
HAM  67  64        -2.3605951502
HAM  65  68        -4.8900590911
HAM  68  65        -4.8900590911
HAM  65  67         2.9936894426
HAM  67  65         2.9936894426
HAM  66 193      -300.4188662192
HAM 193  66      -300.4188662192
HAM  66 193      -355.2935556330
HAM 193  66      -355.2935556330
HAM  66 193        81.7595963413
HAM 193  66        81.7595963413
HAM  66 102      -170.7952171627
HAM 102  66      -170.7952171627
HAM  66 102       -11.6484528492
HAM 102  66       -11.6484528492
HAM  66 102       -24.3563531820
HAM 102  66       -24.3563531820
HAM  66 194      -357.0126665684
HAM 194  66      -357.0126665684
HAM  66  69        -6.2829398337
HAM  69  66        -6.2829398337
HAM  67  68         8.3491699926
HAM  68  67         8.3491699926
HAM  68 183      -300.4188662192
HAM 183  68      -300.4188662192
HAM  68 183        22.6009747399
HAM 183  68        22.6009747399
HAM  68 183        10.1816057936
HAM 183  68        10.1816057936
HAM  68 183        79.2570040213
HAM 183  68        79.2570040213
HAM  68 183       113.9080258357
HAM 183  68       113.9080258357
HAM  68 108      -241.5409125000
HAM 108  68      -241.5409125000
HAM  68 108       -57.1844450000
HAM 108  68       -57.1844450000
HAM  68 108       -81.6484550000
HAM 108  68       -81.6484550000
HAM  68 108       -24.7845100000
HAM 108  68       -24.7845100000
HAM  68 108       -25.3440800000
HAM 108  68       -25.3440800000
HAM  68  69         4.0418029756
HAM  69  68         4.0418029756
HAM  68  70         4.2461309736
HAM  70  68         4.2461309736
HAM  69 195      -238.8224875000
HAM 195  69      -238.8224875000
HAM  69 195      -424.8564350000
HAM 195  69      -424.8564350000
HAM  69 195        31.9626050000
HAM 195  69        31.9626050000
HAM  69 107      -241.5409125000
HAM 107  69      -241.5409125000
HAM  69 107       -12.2153400000
HAM 107  69       -12.2153400000
HAM  69 107       -57.1844450000
HAM 107  69       -57.1844450000
HAM  69  71        -7.1130613178
HAM  71  69        -7.1130613178
HAM  69  70        -3.8549362026
HAM  70  69        -3.8549362026
HAM  70  72        11.8807505823
HAM  72  70        11.8807505823
HAM  70  71        -3.6947004303
HAM  71  70        -3.6947004303
HAM  71  75      -101.2430327423
HAM  75  71      -101.2430327423
HAM  74  79        37.6104475000
HAM  79  74        37.6104475000
HAM  76  78        -6.3015848752
HAM  78  76        -6.3015848752
HAM  77  88       -49.1071906307
HAM  88  77       -49.1071906307
HAM  77 123      -101.2430327423
HAM 123  77      -101.2430327423
HAM  77  81       -10.7579072532
HAM  81  77       -10.7579072532
HAM  77  85       -11.8138657164
HAM  85  77       -11.8138657164
HAM  78  79        -4.9463631074
HAM  79  78        -4.9463631074
HAM  79  80         5.7159725845
HAM  80  79         5.7159725845
HAM  81  84        37.6104475000
HAM  84  81        37.6104475000
HAM  81  94        -4.2398725677
HAM  94  81        -4.2398725677
HAM  81  85        -3.7169879872
HAM  85  81        -3.7169879872
HAM  81  93        -3.4841136458
HAM  93  81        -3.4841136458
HAM  82  85        37.6104475000
HAM  85  82        37.6104475000
HAM  82  83         7.0230418611
HAM  83  82         7.0230418611
HAM  82  88       -16.6255961673
HAM  88  82       -16.6255961673
HAM  82  89        28.6307467166
HAM  89  82        28.6307467166
HAM  82  84        -3.7169879872
HAM  84  82        -3.7169879872
HAM  83  89         6.1300165675
HAM  89  83         6.1300165675
HAM  83  87         2.9936894426
HAM  87  83         2.9936894426
HAM  84  86       -27.7182772037
HAM  86  84       -27.7182772037
HAM  84  88       -15.1221891670
HAM  88  84       -15.1221891670
HAM  84  91        -4.2398725677
HAM  91  84        -4.2398725677
HAM  84  90        -3.4841136458
HAM  90  84        -3.4841136458
HAM  86  87         2.2106598596
HAM  87  86         2.2106598596
HAM  86  89       -10.5031177239
HAM  89  86       -10.5031177239
HAM  86  88         8.0159015621
HAM  88  86         8.0159015621
HAM  88 155      -143.1792700000
HAM 155  88      -143.1792700000
HAM  88  89        -7.4474313928
HAM  89  88        -7.4474313928
HAM  90  93        37.6104475000
HAM  93  90        37.6104475000
HAM  90  91        -2.0797773582
HAM  91  90        -2.0797773582
HAM  91  94        37.6104475000
HAM  94  91        37.6104475000
HAM  91  92         7.0230418611
HAM  92  91         7.0230418611
HAM  93 115       116.7014264260
HAM 115  93       116.7014264260
HAM  93  94        -2.0797773582
HAM  94  93        -2.0797773582
HAM  94 114      -141.6946317950
HAM 114  94      -141.6946317950
HAM  95 100        59.4872503449
HAM 100  95        59.4872503449
HAM  96 102         2.8175646831
HAM 102  96         2.8175646831
HAM  97 141       -58.3274140446
HAM 141  97       -58.3274140446
HAM  97 100         7.0230418611
HAM 100  97         7.0230418611
HAM  97 103         4.3345762837
HAM 103  97         4.3345762837
HAM  97  98         2.1168581056
HAM  98  97         2.1168581056
HAM  98 147        68.0216641669
HAM 147  98        68.0216641669
HAM  99 107        37.6104475000
HAM 107  99        37.6104475000
HAM 100 101        37.6104475000
HAM 101 100        37.6104475000
HAM 100 110        -5.3975604309
HAM 110 100        -5.3975604309
HAM 100 104       -11.7560717912
HAM 104 100       -11.7560717912
HAM 100 111        10.5189624984
HAM 111 100        10.5189624984
HAM 100 103        20.2449951537
HAM 103 100        20.2449951537
HAM 100 105        -5.3789536266
HAM 105 100        -5.3789536266
HAM 101 110       -69.4480550000
HAM 110 101       -69.4480550000
HAM 101 106        -9.3166209729
HAM 106 101        -9.3166209729
HAM 102 107        -8.8854187243
HAM 107 102        -8.8854187243
HAM 103 109        -5.4570533515
HAM 109 103        -5.4570533515
HAM 103 104        -7.4474313928
HAM 104 103        -7.4474313928
HAM 104 105        -5.3744735722
HAM 105 104        -5.3744735722
HAM 104 110        -5.9069328582
HAM 110 104        -5.9069328582
HAM 105 106        65.1432059654
HAM 106 105        65.1432059654
HAM 105 109       -19.5997817736
HAM 109 105       -19.5997817736
HAM 105 110       -10.6930025064
HAM 110 105       -10.6930025064
HAM 107 108         4.0418029756
HAM 108 107         4.0418029756
HAM 109 110         8.0159015621
HAM 110 109         8.0159015621
HAM 111 160       -82.4874200000
HAM 160 111       -82.4874200000
HAM 111 114        -4.9261354829
HAM 114 111        -4.9261354829
HAM 111 112         3.0918811583
HAM 112 111         3.0918811583
HAM 112 161        96.1971600000
HAM 161 112        96.1971600000
HAM 112 114        -5.4570533515
HAM 114 112        -5.4570533515
HAM 112 115        -4.7701024864
HAM 115 112        -4.7701024864
HAM 113 150      -100.1932350000
HAM 150 113      -100.1932350000
HAM 113 114         3.1263451552
HAM 114 113         3.1263451552
HAM 114 160      -100.1932350000
HAM 160 114      -100.1932350000
HAM 114 115         2.8175646831
HAM 115 114         2.8175646831
HAM 115 161        82.5203700000
HAM 161 115        82.5203700000
HAM 116 118        84.1276762261
HAM 118 116        84.1276762261
HAM 117 121        34.3449800000
HAM 121 117        34.3449800000
HAM 117 118         7.0230418611
HAM 118 117         7.0230418611
HAM 118 119        37.6104475000
HAM 119 118        37.6104475000
HAM 118 148        48.5711365154
HAM 148 118        48.5711365154
HAM 118 125        -3.8549362026
HAM 125 118        -3.8549362026
HAM 118 123        -7.6333031652
HAM 123 118        -7.6333031652
HAM 119 124        34.3449800000
HAM 124 119        34.3449800000
HAM 119 131        24.0044049238
HAM 131 119        24.0044049238
HAM 119 123       -98.2143812614
HAM 123 119       -98.2143812614
HAM 120 121        19.8641620983
HAM 121 120        19.8641620983
HAM 121 122        37.6104475000
HAM 122 121        37.6104475000
HAM 121 137         5.7159725845
HAM 137 121         5.7159725845
HAM 121 148         9.9320810491
HAM 148 121         9.9320810491
HAM 121 149       -21.2027686422
HAM 149 121       -21.2027686422
HAM 121 156        21.2276205027
HAM 156 121        21.2276205027
HAM 121 147       -12.9461802595
HAM 147 121       -12.9461802595
HAM 121 141        13.1969367648
HAM 141 121        13.1969367648
HAM 122 124         7.0230418611
HAM 124 122         7.0230418611
HAM 123 129        16.9736775000
HAM 129 123        16.9736775000
HAM 123 155       -69.4480550000
HAM 155 123       -69.4480550000
HAM 123 128        -3.7926138140
HAM 128 123        -3.7926138140
HAM 123 124        -7.6006534165
HAM 124 123        -7.6006534165
HAM 124 127        92.1264053727
HAM 127 124        92.1264053727
HAM 124 148        53.1892049414
HAM 148 124        53.1892049414
HAM 124 132        24.0044049238
HAM 132 124        24.0044049238
HAM 124 182      -170.7952171627
HAM 182 124      -170.7952171627
HAM 124 182        -8.6375497485
HAM 182 124        -8.6375497485
HAM 124 182       -39.4008454469
HAM 182 124       -39.4008454469
HAM 124 142        -7.1130613178
HAM 142 124        -7.1130613178
HAM 124 139         4.0418029756
HAM 139 124         4.0418029756
HAM 125 130        34.3449800000
HAM 130 125        34.3449800000
HAM 125 134        -7.6069891701
HAM 134 125        -7.6069891701
HAM 125 131        11.8807505823
HAM 131 125        11.8807505823
HAM 126 140       -49.1071906307
HAM 140 126       -49.1071906307
HAM 126 142       -11.8138657164
HAM 142 126       -11.8138657164
HAM 126 133        -3.7169879872
HAM 133 126        -3.7169879872
HAM 126 134        -5.2250954574
HAM 134 126        -5.2250954574
HAM 128 146       -49.1071906307
HAM 146 128       -49.1071906307
HAM 128 139        -6.9666076100
HAM 139 128        -6.9666076100
HAM 129 131       -69.4480550000
HAM 131 129       -69.4480550000
HAM 129 132        -5.3744735722
HAM 132 129        -5.3744735722
HAM 129 138        13.1422604482
HAM 138 129        13.1422604482
HAM 130 148        -5.4517030598
HAM 148 130        -5.4517030598
HAM 130 138       -11.7560717912
HAM 138 130       -11.7560717912
HAM 130 135        20.2449951537
HAM 135 130        20.2449951537
HAM 130 132        11.8807505823
HAM 132 130        11.8807505823
HAM 130 143        -3.6947004303
HAM 143 130        -3.6947004303
HAM 130 136         4.2461309736
HAM 136 130         4.2461309736
HAM 131 132        34.3449800000
HAM 132 131        34.3449800000
HAM 131 134        18.5859629661
HAM 134 131        18.5859629661
HAM 133 145       -49.1071906307
HAM 145 133       -49.1071906307
HAM 133 142       -10.7579072532
HAM 142 133       -10.7579072532
HAM 134 185      -170.7952171627
HAM 185 134      -170.7952171627
HAM 134 185       -19.7004227235
HAM 185 134       -19.7004227235
HAM 134 185       -19.3735590783
HAM 185 134       -19.3735590783
HAM 134 185       -17.5252950894
HAM 185 134       -17.5252950894
HAM 134 185        -2.2151039159
HAM 185 134        -2.2151039159
HAM 134 185        -9.9286949111
HAM 185 134        -9.9286949111
HAM 134 138       -49.1071906307
HAM 138 134       -49.1071906307
HAM 135 184      -170.7952171627
HAM 184 135      -170.7952171627
HAM 135 184       -17.5252950894
HAM 184 135       -17.5252950894
HAM 135 184       -17.9209708309
HAM 184 135       -17.9209708309
HAM 135 184       -11.6484528492
HAM 184 135       -11.6484528492
HAM 135 184        -9.9286949111
HAM 184 135        -9.9286949111
HAM 135 136        -4.9463631074
HAM 136 135        -4.9463631074
HAM 135 138        -7.4474313928
HAM 138 135        -7.4474313928
HAM 135 147        -3.6947004303
HAM 147 135        -3.6947004303
HAM 136 139        37.6104475000
HAM 139 136        37.6104475000
HAM 136 183      -170.7952171627
HAM 183 136      -170.7952171627
HAM 136 183        -8.6375497485
HAM 183 136        -8.6375497485
HAM 136 183       -57.7341762039
HAM 183 136       -57.7341762039
HAM 136 183       -17.5252950894
HAM 183 136       -17.5252950894
HAM 136 183       -17.9209708309
HAM 183 136       -17.9209708309
HAM 136 148         5.7159725845
HAM 148 136         5.7159725845
HAM 136 137         9.9320810491
HAM 137 136         9.9320810491
HAM 136 146        -8.5713498230
HAM 146 136        -8.5713498230
HAM 137 191      -170.7952171627
HAM 191 137      -170.7952171627
HAM 137 191       -57.7341762039
HAM 191 137       -57.7341762039
HAM 137 191       -17.5252950894
HAM 191 137       -17.5252950894
HAM 137 191       -35.8419416619
HAM 191 137       -35.8419416619
HAM 137 191       -42.3469492822
HAM 191 137       -42.3469492822
HAM 137 191       -24.3563531820
HAM 191 137       -24.3563531820
HAM 138 187      -170.7952171627
HAM 187 138      -170.7952171627
HAM 138 187       -19.3735590783
HAM 187 138       -19.3735590783
HAM 138 187       -17.5252950894
HAM 187 138       -17.5252950894
HAM 138 187        -7.6813044996
HAM 187 138        -7.6813044996
HAM 138 187        -9.9286949111
HAM 187 138        -9.9286949111
HAM 138 140        -5.2250954574
HAM 140 138        -5.2250954574
HAM 139 192      -170.7952171627
HAM 192 139      -170.7952171627
HAM 139 192       -39.4008454469
HAM 192 139       -39.4008454469
HAM 139 192       -57.7341762039
HAM 192 139       -57.7341762039
HAM 139 192       -17.5252950894
HAM 192 139       -17.5252950894
HAM 139 192       -17.9209708309
HAM 192 139       -17.9209708309
HAM 140 143       -16.6255961673
HAM 143 140       -16.6255961673
HAM 140 145        -3.7169879872
HAM 145 140        -3.7169879872
HAM 140 147       -10.5322584806
HAM 147 140       -10.5322584806
HAM 141 144         4.4213197191
HAM 144 141         4.4213197191
HAM 141 143       -19.5997817736
HAM 143 141       -19.5997817736
HAM 141 147       -11.3018940423
HAM 147 141       -11.3018940423
HAM 141 149        16.5567958789
HAM 149 141        16.5567958789
HAM 141 145        11.3361967038
HAM 145 141        11.3361967038
HAM 142 143        37.6104475000
HAM 143 142        37.6104475000
HAM 143 178      -101.2430327423
HAM 178 143      -101.2430327423
HAM 143 148       -10.0593877856
HAM 148 143       -10.0593877856
HAM 143 145       -15.1221891670
HAM 145 143       -15.1221891670
HAM 143 149        10.5189624984
HAM 149 143        10.5189624984
HAM 143 147        20.2449951537
HAM 147 143        20.2449951537
HAM 146 155        -5.3635658927
HAM 155 146        -5.3635658927
HAM 147 156        16.7080383106
HAM 156 147        16.7080383106
HAM 148 200      -584.9932334772
HAM 200 148      -584.9932334772
HAM 148 200      -520.3407398440
HAM 200 148      -520.3407398440
HAM 148 195      -170.7952171627
HAM 195 148      -170.7952171627
HAM 148 195       -17.2750994970
HAM 195 148       -17.2750994970
HAM 148 160        28.6213026111
HAM 160 148        28.6213026111
HAM 148 155        25.9737696380
HAM 155 148        25.9737696380
HAM 148 161        27.8825741033
HAM 161 148        27.8825741033
HAM 149 160        -7.1047956181
HAM 160 149        -7.1047956181
HAM 149 156       -10.5031177239
HAM 156 149       -10.5031177239
HAM 149 150         2.0538910306
HAM 150 149         2.0538910306
HAM 149 157         3.0918811583
HAM 157 149         3.0918811583
HAM 150 151         6.2526903104
HAM 151 150         6.2526903104
HAM 150 160         3.1263451552
HAM 160 150         3.1263451552
HAM 150 154         8.4009593024
HAM 154 150         8.4009593024
HAM 150 157       -11.3018940423
HAM 157 150       -11.3018940423
HAM 150 156         2.8175646831
HAM 156 150         2.8175646831
HAM 152 157        -6.3015848752
HAM 157 152        -6.3015848752
HAM 152 153         2.1168581056
HAM 153 152         2.1168581056
HAM 153 156        -6.3015848752
HAM 156 153        -6.3015848752
HAM 153 159         6.1300165675
HAM 159 153         6.1300165675
HAM 155 201      -300.4188662192
HAM 201 155      -300.4188662192
HAM 155 201      -678.0155455383
HAM 201 155      -678.0155455383
HAM 155 197      -170.7952171627
HAM 197 155      -170.7952171627
HAM 155 197       -15.3626089991
HAM 197 155       -15.3626089991
HAM 155 204      -504.8921550000
HAM 204 155      -504.8921550000
HAM 155 160        47.0691516705
HAM 160 155        47.0691516705
HAM 155 161        47.2649412718
HAM 161 155        47.2649412718
HAM 156 161         6.1300165675
HAM 161 156         6.1300165675
HAM 156 159         8.3491699926
HAM 159 156         8.3491699926
HAM 156 157         2.1168581056
HAM 157 156         2.1168581056
HAM 157 159        -3.4577939437
HAM 159 157        -3.4577939437
HAM 158 159        -7.4474313928
HAM 159 158        -7.4474313928
HAM 159 161        -6.3015848752
HAM 161 159        -6.3015848752
HAM 160 202      -300.4188662192
HAM 202 160      -300.4188662192
HAM 160 202      -718.3080314231
HAM 202 160      -718.3080314231
HAM 160 198      -170.7952171627
HAM 198 160      -170.7952171627
HAM 160 198       -19.9085348558
HAM 198 160       -19.9085348558
HAM 160 204      -504.8921550000
HAM 204 160      -504.8921550000
HAM 160 161        46.4776828590
HAM 161 160        46.4776828590
HAM 161 203      -300.4188662192
HAM 203 161      -300.4188662192
HAM 161 203      -710.5871112661
HAM 203 161      -710.5871112661
HAM 161 199      -170.7952171627
HAM 199 161      -170.7952171627
HAM 161 199       -23.2969056984
HAM 199 161       -23.2969056984
HAM 161 204      -504.8921550000
HAM 204 161      -504.8921550000
HAM 162 180        53.1892049414
HAM 180 162        53.1892049414
HAM 162 171        -7.1130613178
HAM 171 162        -7.1130613178
HAM 162 168         5.7159725845
HAM 168 162         5.7159725845
HAM 163 173         4.0418029756
HAM 173 163         4.0418029756
HAM 163 166        -6.9952137908
HAM 166 163        -6.9952137908
HAM 163 167        -7.4474313928
HAM 167 163        -7.4474313928
HAM 163 177        -3.6947004303
HAM 177 163        -3.6947004303
HAM 164 167       -49.1071906307
HAM 167 164       -49.1071906307
HAM 165 166         9.9320810491
HAM 166 165         9.9320810491
HAM 166 168        37.6104475000
HAM 168 166        37.6104475000
HAM 166 180         8.0836059512
HAM 180 166         8.0836059512
HAM 167 170        -5.2250954574
HAM 170 167        -5.2250954574
HAM 169 172         4.4213197191
HAM 172 169         4.4213197191
HAM 170 174       -16.6255961673
HAM 174 170       -16.6255961673
HAM 170 176        -3.7169879872
HAM 176 170        -3.7169879872
HAM 170 177       -10.5322584806
HAM 177 170       -10.5322584806
HAM 171 174        37.6104475000
HAM 174 171        37.6104475000
HAM 172 174       -19.5997817736
HAM 174 172       -19.5997817736
HAM 172 177       -11.3018940423
HAM 177 172       -11.3018940423
HAM 172 176        11.3361967038
HAM 176 172        11.3361967038
HAM 173 175        -7.1130613178
HAM 175 173        -7.1130613178
HAM 173 180        -6.9952137908
HAM 180 173        -6.9952137908
HAM 173 179       -14.2538605748
HAM 179 173       -14.2538605748
HAM 174 180       -10.0593877856
HAM 180 174       -10.0593877856
HAM 174 176       -15.1221891670
HAM 176 174       -15.1221891670
HAM 174 175        -4.9463631074
HAM 175 174        -4.9463631074
HAM 174 177        20.2449951537
HAM 177 174        20.2449951537
HAM 175 177         4.2461309736
HAM 177 175         4.2461309736
HAM 182 195        53.1892049414
HAM 195 182        53.1892049414
HAM 182 192         4.0418029756
HAM 192 182         4.0418029756
HAM 183 192        37.6104475000
HAM 192 183        37.6104475000
HAM 183 195         5.7159725845
HAM 195 183         5.7159725845
HAM 183 191         9.9320810491
HAM 191 183         9.9320810491
HAM 183 184        -4.9463631074
HAM 184 183        -4.9463631074
HAM 184 187        -7.4474313928
HAM 187 184        -7.4474313928
HAM 185 187       -49.1071906307
HAM 187 185       -49.1071906307
HAM 185 189        18.5859629661
HAM 189 185        18.5859629661
HAM 185 190         2.1168581056
HAM 190 185         2.1168581056
HAM 186 196       -15.0952817015
HAM 196 186       -15.0952817015
HAM 186 194        -8.5713498230
HAM 194 186        -8.5713498230
HAM 186 193         2.8175646831
HAM 193 186         2.8175646831
HAM 187 188         2.1168581056
HAM 188 187         2.1168581056
HAM 188 190       -49.1071906307
HAM 190 188       -49.1071906307
HAM 193 195        -8.8854187243
HAM 195 193        -8.8854187243
HAM 193 194       -14.2538605748
HAM 194 193       -14.2538605748
HAM 193 196        -7.9627288995
HAM 196 193        -7.9627288995
HAM 194 196         3.0918811583
HAM 196 194         3.0918811583
HAM 195 198        28.6213026111
HAM 198 195        28.6213026111
HAM 195 197        25.9737696380
HAM 197 195        25.9737696380
HAM 195 199        27.8825741033
HAM 199 195        27.8825741033
HAM 197 198        47.0691516705
HAM 198 197        47.0691516705
HAM 197 199        47.2649412718
HAM 199 197        47.2649412718
HAM 198 199        46.4776828590
HAM 199 198        46.4776828590
HAM 200 202        49.5735503011
HAM 202 200        49.5735503011
HAM 200 201        44.9878886771
HAM 201 200        44.9878886771
HAM 200 203        48.2940349926
HAM 203 200        48.2940349926
HAM 201 202        47.0691516705
HAM 202 201        47.0691516705
HAM 201 203        47.2649412718
HAM 203 201        47.2649412718
HAM 202 204       -21.3479521101
HAM 204 202       -21.3479521101
HAM 202 203        46.4776828590
HAM 203 202        46.4776828590
HAM 203 204       -20.1580029410
HAM 204 203       -20.1580029410
Type: text/x-csrc
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160508/60d65c27/attachment-0001.c>
