[petsc-users] -snes_mf and -snes_fd
Thu May 5 12:37:42 CDT 2016
On Thu, May 5, 2016 at 12:01 PM, Juha Jaykka <juhaj at iki.fi> wrote:
> Dear list,
> I am a bit confused by some SNES options. How do -snes_mf, -snes_fd,
> SNESSetJacobian exactly interact?
> I run my code (it's basically the Bratu3D example in python) with
It would help to have -snes_monitor -snes_converged_reason here:
> -snes_fd 0 -snes_mf 0 and my RHS code gets called 7 times
This looks like 7 iterates with your assembled Jacobian. Judging from
below, it appears there might be a different PC here.
> -snes_fd 0 -snes_mf 1 and RHS called 44 times
Here each action of the Jacobian takes one RHS evaluation, and one at the
beginning of each Newton iterate.
> -snes_fd 1 -snes_mf 0 and RHS called 775 times
Here we have one RHS for each column of the Jacobian  at each Newton
iterate since we form it explicitly (actually for each color in the
graph, but that is a detail).
> -snes_fd 1 -snes_mf 1 and RHS called 44 times
The second option overrides the first.
> without -snes_mf AT ALL but with -snes_fd 0 I get RHS called 3 times [1]
I need to see the output of -snes_view for these cases. Its possible that we
have a bug related to the argument.
> without -snes_mf AT ALL but with -snes_fd 1 I get RHS called 775 times
> without -snes_mf OR -snes_fd, I get RHS called 3 times [1]
Yes.
> without -snes_fd at all and -snes_mf, I get 44 calls
> without -snes_fd at all and -snes_mf 1, I get 44 calls
These two are the same since we assume a 1 argument.
    Matt
> without -snes_fd at all and -snes_mf 0, I get 3 calls [1]
> I would have expected -snes_mf 0 and no snes_mf at all to behave in the
> same
> way. I am also puzzled by the fact that there seem to be four different
> ways
> to solve the problem: with Jacobian (3 calls), with fd (775 calls) and
> with mf
> (44 calls). What is the 7 calls case all about?
> I guess in all the years I've used PETSc I should have learnt better, but I
> had never taught it to anyone before, so hand't noticed my lack of
> knowledge.
> Cheers,
> Juha
> [1] This causes my Jacobian routine to be called as intended.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160505/5c224991/attachment.html>
