[petsc-users] Binary input-output for parallel dense matrices	(petsc4py)
    Analabha Roy
    hariseldon99 at gmail.com
    Thu Jun 30 11:30:29 CDT 2016
Hi all,
 I'm trying to do basic binary input/output for parallel matrices.
Following the example in "petsc4py/demo/binary-io/matvecio.py
<https://github.com/erdc-cm/petsc4py/blob/master/demo/binary-io/matvecio.py>
", the code below seems to work fine (raw python file attached) with
"mpirun -np 2 python ./test_binwrite.py" until I uncomment
"#A.setType(PETSc.Mat.Type.DENSE)" in order to do it for parallel dense
matrices. Then it crashes with error (stderr file attached, see below for
highlighted message).  What am I doing wrong?
Python Code
#!/usr/bin/env python
"""Created on Wed Jun 29 22:05:59 2016 at author: daneel at utexas.edu"""
import numpy as npfrom petsc4py import PETScPrint = PETSc.Sys.Print
matsize = 100
filename = 'tmpMatrix-A.dat'
A = PETSc.Mat().create(PETSc.COMM_WORLD)
A.setSizes([matsize, matsize])#A.setType(PETSc.Mat.Type.DENSE)
A.setUp()
Istart, Iend = A.getOwnershipRange()for I in xrange(Istart, Iend) :
    A[I,:] = np.random.random(matsize)
A.assemble()Print("Random matrix assembled. Now writing to temporary
file ...")# save
viewer = PETSc.Viewer().createBinary(filename, 'w')
viewer.pushFormat(viewer.Format.NATIVE)
viewer.view(A)Print("Written to ", filename)# reloadPrint("Now
reloading from ", filename)
viewer_new = PETSc.Viewer().createBinary(filename, 'r')
viewer_new.pushFormat(viewer.getFormat())
A_new = PETSc.Mat().load(viewer_new)assert A_new.equal(A), "Reload
unsuccessful"Print("Reload successful")
stderr output for parallel dense matrices:
Random matrix assembled. Now writing to temporary file ...
Written to  tmpMatrix-A.dat
Now reloading from  tmpMatrix-A.dat
Traceback (most recent call last):
  File "./test_binwrite.py", line 36, in <module>
      File "PETSc/Mat.pyx", line 642, in petsc4py.PETSc.Mat.load
(src/petsc4py.PETSc.c:118243)
petsc4py.PETSc.Errorpetsc4py.PETSc.Error: : error code 55[0] MatLoad()
line 1013 in /home/daneel/.local/src/petsc-3.7.2/src/mat/interface/matrix.c[0]
MatLoad_MPIAIJ() line 2947 in
/home/daneel/.local/src/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c[0]
Out of memory. Allocated: 0, Used by process: 23687168[0] Memory
requested 5942180016
error code 55[1] MatLoad() line 1013 in
/home/daneel/.local/src/petsc-3.7.2/src/mat/interface/matrix.c[1]
MatLoad_MPIAIJ() line 2967 in
/home/daneel/.local/src/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c[1]
Out of memory. Allocated: 0, Used by process: 23506944[1] Memory
requested 18446744072415633408
mpirun noticed that the job aborted, but has no info as to the process
that caused that situation.
Analabha Roy
Postdoctoral Fellow
National Institute of Theoretical Physics (NiTheP)
<http://www.nithep.ac.za/>
Private Bag X1, Matieland,
Stellenbosch, South Africa,7602
Emails: daneel at utexas.edu, daneel at sun.ac.za, hariseldon99 at gmail.com
Webpage: http://www.ph.utexas.edu/~daneel/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160630/df832a52/attachment-0001.html>
daneel at fis406826:~/gitrepos/ising_exact$ mpirun -np 2 ./test_binwrite.py
      File "PETSc/Mat.pyx", line 642, in petsc4py.PETSc.Mat.load (src/petsc4py.PETSc.c:118243)
[0] MatLoad() line 1013 in /home/daneel/.local/src/petsc-3.7.2/src/mat/interface/matrix.c
[0] MatLoad_MPIAIJ() line 2947 in /home/daneel/.local/src/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
[0] Out of memory. Allocated: 0, Used by process: 23687168
[0] Memory requested 5942180016
error code 55
[1] MatLoad() line 1013 in /home/daneel/.local/src/petsc-3.7.2/src/mat/interface/matrix.c
[1] MatLoad_MPIAIJ() line 2967 in /home/daneel/.local/src/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
[1] Out of memory. Allocated: 0, Used by process: 23506944
[1] Memory requested 18446744072415633408
Type: text/x-python
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160630/df832a52/attachment-0001.py>
