[petsc-users] SNESFAS for an unstructured mesh
Khai Pham
khaipham at utexas.edu
Wed Jun 29 20:34:12 CDT 2016
Hi Lawrence and Vijay,
Thanks for the suggestion. I will look at the ex65 and start from there.
On Wed, Jun 29, 2016 at 3:41 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
wrote:
> >> Thanks for your response. Is DMMoad is other special kind of data
> structure in Petsc?
> DMMoab is a concrete implementation of the DM object, which uses MOAB
> mesh database underneath.
> > Would it be possible to use FAS without using petsc DM/DMPlex by adding
> extra code?
> If you have your own mesh handling code, as Lawrence suggests, use a
> DMShell object and create appropriate wrapper routines that utilizes
> your home grown API underneath. There is a linear solver example with
> DMShell, which should help you get started. Instead of the DA object
> reference used in the shell implementation, you can replace it with
> your own structures and context.
> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex65.c.html
> Vijay
> On Wed, Jun 29, 2016 at 1:58 PM, Lawrence Mitchell
> <lawrence.mitchell at imperial.ac.uk> wrote:
> structure in Petsc? I'd like to use the petsc FAS for the finite element
> code in our group and all the data structure for mesh topology is all set.
> Thus I try to avoid all petsc data structure. As far as I know the FAS will
> construct the coarse solution based on DM for structured grid and DMPlex
> for unstructured grid as in ex12. Would it be possible to use FAS without
> using petsc DM/DMPlex by adding extra code? How much effort would you
> estimate? Thanks !
> > You can use a DMShell and just implement the needed grid transfer
> operations using your own data structures and then use the DMShellSetXXX
> interfaces to hook them up.
> > Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160629/4c6e4755/attachment.html>
