[petsc-users] Performance of mumps vs. Intel Pardiso
Faraz Hussain faraz_hussain at yahoo.com
Tue Jun 28 13:09:55 CDT 2016
Thanks, the solve times are faster after  I tried sequential symbolic factorization instead of parallel. However, they are still slower than Pardiso with 24 cpus ( 120 seconds ). I am not sure if it a configuration issue on my end or a limitation of mumps?
Is it possible for someone else to solve my matrix to verify they get the same times? If not, I will contact mumps developers to see if I can send them my matrix to benchmark.
24 cpus
MatCholFctrSym         1 1.0 1.0325e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 16  0  0  0 15  16  0  0  0 $
MatCholFctrNum         1 1.0 4.2542e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 67  0  0  0  0  67  0  0  0 $
48 cpus
MatCholFctrSym         1 1.0 4.3957e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 12  0  0  0 15  12  0  0  0 $
MatCholFctrNum         1 1.0 2.5982e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 70  0  0  0  0  70  0  0  0 $
72 cpus
MatCholFctrSym         1 1.0 4.3596e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 12  0  0  0 15  12  0  0  0 $
MatCholFctrNum         1 1.0 2.2195e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 59  0  0  0  0  59  0  0  0 $
240 cpus
MatCholFctrSym         1 1.0 4.7354e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 13  0  0  0 15  13  0  0  0 $
MatCholFctrNum         1 1.0 1.8543e+02 1.0 0.00e+00 0.0 0.0e+00
On Mon, 6/27/16, Hong <hzhang at mcs.anl.gov> wrote:
 Subject: Re: [petsc-users] Performance of mumps vs. Intel Pardiso
 To: "Faraz Hussain" <faraz_hussain at yahoo.com>
 Cc: "Barry Smith" <bsmith at mcs.anl.gov>, "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
 Date: Monday, June 27, 2016, 8:40 PM
 Faraz :Direct sparse solvers are
 generally not scalable -- they are used for ill-conditioned
 problems which cannot be solved by iterative
 methods.
 Can
 you try sequential symbolic factorization instead of
 parallel, i.e., use mumps default '-mat_mumps_icntl_28
 1'?
 Hong
 Thanks
 for the quick response. Here are the log_summary for 24, 48
 and 72 cpus:
 24 cpus
 MatSolve               1 1.0 1.8100e+00 1.0 0.00e+00
 0.0 7.0e+02 7.4e+04 3.0e+00  0  0 68  3  9   0  0
 68  3  9     0
 MatCholFctrSym         1 1.0 4.6683e+01 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 5.0e+00  6  0  0  0 15   6  0
 0  0 15     0
 MatCholFctrNum         1 1.0 5.8129e+02 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 0.0e+00 78  0  0  0  0  78  0
 0  0  0     0
 48 cpus
 MatSolve               1 1.0 1.4915e+00 1.0 0.00e+00
 0.0 1.6e+03 3.3e+04 3.0e+00  0  0 68  3  9   0  0
 68  3  9     0
 MatCholFctrSym         1 1.0 5.3486e+01 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 5.0e+00  9  0  0  0 15   9  0
 0  0 15     0
 MatCholFctrNum         1 1.0 4.0803e+02 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 0.0e+00 71  0  0  0  0  71  0
 0  0  0     0
 72 cpus
 MatSolve               1
 1.0 7.7200e+00 1.1 0.00e+00 0.0 2.6e+03 2.0e+04 3.0e+00
 1  0 68  2  9   1  0 68  2  9     0
 MatCholFctrSym         1 1.0 1.8439e+02 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 5.0e+00 29  0  0  0 15  29  0  0
 0 15     0
 MatCholFctrNum         1 1.0 3.3969e+02 1.0 0.00e+00
 0.0 0.0e+00 0.0e+00 0.0e+00 53  0  0  0  0  53  0
 0  0  0     0
 Does this look normal or is something off here?
 Regarding reordering algorithm of Pardiso. At this time I do
 not know much about that. I will do some research and see
 what I can learn. However,  I believe Mumps only has two
 options:
         -mat_mumps_icntl_29     - ICNTL(29): parallel
 ordering 1 = ptscotch, 2 = parmetis
 I have tried both and do not see any speed difference. Or
 are you referring to some other kind of reordering?
 On Mon, 6/27/16, Barry Smith <bsmith at mcs.anl.gov>
 Pardiso
  Cc: "petsc-users at mcs.anl.gov"
  Date: Monday, June 27, 2016, 5:50 PM
     These are the only lines that
  matter
  MatSolve
               1 1.0 7.7200e+00 1.1 0.00e+00
  0.0 2.6e+03 2.0e+04 3.0e+00  1  0 68  2
  9   1  0 68  2  9     0
  1.8439e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 29
 0
  0  0 15  29  0  0  0 15     0
  3.3969e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 53
 0
  0  0  0  53  0  0  0  0     0
  look at the log summary for 24
  and 48 processes. How are the symbolic and numeric
 parts
  scaling with the number of processes?
  Things that could affect the performance a lot.
  Is the symbolic factorization done in parallel? What
  reordering is used? If Pardiso is using a reordering that
 is
  better for this matrix and has (much) lower fill that
 could
  explain why it is so much faster.
   Perhaps correspond with the MUMPS developers
  on what MUMPS options might make it faster
    Barry
  > On Jun 27, 2016, at 5:39 PM, Faraz Hussain
  wrote:
  > I am
  struggling trying to understand why mumps is so much
 slower
  than Intel Pardiso solver for my simple test matrix (
  3million^2 sparse symmetrix matrix with ~1000 non-zero
  entries per line ).
  > My compute nodes have 24 cpus each. Intel
  Pardiso solves it in in 120 seconds using all 24 cpus of
 one
  node. With Mumps I get:
  > 24 cpus - 765 seconds
  48 cpus - 401 seconds
  > 72 cpus - 344
  seconds
  > beyond 72 cpus no speed
  improvement.
  > I am attaching the -log_summary to see if
  there is something wrong in how I am solving the problem.
 I
  am really hoping mumps will be faster when using more
 cpus..
  Otherwise I will have to abort my exploration of
  mumps!<log_summary.o265103>
