[petsc-users] Performance of mumps vs. Intel Pardiso
Faraz Hussain
faraz_hussain at yahoo.com
Mon Jun 27 19:59:39 CDT 2016
Thanks for the quick response. Here are the log_summary for 24, 48 and 72 cpus:
24 cpus
MatSolve 1 1.0 1.8100e+00 1.0 0.00e+00 0.0 7.0e+02 7.4e+04 3.0e+00 0 0 68 3 9 0 0 68 3 9 0
MatCholFctrSym 1 1.0 4.6683e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 6 0 0 0 15 6 0 0 0 15 0
MatCholFctrNum 1 1.0 5.8129e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 78 0 0 0 0 78 0 0 0 0 0
48 cpus
MatSolve 1 1.0 1.4915e+00 1.0 0.00e+00 0.0 1.6e+03 3.3e+04 3.0e+00 0 0 68 3 9 0 0 68 3 9 0
MatCholFctrSym 1 1.0 5.3486e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 9 0 0 0 15 9 0 0 0 15 0
MatCholFctrNum 1 1.0 4.0803e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 71 0 0 0 0 71 0 0 0 0 0
72 cpus
MatSolve 1 1.0 7.7200e+00 1.1 0.00e+00 0.0 2.6e+03 2.0e+04 3.0e+00 1 0 68 2 9 1 0 68 2 9 0
MatCholFctrSym 1 1.0 1.8439e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00 29 0 0 0 15 29 0 0 0 15 0
MatCholFctrNum 1 1.0 3.3969e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 53 0 0 0 0 53 0 0 0 0 0
Does this look normal or is something off here? Regarding reordering algorithm of Pardiso. At this time I do not know much about that. I will do some research and see what I can learn. However, I believe Mumps only has two options:
-mat_mumps_icntl_29 - ICNTL(29): parallel ordering 1 = ptscotch, 2 = parmetis
I have tried both and do not see any speed difference. Or are you referring to some other kind of reordering?
On Mon, 6/27/16, Barry Smith <bsmith at mcs.anl.gov> wrote:
Subject: Re: [petsc-users] Performance of mumps vs. Intel Pardiso
To: "Faraz Hussain" <faraz_hussain at yahoo.com>
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Date: Monday, June 27, 2016, 5:50 PM
These are the only lines that
matter
MatSolve
9 1 0 68 2 9 0
0 0 0 53 0 0 0 0 0
look at the log summary for 24
and 48 processes. How are the symbolic and numeric parts
scaling with the number of processes?
Things that could affect the performance a lot.
Is the symbolic factorization done in parallel? What
reordering is used? If Pardiso is using a reordering that is
better for this matrix and has (much) lower fill that could
explain why it is so much faster.
Perhaps correspond with the MUMPS developers
on what MUMPS options might make it faster
Barry
> On Jun 27, 2016, at 5:39 PM, Faraz Hussain
wrote:
> I am
struggling trying to understand why mumps is so much slower
than Intel Pardiso solver for my simple test matrix (
3million^2 sparse symmetrix matrix with ~1000 non-zero
entries per line ).
> My compute nodes have 24 cpus each. Intel
Pardiso solves it in in 120 seconds using all 24 cpus of one
node. With Mumps I get:
> 24 cpus - 765 seconds
48 cpus - 401 seconds
> 72 cpus - 344
seconds
> beyond 72 cpus no speed
improvement.
> I am attaching the -log_summary to see if
there is something wrong in how I am solving the problem. I
am really hoping mumps will be faster when using more cpus..
Otherwise I will have to abort my exploration of
mumps!<log_summary.o265103>
