[petsc-users] SetVariableBounds vs ComputeVariableBounds
Justin Chang
jychang48 at gmail.com
Mon Jun 27 12:37:38 CDT 2016
So I figured it out. I had to explicitly form the Tao Gradient/Constraints
and Jacobian. I couldn't just "pre-process" the gradient Vec and Jacobian
Mat through SNESComputeXXX. Attached is the updated file and makefile.
My question now is, why exactly is this the case? This preprocessing
strategy seemed to work for bounded constrained optimization solvers (e.g.,
TRON/BLMVM) but apparently not with the MCP ones. The system is linear so
my original reasoning was that the Jacobian shouldn't change, thus it just
needs to be assembled once. I recall faintly from a previous discussion
that the SNESVI solvers will vary the Mat and Vec sizes depending on the
regions that need to be "constrained" or something?
Justin
On Sun, Jun 26, 2016 at 5:03 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I wish I could answer this but I am weak on these algorithms. Hopefully
> Todd has a good understanding of their application and strengths and
> weaknesses.
> Barry
> > On Jun 25, 2016, at 3:31 PM, Justin Chang <jychang48 at gmail.com> wrote:
> > Hi all,
> > So I modified SNES ex9.c so that one has the option to use TAO's
> complementarity solvers for this problem. Attached is the file.
> > I expect the TAO solvers to behave the same as the SNESVI ones, but I am
> having the same issues as before - SSILS and SSFLS do not work whatsoever
> but for some reason ASILS and ASFLS work. Although the latter two produce
> the same results as the SNES VI counterparts, they converge much slower,
> and something tells me I am not doing something correctly. Based on what I
> have seen from the two TAO complementarity examples, I would also expect
> the AS and SS solvers to be roughly the same.
> > BTW, in the modified code, I made some "shortcuts." Instead of
> explicitly forming the Tao versions of the Gradient and Jacobian, I first
> assemble the residual r and Jacobian J through the SNESComputeXXX
> functions. Then I pass them into the TaoSetConstraints and TaoSetJacobian
> routines. Because this is a linear system, I have:
> > f = r - J*u^0
> > gradient g = J*u - f = J*(u + *u^0) + r
> > were u^0 is the initial vector. I am not sure if this "shortcut" has
> anything to do with the issue at hand. Attached is the makefile which has
> instructions on how to run the problem.
> > Any ideas what is going on??
> > Thanks!
> > Justin
> > On Wed, Jun 22, 2016 at 9:42 PM, Ed Bueler <elbueler at alaska.edu> wrote:
> > Justin --
> > Yeah, good point. SNESVISetVariableBounds() works fine, at least in
> ex9.c (see attached patch). The reason for the other choice, which I found
> in my 5 year old email, was some bug in petsc3.2.
> > Ed
> > Date: Wed, 22 Jun 2016 08:42:33 +0100
> > From: Justin Chang <jychang48 at gmail.com>
> > To: petsc-users <petsc-users at mcs.anl.gov>
> > Subject: [petsc-users] SetVariableBounds vs ComputeVariableBounds
> > Hi all,
> > I am looking at the SNES tutorials ex9.c and ex58.c and am wondering why
> > SNESVISetComputeVariableBounds() is called instead of just
> > SNESVISetVariableBounds(). When would it be appropriate to use only using
> > the latter?
> > Thanks,
> > Justin
> > <ex9_TAO.c><makefile>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160627/1cb4ffc5/attachment.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160627/1cb4ffc5/attachment.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160627/1cb4ffc5/attachment.obj>
