[petsc-users] undefined symbol: mpi_init_
Antonio Trande
anto.trande at gmail.com
Sun Jun 26 14:32:26 CDT 2016
On 06/26/2016 02:24 AM, Satish Balay wrote:
> On Sat, 25 Jun 2016, Antonio Trande wrote:
>> On 06/25/2016 09:41 PM, Antonio Trande wrote:
>>> On 06/25/2016 03:59 PM, Matthew Knepley wrote:
>>>> On Sat, Jun 25, 2016 at 8:21 AM, Antonio Trande <anto.trande at gmail.com
>>>> <mailto:anto.trande at gmail.com>> wrote:
>>>> Hi all,
>>>> is it possible to compile serial PETSc library ?
>>>> I'm trying to compile PETSc without MPI by configuring with options:
>>>> --with-mpi=0 --with-mpiuni-fortran-binding=0
>>>> but compiler uses -I/.../petsc-3.7.2/include/petsc/mpiuni flag anyway
>>>> and libpetsc.so contains an "undefined symbol":
>>>> undefined symbol: mpi_init_ (/usr/lib64/libpetsc.so.3.7.2)
>>>> How I can fix this issue ?
>>>> Full log:
>>>> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00362302-petsc/build.log.gz
>>>> 1) Why are you giving --with-mpiuni-fortran-binding=0 if you still have
>>>> Fortran turned on? If you want to turn off Fortran, use --with-fc=0.
>>> I did't know what it does. If I active --with-mpiuni-fortran-binding,
>>> 'undefined symbol' disappears.
>>>> 2) You did not send configure.log which is what I need, not a screen
>>>> capture.
>>>> 3) I cannot see the error you sent anywhere. It would be more useful to
>>>> send the output from 'make test'.
>>>> Matt
>>> I send you all config.log; petsc-serial, petsc-serial (64bit integer),
>>> petsc-openmpi and petsc-mpich are compiled from an own fresh source
>>> directory, respectively from petsc-3.7.2, build64, buildopenmpi_dir,
>>> buildmpich_dir.
>>> All libraries look compiled fine and related test passed.
>>> I will send you latest builds log from Fedora Copr build-system.
>> No, tests not passed with
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> This is a build log from Fedora 24 64 bit:
>> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00362535-petsc/build.log.gz
> + echo 'Patch #1 (petsc-lib64.patch):'
> + /usr/bin/patch -p0 --fuzz=0
> patching file config/BuildSystem/config/setCompilers.py
> patching file gmakefile
> Patch #0 (petsc-3.7-no-rpath.patch):
> Well looks like there were some modifications done to get the 'multi-variant' build working.
Yes.
> + make test -C petsc-3.7.2
> make: Entering directory '/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2'
> Running test examples to verify correct installation
> Using PETSC_DIR=/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2 and PETSC_ARCH=x86_64
> *******************Error detected during compile or link!*******************
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> /builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/src/snes/examples/tutorials ex19
> gcc -o ex19.o -c -O2 -fPIC -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic -fopenmp -I/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/include -I/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/x86_64/include -I/usr/include -I/usr/include/suitesparse -I/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/include/petsc/mpiuni `pwd`/ex19.c
> gcc -Wl,-z,relro -O2 -fPIC -O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic -fopenmp -o ex19 ex19.o -L/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/x86_64/lib -L/builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/x86_64/lib -lpetsc -lmetis -L/usr/lib64 -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -llapack -lblas -lOpenCL -lhwloc -lpapi -lgmp -lpthread -ljpeg -lpng -lm -L/usr/lib/gcc/x86_64-redhat-linux/6.1.1 -lgfortran -lm -lgfortran -lm -lquadmath -lm -lstdc++ -L/usr/lib/gcc/x86_64-redhat-linux/6.1.1 -ldl -lgcc_s -ldl
> /usr/bin/rm -f ex19.o
> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
> [0]PETSC ERROR: #1 PetscLogInitialize() line 219 in /builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/src/sys/logging/plog.c
> [0]PETSC ERROR: #2 PetscInitialize() line 891 in /builddir/build/BUILD/petsc-3.7.2/petsc-3.7.2/src/sys/objects/pinit.c
> /usr/bin/sh: line 13: 16933 Aborted (core dumped)
> So there is no -rpath here. Which -lpetsc variant is getting used at runtime?
Yes, no rpaths for the serial libraries, so 'libpetsc.so' and
'libpetsc64.so' (renamed for mine needs).
Test reported is for PETSc (32 bit integer) serial library: libpetsc.so
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160626/b06a338c/attachment.pgp>
