[petsc-users] Tips on integrating petsc into my application?
Faraz Hussain
faraz_hussain at yahoo.com
Thu Jun 23 08:06:19 CDT 2016
I have successfully integrated petsc into my application . However, when I do mpiexec -np x, then each process reads my input deck and consumes a lot of memory allocating all the data for the arrays.
I believe I need to have only rank 0 do all the processing? What I have tried to do is put a giant if statement in my main function as follows:
if ( ! rank ) {
run_app();
However, when I run with more than np > 1, the code just hangs when it gets to the petsc.c code. I moved PetscInitializeNoArguments() into my main function. Does it need to be in both main and my petsc.c code? Do I need to pass PETSC_COMM_WORLD to my petsc.c code?
To: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Sent: Wednesday, June 22, 2016 9:35 AM
Subject: Example on using VecGetValues?
I am trying to get my petsc vector of values into my c array of doubles. I tried this but it keeps giving value of 0:
VecScatter ctx;
VecScatterCreateToZero(petsc_x,&ctx,&petsc_b);
VecScatterBegin(ctx,petsc_x,petsc_b,INSERT_VALUES,SCATTER_FORWARD);
VecScatterEnd(ctx,petsc_x,petsc_b,INSERT_VALUES,SCATTER_FORWARD);
VecScatterDestroy(&ctx);
VecView( petsc_b,PETSC_VIEWER_STDOUT_WORLD);
PetscScalar value;
for ( row=0; row < size ; row++ ) {
ierr = VecGetValues( petsc_b, 0, row, &value );CHKERRQ(ierr);
b[row] = value;
printf ( "Value is %.17g\n", b[row]);
It keeps printing this out, but the values should be real numbers, not 0:
Value is 0
Value is 0
Value is 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160623/e093ae57/attachment-0001.html>
