[petsc-users] SetVariableBounds vs ComputeVariableBounds
Ed Bueler elbueler at alaska.edu
Wed Jun 22 14:42:12 CDT 2016
Justin --
Yeah, good point.  SNESVISetVariableBounds() works fine, at least in ex9.c
(see attached patch).  The reason for the other choice, which I found in my
5 year old email, was some bug in petsc3.2.
Ed
Date: Wed, 22 Jun 2016 08:42:33 +0100
> From: Justin Chang <jychang48 at gmail.com>
> To: petsc-users <petsc-users at mcs.anl.gov>
> Subject: [petsc-users] SetVariableBounds vs ComputeVariableBounds
> Hi all,
> I am looking at the SNES tutorials ex9.c and ex58.c and am wondering why
> SNESVISetComputeVariableBounds() is called instead of just
> SNESVISetVariableBounds(). When would it be appropriate to use only using
> the latter?
> Thanks,
> Justin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160622/54434ed1/attachment-0001.html>
diff --git a/src/snes/examples/tutorials/ex9.c b/src/snes/examples/tutorials/ex9.c
index 4e57917..acd5ca7 100644
--- a/src/snes/examples/tutorials/ex9.c
+++ b/src/snes/examples/tutorials/ex9.c
@@ -42,7 +42,6 @@ typedef struct {
 } ObsCtx;
 extern PetscErrorCode FormPsiAndExactSoln(DM);
-extern PetscErrorCode FormBounds(SNES,Vec,Vec);
 extern PetscErrorCode FormFunctionLocal(DMDALocalInfo*,PetscScalar**,PetscScalar**,ObsCtx*);
 extern PetscErrorCode FormJacobianLocal(DMDALocalInfo*,PetscScalar**,Mat,Mat,ObsCtx*);
@@ -54,7 +53,8 @@ int main(int argc,char **argv)
   ObsCtx              user;
   SNES                snes;
   DM                  da;
-  Vec                 u;     /* solution */
+  Vec                 u,     /* solution */
+                      Xu;    /* upper bound */
   DMDALocalInfo       info;
   PetscReal           error1,errorinf;
@@ -84,7 +84,12 @@ int main(int argc,char **argv)
   ierr = SNESSetDM(snes,da);CHKERRQ(ierr);
   ierr = SNESSetApplicationContext(snes,&user);CHKERRQ(ierr);
   ierr = SNESSetType(snes,SNESVINEWTONRSLS);CHKERRQ(ierr);
-  ierr = SNESVISetComputeVariableBounds(snes,&FormBounds);CHKERRQ(ierr);
+  /* set upper and lower bound constraints for VI */
+  ierr = VecDuplicate(u,&Xu);CHKERRQ(ierr);
+  ierr = VecSet(Xu,PETSC_INFINITY);CHKERRQ(ierr);
+  ierr = SNESVISetVariableBounds(snes,user.psi,Xu);CHKERRQ(ierr);
+  ierr = VecDestroy(&Xu);CHKERRQ(ierr);
   ierr = DMDASNESSetFunctionLocal(da,INSERT_VALUES,(PetscErrorCode (*)(DMDALocalInfo*,void*,void*,void*))FormFunctionLocal,&user);CHKERRQ(ierr);
   ierr = DMDASNESSetJacobianLocal(da,(PetscErrorCode (*)(DMDALocalInfo*,void*,Mat,Mat,void*))FormJacobianLocal,&user);CHKERRQ(ierr);
@@ -158,22 +163,6 @@ PetscErrorCode FormPsiAndExactSoln(DM da) {
 #undef __FUNCT__
-#define __FUNCT__ "FormBounds"
-/*  FormBounds() for call-back: tell SNESVI (variational inequality)
-  that we want u >= psi */
-PetscErrorCode FormBounds(SNES snes, Vec Xl, Vec Xu) {
-  PetscErrorCode ierr;
-  ObsCtx         *user;
-  PetscFunctionBeginUser;
-  ierr = SNESGetApplicationContext(snes,&user);CHKERRQ(ierr);
-  ierr = VecCopy(user->psi,Xl);CHKERRQ(ierr);  /* u >= psi */
-  ierr = VecSet(Xu,PETSC_INFINITY);CHKERRQ(ierr);
-  PetscFunctionReturn(0);
-#undef __FUNCT__
 #define __FUNCT__ "FormFunctionLocal"
 /* FormFunctionLocal - Evaluates nonlinear function, F(x) on local process patch */
 PetscErrorCode FormFunctionLocal(DMDALocalInfo *info,PetscScalar **x,PetscScalar **f,ObsCtx *user) {
diff --git a/src/snes/examples/tutorials/output/ex9_5.out b/src/snes/examples/tutorials/output/ex9_5.out
index d465a07..8b81a5b 100644
--- a/src/snes/examples/tutorials/output/ex9_5.out
+++ b/src/snes/examples/tutorials/output/ex9_5.out
@@ -1,6 +1,6 @@
 setup done: grid  Mx,My = 11,11  with spacing  dx,dy = 0.4000,0.4000
   0 SNES Function norm 3.8949
   1 SNES Function norm 0.595977
-  2 SNES Function norm 1.33042e-06
+  2 SNES Function norm 1.33052e-06
   3 SNES Function norm < 1.e-11
 errors:     av |u-uexact|  = 7.156e-03    |u-uexact|_inf = 2.550e-02
diff --git a/src/snes/examples/tutorials/output/ex9_6.out b/src/snes/examples/tutorials/output/ex9_6.out
index bbcd4d9..7f04d68 100644
--- a/src/snes/examples/tutorials/output/ex9_6.out
+++ b/src/snes/examples/tutorials/output/ex9_6.out
@@ -1,53 +1,53 @@
 setup done: grid  Mx,My = 81,81  with spacing  dx,dy = 0.0500,0.0500
   0 SNES Function norm 8.91139
-    0 KSP Residual norm 7.66854
-    1 KSP Residual norm 0.0817114
-    2 KSP Residual norm 0.0014303
-    3 KSP Residual norm 4.09214e-05
+    0 KSP Residual norm 7.66838
+    1 KSP Residual norm 0.0855604
+    2 KSP Residual norm 0.00147261
+    3 KSP Residual norm 4.02632e-05
   1 SNES Function norm 1.79664
-    0 KSP Residual norm 3.66508
-    1 KSP Residual norm 0.0254715
-    2 KSP Residual norm 0.000698771
-    3 KSP Residual norm 1.52442e-05
+    0 KSP Residual norm 3.66486
+    1 KSP Residual norm 0.0256337
+    2 KSP Residual norm 0.000698574
+    3 KSP Residual norm 1.50355e-05
   2 SNES Function norm 0.965357
-    0 KSP Residual norm 2.0992
-    1 KSP Residual norm 0.0107506
-    2 KSP Residual norm 0.000332135
-    3 KSP Residual norm 7.30506e-06
+    0 KSP Residual norm 2.09921
+    1 KSP Residual norm 0.010811
+    2 KSP Residual norm 0.000336569
+    3 KSP Residual norm 7.32146e-06
   3 SNES Function norm 0.602599
-    0 KSP Residual norm 1.33076
-    1 KSP Residual norm 0.00851554
-    2 KSP Residual norm 0.000224731
-    3 KSP Residual norm 4.94949e-06
+    0 KSP Residual norm 1.33072
+    1 KSP Residual norm 0.0085465
+    2 KSP Residual norm 0.000224369
+    3 KSP Residual norm 4.90542e-06
   4 SNES Function norm 0.37491
-    0 KSP Residual norm 0.826408
-    1 KSP Residual norm 0.00409587
-    2 KSP Residual norm 0.000122243
-    3 KSP Residual norm 2.85825e-06
+    0 KSP Residual norm 0.826413
+    1 KSP Residual norm 0.00411738
+    2 KSP Residual norm 0.000124072
+    3 KSP Residual norm 2.84879e-06
   5 SNES Function norm 0.215489
-    0 KSP Residual norm 0.419143
-    1 KSP Residual norm 0.00291159
-    2 KSP Residual norm 8.03321e-05
-    3 KSP Residual norm 1.69582e-06
+    0 KSP Residual norm 0.41911
+    1 KSP Residual norm 0.00292809
+    2 KSP Residual norm 8.03589e-05
+    3 KSP Residual norm 1.69054e-06
   6 SNES Function norm 0.110008
-    0 KSP Residual norm 0.145017
-    1 KSP Residual norm 0.00102091
-    2 KSP Residual norm 2.75348e-05
-    3 KSP Residual norm 5.21408e-07
+    0 KSP Residual norm 0.144991
+    1 KSP Residual norm 0.00101012
+    2 KSP Residual norm 2.76287e-05
+    3 KSP Residual norm 5.30273e-07
   7 SNES Function norm 0.0509393
-    0 KSP Residual norm 0.06307
-    1 KSP Residual norm 0.000503537
-    2 KSP Residual norm 1.32709e-05
-    3 KSP Residual norm 3.31102e-07
+    0 KSP Residual norm 0.0630681
+    1 KSP Residual norm 0.00050114
+    2 KSP Residual norm 1.32608e-05
+    3 KSP Residual norm 3.33183e-07
   8 SNES Function norm 0.00699757
-    0 KSP Residual norm 0.00485744
-    1 KSP Residual norm 3.93063e-05
-    2 KSP Residual norm 1.07492e-06
-    3 KSP Residual norm 2.17717e-08
-  9 SNES Function norm 9.21939e-08
-    0 KSP Residual norm 2.17718e-08
-    1 KSP Residual norm 8.694e-10
-    2 KSP Residual norm 2.238e-11
+    0 KSP Residual norm 0.00485817
+    1 KSP Residual norm 3.88895e-05
+    2 KSP Residual norm 1.07055e-06
+    3 KSP Residual norm 2.16788e-08
+  9 SNES Function norm 9.18511e-08
+    0 KSP Residual norm 2.16788e-08
+    1 KSP Residual norm 8.553e-10
+    2 KSP Residual norm 2.212e-11
     3 KSP Residual norm < 1.e-11
     4 KSP Residual norm < 1.e-11
  10 SNES Function norm < 1.e-11
diff --git a/src/snes/examples/tutorials/output/ex9_7.out b/src/snes/examples/tutorials/output/ex9_7.out
index e4b2c9c..27ca8d8 100644
--- a/src/snes/examples/tutorials/output/ex9_7.out
+++ b/src/snes/examples/tutorials/output/ex9_7.out
@@ -1,18 +1,18 @@
 setup done: grid  Mx,My = 21,21  with spacing  dx,dy = 0.2000,0.2000
   0 SNES Function norm 4.16496
-    0 SNES VI Function norm 5.529305066445e+00 Active lower constraints 69/79 upper constraints 0/0 Percent of total 0.156463 Percent of bounded 0.
-    1 SNES VI Function norm 6.955134607642e-01 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.
-    0 SNES VI Function norm 6.955134607642e-01 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.
-    1 SNES VI Function norm 2.094553435635e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
+    0 SNES VI Function norm 5.52931 Active lower constraints 69/79 upper constraints 0/0 Percent of total 0.156463 Percent of bounded 0.156463
+    1 SNES VI Function norm 0.695513 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.129252
+    0 SNES VI Function norm 0.695513 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.129252
+    1 SNES VI Function norm 0.209455 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.111111
   1 SNES Function norm 0.209455
-    0 SNES VI Function norm 2.094553435635e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
-    1 SNES VI Function norm 8.520955028454e-02 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    0 SNES VI Function norm 8.520955028454e-02 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 1.306727995906e-02 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 0.209455 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.111111
+    1 SNES VI Function norm 0.0852096 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    0 SNES VI Function norm 0.0852096 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 0.0130673 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   2 SNES Function norm 0.0130673
-    0 SNES VI Function norm 1.306727995906e-02 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 5.700004299565e-08 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    0 SNES VI Function norm 5.700004299565e-08 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 4.214574191759e-13 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 0.0130673 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 5.7e-08 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    0 SNES VI Function norm 5.7e-08 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 4.21547e-13 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
 errors:     av |u-uexact|  = 1.287e-03    |u-uexact|_inf = 7.882e-03
diff --git a/src/snes/examples/tutorials/output/ex9_8.out b/src/snes/examples/tutorials/output/ex9_8.out
index 24cc9a2..10f06d0 100644
--- a/src/snes/examples/tutorials/output/ex9_8.out
+++ b/src/snes/examples/tutorials/output/ex9_8.out
@@ -1,18 +1,18 @@
   1 SNES Function norm 0.695513
-    1 SNES VI Function norm 2.242112530318e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
+    1 SNES VI Function norm 0.224211 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.111111
   2 SNES Function norm 0.224211
-    0 SNES VI Function norm 2.242112530318e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
-    1 SNES VI Function norm 8.520960015422e-02 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 0.224211 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.111111
   3 SNES Function norm 0.0852096
-    0 SNES VI Function norm 8.520960015422e-02 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 3.719497543884e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    1 SNES VI Function norm 3.7195e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   4 SNES Function norm 3.7195e-07
-    0 SNES VI Function norm 3.719497543884e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 2.762524667649e-12 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 3.7195e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 2.76257e-12 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   5 SNES Function norm < 1.e-11
diff --git a/src/snes/examples/tutorials/output/ex9_9.out b/src/snes/examples/tutorials/output/ex9_9.out
index ef6570a..77ab4ee 100644
--- a/src/snes/examples/tutorials/output/ex9_9.out
+++ b/src/snes/examples/tutorials/output/ex9_9.out
@@ -1,21 +1,21 @@
   1 SNES Function norm 0.708647
-    0 SNES VI Function norm 6.520805467410e-01 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.
-    1 SNES VI Function norm 2.242111559824e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
+    0 SNES VI Function norm 0.652081 Active lower constraints 57/69 upper constraints 0/0 Percent of total 0.129252 Percent of bounded 0.129252
   2 SNES Function norm 0.759478
-    0 SNES VI Function norm 2.242111559824e-01 Active lower constraints 49/57 upper constraints 0/0 Percent of total 0.111111 Percent of bounded 0.
-    1 SNES VI Function norm 8.520960016210e-02 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
   3 SNES Function norm 0.134526
-    0 SNES VI Function norm 1.345259947681e-01 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 2.347080344381e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 0.134526 Active lower constraints 45/49 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 2.34708e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   4 SNES Function norm 0.00191518
-    0 SNES VI Function norm 1.915180573496e-03 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 3.337090244033e-09 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 0.00191518 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 3.33709e-09 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   5 SNES Function norm 3.82153e-07
-    0 SNES VI Function norm 3.821526562597e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
-    1 SNES VI Function norm 7.033950685756e-13 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.
+    0 SNES VI Function norm 3.82153e-07 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
+    1 SNES VI Function norm 7.03211e-13 Active lower constraints 45/45 upper constraints 0/0 Percent of total 0.102041 Percent of bounded 0.102041
   6 SNES Function norm < 1.e-11
