[petsc-users] [petsc-maint] VecGetSubVector causes NaN
Wed Jun 22 14:03:14 CDT 2016
On Wed, Jun 22, 2016 at 11:54 AM, ehsan sadrfaridpour <it.sadr at gmail.com>
wrote:
> Thanks a lot for your prompt reply and useful advice.
> I have another question. In my current case, I don't change any value in
> the sub-vector and in another words I used it as read-only.
> What should I do after I don't need it anymore?
> Should I call VecRestoreSubVector method or it is faster if I call the
> Destroy method on the sub-vector ?
Restore not Destroy for subvec.
> If I understand you correctly, the subvector doesn't have any space for
> itself, in that case Destroy method does not release the memory.
> And finally, I destroy the original vector after I call either Restore or
> Destroy on the sub-vector.
Yes, after Restore.
  Matt
> Best,
> Ehsan
> On Wed, Jun 22, 2016 at 12:44 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jun 22, 2016 at 9:21 AM, ehsan sadrfaridpour <it.sadr at gmail.com>
>> wrote:
>>> Hi,
>>> If I use VecGetSubVector to get a subvector it works fine as far as I
>>> don't destroy the original vector.
>>> But, if I destroy the original vector, I get NaN values. So, it is my
>>> misunderstanding of what the function suppose to do, or is it a problem?
>> You cannot destroy the original vector since you still need to call
>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecRestoreSubVector.html#VecRestoreSubVector
>>> I do the same thing with MatGetSubMatrix
>>> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetSubMatrix.html#MatGetSubMatrix>
>>> and I haven't had any problem with it.
>> MatGetSubMatrix() is a hybrid since for INITIAL_MATRIX it creates a new
>> matrix, whereas for REUSE_MATRIX it refills and existing
>> one. However there is not Restore().
>>    Matt
>> Best,
>>> Ehsan
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160622/9b801f69/attachment.html>
