[petsc-users] Problem with interpolating projected field of quadratic order
Sander Arens
Sander.Arens at ugent.be
Sat Jun 18 12:49:08 CDT 2016
> 1) Does the test run for you?
I ran the tests and they all pass.
2) If so, then could it be that you assume something about the order of
> functions?
I'm not really sure what you mean with this.
So the values in 'u' are the FEM coefficients for the coordinate function
> {x, y}. Why are you calling 'x' projected and
> 'y' interpolated?
No, u is a vector with three fields which are obtained in the following way:
1) Project the coordinates onto field nr 0 so that I have the coordinates
for all the dofs
2) Project the coordinates onto field nr 1, so that I get the coordinates
at the centroid of the cell
3) Project field nr 0 onto field nr 2, so that I get the coordinates at the
I then output the values of the different fields, so that I can compare the
values of field 1 and 2.
What I would expect is that the values of field 1 and 2 would be the same.
This is the case for field 0 being P1, but not for P2.
I also projected the coordinates onto a P2 field in
snes/examples/tutorials/ex77.c, but this was done using DMPlexCreateBoxMesh
and gave no problems.
Maybe it's some assumption on the vertex numbering in
DMPlexCreateFromCellList or DMPlexCreateFromFile that I'm not aware of?
I hope I made the problem clearer now?
Sander
On 18 June 2016 at 16:33, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jun 18, 2016 at 9:26 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Sat, Jun 18, 2016 at 8:56 AM, Sander Arens <Sander.Arens at ugent.be>
>> wrote:
>>> Hello all,
>>> Recently I've been trying to run a fem problem using DMPlex, PetscFE,
>>> etc. using a mesh created with gmsh. I used DMPlexReverseCell to get rid of
>>> the negative jacobian determinants. However, I noticed another problem:
>>> when I projected the coordinates on a quadratic fem-field and interpolated
>>> them they didn't match the interpolated values of the original coordinate
>>> field anymore.
>>> I attached a simple test to reproduce this. With linear interpolation I
>>> see no problem, it's only when I start using quadratic interpolation.
>>> I have no idea why this is giving problems. Am I missing something
>>> simple here or is this a bug?
>> Tests for this already exist
>> https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/src/dm/impls/plex/examples/tests/ex3.c?at=master&fileviewer=file-view-default
>> with run parameters here:
>> https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/config/builder.py?at=master&fileviewer=file-view-default#builder.py-58
>> and specifically for P2 triangles
>> https://bitbucket.org/petsc/petsc/src/996a00f1a1693e2d85044ed633fe1848cf357f2a/config/builder.py?at=master&fileviewer=file-view-default#builder.py-72
>> ./config/builder2.py check src/dm/impls/plex/examples/tests/ex3.c
>> functions?
> I am having a hard time understanding what you are doing here:
> /* View the projected coordinates field */
> ierr = VecGetSubVector(u, fields[0], &subvec);CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) subvec, fieldNames[0]);CHKERRQ(ierr);
> ierr = VecViewFromOptions(subvec, NULL, "-projectedcoordinates_vec_view");CHKERRQ(ierr);
> ierr = VecRestoreSubVector(u, fields[0], &subvec);CHKERRQ(ierr);
> /* View the interpolated coordinates field */
> ierr = VecGetSubVector(u, fields[1], &subvec);CHKERRQ(ierr);
> ierr = PetscObjectSetName((PetscObject) subvec, fieldNames[1]);CHKERRQ(ierr);
> ierr = VecViewFromOptions(subvec, NULL, "-interpolatedcoordinates_vec_view");CHKERRQ(ierr);
> ierr = VecRestoreSubVector(u, fields[1], &subvec);CHKERRQ(ierr);
> 'y' interpolated?
> Thanks,
> Matt
>> Thanks,
>> Matt
>>> Thanks,
>>> Sander
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160618/31b2fe6e/attachment.html>
