[petsc-users] TSSetExactFinalTime Behavior Without TSAdapt
Fri Jun 17 15:32:33 CDT 2016
   Yeah this is an error. Just keep the TSSetFromOptions() in there and it will be fine.
   Barry
> On Jun 17, 2016, at 2:59 PM, Paul Urbanczyk <gomer at stanford.edu> wrote:
> Hello Hong,
> I went back, removed the following:
> TSAdapt ts_adapt;
> TSGetAdapt(ts_solver,&ts_adapt);
> TSAdaptSetType(ts_adapt,TSADAPTNONE);
> And then added the following before TSSolve():
> TSSetFromOptions(ts_solver);
> The code runs without problem. So, it appears that the TSAdapt behavior either has to be set manually, or it needs to be set by default from TSSetFromOptions. Apparently, it is not being set correctly in TSCreate?
> Thanks,
> Paul
> On 06/08/2016 08:47 PM, Hong Zhang wrote:
>> Add TSSetFromOptions(ts_solver) before TSSolve(). Please let us know if it works.
>> Hong
>>> On Jun 7, 2016, at 12:49 PM, Paul Urbanczyk <gomer at stanford.edu> wrote:
>>> Hello,
>>> See below for my initial code, before adding TSSetExactFinalTime.
>>> That version yielded the following error:
>>> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>>> [0]PETSC ERROR: Object is in wrong state
>>> [0]PETSC ERROR: You must call TSSetExactFinalTime() or use -ts_exact_final_time <stepover,interpolate,matchstep> before calling TSSolve()
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.7.1-449-g419beca  GIT Date: 2016-06-01 15:39:33 -0500
>>> [0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by gomer Tue Jun  7 12:42:05 2016
>>> [0]PETSC ERROR: Configure options
>>> [0]PETSC ERROR: #1 TSSolve() line 3946 in /home/gomer/local/petsc/src/ts/interface/ts.c
>>> I then added:
>>> TSSetExactFinalTime(ts_solver,TS_EXACTFINALTIME_STEPOVER);
>>> Running then yielded the following error:
>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>> [0]PETSC ERROR: likely location of problem given in stack below
>>> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>> [0]PETSC ERROR:       is given.
>>> [0]PETSC ERROR: [0] TSAdaptChoose line 571 /home/gomer/local/petsc/src/ts/adapt/interface/tsadapt.c
>>> [0]PETSC ERROR: [0] TSStep_Euler line 20 /home/gomer/local/petsc/src/ts/impls/explicit/euler/euler.c
>>> [0]PETSC ERROR: [0] TSStep line 3707 /home/gomer/local/petsc/src/ts/interface/ts.c
>>> [0]PETSC ERROR: [0] TSSolve line 3928 /home/gomer/local/petsc/src/ts/interface/ts.c
>>> [0]PETSC ERROR: Signal received
>>> [0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named prometheus by gomer Tue Jun  7 12:44:17 2016
>>> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
>>> Finally, I added
>>> TSAdapt ts_adapt;
>>> After adding this, the program runs without error.
>>> Hope that helps.
>>> Please let me know if I was doing something wrong before to have caused this. It's not pressing for me, though, as my code now appears to be running ok.
>>> -Paul
>>> ORIGINAL VERSION WITHOUT TSSetExactFinalTime:
>>> void cPETScSolverClass::SolveTSProblem()
>>>    if(mpi_main.getRank() == 0)
>>>        std::cout << "*****STARTING SOLUTION*****" << std::endl;
>>>    // Set up the time-stepping solver object
>>>    TSCreate(PETSC_COMM_WORLD,&ts_solver);
>>>    // Set the problem type to be nonlinear
>>>    TSSetProblemType(ts_solver,TS_NONLINEAR);
>>>    // Point the solution to the solution vector (vector of conserved variables)
>>>    TSSetSolution(ts_solver,solver_main.U_cons);
>>>    // Set the time-stepping type
>>>    TSSetType(ts_solver,TSEULER);
>>>    // Set the initial time and the time step
>>>    TSSetInitialTimeStep(ts_solver,0.0,0.001);
>>>    // Set the total duration (number of steps and total time)
>>>    TSSetDuration(ts_solver,10,0.01);
>>>    // Point the solver to the monitor function
>>>    TSMonitorSet(ts_solver,solver_main.TS_Monitor,this,NULL);
>>>    // Set the distributed array context for the solver
>>>    TSSetDM(ts_solver,main_da);
>>>    // Get the nonlinear solver for the time-stepping solver
>>>    TSGetSNES(ts_solver,&nl_solver);
>>>    // Write out the initial condition before the solver is started
>>>    WriteSolutionCSV("initial_condition.csv");
>>>    // Run the solver!
>>>    TSSolve(ts_solver,solver_main.U_cons);
>>>        std::cout << "-----COMPLETED SOLUTION-----" << std::endl;
>>>    // Write out the solution at the end
>>>    WriteSolutionCSV("output_test.csv");
>>>    // Destroy the time-stepping solver
>>>    TSDestroy(&ts_solver);
>>> NEW VERSION WITH TSSetExactFinalTime and TSAdaptSetType:
>>>    TSSetDuration(ts_solver,1,0.001);
>>>    // Set TS exact final time behavior
>>>    // Set TS adaptive time stepping behavior
>>>    TSAdapt ts_adapt;
>>>    // Point the solver to the function which evaluates the right hand side
>>> TSSetRHSFunction(ts_solver,solver_main.RHS,solver_main.FormFunction,this);
>>>    // Run the solver!
>>> On 06/05/2016 06:44 PM, Barry Smith wrote:
>>>>   Paul,
>>>>    I don't think this was an expected change. Can you send code or walk us through the steps that led you to this?
>>>>   Barry
>>>>> On Jun 3, 2016, at 10:23 AM, Paul Urbanczyk <gomer at stanford.edu> wrote:
>>>>> Hello,
>>>>> I recently upgraded to the latest version of PETSc (3.7.1) from the git repository.
>>>>> Running my code gave me an error message about TSSolve being in the wrong state and needing to call TSSetExactFinalTime.
>>>>> I added this function call with TS_EXACTFINALTIME_STEPOVER, but when I re-ran my code, I got a seg fault and error messages pointing to TSAdaptChoose.
>>>>> After fiddling around for a while, I found that I now needed to explicitly set the time step adaptation through TSAdaptSetType.
>>>>> Can anyone confirm that this is so? If so, it might be helpful to note that in documentation or error messages somewhere.
>>>>> Thanks,
>>>>> Paul
