[petsc-users] Error with MatView on multiple processors
Paul Urbanczyk
gomer at stanford.edu
Fri Jun 3 10:13:56 CDT 2016
For the benefit of anyone else who happens to run into this issue...
Earlier in my code, I had used the function DMDAGetAO(DM da, AO *ao),
and then destroyed the AO at the end of the function with AODestroy.
I'm guessing that, when I did this, I destroyed the AO for the DM, so
when it came time to view the matrix, PETSc could not convert the
numbering for display.
Does this sound right or make sense?
Paul
On 05/27/2016 06:43 PM, Matthew Knepley wrote:
> On Fri, May 27, 2016 at 8:38 PM, Paul Urbanczyk <gomer at stanford.edu
> <mailto:gomer at stanford.edu>> wrote:
> On 05/27/2016 05:44 PM, Matthew Knepley wrote:
>> On Fri, May 27, 2016 at 6:34 PM, Paul Urbanczyk
>> <gomer at stanford.edu <mailto:gomer at stanford.edu>> wrote:
>> Hello,
>> I'm having trouble with the MatView function drawing the
>> matrix structure(s) when I execute my code on multiple
>> processors.
>> When I run on a single processor, the code runs fine, and the
>> graphics window displays cleanly.
>> Lets start with an example. I do this
>> cd $PETSC_DIR/src/snes/examples/tutorials
>> make ex19
>> Make sure it runs
>> ./ex19 -snes_monitor
>> Make sure it runs in parallel (maybe you need
>> $PETSC_DIR/$PETSC_ARCH/bin/mpiexec)
>> mpiexec -n 2 ./ex19 -snes_monitor
>> Make sure it can draw
>> mpiexec -n 2 ./ex19 -snes_monitor -mat_view draw -draw_pause 1
>> This runs fine for me. Can you try it?
>> Thanks,
>> Matt
> Hello Matt,
> Yes, this example seems to run just fine. How should I proceed?
> I am not sure what you are doing in your code. Can you try and change
> one of these examples
> to do something like what you do? SNEX ex19 seems like it does things
> mostly the way you
> describe.
> Matt
> -Paul
>> When I run with multiple processors, I get error messages
>> (see below).
>> The matrices are constructed with DMCreateMatrix(da, &A_matrix).
>> I then set the values with
>> MatSetValuesStencil(A_matrix,1,&row,2,col_A,value_A,INSERT_VALUES).
>> Finally, I call MatAssemblyBegin(A_matrix,MAT_FINAL_ASSEMBLY)
>> and MatAssemblyEnd(A_matrix,MAT_FINAL_ASSEMBLY).
>> I also test that the matrices are assembled with
>> MatAssembled(A_matrix, &is_assembled_bool), and it appears
>> they are successfully assembled.
>> Any help/advice is greatly appreciated.
>> Thanks in advance!
>> -Paul Urbanczyk
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Wrong type of object: Parameter # 1
>> [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html for
>> trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.7.1, unknown
>> [0]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named
>> prometheus by gomer Fri May 27 16:29:01 2016
>> [0]PETSC ERROR: Configure options --with-cc=mpicc
>> --with-cxx=mpicxx --with-fc=mpif90
>> [0]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
>> /home/gomer/local/petsc/src/vec/is/ao/interface/ao.c
>> [0]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
>> /home/gomer/local/petsc/src/dm/impls/da/fdda.c
>> [0]PETSC ERROR: #3 MatView() line 901 in
>> /home/gomer/local/petsc/src/mat/interface/matrix.c
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Invalid argument
>> [1]PETSC ERROR: Wrong type of object: Parameter # 1
>> [1]PETSC ERROR: See
>> trouble shooting.
>> [1]PETSC ERROR: Petsc Release Version 3.7.1, unknown
>> [1]PETSC ERROR: ./urbanSCFD on a arch-linux2-c-debug named
>> [1]PETSC ERROR: Configure options --with-cc=mpicc
>> [1]PETSC ERROR: #1 AOApplicationToPetsc() line 267 in
>> [1]PETSC ERROR: #2 MatView_MPI_DA() line 557 in
>> [1]PETSC ERROR: #3 MatView() line 901 in
>> [1]PETSC ERROR: See
>> trouble shooting.
>> [1]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
>> [1]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
>> [1]PETSC ERROR: #6 MatView() line 901 in
>> [0]PETSC ERROR: See
>> trouble shooting.
>> [0]PETSC ERROR: #4 AOApplicationToPetsc() line 267 in
>> [0]PETSC ERROR: #5 MatView_MPI_DA() line 557 in
>> [0]PETSC ERROR: #6 MatView() line 901 in
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160603/459429d1/attachment.html>
