[petsc-users] Tuning performance for simple solver
Michael Becker Michael.Becker at physik.uni-giessen.de
Fri Jun 3 05:37:38 CDT 2016
Dear all,
I have a few questions regarding possible performance enhancements for
the PETSc solver I included in my project.
It's a particle-in-cell plasma simulation written in C++, where
Poisson's equation needs to be solved repeatedly on every timestep.
The simulation domain is discretized using finite differences, so the
solver therefore needs to be able to efficiently solve the linear system
A x = b successively with changing b. The solution x of the previous
timestep is generally a good initial guess for the solution.
I wrote a class PETScSolver that holds all PETSc objects and necessary
information about domain size and decomposition. To solve the linear
system, two arrays, 'phi' and 'charge', are passed to a member function
solve(), where they are copied to PETSc vectors, and KSPSolve() is
called. After convergence, the solution is then transferred again to the
phi array so that other program parts can use it.
The matrix is created using DMDA. An array 'bound' is used to determine
whether a node is either a Dirichlet BC or holds a charge.
I attached three files, petscsolver.h, petscsolver.cpp and main.cpp,
that contain a shortened version of the solver class and a set-up to
initialize and run a simple problem.
Is there anything I can change to generally make the program run faster?
And, since I'm rather unexperienced with KSP methods, how do I
efficiently choose PC and KSP? Just by testing every combination?
Would multigrid be a viable option as a pure solver (-ksp_type preonly)?
Michael
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160603/a2c0f1fb/attachment.cpp>
Type: text/x-chdr
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160603/a2c0f1fb/attachment.h>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160603/a2c0f1fb/attachment-0001.cpp>
