[petsc-users] Fwd: Re: Error with PETSc on K computer
TAY wee-beng
zonexo at gmail.com
Fri Jun 3 03:22:53 CDT 2016
Is there any update to the issue below?
No hurry, just to make sure that the email is sent successfully.
Thanks
-------- Forwarded Message --------
Subject: Re: [petsc-users] Error with PETSc on K computer
Date: Thu, 2 Jun 2016 10:25:22 +0800
To: petsc-users <petsc-users at mcs.anl.gov>
Hi Satish,
The X9 option is :
Provides a different interpretation under Fortran 95 specifications
for any parts not conforming to the language specifications of this
compiler
I just patched and re-compiled but it still can't work. I've attached
the configure.log for both builds.
FYI, some parts of the PETSc 3.6.3 code were initially patch to make it
work with the K computer system:
$ diff -u petsc-3.6.3/config/BuildSystem/config/package.py.org
--- petsc-3.6.3/config/BuildSystem/config/package.py.org 2015-12-04
14:06:42.000000000 +0900
+++ petsc-3.6.3/config/BuildSystem/config/package.py 2016-01-22
11:09:37.000000000 +0900
@@ -174,7 +174,7 @@
return ''
def getSharedFlag(self,cflags):
- for flag in ['-PIC', '-fPIC', '-KPIC', '-qpic']:
+ for flag in ['-KPIC', '-fPIC', '-PIC', '-qpic']:
if cflags.find(flag) >=0: return flag
return ''
$ diff -u petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org
--- petsc-3.6.3/config/BuildSystem/config/setCompilers.py.org 2015-07-23
00:22:46.000000000 +0900
+++ petsc-3.6.3/config/BuildSystem/config/setCompilers.py 2016-01-22
11:10:05.000000000 +0900
@@ -1017,7 +1017,7 @@
self.pushLanguage(language)
#different compilers are sensitive to the order of testing these
flags. So separete out GCC test.
if config.setCompilers.Configure.isGNU(self.getCompiler()):
testFlags = ['-fPIC']
- else: testFlags = ['-PIC', '-fPIC', '-KPIC','-qpic']
+ else: testFlags = ['-KPIC', '-fPIC', '-PIC','-qpic']
for testFlag in testFlags:
try:
self.logPrint('Trying '+language+' compiler flag '+testFlag)
$ diff -u petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org
--- petsc-3.6.3/config/BuildSystem/config/packages/openmp.py.org
2016-01-25 15:42:23.000000000+0900
+++ petsc-3.6.3/config/BuildSystem/config/packages/openmp.py 2016-01-22
17:13:52.000000000 +0900
@@ -19,7 +19,8 @@
self.found = 0
self.setCompilers.pushLanguage('C')
- for flag in ["-fopenmp", # Gnu
+ for flag in ["-Kopenmp", # Fujitsu
+ "-fopenmp", # Gnu
"-qsmp=omp",# IBM XL C/C++
"-h omp", # Cray. Must come after XL because XL
interprets this option as meaning"-soname omp"
"-mp", # Portland Group
$ diff -u ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org
--- ./petsc-3.6.3/config/BuildSystem/config/compilers.py.org 2015-06-10
06:24:49.000000000 +0900
+++ ./petsc-3.6.3/config/BuildSystem/config/compilers.py 2016-02-19
11:56:12.000000000 +0900
@@ -164,7 +164,7 @@
def checkCLibraries(self):
'''Determines the libraries needed to link with C'''
oldFlags = self.setCompilers.LDFLAGS
- self.setCompilers.LDFLAGS += ' -v'
+ self.setCompilers.LDFLAGS += ' -###'
self.pushLanguage('C')
(output, returnCode) = self.outputLink('', '')
self.setCompilers.LDFLAGS = oldFlags
@@ -413,7 +413,7 @@
def checkCxxLibraries(self):
'''Determines the libraries needed to link with C++'''
self.pushLanguage('Cxx')
Thank you
Yours sincerely,
TAY wee-beng
On 2/6/2016 3:18 AM, Satish Balay wrote:
> What does -X9 in --FFLAGS="-X9 -O0" do?
> can you send configure.log for this build?
> And does the attached patch make a difference with this example?
> [suggest doing a separate temporary build of PETSc - in a different source location - to check this.]
> Satish
> On Wed, 1 Jun 2016, TAY wee-beng wrote:
>> Hi Satish,
>> Only partially working:
>> [t00196 at b04-036 tutorials]$ mpiexec -n 2 ./ex4f90
>> jwe1050i-w The hardware barrier couldn't be used and continues processing
>> using the software barrier.
>> taken to (standard) corrective action, execution continuing.
>> Vec Object:Vec Object:initial vector:initial vector: 1 MPI processes
>> type: seq
>> 10
>> 20
>> 30
>> 40
>> 50
>> 60
>> 1 MPI processes
>> type: seq
>> 10
>> 20
>> 30
>> 40
>> 50
>> 60
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably
>> memory access out of range
>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [1]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> [1]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac OS X to
>> find memory corruption errors
>> [1]PETSC ERROR: likely location of problem given in stack below
>> [1]PETSC ERROR: --------------------- Stack Frames
>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [1]PETSC ERROR: INSTEAD the line number of the start of the function
>> [1]PETSC ERROR: is given.
>> [1]PETSC ERROR: [1] F90Array1dCreate line 50
>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c
>> [1]PETSC ERROR: --------------------- Error Message
>> ------------------------------------------[0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> [0]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac OS X to
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: --------------------- Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>> [0]PETSC ERROR: INSTEAD the line number of the start of the function
>> [0]PETSC ERROR: is given.
>> [0]PETSC ERROR: [0] F90Array1dCreate line 50
>> [0]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Signal received
>> [1]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html for
>> trouble shooting.
>> [1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>> [1]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown Wed
>> Jun 1 13:23:41 2016
>> [1]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>> --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS="-Xg -O0"
>> --CXX=mpiFCC --CXXFLAGS="-Xg -O0" --FC=mpifrt --FFLAGS="-X9 -O0" --LD_SHARED=
>> --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big
>> --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2
>> --with-scalapack-lib=-SCALAPACK
>> --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_debug
>> --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0 --with-hypre=1
>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
>> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
>> [mpi::mpi-api::mpi-abort]
>> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> [b04-036:28998]
>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84)
>> [0xffffffff11360404]
>> [b04-036:28998]
>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_abort+0x51c)
>> [0xffffffff1110391c]
>> [b04-036:28998] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Abort+0x6c)
>> [0xffffffff1111b5ec]
>> [b04-036:28998]
>> /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c)
>> [0xffffffff00281bf0]
>> [b04-036:28998] ./ex4f90 [0x292548]
>> [b04-036:28998] ./ex4f90 [0x29165c]
>> [b04-036:28998] /opt/FJSVxosmmm/lib64/libmpgpthread.so.1(_IO_funlockfile+0x5c)
>> [0xffffffff121e1974]
>> [b04-036:28998] ./ex4f90 [0x9f6748]
>> [b04-036:28998] ./ex4f90 [0x9f0ea4]
>> [b04-036:28998] ./ex4f90 [0x2c76a0]
>> [b04-036:28998] ./ex4f90(MAIN__+0x38c) [0x10688c]
>> [b04-036:28998] ./ex4f90(main+0xec) [0x268e91c]
>> [b04-036:28998] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff138cb81c]
>> [b04-036:28998] ./ex4f90 [0x1063ac]
>> [1]PETSC ERROR:
>> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch
>> system) has told this process to end
>> [1]PETSC ERROR: Tr--------------------
>> [0]PETSC ERROR: Signal received
>> [0]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html for
>> trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>> [0]PETSC ERROR: ./ex4f90 on a petsc-3.6.3_debug named b04-036 by Unknown Wed
>> Jun 1 13:23:41 2016
>> [0]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> [b04-036:28997]
>> [b04-036:28997]
>> [b04-036:28997] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Abort+0x6c)
>> [b04-036:28997]
>> [b04-036:28997] ./ex4f90 [0x292548]
>> [b04-036:28997] ./ex4f90 [0x29165c]
>> [b04-036:28997] /opt/FJSVxosmmm/lib64/libmpgpthread.so.1(_IO_funlockfile+0x5c)
>> [b04-036:28997] ./ex4f90 [0x9f6748]
>> [b04-036:28997] ./ex4f90 [0x9f0ea4]
>> [b04-036:28997] ./ex4f90 [0x2c76a0]
>> [b04-036:28997] ./ex4f90(MAIN__+0x38c) [0x10688c]
>> [b04-036:28997] ./ex4f90(main+0xec) [0x268e91c]
>> [b04-036:28997] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff138cb81c]
>> [b04-036:28997] ./ex4f90 [0x1063ac]
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or the batch
>> trouble shooting.
>> Jun 1 13:23:41 2016
>> --with-fortran-interfaces=1 --with-debuy option -start_in_debugger or
>> trouble shooting.
>> Jun 1 13:23:41 2016
>> [1]PETSC ERROR: #2 User provided function() line 0 in unknown file
>> [0]PETSC ERROR: #2 User provided function() line 0 in unknown file
>> [ERR.] PLE 0019 plexec One of MPI processes was
>> aborted.(rank=0)(nid=0x04180034)(CODE=1938,793745140674134016,15104)
>> [ERR.] PLE 0021 plexec The interactive job has aborted with the
>> signal.(sig=24)
>> [INFO] PJM 0083 pjsub Interactive job 5211401 completed.
>> Thank you
>> Yours sincerely,
>> TAY wee-beng
>> On 1/6/2016 12:21 PM, Satish Balay wrote:
>>> Do PETSc examples using VecGetArrayF90() work?
>>> say src/vec/vec/examples/tutorials/ex4f90.F
>>> Satish
>>> On Tue, 31 May 2016, TAY wee-beng wrote:
>>>> Hi,
>>>> I'm trying to run my MPI CFD code on Japan's K computer. My code can run
>>>> if I
>>>> didn't make use of the PETSc DMDAVecGetArrayF90 subroutine. If it's called
>>>> call DMDAVecGetArrayF90(da_u,u_local,u_array,ierr)
>>>> I get the error below. I have no problem with my code on other clusters
>>>> using
>>>> the new Intel compilers. I used to have problems with DM when using the
>>>> old
>>>> Intel compilers. Now on the K computer, I'm using Fujitsu's Fortran
>>>> compiler.
>>>> How can I troubleshoot?
>>>> Btw, I also tested on the ex13f90 example and it didn't work too. The
>>>> error is
>>>> below.
>>>> My code error:
>>>> /* size_x,size_y,size_z 76x130x136*//*
>>>> *//* total grid size = 1343680*//*
>>>> *//* recommended cores (50k / core) = 26.87360000000000*//*
>>>> *//* 0*//*
>>>> *//* 1*//*
>>>> *//* 1*//*
>>>> *//*[3]PETSC ERROR: [1]PETSC ERROR:
>>>> *//*[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range*//*
>>>> *//*[1]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger*//*
>>>> *//*[1]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind*//*
>>>> *//*[1]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac
>>>> OS X
>>>> to find memory corruption errors*//*
>>>> *//*[1]PETSC ERROR: likely location of problem given in stack below*//*
>>>> *//*[1]PETSC ERROR: --------------------- Stack Frames
>>>> *//*[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,*//*
>>>> *//*[1]PETSC ERROR: INSTEAD the line number of the start of the
>>>> function*//*
>>>> *//*[1]PETSC ERROR: is given.*//*
>>>> *//*[1]PETSC ERROR: [1] F90Array3dCreate line 244
>>>> /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/src/sys/f90-src/f90_cwrap.c*//*
>>>> *//* 1*//*
>>>> *//*[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> *//*[3]PETSC ERROR: Try option -start_in_debugger or
>>>> *//*[3]PETSC ERROR: or see
>>>> *//*[3]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac
>>>> OS X
>>>> *//*[3]PETSC ERROR: likely location of problem given in stack below*//*
>>>> *//*[3]PETSC ERROR: --------------------- Stack Frames
>>>> *//*[0]PETSC ERROR:
>>>> *//*[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> *//*[0]PETSC ERROR: Try option -start_in_debugger or
>>>> *//*[0]PETSC ERROR: or see
>>>> *//*[0]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac
>>>> OS X
>>>> *//*[0]PETSC ERROR: likely location of problem given in stack below*//*
>>>> *//*[0]PETSC ERROR: --------------------- Stack Frames
>>>> *//*[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,*//*
>>>> *//*[0]PETSC ERROR: INSTEAD the line number of the start of the
>>>> function*//*
>>>> *//*[0]PETSC ERROR: is given.*//*
>>>> *//*[0]PETSC ERROR: [0] F90Array3dCreate line 244
>>>> *//*[0]PETSC ERROR: --------------------- Error Message
>>>> ----------------------------------------- 1*//*
>>>> *//*[2]PETSC ERROR:
>>>> *//*[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> *//*[2]PETSC ERROR: Try option -start_in_debugger or
>>>> *//*[2]PETSC ERROR: or see
>>>> *//*[2]PETSC ERROR: or tryhttp://valgrind.org on GNU/linux and Apple Mac
>>>> OS X
>>>> *//*[2]PETSC ERROR: likely location of problem given in stack below*//*
>>>> *//*[2]PETSC ERROR: --------------------- Stack Frames
>>>> *//*[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>>> available,*//*
>>>> *//*[2]PETSC ERROR: INSTEAD the line number of the start of the
>>>> function*//*
>>>> *//*[2]PETSC ERROR: is given.*//*
>>>> *//*[2]PETSC ERROR: [2] F90Array3dCreate line 244
>>>> *//*[2]PETSC ERROR: --------------------- Error Message
>>>> -----------------------------------------[3]PETSC ERROR: Note: The EXACT
>>>> line
>>>> numbers in the stack are not available,*//*
>>>> *//*[3]PETSC ERROR: INSTEAD the line number of the start of the
>>>> function*//*
>>>> *//*[3]PETSC ERROR: is given.*//*
>>>> *//*[3]PETSC ERROR: [3] F90Array3dCreate line 244
>>>> *//*[3]PETSC ERROR: --------------------- Error Message
>>>> *//*[3]PETSC ERROR: Signal received*//*
>>>> *//*[3]PETSC ERROR: See
>>>> for trouble shooting.*//*
>>>> *//*[3]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>> *//*[3]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036 by
>>>> Unknown Wed Jun 1 12:54:34 2016*//*
>>>> *//*[3]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --LD_SHARED=
>>>> --with-shared----------------------*//*
>>>> *//*[0]PETSC ERROR: Signal received*//*
>>>> *//*[0]PETSC ERROR: See
>>>> *//*[0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>> *//*[0]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036 by
>>>> *//*[0]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4*//*
>>>> *//*[0]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>> file*//*
>>>> *//*[m---------------------*//*
>>>> *//*[2]PETSC ERROR: Signal received*//*
>>>> *//*[2]PETSC ERROR: See
>>>> *//*[2]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>> *//*[2]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036 by
>>>> *//*[2]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> *//*[2]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>> file*//*
>>>> *//*[m[1]PETSC ERROR: --------------------- Error Message
>>>> *//*[1]PETSC ERROR: Signal received*//*
>>>> *//*[1]PETSC ERROR: See
>>>> *//*[1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015*//*
>>>> *//*[1]PETSC ERROR: ./a-debug.out on a petsc-3.6.3_debug named b04-036 by
>>>> *//*[1]PETSC ERROR: Configure options --with-cc=mpifcc --with-cxx=mpiFCC
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> *//*[1]PETSC ERROR: #1 User provided function() line 0 ilibraries=0
>>>> --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK
>>>> --with-hypre=1
>>>> *//*[3]PETSC ERROR: #1 User provided function() line 0 in unknown
>>>> file*//*
>>>> *//*[mpi::mpi-api::mpi-abort]*//*
>>>> *//*MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD*//*
>>>> *//*with errorcode 59.*//*
>>>> *//*NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>>> processes.*//*
>>>> *//*You may or may not see output from other processes, depending on*//*
>>>> *//*exactly when Open MPI kills them.*//*
>>>> *//*[b04-036:28416]
>>>> [0xffffffff11360404]*//*
>>>> *//*[b04-036:28416]
>>>> [0xffffffff1110391c]*//*
>>>> *//*[b04-036:28416] /opt/FJSVtclang/GM-1.2.0-2pi::mpi-api::mpi-abort]*//*
>>>> *//*MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD*//*
>>>> ex13f90 error:
>>>> /*[t00196 at b04-036 tutorials]$ mpiexec -np 2 ./ex13f90*//*
>>>> *//*jwe1050i-w The hardware barrier couldn't be used and continues
>>>> processing
>>>> using the software barrier.*//*
>>>> *//*taken to (standard) corrective action, execution continuing.*//*
>>>> processing
>>>> *//* Hi! We're solving van der Pol using 2 processes.*//*
>>>> *//* t x1 x2*//*
>>>> *//*[1]PETSC ERROR:
>>>> *//*[1]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>> illegal
>>>> memory access*//*
>>>> *//*[0]PETSC ERROR:
>>>> *//*[0]PETSC ERROR: Caught signal number 10 BUS: Bus Error, possibly
>>>> illegal
>>>> memory access*//*
>>>> OS X
>>>> OS X
>>>> available,*//*
>>>> function*//*
>>>> *//*[1]PETSC ERROR: [1] F90Array4dCreate line 337
>>>> available,*//*
>>>> function*//*
>>>> *//*[0]PETSC ERROR: [0] F90Array4dCreate line 337
>>>> *//*[1]PETSC ERROR: --------------------- Error Message
>>>> *//*[1]PETSC ERROR: ./ex13f90 on a petsc-3.6.3_debug named b04-036 by
>>>> Unknown
>>>> Wed Jun 1 13:04:34 2016*//*
>>>> --LD_SHARED=
>>>> --with-hypre=1
>>>> --with-hyp*//*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160603/77339ccc/attachment-0001.html>
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Starting Configure Run at Thu Jun 2 10:39:34 2016
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc=mpifcc --with-cxx=mpiFCC --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS="-Xg -O0" --CXX=mpiFCC --CXXFLAGS="-Xg -O0" --FC=mpifrt --FFLAGS="-X9 -O0" --LD_SHARED= --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0 --with-hypre=1 --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
Working directory: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Machine platform:
('Linux', 'd01-037', '2.6.25.8', '#1 SMP Wed Jan 6 11:32:25 JST 2016', 's64fx', 's64fx')
Python version:
2.6.2 (r262:71600, Dec 20 2011, 15:18:11)
[GCC 4.2.4]
Pushing language C
Popping language C
Pushing language FC
Popping language FC
TEST configureExternalPackagesDir from config.framework(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/framework.py:832)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:832)
TEST configureDebuggers from config.utilities.debuggers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
Find a default debugger and determine its arguments
Checking for program /opt/FJSVtclang/check/gdb...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/gdb...not found
Checking for program /opt/kusu/bin/gdb...not found
Checking for program /opt/kusu/sbin/gdb...not found
Checking for program /usr/pgsql-9.0/bin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /home/hp150306/t00196/bin/gdb...not found
Checking for program /home/hp150306/t00196/shortcut/gdb...not found
Checking for program /opt/FJSVxosmmm/sbin/gdb...not found
Checking for program /home/hp150306/t00196/gdb...not found
Checking for program /opt/FJSVtclang/check/dbx...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/dbx...not found
Checking for program /opt/kusu/bin/dbx...not found
Checking for program /opt/kusu/sbin/dbx...not found
Checking for program /usr/pgsql-9.0/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /home/hp150306/t00196/bin/dbx...not found
Checking for program /home/hp150306/t00196/shortcut/dbx...not found
Checking for program /opt/FJSVxosmmm/sbin/dbx...not found
Checking for program /home/hp150306/t00196/dbx...not found
Checking for program /opt/FJSVtclang/check/xdb...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/xdb...not found
Checking for program /opt/kusu/bin/xdb...not found
Checking for program /opt/kusu/sbin/xdb...not found
Checking for program /usr/pgsql-9.0/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /home/hp150306/t00196/bin/xdb...not found
Checking for program /home/hp150306/t00196/shortcut/xdb...not found
Checking for program /opt/FJSVxosmmm/sbin/xdb...not found
Checking for program /home/hp150306/t00196/xdb...not found
Checking for program /opt/FJSVtclang/check/dsymutil...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/dsymutil...not found
Checking for program /opt/kusu/bin/dsymutil...not found
Checking for program /opt/kusu/sbin/dsymutil...not found
Checking for program /usr/pgsql-9.0/bin/dsymutil...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /home/hp150306/t00196/bin/dsymutil...not found
Checking for program /home/hp150306/t00196/shortcut/dsymutil...not found
Checking for program /opt/FJSVxosmmm/sbin/dsymutil...not found
Checking for program /home/hp150306/t00196/dsymutil...not found
Defined make macro "DSYMUTIL" to "true"
TEST configureGit from config.sourceControl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
Find the Git executable
Checking for program /opt/FJSVtclang/check/git...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/git...not found
Checking for program /opt/kusu/bin/git...not found
Checking for program /opt/kusu/sbin/git...not found
Checking for program /usr/pgsql-9.0/bin/git...not found
Checking for program /usr/local/bin/git...not found
Checking for program /bin/git...not found
Checking for program /usr/bin/git...not found
Checking for program /home/hp150306/t00196/bin/git...not found
Checking for program /home/hp150306/t00196/shortcut/git...not found
Checking for program /opt/FJSVxosmmm/sbin/git...not found
Checking for program /home/hp150306/t00196/git...not found
TEST configureCLanguage from PETSc.options.languages(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
Choose whether to compile the PETSc library using a C or C++ compiler
C language is C
Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
Checks PETSC_DIR and sets if not set
Version Information:
#define PETSC_VERSION_RELEASE 1
#define PETSC_VERSION_MAJOR 3
#define PETSC_VERSION_MINOR 6
#define PETSC_VERSION_SUBMINOR 3
#define PETSC_VERSION_PATCH 0
#define PETSC_VERSION_DATE "Dec, 03, 2015"
#define PETSC_VERSION_GIT "v3.6.2-37-g6fc57b5"
#define PETSC_VERSION_DATE_GIT "2015-12-03 23:02:05 -0600"
#define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
Defined make macro "DIR" to "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3"
TEST getDatafilespath from PETSc.options.dataFilesPath(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
Checks PETSC_ARCH and sets if not set
Defined "ARCH" to ""petsc-3.6.3_patch_debug""
TEST setInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:74)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:74)
TEST cleanInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:67)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:67)
TEST configureInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:51)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:51)
Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
Changed persistence directory to /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:87)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:87)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1538)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1538)
**** printenv ****
Timezone_ntp_server1=10.0.160.15
Timezone_ntp_server2=10.0.160.1
DEPOT_REPOS_ROOT=/depot/repos
NII_PARENTIPS=10.246.0.65;10.0.2.131
PJM_O_WORKDIR=/volume2/home/hp150306/t00196/source/petsc-3.6.3
NII_PGID=
DEPOT_AUTOINST_ROOT=/depot/repos/instconf
InstallerServeNFS=1
CFMBaseDir=/opt/kusu/cfm
OMPI_CKPTCONFIG=0x00
PJM_O_SHELL=/bin/bash
MANPATH=:/opt/kusu/man
Timezone_utc=0
Timezone_zone=Asia/Tokyo
KUSU_TMP=/tmp
root_password_auth=off
PYTHONPATH=/opt/primitive/lib64/python2.6/site-packages:/opt/primitive/lib/python2.6/site-packages:/opt/primitive/lib64/python2.4/site-packages:/opt/primitive/lib/python2.4/site-packages:/opt/kusu/lib64/python:/opt/kusu/lib/python:
KUSU_ROOT=/opt/kusu
PublicDNSZone=k
NII_PEERIP=0
DEPOT_DOCS_ROOT=/depot/www/kits
NII_HAGROUP=,
InstNum=
TUNING_XINET_MAX_CLIENTS=100
PIXIE_ROOT=/tftpboot/kusu
Keyboard=jp106
NII_PARENTIP=10.224.0.92
PJM_JOBID=5213057
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:
Env_base=K-1.2.0-20-1
DB_POOLER_MAX_CLIENTS=32768
snmp_trap_receivers=
NII_NGTYPE=compute-diskless
PJM_DPREFIX=#PJM
LMGRD_PATH=
PJM_O_PATH=/usr/lib64/qt-3.3/bin:/opt/local/openssh/bin:/opt/FJSVtclang/check:/opt/FJSVtclang/GM-1.2.0-20/bin:/opt/FJSVtclang/1.2.0/util/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/bin/SU/bin:/opt/local/gfarm/bin:/opt/local/Python-2.7.3/bin:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut
SYSLOG_SERVER=disabled
passwordless_root_on_compute=on
SHLVL=1
NII_NICDEF0=tofu0|10.246.0.97|255.224.0.0|10.224.0.0|-tofu0|10.255.255.254|0||02:00:10:17:01:c3|provision
PETSC_ARCH=petsc-3.6.3_patch_debug
KUSU_LOGFILE=/var/log/kusu/kusu.log
NII_NID=9242
PETSC_DIR=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
CFM_SERVICE=multicast
MODULESHOME=/usr/share/Modules
KUSU_MAXLOGNUM=10
NII_INSTALLERS=10.224.0.92
PRIMITIVE_ROOT=/opt/primitive
DEPOT_CONTRIB_ROOT=/depot/contrib
MULTICAST_ADDR=239.0.0.80
NII_HOSTNAME=d01-037
PrimaryInstaller=cs01p03
MASTER_UUID=KUSU
NII_BOOTNIC=tofu0
TMPDIR=./
MODULEPATH=/usr/share/Modules/modulefiles:/etc/modulefiles:
NII_NFSROOTSERVER=10.224.0.92
NII_BOOTIP=10.246.0.97
dns1=127.0.0.1
InstallerServeDNS=1
FJPNCKPT_CONFIG=0x00
KUSUSNMPD_LOG_SIZE=5000
KUSU_MAXLOGSIZE=10485760
PROVISION=KUSU
InstallerServeDHCP=1
ssh_port=22
TUNING_ENABLED=1
LM_LICENSE_FILE=
PJM_JOBNAME=STDIN
LD_LIBRARY_PATH=/opt/FJSVpxtof/sparc64fx/lib64:/opt/FJSVtclang/GM-1.2.0-20/lib64:/opt/FJSVpnavi/sparc64fx/lib64:/opt/FJSVXosSclib/lib64
Timezone_ntp_server=10.0.160.14
KUSU_DIST_ARCH=s64fx
G_BROKEN_FILENAMES=1
_=./configure
DEPOT_REPOS_SCRIPTS=/depot/repos/custom_scripts
NII_REPO=/repos/1002
TOFU_HOME=/opt/FJSVpxtof/sparc64fx
Language=en_US
KusuAuthScheme=files
PGBOUNCER_LOG_SIZE=100
KUSU_DHCP_TIMEOUT=120
InstallerServeNTP=1
NII_OSTYPE=xtcos-1.3-sparc64fx
PJM_O_HOST=fe01p08
KUSU_DB_ENGINE=postgres
NII_REPOID=1002
KUSU_LOGLEVEL=DEBUG
NII_INSTALLTYPE=diskless
NII_SNMPD=10.224.0.92
NII_NGID=18
KUSU_HEARTBEAT_INTERFACE=bond0
PJM_JOBDIR=/volume2/home/hp150306/t00196/source/petsc-3.6.3
DEPOT_REPOS_POST=/depot/repos/post_scripts
DB_POOLER_POOL_SIZE=50000
ssh_old_port=22
NII_DBSERVERPORT=6432
DB_POOLER_PORT=6432
PJM_O_LOGNAME=t00196
PATH=/opt/FJSVtclang/check:/opt/FJSVtclang/GM-1.2.0-20/bin:/opt/kusu/bin:/opt/kusu/sbin:/usr/pgsql-9.0/bin:/usr/local/bin:/bin:/usr/bin:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut:/opt/FJSVxosmmm/sbin
PJM_ENVIRONMENT=INTERACT
NII_DBSERVERIP=10.0.160.20
TERM=xterm
KUSU_INSTALLER_GW=10.1.161.254
DNSZone=k
PRESERVE_NODE_IP=1
PJM_O_HOME=/home/hp150306/t00196
CFM_PROTOCOL=broadcast
NII_NFSROOTOPTS=rw,hard,intr,nolock,async,dev,exec,suid
DEPOT_UPDATES_ROOT=/depot/updates
NII_EXTRAID=k-comp_0x02160035
MPI_HOME=/opt/FJSVtclang/GM-1.2.0-20
InstallerServeNIS=0
TUNING_TFTP_MAX_CLIENTS=100
DEPOT_IMAGES_ROOT=/depot/images
KUSU_EVENT_LOGFILE=/var/log/kusu/kusu-events.log
DB_POOLER_ENABLED=1
TUNING_SSH_MAX_CLIENTS=200
NII_NFSROOTPATH=/export/nfsroot/d01-037
LOADEDMODULES=
DEPOT_KITS_ROOT=/depot/kits
PJM_O_MAIL=/var/spool/mail/t00196
KUSU_VERSION=2.1
PWD=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
PJM_O_LANG=en_US.UTF-8
TEST resetEnvCompilers from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1545)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1545)
TEST checkEnvCompilers from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1575)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1575)
TEST checkMPICompilerOverride from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1510)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1510)
Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1529)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1529)
OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:402)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:402)
Determine the compiler vendor
Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:412)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:412)
Initialize the compiler and linker flags
Pushing language C
Initialized CFLAGS to -Xg -O0
Initialized LDFLAGS to
Popping language C
Initialized CUDAFLAGS to
Initialized CXXFLAGS to -Xg -O0
Initialized CXX_CXXFLAGS to
Pushing language FC
Initialized FFLAGS to -X9 -O0
Popping language FC
Initialized CPPFLAGS to
Initialized CUDAPPFLAGS to
Initialized CXXCPPFLAGS to
Initialized CC_LINKER_FLAGS to []
Initialized CXX_LINKER_FLAGS to []
Initialized FC_LINKER_FLAGS to []
Initialized CUDAC_LINKER_FLAGS to []
Initialized sharedLibraryFlags to []
Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:538)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:538)
Locate a functional C compiler
Checking for program /opt/FJSVtclang/check/mpifcc...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpifcc...found
Defined make macro "CC" to "mpifcc"
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest
Popping language C
TEST checkCPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:571)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:571)
Locate a functional C preprocessor
Defined make macro "CPP" to "mpifcc -E"
Pushing language C
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c"
#line 1 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 26 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef int wchar_t;
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 34 "/usr/include/stdlib.h"
#line 95 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) ;
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
extern long long int atoll (const char *__nptr)
extern double strtod (const char * __nptr,
char ** __endptr)
extern float strtof (const char * __nptr,
char ** __endptr) ;
extern long double strtold (const char * __nptr,
char ** __endptr)
extern long int strtol (const char * __nptr,
char ** __endptr, int __base)
extern unsigned long int strtoul (const char * __nptr,
extern long long int strtoq (const char * __nptr,
extern unsigned long long int strtouq (const char * __nptr,
extern long long int strtoll (const char * __nptr,
extern unsigned long long int strtoull (const char * __nptr,
#line 274 "/usr/include/stdlib.h"
#line 305 "/usr/include/stdlib.h"
extern char *l64a (long int __n) ;
extern long int a64l (const char *__s)
#line 1 "/usr/include/sys/types.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 28 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 32 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
#line 419 "/usr/include/time.h"
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 35 "/usr/include/sys/select.h"
typedef __sigset_t sigset_t;
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 45 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 221 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 271 "/usr/include/sys/types.h"
#line 321 "/usr/include/stdlib.h"
extern long int random (void) ;
extern void srandom (unsigned int __seed) ;
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) ;
extern char *setstate (char *__statebuf) ;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data * __buf,
int32_t * __result) ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char * __statebuf,
size_t __statelen,
struct random_data * __buf)
extern int setstate_r (char * __statebuf,
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
extern int rand_r (unsigned int *__seed) ;
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3]) ;
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) ;
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
unsigned long long int __a;
extern int drand48_r (struct drand48_data * __buffer,
double * __result) ;
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data * __buffer,
long int * __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data * __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) ;
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
extern void free (void *__ptr) ;
extern void cfree (void *__ptr) ;
#line 1 "/usr/include/alloca.h"
#line 23 "/usr/include/alloca.h"
#line 26 "/usr/include/alloca.h"
extern void *alloca (size_t __size) ;
#line 498 "/usr/include/stdlib.h"
extern void *valloc (size_t __size) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) ;
extern int atexit (void (*__func) (void)) ;
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) ;
extern void _Exit (int __status) ;
extern char *getenv (const char *__name) ;
extern char *__secure_getenv (const char *__name)
extern int putenv (char *__string) ;
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) ;
extern int clearenv (void) ;
extern char *mktemp (char *__template) ;
extern int mkstemp (char *__template) ;
#line 607 "/usr/include/stdlib.h"
extern char *mkdtemp (char *__template) ;
#line 638 "/usr/include/stdlib.h"
extern int system (const char *__command) ;
#line 655 "/usr/include/stdlib.h"
extern char *realpath (const char * __name,
char * __resolved) ;
typedef int (*__compar_fn_t) (const void *, const void *);
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) ;
extern int abs (int __x) ;
extern long int labs (long int __x) ;
extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
extern lldiv_t lldiv (long long int __numer,
long long int __denom)
extern char *ecvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *fcvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *gcvt (double __value, int __ndigit, char *__buf)
extern char *qecvt (long double __value, int __ndigit,
int * __decpt, int * __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int * __decpt,
int * __sign, char * __buf,
size_t __len) ;
extern int fcvt_r (double __value, int __ndigit, int * __decpt,
size_t __len) ;
extern int qecvt_r (long double __value, int __ndigit,
int * __decpt, int * __sign,
char * __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) ;
extern int mbtowc (wchar_t * __pwc,
const char * __s, size_t __n) ;
extern int wctomb (char *__s, wchar_t __wchar) ;
extern size_t mbstowcs (wchar_t * __pwcs,
extern size_t wcstombs (char * __s,
const wchar_t * __pwcs, size_t __n)
extern int rpmatch (const char *__response) ;
#line 820 "/usr/include/stdlib.h"
extern int posix_openpt (int __oflag) ;
#line 851 "/usr/include/stdlib.h"
#line 862 "/usr/include/stdlib.h"
extern int getloadavg (double __loadavg[], int __nelem)
#line 879 "/usr/include/stdlib.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Popping language C
TEST checkCUDACompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:612)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:612)
Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:652)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:652)
Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:764)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:764)
Locate a functional Cxx compiler
Checking for program /opt/FJSVtclang/check/mpiFCC...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpiFCC...found
Defined make macro "CXX" to "mpiFCC"
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkCxxPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:802)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:802)
Locate a functional Cxx preprocessor
Defined make macro "CXXCPP" to "mpiFCC -E"
Executing: mpiFCC -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/FCC.pre"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc"
extern "C" {
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_prolog.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 33 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 161 "/usr/include/sys/cdefs.h"
#line 354 "/usr/include/sys/cdefs.h"
#line 59 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_stlport_version.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl_user_config.h"
#line 74 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 90 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 28 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 49 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 95 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_site_config.h"
#line 30 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_site_config.h"
#line 99 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 18 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 28 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 53 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 128 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 102 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_confix.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_confix.h"
#line 111 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 121 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 185 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 196 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 262 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 276 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 297 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 305 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 313 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 321 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 338 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 351 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 372 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 417 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 468 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 496 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 507 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 517 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 542 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 556 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 565 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace std { }
namespace __std_alias = std;
#line 623 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 643 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 688 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace stlp_priv {
using namespace std;
#line 713 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace stlport = std;
namespace _STL = std;
#line 758 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 784 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 817 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 857 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 871 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 890 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 921 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 936 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 957 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 994 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1022 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1035 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1060 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1091 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1104 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1114 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1148 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1197 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1219 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1237 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 19 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_prolog.h"
#line 25 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 25 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 35 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 38 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 52 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
extern "C" {
#line 1 "/usr/include/bits/waitflags.h"
#line 43 "/usr/include/stdlib.h"
#line 1 "/usr/include/bits/waitstatus.h"
#line 66 "/usr/include/bits/waitstatus.h"
union wait
int w_status;
struct
#line 79 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_retcode:8;
unsigned int __w_coredump:1;
unsigned int __w_termsig:7;
} __wait_terminated;
struct
#line 93 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_stopsig:8;
unsigned int __w_stopval:8;
} __wait_stopped;
#line 44 "/usr/include/stdlib.h"
#line 57 "/usr/include/stdlib.h"
#line 75 "/usr/include/stdlib.h"
#line 83 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
char ** __endptr)
char ** __endptr) ;
char ** __endptr)
extern "C" {
#line 57 "/usr/include/sys/types.h"
typedef __ino64_t ino64_t;
#line 95 "/usr/include/sys/types.h"
typedef __off64_t off64_t;
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
#line 22 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
typedef __clock_t clock_t;
#line 30 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
typedef __useconds_t useconds_t;
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
__fd_mask fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
extern "C" {
typedef __blksize_t blksize_t;
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
size_t __statelen,
struct drand48_data
extern "C" {
#line 604 "/usr/include/stdlib.h"
extern int mkstemp64 (char *__template) ;
int * __sign) ;
int * __sign) ;
size_t __len) ;
size_t __len) ;
extern int getsubopt (char ** __optionp,
char *const * __tokens,
char ** __valuep)
extern void setkey (const char *__key) ;
extern int grantpt (int __fd) ;
extern int unlockpt (int __fd) ;
extern char *ptsname (int __fd) ;
#line 31 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
namespace std {
using ::div_t;
using ::ldiv_t;
using ::size_t;
using ::abs;
using ::div;
using ::abort;
using ::getenv;
using ::mblen;
using ::mbtowc;
using ::system;
using ::bsearch;
using ::atexit;
using ::exit;
using ::calloc;
using ::free;
using ::malloc;
using ::realloc;
using ::atof;
using ::atoi;
using ::atol;
using ::mbstowcs;
using ::strtod;
using ::strtol;
using ::strtoul;
using ::wcstombs;
using ::wctomb;
using ::qsort;
using ::labs;
using ::ldiv;
using ::llabs;
using ::lldiv_t;
using ::lldiv;
#line 103 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
using ::rand;
using ::srand;
#line 116 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
namespace std {
inline long abs(long __x) { return ::labs(__x); }
inline ldiv_t div(long __x, long __y) { return ::ldiv(__x, __y); }
#line 166 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 27 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 53 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 20 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 170 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc"
TEST checkFortranCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:919)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:919)
Locate a functional Fortran compiler
Checking for program /opt/FJSVtclang/check/mpifrt...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpifrt...found
Defined make macro "FC" to "mpifrt"
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Popping language FC
TEST checkFortranComments from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:940)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:940)
Make sure fortran comment "!" works
Pushing language FC
Successful compile:
Source:
! comment
program main
end
Fortran comments can use ! in column 1
Popping language FC
TEST checkPIC from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1003)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1003)
Determine the PIC option for each compiler
- There needs to be a test that checks that the functionality is actually working
Skip checking PIC options on user request
TEST checkLargeFileIO from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1036)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1036)
TEST checkArchiver from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1135)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1135)
Check that the archiver exists and can make a library usable by the compiler
Pushing language C
Executing: ar -V
stdout:
GNU ar 2.17
Copyright 2005 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License. This program has absolutely no warranty.
Executing: ar -V
stdout:
GNU ar 2.17
Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
return a+1;
Checking for program /opt/FJSVtclang/check/ar...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/ar...not found
Checking for program /opt/kusu/bin/ar...not found
Checking for program /opt/kusu/sbin/ar...not found
Checking for program /usr/pgsql-9.0/bin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /bin/ar...not found
Checking for program /usr/bin/ar...found
Defined make macro "AR" to "/usr/bin/ar"
Checking for program /opt/FJSVtclang/check/ranlib...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/ranlib...not found
Checking for program /opt/kusu/bin/ranlib...not found
Checking for program /opt/kusu/sbin/ranlib...not found
Checking for program /usr/pgsql-9.0/bin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconf1.a /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: '-c': No such file
Ranlib is not functional with your archiver. Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
GNU ar 2.17
Executing: ar -V
stdout:
GNU ar 2.17
Successful compile:
Source:
int foo(int a) {
return a+1;
Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
int b = foo(1); if (b);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -lconf1
Defined make macro "AR_FLAGS" to "cr"
Defined make macro "AR_LIB_SUFFIX" to "a"
Popping language C
TEST checkSharedLinker from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1246)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1246)
Check that the linker can produce shared libraries
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Checking shared linker /usr/bin/ar using flags []
Defined make macro "LD_SHARED" to "/usr/bin/ar"
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
Pushing language C
Popping language C
Executing: /usr/bin/ar cr /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconftest.a /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o ; /usr/bin/ranlib /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconftest.a
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -lconftest
Using shared linker /usr/bin/ar with flags [] and library extension a
Executing: uname -s
stdout: Linux
TEST checkSharedLinkerPaths from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1324)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1324)
Determine the shared linker path options
- IRIX: -rpath
- Linux, OSF: -Wl,-rpath,
- Solaris: -R
- FreeBSD: -Wl,-R,
Pushing language C
Executing: uname -s
stdout: Linux
Executing: mpifcc -V
Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Valid C linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Popping language C
Executing: uname -s
stdout: Linux
Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Valid Cxx linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Pushing language FC
Executing: uname -s
stdout: Linux
Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o
Valid FC linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Popping language FC
TEST checkLibC from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1359)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1359)
Test whether we need to explicitly include libc in shared linking
- Mac OSX requires an explicit reference to libc for shared linking
TEST checkDynamicLinker from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1408)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1408)
Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/dlfcn.h"
#line 25 "/usr/include/dlfcn.h"
#line 27 "/usr/include/dlfcn.h"
#line 1 "/usr/include/bits/dlfcn.h"
#line 30 "/usr/include/dlfcn.h"
#line 52 "/usr/include/dlfcn.h"
extern void *dlopen (const char *__file, int __mode) ;
extern int dlclose (void *__handle) ;
extern void *dlsym (void * __handle,
const char * __name) ;
#line 80 "/usr/include/dlfcn.h"
extern char *dlerror (void) ;
#line 188 "/usr/include/dlfcn.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Defined "HAVE_DLFCN_H" to "1"
Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ldl
Defined "HAVE_LIBDL" to "1"
Popping language C
Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
Checking dynamic linker /usr/bin/ar using flags []
Defined make macro "DYNAMICLINKER" to "/usr/bin/ar"
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: /usr/bin/ar -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconftest.so /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ldl
stderr:
/usr/bin/ar: no operation specified
Checking dynamic linker mpifcc using flags ['-shared']
Defined make macro "DYNAMICLINKER" to "mpifcc"
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -shared -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ldl
Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconftest.so -shared -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
printf("Could not load symbol\n");
return -1;
if ((*foo)()) {
printf("Invalid return from foo()\n");
return -1;
if (dlclose(handle)) {
printf("Could not close library\n");
return -1;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ldl
Using dynamic linker mpifcc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1454)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1454)
Output module data as defines and substitutions
Substituting "CC" with "mpifcc"
Substituting "CFLAGS" with "-Xg -O0"
Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "CPP" with "mpifcc -E"
Substituting "CPPFLAGS" with ""
Substituting "CXX" with "mpiFCC"
Substituting "CXX_CXXFLAGS" with ""
Substituting "CXXFLAGS" with "-Xg -O0"
Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
Substituting "CXXCPP" with "mpiFCC -E"
Substituting "CXXCPPFLAGS" with ""
Substituting "FC" with "mpifrt"
Substituting "FFLAGS" with "-X9 -O0"
Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "LDFLAGS" with ""
Substituting "LIBS" with "-ldl "
Substituting "SHARED_LIBRARY_FLAG" with ""
Executing: uname -s
stdout: Linux
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
Checks whether shared libraries should be used, for which you must
- Specify --with-shared-libraries
- Have found a working shared linker
Defines PETSC_USE_SHARED_LIBRARIES if they are used
Defined make rule "shared_arch" with dependencies "" and code []
Defined make macro "BUILDSHAREDLIB" to "no"
Defined "HAVE_SHARED_LIBRARIES" to "1"
Shared libraries - disabled
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:96)
Checks whether dynamic loading is available (with dlfcn.h and libdl)
Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:102)
Defines PETSC_SERIALIZE_FUNCTIONS if they are used
Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilerFlags.py:71)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:71)
Get the default compiler flags
Pushing language C
Executing: mpifcc --version
Ignoring default options which were overridden using --CFLAGS -Xg -O0
Optimization options found in CFLAGS. Skipping setting defaults
Popping language C
Executing: mpiFCC --version
Ignoring default options which were overridden using --CXXFLAGS -Xg -O0
Optimization options found in CXXFLAGS. Skipping setting defaults
Pushing language FC
Executing: mpifrt --version
Ignoring default options which were overridden using --FFLAGS -X9 -O0
Optimization options found in FFLAGS. Skipping setting defaults
Popping language FC
TEST configureDebugging from PETSc.options.debugging(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
Defined "USE_ERRORCHECKING" to "1"
Executing: mpifcc --help
TEST checkRestrict from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:137)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:137)
Check for the C/CXX restrict keyword
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.c", line 5: error: expected a ";"
float * restrict x;;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.c", line 5: warning: variable "restrict" was declared but never referenced
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.c".
Source:
int main() {
return 0;
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.c", line 5: warning: variable "x" was declared but never referenced
float * __restrict__ x;;
Source:
int main() {
return 0;
compilers: Set C restrict keyword to __restrict__
Defined "C_RESTRICT" to " __restrict__"
Popping language C
TEST checkCFormatting from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:310)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:310)
Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:108)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:108)
Check for C keyword: static inline
Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
return 0;
compilers: Set C StaticInline keyword to static inline
Popping language C
Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:321)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:321)
Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ldl
Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:164)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:164)
Determines the libraries needed to link with C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -### -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ldl
stdout:
/usr/bin/ld --eh-frame-hdr -m elf64_sparc -YP,/usr/lib64 -dynamic-linker /lib64/ld-linux.so.2 /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4 -u__metInit -ltrtmet -ltrtmet_c -Qy -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lm -lnsl -lutil //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64 -u_xfdb_Init -ltrtfdb -lfjrtcl -ltrtth -L/usr/lib64 -lmpg -lmpgpthread -lpapi -lrt -lelf -ldl -lgcc_s -lgcc -lc -lgcc_s -lgcc -lc /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o -L/opt/FJSVxosmmm/lib64 /usr/lib64/crtn.o
//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2 -ir-strip /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest
Popping language C
compilers: Checking arg /usr/bin/ld
compilers: Unknown arg /usr/bin/ld
compilers: Checking arg --eh-frame-hdr
compilers: Unknown arg --eh-frame-hdr
compilers: Checking arg -m
compilers: Unknown arg -m
compilers: Checking arg elf64_sparc
compilers: Unknown arg elf64_sparc
compilers: Checking arg -YP,/usr/lib64
compilers: Unknown arg -YP,/usr/lib64
compilers: Checking arg -dynamic-linker
compilers: Unknown arg -dynamic-linker
compilers: Checking arg /lib64/ld-linux.so.2
compilers: Unknown arg /lib64/ld-linux.so.2
compilers: Checking arg /usr/lib64/crt1.o
compilers: Unknown arg /usr/lib64/crt1.o
compilers: Checking arg /usr/lib64/crti.o
compilers: Unknown arg /usr/lib64/crti.o
compilers: Checking arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o
compilers: Unknown arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o
compilers: Checking arg -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4
compilers: Unknown arg -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4
compilers: Checking arg -u__metInit
compilers: Unknown arg -u__metInit
compilers: Checking arg -ltrtmet
compilers: Found library : -ltrtmet
compilers: Checking arg -ltrtmet_c
compilers: Found library : -ltrtmet_c
compilers: Checking arg -Qy
compilers: Unknown arg -Qy
compilers: Checking arg -o
compilers: Unknown arg -o
compilers: Checking arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest
compilers: Unknown arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest
compilers: Checking arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o
compilers: Unknown arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o
compilers: Checking arg -ldl
compilers: Found library : -ldl
compilers: Checking arg -L/opt/FJSVpxtof/sparc64fx/lib64
compilers: Found library directory: -L/opt/FJSVpxtof/sparc64fx/lib64
compilers: Checking arg -L/opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Found library directory: -L/opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Checking arg -lmpi
compilers: Found library : -lmpi
compilers: Checking arg -ltofucom
compilers: Found library : -ltofucom
compilers: Checking arg -ltofutop
compilers: Found library : -ltofutop
compilers: Checking arg -lnsl
compilers: Found library : -lnsl
compilers: Checking arg -lutil
compilers: Found library : -lutil
compilers: Checking arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o
compilers: Unknown arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o
compilers: Checking arg -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds
compilers: Unknown arg -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds
compilers: Checking arg -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64
compilers: Found library directory: -L//opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Checking arg -u_xfdb_Init
compilers: Unknown arg -u_xfdb_Init
compilers: Checking arg -ltrtfdb
compilers: Found library : -ltrtfdb
compilers: Checking arg -lfjrtcl
compilers: Found library : -lfjrtcl
compilers: Checking arg -ltrtth
compilers: Found library : -ltrtth
compilers: Checking arg -L/usr/lib64
compilers: Checking arg -lmpg
compilers: Found library : -lmpg
compilers: Checking arg -lmpgpthread
compilers: Found library : -lmpgpthread
compilers: Checking arg -lpapi
compilers: Found library : -lpapi
compilers: Checking arg -lrt
compilers: Found library : -lrt
compilers: Checking arg -lelf
compilers: Found library : -lelf
compilers: Checking arg -lgcc_s
compilers: Found library : -lgcc_s
compilers: Skipping system library: -lgcc
compilers: Checking arg -lc
compilers: Skipping system library: -lc
compilers: Checking arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o
compilers: Unknown arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o
compilers: Checking arg -L/opt/FJSVxosmmm/lib64
compilers: Found library directory: -L/opt/FJSVxosmmm/lib64
compilers: Checking arg /usr/lib64/crtn.o
compilers: Unknown arg /usr/lib64/crtn.o
compilers: Checking arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2
compilers: Unknown arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2
compilers: Checking arg -ir-strip
compilers: Unknown arg -ir-strip
compilers: Libraries needed to link C code with another linker: ['-ltrtmet', '-ltrtmet_c', '-ldl', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-lmpi', '-ltofucom', '-ltofutop', '-lnsl', '-lutil', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-ltrtfdb', '-lfjrtcl', '-ltrtth', '-lmpg', '-lmpgpthread', '-lpapi', '-lrt', '-lelf', '-lgcc_s', '-L/opt/FJSVxosmmm/lib64']
compilers: Check that C libraries can be used from Fortran
Pushing language FC
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest
Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1328)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1328)
Check if -MMD works for dependency generation, and add it if it does
Pushing language C
Trying C compiler flag -MMD -MP
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Rejected C compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying C compiler flag -xMMD
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying C compiler flag -qmakedep=gcc
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
stderr:
fcc: warning: -qmakedep=gcc is unrecognized option. This option is passed to the linker.
Source:
int main() {
return 0;
Rejecting compiler flag -qmakedep=gcc due to
Rejected C compiler flag -qmakedep=gcc
Trying C compiler flag -MD
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Popping language C
Trying Cxx compiler flag -MMD -MP
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying Cxx compiler flag -xMMD
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying Cxx compiler flag -qmakedep=gcc
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
stderr:
FCC: warning: -qmakedep=gcc is unrecognized option. This option is passed to the linker.
Source:
int main() {
return 0;
Rejected Cxx compiler flag -qmakedep=gcc
Trying Cxx compiler flag -MD
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -Xg -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Pushing language FC
Trying FC compiler flag -MMD -MP
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -xMMD
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -qmakedep=gcc
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
stderr:
frt: warning: -qmakedep=gcc cannot be specified.
Source:
program main
end
Rejected FC compiler flag -qmakedep=gcc because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -MD
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -X9 -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.d) was generated
Popping language FC
TEST checkC99Flag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1372)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1372)
Check for -std=c99 or equivalent flag
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c", line 10: error: expected an expression
for (int i=0; i<2; i++){
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c", line 10: error: identifier "i" is undefined
2 errors detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c".
Source:
int main() {
int x[2],y;
y = 5;
// c++ comment
int j = 2;
x[i] = i*j*y;
return 0;
Rejecting compiler flag due to nonzero status from link
PETSc Error: No output file produced
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 -std=c99 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c", line 6: warning: variable "x" was set but never used
int x[2],y;
Source:
int main() {
int x[2],y;
y = 5;
// c++ comment
int j = 2;
x[i] = i*j*y;
return 0;
Accepted C99 compile flag: -std=c99
Popping language C
Executing: mpiFCC --help
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.cc
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.cc", line 5: error: expected a ";"
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.cc", line 5: warning: variable "restrict" was declared but never referenced
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.cc".
Source:
int main() {
return 0;
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.cc", line 5: warning: variable "x" was declared but never referenced
Source:
int main() {
return 0;
compilers: Set Cxx restrict keyword to __restrict__
Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:359)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:359)
Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
return 0;
compilers: C++ has namespaces
Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:334)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:334)
Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
return 0;
Added Cxx compiler flag
TEST checkCxxStaticInline from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:122)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:122)
Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
return 0;
compilers: Set Cxx StaticInline keyword to static inline
Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:413)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:413)
Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -### -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stdout:
/usr/bin/ld --eh-frame-hdr -m elf64_sparc -YP,/usr/lib64 -dynamic-linker /lib64/ld-linux.so.2 /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4 -u__metInit -ltrtmetcpp -ltrtmet_c -Qy -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi_cxx -lmpi -ltofucom -ltofutop -lm -lnsl -lutil //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64 -lfjdemgl -u_xfdb_Init -ltrtfdb -lfjrtcl -ltrtth -L/usr/lib64 -lstd_mt -lmpg -lmpgpthread -lpthread -lpapi -lm -lrt -lelf -ldl -lstdc++ -lgcc_s -lgcc -lc -lgcc_s -lgcc -lc /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o -L/opt/FJSVxosmmm/lib64 /usr/lib64/crtn.o
compilers: Checking arg -ltrtmetcpp
compilers: Found library: -ltrtmetcpp
compilers: Found library: -ltrtmet_c
Library already in C list so skipping in C++
compilers: Found library: -ldl
compilers: Found library: -lmpi
compilers: Found library: -ltofucom
compilers: Found library: -ltofutop
compilers: Found library: -lnsl
compilers: Found library: -lutil
compilers: Checking arg -L//opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Found library: -ltrtfdb
compilers: Found library: -lfjrtcl
compilers: Found library: -ltrtth
compilers: Found library: -lmpg
compilers: Found library: -lmpgpthread
compilers: Found library: -lpapi
compilers: Found library: -lrt
compilers: Found library: -lelf
compilers: Found library: -lgcc_s
compilers: Checking arg -lmpi_cxx
compilers: Found library: -lmpi_cxx
compilers: Checking arg -lfjdemgl
compilers: Found library: -lfjdemgl
compilers: Checking arg -lstd_mt
compilers: Found library: -lstd_mt
compilers: Checking arg -lpthread
compilers: Found library: -lpthread
compilers: Checking arg -lstdc++
compilers: Found library: -lstdc++
compilers: Libraries needed to link Cxx code with another linker: ['-ltrtmetcpp', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-L/opt/FJSVxosmmm/lib64', '-lmpi_cxx', '-lfjdemgl', '-lstd_mt', '-lpthread', '-lstdc++']
compilers: Check that Cxx libraries can be used from C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Popping language C
compilers: Check that Cxx libraries can be used from Fortran
Pushing language FC
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Popping language FC
TEST checkCxx11 from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:374)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:374)
Determine the option needed to support the C++11 dialect
We auto-detect C++11 if the compiler supports it without options,
otherwise we require with-cxx-dialect=C++11 to try adding flags to
support it.
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Possible ERROR while running compiler: exit code 1024
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc", line 4: catastrophic error: cannot open source file "random"
#include <random>
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc".
Compilation terminated.
Source:
#include <random>
template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
std::random_device rd;
std::mt19937 mt(rd());
std::normal_distribution<double> dist(0,1);
const double x = dist(mt);
return 0;
#include <random>
TEST checkFortranTypeSizes from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:572)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:572)
Check whether real*8 is supported and suggest flags which will allow support
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
stderr:
Fortran diagnostic messages: program name(main)
jwd2006i-i "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F", line 2: 'variable' is declared but never referenced.
Source:
program main
real*8 variable
end
Popping language FC
TEST checkFortranNameMangling from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:631)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:631)
Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Pushing language C
Successful compile:
Source:
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confc.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
compilers: Fortran name mangling is underscore
Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:668)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:668)
Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1_chk()
end
Pushing language FC
Popping language FC
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o: In function `MAIN__':
conftest.F:(.text+0x30): undefined reference to `d1_chk_'
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o:(.data+0x0): undefined reference to `d1_chk_'
Popping language FC
TEST checkFortranPreprocessor from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:678)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:678)
Determine if Fortran handles preprocessing properly
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef dummy
fooey
#endif
end
Added FC compiler flag
Popping language FC
compilers: Fortran uses CPP preprocessor
TEST checkFortranDefineCompilerOption from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:699)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:699)
Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -X9 -O0 -DTesting /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef Testing
fooey
#endif
end
Defined make macro "FC_DEFINE_FLAG" to "-D"
Popping language FC
compilers: Fortran uses -D for defining macro
TEST checkFortranLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:716)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:716)
Substitutes for FLIBS the libraries needed to link with Fortran
This macro is intended to be used in those situations when it is
necessary to mix, e.g. C++ and Fortran 77, source code into a single
program or shared library.
For example, if object files from a C++ and Fortran 77 compiler must
be linked together, then the C++ compiler/linker must be used for
linking (since special C++-ish things need to happen at link time
like calling global constructors, instantiating templates, enabling
exception support, etc.).
However, the Fortran 77 intrinsic and run-time libraries must be
linked in as well, but the C++ compiler/linker does not know how to
add these Fortran 77 libraries.
This code was translated from the autoconf macro which was packaged in
its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
However, nearly all of this macro came from the OCTAVE_FLIBS macro in
octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
for writing this extremely useful macro.
Pushing language FC
Executing: mpifrt -V
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -v -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
compilers: Libraries needed to link Fortran code with the C linker: []
compilers: Libraries needed to link Fortran main with the C linker: []
compilers: Check that Fortran libraries can be used from C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Popping language C
compilers: Check that Fortran libraries can be used from C++
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
compilers: Fortran libraries can be used from C++
TEST checkFortranLinkingCxx from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1062)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1062)
Check that Fortran can be linked against C++
Successful compile:
Source:
extern "C" void d1chk_(void);
void foo(void){d1chk_();}
Successful compile:
Source:
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/cxxobj.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confc.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/cxxobj.o:(.eh_frame+0x12): undefined reference to `__gxx_personality_v0'
Popping language FC
Successful compile:
Source:
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/cxxobj.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confc.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
compilers: Fortran can link C++ functions using the C++ compiler libraries
TEST checkFortran90 from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1097)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1097)
Determine whether the Fortran compiler handles F90
Pushing language FC
Successful compile:
Source:
program main
INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
INTEGER (KIND=int) :: ierr
ierr = 1
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "USING_F90" to "1"
Fortran compiler supports F90
Popping language FC
TEST checkFortran2003 from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1110)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1110)
Determine whether the Fortran compiler handles F2003
Pushing language FC
Successful compile:
Source:
program main
use,intrinsic :: iso_c_binding
Type(C_Ptr),Dimension(:),Pointer :: CArray
character(kind=c_char),pointer :: nullc => null()
character(kind=c_char,len=5),dimension(:),pointer::list1
allocate(list1(5))
CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
end
Pushing language FC
Popping language FC
Defined "USING_F2003" to "1"
Fortran compiler supports F2003
Popping language FC
TEST checkFortran90Array from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1130)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1130)
Check for F90 array interfaces
Executing: uname -s
stdout: Linux
Pushing language C
Successful compile:
Source:
#include<stdio.h>
#include <stdlib.h>
void f90arraytest_(void* a1, void* a2,void* a3, void* i)
printf("arrays [%p %p %p]\n",a1,a2,a3);
fflush(stdout);
return;
void f90ptrtest_(void* a1, void* a2,void* a3, void* i, void* p1 ,void* p2, void* p3)
if ((p1 == p3) && (p1 != p2)) {
printf("pointers match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
} else {
printf("pointers do not match! [%p %p] [%p]\n",p1,p3,p2);
fflush(stdout);
exit(111);
return;
Popping language C
Pushing language FC
Successful compile:
Source:
program main
Interface
Subroutine f90ptrtest(p1,p2,p3,i)
integer, pointer :: p1(:,:)
integer, pointer :: p2(:,:)
integer, pointer :: p3(:,:)
integer i
End Subroutine
End Interface
integer, pointer :: ptr1(:,:),ptr2(:,:)
integer, target :: array(6:8,9:21)
integer in
in = 25
ptr1 => array
ptr2 => array
call f90arraytest(ptr1,ptr2,ptr1,in)
call f90ptrtest(ptr1,ptr2,ptr1,in)
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/fooobj.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest
stdout:
arrays [0x20000ac0 0x20000ac0 0x20000ac0]
arrays [0x20000a60 0x20000a00 0x20000a60]
pointers match! [0x20000a60 0x20000a60] [0x20000a00]
Popping language FC
Defined "HAVE_F90_2PTR_ARG" to "1"
compilers: F90 compiler uses two arguments for array pointers
TEST checkFortranModuleInclude from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1217)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1217)
Figures out what flag is used to specify the include path for Fortran modules
Pushing language FC
Successful compile:
Source:
module configtest
integer testint
parameter (testint = 42)
end module configtest
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
Successful compile:
Source:
program main
use configtest
write(*,*) testint
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/configtest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
compilers: Fortran module include flag -I found
Popping language FC
TEST checkFortranModuleOutput from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1283)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1283)
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -module /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
Successful compile:
Source:
module configtest
integer testint
compilers: Fortran module output flag -module failed
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -module:/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
Successful compile:
Source:
module configtest
integer testint
compilers: Fortran module output flag -module: failed
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -fmod=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
stderr:
frt: warning: Invalid suboption mod=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir specified for -f.
Source:
module configtest
integer testint
compilers: Fortran module output flag -fmod= failed
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -J/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
stderr:
frt: warning: -J/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir is unrecognized option. This option is passed to the linker.
Source:
module configtest
integer testint
compilers: Fortran module output flag -J failed
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -M/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/confdir -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers/conftest.F
Successful compile:
Source:
module configtest
integer testint
compilers: Fortran module output flag -M found
Popping language FC
TEST setupFrameworkCompilers from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1437)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1437)
TEST configureClosure from config.utilities.closure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
Determine if Apple ^close syntax is supported in C
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure/conftest.c
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure/conftest.c", line 6: error: expected an identifier
int (^closure)(int);;
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure/conftest.c".
Source:
#include <stdio.h>
int main() {
return 0;
Compile failed inside link
TEST configureFortranCPP from PETSc.options.fortranCPP(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/fortranCPP.py:27)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:27)
Handle case where Fortran cannot preprocess properly
Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
Defined "USE_FORTRAN_INTERFACES" to "1"
TEST checkStdC from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
return 0;
Source:
#include <string.h>
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/string.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 27 "/usr/include/string.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 34 "/usr/include/string.h"
extern void *memcpy (void * __dest,
const void * __src, size_t __n)
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void * __dest, const void * __src,
int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) ;
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
extern void *memchr (const void *__s, int __c, size_t __n)
#line 80 "/usr/include/string.h"
extern char *strcpy (char * __dest, const char * __src)
extern char *strncpy (char * __dest,
const char * __src, size_t __n)
extern char *strcat (char * __dest, const char * __src)
extern char *strncat (char * __dest, const char * __src,
size_t __n) ;
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char * __dest,
#line 127 "/usr/include/string.h"
extern char *strdup (const char *__s)
#line 164 "/usr/include/string.h"
extern char *strchr (const char *__s, int __c)
extern char *strrchr (const char *__s, int __c)
#line 180 "/usr/include/string.h"
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
extern char *strpbrk (const char *__s, const char *__accept)
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char * __s, const char * __delim)
extern char *__strtok_r (char * __s,
const char * __delim,
char ** __save_ptr)
extern char *strtok_r (char * __s, const char * __delim,
char ** __save_ptr)
#line 238 "/usr/include/string.h"
extern size_t strlen (const char *__s)
#line 252 "/usr/include/string.h"
extern char *strerror (int __errnum) ;
extern int __xpg_strerror_r (int __errnum, char *__buf, size_t __buflen)
#line 285 "/usr/include/string.h"
extern void __bzero (void *__s, size_t __n) ;
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) ;
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern char *index (const char *__s, int __c)
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) ;
#line 329 "/usr/include/string.h"
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
#line 350 "/usr/include/string.h"
extern char *strsep (char ** __stringp,
#line 396 "/usr/include/string.h"
#line 431 "/usr/include/string.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Source:
#include <stdlib.h>
stdout:
#line 1 "/usr/include/stdlib.h"
#line 26 "/usr/include/stdlib.h"
typedef int wchar_t;
#line 34 "/usr/include/stdlib.h"
#line 95 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) ;
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
extern long long int atoll (const char *__nptr)
extern double strtod (const char * __nptr,
char ** __endptr)
extern float strtof (const char * __nptr,
char ** __endptr) ;
extern long double strtold (const char * __nptr,
char ** __endptr)
extern long int strtol (const char * __nptr,
char ** __endptr, int __base)
extern unsigned long int strtoul (const char * __nptr,
extern long long int strtoq (const char * __nptr,
extern unsigned long long int strtouq (const char * __nptr,
extern long long int strtoll (const char * __nptr,
extern unsigned long long int strtoull (const char * __nptr,
#line 274 "/usr/include/stdlib.h"
#line 305 "/usr/include/stdlib.h"
extern char *l64a (long int __n) ;
extern long int a64l (const char *__s)
#line 1 "/usr/include/sys/types.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 28 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 32 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
#line 419 "/usr/include/time.h"
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 35 "/usr/include/sys/select.h"
typedef __sigset_t sigset_t;
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 45 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 221 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 271 "/usr/include/sys/types.h"
#line 321 "/usr/include/stdlib.h"
extern long int random (void) ;
extern void srandom (unsigned int __seed) ;
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) ;
extern char *setstate (char *__statebuf) ;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data * __buf,
int32_t * __result) ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char * __statebuf,
size_t __statelen,
struct random_data * __buf)
extern int setstate_r (char * __statebuf,
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
extern int rand_r (unsigned int *__seed) ;
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3]) ;
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) ;
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
unsigned long long int __a;
extern int drand48_r (struct drand48_data * __buffer,
double * __result) ;
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data * __buffer,
long int * __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data * __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) ;
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
extern void free (void *__ptr) ;
extern void cfree (void *__ptr) ;
#line 1 "/usr/include/alloca.h"
#line 23 "/usr/include/alloca.h"
#line 26 "/usr/include/alloca.h"
extern void *alloca (size_t __size) ;
#line 498 "/usr/include/stdlib.h"
extern void *valloc (size_t __size) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) ;
extern int atexit (void (*__func) (void)) ;
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) ;
extern void _Exit (int __status) ;
extern char *getenv (const char *__name) ;
extern char *__secure_getenv (const char *__name)
extern int putenv (char *__string) ;
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) ;
extern int clearenv (void) ;
extern char *mktemp (char *__template) ;
extern int mkstemp (char *__template) ;
#line 607 "/usr/include/stdlib.h"
extern char *mkdtemp (char *__template) ;
#line 638 "/usr/include/stdlib.h"
extern int system (const char *__command) ;
#line 655 "/usr/include/stdlib.h"
extern char *realpath (const char * __name,
char * __resolved) ;
typedef int (*__compar_fn_t) (const void *, const void *);
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) ;
extern int abs (int __x) ;
extern long int labs (long int __x) ;
extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
extern lldiv_t lldiv (long long int __numer,
long long int __denom)
extern char *ecvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *fcvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *gcvt (double __value, int __ndigit, char *__buf)
extern char *qecvt (long double __value, int __ndigit,
int * __decpt, int * __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int * __decpt,
int * __sign, char * __buf,
size_t __len) ;
extern int fcvt_r (double __value, int __ndigit, int * __decpt,
size_t __len) ;
extern int qecvt_r (long double __value, int __ndigit,
int * __decpt, int * __sign,
char * __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) ;
extern int mbtowc (wchar_t * __pwc,
const char * __s, size_t __n) ;
extern int wctomb (char *__s, wchar_t __wchar) ;
extern size_t mbstowcs (wchar_t * __pwcs,
extern size_t wcstombs (char * __s,
const wchar_t * __pwcs, size_t __n)
extern int rpmatch (const char *__response) ;
#line 820 "/usr/include/stdlib.h"
extern int posix_openpt (int __oflag) ;
#line 851 "/usr/include/stdlib.h"
#line 862 "/usr/include/stdlib.h"
extern int getloadavg (double __loadavg[], int __nelem)
#line 879 "/usr/include/stdlib.h"
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
int i;
for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
exit(0);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest
Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
You lose.
# endif
#endif
stdout:
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 5 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/sys/stat.h"
#line 28 "/usr/include/sys/stat.h"
#line 40 "/usr/include/sys/stat.h"
#line 63 "/usr/include/sys/stat.h"
#line 82 "/usr/include/sys/stat.h"
#line 104 "/usr/include/sys/stat.h"
#line 1 "/usr/include/bits/stat.h"
struct stat
__dev_t st_dev;
unsigned short int __pad1;
__ino_t st_ino;
__mode_t st_mode;
__nlink_t st_nlink;
__uid_t st_uid;
__gid_t st_gid;
__dev_t st_rdev;
unsigned short int __pad2;
__off_t st_size;
__blksize_t st_blksize;
__blkcnt_t st_blocks;
struct timespec st_atim;
struct timespec st_mtim;
struct timespec st_ctim;
#line 85 "/usr/include/bits/stat.h"
unsigned long int __unused4;
unsigned long int __unused5;
#line 132 "/usr/include/bits/stat.h"
#line 151 "/usr/include/bits/stat.h"
#line 166 "/usr/include/bits/stat.h"
#line 108 "/usr/include/sys/stat.h"
#line 126 "/usr/include/sys/stat.h"
#line 141 "/usr/include/sys/stat.h"
extern int stat (const char * __file,
struct stat * __buf) ;
extern int fstat (int __fd, struct stat *__buf) ;
#line 232 "/usr/include/sys/stat.h"
#line 256 "/usr/include/sys/stat.h"
extern int lstat (const char * __file,
#line 279 "/usr/include/sys/stat.h"
extern int chmod (const char *__file, __mode_t __mode)
extern int lchmod (const char *__file, __mode_t __mode)
extern int fchmod (int __fd, __mode_t __mode) ;
#line 304 "/usr/include/sys/stat.h"
extern __mode_t umask (__mode_t __mask) ;
extern int mkdir (const char *__path, __mode_t __mode)
#line 328 "/usr/include/sys/stat.h"
extern int mknod (const char *__path, __mode_t __mode, __dev_t __dev)
#line 344 "/usr/include/sys/stat.h"
extern int mkfifo (const char *__path, __mode_t __mode)
#line 357 "/usr/include/sys/stat.h"
#line 366 "/usr/include/sys/stat.h"
#line 394 "/usr/include/sys/stat.h"
extern int __fxstat (int __ver, int __fildes, struct stat *__stat_buf)
extern int __xstat (int __ver, const char *__filename,
struct stat *__stat_buf) ;
extern int __lxstat (int __ver, const char *__filename,
extern int __fxstatat (int __ver, int __fildes, const char *__filename,
struct stat *__stat_buf, int __flag)
#line 428 "/usr/include/sys/stat.h"
#line 440 "/usr/include/sys/stat.h"
extern int __xmknod (int __ver, const char *__path, __mode_t __mode,
__dev_t *__dev) ;
extern int __xmknodat (int __ver, int __fd, const char *__path,
__mode_t __mode, __dev_t *__dev)
#line 531 "/usr/include/sys/stat.h"
#line 6 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
TEST checkSysWait from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
Successful compile:
Source:
#include <sys/wait.h>
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
int s;
wait (&s);
s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
return 0;
Defined "HAVE_SYS_WAIT_H" to "1"
TEST checkTime from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
#line 30 "/usr/include/time.h"
#line 40 "/usr/include/time.h"
#line 43 "/usr/include/bits/time.h"
#line 44 "/usr/include/time.h"
#line 58 "/usr/include/time.h"
typedef __clock_t clock_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
struct sigevent;
extern clock_t clock (void) ;
extern time_t time (time_t *__timer) ;
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) ;
extern size_t strftime (char * __s, size_t __maxsize,
const char * __format,
const struct tm * __tp) ;
#line 212 "/usr/include/time.h"
#line 227 "/usr/include/time.h"
extern struct tm *gmtime (const time_t *__timer) ;
extern struct tm *localtime (const time_t *__timer) ;
extern struct tm *gmtime_r (const time_t * __timer,
struct tm * __tp) ;
extern struct tm *localtime_r (const time_t * __timer,
struct tm * __tp) ;
extern char *asctime (const struct tm *__tp) ;
extern char *ctime (const time_t *__timer) ;
extern char *asctime_r (const struct tm * __tp,
char * __buf) ;
extern char *ctime_r (const time_t * __timer,
char * __buf) ;
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) ;
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) ;
extern time_t timegm (struct tm *__tp) ;
extern time_t timelocal (struct tm *__tp) ;
extern int dysize (int __year) ;
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
extern int timer_create (clockid_t __clock_id,
struct sigevent * __evp,
timer_t * __timerid) ;
extern int timer_delete (timer_t __timerid) ;
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec * __value,
struct itimerspec * __ovalue) ;
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) ;
#line 400 "/usr/include/time.h"
#line 415 "/usr/include/time.h"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
#line 1 "/usr/include/sys/time.h"
#line 24 "/usr/include/sys/time.h"
#line 26 "/usr/include/sys/time.h"
#line 28 "/usr/include/sys/time.h"
struct timeval
__time_t tv_sec;
#line 30 "/usr/include/sys/time.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
typedef struct
} fd_set;
#line 32 "/usr/include/sys/time.h"
#line 52 "/usr/include/sys/time.h"
struct timezone
int tz_minuteswest;
int tz_dsttime;
typedef struct timezone * __timezone_ptr_t;
extern int gettimeofday (struct timeval * __tv,
__timezone_ptr_t __tz) ;
extern int settimeofday (const struct timeval *__tv,
const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
struct timeval *__olddelta) ;
enum __itimer_which
ITIMER_REAL = 0,
ITIMER_VIRTUAL = 1,
ITIMER_PROF = 2
struct itimerval
struct timeval it_interval;
struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
struct itimerval *__value) ;
extern int setitimer (__itimer_which_t __which,
const struct itimerval * __new,
struct itimerval * __old) ;
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) ;
#line 159 "/usr/include/sys/time.h"
#line 190 "/usr/include/sys/time.h"
Defined "HAVE_SYS_TIME_H" to "1"
Successful compile:
Source:
#include <sys/time.h>
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
return 0;
Defined "TIME_WITH_SYS_TIME" to "1"
TEST checkMath from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
Checks for the math headers and defines
Checking for header: math.h
stdout:
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/math.h"
#line 1 "/usr/include/math.h"
#line 29 "/usr/include/math.h"
#line 1 "/usr/include/bits/huge_val.h"
#line 40 "/usr/include/bits/huge_val.h"
#line 42 "/usr/include/bits/huge_val.h"
typedef union { unsigned char __c[8]; double __d; } __huge_val_t;
#line 51 "/usr/include/bits/huge_val.h"
static __huge_val_t __huge_val = { { 0x7f, 0xf0, 0, 0, 0, 0, 0, 0 } };
#line 35 "/usr/include/math.h"
#line 1 "/usr/include/bits/huge_valf.h"
#line 40 "/usr/include/bits/huge_valf.h"
typedef union { unsigned char __c[4]; float __f; } __huge_valf_t;
#line 49 "/usr/include/bits/huge_valf.h"
static __huge_valf_t __huge_valf = { { 0x7f, 0x80, 0, 0 } };
#line 37 "/usr/include/math.h"
#line 1 "/usr/include/bits/huge_vall.h"
#line 34 "/usr/include/bits/huge_vall.h"
typedef union { unsigned char __c[16]; long double __ld; } __huge_vall_t;
#line 43 "/usr/include/bits/huge_vall.h"
static __huge_vall_t __huge_vall = { { 0x7f, 0xff, 0,0,0,0,0,0,0,0,0,0,0,0,0,0 } };
#line 38 "/usr/include/math.h"
#line 1 "/usr/include/bits/inf.h"
#line 41 "/usr/include/math.h"
#line 1 "/usr/include/bits/nan.h"
#line 39 "/usr/include/bits/nan.h"
#line 48 "/usr/include/bits/nan.h"
static union { unsigned char __c[4]; float __d; } __nan_union
= { { 0x7f, 0xc0, 0, 0 } };
#line 44 "/usr/include/math.h"
#line 1 "/usr/include/bits/mathdef.h"
#line 25 "/usr/include/bits/mathdef.h"
#line 47 "/usr/include/bits/mathdef.h"
typedef double float_t;
typedef double double_t;
#line 48 "/usr/include/math.h"
#line 66 "/usr/include/math.h"
#line 1 "/usr/include/bits/mathcalls.h"
extern double acos (double __x) ; extern double __acos (double __x) ;
extern double asin (double __x) ; extern double __asin (double __x) ;
extern double atan (double __x) ; extern double __atan (double __x) ;
extern double atan2 (double __y, double __x) ; extern double __atan2 (double __y, double __x) ;
extern double cos (double __x) ; extern double __cos (double __x) ;
extern double sin (double __x) ; extern double __sin (double __x) ;
extern double tan (double __x) ; extern double __tan (double __x) ;
extern double cosh (double __x) ; extern double __cosh (double __x) ;
extern double sinh (double __x) ; extern double __sinh (double __x) ;
extern double tanh (double __x) ; extern double __tanh (double __x) ;
extern double acosh (double __x) ; extern double __acosh (double __x) ;
extern double asinh (double __x) ; extern double __asinh (double __x) ;
extern double atanh (double __x) ; extern double __atanh (double __x) ;
extern double exp (double __x) ; extern double __exp (double __x) ;
extern double frexp (double __x, int *__exponent) ; extern double __frexp (double __x, int *__exponent) ;
extern double ldexp (double __x, int __exponent) ; extern double __ldexp (double __x, int __exponent) ;
extern double log (double __x) ; extern double __log (double __x) ;
extern double log10 (double __x) ; extern double __log10 (double __x) ;
extern double modf (double __x, double *__iptr) ; extern double __modf (double __x, double *__iptr) ;
#line 125 "/usr/include/bits/mathcalls.h"
extern double expm1 (double __x) ; extern double __expm1 (double __x) ;
extern double log1p (double __x) ; extern double __log1p (double __x) ;
extern double logb (double __x) ; extern double __logb (double __x) ;
extern double exp2 (double __x) ; extern double __exp2 (double __x) ;
extern double log2 (double __x) ; extern double __log2 (double __x) ;
extern double pow (double __x, double __y) ; extern double __pow (double __x, double __y) ;
extern double sqrt (double __x) ; extern double __sqrt (double __x) ;
extern double hypot (double __x, double __y) ; extern double __hypot (double __x, double __y) ;
extern double cbrt (double __x) ; extern double __cbrt (double __x) ;
extern double ceil (double __x) ; extern double __ceil (double __x) ;
extern double fabs (double __x) ; extern double __fabs (double __x) ;
extern double floor (double __x) ; extern double __floor (double __x) ;
extern double fmod (double __x, double __y) ; extern double __fmod (double __x, double __y) ;
extern int __isinf (double __value) ;
extern int __finite (double __value) ;
extern int isinf (double __value) ;
extern int finite (double __value) ;
extern double drem (double __x, double __y) ; extern double __drem (double __x, double __y) ;
extern double significand (double __x) ; extern double __significand (double __x) ;
extern double copysign (double __x, double __y) ; extern double __copysign (double __x, double __y) ;
extern double nan (const char *__tagb) ; extern double __nan (const char *__tagb) ;
extern int __isnan (double __value) ;
extern int isnan (double __value) ;
extern double j0 (double) ; extern double __j0 (double) ;
extern double j1 (double) ; extern double __j1 (double) ;
extern double jn (int, double) ; extern double __jn (int, double) ;
extern double y0 (double) ; extern double __y0 (double) ;
extern double y1 (double) ; extern double __y1 (double) ;
extern double yn (int, double) ; extern double __yn (int, double) ;
extern double erf (double) ; extern double __erf (double) ;
extern double erfc (double) ; extern double __erfc (double) ;
extern double lgamma (double) ; extern double __lgamma (double) ;
extern double tgamma (double) ; extern double __tgamma (double) ;
extern double gamma (double) ; extern double __gamma (double) ;
extern double lgamma_r (double, int *__signgamp) ; extern double __lgamma_r (double, int *__signgamp) ;
extern double rint (double __x) ; extern double __rint (double __x) ;
extern double nextafter (double __x, double __y) ; extern double __nextafter (double __x, double __y) ;
extern double nexttoward (double __x, long double __y) ; extern double __nexttoward (double __x, long double __y) ;
extern double remainder (double __x, double __y) ; extern double __remainder (double __x, double __y) ;
extern double scalbn (double __x, int __n) ; extern double __scalbn (double __x, int __n) ;
extern int ilogb (double __x) ; extern int __ilogb (double __x) ;
extern double scalbln (double __x, long int __n) ; extern double __scalbln (double __x, long int __n) ;
extern double nearbyint (double __x) ; extern double __nearbyint (double __x) ;
extern double round (double __x) ; extern double __round (double __x) ;
extern double trunc (double __x) ; extern double __trunc (double __x) ;
extern double remquo (double __x, double __y, int *__quo) ; extern double __remquo (double __x, double __y, int *__quo) ;
extern long int lrint (double __x) ; extern long int __lrint (double __x) ;
extern long long int llrint (double __x) ; extern long long int __llrint (double __x) ;
extern long int lround (double __x) ; extern long int __lround (double __x) ;
extern long long int llround (double __x) ; extern long long int __llround (double __x) ;
extern double fdim (double __x, double __y) ; extern double __fdim (double __x, double __y) ;
extern double fmax (double __x, double __y) ; extern double __fmax (double __x, double __y) ;
extern double fmin (double __x, double __y) ; extern double __fmin (double __x, double __y) ;
extern int __fpclassify (double __value)
extern int __signbit (double __value)
extern double fma (double __x, double __y, double __z) ; extern double __fma (double __x, double __y, double __z) ;
extern double scalb (double __x, double __n) ; extern double __scalb (double __x, double __n) ;
#line 72 "/usr/include/math.h"
extern float acosf (float __x) ; extern float __acosf (float __x) ;
extern float asinf (float __x) ; extern float __asinf (float __x) ;
extern float atanf (float __x) ; extern float __atanf (float __x) ;
extern float atan2f (float __y, float __x) ; extern float __atan2f (float __y, float __x) ;
extern float cosf (float __x) ; extern float __cosf (float __x) ;
extern float sinf (float __x) ; extern float __sinf (float __x) ;
extern float tanf (float __x) ; extern float __tanf (float __x) ;
extern float coshf (float __x) ; extern float __coshf (float __x) ;
extern float sinhf (float __x) ; extern float __sinhf (float __x) ;
extern float tanhf (float __x) ; extern float __tanhf (float __x) ;
extern float acoshf (float __x) ; extern float __acoshf (float __x) ;
extern float asinhf (float __x) ; extern float __asinhf (float __x) ;
extern float atanhf (float __x) ; extern float __atanhf (float __x) ;
extern float expf (float __x) ; extern float __expf (float __x) ;
extern float frexpf (float __x, int *__exponent) ; extern float __frexpf (float __x, int *__exponent) ;
extern float ldexpf (float __x, int __exponent) ; extern float __ldexpf (float __x, int __exponent) ;
extern float logf (float __x) ; extern float __logf (float __x) ;
extern float log10f (float __x) ; extern float __log10f (float __x) ;
extern float modff (float __x, float *__iptr) ; extern float __modff (float __x, float *__iptr) ;
extern float expm1f (float __x) ; extern float __expm1f (float __x) ;
extern float log1pf (float __x) ; extern float __log1pf (float __x) ;
extern float logbf (float __x) ; extern float __logbf (float __x) ;
extern float exp2f (float __x) ; extern float __exp2f (float __x) ;
extern float log2f (float __x) ; extern float __log2f (float __x) ;
extern float powf (float __x, float __y) ; extern float __powf (float __x, float __y) ;
extern float sqrtf (float __x) ; extern float __sqrtf (float __x) ;
extern float hypotf (float __x, float __y) ; extern float __hypotf (float __x, float __y) ;
extern float cbrtf (float __x) ; extern float __cbrtf (float __x) ;
extern float ceilf (float __x) ; extern float __ceilf (float __x) ;
extern float fabsf (float __x) ; extern float __fabsf (float __x) ;
extern float floorf (float __x) ; extern float __floorf (float __x) ;
extern float fmodf (float __x, float __y) ; extern float __fmodf (float __x, float __y) ;
extern int __isinff (float __value) ;
extern int __finitef (float __value) ;
extern int isinff (float __value) ;
extern int finitef (float __value) ;
extern float dremf (float __x, float __y) ; extern float __dremf (float __x, float __y) ;
extern float significandf (float __x) ; extern float __significandf (float __x) ;
extern float copysignf (float __x, float __y) ; extern float __copysignf (float __x, float __y) ;
extern float nanf (const char *__tagb) ; extern float __nanf (const char *__tagb) ;
extern int __isnanf (float __value) ;
extern int isnanf (float __value) ;
extern float j0f (float) ; extern float __j0f (float) ;
extern float j1f (float) ; extern float __j1f (float) ;
extern float jnf (int, float) ; extern float __jnf (int, float) ;
extern float y0f (float) ; extern float __y0f (float) ;
extern float y1f (float) ; extern float __y1f (float) ;
extern float ynf (int, float) ; extern float __ynf (int, float) ;
extern float erff (float) ; extern float __erff (float) ;
extern float erfcf (float) ; extern float __erfcf (float) ;
extern float lgammaf (float) ; extern float __lgammaf (float) ;
extern float tgammaf (float) ; extern float __tgammaf (float) ;
extern float gammaf (float) ; extern float __gammaf (float) ;
extern float lgammaf_r (float, int *__signgamp) ; extern float __lgammaf_r (float, int *__signgamp) ;
extern float rintf (float __x) ; extern float __rintf (float __x) ;
extern float nextafterf (float __x, float __y) ; extern float __nextafterf (float __x, float __y) ;
extern float nexttowardf (float __x, long double __y) ; extern float __nexttowardf (float __x, long double __y) ;
extern float remainderf (float __x, float __y) ; extern float __remainderf (float __x, float __y) ;
extern float scalbnf (float __x, int __n) ; extern float __scalbnf (float __x, int __n) ;
extern int ilogbf (float __x) ; extern int __ilogbf (float __x) ;
extern float scalblnf (float __x, long int __n) ; extern float __scalblnf (float __x, long int __n) ;
extern float nearbyintf (float __x) ; extern float __nearbyintf (float __x) ;
extern float roundf (float __x) ; extern float __roundf (float __x) ;
extern float truncf (float __x) ; extern float __truncf (float __x) ;
extern float remquof (float __x, float __y, int *__quo) ; extern float __remquof (float __x, float __y, int *__quo) ;
extern long int lrintf (float __x) ; extern long int __lrintf (float __x) ;
extern long long int llrintf (float __x) ; extern long long int __llrintf (float __x) ;
extern long int lroundf (float __x) ; extern long int __lroundf (float __x) ;
extern long long int llroundf (float __x) ; extern long long int __llroundf (float __x) ;
extern float fdimf (float __x, float __y) ; extern float __fdimf (float __x, float __y) ;
extern float fmaxf (float __x, float __y) ; extern float __fmaxf (float __x, float __y) ;
extern float fminf (float __x, float __y) ; extern float __fminf (float __x, float __y) ;
extern int __fpclassifyf (float __value)
extern int __signbitf (float __value)
extern float fmaf (float __x, float __y, float __z) ; extern float __fmaf (float __x, float __y, float __z) ;
extern float scalbf (float __x, float __n) ; extern float __scalbf (float __x, float __n) ;
#line 95 "/usr/include/math.h"
#line 129 "/usr/include/math.h"
extern long double acosl (long double __x) ; extern long double __acosl (long double __x) ;
extern long double asinl (long double __x) ; extern long double __asinl (long double __x) ;
extern long double atanl (long double __x) ; extern long double __atanl (long double __x) ;
extern long double atan2l (long double __y, long double __x) ; extern long double __atan2l (long double __y, long double __x) ;
extern long double cosl (long double __x) ; extern long double __cosl (long double __x) ;
extern long double sinl (long double __x) ; extern long double __sinl (long double __x) ;
extern long double tanl (long double __x) ; extern long double __tanl (long double __x) ;
extern long double coshl (long double __x) ; extern long double __coshl (long double __x) ;
extern long double sinhl (long double __x) ; extern long double __sinhl (long double __x) ;
extern long double tanhl (long double __x) ; extern long double __tanhl (long double __x) ;
extern long double acoshl (long double __x) ; extern long double __acoshl (long double __x) ;
extern long double asinhl (long double __x) ; extern long double __asinhl (long double __x) ;
extern long double atanhl (long double __x) ; extern long double __atanhl (long double __x) ;
extern long double expl (long double __x) ; extern long double __expl (long double __x) ;
extern long double frexpl (long double __x, int *__exponent) ; extern long double __frexpl (long double __x, int *__exponent) ;
extern long double ldexpl (long double __x, int __exponent) ; extern long double __ldexpl (long double __x, int __exponent) ;
extern long double logl (long double __x) ; extern long double __logl (long double __x) ;
extern long double log10l (long double __x) ; extern long double __log10l (long double __x) ;
extern long double modfl (long double __x, long double *__iptr) ; extern long double __modfl (long double __x, long double *__iptr) ;
extern long double expm1l (long double __x) ; extern long double __expm1l (long double __x) ;
extern long double log1pl (long double __x) ; extern long double __log1pl (long double __x) ;
extern long double logbl (long double __x) ; extern long double __logbl (long double __x) ;
extern long double exp2l (long double __x) ; extern long double __exp2l (long double __x) ;
extern long double log2l (long double __x) ; extern long double __log2l (long double __x) ;
extern long double powl (long double __x, long double __y) ; extern long double __powl (long double __x, long double __y) ;
extern long double sqrtl (long double __x) ; extern long double __sqrtl (long double __x) ;
extern long double hypotl (long double __x, long double __y) ; extern long double __hypotl (long double __x, long double __y) ;
extern long double cbrtl (long double __x) ; extern long double __cbrtl (long double __x) ;
extern long double ceill (long double __x) ; extern long double __ceill (long double __x) ;
extern long double fabsl (long double __x) ; extern long double __fabsl (long double __x) ;
extern long double floorl (long double __x) ; extern long double __floorl (long double __x) ;
extern long double fmodl (long double __x, long double __y) ; extern long double __fmodl (long double __x, long double __y) ;
extern int __isinfl (long double __value) ;
extern int __finitel (long double __value) ;
extern int isinfl (long double __value) ;
extern int finitel (long double __value) ;
extern long double dreml (long double __x, long double __y) ; extern long double __dreml (long double __x, long double __y) ;
extern long double significandl (long double __x) ; extern long double __significandl (long double __x) ;
extern long double copysignl (long double __x, long double __y) ; extern long double __copysignl (long double __x, long double __y) ;
extern long double nanl (const char *__tagb) ; extern long double __nanl (const char *__tagb) ;
extern int __isnanl (long double __value) ;
extern int isnanl (long double __value) ;
extern long double j0l (long double) ; extern long double __j0l (long double) ;
extern long double j1l (long double) ; extern long double __j1l (long double) ;
extern long double jnl (int, long double) ; extern long double __jnl (int, long double) ;
extern long double y0l (long double) ; extern long double __y0l (long double) ;
extern long double y1l (long double) ; extern long double __y1l (long double) ;
extern long double ynl (int, long double) ; extern long double __ynl (int, long double) ;
extern long double erfl (long double) ; extern long double __erfl (long double) ;
extern long double erfcl (long double) ; extern long double __erfcl (long double) ;
extern long double lgammal (long double) ; extern long double __lgammal (long double) ;
extern long double tgammal (long double) ; extern long double __tgammal (long double) ;
extern long double gammal (long double) ; extern long double __gammal (long double) ;
extern long double lgammal_r (long double, int *__signgamp) ; extern long double __lgammal_r (long double, int *__signgamp) ;
extern long double rintl (long double __x) ; extern long double __rintl (long double __x) ;
extern long double nextafterl (long double __x, long double __y) ; extern long double __nextafterl (long double __x, long double __y) ;
extern long double nexttowardl (long double __x, long double __y) ; extern long double __nexttowardl (long double __x, long double __y) ;
extern long double remainderl (long double __x, long double __y) ; extern long double __remainderl (long double __x, long double __y) ;
extern long double scalbnl (long double __x, int __n) ; extern long double __scalbnl (long double __x, int __n) ;
extern int ilogbl (long double __x) ; extern int __ilogbl (long double __x) ;
extern long double scalblnl (long double __x, long int __n) ; extern long double __scalblnl (long double __x, long int __n) ;
extern long double nearbyintl (long double __x) ; extern long double __nearbyintl (long double __x) ;
extern long double roundl (long double __x) ; extern long double __roundl (long double __x) ;
extern long double truncl (long double __x) ; extern long double __truncl (long double __x) ;
extern long double remquol (long double __x, long double __y, int *__quo) ; extern long double __remquol (long double __x, long double __y, int *__quo) ;
extern long int lrintl (long double __x) ; extern long int __lrintl (long double __x) ;
extern long long int llrintl (long double __x) ; extern long long int __llrintl (long double __x) ;
extern long int lroundl (long double __x) ; extern long int __lroundl (long double __x) ;
extern long long int llroundl (long double __x) ; extern long long int __llroundl (long double __x) ;
extern long double fdiml (long double __x, long double __y) ; extern long double __fdiml (long double __x, long double __y) ;
extern long double fmaxl (long double __x, long double __y) ; extern long double __fmaxl (long double __x, long double __y) ;
extern long double fminl (long double __x, long double __y) ; extern long double __fminl (long double __x, long double __y) ;
extern int __fpclassifyl (long double __value)
extern int __signbitl (long double __value)
extern long double fmal (long double __x, long double __y, long double __z) ; extern long double __fmal (long double __x, long double __y, long double __z) ;
extern long double scalbl (long double __x, long double __n) ; extern long double __scalbl (long double __x, long double __n) ;
#line 142 "/usr/include/math.h"
extern int signgam;
enum
FP_NAN,
FP_INFINITE,
FP_ZERO,
FP_SUBNORMAL,
FP_NORMAL
#line 223 "/usr/include/math.h"
#line 235 "/usr/include/math.h"
#line 247 "/usr/include/math.h"
#line 263 "/usr/include/math.h"
#line 275 "/usr/include/math.h"
typedef enum
_IEEE_ = -1,
_SVID_,
_XOPEN_,
_POSIX_,
_ISOC_
} _LIB_VERSION_TYPE;
extern _LIB_VERSION_TYPE _LIB_VERSION;
struct exception
int type;
char *name;
double arg1;
double arg2;
double retval;
extern int matherr (struct exception *__exc);
#line 334 "/usr/include/math.h"
#line 346 "/usr/include/math.h"
#line 364 "/usr/include/math.h"
#line 383 "/usr/include/math.h"
#line 406 "/usr/include/math.h"
#line 422 "/usr/include/math.h"
#line 430 "/usr/include/math.h"
#line 438 "/usr/include/math.h"
#line 446 "/usr/include/math.h"
#line 454 "/usr/include/math.h"
#line 462 "/usr/include/math.h"
#line 3 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/math.h"
Defined "HAVE_MATH_H" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
return 0;
Found math #defines, like M_PI
TEST check from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
stdout:
#line 1 "/usr/include/sys/socket.h"
#line 25 "/usr/include/sys/socket.h"
#line 1 "/usr/include/sys/uio.h"
#line 23 "/usr/include/sys/uio.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 25 "/usr/include/sys/uio.h"
#line 1 "/usr/include/bits/uio.h"
struct iovec
void *iov_base;
size_t iov_len;
#line 30 "/usr/include/sys/uio.h"
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count);
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count);
#line 29 "/usr/include/sys/socket.h"
#line 31 "/usr/include/sys/socket.h"
#line 1 "/usr/include/bits/socket.h"
#line 31 "/usr/include/bits/socket.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 7 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 1 "/usr/include/bits/posix1_lim.h"
#line 1 "/usr/include/bits/local_lim.h"
#line 34 "/usr/include/bits/local_lim.h"
#line 1 "/usr/include/linux/limits.h"
#line 17 "/usr/include/linux/limits.h"
#line 37 "/usr/include/bits/local_lim.h"
#line 154 "/usr/include/bits/posix1_lim.h"
#line 62 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 1 "/usr/include/bits/posix2_lim.h"
#line 87 "/usr/include/bits/posix2_lim.h"
#line 66 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 33 "/usr/include/bits/socket.h"
typedef __socklen_t socklen_t;
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_PACKET = 10
#line 96 "/usr/include/bits/socket.h"
#line 130 "/usr/include/bits/socket.h"
#line 142 "/usr/include/bits/socket.h"
#line 1 "/usr/include/bits/sockaddr.h"
typedef unsigned short int sa_family_t;
#line 148 "/usr/include/bits/socket.h"
struct sockaddr
sa_family_t sa_family;
char sa_data[14];
#line 166 "/usr/include/bits/socket.h"
struct sockaddr_storage
sa_family_t ss_family;
__uint64_t __ss_align;
char __ss_padding[(128 - (2 * sizeof (__uint64_t)))];
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_DONTROUTE = 0x04,
#line 189 "/usr/include/bits/socket.h"
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_DONTWAIT = 0x40,
MSG_EOR = 0x80,
MSG_WAITALL = 0x100,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_CONFIRM = 0x800,
MSG_RST = 0x1000,
MSG_ERRQUEUE = 0x2000,
MSG_NOSIGNAL = 0x4000,
MSG_MORE = 0x8000,
MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
void *msg_name;
socklen_t msg_namelen;
struct iovec *msg_iov;
size_t msg_iovlen;
void *msg_control;
size_t msg_controllen;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
unsigned char __cmsg_data [];
#line 272 "/usr/include/bits/socket.h"
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
struct cmsghdr *__cmsg) ;
#line 297 "/usr/include/bits/socket.h"
enum
SCM_RIGHTS = 0x01
, SCM_CREDENTIALS = 0x02
struct ucred
pid_t pid;
uid_t uid;
gid_t gid;
#line 1 "/usr/include/asm/socket.h"
#line 1 "/usr/include/asm-s64fx/socket.h"
#line 1 "/usr/include/asm/sockios.h"
#line 1 "/usr/include/asm-s64fx/sockios.h"
#line 12 "/usr/include/asm-s64fx/sockios.h"
#line 6 "/usr/include/asm/sockios.h"
#line 6 "/usr/include/asm-s64fx/socket.h"
#line 19 "/usr/include/asm-s64fx/socket.h"
#line 26 "/usr/include/asm-s64fx/socket.h"
#line 36 "/usr/include/asm-s64fx/socket.h"
#line 6 "/usr/include/asm/socket.h"
#line 321 "/usr/include/bits/socket.h"
struct linger
int l_onoff;
int l_linger;
#line 37 "/usr/include/sys/socket.h"
struct osockaddr
unsigned short int sa_family;
unsigned char sa_data[14];
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
#line 96 "/usr/include/sys/socket.h"
extern int socket (int __domain, int __type, int __protocol) ;
extern int socketpair (int __domain, int __type, int __protocol,
int __fds[2]) ;
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr * __addr,
socklen_t * __len) ;
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr * __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
int __flags, const struct sockaddr * __addr,
socklen_t __addr_len);
extern ssize_t recvfrom (int __fd, void * __buf, size_t __n,
int __flags, struct sockaddr * __addr,
socklen_t * __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
int __flags);
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
extern int getsockopt (int __fd, int __level, int __optname,
void * __optval,
socklen_t * __optlen) ;
extern int setsockopt (int __fd, int __level, int __optname,
const void *__optval, socklen_t __optlen) ;
extern int listen (int __fd, int __n) ;
extern int accept (int __fd, struct sockaddr * __addr,
extern int shutdown (int __fd, int __how) ;
extern int sockatmark (int __fd) ;
extern int isfdtype (int __fd, int __fdtype) ;
Defined "HAVE_SYS_SOCKET_H" to "1"
Checking for header: sys/types.h
stdout:
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
#line 1 "/usr/include/malloc.h"
#line 25 "/usr/include/malloc.h"
typedef long ptrdiff_t;
#line 26 "/usr/include/malloc.h"
#line 40 "/usr/include/malloc.h"
extern void free (void *__ptr);
extern void cfree (void *__ptr);
extern void *memalign (size_t __alignment, size_t __size)
extern void * pvalloc (size_t __size)
extern void *(*__morecore) (ptrdiff_t __size);
extern void *__default_morecore (ptrdiff_t __size)
struct mallinfo {
int arena;
int ordblks;
int smblks;
int hblks;
int hblkhd;
int usmblks;
int fsmblks;
int uordblks;
int fordblks;
int keepcost;
extern struct mallinfo mallinfo (void);
#line 122 "/usr/include/malloc.h"
#line 130 "/usr/include/malloc.h"
extern int mallopt (int __param, int __val);
extern int malloc_trim (size_t __pad);
extern size_t malloc_usable_size (void *__ptr);
extern void malloc_stats (void);
extern void *malloc_get_state (void);
extern int malloc_set_state (void *__ptr);
extern void (*__malloc_initialize_hook) (void);
extern void (*__free_hook) (void *__ptr, const void *);
extern void *(*__malloc_hook) (size_t __size, const void *);
extern void *(*__realloc_hook) (void *__ptr, size_t __size, const void *);
extern void *(*__memalign_hook) (size_t __alignment, size_t __size, const void *);
extern void (*__after_morecore_hook) (void);
extern void __malloc_check_init (void);
Defined "HAVE_MALLOC_H" to "1"
stdout:
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
struct itimerspec
struct sigevent;
struct tm * __tp) ;
struct tm * __tp) ;
char * __buf) ;
char * __buf) ;
Checking for header: Direct.h
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Direct.h"
#include <Direct.h>
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".
Source:
#include <Direct.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Direct.h"
#include <Direct.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Direct.h" #include <Direct.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: Ws2tcpip.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Ws2tcpip.h"
#include <Ws2tcpip.h>
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Ws2tcpip.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "Ws2tcpip.h" #include <Ws2tcpip.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: endian.h
stdout:
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
Defined "HAVE_ENDIAN_H" to "1"
Checking for header: ieeefp.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "ieeefp.h"
#include <ieeefp.h>
Source:
#include <ieeefp.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "ieeefp.h"
#include <ieeefp.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "ieeefp.h" #include <ieeefp.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: strings.h
stdout:
#line 1 "/usr/include/strings.h"
#line 28 "/usr/include/strings.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 30 "/usr/include/strings.h"
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern void bcopy (const void *__src, void *__dest, size_t __n) ;
extern void bzero (void *__s, size_t __n) ;
extern int ffs (int __i) ;
extern char *index (const char *__s, int __c) ;
extern char *rindex (const char *__s, int __c) ;
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Defined "HAVE_STRINGS_H" to "1"
Checking for header: sched.h
stdout:
#line 1 "/usr/include/sched.h"
#line 24 "/usr/include/sched.h"
#line 27 "/usr/include/sched.h"
#line 30 "/usr/include/sched.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 33 "/usr/include/sched.h"
#line 1 "/usr/include/bits/sched.h"
#line 36 "/usr/include/bits/sched.h"
#line 64 "/usr/include/bits/sched.h"
struct sched_param
int __sched_priority;
extern int clone (int (*__fn) (void *__arg), void *__child_stack,
int __flags, void *__arg, ...) ;
extern int unshare (int __flags) ;
extern int sched_getcpu (void) ;
struct __sched_param
typedef unsigned long int __cpu_mask;
typedef struct
__cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
#line 146 "/usr/include/bits/sched.h"
#line 164 "/usr/include/bits/sched.h"
#line 174 "/usr/include/bits/sched.h"
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) ;
extern void __sched_cpufree (cpu_set_t *__set) ;
#line 36 "/usr/include/sched.h"
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) ;
extern int sched_setscheduler (__pid_t __pid, int __policy,
const struct sched_param *__param) ;
extern int sched_getscheduler (__pid_t __pid) ;
extern int sched_yield (void) ;
extern int sched_get_priority_max (int __algorithm) ;
extern int sched_get_priority_min (int __algorithm) ;
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) ;
#line 117 "/usr/include/sched.h"
Defined "HAVE_SCHED_H" to "1"
Checking for header: cxxabi.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "cxxabi.h"
#include <cxxabi.h>
Source:
#include <cxxabi.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "cxxabi.h"
#include <cxxabi.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "cxxabi.h" #include <cxxabi.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: sys/systeminfo.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h"
#include <sys/systeminfo.h>
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h" #include <sys/systeminfo.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: dos.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "dos.h"
#include <dos.h>
Source:
#include <dos.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "dos.h"
#include <dos.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "dos.h" #include <dos.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: WindowsX.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "WindowsX.h"
#include <WindowsX.h>
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "WindowsX.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "WindowsX.h" #include <WindowsX.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: sys/sysinfo.h
stdout:
#line 1 "/usr/include/sys/sysinfo.h"
#line 23 "/usr/include/sys/sysinfo.h"
#line 1 "/usr/include/linux/kernel.h"
struct sysinfo {
long uptime;
unsigned long loads[3];
unsigned long totalram;
unsigned long freeram;
unsigned long sharedram;
unsigned long bufferram;
unsigned long totalswap;
unsigned long freeswap;
unsigned short procs;
unsigned short pad;
unsigned long totalhigh;
unsigned long freehigh;
unsigned int mem_unit;
char _f[20-2*sizeof(long)-sizeof(int)];
#line 26 "/usr/include/sys/sysinfo.h"
extern int sysinfo (struct sysinfo *__info) ;
extern int get_nprocs_conf (void) ;
extern int get_nprocs (void) ;
extern long int get_phys_pages (void) ;
extern long int get_avphys_pages (void) ;
Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/wait.h
stdout:
#line 1 "/usr/include/sys/wait.h"
#line 28 "/usr/include/sys/wait.h"
#line 1 "/usr/include/signal.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 30 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 100 "/usr/include/bits/sigset.h"
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
#line 124 "/usr/include/bits/sigset.h"
#line 34 "/usr/include/signal.h"
typedef __sig_atomic_t sig_atomic_t;
typedef __sigset_t sigset_t;
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 58 "/usr/include/signal.h"
#line 1 "/usr/include/bits/signum.h"
#line 52 "/usr/include/bits/signum.h"
#line 72 "/usr/include/bits/signum.h"
#line 59 "/usr/include/signal.h"
typedef __pid_t pid_t;
typedef __uid_t uid_t;
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
#line 104 "/usr/include/signal.h"
#line 112 "/usr/include/signal.h"
extern int kill (__pid_t __pid, int __sig) ;
extern int killpg (__pid_t __pgrp, int __sig) ;
extern int raise (int __sig) ;
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) ;
extern void psignal (int __sig, const char *__s);
extern int __sigpause (int __sig_or_mask, int __is_sig);
#line 169 "/usr/include/signal.h"
extern int sigblock (int __mask) ;
extern int sigsetmask (int __mask) ;
extern int siggetmask (void) ;
typedef __sighandler_t sig_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 419 "/usr/include/time.h"
#line 210 "/usr/include/signal.h"
#line 1 "/usr/include/bits/siginfo.h"
#line 26 "/usr/include/bits/siginfo.h"
typedef union sigval
int sival_int;
void *sival_ptr;
} sigval_t;
#line 50 "/usr/include/bits/siginfo.h"
typedef struct siginfo
int si_signo;
int si_errno;
int si_code;
union
int _pad[((128 / sizeof (int)) - 4)];
struct
__pid_t si_pid;
__uid_t si_uid;
} _kill;
struct
int si_tid;
int si_overrun;
sigval_t si_sigval;
} _timer;
struct
__pid_t si_pid;
__uid_t si_uid;
sigval_t si_sigval;
} _rt;
struct
__pid_t si_pid;
__uid_t si_uid;
int si_status;
__clock_t si_utime;
__clock_t si_stime;
} _sigchld;
struct
void *si_addr;
int si_trapno;
} _sigfault;
struct
int si_band;
int si_fd;
} _sigpoll;
} _sifields;
} siginfo_t;
#line 127 "/usr/include/bits/siginfo.h"
enum
SI_ASYNCNL = -60,
SI_TKILL = -6,
SI_SIGIO,
SI_ASYNCIO,
SI_MESGQ,
SI_TIMER,
SI_QUEUE,
SI_USER,
SI_KERNEL = 0x80
enum
ILL_ILLOPC = 1,
ILL_ILLOPN,
ILL_ILLADR,
ILL_ILLTRP,
ILL_PRVOPC,
ILL_PRVREG,
ILL_COPROC,
ILL_BADSTK
enum
FPE_INTDIV = 1,
FPE_INTOVF,
FPE_FLTDIV,
FPE_FLTOVF,
FPE_FLTUND,
FPE_FLTRES,
FPE_FLTINV,
FPE_FLTSUB
enum
SEGV_MAPERR = 1,
SEGV_ACCERR
enum
BUS_ADRALN = 1,
BUS_ADRERR,
BUS_OBJERR
enum
TRAP_BRKPT = 1,
TRAP_TRACE
enum
CLD_EXITED = 1,
CLD_KILLED,
CLD_DUMPED,
CLD_TRAPPED,
CLD_STOPPED,
CLD_CONTINUED
enum
POLL_IN = 1,
POLL_OUT,
POLL_MSG,
POLL_ERR,
POLL_PRI,
POLL_HUP
enum
EMT_TAGOVF = 1
#line 281 "/usr/include/bits/siginfo.h"
typedef struct sigevent
sigval_t sigev_value;
int sigev_signo;
int sigev_notify;
union
int _pad[((64 / sizeof (int)) - 4)];
struct
void (*_function) (sigval_t);
void *_attribute;
} _sigev_thread;
} _sigev_un;
} sigevent_t;
enum
SIGEV_SIGNAL = 0,
SIGEV_NONE,
SIGEV_THREAD,
SIGEV_THREAD_ID = 4
#line 213 "/usr/include/signal.h"
extern int sigemptyset (sigset_t *__set) ;
extern int sigfillset (sigset_t *__set) ;
extern int sigaddset (sigset_t *__set, int __signo) ;
extern int sigdelset (sigset_t *__set, int __signo) ;
extern int sigismember (const sigset_t *__set, int __signo)
#line 243 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigaction.h"
struct sigaction
union
__sighandler_t sa_handler;
void (*sa_sigaction) (int, siginfo_t *, void *);
__sigaction_handler;
__sigset_t sa_mask;
unsigned long sa_flags;
void (*sa_restorer) (void);
#line 66 "/usr/include/bits/sigaction.h"
#line 247 "/usr/include/signal.h"
extern int sigprocmask (int __how, const sigset_t * __set,
sigset_t * __oset) ;
extern int sigsuspend (const sigset_t *__set) ;
extern int sigaction (int __sig, const struct sigaction * __act,
struct sigaction * __oact) ;
extern int sigpending (sigset_t *__set) ;
extern int sigwait (const sigset_t * __set, int * __sig)
extern int sigwaitinfo (const sigset_t * __set,
siginfo_t * __info) ;
extern int sigtimedwait (const sigset_t * __set,
siginfo_t * __info,
const struct timespec * __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
__sighandler_t sv_handler;
int sv_mask;
int sv_flags;
extern int sigvec (int __sig, const struct sigvec *__vec,
struct sigvec *__ovec) ;
#line 1 "/usr/include/bits/sigcontext.h"
#line 24 "/usr/include/bits/sigcontext.h"
#line 1 "/usr/include/stdint.h"
#line 27 "/usr/include/stdint.h"
#line 1 "/usr/include/bits/wchar.h"
#line 28 "/usr/include/stdint.h"
#line 29 "/usr/include/stdint.h"
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
#line 102 "/usr/include/stdint.h"
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
#line 115 "/usr/include/stdint.h"
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
#line 131 "/usr/include/stdint.h"
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
#line 143 "/usr/include/stdint.h"
#line 156 "/usr/include/stdint.h"
#line 205 "/usr/include/stdint.h"
#line 215 "/usr/include/stdint.h"
#line 226 "/usr/include/stdint.h"
#line 238 "/usr/include/stdint.h"
#line 259 "/usr/include/stdint.h"
#line 298 "/usr/include/stdint.h"
#line 308 "/usr/include/stdint.h"
#line 317 "/usr/include/stdint.h"
#line 25 "/usr/include/bits/sigcontext.h"
#line 48 "/usr/include/bits/sigcontext.h"
typedef struct
unsigned int si_float_regs [64];
unsigned long si_fsr;
unsigned long si_gsr;
unsigned long si_fprs;
uint64_t si_xglob_regs[32];
uint32_t si_xfloat_regs[448];
uint64_t si_xasr;
} __siginfo_fpu_t;
struct sigcontext
char sigc_info[128];
struct
unsigned long u_regs[16];
unsigned long tstate;
unsigned long tpc;
unsigned long tnpc;
unsigned int y;
unsigned int fprs;
} sigc_regs;
__siginfo_fpu_t * sigc_fpu_save;
uint64_t si_txar;
uint64_t si_sccr;
struct
void * ss_sp;
int ss_flags;
unsigned long ss_size;
} sigc_stack;
unsigned long sigc_mask;
#line 334 "/usr/include/signal.h"
extern int sigreturn (struct sigcontext *__scp) ;
#line 344 "/usr/include/signal.h"
extern int siginterrupt (int __sig, int __interrupt) ;
#line 1 "/usr/include/bits/sigstack.h"
struct sigstack
void *ss_sp;
int ss_onstack;
enum
SS_ONSTACK = 1,
SS_DISABLE
typedef struct sigaltstack
void *ss_sp;
int ss_flags;
size_t ss_size;
} stack_t;
#line 351 "/usr/include/signal.h"
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack * __ss,
struct sigaltstack * __oss) ;
#line 384 "/usr/include/signal.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 389 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigthread.h"
extern int pthread_sigmask (int __how,
const __sigset_t * __newmask,
__sigset_t * __oldmask);
extern int pthread_kill (pthread_t __threadid, int __signo) ;
#line 390 "/usr/include/signal.h"
extern int __libc_current_sigrtmin (void) ;
extern int __libc_current_sigrtmax (void) ;
#line 32 "/usr/include/sys/wait.h"
#line 1 "/usr/include/sys/resource.h"
#line 23 "/usr/include/sys/resource.h"
#line 1 "/usr/include/bits/resource.h"
enum __rlimit_resource
RLIMIT_CPU = 0,
RLIMIT_FSIZE = 1,
RLIMIT_DATA = 2,
RLIMIT_STACK = 3,
RLIMIT_CORE = 4,
__RLIMIT_RSS = 5,
RLIMIT_NOFILE = 6,
__RLIMIT_OFILE = RLIMIT_NOFILE,
RLIMIT_AS = 9,
__RLIMIT_NPROC = 7,
__RLIMIT_MEMLOCK = 8,
__RLIMIT_LOCKS = 10,
__RLIMIT_SIGPENDING = 11,
__RLIMIT_MSGQUEUE = 12,
__RLIMIT_NICE = 13,
__RLIMIT_RTPRIO = 14,
__RLIMIT_NLIMITS = 15,
__RLIM_NLIMITS = __RLIMIT_NLIMITS
#line 135 "/usr/include/bits/resource.h"
typedef __rlim_t rlim_t;
#line 150 "/usr/include/bits/resource.h"
struct rlimit
rlim_t rlim_cur;
rlim_t rlim_max;
#line 168 "/usr/include/bits/resource.h"
enum __rusage_who
RUSAGE_SELF = 0,
RUSAGE_CHILDREN = -1
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 183 "/usr/include/bits/resource.h"
struct rusage
struct timeval ru_utime;
struct timeval ru_stime;
long int ru_maxrss;
long int ru_ixrss;
long int ru_idrss;
long int ru_isrss;
long int ru_minflt;
long int ru_majflt;
long int ru_nswap;
long int ru_inblock;
long int ru_oublock;
long int ru_msgsnd;
long int ru_msgrcv;
long int ru_nsignals;
long int ru_nvcsw;
long int ru_nivcsw;
enum __priority_which
PRIO_PROCESS = 0,
PRIO_PGRP = 1,
PRIO_USER = 2
#line 26 "/usr/include/sys/resource.h"
typedef __id_t id_t;
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
struct rlimit *__rlimits) ;
#line 65 "/usr/include/sys/resource.h"
extern int setrlimit (__rlimit_resource_t __resource,
const struct rlimit *__rlimits) ;
#line 85 "/usr/include/sys/resource.h"
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) ;
extern int getpriority (__priority_which_t __which, id_t __who) ;
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
#line 33 "/usr/include/sys/wait.h"
#line 1 "/usr/include/bits/waitflags.h"
#line 39 "/usr/include/sys/wait.h"
#line 52 "/usr/include/sys/wait.h"
#line 70 "/usr/include/sys/wait.h"
#line 78 "/usr/include/sys/wait.h"
#line 1 "/usr/include/bits/waitstatus.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 66 "/usr/include/bits/waitstatus.h"
union wait
int w_status;
struct
#line 79 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_retcode:8;
unsigned int __w_coredump:1;
unsigned int __w_termsig:7;
} __wait_terminated;
struct
#line 93 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_stopsig:8;
unsigned int __w_stopval:8;
} __wait_stopped;
#line 81 "/usr/include/sys/wait.h"
#line 92 "/usr/include/sys/wait.h"
#line 99 "/usr/include/sys/wait.h"
typedef enum
P_ALL,
P_PID,
P_PGID
} idtype_t;
extern __pid_t wait (void * __stat_loc);
extern __pid_t waitpid (__pid_t __pid, int *__stat_loc, int __options);
#line 39 "/usr/include/bits/siginfo.h"
#line 268 "/usr/include/bits/siginfo.h"
#line 144 "/usr/include/sys/wait.h"
extern int waitid (idtype_t __idtype, __id_t __id, siginfo_t *__infop,
int __options);
struct rusage;
extern __pid_t wait3 (void * __stat_loc, int __options,
struct rusage * __usage) ;
extern __pid_t wait4 (__pid_t __pid, void * __stat_loc, int __options,
Defined "HAVE_SYS_WAIT_H" to "1"
Checking for header: stdlib.h
stdout:
#line 1 "/usr/include/stdlib.h"
#line 26 "/usr/include/stdlib.h"
typedef int wchar_t;
#line 34 "/usr/include/stdlib.h"
#line 95 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) ;
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
extern long long int atoll (const char *__nptr)
extern double strtod (const char * __nptr,
char ** __endptr)
extern float strtof (const char * __nptr,
char ** __endptr) ;
extern long double strtold (const char * __nptr,
char ** __endptr)
extern long int strtol (const char * __nptr,
char ** __endptr, int __base)
extern unsigned long int strtoul (const char * __nptr,
extern long long int strtoq (const char * __nptr,
extern unsigned long long int strtouq (const char * __nptr,
extern long long int strtoll (const char * __nptr,
extern unsigned long long int strtoull (const char * __nptr,
#line 274 "/usr/include/stdlib.h"
#line 305 "/usr/include/stdlib.h"
extern char *l64a (long int __n) ;
extern long int a64l (const char *__s)
#line 1 "/usr/include/sys/types.h"
#line 28 "/usr/include/sys/types.h"
#line 32 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef char int8_t;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
typedef struct
} __sigset_t;
#line 35 "/usr/include/sys/select.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 45 "/usr/include/sys/select.h"
struct timeval
__time_t tv_sec;
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 221 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 271 "/usr/include/sys/types.h"
#line 321 "/usr/include/stdlib.h"
extern long int random (void) ;
extern void srandom (unsigned int __seed) ;
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) ;
extern char *setstate (char *__statebuf) ;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data * __buf,
int32_t * __result) ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char * __statebuf,
size_t __statelen,
struct random_data * __buf)
extern int setstate_r (char * __statebuf,
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
extern int rand_r (unsigned int *__seed) ;
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3]) ;
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) ;
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
unsigned long long int __a;
extern int drand48_r (struct drand48_data * __buffer,
double * __result) ;
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data * __buffer,
long int * __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data * __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) ;
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
extern void free (void *__ptr) ;
extern void cfree (void *__ptr) ;
#line 1 "/usr/include/alloca.h"
#line 23 "/usr/include/alloca.h"
#line 26 "/usr/include/alloca.h"
extern void *alloca (size_t __size) ;
#line 498 "/usr/include/stdlib.h"
extern void *valloc (size_t __size) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) ;
extern int atexit (void (*__func) (void)) ;
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) ;
extern void _Exit (int __status) ;
extern char *getenv (const char *__name) ;
extern char *__secure_getenv (const char *__name)
extern int putenv (char *__string) ;
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) ;
extern int clearenv (void) ;
extern char *mktemp (char *__template) ;
extern int mkstemp (char *__template) ;
#line 607 "/usr/include/stdlib.h"
extern char *mkdtemp (char *__template) ;
#line 638 "/usr/include/stdlib.h"
extern int system (const char *__command) ;
#line 655 "/usr/include/stdlib.h"
extern char *realpath (const char * __name,
char * __resolved) ;
typedef int (*__compar_fn_t) (const void *, const void *);
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) ;
extern int abs (int __x) ;
extern long int labs (long int __x) ;
extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
extern lldiv_t lldiv (long long int __numer,
long long int __denom)
extern char *ecvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *fcvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *gcvt (double __value, int __ndigit, char *__buf)
extern char *qecvt (long double __value, int __ndigit,
int * __decpt, int * __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int * __decpt,
int * __sign, char * __buf,
size_t __len) ;
extern int fcvt_r (double __value, int __ndigit, int * __decpt,
size_t __len) ;
extern int qecvt_r (long double __value, int __ndigit,
int * __decpt, int * __sign,
char * __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) ;
extern int mbtowc (wchar_t * __pwc,
const char * __s, size_t __n) ;
extern int wctomb (char *__s, wchar_t __wchar) ;
extern size_t mbstowcs (wchar_t * __pwcs,
extern size_t wcstombs (char * __s,
const wchar_t * __pwcs, size_t __n)
extern int rpmatch (const char *__response) ;
#line 820 "/usr/include/stdlib.h"
extern int posix_openpt (int __oflag) ;
#line 851 "/usr/include/stdlib.h"
#line 862 "/usr/include/stdlib.h"
extern int getloadavg (double __loadavg[], int __nelem)
#line 879 "/usr/include/stdlib.h"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
#line 1 "/usr/include/pthread.h"
#line 24 "/usr/include/pthread.h"
#line 25 "/usr/include/pthread.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct sched_param
typedef struct
} cpu_set_t;
#line 26 "/usr/include/pthread.h"
#line 30 "/usr/include/time.h"
#line 40 "/usr/include/time.h"
#line 43 "/usr/include/bits/time.h"
#line 44 "/usr/include/time.h"
typedef __clock_t clock_t;
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
struct sigevent;
extern clock_t clock (void) ;
extern time_t time (time_t *__timer) ;
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) ;
extern size_t strftime (char * __s, size_t __maxsize,
const char * __format,
const struct tm * __tp) ;
#line 212 "/usr/include/time.h"
#line 227 "/usr/include/time.h"
extern struct tm *gmtime (const time_t *__timer) ;
extern struct tm *localtime (const time_t *__timer) ;
extern struct tm *gmtime_r (const time_t * __timer,
struct tm * __tp) ;
extern struct tm *localtime_r (const time_t * __timer,
struct tm * __tp) ;
extern char *asctime (const struct tm *__tp) ;
extern char *ctime (const time_t *__timer) ;
extern char *asctime_r (const struct tm * __tp,
char * __buf) ;
extern char *ctime_r (const time_t * __timer,
char * __buf) ;
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) ;
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) ;
extern time_t timegm (struct tm *__tp) ;
extern time_t timelocal (struct tm *__tp) ;
extern int dysize (int __year) ;
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
extern int timer_create (clockid_t __clock_id,
struct sigevent * __evp,
timer_t * __timerid) ;
extern int timer_delete (timer_t __timerid) ;
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec * __value,
struct itimerspec * __ovalue) ;
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) ;
#line 400 "/usr/include/time.h"
#line 415 "/usr/include/time.h"
#line 27 "/usr/include/pthread.h"
typedef struct
} __sigset_t;
#line 46 "/usr/include/signal.h"
#line 401 "/usr/include/signal.h"
#line 30 "/usr/include/pthread.h"
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 31 "/usr/include/pthread.h"
#line 1 "/usr/include/bits/setjmp.h"
#line 28 "/usr/include/bits/setjmp.h"
typedef struct __sparc64_jmp_buf
struct __sparc64_jmp_buf *uc_link;
unsigned long uc_flags;
unsigned long uc_sigmask;
struct __sparc64_jmp_buf_mcontext
unsigned long mc_gregs[53];
unsigned long mc_fp;
unsigned long mc_i7;
struct __sparc64_jmp_buf_fpu
union
unsigned int sregs[512];
unsigned long dregs[256];
long double qregs[128];
} mcfpu_fpregs;
unsigned long mcfpu_fsr;
unsigned long mcfpu_fprs;
unsigned long mcfpu_gsr;
unsigned long mcfpu_xasr;
void *mcfpu_fq;
unsigned char mcfpu_qcnt;
unsigned char mcfpu_qentsz;
unsigned char mcfpu_enab;
} mc_fpregs;
} uc_mcontext;
} __jmp_buf[1];
#line 70 "/usr/include/bits/setjmp.h"
#line 32 "/usr/include/pthread.h"
#line 33 "/usr/include/pthread.h"
enum
PTHREAD_CREATE_JOINABLE,
PTHREAD_CREATE_DETACHED
enum
PTHREAD_MUTEX_TIMED_NP,
PTHREAD_MUTEX_RECURSIVE_NP,
PTHREAD_MUTEX_ERRORCHECK_NP,
PTHREAD_MUTEX_ADAPTIVE_NP
#line 63 "/usr/include/pthread.h"
#line 74 "/usr/include/pthread.h"
#line 85 "/usr/include/pthread.h"
#line 111 "/usr/include/pthread.h"
enum
PTHREAD_RWLOCK_PREFER_READER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
#line 144 "/usr/include/pthread.h"
enum
PTHREAD_INHERIT_SCHED,
PTHREAD_EXPLICIT_SCHED
enum
PTHREAD_SCOPE_SYSTEM,
PTHREAD_SCOPE_PROCESS
enum
PTHREAD_PROCESS_PRIVATE,
PTHREAD_PROCESS_SHARED
struct _pthread_cleanup_buffer
void (*__routine) (void *);
void *__arg;
int __canceltype;
struct _pthread_cleanup_buffer *__prev;
enum
PTHREAD_CANCEL_ENABLE,
PTHREAD_CANCEL_DISABLE
enum
PTHREAD_CANCEL_DEFERRED,
PTHREAD_CANCEL_ASYNCHRONOUS
extern int pthread_create (pthread_t * __newthread,
const pthread_attr_t * __attr,
void *(*__start_routine) (void *),
void * __arg) ;
extern void pthread_exit (void *__retval) ;
extern int pthread_join (pthread_t __th, void **__thread_return);
#line 258 "/usr/include/pthread.h"
extern int pthread_detach (pthread_t __th) ;
extern pthread_t pthread_self (void) ;
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) ;
extern int pthread_attr_init (pthread_attr_t *__attr) ;
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *
__attr,
struct sched_param * __param)
extern int pthread_attr_setschedparam (pthread_attr_t * __attr,
__param) ;
extern int pthread_attr_getschedpolicy (const pthread_attr_t *
__attr, int * __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *
__attr, int * __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t * __attr,
int * __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *
__attr, void ** __stackaddr)
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
void *__stackaddr)
extern int pthread_attr_getstacksize (const pthread_attr_t *
__attr, size_t * __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t * __attr,
void ** __stackaddr,
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
size_t __stacksize) ;
#line 407 "/usr/include/pthread.h"
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
extern int pthread_getschedparam (pthread_t __target_thread,
int * __policy,
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
#line 435 "/usr/include/pthread.h"
#line 455 "/usr/include/pthread.h"
extern int pthread_once (pthread_once_t *__once_control,
void (*__init_routine) (void)) ;
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
struct
__jmp_buf __cancel_jmp_buf;
int __mask_was_saved;
} __cancel_jmp_buf[1];
void *__pad[4];
} __pthread_unwind_buf_t ;
struct __pthread_cleanup_frame
void (*__cancel_routine) (void *);
void *__cancel_arg;
int __do_it;
int __cancel_type;
#line 629 "/usr/include/pthread.h"
#line 652 "/usr/include/pthread.h"
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
#line 663 "/usr/include/pthread.h"
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
#line 701 "/usr/include/pthread.h"
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) ;
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t * __mutex,
__abstime) ;
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
#line 761 "/usr/include/pthread.h"
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
__attr,
int * __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
int __pshared)
#line 827 "/usr/include/pthread.h"
#line 839 "/usr/include/pthread.h"
extern int pthread_rwlock_init (pthread_rwlock_t * __rwlock,
const pthread_rwlockattr_t *
__attr) ;
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t * __rwlock,
__abstime) ;
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t * __rwlock,
__abstime) ;
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
__attr,
int * __pshared)
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
__attr,
int * __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
int __pref) ;
extern int pthread_cond_init (pthread_cond_t * __cond,
const pthread_condattr_t *
__cond_attr) ;
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t * __cond,
pthread_mutex_t * __mutex)
extern int pthread_cond_timedwait (pthread_cond_t * __cond,
__abstime) ;
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
__attr,
int * __pshared)
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
int __pshared) ;
extern int pthread_condattr_getclock (const pthread_condattr_t *
__attr,
__clockid_t * __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
__clockid_t __clock_id)
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t * __barrier,
const pthread_barrierattr_t *
__attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
__attr,
int * __pshared)
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
int __pshared)
extern int pthread_key_create (pthread_key_t *__key,
void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) ;
extern void *pthread_getspecific (pthread_key_t __key) ;
extern int pthread_setspecific (pthread_key_t __key,
const void *__pointer) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
__clockid_t *__clock_id)
extern int pthread_atfork (void (*__prepare) (void),
void (*__parent) (void),
void (*__child) (void)) ;
#line 1116 "/usr/include/pthread.h"
Defined "HAVE_PTHREAD_H" to "1"
Checking for header: setjmp.h
stdout:
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/setjmp.h"
#line 1 "/usr/include/setjmp.h"
#line 27 "/usr/include/setjmp.h"
union
} mcfpu_fpregs;
void *mcfpu_fq;
} mc_fpregs;
} uc_mcontext;
} __jmp_buf[1];
#line 31 "/usr/include/setjmp.h"
typedef struct
} __sigset_t;
#line 32 "/usr/include/setjmp.h"
__jmp_buf __jmpbuf;
__sigset_t __saved_mask;
typedef struct __jmp_buf_tag jmp_buf[1];
extern int setjmp (jmp_buf __env) ;
extern int __sigsetjmp (struct __jmp_buf_tag __env[1], int __savemask) ;
extern int _setjmp (struct __jmp_buf_tag __env[1]) ;
#line 76 "/usr/include/setjmp.h"
extern void longjmp (struct __jmp_buf_tag __env[1], int __val)
extern void _longjmp (struct __jmp_buf_tag __env[1], int __val)
typedef struct __jmp_buf_tag sigjmp_buf[1];
extern void siglongjmp (sigjmp_buf __env, int __val)
#line 3 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/setjmp.h"
#pragma unknown_control_flow(setjmp)
#pragma unknown_control_flow(sigsetjmp)
Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
#line 1 "/usr/include/sys/utsname.h"
#line 27 "/usr/include/sys/utsname.h"
#line 1 "/usr/include/bits/utsname.h"
#line 31 "/usr/include/sys/utsname.h"
#line 47 "/usr/include/sys/utsname.h"
struct utsname
char sysname[65];
char nodename[65];
char release[65];
char version[65];
char machine[65];
char __domainname[65];
extern int uname (struct utsname *__name) ;
Defined "HAVE_SYS_UTSNAME_H" to "1"
TEST check from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: machine/endian.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "machine/endian.h"
#include <machine/endian.h>
Source:
#include "confdefs.h"
#include "conffix.h"
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "machine/endian.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "machine/endian.h" #include <machine/endian.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: limits.h
stdout:
Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
#line 1 "/usr/include/fcntl.h"
#line 28 "/usr/include/fcntl.h"
#line 1 "/usr/include/bits/fcntl.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 26 "/usr/include/bits/fcntl.h"
#line 27 "/usr/include/bits/fcntl.h"
#line 46 "/usr/include/bits/fcntl.h"
#line 54 "/usr/include/bits/fcntl.h"
#line 62 "/usr/include/bits/fcntl.h"
#line 98 "/usr/include/bits/fcntl.h"
#line 111 "/usr/include/bits/fcntl.h"
#line 121 "/usr/include/bits/fcntl.h"
#line 142 "/usr/include/bits/fcntl.h"
#line 149 "/usr/include/bits/fcntl.h"
#line 160 "/usr/include/bits/fcntl.h"
struct flock
short int l_type;
short int l_whence;
__off_t l_start;
__off_t l_len;
__pid_t l_pid;
short int __unused;
#line 187 "/usr/include/bits/fcntl.h"
#line 197 "/usr/include/bits/fcntl.h"
#line 207 "/usr/include/bits/fcntl.h"
#line 229 "/usr/include/bits/fcntl.h"
#line 258 "/usr/include/bits/fcntl.h"
#line 35 "/usr/include/fcntl.h"
#line 51 "/usr/include/fcntl.h"
#line 70 "/usr/include/fcntl.h"
extern int fcntl (int __fd, int __cmd, ...);
extern int open (const char *__file, int __oflag, ...) ;
#line 97 "/usr/include/fcntl.h"
#line 123 "/usr/include/fcntl.h"
extern int creat (const char *__file, __mode_t __mode) ;
#line 142 "/usr/include/fcntl.h"
extern int lockf (int __fd, int __cmd, __off_t __len);
#line 171 "/usr/include/fcntl.h"
extern int posix_fadvise (int __fd, __off_t __offset, __off_t __len,
int __advise) ;
#line 191 "/usr/include/fcntl.h"
extern int posix_fallocate (int __fd, __off_t __offset, __off_t __len);
#line 212 "/usr/include/fcntl.h"
Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
#line 1 "/usr/include/string.h"
#line 27 "/usr/include/string.h"
#line 34 "/usr/include/string.h"
extern void *memcpy (void * __dest,
const void * __src, size_t __n)
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void * __dest, const void * __src,
int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) ;
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
extern void *memchr (const void *__s, int __c, size_t __n)
#line 80 "/usr/include/string.h"
extern char *strcpy (char * __dest, const char * __src)
extern char *strncpy (char * __dest,
const char * __src, size_t __n)
extern char *strcat (char * __dest, const char * __src)
extern char *strncat (char * __dest, const char * __src,
size_t __n) ;
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char * __dest,
#line 127 "/usr/include/string.h"
extern char *strdup (const char *__s)
#line 164 "/usr/include/string.h"
extern char *strchr (const char *__s, int __c)
extern char *strrchr (const char *__s, int __c)
#line 180 "/usr/include/string.h"
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
extern char *strpbrk (const char *__s, const char *__accept)
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char * __s, const char * __delim)
extern char *__strtok_r (char * __s,
const char * __delim,
char ** __save_ptr)
extern char *strtok_r (char * __s, const char * __delim,
char ** __save_ptr)
#line 238 "/usr/include/string.h"
extern size_t strlen (const char *__s)
#line 252 "/usr/include/string.h"
extern char *strerror (int __errnum) ;
extern int __xpg_strerror_r (int __errnum, char *__buf, size_t __buflen)
#line 285 "/usr/include/string.h"
extern void __bzero (void *__s, size_t __n) ;
#line 329 "/usr/include/string.h"
#line 350 "/usr/include/string.h"
extern char *strsep (char ** __stringp,
#line 396 "/usr/include/string.h"
#line 431 "/usr/include/string.h"
Defined "HAVE_STRING_H" to "1"
Checking for header: sys/times.h
stdout:
#line 1 "/usr/include/sys/times.h"
#line 27 "/usr/include/sys/times.h"
#line 58 "/usr/include/time.h"
#line 30 "/usr/include/sys/times.h"
struct tms
clock_t tms_utime;
clock_t tms_stime;
clock_t tms_cutime;
clock_t tms_cstime;
extern clock_t times (struct tms *__buffer) ;
Defined "HAVE_SYS_TIMES_H" to "1"
Checking for header: io.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "io.h"
#include <io.h>
Source:
#include <io.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "io.h"
#include <io.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "io.h" #include <io.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: stdint.h
stdout:
Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
#line 1 "/usr/include/pwd.h"
#line 27 "/usr/include/pwd.h"
#line 31 "/usr/include/pwd.h"
#line 34 "/usr/include/pwd.h"
struct passwd
char *pw_name;
char *pw_passwd;
__uid_t pw_uid;
__gid_t pw_gid;
char *pw_gecos;
char *pw_dir;
char *pw_shell;
#line 1 "/usr/include/stdio.h"
#line 40 "/usr/include/stdio.h"
struct _IO_FILE;
typedef struct _IO_FILE FILE;
#line 70 "/usr/include/stdio.h"
#line 917 "/usr/include/stdio.h"
#line 65 "/usr/include/pwd.h"
extern void setpwent (void);
extern void endpwent (void);
extern struct passwd *getpwent (void);
extern struct passwd *fgetpwent (FILE *__stream);
extern int putpwent (const struct passwd * __p,
FILE * __f);
extern struct passwd *getpwuid (__uid_t __uid);
extern struct passwd *getpwnam (const char *__name);
extern int getpwent_r (struct passwd * __resultbuf,
char * __buffer, size_t __buflen,
struct passwd ** __result);
extern int getpwuid_r (__uid_t __uid,
extern int getpwnam_r (const char * __name,
extern int fgetpwent_r (FILE * __stream,
#line 183 "/usr/include/pwd.h"
Defined "HAVE_PWD_H" to "1"
Checking for header: float.h
stdout:
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/float.h"
#line 65 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/float.h"
#line 80 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/float.h"
#line 91 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/float.h"
Defined "HAVE_FLOAT_H" to "1"
Checking for header: sys/param.h
stdout:
#line 1 "/usr/include/sys/param.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 7 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 1 "/usr/include/bits/posix1_lim.h"
#line 1 "/usr/include/bits/local_lim.h"
#line 34 "/usr/include/bits/local_lim.h"
#line 1 "/usr/include/linux/limits.h"
#line 17 "/usr/include/linux/limits.h"
#line 37 "/usr/include/bits/local_lim.h"
#line 154 "/usr/include/bits/posix1_lim.h"
#line 62 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 1 "/usr/include/bits/posix2_lim.h"
#line 87 "/usr/include/bits/posix2_lim.h"
#line 66 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/limits.h"
#line 23 "/usr/include/sys/param.h"
#line 1 "/usr/include/linux/param.h"
#line 1 "/usr/include/asm/param.h"
#line 1 "/usr/include/asm-s64fx/param.h"
#line 6 "/usr/include/asm/param.h"
#line 5 "/usr/include/linux/param.h"
#line 25 "/usr/include/sys/param.h"
#line 36 "/usr/include/sys/param.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 43 "/usr/include/sys/param.h"
#line 62 "/usr/include/sys/param.h"
Defined "HAVE_SYS_PARAM_H" to "1"
Checking for header: netdb.h
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/netdb.h"
#line 27 "/usr/include/netdb.h"
#line 1 "/usr/include/netinet/in.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 24 "/usr/include/netinet/in.h"
#line 25 "/usr/include/netinet/in.h"
#line 1 "/usr/include/sys/socket.h"
#line 25 "/usr/include/sys/socket.h"
#line 1 "/usr/include/sys/uio.h"
#line 23 "/usr/include/sys/uio.h"
#line 172 "/usr/include/sys/types.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 25 "/usr/include/sys/uio.h"
#line 1 "/usr/include/bits/uio.h"
struct iovec
void *iov_base;
size_t iov_len;
#line 30 "/usr/include/sys/uio.h"
extern ssize_t readv (int __fd, const struct iovec *__iovec, int __count);
extern ssize_t writev (int __fd, const struct iovec *__iovec, int __count);
#line 29 "/usr/include/sys/socket.h"
#line 31 "/usr/include/sys/socket.h"
#line 1 "/usr/include/bits/socket.h"
#line 31 "/usr/include/bits/socket.h"
#line 33 "/usr/include/bits/socket.h"
typedef __socklen_t socklen_t;
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_PACKET = 10
#line 96 "/usr/include/bits/socket.h"
#line 130 "/usr/include/bits/socket.h"
#line 142 "/usr/include/bits/socket.h"
#line 1 "/usr/include/bits/sockaddr.h"
typedef unsigned short int sa_family_t;
#line 148 "/usr/include/bits/socket.h"
struct sockaddr
sa_family_t sa_family;
char sa_data[14];
#line 166 "/usr/include/bits/socket.h"
struct sockaddr_storage
sa_family_t ss_family;
__uint64_t __ss_align;
char __ss_padding[(128 - (2 * sizeof (__uint64_t)))];
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_DONTROUTE = 0x04,
#line 189 "/usr/include/bits/socket.h"
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_DONTWAIT = 0x40,
MSG_EOR = 0x80,
MSG_WAITALL = 0x100,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_CONFIRM = 0x800,
MSG_RST = 0x1000,
MSG_ERRQUEUE = 0x2000,
MSG_NOSIGNAL = 0x4000,
MSG_MORE = 0x8000,
MSG_CMSG_CLOEXEC = 0x40000000
struct msghdr
void *msg_name;
socklen_t msg_namelen;
struct iovec *msg_iov;
size_t msg_iovlen;
void *msg_control;
size_t msg_controllen;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
unsigned char __cmsg_data [];
#line 272 "/usr/include/bits/socket.h"
extern struct cmsghdr *__cmsg_nxthdr (struct msghdr *__mhdr,
struct cmsghdr *__cmsg) ;
#line 297 "/usr/include/bits/socket.h"
enum
SCM_RIGHTS = 0x01
, SCM_CREDENTIALS = 0x02
struct ucred
pid_t pid;
uid_t uid;
gid_t gid;
#line 1 "/usr/include/asm/socket.h"
#line 1 "/usr/include/asm-s64fx/socket.h"
#line 1 "/usr/include/asm/sockios.h"
#line 1 "/usr/include/asm-s64fx/sockios.h"
#line 12 "/usr/include/asm-s64fx/sockios.h"
#line 6 "/usr/include/asm/sockios.h"
#line 6 "/usr/include/asm-s64fx/socket.h"
#line 19 "/usr/include/asm-s64fx/socket.h"
#line 26 "/usr/include/asm-s64fx/socket.h"
#line 36 "/usr/include/asm-s64fx/socket.h"
#line 6 "/usr/include/asm/socket.h"
#line 321 "/usr/include/bits/socket.h"
struct linger
int l_onoff;
int l_linger;
#line 37 "/usr/include/sys/socket.h"
struct osockaddr
unsigned short int sa_family;
unsigned char sa_data[14];
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
#line 96 "/usr/include/sys/socket.h"
extern int socket (int __domain, int __type, int __protocol) ;
extern int socketpair (int __domain, int __type, int __protocol,
int __fds[2]) ;
extern int bind (int __fd, const struct sockaddr * __addr, socklen_t __len)
extern int getsockname (int __fd, struct sockaddr * __addr,
socklen_t * __len) ;
extern int connect (int __fd, const struct sockaddr * __addr, socklen_t __len);
extern int getpeername (int __fd, struct sockaddr * __addr,
extern ssize_t send (int __fd, const void *__buf, size_t __n, int __flags);
extern ssize_t recv (int __fd, void *__buf, size_t __n, int __flags);
extern ssize_t sendto (int __fd, const void *__buf, size_t __n,
int __flags, const struct sockaddr * __addr,
socklen_t __addr_len);
extern ssize_t recvfrom (int __fd, void * __buf, size_t __n,
int __flags, struct sockaddr * __addr,
socklen_t * __addr_len);
extern ssize_t sendmsg (int __fd, const struct msghdr *__message,
int __flags);
extern ssize_t recvmsg (int __fd, struct msghdr *__message, int __flags);
extern int getsockopt (int __fd, int __level, int __optname,
void * __optval,
socklen_t * __optlen) ;
extern int setsockopt (int __fd, int __level, int __optname,
const void *__optval, socklen_t __optlen) ;
extern int listen (int __fd, int __n) ;
extern int accept (int __fd, struct sockaddr * __addr,
extern int shutdown (int __fd, int __how) ;
extern int sockatmark (int __fd) ;
extern int isfdtype (int __fd, int __fdtype) ;
#line 26 "/usr/include/netinet/in.h"
enum
IPPROTO_IP = 0,
IPPROTO_HOPOPTS = 0,
IPPROTO_ICMP = 1,
IPPROTO_IGMP = 2,
IPPROTO_IPIP = 4,
IPPROTO_TCP = 6,
IPPROTO_EGP = 8,
IPPROTO_PUP = 12,
IPPROTO_UDP = 17,
IPPROTO_IDP = 22,
IPPROTO_TP = 29,
IPPROTO_IPV6 = 41,
IPPROTO_ROUTING = 43,
IPPROTO_FRAGMENT = 44,
IPPROTO_RSVP = 46,
IPPROTO_GRE = 47,
IPPROTO_ESP = 50,
IPPROTO_AH = 51,
IPPROTO_ICMPV6 = 58,
IPPROTO_NONE = 59,
IPPROTO_DSTOPTS = 60,
IPPROTO_MTP = 92,
IPPROTO_ENCAP = 98,
IPPROTO_PIM = 103,
IPPROTO_COMP = 108,
IPPROTO_SCTP = 132,
IPPROTO_RAW = 255,
IPPROTO_MAX
typedef uint16_t in_port_t;
enum
IPPORT_ECHO = 7,
IPPORT_DISCARD = 9,
IPPORT_SYSTAT = 11,
IPPORT_DAYTIME = 13,
IPPORT_NETSTAT = 15,
IPPORT_FTP = 21,
IPPORT_TELNET = 23,
IPPORT_SMTP = 25,
IPPORT_TIMESERVER = 37,
IPPORT_NAMESERVER = 42,
IPPORT_WHOIS = 43,
IPPORT_MTP = 57,
IPPORT_TFTP = 69,
IPPORT_RJE = 77,
IPPORT_FINGER = 79,
IPPORT_TTYLINK = 87,
IPPORT_SUPDUP = 95,
IPPORT_EXECSERVER = 512,
IPPORT_LOGINSERVER = 513,
IPPORT_CMDSERVER = 514,
IPPORT_EFSSERVER = 520,
IPPORT_BIFFUDP = 512,
IPPORT_WHOSERVER = 513,
IPPORT_ROUTESERVER = 520,
IPPORT_RESERVED = 1024,
IPPORT_USERRESERVED = 5000
typedef uint32_t in_addr_t;
struct in_addr
in_addr_t s_addr;
struct in6_addr
union
uint8_t u6_addr8[16];
uint16_t u6_addr16[8];
uint32_t u6_addr32[4];
} in6_u;
extern const struct in6_addr in6addr_any;
extern const struct in6_addr in6addr_loopback;
struct sockaddr_in
sa_family_t sin_family;
in_port_t sin_port;
struct in_addr sin_addr;
unsigned char sin_zero[sizeof (struct sockaddr) -
(sizeof (unsigned short int)) -
sizeof (in_port_t) -
sizeof (struct in_addr)];
struct sockaddr_in6
sa_family_t sin6_family;
in_port_t sin6_port;
uint32_t sin6_flowinfo;
struct in6_addr sin6_addr;
uint32_t sin6_scope_id;
struct ip_mreq
struct in_addr imr_multiaddr;
struct in_addr imr_interface;
struct ip_mreq_source
struct in_addr imr_sourceaddr;
struct ipv6_mreq
struct in6_addr ipv6mr_multiaddr;
unsigned int ipv6mr_interface;
struct group_req
uint32_t gr_interface;
struct sockaddr_storage gr_group;
struct group_source_req
uint32_t gsr_interface;
struct sockaddr_storage gsr_group;
struct sockaddr_storage gsr_source;
struct ip_msfilter
struct in_addr imsf_multiaddr;
struct in_addr imsf_interface;
uint32_t imsf_fmode;
uint32_t imsf_numsrc;
struct in_addr imsf_slist[1];
struct group_filter
uint32_t gf_interface;
struct sockaddr_storage gf_group;
uint32_t gf_fmode;
uint32_t gf_numsrc;
struct sockaddr_storage gf_slist[1];
#line 1 "/usr/include/bits/in.h"
#line 53 "/usr/include/bits/in.h"
#line 65 "/usr/include/bits/in.h"
struct ip_opts
struct in_addr ip_dst;
char ip_opts[40];
struct ip_mreqn
struct in_addr imr_address;
int imr_ifindex;
struct in_pktinfo
int ipi_ifindex;
struct in_addr ipi_spec_dst;
struct in_addr ipi_addr;
#line 115 "/usr/include/bits/in.h"
#line 135 "/usr/include/bits/in.h"
#line 147 "/usr/include/bits/in.h"
#line 344 "/usr/include/netinet/in.h"
extern uint32_t ntohl (uint32_t __netlong) ;
extern uint16_t ntohs (uint16_t __netshort)
extern uint32_t htonl (uint32_t __hostlong)
extern uint16_t htons (uint16_t __hostshort)
#line 1 "/usr/include/bits/byteswap.h"
static unsigned short int
__bswap_16 (unsigned short int __bsx)
return ((((__bsx) >> 8) & 0xffu) | (((__bsx) & 0xffu) << 8));
static unsigned int
__bswap_32 (unsigned int __bsx)
return ((((__bsx) & 0xff000000u) >> 24) | (((__bsx) & 0x00ff0000u) >> 8) | (((__bsx) & 0x0000ff00u) << 8) | (((__bsx) & 0x000000ffu) << 24));
#line 86 "/usr/include/bits/byteswap.h"
#line 364 "/usr/include/netinet/in.h"
#line 385 "/usr/include/netinet/in.h"
extern int bindresvport (int __sockfd, struct sockaddr_in *__sock_in) ;
extern int bindresvport6 (int __sockfd, struct sockaddr_in6 *__sock_in)
struct in6_pktinfo
struct in6_addr ipi6_addr;
unsigned int ipi6_ifindex;
struct ip6_mtuinfo
struct sockaddr_in6 ip6m_addr;
uint32_t ip6m_mtu;
#line 548 "/usr/include/netinet/in.h"
#line 29 "/usr/include/netdb.h"
#line 1 "/usr/include/rpc/netdb.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 40 "/usr/include/rpc/netdb.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 43 "/usr/include/rpc/netdb.h"
struct rpcent
char *r_name;
char **r_aliases;
int r_number;
extern void setrpcent (int __stayopen) ;
extern void endrpcent (void) ;
extern struct rpcent *getrpcbyname (const char *__name) ;
extern struct rpcent *getrpcbynumber (int __number) ;
extern struct rpcent *getrpcent (void) ;
extern int getrpcbyname_r (const char *__name, struct rpcent *__result_buf,
char *__buffer, size_t __buflen,
struct rpcent **__result) ;
extern int getrpcbynumber_r (int __number, struct rpcent *__result_buf,
extern int getrpcent_r (struct rpcent *__result_buf, char *__buffer,
size_t __buflen, struct rpcent **__result) ;
#line 34 "/usr/include/netdb.h"
#line 42 "/usr/include/netdb.h"
#line 1 "/usr/include/bits/netdb.h"
struct netent
char *n_name;
char **n_aliases;
int n_addrtype;
uint32_t n_net;
#line 44 "/usr/include/netdb.h"
#line 52 "/usr/include/netdb.h"
extern int *__h_errno_location (void) ;
#line 75 "/usr/include/netdb.h"
extern void herror (const char *__str) ;
extern const char *hstrerror (int __err_num) ;
struct hostent
char *h_name;
char **h_aliases;
int h_addrtype;
int h_length;
char **h_addr_list;
extern void sethostent (int __stay_open);
extern void endhostent (void);
extern struct hostent *gethostent (void);
extern struct hostent *gethostbyaddr (const void *__addr, __socklen_t __len,
int __type);
extern struct hostent *gethostbyname (const char *__name);
extern struct hostent *gethostbyname2 (const char *__name, int __af);
extern int gethostent_r (struct hostent * __result_buf,
char * __buf, size_t __buflen,
struct hostent ** __result,
int * __h_errnop);
extern int gethostbyaddr_r (const void * __addr, __socklen_t __len,
int __type,
int * __h_errnop);
extern int gethostbyname_r (const char * __name,
int * __h_errnop);
extern int gethostbyname2_r (const char * __name, int __af,
int * __h_errnop);
extern void setnetent (int __stay_open);
extern void endnetent (void);
extern struct netent *getnetent (void);
extern struct netent *getnetbyaddr (uint32_t __net, int __type);
extern struct netent *getnetbyname (const char *__name);
extern int getnetent_r (struct netent * __result_buf,
struct netent ** __result,
int * __h_errnop);
extern int getnetbyaddr_r (uint32_t __net, int __type,
int * __h_errnop);
extern int getnetbyname_r (const char * __name,
int * __h_errnop);
struct servent
char *s_name;
char **s_aliases;
int s_port;
char *s_proto;
extern void setservent (int __stay_open);
extern void endservent (void);
extern struct servent *getservent (void);
extern struct servent *getservbyname (const char *__name,
const char *__proto);
extern struct servent *getservbyport (int __port, const char *__proto);
extern int getservent_r (struct servent * __result_buf,
struct servent ** __result);
extern int getservbyname_r (const char * __name,
const char * __proto,
extern int getservbyport_r (int __port, const char * __proto,
struct protoent
char *p_name;
char **p_aliases;
int p_proto;
extern void setprotoent (int __stay_open);
extern void endprotoent (void);
extern struct protoent *getprotoent (void);
extern struct protoent *getprotobyname (const char *__name);
extern struct protoent *getprotobynumber (int __proto);
extern int getprotoent_r (struct protoent * __result_buf,
struct protoent ** __result);
extern int getprotobyname_r (const char * __name,
extern int getprotobynumber_r (int __proto,
extern int setnetgrent (const char *__netgroup);
extern void endnetgrent (void);
extern int getnetgrent (char ** __hostp,
char ** __userp,
char ** __domainp);
extern int innetgr (const char *__netgroup, const char *__host,
const char *__user, const char *domain);
extern int getnetgrent_r (char ** __hostp,
char ** __userp,
char ** __domainp,
char * __buffer, size_t __buflen);
extern int rcmd (char ** __ahost, unsigned short int __rport,
const char * __locuser,
const char * __remuser,
const char * __cmd, int * __fd2p);
extern int rcmd_af (char ** __ahost, unsigned short int __rport,
const char * __cmd, int * __fd2p,
sa_family_t __af);
extern int rexec (char ** __ahost, int __rport,
const char * __pass,
extern int rexec_af (char ** __ahost, int __rport,
sa_family_t __af);
extern int ruserok (const char *__rhost, int __suser,
const char *__remuser, const char *__locuser);
extern int ruserok_af (const char *__rhost, int __suser,
const char *__remuser, const char *__locuser,
sa_family_t __af);
extern int rresvport (int *__alport);
extern int rresvport_af (int *__alport, sa_family_t __af);
struct addrinfo
int ai_flags;
int ai_family;
int ai_socktype;
int ai_protocol;
socklen_t ai_addrlen;
struct sockaddr *ai_addr;
char *ai_canonname;
struct addrinfo *ai_next;
#line 567 "/usr/include/netdb.h"
#line 587 "/usr/include/netdb.h"
#line 609 "/usr/include/netdb.h"
#line 625 "/usr/include/netdb.h"
extern int getaddrinfo (const char * __name,
const char * __service,
const struct addrinfo * __req,
struct addrinfo ** __pai);
extern void freeaddrinfo (struct addrinfo *__ai) ;
extern const char *gai_strerror (int __ecode) ;
extern int getnameinfo (const struct sockaddr * __sa,
socklen_t __salen, char * __host,
socklen_t __hostlen, char * __serv,
socklen_t __servlen, unsigned int __flags);
#line 681 "/usr/include/netdb.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Defined "HAVE_NETDB_H" to "1"
Checking for header: search.h
stdout:
#line 1 "/usr/include/search.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 24 "/usr/include/search.h"
typedef unsigned long size_t;
#line 27 "/usr/include/search.h"
#line 42 "/usr/include/search.h"
extern void insque (void *__elem, void *__prev) ;
extern void remque (void *__elem) ;
typedef enum
FIND,
ENTER
ACTION;
typedef struct entry
char *key;
void *data;
ENTRY;
struct _ENTRY;
extern ENTRY *hsearch (ENTRY __item, ACTION __action) ;
extern int hcreate (size_t __nel) ;
extern void hdestroy (void) ;
#line 114 "/usr/include/search.h"
typedef enum
preorder,
postorder,
endorder,
leaf
VISIT;
extern void *tsearch (const void *__key, void **__rootp,
__compar_fn_t __compar);
extern void *tfind (const void *__key, void *const *__rootp,
extern void *tdelete (const void * __key,
void ** __rootp,
typedef void (*__action_fn_t) (const void *__nodep, VISIT __value,
int __level);
extern void twalk (const void *__root, __action_fn_t __action);
#line 163 "/usr/include/search.h"
extern void *lfind (const void *__key, const void *__base,
size_t *__nmemb, size_t __size, __compar_fn_t __compar);
extern void *lsearch (const void *__key, void *__base,
Defined "HAVE_SEARCH_H" to "1"
Checking for header: mathimf.h
stdout:
Possible ERROR while running preprocessor: exit code 512
stdout:
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "mathimf.h"
#include <mathimf.h>
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "mathimf.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "mathimf.h" #include <mathimf.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: sys/procfs.h
stdout:
#line 1 "/usr/include/sys/procfs.h"
#line 27 "/usr/include/sys/procfs.h"
#line 1 "/usr/include/signal.h"
#line 30 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 100 "/usr/include/bits/sigset.h"
extern int __sigismember (const __sigset_t *, int);
extern int __sigaddset (__sigset_t *, int);
extern int __sigdelset (__sigset_t *, int);
#line 124 "/usr/include/bits/sigset.h"
#line 34 "/usr/include/signal.h"
typedef __sig_atomic_t sig_atomic_t;
typedef __sigset_t sigset_t;
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 58 "/usr/include/signal.h"
#line 1 "/usr/include/bits/signum.h"
#line 52 "/usr/include/bits/signum.h"
#line 72 "/usr/include/bits/signum.h"
#line 59 "/usr/include/signal.h"
typedef __pid_t pid_t;
typedef __uid_t uid_t;
typedef void (*__sighandler_t) (int);
extern __sighandler_t __sysv_signal (int __sig, __sighandler_t __handler)
extern __sighandler_t signal (int __sig, __sighandler_t __handler)
#line 104 "/usr/include/signal.h"
#line 112 "/usr/include/signal.h"
extern int kill (__pid_t __pid, int __sig) ;
extern int killpg (__pid_t __pgrp, int __sig) ;
extern int raise (int __sig) ;
extern __sighandler_t ssignal (int __sig, __sighandler_t __handler)
extern int gsignal (int __sig) ;
extern void psignal (int __sig, const char *__s);
extern int __sigpause (int __sig_or_mask, int __is_sig);
#line 169 "/usr/include/signal.h"
extern int sigblock (int __mask) ;
extern int sigsetmask (int __mask) ;
extern int siggetmask (void) ;
typedef __sighandler_t sig_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 419 "/usr/include/time.h"
#line 210 "/usr/include/signal.h"
#line 1 "/usr/include/bits/siginfo.h"
#line 26 "/usr/include/bits/siginfo.h"
typedef union sigval
int sival_int;
void *sival_ptr;
} sigval_t;
#line 50 "/usr/include/bits/siginfo.h"
typedef struct siginfo
int si_signo;
int si_errno;
int si_code;
union
int _pad[((128 / sizeof (int)) - 4)];
struct
__pid_t si_pid;
__uid_t si_uid;
} _kill;
struct
int si_tid;
int si_overrun;
sigval_t si_sigval;
} _timer;
struct
__pid_t si_pid;
__uid_t si_uid;
sigval_t si_sigval;
} _rt;
struct
__pid_t si_pid;
__uid_t si_uid;
int si_status;
__clock_t si_utime;
__clock_t si_stime;
} _sigchld;
struct
void *si_addr;
int si_trapno;
} _sigfault;
struct
int si_band;
int si_fd;
} _sigpoll;
} _sifields;
} siginfo_t;
#line 127 "/usr/include/bits/siginfo.h"
enum
SI_ASYNCNL = -60,
SI_TKILL = -6,
SI_SIGIO,
SI_ASYNCIO,
SI_MESGQ,
SI_TIMER,
SI_QUEUE,
SI_USER,
SI_KERNEL = 0x80
enum
ILL_ILLOPC = 1,
ILL_ILLOPN,
ILL_ILLADR,
ILL_ILLTRP,
ILL_PRVOPC,
ILL_PRVREG,
ILL_COPROC,
ILL_BADSTK
enum
FPE_INTDIV = 1,
FPE_INTOVF,
FPE_FLTDIV,
FPE_FLTOVF,
FPE_FLTUND,
FPE_FLTRES,
FPE_FLTINV,
FPE_FLTSUB
enum
SEGV_MAPERR = 1,
SEGV_ACCERR
enum
BUS_ADRALN = 1,
BUS_ADRERR,
BUS_OBJERR
enum
TRAP_BRKPT = 1,
TRAP_TRACE
enum
CLD_EXITED = 1,
CLD_KILLED,
CLD_DUMPED,
CLD_TRAPPED,
CLD_STOPPED,
CLD_CONTINUED
enum
POLL_IN = 1,
POLL_OUT,
POLL_MSG,
POLL_ERR,
POLL_PRI,
POLL_HUP
enum
EMT_TAGOVF = 1
#line 281 "/usr/include/bits/siginfo.h"
typedef struct sigevent
sigval_t sigev_value;
int sigev_signo;
int sigev_notify;
union
int _pad[((64 / sizeof (int)) - 4)];
struct
void (*_function) (sigval_t);
void *_attribute;
} _sigev_thread;
} _sigev_un;
} sigevent_t;
enum
SIGEV_SIGNAL = 0,
SIGEV_NONE,
SIGEV_THREAD,
SIGEV_THREAD_ID = 4
#line 213 "/usr/include/signal.h"
extern int sigemptyset (sigset_t *__set) ;
extern int sigfillset (sigset_t *__set) ;
extern int sigaddset (sigset_t *__set, int __signo) ;
extern int sigdelset (sigset_t *__set, int __signo) ;
extern int sigismember (const sigset_t *__set, int __signo)
#line 243 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigaction.h"
struct sigaction
union
__sighandler_t sa_handler;
void (*sa_sigaction) (int, siginfo_t *, void *);
__sigaction_handler;
__sigset_t sa_mask;
unsigned long sa_flags;
void (*sa_restorer) (void);
#line 66 "/usr/include/bits/sigaction.h"
#line 247 "/usr/include/signal.h"
extern int sigprocmask (int __how, const sigset_t * __set,
sigset_t * __oset) ;
extern int sigsuspend (const sigset_t *__set) ;
extern int sigaction (int __sig, const struct sigaction * __act,
struct sigaction * __oact) ;
extern int sigpending (sigset_t *__set) ;
extern int sigwait (const sigset_t * __set, int * __sig)
extern int sigwaitinfo (const sigset_t * __set,
siginfo_t * __info) ;
extern int sigtimedwait (const sigset_t * __set,
siginfo_t * __info,
const struct timespec * __timeout)
extern int sigqueue (__pid_t __pid, int __sig, const union sigval __val)
extern const char *const _sys_siglist[65];
extern const char *const sys_siglist[65];
struct sigvec
__sighandler_t sv_handler;
int sv_mask;
int sv_flags;
extern int sigvec (int __sig, const struct sigvec *__vec,
struct sigvec *__ovec) ;
#line 1 "/usr/include/bits/sigcontext.h"
#line 24 "/usr/include/bits/sigcontext.h"
#line 1 "/usr/include/stdint.h"
#line 27 "/usr/include/stdint.h"
#line 1 "/usr/include/bits/wchar.h"
#line 28 "/usr/include/stdint.h"
#line 29 "/usr/include/stdint.h"
typedef signed char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned long int uint64_t;
typedef signed char int_least8_t;
typedef short int int_least16_t;
typedef int int_least32_t;
typedef long int int_least64_t;
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned long int uint_least64_t;
typedef signed char int_fast8_t;
typedef long int int_fast16_t;
typedef long int int_fast32_t;
typedef long int int_fast64_t;
#line 102 "/usr/include/stdint.h"
typedef unsigned char uint_fast8_t;
typedef unsigned long int uint_fast16_t;
typedef unsigned long int uint_fast32_t;
typedef unsigned long int uint_fast64_t;
#line 115 "/usr/include/stdint.h"
typedef long int intptr_t;
typedef unsigned long int uintptr_t;
#line 131 "/usr/include/stdint.h"
typedef long int intmax_t;
typedef unsigned long int uintmax_t;
#line 143 "/usr/include/stdint.h"
#line 156 "/usr/include/stdint.h"
#line 205 "/usr/include/stdint.h"
#line 215 "/usr/include/stdint.h"
#line 226 "/usr/include/stdint.h"
#line 238 "/usr/include/stdint.h"
#line 259 "/usr/include/stdint.h"
#line 298 "/usr/include/stdint.h"
#line 308 "/usr/include/stdint.h"
#line 317 "/usr/include/stdint.h"
#line 25 "/usr/include/bits/sigcontext.h"
#line 48 "/usr/include/bits/sigcontext.h"
typedef struct
unsigned int si_float_regs [64];
unsigned long si_fsr;
unsigned long si_gsr;
unsigned long si_fprs;
uint64_t si_xglob_regs[32];
uint32_t si_xfloat_regs[448];
uint64_t si_xasr;
} __siginfo_fpu_t;
struct sigcontext
char sigc_info[128];
struct
unsigned long u_regs[16];
unsigned long tstate;
unsigned long tpc;
unsigned long tnpc;
unsigned int y;
unsigned int fprs;
} sigc_regs;
__siginfo_fpu_t * sigc_fpu_save;
uint64_t si_txar;
uint64_t si_sccr;
struct
void * ss_sp;
int ss_flags;
unsigned long ss_size;
} sigc_stack;
unsigned long sigc_mask;
#line 334 "/usr/include/signal.h"
extern int sigreturn (struct sigcontext *__scp) ;
#line 344 "/usr/include/signal.h"
extern int siginterrupt (int __sig, int __interrupt) ;
#line 1 "/usr/include/bits/sigstack.h"
struct sigstack
void *ss_sp;
int ss_onstack;
enum
SS_ONSTACK = 1,
SS_DISABLE
typedef struct sigaltstack
void *ss_sp;
int ss_flags;
size_t ss_size;
} stack_t;
#line 351 "/usr/include/signal.h"
extern int sigstack (struct sigstack *__ss, struct sigstack *__oss)
extern int sigaltstack (const struct sigaltstack * __ss,
struct sigaltstack * __oss) ;
#line 384 "/usr/include/signal.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 389 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigthread.h"
extern int pthread_sigmask (int __how,
const __sigset_t * __newmask,
__sigset_t * __oldmask);
extern int pthread_kill (pthread_t __threadid, int __signo) ;
#line 390 "/usr/include/signal.h"
extern int __libc_current_sigrtmin (void) ;
extern int __libc_current_sigrtmax (void) ;
#line 28 "/usr/include/sys/procfs.h"
#line 1 "/usr/include/sys/time.h"
#line 24 "/usr/include/sys/time.h"
typedef __time_t time_t;
#line 129 "/usr/include/time.h"
#line 28 "/usr/include/sys/time.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 30 "/usr/include/sys/time.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
#line 35 "/usr/include/bits/sigset.h"
#line 35 "/usr/include/sys/select.h"
#line 45 "/usr/include/sys/select.h"
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 32 "/usr/include/sys/time.h"
#line 52 "/usr/include/sys/time.h"
struct timezone
int tz_minuteswest;
int tz_dsttime;
typedef struct timezone * __timezone_ptr_t;
extern int gettimeofday (struct timeval * __tv,
__timezone_ptr_t __tz) ;
extern int settimeofday (const struct timeval *__tv,
const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
struct timeval *__olddelta) ;
enum __itimer_which
ITIMER_REAL = 0,
ITIMER_VIRTUAL = 1,
ITIMER_PROF = 2
struct itimerval
struct timeval it_interval;
struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
struct itimerval *__value) ;
extern int setitimer (__itimer_which_t __which,
const struct itimerval * __new,
struct itimerval * __old) ;
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) ;
#line 159 "/usr/include/sys/time.h"
#line 190 "/usr/include/sys/time.h"
#line 29 "/usr/include/sys/procfs.h"
#line 1 "/usr/include/sys/types.h"
#line 28 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
#line 30 "/usr/include/sys/procfs.h"
#line 1 "/usr/include/sys/ucontext.h"
#line 23 "/usr/include/sys/ucontext.h"
#line 25 "/usr/include/sys/ucontext.h"
#line 82 "/usr/include/sys/ucontext.h"
typedef unsigned long mc_greg_t;
typedef mc_greg_t mc_gregset_t[53];
struct mc_fq {
unsigned long *mcfq_addr;
unsigned int mcfq_insn;
struct mc_fpu {
union {
} mcfpu_fregs;
struct mc_fq *mcfpu_fq;
unsigned char pad[5];
typedef struct mc_fpu mc_fpu_t;
typedef struct {
mc_gregset_t mc_gregs;
mc_greg_t mc_fp;
mc_greg_t mc_i7;
mc_fpu_t mc_fpregs;
} mcontext_t;
typedef struct ucontext {
struct ucontext *uc_link;
unsigned long __uc_sigmask;
mcontext_t uc_mcontext;
stack_t uc_stack;
__sigset_t uc_sigmask;
} ucontext_t;
#line 186 "/usr/include/sys/ucontext.h"
typedef long greg_t;
#line 211 "/usr/include/sys/ucontext.h"
typedef greg_t gregset_t[21];
struct rwindow
greg_t rw_local[8];
greg_t rw_in[8];
typedef struct gwindows
int wbcnt;
int *spbuf[31];
struct rwindow wbuf[31];
} gwindows_t;
struct fpq
unsigned long *fpq_addr;
unsigned long fpq_instr;
struct fq
union
double whole;
struct fpq fpq;
} FQu;
typedef struct fpu
union {
unsigned fpu_regs[512];
double fpu_dregs[256];
long double fpu_qregs[128];
} fpu_fr;
struct fq *fpu_q;
unsigned long fpu_fsr;
unsigned char fpu_qcnt;
unsigned char fpu_q_entrysize;
unsigned char fpu_en;
unsigned long fpu_xasr;
} fpregset_t;
#line 31 "/usr/include/sys/procfs.h"
#line 1 "/usr/include/sys/user.h"
struct sunos_regs
unsigned int psr, pc, npc, y;
unsigned int regs[15];
struct sunos_fpqueue
unsigned int *addr;
unsigned int inst;
struct sunos_fp
union
unsigned int regs[32];
double reg_dbls[16];
} fregs;
unsigned int fsr;
unsigned int flags;
unsigned int extra;
unsigned int fpq_count;
struct sunos_fpqueue fpq[16];
struct sunos_fpu
struct sunos_fp fpstatus;
struct user {
unsigned int magic;
unsigned int len;
struct sunos_regs regs;
struct
unsigned char a_dynamic :1;
unsigned char a_toolversion :7;
unsigned char a_machtype;
unsigned short a_info;
unsigned int a_text;
unsigned int a_data;
unsigned int a_bss;
unsigned int a_syms;
unsigned int a_entry;
unsigned int a_trsize;
unsigned int a_drsize;
} uexec;
int signal;
size_t u_tsize;
size_t u_dsize;
size_t u_ssize;
char u_comm[17];
struct sunos_fpu fpu;
unsigned int sigcode;
#line 32 "/usr/include/sys/procfs.h"
#line 33 "/usr/include/sys/procfs.h"
typedef struct
unsigned long pr_regs[32];
unsigned long pr_fsr;
unsigned long pr_gsr;
unsigned long pr_fprs;
} elf_fpregset_t;
#line 68 "/usr/include/sys/procfs.h"
typedef unsigned long elf_greg_t;
typedef elf_greg_t elf_gregset_t[36];
struct elf_siginfo
int si_signo;
int si_code;
int si_errno;
struct elf_prstatus
struct elf_siginfo pr_info;
short int pr_cursig;
unsigned long int pr_sigpend;
unsigned long int pr_sighold;
__pid_t pr_pid;
__pid_t pr_ppid;
__pid_t pr_pgrp;
__pid_t pr_sid;
struct timeval pr_utime;
struct timeval pr_stime;
struct timeval pr_cutime;
struct timeval pr_cstime;
elf_gregset_t pr_reg;
int pr_fpvalid;
struct elf_prpsinfo
char pr_state;
char pr_sname;
char pr_zomb;
char pr_nice;
unsigned long int pr_flag;
unsigned int pr_uid;
unsigned int pr_gid;
int pr_pid, pr_ppid, pr_pgrp, pr_sid;
char pr_fname[16];
char pr_psargs[(80)];
typedef void *psaddr_t;
typedef elf_gregset_t prgregset_t;
typedef elf_fpregset_t prfpregset_t;
#line 1 "/usr/include/xos_sft/asm/xreg.h"
struct xregs {
uint64_t xregs[32];
uint64_t txar;
uint64_t sccr;
uint64_t watchpoint;
uint64_t dcucr;
uint64_t rsv[12];
struct xfpregs {
uint64_t xfpregs[224];
uint64_t xasr;
uint64_t fprs;
#line 136 "/usr/include/sys/procfs.h"
typedef struct xregs prxgregset_t;
typedef struct xfpregs prxfpregset_t;
typedef __pid_t lwpid_t;
typedef struct elf_prstatus prstatus_t;
typedef struct elf_prpsinfo prpsinfo_t;
typedef struct
union
unsigned int pr_regs[32];
double pr_dregs[16];
} pr_fr;
unsigned int __unused;
unsigned int pr_fsr;
unsigned char pr_qcnt;
unsigned char pr_q_entrysize;
unsigned char pr_en;
unsigned int pr_q[64];
} elf_fpregset_t32;
typedef unsigned int elf_greg_t32;
typedef elf_greg_t32 elf_gregset_t32[38];
struct elf_prstatus32
unsigned int pr_sigpend;
unsigned int pr_sighold;
__pid_t pr_pid;
__pid_t pr_ppid;
__pid_t pr_pgrp;
__pid_t pr_sid;
struct
int tv_sec, tv_usec;
} pr_utime,
pr_stime,
pr_cutime,
pr_cstime;
elf_gregset_t32 pr_reg;
int pr_fpvalid;
struct elf_prpsinfo32
char pr_state;
char pr_sname;
char pr_zomb;
char pr_nice;
unsigned int pr_flag;
unsigned short int pr_uid;
unsigned short int pr_gid;
char pr_fname[16];
typedef elf_gregset_t32 prgregset32_t;
typedef elf_fpregset_t32 prfpregset32_t;
typedef struct elf_prstatus32 prstatus32_t;
typedef struct elf_prpsinfo32 prpsinfo32_t;
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_SYS_PROCFS_H" to "1"
Checking for header: sys/resource.h
stdout:
#line 1 "/usr/include/sys/resource.h"
#line 23 "/usr/include/sys/resource.h"
#line 1 "/usr/include/bits/resource.h"
#line 26 "/usr/include/bits/resource.h"
enum __rlimit_resource
RLIMIT_CPU = 0,
RLIMIT_FSIZE = 1,
RLIMIT_DATA = 2,
RLIMIT_STACK = 3,
RLIMIT_CORE = 4,
__RLIMIT_RSS = 5,
RLIMIT_NOFILE = 6,
__RLIMIT_OFILE = RLIMIT_NOFILE,
RLIMIT_AS = 9,
__RLIMIT_NPROC = 7,
__RLIMIT_MEMLOCK = 8,
__RLIMIT_LOCKS = 10,
__RLIMIT_SIGPENDING = 11,
__RLIMIT_MSGQUEUE = 12,
__RLIMIT_NICE = 13,
__RLIMIT_RTPRIO = 14,
__RLIMIT_NLIMITS = 15,
__RLIM_NLIMITS = __RLIMIT_NLIMITS
#line 135 "/usr/include/bits/resource.h"
typedef __rlim_t rlim_t;
#line 150 "/usr/include/bits/resource.h"
struct rlimit
rlim_t rlim_cur;
rlim_t rlim_max;
#line 168 "/usr/include/bits/resource.h"
enum __rusage_who
RUSAGE_SELF = 0,
RUSAGE_CHILDREN = -1
struct timeval
__time_t tv_sec;
#line 183 "/usr/include/bits/resource.h"
struct rusage
struct timeval ru_utime;
struct timeval ru_stime;
long int ru_maxrss;
long int ru_ixrss;
long int ru_idrss;
long int ru_isrss;
long int ru_minflt;
long int ru_majflt;
long int ru_nswap;
long int ru_inblock;
long int ru_oublock;
long int ru_msgsnd;
long int ru_msgrcv;
long int ru_nsignals;
long int ru_nvcsw;
long int ru_nivcsw;
enum __priority_which
PRIO_PROCESS = 0,
PRIO_PGRP = 1,
PRIO_USER = 2
#line 26 "/usr/include/sys/resource.h"
typedef int __rlimit_resource_t;
typedef int __rusage_who_t;
typedef int __priority_which_t;
extern int getrlimit (__rlimit_resource_t __resource,
struct rlimit *__rlimits) ;
#line 65 "/usr/include/sys/resource.h"
extern int setrlimit (__rlimit_resource_t __resource,
const struct rlimit *__rlimits) ;
#line 85 "/usr/include/sys/resource.h"
extern int getrusage (__rusage_who_t __who, struct rusage *__usage) ;
extern int getpriority (__priority_which_t __which, id_t __who) ;
extern int setpriority (__priority_which_t __which, id_t __who, int __prio)
Defined "HAVE_SYS_RESOURCE_H" to "1"
Checking for header: unistd.h
stdout:
#line 1 "/usr/include/unistd.h"
#line 27 "/usr/include/unistd.h"
#line 66 "/usr/include/unistd.h"
#line 1 "/usr/include/bits/posix_opt.h"
#line 174 "/usr/include/unistd.h"
#line 189 "/usr/include/unistd.h"
#line 198 "/usr/include/unistd.h"
#line 224 "/usr/include/unistd.h"
typedef __useconds_t useconds_t;
typedef __intptr_t intptr_t;
extern int access (const char *__name, int __type) ;
#line 270 "/usr/include/unistd.h"
#line 278 "/usr/include/unistd.h"
extern __off_t lseek (int __fd, __off_t __offset, int __whence) ;
#line 315 "/usr/include/unistd.h"
extern int close (int __fd);
extern ssize_t read (int __fd, void *__buf, size_t __nbytes) ;
extern ssize_t write (int __fd, const void *__buf, size_t __n) ;
#line 379 "/usr/include/unistd.h"
extern int pipe (int __pipedes[2]) ;
extern unsigned int alarm (unsigned int __seconds) ;
extern unsigned int sleep (unsigned int __seconds);
extern __useconds_t ualarm (__useconds_t __value, __useconds_t __interval)
extern int usleep (__useconds_t __useconds);
extern int pause (void);
extern int chown (const char *__file, __uid_t __owner, __gid_t __group)
extern int fchown (int __fd, __uid_t __owner, __gid_t __group) ;
extern int lchown (const char *__file, __uid_t __owner, __gid_t __group)
#line 455 "/usr/include/unistd.h"
extern int chdir (const char *__path) ;
extern int fchdir (int __fd) ;
extern char *getcwd (char *__buf, size_t __size) ;
#line 479 "/usr/include/unistd.h"
extern char *getwd (char *__buf)
extern int dup (int __fd) ;
extern int dup2 (int __fd, int __fd2) ;
extern char **__environ;
extern int execve (const char *__path, char *const __argv[],
char *const __envp[]) ;
#line 513 "/usr/include/unistd.h"
extern int execv (const char *__path, char *const __argv[])
extern int execle (const char *__path, const char *__arg, ...)
extern int execl (const char *__path, const char *__arg, ...)
extern int execvp (const char *__file, char *const __argv[])
extern int execlp (const char *__file, const char *__arg, ...)
extern int nice (int __inc) ;
extern void _exit (int __status) ;
#line 1 "/usr/include/bits/confname.h"
enum
_PC_LINK_MAX,
_PC_MAX_CANON,
_PC_MAX_INPUT,
_PC_NAME_MAX,
_PC_PATH_MAX,
_PC_PIPE_BUF,
_PC_CHOWN_RESTRICTED,
_PC_NO_TRUNC,
_PC_VDISABLE,
_PC_SYNC_IO,
_PC_ASYNC_IO,
_PC_PRIO_IO,
_PC_SOCK_MAXBUF,
_PC_FILESIZEBITS,
_PC_REC_INCR_XFER_SIZE,
_PC_REC_MAX_XFER_SIZE,
_PC_REC_MIN_XFER_SIZE,
_PC_REC_XFER_ALIGN,
_PC_ALLOC_SIZE_MIN,
_PC_SYMLINK_MAX,
_PC_2_SYMLINKS
enum
_SC_ARG_MAX,
_SC_CHILD_MAX,
_SC_CLK_TCK,
_SC_NGROUPS_MAX,
_SC_OPEN_MAX,
_SC_STREAM_MAX,
_SC_TZNAME_MAX,
_SC_JOB_CONTROL,
_SC_SAVED_IDS,
_SC_REALTIME_SIGNALS,
_SC_PRIORITY_SCHEDULING,
_SC_TIMERS,
_SC_ASYNCHRONOUS_IO,
_SC_PRIORITIZED_IO,
_SC_SYNCHRONIZED_IO,
_SC_FSYNC,
_SC_MAPPED_FILES,
_SC_MEMLOCK,
_SC_MEMLOCK_RANGE,
_SC_MEMORY_PROTECTION,
_SC_MESSAGE_PASSING,
_SC_SEMAPHORES,
_SC_SHARED_MEMORY_OBJECTS,
_SC_AIO_LISTIO_MAX,
_SC_AIO_MAX,
_SC_AIO_PRIO_DELTA_MAX,
_SC_DELAYTIMER_MAX,
_SC_MQ_OPEN_MAX,
_SC_MQ_PRIO_MAX,
_SC_VERSION,
_SC_PAGESIZE,
_SC_RTSIG_MAX,
_SC_SEM_NSEMS_MAX,
_SC_SEM_VALUE_MAX,
_SC_SIGQUEUE_MAX,
_SC_TIMER_MAX,
_SC_BC_BASE_MAX,
_SC_BC_DIM_MAX,
_SC_BC_SCALE_MAX,
_SC_BC_STRING_MAX,
_SC_COLL_WEIGHTS_MAX,
_SC_EQUIV_CLASS_MAX,
_SC_EXPR_NEST_MAX,
_SC_LINE_MAX,
_SC_RE_DUP_MAX,
_SC_CHARCLASS_NAME_MAX,
_SC_2_VERSION,
_SC_2_C_BIND,
_SC_2_C_DEV,
_SC_2_FORT_DEV,
_SC_2_FORT_RUN,
_SC_2_SW_DEV,
_SC_2_LOCALEDEF,
_SC_PII,
_SC_PII_XTI,
_SC_PII_SOCKET,
_SC_PII_INTERNET,
_SC_PII_OSI,
_SC_POLL,
_SC_SELECT,
_SC_UIO_MAXIOV,
_SC_IOV_MAX = _SC_UIO_MAXIOV,
_SC_PII_INTERNET_STREAM,
_SC_PII_INTERNET_DGRAM,
_SC_PII_OSI_COTS,
_SC_PII_OSI_CLTS,
_SC_PII_OSI_M,
_SC_T_IOV_MAX,
_SC_THREADS,
_SC_THREAD_SAFE_FUNCTIONS,
_SC_GETGR_R_SIZE_MAX,
_SC_GETPW_R_SIZE_MAX,
_SC_LOGIN_NAME_MAX,
_SC_TTY_NAME_MAX,
_SC_THREAD_DESTRUCTOR_ITERATIONS,
_SC_THREAD_KEYS_MAX,
_SC_THREAD_STACK_MIN,
_SC_THREAD_THREADS_MAX,
_SC_THREAD_ATTR_STACKADDR,
_SC_THREAD_ATTR_STACKSIZE,
_SC_THREAD_PRIORITY_SCHEDULING,
_SC_THREAD_PRIO_INHERIT,
_SC_THREAD_PRIO_PROTECT,
_SC_THREAD_PROCESS_SHARED,
_SC_NPROCESSORS_CONF,
_SC_NPROCESSORS_ONLN,
_SC_PHYS_PAGES,
_SC_AVPHYS_PAGES,
_SC_ATEXIT_MAX,
_SC_PASS_MAX,
_SC_XOPEN_VERSION,
_SC_XOPEN_XCU_VERSION,
_SC_XOPEN_UNIX,
_SC_XOPEN_CRYPT,
_SC_XOPEN_ENH_I18N,
_SC_XOPEN_SHM,
_SC_2_CHAR_TERM,
_SC_2_C_VERSION,
_SC_2_UPE,
_SC_XOPEN_XPG2,
_SC_XOPEN_XPG3,
_SC_XOPEN_XPG4,
_SC_CHAR_BIT,
_SC_CHAR_MAX,
_SC_CHAR_MIN,
_SC_INT_MAX,
_SC_INT_MIN,
_SC_LONG_BIT,
_SC_WORD_BIT,
_SC_MB_LEN_MAX,
_SC_NZERO,
_SC_SSIZE_MAX,
_SC_SCHAR_MAX,
_SC_SCHAR_MIN,
_SC_SHRT_MAX,
_SC_SHRT_MIN,
_SC_UCHAR_MAX,
_SC_UINT_MAX,
_SC_ULONG_MAX,
_SC_USHRT_MAX,
_SC_NL_ARGMAX,
_SC_NL_LANGMAX,
_SC_NL_MSGMAX,
_SC_NL_NMAX,
_SC_NL_SETMAX,
_SC_NL_TEXTMAX,
_SC_XBS5_ILP32_OFF32,
_SC_XBS5_ILP32_OFFBIG,
_SC_XBS5_LP64_OFF64,
_SC_XBS5_LPBIG_OFFBIG,
_SC_XOPEN_LEGACY,
_SC_XOPEN_REALTIME,
_SC_XOPEN_REALTIME_THREADS,
_SC_ADVISORY_INFO,
_SC_BARRIERS,
_SC_BASE,
_SC_C_LANG_SUPPORT,
_SC_C_LANG_SUPPORT_R,
_SC_CLOCK_SELECTION,
_SC_CPUTIME,
_SC_THREAD_CPUTIME,
_SC_DEVICE_IO,
_SC_DEVICE_SPECIFIC,
_SC_DEVICE_SPECIFIC_R,
_SC_FD_MGMT,
_SC_FIFO,
_SC_PIPE,
_SC_FILE_ATTRIBUTES,
_SC_FILE_LOCKING,
_SC_FILE_SYSTEM,
_SC_MONOTONIC_CLOCK,
_SC_MULTI_PROCESS,
_SC_SINGLE_PROCESS,
_SC_NETWORKING,
_SC_READER_WRITER_LOCKS,
_SC_SPIN_LOCKS,
_SC_REGEXP,
_SC_REGEX_VERSION,
_SC_SHELL,
_SC_SIGNALS,
_SC_SPAWN,
_SC_SPORADIC_SERVER,
_SC_THREAD_SPORADIC_SERVER,
_SC_SYSTEM_DATABASE,
_SC_SYSTEM_DATABASE_R,
_SC_TIMEOUTS,
_SC_TYPED_MEMORY_OBJECTS,
_SC_USER_GROUPS,
_SC_USER_GROUPS_R,
_SC_2_PBS,
_SC_2_PBS_ACCOUNTING,
_SC_2_PBS_LOCATE,
_SC_2_PBS_MESSAGE,
_SC_2_PBS_TRACK,
_SC_SYMLOOP_MAX,
_SC_STREAMS,
_SC_2_PBS_CHECKPOINT,
_SC_V6_ILP32_OFF32,
_SC_V6_ILP32_OFFBIG,
_SC_V6_LP64_OFF64,
_SC_V6_LPBIG_OFFBIG,
_SC_HOST_NAME_MAX,
_SC_TRACE,
_SC_TRACE_EVENT_FILTER,
_SC_TRACE_INHERIT,
_SC_TRACE_LOG,
_SC_LEVEL1_ICACHE_SIZE,
_SC_LEVEL1_ICACHE_ASSOC,
_SC_LEVEL1_ICACHE_LINESIZE,
_SC_LEVEL1_DCACHE_SIZE,
_SC_LEVEL1_DCACHE_ASSOC,
_SC_LEVEL1_DCACHE_LINESIZE,
_SC_LEVEL2_CACHE_SIZE,
_SC_LEVEL2_CACHE_ASSOC,
_SC_LEVEL2_CACHE_LINESIZE,
_SC_LEVEL3_CACHE_SIZE,
_SC_LEVEL3_CACHE_ASSOC,
_SC_LEVEL3_CACHE_LINESIZE,
_SC_LEVEL4_CACHE_SIZE,
_SC_LEVEL4_CACHE_ASSOC,
_SC_LEVEL4_CACHE_LINESIZE,
_SC_IPV6 = _SC_LEVEL1_ICACHE_SIZE + 50,
_SC_RAW_SOCKETS
enum
_CS_PATH,
_CS_V6_WIDTH_RESTRICTED_ENVS,
_CS_GNU_LIBC_VERSION,
_CS_GNU_LIBPTHREAD_VERSION,
_CS_LFS_CFLAGS = 1000,
_CS_LFS_LDFLAGS,
_CS_LFS_LIBS,
_CS_LFS_LINTFLAGS,
_CS_LFS64_CFLAGS,
_CS_LFS64_LDFLAGS,
_CS_LFS64_LIBS,
_CS_LFS64_LINTFLAGS,
_CS_XBS5_ILP32_OFF32_CFLAGS = 1100,
_CS_XBS5_ILP32_OFF32_LDFLAGS,
_CS_XBS5_ILP32_OFF32_LIBS,
_CS_XBS5_ILP32_OFF32_LINTFLAGS,
_CS_XBS5_ILP32_OFFBIG_CFLAGS,
_CS_XBS5_ILP32_OFFBIG_LDFLAGS,
_CS_XBS5_ILP32_OFFBIG_LIBS,
_CS_XBS5_ILP32_OFFBIG_LINTFLAGS,
_CS_XBS5_LP64_OFF64_CFLAGS,
_CS_XBS5_LP64_OFF64_LDFLAGS,
_CS_XBS5_LP64_OFF64_LIBS,
_CS_XBS5_LP64_OFF64_LINTFLAGS,
_CS_XBS5_LPBIG_OFFBIG_CFLAGS,
_CS_XBS5_LPBIG_OFFBIG_LDFLAGS,
_CS_XBS5_LPBIG_OFFBIG_LIBS,
_CS_XBS5_LPBIG_OFFBIG_LINTFLAGS,
_CS_POSIX_V6_ILP32_OFF32_CFLAGS,
_CS_POSIX_V6_ILP32_OFF32_LDFLAGS,
_CS_POSIX_V6_ILP32_OFF32_LIBS,
_CS_POSIX_V6_ILP32_OFF32_LINTFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS,
_CS_POSIX_V6_ILP32_OFFBIG_LIBS,
_CS_POSIX_V6_ILP32_OFFBIG_LINTFLAGS,
_CS_POSIX_V6_LP64_OFF64_CFLAGS,
_CS_POSIX_V6_LP64_OFF64_LDFLAGS,
_CS_POSIX_V6_LP64_OFF64_LIBS,
_CS_POSIX_V6_LP64_OFF64_LINTFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS,
_CS_POSIX_V6_LPBIG_OFFBIG_LIBS,
_CS_POSIX_V6_LPBIG_OFFBIG_LINTFLAGS
#line 555 "/usr/include/unistd.h"
extern long int pathconf (const char *__path, int __name)
extern long int fpathconf (int __fd, int __name) ;
extern long int sysconf (int __name) ;
extern size_t confstr (int __name, char *__buf, size_t __len) ;
extern __pid_t getpid (void) ;
extern __pid_t getppid (void) ;
extern __pid_t getpgrp (void) ;
#line 589 "/usr/include/unistd.h"
extern __pid_t __getpgid (__pid_t __pid) ;
extern int setpgid (__pid_t __pid, __pid_t __pgid) ;
extern int setpgrp (void) ;
#line 630 "/usr/include/unistd.h"
extern __pid_t setsid (void) ;
extern __uid_t getuid (void) ;
extern __uid_t geteuid (void) ;
extern __gid_t getgid (void) ;
extern __gid_t getegid (void) ;
extern int getgroups (int __size, __gid_t __list[]) ;
extern int setuid (__uid_t __uid) ;
extern int setreuid (__uid_t __ruid, __uid_t __euid) ;
extern int seteuid (__uid_t __uid) ;
extern int setgid (__gid_t __gid) ;
extern int setregid (__gid_t __rgid, __gid_t __egid) ;
extern int setegid (__gid_t __gid) ;
#line 718 "/usr/include/unistd.h"
extern __pid_t fork (void) ;
extern __pid_t vfork (void) ;
extern char *ttyname (int __fd) ;
extern int ttyname_r (int __fd, char *__buf, size_t __buflen)
extern int isatty (int __fd) ;
extern int ttyslot (void) ;
extern int link (const char *__from, const char *__to)
#line 766 "/usr/include/unistd.h"
extern int symlink (const char *__from, const char *__to)
extern ssize_t readlink (const char * __path,
char * __buf, size_t __len)
#line 790 "/usr/include/unistd.h"
extern int unlink (const char *__name) ;
extern int rmdir (const char *__path) ;
extern __pid_t tcgetpgrp (int __fd) ;
extern int tcsetpgrp (int __fd, __pid_t __pgrp_id) ;
extern char *getlogin (void);
extern int getlogin_r (char *__name, size_t __name_len) ;
extern int setlogin (const char *__name) ;
#line 1 "/usr/include/getopt.h"
#line 48 "/usr/include/getopt.h"
extern char *optarg;
extern int optind;
extern int opterr;
extern int optopt;
#line 122 "/usr/include/getopt.h"
extern int getopt (int ___argc, char *const *___argv, const char *__shortopts)
#line 169 "/usr/include/getopt.h"
#line 838 "/usr/include/unistd.h"
extern int gethostname (char *__name, size_t __len) ;
extern int sethostname (const char *__name, size_t __len)
extern int sethostid (long int __id) ;
extern int getdomainname (char *__name, size_t __len)
extern int setdomainname (const char *__name, size_t __len)
extern int vhangup (void) ;
extern int revoke (const char *__file) ;
extern int profil (unsigned short int *__sample_buffer, size_t __size,
size_t __offset, unsigned int __scale)
extern int acct (const char *__name) ;
extern char *getusershell (void) ;
extern void endusershell (void) ;
extern void setusershell (void) ;
extern int daemon (int __nochdir, int __noclose) ;
extern int chroot (const char *__path) ;
extern char *getpass (const char *__prompt) ;
extern int fsync (int __fd);
extern long int gethostid (void);
extern void sync (void) ;
extern int getpagesize (void) ;
extern int getdtablesize (void) ;
extern int truncate (const char *__file, __off_t __length)
#line 963 "/usr/include/unistd.h"
extern int ftruncate (int __fd, __off_t __length) ;
#line 982 "/usr/include/unistd.h"
extern int brk (void *__addr) ;
extern void *sbrk (intptr_t __delta) ;
extern long int syscall (long int __sysno, ...) ;
extern int lockf (int __fd, int __cmd, __off_t __len) ;
#line 1047 "/usr/include/unistd.h"
#line 1061 "/usr/include/unistd.h"
extern int fdatasync (int __fildes);
#line 1088 "/usr/include/unistd.h"
Defined "HAVE_UNISTD_H" to "1"
TEST check from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
Checks for "header", and defines HAVE_"header" if found
Checking for header: netinet/in.h
stdout:
#line 32 "/usr/include/sys/types.h"
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
#line 221 "/usr/include/sys/types.h"
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 271 "/usr/include/sys/types.h"
struct iovec
void *iov_base;
size_t iov_len;
enum __socket_type
SOCK_STREAM = 1,
SOCK_DGRAM = 2,
SOCK_RAW = 3,
SOCK_RDM = 4,
SOCK_SEQPACKET = 5,
SOCK_PACKET = 10
struct sockaddr
char sa_data[14];
enum
MSG_OOB = 0x01,
MSG_PEEK = 0x02,
MSG_CTRUNC = 0x08,
MSG_PROXY = 0x10,
MSG_TRUNC = 0x20,
MSG_EOR = 0x80,
MSG_FIN = 0x200,
MSG_SYN = 0x400,
MSG_RST = 0x1000,
MSG_MORE = 0x8000,
struct msghdr
void *msg_name;
size_t msg_iovlen;
void *msg_control;
int msg_flags;
struct cmsghdr
size_t cmsg_len;
int cmsg_level;
int cmsg_type;
enum
SCM_RIGHTS = 0x01
struct ucred
pid_t pid;
uid_t uid;
gid_t gid;
struct linger
int l_onoff;
int l_linger;
struct osockaddr
enum
SHUT_RD = 0,
SHUT_WR,
SHUT_RDWR
int __fds[2]) ;
int __flags);
void * __optval,
enum
IPPROTO_IP = 0,
IPPROTO_ICMP = 1,
IPPROTO_IGMP = 2,
IPPROTO_IPIP = 4,
IPPROTO_TCP = 6,
IPPROTO_EGP = 8,
IPPROTO_PUP = 12,
IPPROTO_UDP = 17,
IPPROTO_IDP = 22,
IPPROTO_TP = 29,
IPPROTO_IPV6 = 41,
IPPROTO_RSVP = 46,
IPPROTO_GRE = 47,
IPPROTO_ESP = 50,
IPPROTO_AH = 51,
IPPROTO_NONE = 59,
IPPROTO_MTP = 92,
IPPROTO_ENCAP = 98,
IPPROTO_PIM = 103,
IPPROTO_COMP = 108,
IPPROTO_SCTP = 132,
IPPROTO_RAW = 255,
IPPROTO_MAX
enum
IPPORT_ECHO = 7,
IPPORT_DISCARD = 9,
IPPORT_SYSTAT = 11,
IPPORT_FTP = 21,
IPPORT_TELNET = 23,
IPPORT_SMTP = 25,
IPPORT_WHOIS = 43,
IPPORT_MTP = 57,
IPPORT_TFTP = 69,
IPPORT_RJE = 77,
IPPORT_FINGER = 79,
IPPORT_SUPDUP = 95,
struct in_addr
in_addr_t s_addr;
struct in6_addr
union
} in6_u;
struct sockaddr_in
in_port_t sin_port;
struct sockaddr_in6
struct ip_mreq
struct ipv6_mreq
struct group_req
struct ip_msfilter
struct group_filter
uint32_t gf_fmode;
uint32_t gf_numsrc;
struct ip_opts
char ip_opts[40];
struct ip_mreqn
int imr_ifindex;
struct in_pktinfo
int ipi_ifindex;
static unsigned int
struct in6_pktinfo
struct ip6_mtuinfo
uint32_t ip6m_mtu;
Defined "HAVE_NETINET_IN_H" to "1"
TEST checkRecursiveMacros from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:218)
TESTING: checkRecursiveMacros from config.headers(config/BuildSystem/config/headers.py:218)
Checks that the preprocessor allows recursive macros, and if not defines HAVE_BROKEN_RECURSIVE_MACRO
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
void a(int i, int j) {}
#define a(b) a(b,__LINE__)
int main() {
a(0);
return 0;
TEST configureCacheDetails from config.utilities.cacheDetails(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/cacheDetails.py:78)
TESTING: configureCacheDetails from config.utilities.cacheDetails(config/BuildSystem/config/utilities/cacheDetails.py:78)
Try to determine the size and associativity of the cache.
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <unistd.h>
long getconf_LEVEL1_DCACHE_SIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_SIZE); return (16 <= val && val <= 2147483647) ? val : 32768; }
int main() {
return 0;
Popping language C
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest.c
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_SIZE()); fclose(output);;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails/conftest
Popping language C
Defined "LEVEL1_DCACHE_SIZE" to "32768"
Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_LINESIZE() { long val = sysconf(_SC_LEVEL1_DCACHE_LINESIZE); return (16 <= val && val <= 2147483647) ? val : 32; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_LINESIZE()); fclose(output);;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "LEVEL1_DCACHE_LINESIZE" to "32"
Pushing language C
Successful compile:
Source:
#include <stdio.h>
#include <unistd.h>
long getconf_LEVEL1_DCACHE_ASSOC() { long val = sysconf(_SC_LEVEL1_DCACHE_ASSOC); return (0 <= val && val <= 2147483647) ? val : 2; }
int main() {
FILE *output = fopen("conftestval","w"); if (!output) return 1; fprintf(output,"%ld",getconf_LEVEL1_DCACHE_ASSOC()); fclose(output);;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "LEVEL1_DCACHE_ASSOC" to "0"
TEST check_siginfo_t from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:46)
TESTING: check_siginfo_t from config.types(config/BuildSystem/config/types.py:46)
Checks if siginfo_t exists in signal.h. This check is for windows, and C89 check.
Checking for type: siginfo_t
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c
Possible ERROR while running compiler:
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 13: warning: variable "a" was declared but never referenced
siginfo_t a;;
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#include<signal.h>
#endif
int main() {
siginfo_t a;;
return 0;
siginfo_t found
Defined "HAVE_SIGINFO_T" to "1"
TEST check__int64 from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:52)
TESTING: check__int64 from config.types(config/BuildSystem/config/types.py:52)
Checks if __int64 exists. This is primarily for windows.
Checking for type: __int64
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 13: error: identifier "__int64" is undefined
__int64 a;;
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c".
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
__int64 a;;
return 0;
__int64 found
TEST checkSizeTypes from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:58)
TESTING: checkSizeTypes from config.types(config/BuildSystem/config/types.py:58)
Checks for types associated with sizes, such as size_t.
Checking for type: size_t
stderr:
size_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
size_t a;;
return 0;
size_t found
TEST checkFileTypes from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:68)
TESTING: checkFileTypes from config.types(config/BuildSystem/config/types.py:68)
Checks for types associated with files, such as mode_t, off_t, etc.
Checking for type: mode_t
stderr:
mode_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
mode_t a;;
return 0;
mode_t found
Checking for type: off_t
stderr:
off_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
off_t a;;
return 0;
off_t found
TEST checkIntegerTypes from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:63)
TESTING: checkIntegerTypes from config.types(config/BuildSystem/config/types.py:63)
Checks for types associated with integers, such as int32_t.
Checking for type: int32_t
stderr:
int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
return 0;
int32_t found
TEST checkPID from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:74)
TESTING: checkPID from config.types(config/BuildSystem/config/types.py:74)
Checks for pid_t, and defines it if necessary
Checking for type: pid_t
stderr:
pid_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
pid_t a;;
return 0;
pid_t found
TEST checkUID from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:78)
TESTING: checkUID from config.types(config/BuildSystem/config/types.py:78)
Checks for uid_t and gid_t, and defines them if necessary
Source:
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
typedef char int8_t;
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
} fd_set;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c"
TEST checkSignal from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:85)
TESTING: checkSignal from config.types(config/BuildSystem/config/types.py:85)
Checks the return type of signal() and defines RETSIGTYPE to that type name
Successful compile:
Source:
#include <signal.h>
#ifdef signal
#undef signal
#endif
#ifdef __cplusplus
extern "C" void (*signal (int, void(*)(int)))(int);
#else
void (*signal())();
#endif
int main() {
return 0;
Defined "RETSIGTYPE" to "void"
TEST checkC99Complex from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:106)
TESTING: checkC99Complex from config.types(config/BuildSystem/config/types.py:106)
Check for complex numbers in in C99 std
Note that since PETSc source code uses _Complex we test specifically for that, not complex
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 6: warning: variable "x" was set but never used
double _Complex x;
Source:
#include <complex.h>
int main() {
double _Complex x;
x = I;
return 0;
stderr:
double _Complex x;
Source:
int main() {
double _Complex x;
x = I;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_C99_COMPLEX" to "1"
TEST checkCxxComplex from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:117)
TESTING: checkCxxComplex from config.types(config/BuildSystem/config/types.py:117)
Check for complex numbers in namespace std
Pushing language Cxx
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.cc
Successful compile:
Source:
#include <complex>
int main() {
std::complex<double> x;
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_CXX_COMPLEX" to "1"
Popping language Cxx
TEST checkFortranKind from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:138)
TESTING: checkFortranKind from config.types(config/BuildSystem/config/types.py:138)
Checks whether selected_int_kind etc work USE_FORTRANKIND
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.F
stderr:
Fortran diagnostic messages: program name(main)
jwd2006i-i "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.F", line 3: 'i' is declared but never referenced.
jwd2006i-i "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.F", line 4: 'd' is declared but never referenced.
Source:
program main
integer(kind=selected_int_kind(10)) i
real(kind=selected_real_kind(10)) d
end
Defined "USE_FORTRANKIND" to "1"
Popping language FC
TEST checkConst from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:150)
TESTING: checkConst from config.types(config/BuildSystem/config/types.py:150)
Checks for working const, and if not found defines it to empty string
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 25: warning: variable "x" is used before its value is set
if (x[0]);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 30: warning: variable "t" is used before its value is set
*t++ = 0;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 46: warning: variable "b" is used before its value is set
struct s *b; b->j = 5;
Source:
int main() {
/* Ultrix mips cc rejects this. */
typedef int charset[2]; const charset x;
/* SunOS 4.1.1 cc rejects this. */
char const *const *ccp;
char **p;
/* NEC SVR4.0.2 mips cc rejects this. */
struct point {int x, y;};
static struct point const zero = {0,0};
/* AIX XL C 1.02.0.0 rejects this.
It does not let you subtract one const X* pointer from another in an arm
of an if-expression whose if-part is not a constant expression */
const char *g = "string";
ccp = &g + (g ? g-g : 0);
/* HPUX 7.0 cc rejects these. */
++ccp;
p = (char**) ccp;
ccp = (char const *const *) p;
/* This section avoids unused variable warnings */
if (zero.x);
if (x[0]);
{ /* SCO 3.2v4 cc rejects this. */
char *t;
char const *s = 0 ? (char *) 0 : (char const *) 0;
*t++ = 0;
if (*s);
{ /* Someone thinks the Sun supposedly-ANSI compiler will reject this. */
int x[] = {25, 17};
const int *foo = &x[0];
++foo;
{ /* Sun SC1.0 ANSI compiler rejects this -- but not the above. */
typedef const int *iptr;
iptr p = 0;
++p;
{ /* AIX XL C 1.02.0.0 rejects this saying
"k.c", line 2.27: 1506-025 (S) Operand must be a modifiable lvalue. */
struct s { int j; const int *ap[3]; };
{ /* ULTRIX-32 V3.1 (Rev 9) vcc rejects this */
const int foo = 10;
/* Get rid of unused variable warning */
if (foo);
return 0;
TEST checkEndian from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:206)
TESTING: checkEndian from config.types(config/BuildSystem/config/types.py:206)
If the machine is big endian, defines WORDS_BIGENDIAN
Defined "WORDS_BIGENDIAN" to "1"
TEST checkSizeof from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:259)
TESTING: checkSizeof from config.types(config/BuildSystem/config/types.py:259)
Determines the size of type "typeName", and defines SIZEOF_"typeName" to be the size
Checking for size of type: char
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(char));
return 0;
Pushing language C
Popping language C
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest
Popping language C
Defined "SIZEOF_CHAR" to "1"
Checking for size of type: void *
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(void *));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_VOID_P" to "8"
Checking for size of type: short
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(short));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_SHORT" to "2"
Checking for size of type: int
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(int));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_INT" to "4"
Checking for size of type: long
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_LONG" to "8"
Checking for size of type: long long
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(long long));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_LONG_LONG" to "8"
Checking for size of type: float
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(float));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_FLOAT" to "4"
Checking for size of type: double
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(double));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_DOUBLE" to "8"
Checking for size of type: size_t
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(size_t));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_SIZE_T" to "8"
TEST checkBitsPerByte from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:310)
TESTING: checkBitsPerByte from config.types(config/BuildSystem/config/types.py:310)
Determine the nubmer of bits per byte and define BITS_PER_BYTE
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#endif
int main() {
char val[2];
int i = 0;
if (!f) exit(1);
val[0]='\1';
val[1]='\0';
while(val[0]) {val[0] <<= 1; i++;}
fprintf(f, "%d\n", i);
return 0;
Pushing language C
Popping language C
Defined "BITS_PER_BYTE" to "8"
TEST checkVisibility from config.types(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/types.py:356)
TESTING: checkVisibility from config.types(config/BuildSystem/config/types.py:356)
TEST configureMemAlign from PETSc.options.memAlign(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/memAlign.py:30)
TESTING: configureMemAlign from PETSc.options.memAlign(config/PETSc/options/memAlign.py:30)
Choose alignment
Defined "MEMALIGN" to "16"
Memory alignment is 16
TEST check from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [socket] in library ['socket', 'nsl'] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char socket();
static void _check_socket() { socket(); }
int main() {
_check_socket();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lsocket -lnsl -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lsocket
Popping language C
Checking for functions [handle_sigfpes] in library ['fpe'] []
Pushing language C
Successful compile:
Source:
char handle_sigfpes();
static void _check_handle_sigfpes() { handle_sigfpes(); }
int main() {
_check_handle_sigfpes();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lfpe -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
/usr/bin/ld: cannot find -lfpe
Popping language C
Pushing language C
Successful compile:
Source:
char socket();
int main() {
_check_socket();;
return 0;
Pushing language C
Popping language C
stderr:
Popping language C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
stderr:
Popping language C
TEST checkMath from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:251)
TESTING: checkMath from config.libraries(config/BuildSystem/config/libraries.py:251)
Check for sin() in libm, the math library
Checking for functions [sin floor log10 pow] in library [''] []
Pushing language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 5: warning: variable "y" was set but never used
static void _check_sin() { double x = 0,y; y = sin(x);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 8: warning: variable "y" was set but never used
static void _check_floor() { double x = 0,y; y = floor(x);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 11: warning: variable "y" was set but never used
static void _check_log10() { double x = 0,y; y = log10(x);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 14: warning: variable "y" was set but never used
static void _check_pow() { double x = 0,y ; y = pow(x, x);
Source:
double sin(double);
double floor(double);
double log10(double);
double pow(double, double);
int main() {
_check_sin();
_check_floor();
_check_log10();
_check_pow();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Math functions are linked in by default
TEST checkMathErf from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:267)
TESTING: checkMathErf from config.libraries(config/BuildSystem/config/libraries.py:267)
Check for erf() in libm, the math library
Checking for functions [erf] in library [] []
Pushing language C
stderr:
static void _check_erf() { double x = 0,y; y = erf(x);
Source:
double erf(double);
int main() {
_check_erf();;
return 0;
Pushing language C
Popping language C
Popping language C
erf() found
Defined "HAVE_ERF" to "1"
TEST checkMathTgamma from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:276)
TESTING: checkMathTgamma from config.libraries(config/BuildSystem/config/libraries.py:276)
Check for tgama() in libm, the math library
Checking for functions [tgamma] in library [] []
Pushing language C
stderr:
static void _check_tgamma() { double x = 0,y; y = tgamma(x);
Source:
double tgamma(double);
int main() {
_check_tgamma();;
return 0;
Pushing language C
Popping language C
Popping language C
tgamma() found
Defined "HAVE_TGAMMA" to "1"
TEST checkMathFenv from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:285)
TESTING: checkMathFenv from config.libraries(config/BuildSystem/config/libraries.py:285)
Checks if <fenv.h> can be used with FE_DFL_ENV
Checking for functions [fesetenv] in library [] []
Pushing language C
Successful compile:
Source:
#include <fenv.h>
static void _check_fesetenv() { fesetenv(FE_DFL_ENV);; }
int main() {
_check_fesetenv();;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "HAVE_FENV_H" to "1"
TEST checkMathLog2 from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:293)
TESTING: checkMathLog2 from config.libraries(config/BuildSystem/config/libraries.py:293)
Check for log2() in libm, the math library
Checking for functions [log2] in library [] []
Pushing language C
stderr:
static void _check_log2() { double x = 1,y; y = log2(x);
Source:
double log2(double);
int main() {
_check_log2();;
return 0;
Pushing language C
Popping language C
Popping language C
log2() found
Defined "HAVE_LOG2" to "1"
TEST checkCompression from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:302)
TESTING: checkCompression from config.libraries(config/BuildSystem/config/libraries.py:302)
Check for libz, the compression library
Checking for functions [compress uncompress] in library [''] []
Pushing language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 5: warning: variable "ret" was set but never used
static void _check_compress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = compress(dest, &destLen, source, sourceLen);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 8: warning: variable "ret" was set but never used
static void _check_uncompress() { char *dest = 0; const char *source = 0; unsigned long destLen = 0, sourceLen = 0; int ret = 0; ret = uncompress(dest, &destLen, source, sourceLen);
Source:
int compress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int uncompress(char *dest, unsigned long *destLen, const char *source, unsigned long sourceLen);
int main() {
_check_compress();
_check_uncompress();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_compress':
conftest.c:(.text+0x48): undefined reference to `compress'
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_uncompress':
conftest.c:(.text+0xa8): undefined reference to `uncompress'
Popping language C
Checking for functions [compress uncompress] in library ['z'] []
Pushing language C
stderr:
Source:
int main() {
_check_compress();
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lz -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_LIBZ" to "1"
Popping language C
Using libz for the compression library
TEST checkRealtime from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:323)
TESTING: checkRealtime from config.libraries(config/BuildSystem/config/libraries.py:323)
Check for presence of clock_gettime() in realtime library (POSIX Realtime extensions)
Checking for functions [clock_gettime] in library [''] []
Pushing language C
Successful compile:
Source:
#include <time.h>
static void _check_clock_gettime() { struct timespec tp; clock_gettime(CLOCK_REALTIME,&tp);; }
int main() {
_check_clock_gettime();;
return 0;
Pushing language C
Popping language C
Popping language C
realtime functions are linked in by default
TEST checkDynamic from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:339)
TESTING: checkDynamic from config.libraries(config/BuildSystem/config/libraries.py:339)
Check for the header and libraries necessary for dynamic library manipulation
Checking for functions [dlopen] in library ['dl'] []
Pushing language C
Successful compile:
Source:
char dlopen();
static void _check_dlopen() { dlopen(); }
int main() {
_check_dlopen();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ldl -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_LIBDL" to "1"
Popping language C
Checking for header: dlfcn.h
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/dlfcn.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 25 "/usr/include/dlfcn.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 27 "/usr/include/dlfcn.h"
#line 1 "/usr/include/bits/dlfcn.h"
#line 30 "/usr/include/dlfcn.h"
#line 52 "/usr/include/dlfcn.h"
extern void *dlopen (const char *__file, int __mode) ;
extern int dlclose (void *__handle) ;
extern void *dlsym (void * __handle,
const char * __name) ;
#line 80 "/usr/include/dlfcn.h"
extern char *dlerror (void) ;
#line 188 "/usr/include/dlfcn.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Defined "HAVE_DLFCN_H" to "1"
TEST configureLibraryOptions from PETSc.options.libraryOptions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/libraryOptions.py:37)
TESTING: configureLibraryOptions from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:37)
Sets PETSC_USE_DEBUG, PETSC_USE_INFO, PETSC_USE_LOG, PETSC_USE_CTABLE and PETSC_USE_FORTRAN_KERNELS
Defined "USE_LOG" to "1"
Defined "USE_DEBUG" to "1"
Defined "USE_INFO" to "1"
Defined "USE_CTABLE" to "1"
**********Checking if running on BGL/IBM detected
Checking for functions [bgl_perfctr_void] in library [''] []
Pushing language C
Successful compile:
Source:
char bgl_perfctr_void();
static void _check_bgl_perfctr_void() { bgl_perfctr_void(); }
int main() {
_check_bgl_perfctr_void();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_bgl_perfctr_void':
conftest.c:(.text+0x4): undefined reference to `bgl_perfctr_void'
Popping language C
Checking for functions [ADIOI_BGL_Open] in library [''] []
Pushing language C
Successful compile:
Source:
char ADIOI_BGL_Open();
static void _check_ADIOI_BGL_Open() { ADIOI_BGL_Open(); }
int main() {
_check_ADIOI_BGL_Open();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_ADIOI_BGL_Open':
conftest.c:(.text+0x4): undefined reference to `ADIOI_BGL_Open'
Popping language C
*********BGL/IBM test failure
Defined "USE_BACKWARD_LOOP" to "1"
Defined "Alignx(a,b)" to " "
TEST configureISColorValueType from PETSc.options.libraryOptions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/libraryOptions.py:87)
TESTING: configureISColorValueType from PETSc.options.libraryOptions(config/PETSc/options/libraryOptions.py:87)
Sets PETSC_IS_COLOR_VALUE_TYPE, MPIU_COLORING_VALUE, IS_COLORING_MAX required by ISColor
Defined "MPIU_COLORING_VALUE" to "MPI_UNSIGNED_SHORT"
Defined "IS_COLORING_MAX" to "65535"
Defined "IS_COLOR_VALUE_TYPE" to "short"
Defined "IS_COLOR_VALUE_TYPE_SIZE" to "PETSC_SIZEOF_SHORT"
TEST configureCPURelax from config.atomics(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/atomics.py:17)
TESTING: configureCPURelax from config.atomics(config/BuildSystem/config/atomics.py:17)
Definitions for cpu relax assembly instructions
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
.//FCCpMjRiH.s: Assembler messages:
.//FCCpMjRiH.s:15: Error: Unknown opcode: `rep'
Source:
int main() {
asm volatile("rep; nop" ::: "memory");;
return 0;
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.c", line 5: error: identifier "HMT_low" is undefined
do { HMT_low; HMT_medium; __asm__ __volatile__ ("":::"memory"); } while (0);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.c", line 5: error: identifier "HMT_medium" is undefined
2 errors detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics/conftest.c".
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
__asm__ __volatile__ ("":::"memory");;
return 0;
Defined "CPU_RELAX()" to "__asm__ __volatile__ ("":::"memory")"
TEST configureMemoryBarriers from config.atomics(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/atomics.py:36)
TESTING: configureMemoryBarriers from config.atomics(config/BuildSystem/config/atomics.py:36)
Definitions for memory barrier instructions
stderr:
.//FCCCrePQf.s: Assembler messages:
.//FCCCrePQf.s:15: Error: Unknown opcode: `mfence'
Source:
int main() {
asm volatile("mfence":::"memory");
return 0;
stderr:
.//FCCyVCPFq.s: Assembler messages:
.//FCCyVCPFq.s:15: Error: Unknown opcode: `lfence'
Source:
int main() {
asm volatile("lfence":::"memory");
return 0;
stderr:
.//FCCshCCwG.s: Assembler messages:
.//FCCshCCwG.s:15: Error: Unknown opcode: `sfence'
Source:
int main() {
asm volatile("sfence":::"memory");
return 0;
TEST checkMemcmp from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:110)
TESTING: checkMemcmp from config.functions(config/BuildSystem/config/functions.py:110)
Check for 8-bit clean memcmp
Making executable to test memcmp()
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c
Successful compile:
Source:
#include <string.h>
void exit(int);
int main() {
char c0 = 0x40;
char c1 = (char) 0x80;
char c2 = (char) 0x81;
exit(memcmp(&c0, &c2, 1) < 0 && memcmp(&c1, &c2, 1) < 0 ? 0 : 1);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest
TEST checkSysinfo from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:135)
TESTING: checkSysinfo from config.functions(config/BuildSystem/config/functions.py:135)
Check whether sysinfo takes three arguments, and if it does define HAVE_SYSINFO_3ARG
Checking for functions [sysinfo]
Successful compile:
Source:
/* System header to define __stub macros and hopefully no other prototypes since they would conflict with our 'char funcname()' declaration below. */
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char sysinfo();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_sysinfo) || defined (__stub___sysinfo)
sysinfo_will_always_fail_with_ENOSYS();
#else
sysinfo();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SYSINFO" to "1"
Checking for header: linux/kernel.h
stdout:
#line 1 "/usr/include/linux/kernel.h"
struct sysinfo {
long uptime;
unsigned long loads[3];
unsigned long totalram;
unsigned long freeram;
unsigned long sharedram;
unsigned long bufferram;
unsigned long totalswap;
unsigned long freeswap;
unsigned short procs;
unsigned short pad;
unsigned long totalhigh;
unsigned long freehigh;
unsigned int mem_unit;
char _f[20-2*sizeof(long)-sizeof(int)];
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_LINUX_KERNEL_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
#line 1 "/usr/include/sys/sysinfo.h"
#line 23 "/usr/include/sys/sysinfo.h"
struct sysinfo {
long uptime;
unsigned short pad;
#line 26 "/usr/include/sys/sysinfo.h"
extern int sysinfo (struct sysinfo *__info) ;
extern int get_nprocs_conf (void) ;
extern int get_nprocs (void) ;
extern long int get_phys_pages (void) ;
extern long int get_avphys_pages (void) ;
Defined "HAVE_SYS_SYSINFO_H" to "1"
Checking for header: sys/systeminfo.h
stdout:
Possible ERROR while running preprocessor: exit code 512
stdout:
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h"
#include <sys/systeminfo.h>
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sys/systeminfo.h" #include <sys/systeminfo.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Possible ERROR while running compiler: exit code 1024
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 13: catastrophic error: #error directive: "Cannot check sysinfo without special headers"
# error "Cannot check sysinfo without special headers"
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c".
Compilation terminated.
Source:
#ifdef HAVE_LINUX_KERNEL_H
# include <linux/kernel.h>
# include <linux/sys.h>
# ifdef HAVE_SYS_SYSINFO_H
# include <sys/sysinfo.h>
# endif
#elif defined(HAVE_SYS_SYSTEMINFO_H)
# include <sys/systeminfo.h>
#else
#endif
int main() {
char buf[10]; long count=10; sysinfo(1, buf, count);
return 0;
Compile failed inside link
TEST checkVPrintf from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:158)
TESTING: checkVPrintf from config.functions(config/BuildSystem/config/functions.py:158)
Checks whether vprintf requires a char * last argument, and if it does defines HAVE_VPRINTF_CHAR
Checking for functions [vprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vprintf) || defined (__stub___vprintf)
vprintf_will_always_fail_with_ENOSYS();
#else
vprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_VPRINTF" to "1"
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 8: warning: variable "Argp" is used before its value is set
vprintf( "%d", Argp );
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
return 0;
Pushing language C
Popping language C
TEST checkVFPrintf from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:165)
TESTING: checkVFPrintf from config.functions(config/BuildSystem/config/functions.py:165)
Checks whether vfprintf requires a char * last argument, and if it does defines HAVE_VFPRINTF_CHAR
Checking for functions [vfprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vfprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vfprintf) || defined (__stub___vfprintf)
vfprintf_will_always_fail_with_ENOSYS();
#else
vfprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_VFPRINTF" to "1"
stderr:
vfprintf(stdout, "%d", Argp );
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;
return 0;
Pushing language C
Popping language C
TEST checkVSNPrintf from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:172)
TESTING: checkVSNPrintf from config.functions(config/BuildSystem/config/functions.py:172)
Checks whether vsnprintf requires a char * last argument, and if it does defines HAVE_VSNPRINTF_CHAR
Successful compile:
Source:
#include <stdio.h>
int main() {
_vsnprintf(0,0,0,0);
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o: In function `main':
conftest.c:(.text+0x34): undefined reference to `_vsnprintf'
Checking for functions [vsnprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char vsnprintf();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_vsnprintf) || defined (__stub___vsnprintf)
vsnprintf_will_always_fail_with_ENOSYS();
#else
vsnprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_VSNPRINTF" to "1"
stderr:
vsnprintf(str,5, "%d", Argp );
Source:
#include <stdio.h>
#include <stdarg.h>
int main() {
va_list Argp;char str[6];
return 0;
Pushing language C
Popping language C
TEST checkNanosleep from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:206)
TESTING: checkNanosleep from config.functions(config/BuildSystem/config/functions.py:206)
Check for functional nanosleep() - as time.h behaves differently for different compiler flags - like -std=c89
Successful compile:
Source:
#include <time.h>
int main() {
struct timespec tp;
tp.tv_sec = 0;
tp.tv_nsec = (long)(1e9);
nanosleep(&tp,0);
return 0;
Pushing language C
Popping language C
Defined "HAVE_NANOSLEEP" to "1"
TEST checkSignalHandlerType from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:182)
TESTING: checkSignalHandlerType from config.functions(config/BuildSystem/config/functions.py:182)
Checks the type of C++ signals handlers, and defines SIGNAL_CAST to the correct value
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.cc
Successful compile:
Source:
#include <signal.h>
static void myhandler(int sig) {}
int main() {
signal(SIGFPE,myhandler);
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "SIGNAL_CAST" to " "
TEST checkFreeReturnType from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:192)
TESTING: checkFreeReturnType from config.functions(config/BuildSystem/config/functions.py:192)
Checks whether free returns void or int, and defines HAVE_FREE_RETURN_INT
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 6: warning: variable "p" is used before its value is set
int ierr; void *p; ierr = free(p); return 0;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 6: error: a value of type "void" cannot be assigned to an entity of type "int"
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 8: warning: statement is unreachable
return 0;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 6: warning: variable "ierr" was set but never used
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c".
Source:
#include <stdlib.h>
int main() {
return 0;
TEST checkVariableArgumentLists from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:198)
TESTING: checkVariableArgumentLists from config.functions(config/BuildSystem/config/functions.py:198)
Checks whether the variable argument list functionality is working
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 7: warning: variable "l2" is used before its value is set
va_copy(l1, l2);
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 10: warning: statement is unreachable
return 0;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 6: warning: variable "l1" was set but never used
va_list l1, l2;
Source:
#include <stdarg.h>
int main() {
va_list l1, l2;
va_copy(l1, l2);
return 0;
return 0;
Pushing language C
Popping language C
Defined "HAVE_VA_COPY" to "1"
TEST checkClassify from config.functions(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/functions.py:89)
TESTING: checkClassify from config.functions(config/BuildSystem/config/functions.py:89)
Recursive decompose to rapidly classify functions as found or missing
To confirm that a function is missing, we require a compile/link
failure with only that function in a compilation unit. In contrast,
we can confirm that many functions are present by compiling them all
together in a large compilation unit. We optimistically compile
everything together, then trim all functions that were named in the
error message and bisect the result. The trimming is only an
optimization to increase the likelihood of a big-batch compile
succeeding; we do not rely on the compiler naming missing functions.
Checking for functions [rand getdomainname _sleep snprintf realpath dlsym bzero _getcwd getwd uname _lseek sleep _access lseek usleep dlclose gethostname clock get_nprocs access _snprintf dlerror mkstemp fork getpagesize sbreak memalign sigset getcwd gethostbyname gettimeofday readlink _set_output_format PXFGETARG sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time sysctlbyname stricmp]
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char getdomainname();
char _sleep();
char snprintf();
char realpath();
char dlsym();
char bzero();
char _getcwd();
char getwd();
char uname();
char _lseek();
char sleep();
char _access();
char lseek();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char access();
char _snprintf();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
char sbreak();
char memalign();
char sigset();
char getcwd();
char gethostbyname();
char gettimeofday();
char readlink();
char _set_output_format();
char PXFGETARG();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
char sysctlbyname();
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_rand) || defined (__stub___rand)
rand_will_always_fail_with_ENOSYS();
#else
rand();
#endif
#if defined (__stub_getdomainname) || defined (__stub___getdomainname)
getdomainname_will_always_fail_with_ENOSYS();
#else
getdomainname();
#endif
#if defined (__stub__sleep) || defined (__stub____sleep)
_sleep_will_always_fail_with_ENOSYS();
#else
_sleep();
#endif
#if defined (__stub_snprintf) || defined (__stub___snprintf)
#else
snprintf();
#endif
#if defined (__stub_realpath) || defined (__stub___realpath)
realpath_will_always_fail_with_ENOSYS();
#else
realpath();
#endif
#if defined (__stub_dlsym) || defined (__stub___dlsym)
dlsym_will_always_fail_with_ENOSYS();
#else
dlsym();
#endif
#if defined (__stub_bzero) || defined (__stub___bzero)
bzero_will_always_fail_with_ENOSYS();
#else
bzero();
#endif
#if defined (__stub__getcwd) || defined (__stub____getcwd)
_getcwd_will_always_fail_with_ENOSYS();
#else
_getcwd();
#endif
#if defined (__stub_getwd) || defined (__stub___getwd)
getwd_will_always_fail_with_ENOSYS();
#else
getwd();
#endif
#if defined (__stub_uname) || defined (__stub___uname)
uname_will_always_fail_with_ENOSYS();
#else
uname();
#endif
#if defined (__stub__lseek) || defined (__stub____lseek)
_lseek_will_always_fail_with_ENOSYS();
#else
_lseek();
#endif
#if defined (__stub_sleep) || defined (__stub___sleep)
#else
sleep();
#endif
#if defined (__stub__access) || defined (__stub____access)
_access_will_always_fail_with_ENOSYS();
#else
_access();
#endif
#if defined (__stub_lseek) || defined (__stub___lseek)
#else
lseek();
#endif
#if defined (__stub_usleep) || defined (__stub___usleep)
usleep_will_always_fail_with_ENOSYS();
#else
usleep();
#endif
#if defined (__stub_dlclose) || defined (__stub___dlclose)
dlclose_will_always_fail_with_ENOSYS();
#else
dlclose();
#endif
#if defined (__stub_gethostname) || defined (__stub___gethostname)
gethostname_will_always_fail_with_ENOSYS();
#else
gethostname();
#endif
#if defined (__stub_clock) || defined (__stub___clock)
clock_will_always_fail_with_ENOSYS();
#else
clock();
#endif
#if defined (__stub_get_nprocs) || defined (__stub___get_nprocs)
get_nprocs_will_always_fail_with_ENOSYS();
#else
get_nprocs();
#endif
#if defined (__stub_access) || defined (__stub___access)
#else
access();
#endif
#if defined (__stub__snprintf) || defined (__stub____snprintf)
_snprintf_will_always_fail_with_ENOSYS();
#else
_snprintf();
#endif
#if defined (__stub_dlerror) || defined (__stub___dlerror)
dlerror_will_always_fail_with_ENOSYS();
#else
dlerror();
#endif
#if defined (__stub_mkstemp) || defined (__stub___mkstemp)
mkstemp_will_always_fail_with_ENOSYS();
#else
mkstemp();
#endif
#if defined (__stub_fork) || defined (__stub___fork)
fork_will_always_fail_with_ENOSYS();
#else
fork();
#endif
#if defined (__stub_getpagesize) || defined (__stub___getpagesize)
getpagesize_will_always_fail_with_ENOSYS();
#else
getpagesize();
#endif
#if defined (__stub_sbreak) || defined (__stub___sbreak)
sbreak_will_always_fail_with_ENOSYS();
#else
sbreak();
#endif
#if defined (__stub_memalign) || defined (__stub___memalign)
memalign_will_always_fail_with_ENOSYS();
#else
memalign();
#endif
#if defined (__stub_sigset) || defined (__stub___sigset)
sigset_will_always_fail_with_ENOSYS();
#else
sigset();
#endif
#if defined (__stub_getcwd) || defined (__stub___getcwd)
#else
getcwd();
#endif
#if defined (__stub_gethostbyname) || defined (__stub___gethostbyname)
gethostbyname_will_always_fail_with_ENOSYS();
#else
gethostbyname();
#endif
#if defined (__stub_gettimeofday) || defined (__stub___gettimeofday)
gettimeofday_will_always_fail_with_ENOSYS();
#else
gettimeofday();
#endif
#if defined (__stub_readlink) || defined (__stub___readlink)
readlink_will_always_fail_with_ENOSYS();
#else
readlink();
#endif
#if defined (__stub__set_output_format) || defined (__stub____set_output_format)
_set_output_format_will_always_fail_with_ENOSYS();
#else
#endif
#if defined (__stub_PXFGETARG) || defined (__stub___PXFGETARG)
PXFGETARG_will_always_fail_with_ENOSYS();
#else
PXFGETARG();
#endif
#if defined (__stub_sigaction) || defined (__stub___sigaction)
sigaction_will_always_fail_with_ENOSYS();
#else
sigaction();
#endif
#if defined (__stub_strcasecmp) || defined (__stub___strcasecmp)
strcasecmp_will_always_fail_with_ENOSYS();
#else
strcasecmp();
#endif
#if defined (__stub_dlopen) || defined (__stub___dlopen)
dlopen_will_always_fail_with_ENOSYS();
#else
dlopen();
#endif
#if defined (__stub_drand48) || defined (__stub___drand48)
drand48_will_always_fail_with_ENOSYS();
#else
drand48();
#endif
#if defined (__stub_socket) || defined (__stub___socket)
socket_will_always_fail_with_ENOSYS();
#else
socket();
#endif
#if defined (__stub_memmove) || defined (__stub___memmove)
memmove_will_always_fail_with_ENOSYS();
#else
memmove();
#endif
#if defined (__stub_signal) || defined (__stub___signal)
signal_will_always_fail_with_ENOSYS();
#else
signal();
#endif
#if defined (__stub_popen) || defined (__stub___popen)
popen_will_always_fail_with_ENOSYS();
#else
popen();
#endif
#if defined (__stub_getrusage) || defined (__stub___getrusage)
getrusage_will_always_fail_with_ENOSYS();
#else
getrusage();
#endif
#if defined (__stub_times) || defined (__stub___times)
times_will_always_fail_with_ENOSYS();
#else
times();
#endif
#if defined (__stub_time) || defined (__stub___time)
time_will_always_fail_with_ENOSYS();
#else
time();
#endif
#if defined (__stub_sysctlbyname) || defined (__stub___sysctlbyname)
sysctlbyname_will_always_fail_with_ENOSYS();
#else
sysctlbyname();
#endif
#if defined (__stub_stricmp) || defined (__stub___stricmp)
stricmp_will_always_fail_with_ENOSYS();
#else
stricmp();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x64): warning: the `getwd' function is dangerous and should not be used.
conftest.c:(.text+0x1c): undefined reference to `_sleep'
conftest.c:(.text+0x58): undefined reference to `_getcwd'
conftest.c:(.text+0x7c): undefined reference to `_lseek'
conftest.c:(.text+0x94): undefined reference to `_access'
conftest.c:(.text+0xf4): undefined reference to `_snprintf'
conftest.c:(.text+0x130): undefined reference to `sbreak'
conftest.c:(.text+0x184): undefined reference to `_set_output_format'
conftest.c:(.text+0x190): undefined reference to `PXFGETARG'
conftest.c:(.text+0x220): undefined reference to `sysctlbyname'
conftest.c:(.text+0x22c): undefined reference to `stricmp'
Checking for functions [rand getdomainname realpath dlsym bzero uname usleep dlclose gethostname clock get_nprocs dlerror mkstemp fork getpagesize]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char rand();
char realpath();
char dlsym();
char bzero();
char uname();
char usleep();
char dlclose();
char gethostname();
char clock();
char get_nprocs();
char dlerror();
char mkstemp();
char fork();
char getpagesize();
#ifdef __cplusplus
#endif
int main() {
#else
rand();
#endif
#else
getdomainname();
#endif
#else
realpath();
#endif
#else
dlsym();
#endif
#else
bzero();
#endif
#else
uname();
#endif
#else
usleep();
#endif
#else
dlclose();
#endif
#else
gethostname();
#endif
#else
clock();
#endif
#else
get_nprocs();
#endif
#else
dlerror();
#endif
#else
mkstemp();
#endif
#else
fork();
#endif
#else
getpagesize();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_RAND" to "1"
Defined "HAVE_GETDOMAINNAME" to "1"
Defined "HAVE_REALPATH" to "1"
Defined "HAVE_DLSYM" to "1"
Defined "HAVE_BZERO" to "1"
Defined "HAVE_UNAME" to "1"
Defined "HAVE_USLEEP" to "1"
Defined "HAVE_DLCLOSE" to "1"
Defined "HAVE_GETHOSTNAME" to "1"
Defined "HAVE_CLOCK" to "1"
Defined "HAVE_GET_NPROCS" to "1"
Defined "HAVE_DLERROR" to "1"
Defined "HAVE_MKSTEMP" to "1"
Defined "HAVE_FORK" to "1"
Defined "HAVE_GETPAGESIZE" to "1"
Checking for functions [memalign sigset gethostbyname gettimeofday readlink sigaction strcasecmp dlopen drand48 socket memmove signal popen getrusage times time]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char memalign();
char sigset();
char readlink();
char sigaction();
char strcasecmp();
char dlopen();
char drand48();
char socket();
char memmove();
char signal();
char popen();
char getrusage();
char times();
char time();
#ifdef __cplusplus
#endif
int main() {
#else
memalign();
#endif
#else
sigset();
#endif
#else
gethostbyname();
#endif
#else
gettimeofday();
#endif
#else
readlink();
#endif
#else
sigaction();
#endif
#else
strcasecmp();
#endif
#else
dlopen();
#endif
#else
drand48();
#endif
#else
socket();
#endif
#else
memmove();
#endif
#else
signal();
#endif
#else
popen();
#endif
#else
getrusage();
#endif
#else
times();
#endif
#else
time();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_MEMALIGN" to "1"
Defined "HAVE_SIGSET" to "1"
Defined "HAVE_GETHOSTBYNAME" to "1"
Defined "HAVE_GETTIMEOFDAY" to "1"
Defined "HAVE_READLINK" to "1"
Defined "HAVE_SIGACTION" to "1"
Defined "HAVE_STRCASECMP" to "1"
Defined "HAVE_DLOPEN" to "1"
Defined "HAVE_DRAND48" to "1"
Defined "HAVE_SOCKET" to "1"
Defined "HAVE_MEMMOVE" to "1"
Defined "HAVE_SIGNAL" to "1"
Defined "HAVE_POPEN" to "1"
Defined "HAVE_GETRUSAGE" to "1"
Defined "HAVE_TIMES" to "1"
Defined "HAVE_TIME" to "1"
Checking for functions [_sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _sleep();
#ifdef __cplusplus
#endif
int main() {
#else
_sleep();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_sleep'
Checking for functions [snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
snprintf();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SNPRINTF" to "1"
Checking for functions [_getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
_getcwd();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_getcwd'
Checking for functions [getwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getwd();
#ifdef __cplusplus
#endif
int main() {
#else
getwd();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): warning: the `getwd' function is dangerous and should not be used.
Defined "HAVE_GETWD" to "1"
Checking for functions [_lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _lseek();
#ifdef __cplusplus
#endif
int main() {
#else
_lseek();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_lseek'
Checking for functions [sleep]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sleep();
#ifdef __cplusplus
#endif
int main() {
#else
sleep();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_SLEEP" to "1"
Checking for functions [_access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _access();
#ifdef __cplusplus
#endif
int main() {
#else
_access();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_access'
Checking for functions [lseek]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char lseek();
#ifdef __cplusplus
#endif
int main() {
#else
lseek();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_LSEEK" to "1"
Checking for functions [access]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char access();
#ifdef __cplusplus
#endif
int main() {
#else
access();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_ACCESS" to "1"
Checking for functions [_snprintf]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _snprintf();
#ifdef __cplusplus
#endif
int main() {
#else
_snprintf();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_snprintf'
Checking for functions [sbreak]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char sbreak();
#ifdef __cplusplus
#endif
int main() {
#else
sbreak();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `sbreak'
Checking for functions [getcwd]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char getcwd();
#ifdef __cplusplus
#endif
int main() {
#else
getcwd();
#endif
return 0;
Pushing language C
Popping language C
Defined "HAVE_GETCWD" to "1"
Checking for functions [_set_output_format]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_set_output_format'
Checking for functions [PXFGETARG]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `PXFGETARG'
Checking for functions [sysctlbyname]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
#else
sysctlbyname();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `sysctlbyname'
Checking for functions [stricmp]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char stricmp();
#ifdef __cplusplus
#endif
int main() {
#else
stricmp();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `stricmp'
TEST configureMemorySize from config.utilities.getResidentSetSize(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/getResidentSetSize.py:31)
TESTING: configureMemorySize from config.utilities.getResidentSetSize(config/BuildSystem/config/utilities/getResidentSetSize.py:31)
Try to determine how to measure the memory usage
Defined "USE_PROC_FOR_SIZE" to "1"
Using /proc for PetscMemoryGetCurrentUsage()
TEST configureFortranCommandLine from config.utilities.fortranCommandLine(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/fortranCommandLine.py:27)
TESTING: configureFortranCommandLine from config.utilities.fortranCommandLine(config/BuildSystem/config/utilities/fortranCommandLine.py:27)
Check for the mechanism to retrieve command line arguments in Fortran
Pushing language FC
Checking for functions [] in library [''] []
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.F
stderr:
Fortran diagnostic messages: program name(main)
jwd2005i-w "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.F", line 4: 'i' is used but never set.
Source:
program main
integer i
character*(80) arg
call get_command_argument(i,arg)
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
Defined "HAVE_FORTRAN_GET_COMMAND_ARGUMENT" to "1"
Popping language FC
Pushing language C
Checking for functions [get_command_argument_] in library [''] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
char get_command_argument_();
static void _check_get_command_argument_() { get_command_argument_(); }
int main() {
_check_get_command_argument_();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_get_command_argument_':
conftest.c:(.text+0x4): undefined reference to `get_command_argument_'
Popping language C
Checking for functions [getarg_] in library [''] []
Pushing language C
Successful compile:
Source:
char getarg_();
static void _check_getarg_() { getarg_(); }
int main() {
_check_getarg_();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_getarg_':
conftest.c:(.text+0x4): undefined reference to `getarg_'
Popping language C
Checking for functions [ipxfargc_]
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char ipxfargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_ipxfargc_) || defined (__stub___ipxfargc_)
ipxfargc__will_always_fail_with_ENOSYS();
#else
ipxfargc_();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `ipxfargc_'
Checking for functions [f90_unix_MP_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char f90_unix_MP_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_f90_unix_MP_iargc) || defined (__stub___f90_unix_MP_iargc)
f90_unix_MP_iargc_will_always_fail_with_ENOSYS();
#else
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `f90_unix_MP_iargc'
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char PXFGETARG();
#ifdef __cplusplus
#endif
int main() {
#else
PXFGETARG();
#endif
return 0;
Pushing language C
Popping language C
stderr:
Checking for functions [iargc_]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char iargc_();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub_iargc_) || defined (__stub___iargc_)
iargc__will_always_fail_with_ENOSYS();
#else
iargc_();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `iargc_'
Checking for functions [GETARG at 16]
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 13: error: unrecognized token
char GETARG at 16();
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 13: error: expected a ";"
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 21: error: unrecognized token
#if defined (__stub_GETARG at 16) || defined (__stub___GETARG at 16)
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 21: error: expected a ")"
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 21: error: extra text after expected end of preprocessing directive
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 24: error: unrecognized token
GETARG at 16();
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 24: warning: expression has no effect
GETARG at 16();
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c", line 24: error: expected a ";"
GETARG at 16();
7 errors detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions/conftest.c".
Source:
#include <assert.h>
/* Override any gcc2 internal prototype to avoid an error. */
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
int main() {
GETARG at 16_will_always_fail_with_ENOSYS();
#else
GETARG at 16();
#endif
return 0;
Checking for functions [_gfortran_iargc]
Successful compile:
Source:
#include <assert.h>
#ifdef __cplusplus
extern "C" {
#endif
char _gfortran_iargc();
#ifdef __cplusplus
#endif
int main() {
#if defined (__stub__gfortran_iargc) || defined (__stub____gfortran_iargc)
_gfortran_iargc_will_always_fail_with_ENOSYS();
#else
_gfortran_iargc();
#endif
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x4): undefined reference to `_gfortran_iargc'
Popping language C
TEST configureFeatureTestMacros from config.utilities.featureTestMacros(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/featureTestMacros.py:13)
TESTING: configureFeatureTestMacros from config.utilities.featureTestMacros(config/BuildSystem/config/utilities/featureTestMacros.py:13)
Checks if certain feature test macros are support
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros/conftest.c", line 4: catastrophic error: cannot open source file "sysctl.h"
#include <sysctl.h>
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros/conftest.c".
Source:
#define _POSIX_C_SOURCE 200112L
#include <sysctl.h>
int main() {
return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_BSD_SOURCE" to "1"
Successful compile:
Source:
#define _DEFAULT_SOURCE
#include<stdlib.h>
int main() {
return 0;
Defined "_DEFAULT_SOURCE" to "1"
Successful compile:
Source:
#define _GNU_SOURCE
#include <sched.h>
int main() {
cpu_set_t mset;
CPU_ZERO(&mset);;
return 0;
Defined "_GNU_SOURCE" to "1"
TEST configureMissingDefines from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:57)
TESTING: configureMissingDefines from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:57)
Checks for limits
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_LIMITS_H
#include <limits.h>
#endif
int main() {
int i=INT_MAX;
if (i);
return 0;
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_FLOAT_H
#include <float.h>
#endif
int main() {
double d=DBL_MAX;
if (d);
return 0;
TEST configureMissingUtypeTypedefs from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:67)
TESTING: configureMissingUtypeTypedefs from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:67)
Checks if u_short is undefined
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.c", line 6: warning: variable "foo" was declared but never referenced
u_short foo;
Source:
#include <sys/types.h>
int main() {
u_short foo;
return 0;
TEST configureMissingFunctions from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:73)
TESTING: configureMissingFunctions from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:73)
Checks for SOCKETS
TEST configureMissingSignals from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:93)
TESTING: configureMissingSignals from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:93)
Check for missing signals, and define MISSING_<signal name> if necessary
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGABRT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGALRM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGBUS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCHLD;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGCONT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGFPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGHUP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGINT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGKILL;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGPIPE;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGQUIT;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSEGV;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSTOP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGSYS;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTERM;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTRAP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGTSTP;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGURG;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR1;
if (i);
return 0;
Successful compile:
Source:
#include <signal.h>
int main() {
int i=SIGUSR2;
if (i);
return 0;
TEST configureMissingGetdomainnamePrototype from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:110)
TESTING: configureMissingGetdomainnamePrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:110)
Successful compile:
Source:
#if !defined(_BSD_SOURCE)
#define _BSD_SOURCE
#endif
#if !defined(_DEFAULT_SOURCE)
#endif
#if !defined(_GNU_SOURCE)
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_UNISTD_H
#include <unistd.h>
#endif
#ifdef PETSC_HAVE_NETDB_H
#include <netdb.h>
#endif
int main() {
int (*getdomainname_ptr)(char*,size_t) = getdomainname;
char test[10];
if (getdomainname_ptr(test,10)) return 1;
return 0;
Pushing language Cxx
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.cc
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <unistd.h>
#endif
#include <netdb.h>
#endif
int main() {
char test[10];
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language Cxx
TEST configureMissingSrandPrototype from config.utilities.missing(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/missing.py:135)
TESTING: configureMissingSrandPrototype from config.utilities.missing(config/BuildSystem/config/utilities/missing.py:135)
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
int main() {
double (*drand48_ptr)(void) = drand48;
void (*srand48_ptr)(long int) = srand48;
long int seed=10;
srand48_ptr(seed);
if (drand48_ptr() > 0.5) return 1;
return 0;
Successful compile:
Source:
#define _BSD_SOURCE
#endif
#endif
#define _GNU_SOURCE
#endif
#include <stdlib.h>
#endif
int main() {
long int seed=10;
srand48_ptr(seed);
return 0;
TEST configureFPTrap from config.utilities.FPTrap(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/FPTrap.py:27)
TESTING: configureFPTrap from config.utilities.FPTrap(config/BuildSystem/config/utilities/FPTrap.py:27)
Checking the handling of floating point traps
Checking for header: sigfpe.h
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sigfpe.h"
#include <sigfpe.h>
Source:
#include <sigfpe.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sigfpe.h"
#include <sigfpe.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "sigfpe.h" #include <sigfpe.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: fpxcp.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "fpxcp.h"
#include <fpxcp.h>
Source:
#include <fpxcp.h>
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "fpxcp.h"
#include <fpxcp.h>
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "fpxcp.h" #include <fpxcp.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Checking for header: floatingpoint.h
stdout:
stdout:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "floatingpoint.h"
#include <floatingpoint.h>
Source:
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "floatingpoint.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "floatingpoint.h" #include <floatingpoint.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
TEST configureMkdir from config.programs(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/programs.py:22)
TESTING: configureMkdir from config.programs(config/BuildSystem/config/programs.py:22)
Make sure we can have mkdir automatically make intermediate directories
Checking for program /opt/FJSVtclang/check/mkdir...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mkdir...not found
Checking for program /opt/kusu/bin/mkdir...not found
Checking for program /opt/kusu/sbin/mkdir...not found
Checking for program /usr/pgsql-9.0/bin/mkdir...not found
Checking for program /usr/local/bin/mkdir...not found
Checking for program /bin/mkdir...found
Executing: /bin/mkdir -p .conftest/tmp
Adding -p flag to /bin/mkdir -p to automatically create directories
Defined make macro "MKDIR" to "/bin/mkdir -p"
TEST configureAutoreconf from config.programs(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/programs.py:44)
TESTING: configureAutoreconf from config.programs(config/BuildSystem/config/programs.py:44)
Check for autoreconf
Checking for program /opt/FJSVtclang/check/autoreconf...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/autoreconf...not found
Checking for program /opt/kusu/bin/autoreconf...not found
Checking for program /opt/kusu/sbin/autoreconf...not found
Checking for program /usr/pgsql-9.0/bin/autoreconf...not found
Checking for program /usr/local/bin/autoreconf...not found
Checking for program /bin/autoreconf...not found
Checking for program /usr/bin/autoreconf...found
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.programs
Executing: cd /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.programs/autoconfdir&&/usr/bin/autoreconf
autoreconf test successful!
TEST configurePrograms from config.programs(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/programs.py:66)
TESTING: configurePrograms from config.programs(config/BuildSystem/config/programs.py:66)
Check for the programs needed to build and run PETSc
Checking for program /opt/FJSVtclang/check/sh...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/sh...not found
Checking for program /opt/kusu/bin/sh...not found
Checking for program /opt/kusu/sbin/sh...not found
Checking for program /usr/pgsql-9.0/bin/sh...not found
Checking for program /usr/local/bin/sh...not found
Checking for program /bin/sh...found
Defined make macro "SHELL" to "/bin/sh"
Checking for program /opt/FJSVtclang/check/sed...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/sed...not found
Checking for program /opt/kusu/bin/sed...not found
Checking for program /opt/kusu/sbin/sed...not found
Checking for program /usr/pgsql-9.0/bin/sed...not found
Checking for program /usr/local/bin/sed...not found
Checking for program /bin/sed...found
Defined make macro "SED" to "/bin/sed"
Executing: /bin/sed -i s/sed/sd/g "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.programs/sed1"
Adding SEDINPLACE cmd: /bin/sed -i
Defined make macro "SEDINPLACE" to "/bin/sed -i"
Checking for program /opt/FJSVtclang/check/mv...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mv...not found
Checking for program /opt/kusu/bin/mv...not found
Checking for program /opt/kusu/sbin/mv...not found
Checking for program /usr/pgsql-9.0/bin/mv...not found
Checking for program /usr/local/bin/mv...not found
Checking for program /bin/mv...found
Defined make macro "MV" to "/bin/mv"
Checking for program /opt/FJSVtclang/check/cp...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/cp...not found
Checking for program /opt/kusu/bin/cp...not found
Checking for program /opt/kusu/sbin/cp...not found
Checking for program /usr/pgsql-9.0/bin/cp...not found
Checking for program /usr/local/bin/cp...not found
Checking for program /bin/cp...found
Defined make macro "CP" to "/bin/cp"
Checking for program /opt/FJSVtclang/check/grep...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/grep...not found
Checking for program /opt/kusu/bin/grep...not found
Checking for program /opt/kusu/sbin/grep...not found
Checking for program /usr/pgsql-9.0/bin/grep...not found
Checking for program /usr/local/bin/grep...not found
Checking for program /bin/grep...found
Defined make macro "GREP" to "/bin/grep"
Checking for program /opt/FJSVtclang/check/rm...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/rm...not found
Checking for program /opt/kusu/bin/rm...not found
Checking for program /opt/kusu/sbin/rm...not found
Checking for program /usr/pgsql-9.0/bin/rm...not found
Checking for program /usr/local/bin/rm...not found
Checking for program /bin/rm...found
Defined make macro "RM" to "/bin/rm -f"
Checking for program /opt/FJSVtclang/check/diff...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/diff...not found
Checking for program /opt/kusu/bin/diff...not found
Checking for program /opt/kusu/sbin/diff...not found
Checking for program /usr/pgsql-9.0/bin/diff...not found
Checking for program /usr/local/bin/diff...not found
Checking for program /bin/diff...not found
Checking for program /usr/bin/diff...found
Executing: "/usr/bin/diff" -w "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.programs/diff1" "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.programs/diff2"
Defined make macro "DIFF" to "/usr/bin/diff -w"
Checking for program /usr/ucb/ps...not found
Checking for program /usr/usb/ps...not found
Checking for program /home/hp150306/t00196/ps...not found
Checking for program /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/bin/win32fe/ps...not found
Checking for program /opt/FJSVtclang/check/gzip...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/gzip...not found
Checking for program /opt/kusu/bin/gzip...not found
Checking for program /opt/kusu/sbin/gzip...not found
Checking for program /usr/pgsql-9.0/bin/gzip...not found
Checking for program /usr/local/bin/gzip...not found
Checking for program /bin/gzip...found
Defined make macro "GZIP" to "/bin/gzip"
Defined "HAVE_GZIP" to "1"
Defined make macro "PYTHON" to "/usr/bin/python"
TEST configureMake from config.packages.make(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/make.py:66)
TESTING: configureMake from config.packages.make(config/BuildSystem/config/packages/make.py:66)
Check for user specified make - or gmake, make
Checking for program /opt/FJSVtclang/check/gmake...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/gmake...not found
Checking for program /opt/kusu/bin/gmake...not found
Checking for program /opt/kusu/sbin/gmake...not found
Checking for program /usr/pgsql-9.0/bin/gmake...not found
Checking for program /usr/local/bin/gmake...not found
Checking for program /bin/gmake...not found
Checking for program /usr/bin/gmake...found
Defined make macro "MAKE" to "/usr/bin/gmake"
TEST configureCheckGNUMake from config.packages.make(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/make.py:84)
TESTING: configureCheckGNUMake from config.packages.make(config/BuildSystem/config/packages/make.py:84)
Check for GNU make
Executing: /usr/bin/gmake --version
stdout:
GNU Make 3.81
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for sparc64-unknown-linux-gnu
Defined make macro "MAKE_IS_GNUMAKE" to "1"
Defined make rule "libc" with dependencies "${LIBNAME}(${OBJSC})" and code []
Defined make rule "libcxx" with dependencies "${LIBNAME}(${OBJSCXX})" and code []
Defined make rule "libcu" with dependencies "${LIBNAME}(${OBJSCU})" and code []
Defined make rule "libf" with dependencies "${OBJSF}" and code -${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
TEST configureMakeNP from config.packages.make(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/make.py:119)
TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:119)
check no of cores on the build machine [perhaps to do make '-j ncores']
module multiprocessing found 8 cores: using make_np = 7
Defined make macro "MAKE_NP" to "7"
Defined make macro "OMAKE_PRINTDIR " to "/usr/bin/gmake --print-directory"
Defined make macro "OMAKE" to "/usr/bin/gmake --no-print-directory"
TEST alternateConfigureLibrary from config.packages.OpenMPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.OpenMPI(config/BuildSystem/config/package.py:630)
Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.MPICH(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.MPICH(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:476)
TESTING: configureLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:476)
Calls the regular package configureLibrary and then does an additional test needed by MPI
Checking for a functional MPI
Checking for library in Compiler specific search MPI: []
TEST check from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [MPI_Init MPI_Comm_create] in library [] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
char MPI_Init();
static void _check_MPI_Init() { MPI_Init(); }
char MPI_Comm_create();
static void _check_MPI_Comm_create() { MPI_Comm_create(); }
int main() {
_check_MPI_Init();
_check_MPI_Comm_create();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Checking for headers Compiler specific search MPI: []
Pushing language C
TEST checkInclude from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['mpi.h'] in []
Checking include with compiler flags var CPPFLAGS []
stdout:
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 212 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef long ptrdiff_t;
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef int wchar_t;
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 225 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 343 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 386 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 258 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 278 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
typedef ptrdiff_t MPI_Aint;
typedef long long MPI_Offset;
typedef struct ompi_communicator_t *MPI_Comm;
typedef struct ompi_datatype_t *MPI_Datatype;
typedef struct ompi_errhandler_t *MPI_Errhandler;
typedef struct ompi_file_t *MPI_File;
typedef struct ompi_group_t *MPI_Group;
typedef struct ompi_info_t *MPI_Info;
typedef struct ompi_op_t *MPI_Op;
typedef struct ompi_request_t *MPI_Request;
typedef struct ompi_message_t *MPI_Message;
typedef struct ompi_status_public_t MPI_Status;
typedef struct ompi_win_t *MPI_Win;
#pragma pack(4)
struct ompi_status_public_t {
int MPI_SOURCE;
int MPI_TAG;
int MPI_ERROR;
unsigned long _cancelled : 1;
unsigned long _ucount : 63;
#pragma pack()
typedef struct ompi_status_public_t ompi_status_public_t;
typedef int (MPI_Copy_function)(MPI_Comm, int, void *,
void *, void *, int *);
typedef int (MPI_Delete_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype, MPI_Aint *, void *);
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype,
int, void *, MPI_Offset, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn
typedef void (ompi_file_errhandler_fn)(MPI_File *, int *, ...);
typedef ompi_file_errhandler_fn MPI_File_errhandler_fn
typedef ompi_file_errhandler_fn MPI_File_errhandler_function;
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn
typedef void (MPI_Handler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_User_function)(void *, void *, int *, MPI_Datatype *);
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *,
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *,
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int,
void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *,
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_cancel_function)(void *, int);
#line 432 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 453 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 469 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
enum {
MPI_TAG_UB,
MPI_HOST,
MPI_IO,
MPI_WTIME_IS_GLOBAL,
MPI_APPNUM,
MPI_LASTUSEDCODE,
MPI_UNIVERSE_SIZE,
MPI_WIN_BASE,
MPI_WIN_SIZE,
MPI_WIN_DISP_UNIT,
IMPI_CLIENT_SIZE,
IMPI_CLIENT_COLOR,
IMPI_HOST_SIZE,
IMPI_HOST_COLOR
#line 582 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
enum {
MPI_IDENT,
MPI_CONGRUENT,
MPI_SIMILAR,
MPI_UNEQUAL
enum {
MPI_THREAD_SINGLE,
MPI_THREAD_FUNNELED,
MPI_THREAD_SERIALIZED,
MPI_THREAD_MULTIPLE
enum {
MPI_COMBINER_NAMED,
MPI_COMBINER_DUP,
MPI_COMBINER_CONTIGUOUS,
MPI_COMBINER_VECTOR,
MPI_COMBINER_HVECTOR_INTEGER,
MPI_COMBINER_HVECTOR,
MPI_COMBINER_INDEXED,
MPI_COMBINER_HINDEXED_INTEGER,
MPI_COMBINER_HINDEXED,
MPI_COMBINER_INDEXED_BLOCK,
MPI_COMBINER_STRUCT_INTEGER,
MPI_COMBINER_STRUCT,
MPI_COMBINER_SUBARRAY,
MPI_COMBINER_DARRAY,
MPI_COMBINER_F90_REAL,
MPI_COMBINER_F90_COMPLEX,
MPI_COMBINER_F90_INTEGER,
MPI_COMBINER_RESIZED,
MPI_COMBINER_HINDEXED_BLOCK
#line 649 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
int OMPI_C_MPI_TYPE_NULL_DELETE_FN( MPI_Datatype datatype,
int type_keyval,
void* attribute_val_out,
void* extra_state );
int OMPI_C_MPI_TYPE_NULL_COPY_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
void* attribute_val_in,
int* flag );
int OMPI_C_MPI_TYPE_DUP_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_COMM_NULL_DELETE_FN( MPI_Comm comm,
int comm_keyval,
int OMPI_C_MPI_COMM_NULL_COPY_FN( MPI_Comm comm,
int comm_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_COMM_DUP_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_NULL_DELETE_FN( MPI_Comm comm, int comm_keyval,
void* extra_state )
int OMPI_C_MPI_NULL_COPY_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag )
int OMPI_C_MPI_DUP_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag )
int OMPI_C_MPI_WIN_NULL_DELETE_FN( MPI_Win window,
int win_keyval,
int OMPI_C_MPI_WIN_NULL_COPY_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_WIN_DUP_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
extern struct ompi_predefined_communicator_t ompi_mpi_comm_world;
extern struct ompi_predefined_communicator_t ompi_mpi_comm_self;
extern struct ompi_predefined_communicator_t ompi_mpi_comm_null;
extern struct ompi_predefined_group_t ompi_mpi_group_empty;
extern struct ompi_predefined_group_t ompi_mpi_group_null;
extern struct ompi_predefined_request_t ompi_request_null;
extern struct ompi_predefined_message_t ompi_message_null;
extern struct ompi_predefined_message_t ompi_message_no_proc;
extern struct ompi_predefined_op_t ompi_mpi_op_null;
extern struct ompi_predefined_op_t ompi_mpi_op_min;
extern struct ompi_predefined_op_t ompi_mpi_op_max;
extern struct ompi_predefined_op_t ompi_mpi_op_sum;
extern struct ompi_predefined_op_t ompi_mpi_op_prod;
extern struct ompi_predefined_op_t ompi_mpi_op_land;
extern struct ompi_predefined_op_t ompi_mpi_op_band;
extern struct ompi_predefined_op_t ompi_mpi_op_lor;
extern struct ompi_predefined_op_t ompi_mpi_op_bor;
extern struct ompi_predefined_op_t ompi_mpi_op_lxor;
extern struct ompi_predefined_op_t ompi_mpi_op_bxor;
extern struct ompi_predefined_op_t ompi_mpi_op_maxloc;
extern struct ompi_predefined_op_t ompi_mpi_op_minloc;
extern struct ompi_predefined_op_t ompi_mpi_op_replace;
extern struct ompi_predefined_datatype_t ompi_mpi_datatype_null;
extern struct ompi_predefined_datatype_t ompi_mpi_lb ;
extern struct ompi_predefined_datatype_t ompi_mpi_ub ;
extern struct ompi_predefined_datatype_t ompi_mpi_char;
extern struct ompi_predefined_datatype_t ompi_mpi_signed_char;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_char;
extern struct ompi_predefined_datatype_t ompi_mpi_byte;
extern struct ompi_predefined_datatype_t ompi_mpi_short;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_short;
extern struct ompi_predefined_datatype_t ompi_mpi_int;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned;
extern struct ompi_predefined_datatype_t ompi_mpi_long;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long;
extern struct ompi_predefined_datatype_t ompi_mpi_long_long_int;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long_long;
extern struct ompi_predefined_datatype_t ompi_mpi_float;
extern struct ompi_predefined_datatype_t ompi_mpi_double;
extern struct ompi_predefined_datatype_t ompi_mpi_long_double;
extern struct ompi_predefined_datatype_t ompi_mpi_wchar;
extern struct ompi_predefined_datatype_t ompi_mpi_packed;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_bool;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_ldblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_logic;
extern struct ompi_predefined_datatype_t ompi_mpi_character;
extern struct ompi_predefined_datatype_t ompi_mpi_integer;
extern struct ompi_predefined_datatype_t ompi_mpi_real;
extern struct ompi_predefined_datatype_t ompi_mpi_dblprec;
extern struct ompi_predefined_datatype_t ompi_mpi_cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_ldblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_2int;
extern struct ompi_predefined_datatype_t ompi_mpi_2integer;
extern struct ompi_predefined_datatype_t ompi_mpi_2real;
extern struct ompi_predefined_datatype_t ompi_mpi_2dblprec;
extern struct ompi_predefined_datatype_t ompi_mpi_2cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_2dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_float_int;
extern struct ompi_predefined_datatype_t ompi_mpi_double_int;
extern struct ompi_predefined_datatype_t ompi_mpi_longdbl_int;
extern struct ompi_predefined_datatype_t ompi_mpi_short_int;
extern struct ompi_predefined_datatype_t ompi_mpi_long_int;
extern struct ompi_predefined_datatype_t ompi_mpi_logical1;
extern struct ompi_predefined_datatype_t ompi_mpi_logical2;
extern struct ompi_predefined_datatype_t ompi_mpi_logical4;
extern struct ompi_predefined_datatype_t ompi_mpi_logical8;
extern struct ompi_predefined_datatype_t ompi_mpi_integer1;
extern struct ompi_predefined_datatype_t ompi_mpi_integer2;
extern struct ompi_predefined_datatype_t ompi_mpi_integer4;
extern struct ompi_predefined_datatype_t ompi_mpi_integer8;
extern struct ompi_predefined_datatype_t ompi_mpi_integer16;
extern struct ompi_predefined_datatype_t ompi_mpi_real2;
extern struct ompi_predefined_datatype_t ompi_mpi_real4;
extern struct ompi_predefined_datatype_t ompi_mpi_real8;
extern struct ompi_predefined_datatype_t ompi_mpi_real16;
extern struct ompi_predefined_datatype_t ompi_mpi_complex8;
extern struct ompi_predefined_datatype_t ompi_mpi_complex16;
extern struct ompi_predefined_datatype_t ompi_mpi_complex32;
extern struct ompi_predefined_datatype_t ompi_mpi_int8_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint8_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int16_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint16_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int32_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint32_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int64_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint64_t;
extern struct ompi_predefined_datatype_t ompi_mpi_aint;
extern struct ompi_predefined_datatype_t ompi_mpi_offset;
extern struct ompi_predefined_datatype_t ompi_mpi_c_bool;
extern struct ompi_predefined_datatype_t ompi_mpi_c_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_float_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_double_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_long_double_complex;
extern struct ompi_predefined_errhandler_t ompi_mpi_errhandler_null;
extern struct ompi_predefined_errhandler_t ompi_mpi_errors_are_fatal;
extern struct ompi_predefined_errhandler_t ompi_mpi_errors_return;
extern struct ompi_predefined_win_t ompi_mpi_win_null;
extern struct ompi_predefined_file_t ompi_mpi_file_null;
extern struct ompi_predefined_info_t ompi_mpi_info_null;
extern int *MPI_F_STATUS_IGNORE;
extern int *MPI_F_STATUSES_IGNORE;
#line 921 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 954 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1011 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1038 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Accumulate(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int target_rank, MPI_Aint target_disp, int target_count,
MPI_Datatype target_datatype, MPI_Op op, MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, char *string);
int MPI_Address(void *location, MPI_Aint *address)
int MPI_Allgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int recvcount,
MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Iallgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Allgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int *recvcounts,
int *displs, MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Iallgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int *displs, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info,
void *baseptr);
int MPI_Allreduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, MPI_Comm comm);
int MPI_Iallreduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request);
int MPI_Alltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ialltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Alltoallv(void *sendbuf, int *sendcounts, int *sdispls,
MPI_Datatype sendtype, void *recvbuf, int *recvcounts,
int *rdispls, MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Ialltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int *rdispls, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Alltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
void *recvbuf, int *recvcounts, int *rdispls, MPI_Datatype *recvtypes,
MPI_Comm comm);
int MPI_Ialltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
int MPI_Attr_delete(MPI_Comm comm, int keyval)
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag)
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val)
int MPI_Barrier(MPI_Comm comm);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype,
int root, MPI_Comm comm);
int MPI_Bsend(void *buf, int count, MPI_Datatype datatype,
int dest, int tag, MPI_Comm comm);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype,
int root, MPI_Comm comm,
int MPI_Bsend_init(void *buf, int count, MPI_Datatype datatype,
int dest, int tag, MPI_Comm comm, MPI_Request *request);
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer, int *size);
int MPI_Cancel(MPI_Request *request);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int *coords);
int MPI_Cart_create(MPI_Comm old_comm, int ndims, int *dims,
int *periods, int reorder, MPI_Comm *comm_cart);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int *dims,
int *periods, int *coords);
int MPI_Cart_map(MPI_Comm comm, int ndims, int *dims,
int *periods, int *newrank);
int MPI_Cart_rank(MPI_Comm comm, int *coords, int *rank);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp,
int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, int *remain_dims, MPI_Comm *new_comm);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Close_port(char *port_name);
int MPI_Comm_accept(char *port_name, MPI_Info info, int root,
MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_c2f(MPI_Comm comm);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_connect(char *port_name, MPI_Info info, int root,
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *function,
MPI_Errhandler *errhandler);
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
MPI_Comm_delete_attr_function *comm_delete_attr_fn,
int *comm_keyval, void *extra_state);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
MPI_Comm MPI_Comm_f2c(int comm);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval,
void *attribute_val, int *flag);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, int nodes[],
int degrees[], int targets[],
int weights[], MPI_Info info,
int reorder, MPI_Comm * newcomm);
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old,
int indegree, int sources[],
int sourceweights[],
int outdegree,
int destinations[],
int destweights[],
MPI_Info info, int reorder,
MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree,
int sources[], int sourceweights[],
int maxoutdegree,
int destinations[],
int destweights[]);
int MPI_Dist_graph_neighbors_count(MPI_Comm comm,
int *inneighbors,
int *outneighbors,
int *weighted);
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *erhandler);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Comm_set_name(MPI_Comm comm, char *comm_name);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_spawn(char *command, char **argv, int maxprocs, MPI_Info info,
int root, MPI_Comm comm, MPI_Comm *intercomm,
int *array_of_errcodes);
int MPI_Comm_spawn_multiple(int count, char **array_of_commands, char ***array_of_argv,
int *array_of_maxprocs, MPI_Info *array_of_info,
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Dims_create(int nnodes, int ndims, int *dims);
int MPI_Errhandler_c2f(MPI_Errhandler errhandler);
int MPI_Errhandler_create(MPI_Handler_function *function,
MPI_Errhandler MPI_Errhandler_f2c(int errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler)
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler)
int MPI_Error_class(int errorcode, int *errorclass);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Exscan(void *sendbuf, void *recvbuf, int count,
int MPI_Iexscan(void *sendbuf, void *recvbuf, int count,
int MPI_File_c2f(MPI_File file);
MPI_File MPI_File_f2c(int file);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_File_create_errhandler(MPI_File_errhandler_function *function,
int MPI_File_set_errhandler( MPI_File file, MPI_Errhandler errhandler);
int MPI_File_get_errhandler( MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_open(MPI_Comm comm, char *filename, int amode,
MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
MPI_Datatype filetype, char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp,
MPI_Datatype *etype,
MPI_Datatype *filetype, char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype, MPI_Status *status);
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype, MPI_Request *request);
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_read(MPI_File fh, void *buf, int count,
int MPI_File_read_all(MPI_File fh, void *buf, int count,
int MPI_File_write(MPI_File fh, void *buf, int count,
int MPI_File_write_all(MPI_File fh, void *buf, int count,
int MPI_File_iread(MPI_File fh, void *buf, int count,
int MPI_File_iwrite(MPI_File fh, void *buf, int count,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset,
MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count,
int MPI_File_write_shared(MPI_File fh, void *buf, int count,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count,
int MPI_File_iwrite_shared(MPI_File fh, void *buf, int count,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count,
int MPI_File_write_ordered(MPI_File fh, void *buf, int count,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype);
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count,
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, void *buf, int count,
int MPI_File_write_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count,
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, void *buf, int count,
int MPI_File_write_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype,
MPI_Aint *extent);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
int MPI_Finalize(void);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Gather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Igather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int root, MPI_Comm comm, MPI_Request *request);
int MPI_Gatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int *recvcounts, int *displs,
MPI_Datatype recvtype, int root, MPI_Comm comm);
int MPI_Igatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request);
int MPI_Get_address(void *location, MPI_Aint *address);
int MPI_Get_count(MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Get_elements(MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Get(void *origin_addr, int origin_count,
MPI_Datatype origin_datatype, int target_rank,
MPI_Datatype target_datatype, MPI_Win win);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, int *index,
int *edges, int reorder, MPI_Comm *comm_graph);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges,
int *index, int *edges);
int MPI_Graph_map(MPI_Comm comm, int nnodes, int *index, int *edges,
int *newrank);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors,
int *neighbors);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn,
MPI_Grequest_free_function *free_fn,
MPI_Grequest_cancel_function *cancel_fn,
void *extra_state, MPI_Request *request);
int MPI_Group_c2f(MPI_Group group);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2,
MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, int *ranks,
MPI_Group MPI_Group_f2c(int group);
int MPI_Group_free(MPI_Group *group);
int MPI_Group_incl(MPI_Group group, int n, int *ranks,
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2,
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3],
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3],
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_translate_ranks(MPI_Group group1, int n, int *ranks1,
MPI_Group group2, int *ranks2);
int MPI_Group_union(MPI_Group group1, MPI_Group group2,
int MPI_Ibsend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Improbe(int source, int tag, MPI_Comm comm,
int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype type,
MPI_Message *message, MPI_Request *request);
int MPI_Info_c2f(MPI_Info info);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
MPI_Info MPI_Info_f2c(int info);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, char *key, int valuelen,
char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, char *key, int *valuelen,
int *flag);
int MPI_Info_set(MPI_Info info, char *key, char *value);
int MPI_Init(int *argc, char ***argv);
int MPI_Initialized(int *flag);
int MPI_Init_thread(int *argc, char ***argv, int required,
int *provided);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
MPI_Comm bridge_comm, int remote_leader,
int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Irsend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Isend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Issend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Is_thread_main(int *flag);
int MPI_Keyval_create(MPI_Copy_function *copy_fn,
MPI_Delete_function *delete_fn,
int *keyval, void *extra_state)
int MPI_Keyval_free(int *keyval)
int MPI_Lookup_name(char *service_name, MPI_Info info, char *port_name);
int MPI_Message_c2f(MPI_Message message);
MPI_Message MPI_Message_f2c(int message);
int MPI_Mprobe(int source, int tag, MPI_Comm comm,
int MPI_Mrecv(void *buf, int count, MPI_Datatype type,
MPI_Message *message, MPI_Status *status);
int MPI_Op_c2f(MPI_Op op);
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Op_create(MPI_User_function *function, int commute, MPI_Op *op);
int MPI_Open_port(MPI_Info info, char *port_name);
MPI_Op MPI_Op_f2c(int op);
int MPI_Op_free(MPI_Op *op);
int MPI_Pack_external(char *datarep, void *inbuf, int incount,
MPI_Datatype datatype, void *outbuf,
MPI_Aint outsize, MPI_Aint *position);
int MPI_Pack_external_size(char *datarep, int incount,
MPI_Datatype datatype, MPI_Aint *size);
int MPI_Pack(void *inbuf, int incount, MPI_Datatype datatype,
void *outbuf, int outsize, int *position, MPI_Comm comm);
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm,
int *size);
int MPI_Pcontrol(const int level, ...);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Publish_name(char *service_name, MPI_Info info,
char *port_name);
int MPI_Put(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Query_thread(int *provided);
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Reduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm);
int MPI_Ireduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm, MPI_Request *request);
int MPI_Reduce_local(void *inbuf, void *inoutbuf, int count,
MPI_Datatype datatype, MPI_Op op);
int MPI_Reduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int MPI_Ireduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int MPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int MPI_Ireduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int MPI_Register_datarep(char *datarep,
MPI_Datarep_conversion_function *read_conversion_fn,
MPI_Datarep_conversion_function *write_conversion_fn,
MPI_Datarep_extent_function *dtype_file_extent_fn,
void *extra_state);
int MPI_Request_c2f(MPI_Request request);
MPI_Request MPI_Request_f2c(int request);
int MPI_Request_free(MPI_Request *request);
int MPI_Request_get_status(MPI_Request request, int *flag,
int MPI_Rsend(void *ibuf, int count, MPI_Datatype datatype, int dest,
int MPI_Rsend_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Scan(void *sendbuf, void *recvbuf, int count,
int MPI_Iscan(void *sendbuf, void *recvbuf, int count,
int MPI_Scatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Iscatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Scatterv(void *sendbuf, int *sendcounts, int *displs,
MPI_Datatype sendtype, void *recvbuf, int recvcount,
int MPI_Iscatterv(void *sendbuf, int *sendcounts, int *displs,
int MPI_Send_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Send(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Sendrecv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int dest, int sendtag, void *recvbuf, int recvcount,
MPI_Datatype recvtype, int source, int recvtag,
int MPI_Sendrecv_replace(void * buf, int count, MPI_Datatype datatype,
int dest, int sendtag, int source, int recvtag,
int MPI_Ssend_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Ssend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request *array_of_requests);
int MPI_Status_c2f(MPI_Status *c_status, int *f_status);
int MPI_Status_f2c(int *f_status, MPI_Status *c_status);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype,
int count);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
MPI_Status array_of_statuses[]);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *index,
int *flag, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Test_cancelled(MPI_Status *status, int *flag);
int MPI_Testsome(int incount, MPI_Request array_of_requests[],
int *outcount, int array_of_indices[],
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Type_c2f(MPI_Datatype datatype);
int MPI_Type_commit(MPI_Datatype *type);
int MPI_Type_contiguous(int count, MPI_Datatype oldtype,
MPI_Datatype *newtype);
int MPI_Type_create_darray(int size, int rank, int ndims,
int gsize_array[], int distrib_array[],
int darg_array[], int psize_array[],
int order, MPI_Datatype oldtype,
int MPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int MPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int MPI_Type_create_hindexed(int count, int array_of_blocklengths[],
MPI_Aint array_of_displacements[],
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride,
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
MPI_Type_delete_attr_function *type_delete_attr_fn,
int *type_keyval, void *extra_state);
int MPI_Type_create_indexed_block(int count, int blocklength,
int MPI_Type_create_struct(int count, int array_of_block_lengths[],
MPI_Datatype array_of_types[],
int MPI_Type_create_subarray(int ndims, int size_array[], int subsize_array[],
int start_array[], int order,
MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb,
MPI_Aint extent, MPI_Datatype *newtype);
int MPI_Type_delete_attr(MPI_Datatype type, int type_keyval);
int MPI_Type_dup(MPI_Datatype type, MPI_Datatype *newtype);
int MPI_Type_extent(MPI_Datatype type, MPI_Aint *extent)
int MPI_Type_free(MPI_Datatype *type);
int MPI_Type_free_keyval(int *type_keyval);
MPI_Datatype MPI_Type_f2c(int datatype);
int MPI_Type_get_attr(MPI_Datatype type, int type_keyval,
int MPI_Type_get_contents(MPI_Datatype mtype, int max_integers,
int max_addresses, int max_datatypes,
int array_of_integers[],
MPI_Aint array_of_addresses[],
MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype type, int *num_integers,
int *num_addresses, int *num_datatypes,
int *combiner);
int MPI_Type_get_extent(MPI_Datatype type, MPI_Aint *lb,
MPI_Aint *extent);
int MPI_Type_get_name(MPI_Datatype type, char *type_name,
int *resultlen);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb,
MPI_Aint *true_extent);
int MPI_Type_hindexed(int count, int array_of_blocklengths[],
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride,
int MPI_Type_indexed(int count, int array_of_blocklengths[],
int MPI_Type_lb(MPI_Datatype type, MPI_Aint *lb)
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *type);
int MPI_Type_set_attr(MPI_Datatype type, int type_keyval,
void *attr_val);
int MPI_Type_set_name(MPI_Datatype type, char *type_name);
int MPI_Type_size(MPI_Datatype type, int *size);
int MPI_Type_struct(int count, int array_of_blocklengths[],
int MPI_Type_ub(MPI_Datatype mtype, MPI_Aint *ub)
int MPI_Type_vector(int count, int blocklength, int stride,
int MPI_Unpack(void *inbuf, int insize, int *position,
void *outbuf, int outcount, MPI_Datatype datatype,
MPI_Comm comm);
int MPI_Unpublish_name(char *service_name, MPI_Info info, char *port_name);
int MPI_Unpack_external (char *datarep, void *inbuf, MPI_Aint insize,
MPI_Aint *position, void *outbuf, int outcount,
int MPI_Waitall(int count, MPI_Request *array_of_requests,
MPI_Status *array_of_statuses);
int MPI_Waitany(int count, MPI_Request *array_of_requests,
int *index, MPI_Status *status);
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Waitsome(int incount, MPI_Request *array_of_requests,
int *outcount, int *array_of_indices,
int MPI_Win_c2f(MPI_Win win);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit,
MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *function,
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
MPI_Win_delete_attr_function *win_delete_attr_fn,
int *win_keyval, void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
MPI_Win MPI_Win_f2c(int win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Win_set_name(MPI_Win win, char *win_name);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
double MPI_Wtick(void);
double MPI_Wtime(void);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Accumulate(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, char *string);
int PMPI_Address(void *location, MPI_Aint *address)
int PMPI_Allgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iallgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Allgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iallgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info,
void *baseptr);
int PMPI_Allreduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Iallreduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Alltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ialltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Alltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int PMPI_Ialltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int PMPI_Alltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
MPI_Comm comm);
int PMPI_Ialltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
int PMPI_Attr_delete(MPI_Comm comm, int keyval)
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag)
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, int nodes[],
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old,
int outdegree,
int destinations[],
int destweights[],
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree,
int maxoutdegree,
int destinations[],
int destweights[]);
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm,
int *inneighbors,
int *outneighbors,
int *weighted);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val)
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype,
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype,
int PMPI_Bsend(void *buf, int count, MPI_Datatype datatype,
int PMPI_Bsend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer, int *size);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int *coords);
int PMPI_Cart_create(MPI_Comm old_comm, int ndims, int *dims,
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int *dims,
int PMPI_Cart_map(MPI_Comm comm, int ndims, int *dims,
int PMPI_Cart_rank(MPI_Comm comm, int *coords, int *rank);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp,
int PMPI_Cart_sub(MPI_Comm comm, int *remain_dims, MPI_Comm *new_comm);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Close_port(char *port_name);
int PMPI_Comm_accept(char *port_name, MPI_Info info, int root,
int PMPI_Comm_c2f(MPI_Comm comm);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_connect(char *port_name, MPI_Info info, int root,
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *function,
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
MPI_Comm PMPI_Comm_f2c(int comm);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *erhandler);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Comm_set_name(MPI_Comm comm, char *comm_name);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_spawn(char *command, char **argv, int maxprocs, MPI_Info info,
int PMPI_Comm_spawn_multiple(int count, char **array_of_commands, char ***array_of_argv,
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Dims_create(int nnodes, int ndims, int *dims);
int PMPI_Errhandler_c2f(MPI_Errhandler errhandler);
int PMPI_Errhandler_create(MPI_Handler_function *function,
MPI_Errhandler PMPI_Errhandler_f2c(int errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler)
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler)
int PMPI_Error_class(int errorcode, int *errorclass);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Exscan(void *sendbuf, void *recvbuf, int count,
int PMPI_Iexscan(void *sendbuf, void *recvbuf, int count,
int PMPI_File_c2f(MPI_File file);
MPI_File PMPI_File_f2c(int file);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *function,
int PMPI_File_set_errhandler( MPI_File file, MPI_Errhandler errhandler);
int PMPI_File_get_errhandler( MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_open(MPI_Comm comm, char *filename, int amode,
int PMPI_File_close(MPI_File *fh);
int PMPI_File_delete(char *filename, MPI_Info info);
int PMPI_File_set_size(MPI_File fh, MPI_Offset size);
int PMPI_File_preallocate(MPI_File fh, MPI_Offset size);
int PMPI_File_get_size(MPI_File fh, MPI_Offset *size);
int PMPI_File_get_group(MPI_File fh, MPI_Group *group);
int PMPI_File_get_amode(MPI_File fh, int *amode);
int PMPI_File_set_info(MPI_File fh, MPI_Info info);
int PMPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int PMPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
int PMPI_File_get_view(MPI_File fh, MPI_Offset *disp,
int PMPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read(MPI_File fh, void *buf, int count,
int PMPI_File_read_all(MPI_File fh, void *buf, int count,
int PMPI_File_write(MPI_File fh, void *buf, int count,
int PMPI_File_write_all(MPI_File fh, void *buf, int count,
int PMPI_File_iread(MPI_File fh, void *buf, int count,
int PMPI_File_iwrite(MPI_File fh, void *buf, int count,
int PMPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int PMPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int PMPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset,
MPI_Offset *disp);
int PMPI_File_read_shared(MPI_File fh, void *buf, int count,
int PMPI_File_write_shared(MPI_File fh, void *buf, int count,
int PMPI_File_iread_shared(MPI_File fh, void *buf, int count,
int PMPI_File_iwrite_shared(MPI_File fh, void *buf, int count,
int PMPI_File_read_ordered(MPI_File fh, void *buf, int count,
int PMPI_File_write_ordered(MPI_File fh, void *buf, int count,
int PMPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int PMPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int PMPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_read_all_begin(MPI_File fh, void *buf, int count,
int PMPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_all_begin(MPI_File fh, void *buf, int count,
int PMPI_File_write_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_read_ordered_begin(MPI_File fh, void *buf, int count,
int PMPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_ordered_begin(MPI_File fh, void *buf, int count,
int PMPI_File_write_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype,
MPI_Aint *extent);
int PMPI_File_set_atomicity(MPI_File fh, int flag);
int PMPI_File_get_atomicity(MPI_File fh, int *flag);
int PMPI_File_sync(MPI_File fh);
int PMPI_Finalize(void);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Gather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Igather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Gatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Igatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Get_address(void *location, MPI_Aint *address);
int PMPI_Get_count(MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Get_elements(MPI_Status *status, MPI_Datatype datatype,
int *count);
int PMPI_Get(void *origin_addr, int origin_count,
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, int *index,
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges,
int PMPI_Graph_map(MPI_Comm comm, int nnodes, int *index, int *edges,
int *newrank);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors,
int *neighbors);
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPI_Group_c2f(MPI_Group group);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2,
int PMPI_Group_excl(MPI_Group group, int n, int *ranks,
MPI_Group PMPI_Group_f2c(int group);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Group_incl(MPI_Group group, int n, int *ranks,
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2,
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3],
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3],
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, int *ranks1,
int PMPI_Group_union(MPI_Group group1, MPI_Group group2,
int PMPI_Ibsend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Improbe(int source, int tag, MPI_Comm comm,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype type,
int PMPI_Info_c2f(MPI_Info info);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
MPI_Info PMPI_Info_f2c(int info);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, char *key, int valuelen,
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, char *key, int *valuelen,
int *flag);
int PMPI_Info_set(MPI_Info info, char *key, char *value);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Initialized(int *flag);
int PMPI_Init_thread(int *argc, char ***argv, int required,
int *provided);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Irsend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Isend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Issend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Is_thread_main(int *flag);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn,
int PMPI_Keyval_free(int *keyval)
int PMPI_Lookup_name(char *service_name, MPI_Info info, char *port_name);
int PMPI_Message_c2f(MPI_Message message);
MPI_Message PMPI_Message_f2c(int message);
int PMPI_Mprobe(int source, int tag, MPI_Comm comm,
int PMPI_Mrecv(void *buf, int count, MPI_Datatype type,
int PMPI_Op_c2f(MPI_Op op);
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Op_create(MPI_User_function *function, int commute, MPI_Op *op);
int PMPI_Open_port(MPI_Info info, char *port_name);
MPI_Op PMPI_Op_f2c(int op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Pack_external(char *datarep, void *inbuf, int incount,
int PMPI_Pack_external_size(char *datarep, int incount,
int PMPI_Pack(void *inbuf, int incount, MPI_Datatype datatype,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm,
int *size);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Publish_name(char *service_name, MPI_Info info,
char *port_name);
int PMPI_Put(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Query_thread(int *provided);
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Reduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Ireduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Reduce_local(void *inbuf, void *inoutbuf, int count,
MPI_Datatype datatype, MPI_Op);
int PMPI_Reduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int PMPI_Ireduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int PMPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Ireduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Register_datarep(char *datarep,
void *extra_state);
int PMPI_Request_c2f(MPI_Request request);
MPI_Request PMPI_Request_f2c(int request);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Request_get_status(MPI_Request request, int *flag,
int PMPI_Rsend(void *ibuf, int count, MPI_Datatype datatype, int dest,
int PMPI_Rsend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Scan(void *sendbuf, void *recvbuf, int count,
int PMPI_Iscan(void *sendbuf, void *recvbuf, int count,
int PMPI_Scatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iscatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Scatterv(void *sendbuf, int *sendcounts, int *displs,
int PMPI_Iscatterv(void *sendbuf, int *sendcounts, int *displs,
int PMPI_Send_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Send(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Sendrecv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Sendrecv_replace(void * buf, int count, MPI_Datatype datatype,
int PMPI_Ssend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Ssend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request *array_of_requests);
int PMPI_Status_c2f(MPI_Status *c_status, int *f_status);
int PMPI_Status_f2c(int *f_status, MPI_Status *c_status);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype,
int count);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *index, int *flag, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Test_cancelled(MPI_Status *status, int *flag);
int PMPI_Testsome(int incount, MPI_Request array_of_requests[],
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Type_c2f(MPI_Datatype datatype);
int PMPI_Type_commit(MPI_Datatype *type);
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype,
int PMPI_Type_create_darray(int size, int rank, int ndims,
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_hindexed(int count, int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride,
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_create_indexed_block(int count, int blocklength,
int PMPI_Type_create_struct(int count, int array_of_block_lengths[],
int PMPI_Type_create_subarray(int ndims, int size_array[], int subsize_array[],
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb,
int PMPI_Type_delete_attr(MPI_Datatype type, int type_keyval);
int PMPI_Type_dup(MPI_Datatype type, MPI_Datatype *newtype);
int PMPI_Type_extent(MPI_Datatype type, MPI_Aint *extent)
int PMPI_Type_free(MPI_Datatype *type);
int PMPI_Type_free_keyval(int *type_keyval);
MPI_Datatype PMPI_Type_f2c(int datatype);
int PMPI_Type_get_attr(MPI_Datatype type, int type_keyval,
int PMPI_Type_get_contents(MPI_Datatype mtype, int max_integers,
int PMPI_Type_get_envelope(MPI_Datatype type, int *num_integers,
int *combiner);
int PMPI_Type_get_extent(MPI_Datatype type, MPI_Aint *lb,
MPI_Aint *extent);
int PMPI_Type_get_name(MPI_Datatype type, char *type_name,
int *resultlen);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb,
int PMPI_Type_hindexed(int count, int array_of_blocklengths[],
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride,
int PMPI_Type_indexed(int count, int array_of_blocklengths[],
int PMPI_Type_lb(MPI_Datatype type, MPI_Aint *lb)
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *type);
int PMPI_Type_set_attr(MPI_Datatype type, int type_keyval,
void *attr_val);
int PMPI_Type_set_name(MPI_Datatype type, char *type_name);
int PMPI_Type_size(MPI_Datatype type, int *size);
int PMPI_Type_struct(int count, int array_of_blocklengths[],
int PMPI_Type_ub(MPI_Datatype mtype, MPI_Aint *ub)
int PMPI_Type_vector(int count, int blocklength, int stride,
int PMPI_Unpack(void *inbuf, int insize, int *position,
MPI_Comm comm);
int PMPI_Unpublish_name(char *service_name, MPI_Info info,
char *port_name);
int PMPI_Unpack_external (char *datarep, void *inbuf, MPI_Aint insize,
int PMPI_Waitall(int count, MPI_Request *array_of_requests,
int PMPI_Waitany(int count, MPI_Request *array_of_requests,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Waitsome(int incount, MPI_Request *array_of_requests,
int PMPI_Win_c2f(MPI_Win win);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *function,
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
MPI_Win PMPI_Win_f2c(int win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Win_set_name(MPI_Win win, char *win_name);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
double PMPI_Wtick(void);
double PMPI_Wtime(void);
#line 2281 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['mpi.h'] in []
Popping language C
TEST configureConversion from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:212)
TESTING: configureConversion from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:212)
Check for the functions which convert communicators between C and Fortran
- Define HAVE_MPI_COMM_F2C and HAVE_MPI_COMM_C2F if they are present
- Some older MPI 1 implementations are missing these
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <mpi.h>
int main() {
if (MPI_Comm_f2c((MPI_Fint)0));
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_MPI_COMM_F2C" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_c2f(MPI_COMM_WORLD));
return 0;
Pushing language C
Popping language C
Defined "HAVE_MPI_COMM_C2F" to "1"
Possible ERROR while running compiler:
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 6: warning: variable "a" was declared but never referenced
MPI_Fint a;
Source:
#include <mpi.h>
int main() {
MPI_Fint a;
return 0;
Pushing language C
Popping language C
Defined "HAVE_MPI_FINT" to "1"
TEST configureMPI2 from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:180)
TESTING: configureMPI2 from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:180)
Check for functions added to the interface in MPI-2
Successful compile:
Source:
#include <mpi.h>
int main() {
int flag;if (MPI_Finalized(&flag));
return 0;
Pushing language C
Popping language C
Defined "HAVE_MPI_FINALIZED" to "1"
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Allreduce(MPI_IN_PLACE,0, 1, MPI_INT, MPI_SUM, MPI_COMM_SELF));
return 0;
Pushing language C
Popping language C
Defined "HAVE_MPI_IN_PLACE" to "1"
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 6: warning: a value of type "int" cannot be used to initialize an entity of type "MPI_Datatype"
int count=2; int blocklens[2]={0,1}; MPI_Aint indices[2]={0,1}; MPI_Datatype old_types[2]={0,1}; MPI_Datatype *newtype = 0;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 6: warning: conversion of nonzero integer to pointer
Source:
#include <mpi.h>
int main() {
if (MPI_Type_create_struct(count, blocklens, indices, old_types, newtype));
return 0;
Pushing language C
Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Comm_errhandler_fn * p_err_fun = 0; MPI_Errhandler * p_errhandler = 0; if (MPI_Comm_create_errhandler(p_err_fun,p_errhandler));
return 0;
Pushing language C
Popping language C
Successful compile:
Source:
#include <mpi.h>
int main() {
if (MPI_Comm_set_errhandler(MPI_COMM_WORLD,MPI_ERRORS_RETURN));
return 0;
Pushing language C
Popping language C
TEST configureTypes from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:232)
TESTING: configureTypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:232)
Checking for MPI types
Checking for size of type: MPI_Comm
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#define MPICH_IGNORE_CXX_SEEK
#define MPICH_SKIP_MPICXX 1
#define OMPI_SKIP_MPICXX 1
#include <mpi.h>
int main() {
FILE *f = fopen("conftestval", "w");
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Comm));
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest
Popping language C
Defined "SIZEOF_MPI_COMM" to "8"
Checking for size of type: MPI_Fint
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
#include <mpi.h>
int main() {
if (!f) exit(1);
fprintf(f, "%lu\n", (unsigned long)sizeof(MPI_Fint));
return 0;
Pushing language C
Popping language C
Popping language C
Defined "SIZEOF_MPI_FINT" to "4"
TEST configureMPITypes from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:244)
TESTING: configureMPITypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:244)
Checking for MPI Datatype handles
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c
Successful compile:
Source:
#ifdef PETSC_HAVE_STDLIB_H
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_LONG_DOUBLE, &size);
if(ierr || (size == 0)) exit(1);
MPI_Finalize();
return 0;
Pushing language C
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Pushing language C
Popping language C
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest
ERROR while running executable: Could not execute "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest":
[d01-037:17214] [mpi::ess-ple::jrm-init-failure] [[INVALID],INVALID] Error caused by PLE. [errno:26674688]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84) [0xffffffff10e58404]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0 [0xffffffff10e5b220]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_init+0x120) [0xffffffff10e1aa60]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_init+0x228) [0xffffffff10bfbe28]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Init+0x144) [0xffffffff10c2c804]
[d01-037:17214] /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Init+0x2c) [0xffffffff0015d668]
[d01-037:17214] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest(main+0x14) [0x100d14]
[d01-037:17214] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff1261b81c]
[d01-037:17214] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest [0x100bac]
[d01-037:17214] [mpi::ess-ple::init-failure] [[INVALID],INVALID] PLE is not yet initialized.
Popping language C
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_INT64_T, &size);
MPI_Finalize();
return 0;
Pushing language C
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Pushing language C
Popping language C
[d01-037:17243] [mpi::ess-ple::jrm-init-failure] [[INVALID],INVALID] Error caused by PLE. [errno:26674688]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84) [0xffffffff10e58404]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0 [0xffffffff10e5b220]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_init+0x120) [0xffffffff10e1aa60]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_init+0x228) [0xffffffff10bfbe28]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Init+0x144) [0xffffffff10c2c804]
[d01-037:17243] /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Init+0x2c) [0xffffffff0015d668]
[d01-037:17243] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest(main+0x14) [0x100d14]
[d01-037:17243] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff1261b81c]
[d01-037:17243] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest [0x100bac]
[d01-037:17243] [mpi::ess-ple::init-failure] [[INVALID],INVALID] PLE is not yet initialized.
Popping language C
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
ierr = MPI_Type_extent(MPI_C_DOUBLE_COMPLEX, &size);
MPI_Finalize();
return 0;
Pushing language C
Successful compile:
Source:
#include <stdlib.h>
#endif
#include <mpi.h>
int main() {
MPI_Aint size;
int ierr;
MPI_Init(0,0);
MPI_Finalize();
return 0;
Pushing language C
Popping language C
[d01-037:17272] [mpi::ess-ple::jrm-init-failure] [[INVALID],INVALID] Error caused by PLE. [errno:26674688]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84) [0xffffffff10e58404]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0 [0xffffffff10e5b220]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(orte_init+0x120) [0xffffffff10e1aa60]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(ompi_mpi_init+0x228) [0xffffffff10bfbe28]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libmpi.so.0(MPI_Init+0x144) [0xffffffff10c2c804]
[d01-037:17272] /opt/FJSVtclang/GM-1.2.0-20/lib64/libtrtmet_c.so.1(MPI_Init+0x2c) [0xffffffff0015d668]
[d01-037:17272] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest(main+0x14) [0x100d14]
[d01-037:17272] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff1261b81c]
[d01-037:17272] /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest [0x100bac]
[d01-037:17272] [mpi::ess-ple::init-failure] [[INVALID],INVALID] PLE is not yet initialized.
Popping language C
TEST configureMissingPrototypes from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:318)
TESTING: configureMissingPrototypes from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:318)
Checks for missing prototypes, which it adds to petscfix.h
TEST SGIMPICheck from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:337)
TESTING: SGIMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:337)
Returns true if SGI MPI is used
Checking for functions [MPI_SGI_barrier] in library [] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_SGI_barrier();
static void _check_MPI_SGI_barrier() { MPI_SGI_barrier(); }
int main() {
_check_MPI_SGI_barrier();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Possible ERROR while running linker: exit code 256
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_MPI_SGI_barrier':
conftest.c:(.text+0x4): undefined reference to `MPI_SGI_barrier'
Popping language C
SGI MPI test failure
TEST CxxMPICheck from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:347)
TESTING: CxxMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:347)
Make sure C++ can compile and link
Pushing language Cxx
Checking for header mpi.h
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.cc
Successful compile:
Source:
#include <mpi.h>
int main() {
return 0;
Checking for C++ MPI_Finalize()
Checking for functions [MPI_Finalize] in library [] []
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.cc", line 5: warning: variable "ierr" was set but never used
static void _check_MPI_Finalize() { int ierr;
Source:
#include <mpi.h>
ierr = MPI_Finalize();; }
int main() {
_check_MPI_Finalize();;
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language Cxx
TEST FortranMPICheck from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:365)
TESTING: FortranMPICheck from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:365)
Make sure fortran include [mpif.h] and library symbols are found
Pushing language FC
Checking for header mpif.h
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.F
Successful compile:
Source:
program main
#include "mpif.h"
end
Checking for fortran mpi_init()
Checking for functions [] in library [] []
Pushing language FC
Successful compile:
Source:
program main
#include "mpif.h"
integer ierr
call mpi_init(ierr)
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
Checking for mpi.mod
Pushing language FC
Successful compile:
Source:
program main
use mpi
integer ierr,rank
call mpi_init(ierr)
call mpi_comm_rank(MPI_COMM_WORLD,rank,ierr)
end
Pushing language FC
Popping language FC
Popping language FC
Defined "HAVE_MPI_F90MODULE" to "1"
Popping language FC
TEST configureIO from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:390)
TESTING: configureIO from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:390)
Check for the functions in MPI/IO
- Define HAVE_MPIIO if they are present
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c
Successful compile:
Source:
#include <mpi.h>
int main() {
MPI_Aint lb, extent;
if (MPI_Type_get_extent(MPI_INT, &lb, &extent));
return 0;
Pushing language C
Popping language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 9: warning: variable "fh" is used before its value is set
if (MPI_File_write_all(fh, buf, 1, MPI_INT, &status));
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 9: warning: variable "buf" is used before its value is set
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
return 0;
Pushing language C
Popping language C
stderr:
if (MPI_File_read_all(fh, buf, 1, MPI_INT, &status));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
void *buf;
MPI_Status status;
return 0;
Pushing language C
Popping language C
stderr:
if (MPI_File_set_view(fh, disp, MPI_INT, MPI_INT, "", info));
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 9: warning: variable "disp" is used before its value is set
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 9: warning: variable "info" is used before its value is set
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Offset disp;
MPI_Info info;
return 0;
Pushing language C
Popping language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 8: warning: variable "info" is used before its value is set
if (MPI_File_open(MPI_COMM_SELF, "", 0, info, &fh));
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
return 0;
Pushing language C
Popping language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 7: warning: variable "info" was declared but never referenced
MPI_Info info;
Source:
#include <mpi.h>
int main() {
MPI_File fh;
MPI_Info info;
if (MPI_File_close(&fh));
return 0;
Pushing language C
Popping language C
Defined "HAVE_MPIIO" to "1"
TEST findMPIInc from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:452)
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:452)
Find MPI include paths from "mpicc -show"
Executing: mpifcc -show
stdout: /opt/FJSVtclang/GM-1.2.0-20/bin/fcc -Kident_mpi -mt -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lm -lnsl -lutil
compilers: Checking arg /opt/FJSVtclang/GM-1.2.0-20/bin/fcc
compilers: Checking arg -Kident_mpi
compilers: Checking arg -mt
compilers: Checking arg -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
compilers: Found include directory: /opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
compilers: Checking arg -L/opt/FJSVpxtof/sparc64fx/lib64
compilers: Checking arg -L/opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Checking arg -lmpi
compilers: Checking arg -ltofucom
compilers: Checking arg -ltofutop
compilers: Checking arg -lnsl
compilers: Checking arg -lutil
TEST checkMPICHorOpenMPI from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:427)
TESTING: checkMPICHorOpenMPI from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:427)
Determine if MPICH_NUMVERSION or OMPI_MAJOR_VERSION exist in mpi.h
Used for consistency checking of MPI installation at compile time
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 4: error: identifier "MPICH_NUMVERSION" is undefined
int mpich_ver = MPICH_NUMVERSION;
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c".
Source:
#include <mpi.h>
int main() {
return 0;
Successful compile:
Source:
#include <mpi.h>
int ompi_major = OMPI_MAJOR_VERSION;
int ompi_minor = OMPI_MINOR_VERSION;
int ompi_release = OMPI_RELEASE_VERSION;
int main() {
return 0;
Source:
#include <mpi.h>
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c"
#line 1 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 212 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef long ptrdiff_t;
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef int wchar_t;
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 225 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 343 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 386 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi_portable_platform.h"
#line 258 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 278 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
typedef ptrdiff_t MPI_Aint;
typedef long long MPI_Offset;
typedef struct ompi_communicator_t *MPI_Comm;
typedef struct ompi_datatype_t *MPI_Datatype;
typedef struct ompi_errhandler_t *MPI_Errhandler;
typedef struct ompi_file_t *MPI_File;
typedef struct ompi_group_t *MPI_Group;
typedef struct ompi_info_t *MPI_Info;
typedef struct ompi_op_t *MPI_Op;
typedef struct ompi_request_t *MPI_Request;
typedef struct ompi_message_t *MPI_Message;
typedef struct ompi_status_public_t MPI_Status;
typedef struct ompi_win_t *MPI_Win;
#pragma pack(4)
struct ompi_status_public_t {
int MPI_SOURCE;
int MPI_TAG;
int MPI_ERROR;
unsigned long _cancelled : 1;
unsigned long _ucount : 63;
#pragma pack()
typedef struct ompi_status_public_t ompi_status_public_t;
typedef int (MPI_Copy_function)(MPI_Comm, int, void *,
void *, void *, int *);
typedef int (MPI_Delete_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Datarep_extent_function)(MPI_Datatype, MPI_Aint *, void *);
typedef int (MPI_Datarep_conversion_function)(void *, MPI_Datatype,
int, void *, MPI_Offset, void *);
typedef void (MPI_Comm_errhandler_function)(MPI_Comm *, int *, ...);
typedef MPI_Comm_errhandler_function MPI_Comm_errhandler_fn
typedef void (ompi_file_errhandler_fn)(MPI_File *, int *, ...);
typedef ompi_file_errhandler_fn MPI_File_errhandler_fn
typedef ompi_file_errhandler_fn MPI_File_errhandler_function;
typedef void (MPI_Win_errhandler_function)(MPI_Win *, int *, ...);
typedef MPI_Win_errhandler_function MPI_Win_errhandler_fn
typedef void (MPI_Handler_function)(MPI_Comm *, int *, ...);
typedef void (MPI_User_function)(void *, void *, int *, MPI_Datatype *);
typedef int (MPI_Comm_copy_attr_function)(MPI_Comm, int, void *,
typedef int (MPI_Comm_delete_attr_function)(MPI_Comm, int, void *, void *);
typedef int (MPI_Type_copy_attr_function)(MPI_Datatype, int, void *,
typedef int (MPI_Type_delete_attr_function)(MPI_Datatype, int,
void *, void *);
typedef int (MPI_Win_copy_attr_function)(MPI_Win, int, void *,
typedef int (MPI_Win_delete_attr_function)(MPI_Win, int, void *, void *);
typedef int (MPI_Grequest_query_function)(void *, MPI_Status *);
typedef int (MPI_Grequest_free_function)(void *);
typedef int (MPI_Grequest_cancel_function)(void *, int);
#line 432 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 453 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 469 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
enum {
MPI_TAG_UB,
MPI_HOST,
MPI_IO,
MPI_WTIME_IS_GLOBAL,
MPI_APPNUM,
MPI_LASTUSEDCODE,
MPI_UNIVERSE_SIZE,
MPI_WIN_BASE,
MPI_WIN_SIZE,
MPI_WIN_DISP_UNIT,
IMPI_CLIENT_SIZE,
IMPI_CLIENT_COLOR,
IMPI_HOST_SIZE,
IMPI_HOST_COLOR
#line 582 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
enum {
MPI_IDENT,
MPI_CONGRUENT,
MPI_SIMILAR,
MPI_UNEQUAL
enum {
MPI_THREAD_SINGLE,
MPI_THREAD_FUNNELED,
MPI_THREAD_SERIALIZED,
MPI_THREAD_MULTIPLE
enum {
MPI_COMBINER_NAMED,
MPI_COMBINER_DUP,
MPI_COMBINER_CONTIGUOUS,
MPI_COMBINER_VECTOR,
MPI_COMBINER_HVECTOR_INTEGER,
MPI_COMBINER_HVECTOR,
MPI_COMBINER_INDEXED,
MPI_COMBINER_HINDEXED_INTEGER,
MPI_COMBINER_HINDEXED,
MPI_COMBINER_INDEXED_BLOCK,
MPI_COMBINER_STRUCT_INTEGER,
MPI_COMBINER_STRUCT,
MPI_COMBINER_SUBARRAY,
MPI_COMBINER_DARRAY,
MPI_COMBINER_F90_REAL,
MPI_COMBINER_F90_COMPLEX,
MPI_COMBINER_F90_INTEGER,
MPI_COMBINER_RESIZED,
MPI_COMBINER_HINDEXED_BLOCK
#line 649 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
int OMPI_C_MPI_TYPE_NULL_DELETE_FN( MPI_Datatype datatype,
int type_keyval,
void* attribute_val_out,
void* extra_state );
int OMPI_C_MPI_TYPE_NULL_COPY_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
void* attribute_val_in,
int* flag );
int OMPI_C_MPI_TYPE_DUP_FN( MPI_Datatype datatype,
int type_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_COMM_NULL_DELETE_FN( MPI_Comm comm,
int comm_keyval,
int OMPI_C_MPI_COMM_NULL_COPY_FN( MPI_Comm comm,
int comm_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_COMM_DUP_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_NULL_DELETE_FN( MPI_Comm comm, int comm_keyval,
void* extra_state )
int OMPI_C_MPI_NULL_COPY_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag )
int OMPI_C_MPI_DUP_FN( MPI_Comm comm, int comm_keyval,
void* extra_state,
int* flag )
int OMPI_C_MPI_WIN_NULL_DELETE_FN( MPI_Win window,
int win_keyval,
int OMPI_C_MPI_WIN_NULL_COPY_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
int OMPI_C_MPI_WIN_DUP_FN( MPI_Win window, int win_keyval,
void* extra_state,
int* flag );
extern struct ompi_predefined_communicator_t ompi_mpi_comm_world;
extern struct ompi_predefined_communicator_t ompi_mpi_comm_self;
extern struct ompi_predefined_communicator_t ompi_mpi_comm_null;
extern struct ompi_predefined_group_t ompi_mpi_group_empty;
extern struct ompi_predefined_group_t ompi_mpi_group_null;
extern struct ompi_predefined_request_t ompi_request_null;
extern struct ompi_predefined_message_t ompi_message_null;
extern struct ompi_predefined_message_t ompi_message_no_proc;
extern struct ompi_predefined_op_t ompi_mpi_op_null;
extern struct ompi_predefined_op_t ompi_mpi_op_min;
extern struct ompi_predefined_op_t ompi_mpi_op_max;
extern struct ompi_predefined_op_t ompi_mpi_op_sum;
extern struct ompi_predefined_op_t ompi_mpi_op_prod;
extern struct ompi_predefined_op_t ompi_mpi_op_land;
extern struct ompi_predefined_op_t ompi_mpi_op_band;
extern struct ompi_predefined_op_t ompi_mpi_op_lor;
extern struct ompi_predefined_op_t ompi_mpi_op_bor;
extern struct ompi_predefined_op_t ompi_mpi_op_lxor;
extern struct ompi_predefined_op_t ompi_mpi_op_bxor;
extern struct ompi_predefined_op_t ompi_mpi_op_maxloc;
extern struct ompi_predefined_op_t ompi_mpi_op_minloc;
extern struct ompi_predefined_op_t ompi_mpi_op_replace;
extern struct ompi_predefined_datatype_t ompi_mpi_datatype_null;
extern struct ompi_predefined_datatype_t ompi_mpi_lb ;
extern struct ompi_predefined_datatype_t ompi_mpi_ub ;
extern struct ompi_predefined_datatype_t ompi_mpi_char;
extern struct ompi_predefined_datatype_t ompi_mpi_signed_char;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_char;
extern struct ompi_predefined_datatype_t ompi_mpi_byte;
extern struct ompi_predefined_datatype_t ompi_mpi_short;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_short;
extern struct ompi_predefined_datatype_t ompi_mpi_int;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned;
extern struct ompi_predefined_datatype_t ompi_mpi_long;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long;
extern struct ompi_predefined_datatype_t ompi_mpi_long_long_int;
extern struct ompi_predefined_datatype_t ompi_mpi_unsigned_long_long;
extern struct ompi_predefined_datatype_t ompi_mpi_float;
extern struct ompi_predefined_datatype_t ompi_mpi_double;
extern struct ompi_predefined_datatype_t ompi_mpi_long_double;
extern struct ompi_predefined_datatype_t ompi_mpi_wchar;
extern struct ompi_predefined_datatype_t ompi_mpi_packed;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_bool;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_cxx_ldblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_logic;
extern struct ompi_predefined_datatype_t ompi_mpi_character;
extern struct ompi_predefined_datatype_t ompi_mpi_integer;
extern struct ompi_predefined_datatype_t ompi_mpi_real;
extern struct ompi_predefined_datatype_t ompi_mpi_dblprec;
extern struct ompi_predefined_datatype_t ompi_mpi_cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_ldblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_2int;
extern struct ompi_predefined_datatype_t ompi_mpi_2integer;
extern struct ompi_predefined_datatype_t ompi_mpi_2real;
extern struct ompi_predefined_datatype_t ompi_mpi_2dblprec;
extern struct ompi_predefined_datatype_t ompi_mpi_2cplex;
extern struct ompi_predefined_datatype_t ompi_mpi_2dblcplex;
extern struct ompi_predefined_datatype_t ompi_mpi_float_int;
extern struct ompi_predefined_datatype_t ompi_mpi_double_int;
extern struct ompi_predefined_datatype_t ompi_mpi_longdbl_int;
extern struct ompi_predefined_datatype_t ompi_mpi_short_int;
extern struct ompi_predefined_datatype_t ompi_mpi_long_int;
extern struct ompi_predefined_datatype_t ompi_mpi_logical1;
extern struct ompi_predefined_datatype_t ompi_mpi_logical2;
extern struct ompi_predefined_datatype_t ompi_mpi_logical4;
extern struct ompi_predefined_datatype_t ompi_mpi_logical8;
extern struct ompi_predefined_datatype_t ompi_mpi_integer1;
extern struct ompi_predefined_datatype_t ompi_mpi_integer2;
extern struct ompi_predefined_datatype_t ompi_mpi_integer4;
extern struct ompi_predefined_datatype_t ompi_mpi_integer8;
extern struct ompi_predefined_datatype_t ompi_mpi_integer16;
extern struct ompi_predefined_datatype_t ompi_mpi_real2;
extern struct ompi_predefined_datatype_t ompi_mpi_real4;
extern struct ompi_predefined_datatype_t ompi_mpi_real8;
extern struct ompi_predefined_datatype_t ompi_mpi_real16;
extern struct ompi_predefined_datatype_t ompi_mpi_complex8;
extern struct ompi_predefined_datatype_t ompi_mpi_complex16;
extern struct ompi_predefined_datatype_t ompi_mpi_complex32;
extern struct ompi_predefined_datatype_t ompi_mpi_int8_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint8_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int16_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint16_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int32_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint32_t;
extern struct ompi_predefined_datatype_t ompi_mpi_int64_t;
extern struct ompi_predefined_datatype_t ompi_mpi_uint64_t;
extern struct ompi_predefined_datatype_t ompi_mpi_aint;
extern struct ompi_predefined_datatype_t ompi_mpi_offset;
extern struct ompi_predefined_datatype_t ompi_mpi_c_bool;
extern struct ompi_predefined_datatype_t ompi_mpi_c_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_float_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_double_complex;
extern struct ompi_predefined_datatype_t ompi_mpi_c_long_double_complex;
extern struct ompi_predefined_errhandler_t ompi_mpi_errhandler_null;
extern struct ompi_predefined_errhandler_t ompi_mpi_errors_are_fatal;
extern struct ompi_predefined_errhandler_t ompi_mpi_errors_return;
extern struct ompi_predefined_win_t ompi_mpi_win_null;
extern struct ompi_predefined_file_t ompi_mpi_file_null;
extern struct ompi_predefined_info_t ompi_mpi_info_null;
extern int *MPI_F_STATUS_IGNORE;
extern int *MPI_F_STATUSES_IGNORE;
#line 921 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 954 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1011 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 1038 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
int MPI_Abort(MPI_Comm comm, int errorcode);
int MPI_Accumulate(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int target_rank, MPI_Aint target_disp, int target_count,
MPI_Datatype target_datatype, MPI_Op op, MPI_Win win);
int MPI_Add_error_class(int *errorclass);
int MPI_Add_error_code(int errorclass, int *errorcode);
int MPI_Add_error_string(int errorcode, char *string);
int MPI_Address(void *location, MPI_Aint *address)
int MPI_Allgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Iallgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Allgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int *displs, MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Iallgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int *displs, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Alloc_mem(MPI_Aint size, MPI_Info info,
void *baseptr);
int MPI_Allreduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, MPI_Comm comm);
int MPI_Iallreduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, MPI_Comm comm, MPI_Request *request);
int MPI_Alltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Ialltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Alltoallv(void *sendbuf, int *sendcounts, int *sdispls,
MPI_Datatype sendtype, void *recvbuf, int *recvcounts,
int *rdispls, MPI_Datatype recvtype, MPI_Comm comm);
int MPI_Ialltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int *rdispls, MPI_Datatype recvtype, MPI_Comm comm, MPI_Request *request);
int MPI_Alltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
void *recvbuf, int *recvcounts, int *rdispls, MPI_Datatype *recvtypes,
MPI_Comm comm);
int MPI_Ialltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
int MPI_Attr_delete(MPI_Comm comm, int keyval)
int MPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag)
int MPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val)
int MPI_Barrier(MPI_Comm comm);
int MPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int MPI_Bcast(void *buffer, int count, MPI_Datatype datatype,
int root, MPI_Comm comm);
int MPI_Bsend(void *buf, int count, MPI_Datatype datatype,
int dest, int tag, MPI_Comm comm);
int MPI_Ibcast(void *buffer, int count, MPI_Datatype datatype,
int root, MPI_Comm comm,
int MPI_Bsend_init(void *buf, int count, MPI_Datatype datatype,
int dest, int tag, MPI_Comm comm, MPI_Request *request);
int MPI_Buffer_attach(void *buffer, int size);
int MPI_Buffer_detach(void *buffer, int *size);
int MPI_Cancel(MPI_Request *request);
int MPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int *coords);
int MPI_Cart_create(MPI_Comm old_comm, int ndims, int *dims,
int *periods, int reorder, MPI_Comm *comm_cart);
int MPI_Cart_get(MPI_Comm comm, int maxdims, int *dims,
int *periods, int *coords);
int MPI_Cart_map(MPI_Comm comm, int ndims, int *dims,
int *periods, int *newrank);
int MPI_Cart_rank(MPI_Comm comm, int *coords, int *rank);
int MPI_Cart_shift(MPI_Comm comm, int direction, int disp,
int *rank_source, int *rank_dest);
int MPI_Cart_sub(MPI_Comm comm, int *remain_dims, MPI_Comm *new_comm);
int MPI_Cartdim_get(MPI_Comm comm, int *ndims);
int MPI_Close_port(char *port_name);
int MPI_Comm_accept(char *port_name, MPI_Info info, int root,
MPI_Comm comm, MPI_Comm *newcomm);
int MPI_Comm_c2f(MPI_Comm comm);
int MPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int MPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int MPI_Comm_connect(char *port_name, MPI_Info info, int root,
int MPI_Comm_create_errhandler(MPI_Comm_errhandler_function *function,
int MPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
MPI_Comm_delete_attr_function *comm_delete_attr_fn,
int *comm_keyval, void *extra_state);
int MPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int MPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int MPI_Comm_disconnect(MPI_Comm *comm);
int MPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
MPI_Comm MPI_Comm_f2c(int comm);
int MPI_Comm_free_keyval(int *comm_keyval);
int MPI_Comm_free(MPI_Comm *comm);
int MPI_Comm_get_attr(MPI_Comm comm, int comm_keyval,
void *attribute_val, int *flag);
int MPI_Dist_graph_create(MPI_Comm comm_old, int n, int nodes[],
int degrees[], int targets[],
int weights[], MPI_Info info,
int reorder, MPI_Comm * newcomm);
int MPI_Dist_graph_create_adjacent(MPI_Comm comm_old,
int indegree, int sources[],
int sourceweights[],
int outdegree,
int destinations[],
int destweights[],
MPI_Info info, int reorder,
MPI_Comm *comm_dist_graph);
int MPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree,
int sources[], int sourceweights[],
int maxoutdegree,
int destinations[],
int destweights[]);
int MPI_Dist_graph_neighbors_count(MPI_Comm comm,
int *inneighbors,
int *outneighbors,
int *weighted);
int MPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *erhandler);
int MPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int MPI_Comm_get_parent(MPI_Comm *parent);
int MPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int MPI_Comm_join(int fd, MPI_Comm *intercomm);
int MPI_Comm_rank(MPI_Comm comm, int *rank);
int MPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int MPI_Comm_remote_size(MPI_Comm comm, int *size);
int MPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int MPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int MPI_Comm_set_name(MPI_Comm comm, char *comm_name);
int MPI_Comm_size(MPI_Comm comm, int *size);
int MPI_Comm_spawn(char *command, char **argv, int maxprocs, MPI_Info info,
int root, MPI_Comm comm, MPI_Comm *intercomm,
int *array_of_errcodes);
int MPI_Comm_spawn_multiple(int count, char **array_of_commands, char ***array_of_argv,
int *array_of_maxprocs, MPI_Info *array_of_info,
int MPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int MPI_Comm_test_inter(MPI_Comm comm, int *flag);
int MPI_Dims_create(int nnodes, int ndims, int *dims);
int MPI_Errhandler_c2f(MPI_Errhandler errhandler);
int MPI_Errhandler_create(MPI_Handler_function *function,
MPI_Errhandler MPI_Errhandler_f2c(int errhandler);
int MPI_Errhandler_free(MPI_Errhandler *errhandler);
int MPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler)
int MPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler)
int MPI_Error_class(int errorcode, int *errorclass);
int MPI_Error_string(int errorcode, char *string, int *resultlen);
int MPI_Exscan(void *sendbuf, void *recvbuf, int count,
int MPI_Iexscan(void *sendbuf, void *recvbuf, int count,
int MPI_File_c2f(MPI_File file);
MPI_File MPI_File_f2c(int file);
int MPI_File_call_errhandler(MPI_File fh, int errorcode);
int MPI_File_create_errhandler(MPI_File_errhandler_function *function,
int MPI_File_set_errhandler( MPI_File file, MPI_Errhandler errhandler);
int MPI_File_get_errhandler( MPI_File file, MPI_Errhandler *errhandler);
int MPI_File_open(MPI_Comm comm, char *filename, int amode,
MPI_Info info, MPI_File *fh);
int MPI_File_close(MPI_File *fh);
int MPI_File_delete(char *filename, MPI_Info info);
int MPI_File_set_size(MPI_File fh, MPI_Offset size);
int MPI_File_preallocate(MPI_File fh, MPI_Offset size);
int MPI_File_get_size(MPI_File fh, MPI_Offset *size);
int MPI_File_get_group(MPI_File fh, MPI_Group *group);
int MPI_File_get_amode(MPI_File fh, int *amode);
int MPI_File_set_info(MPI_File fh, MPI_Info info);
int MPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int MPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
MPI_Datatype filetype, char *datarep, MPI_Info info);
int MPI_File_get_view(MPI_File fh, MPI_Offset *disp,
MPI_Datatype *etype,
MPI_Datatype *filetype, char *datarep);
int MPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype, MPI_Status *status);
int MPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype, MPI_Request *request);
int MPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_read(MPI_File fh, void *buf, int count,
int MPI_File_read_all(MPI_File fh, void *buf, int count,
int MPI_File_write(MPI_File fh, void *buf, int count,
int MPI_File_write_all(MPI_File fh, void *buf, int count,
int MPI_File_iread(MPI_File fh, void *buf, int count,
int MPI_File_iwrite(MPI_File fh, void *buf, int count,
int MPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int MPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset,
MPI_Offset *disp);
int MPI_File_read_shared(MPI_File fh, void *buf, int count,
int MPI_File_write_shared(MPI_File fh, void *buf, int count,
int MPI_File_iread_shared(MPI_File fh, void *buf, int count,
int MPI_File_iwrite_shared(MPI_File fh, void *buf, int count,
int MPI_File_read_ordered(MPI_File fh, void *buf, int count,
int MPI_File_write_ordered(MPI_File fh, void *buf, int count,
int MPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int MPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int MPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int count, MPI_Datatype datatype);
int MPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int MPI_File_write_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_read_all_begin(MPI_File fh, void *buf, int count,
int MPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_all_begin(MPI_File fh, void *buf, int count,
int MPI_File_write_all_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_read_ordered_begin(MPI_File fh, void *buf, int count,
int MPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_write_ordered_begin(MPI_File fh, void *buf, int count,
int MPI_File_write_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int MPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype,
MPI_Aint *extent);
int MPI_File_set_atomicity(MPI_File fh, int flag);
int MPI_File_get_atomicity(MPI_File fh, int *flag);
int MPI_File_sync(MPI_File fh);
int MPI_Finalize(void);
int MPI_Finalized(int *flag);
int MPI_Free_mem(void *base);
int MPI_Gather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int recvcount, MPI_Datatype recvtype,
int MPI_Igather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int root, MPI_Comm comm, MPI_Request *request);
int MPI_Gatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
void *recvbuf, int *recvcounts, int *displs,
MPI_Datatype recvtype, int root, MPI_Comm comm);
int MPI_Igatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
MPI_Datatype recvtype, int root, MPI_Comm comm, MPI_Request *request);
int MPI_Get_address(void *location, MPI_Aint *address);
int MPI_Get_count(MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Get_elements(MPI_Status *status, MPI_Datatype datatype, int *count);
int MPI_Get(void *origin_addr, int origin_count,
MPI_Datatype origin_datatype, int target_rank,
MPI_Datatype target_datatype, MPI_Win win);
int MPI_Get_processor_name(char *name, int *resultlen);
int MPI_Get_version(int *version, int *subversion);
int MPI_Graph_create(MPI_Comm comm_old, int nnodes, int *index,
int *edges, int reorder, MPI_Comm *comm_graph);
int MPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges,
int *index, int *edges);
int MPI_Graph_map(MPI_Comm comm, int nnodes, int *index, int *edges,
int *newrank);
int MPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int MPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors,
int *neighbors);
int MPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int MPI_Grequest_complete(MPI_Request request);
int MPI_Grequest_start(MPI_Grequest_query_function *query_fn,
MPI_Grequest_free_function *free_fn,
MPI_Grequest_cancel_function *cancel_fn,
void *extra_state, MPI_Request *request);
int MPI_Group_c2f(MPI_Group group);
int MPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int MPI_Group_difference(MPI_Group group1, MPI_Group group2,
MPI_Group *newgroup);
int MPI_Group_excl(MPI_Group group, int n, int *ranks,
MPI_Group MPI_Group_f2c(int group);
int MPI_Group_free(MPI_Group *group);
int MPI_Group_incl(MPI_Group group, int n, int *ranks,
int MPI_Group_intersection(MPI_Group group1, MPI_Group group2,
int MPI_Group_range_excl(MPI_Group group, int n, int ranges[][3],
int MPI_Group_range_incl(MPI_Group group, int n, int ranges[][3],
int MPI_Group_rank(MPI_Group group, int *rank);
int MPI_Group_size(MPI_Group group, int *size);
int MPI_Group_translate_ranks(MPI_Group group1, int n, int *ranks1,
MPI_Group group2, int *ranks2);
int MPI_Group_union(MPI_Group group1, MPI_Group group2,
int MPI_Ibsend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Improbe(int source, int tag, MPI_Comm comm,
int *flag, MPI_Message *message,
int MPI_Imrecv(void *buf, int count, MPI_Datatype type,
MPI_Message *message, MPI_Request *request);
int MPI_Info_c2f(MPI_Info info);
int MPI_Info_create(MPI_Info *info);
int MPI_Info_delete(MPI_Info info, char *key);
int MPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
MPI_Info MPI_Info_f2c(int info);
int MPI_Info_free(MPI_Info *info);
int MPI_Info_get(MPI_Info info, char *key, int valuelen,
char *value, int *flag);
int MPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int MPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int MPI_Info_get_valuelen(MPI_Info info, char *key, int *valuelen,
int *flag);
int MPI_Info_set(MPI_Info info, char *key, char *value);
int MPI_Init(int *argc, char ***argv);
int MPI_Initialized(int *flag);
int MPI_Init_thread(int *argc, char ***argv, int required,
int *provided);
int MPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
MPI_Comm bridge_comm, int remote_leader,
int tag, MPI_Comm *newintercomm);
int MPI_Intercomm_merge(MPI_Comm intercomm, int high,
int MPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag,
int MPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Irsend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Isend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Issend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Is_thread_main(int *flag);
int MPI_Keyval_create(MPI_Copy_function *copy_fn,
MPI_Delete_function *delete_fn,
int *keyval, void *extra_state)
int MPI_Keyval_free(int *keyval)
int MPI_Lookup_name(char *service_name, MPI_Info info, char *port_name);
int MPI_Message_c2f(MPI_Message message);
MPI_Message MPI_Message_f2c(int message);
int MPI_Mprobe(int source, int tag, MPI_Comm comm,
int MPI_Mrecv(void *buf, int count, MPI_Datatype type,
MPI_Message *message, MPI_Status *status);
int MPI_Op_c2f(MPI_Op op);
int MPI_Op_commutative(MPI_Op op, int *commute);
int MPI_Op_create(MPI_User_function *function, int commute, MPI_Op *op);
int MPI_Open_port(MPI_Info info, char *port_name);
MPI_Op MPI_Op_f2c(int op);
int MPI_Op_free(MPI_Op *op);
int MPI_Pack_external(char *datarep, void *inbuf, int incount,
MPI_Datatype datatype, void *outbuf,
MPI_Aint outsize, MPI_Aint *position);
int MPI_Pack_external_size(char *datarep, int incount,
MPI_Datatype datatype, MPI_Aint *size);
int MPI_Pack(void *inbuf, int incount, MPI_Datatype datatype,
void *outbuf, int outsize, int *position, MPI_Comm comm);
int MPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm,
int *size);
int MPI_Pcontrol(const int level, ...);
int MPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int MPI_Publish_name(char *service_name, MPI_Info info,
char *port_name);
int MPI_Put(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int MPI_Query_thread(int *provided);
int MPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Recv(void *buf, int count, MPI_Datatype datatype, int source,
int MPI_Reduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm);
int MPI_Ireduce(void *sendbuf, void *recvbuf, int count,
MPI_Datatype datatype, MPI_Op op, int root, MPI_Comm comm, MPI_Request *request);
int MPI_Reduce_local(void *inbuf, void *inoutbuf, int count,
MPI_Datatype datatype, MPI_Op op);
int MPI_Reduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int MPI_Ireduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int MPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int MPI_Ireduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int MPI_Register_datarep(char *datarep,
MPI_Datarep_conversion_function *read_conversion_fn,
MPI_Datarep_conversion_function *write_conversion_fn,
MPI_Datarep_extent_function *dtype_file_extent_fn,
void *extra_state);
int MPI_Request_c2f(MPI_Request request);
MPI_Request MPI_Request_f2c(int request);
int MPI_Request_free(MPI_Request *request);
int MPI_Request_get_status(MPI_Request request, int *flag,
int MPI_Rsend(void *ibuf, int count, MPI_Datatype datatype, int dest,
int MPI_Rsend_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Scan(void *sendbuf, void *recvbuf, int count,
int MPI_Iscan(void *sendbuf, void *recvbuf, int count,
int MPI_Scatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Iscatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int MPI_Scatterv(void *sendbuf, int *sendcounts, int *displs,
MPI_Datatype sendtype, void *recvbuf, int recvcount,
int MPI_Iscatterv(void *sendbuf, int *sendcounts, int *displs,
int MPI_Send_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Send(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Sendrecv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int dest, int sendtag, void *recvbuf, int recvcount,
MPI_Datatype recvtype, int source, int recvtag,
int MPI_Sendrecv_replace(void * buf, int count, MPI_Datatype datatype,
int dest, int sendtag, int source, int recvtag,
int MPI_Ssend_init(void *buf, int count, MPI_Datatype datatype,
int MPI_Ssend(void *buf, int count, MPI_Datatype datatype, int dest,
int MPI_Start(MPI_Request *request);
int MPI_Startall(int count, MPI_Request *array_of_requests);
int MPI_Status_c2f(MPI_Status *c_status, int *f_status);
int MPI_Status_f2c(int *f_status, MPI_Status *c_status);
int MPI_Status_set_cancelled(MPI_Status *status, int flag);
int MPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype,
int count);
int MPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
MPI_Status array_of_statuses[]);
int MPI_Testany(int count, MPI_Request array_of_requests[], int *index,
int *flag, MPI_Status *status);
int MPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int MPI_Test_cancelled(MPI_Status *status, int *flag);
int MPI_Testsome(int incount, MPI_Request array_of_requests[],
int *outcount, int array_of_indices[],
int MPI_Topo_test(MPI_Comm comm, int *status);
int MPI_Type_c2f(MPI_Datatype datatype);
int MPI_Type_commit(MPI_Datatype *type);
int MPI_Type_contiguous(int count, MPI_Datatype oldtype,
MPI_Datatype *newtype);
int MPI_Type_create_darray(int size, int rank, int ndims,
int gsize_array[], int distrib_array[],
int darg_array[], int psize_array[],
int order, MPI_Datatype oldtype,
int MPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int MPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int MPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int MPI_Type_create_hindexed(int count, int array_of_blocklengths[],
MPI_Aint array_of_displacements[],
int MPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride,
int MPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
MPI_Type_delete_attr_function *type_delete_attr_fn,
int *type_keyval, void *extra_state);
int MPI_Type_create_indexed_block(int count, int blocklength,
int MPI_Type_create_struct(int count, int array_of_block_lengths[],
MPI_Datatype array_of_types[],
int MPI_Type_create_subarray(int ndims, int size_array[], int subsize_array[],
int start_array[], int order,
MPI_Datatype oldtype, MPI_Datatype *newtype);
int MPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb,
MPI_Aint extent, MPI_Datatype *newtype);
int MPI_Type_delete_attr(MPI_Datatype type, int type_keyval);
int MPI_Type_dup(MPI_Datatype type, MPI_Datatype *newtype);
int MPI_Type_extent(MPI_Datatype type, MPI_Aint *extent)
int MPI_Type_free(MPI_Datatype *type);
int MPI_Type_free_keyval(int *type_keyval);
MPI_Datatype MPI_Type_f2c(int datatype);
int MPI_Type_get_attr(MPI_Datatype type, int type_keyval,
int MPI_Type_get_contents(MPI_Datatype mtype, int max_integers,
int max_addresses, int max_datatypes,
int array_of_integers[],
MPI_Aint array_of_addresses[],
MPI_Datatype array_of_datatypes[]);
int MPI_Type_get_envelope(MPI_Datatype type, int *num_integers,
int *num_addresses, int *num_datatypes,
int *combiner);
int MPI_Type_get_extent(MPI_Datatype type, MPI_Aint *lb,
MPI_Aint *extent);
int MPI_Type_get_name(MPI_Datatype type, char *type_name,
int *resultlen);
int MPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb,
MPI_Aint *true_extent);
int MPI_Type_hindexed(int count, int array_of_blocklengths[],
int MPI_Type_hvector(int count, int blocklength, MPI_Aint stride,
int MPI_Type_indexed(int count, int array_of_blocklengths[],
int MPI_Type_lb(MPI_Datatype type, MPI_Aint *lb)
int MPI_Type_match_size(int typeclass, int size, MPI_Datatype *type);
int MPI_Type_set_attr(MPI_Datatype type, int type_keyval,
void *attr_val);
int MPI_Type_set_name(MPI_Datatype type, char *type_name);
int MPI_Type_size(MPI_Datatype type, int *size);
int MPI_Type_struct(int count, int array_of_blocklengths[],
int MPI_Type_ub(MPI_Datatype mtype, MPI_Aint *ub)
int MPI_Type_vector(int count, int blocklength, int stride,
int MPI_Unpack(void *inbuf, int insize, int *position,
void *outbuf, int outcount, MPI_Datatype datatype,
MPI_Comm comm);
int MPI_Unpublish_name(char *service_name, MPI_Info info, char *port_name);
int MPI_Unpack_external (char *datarep, void *inbuf, MPI_Aint insize,
MPI_Aint *position, void *outbuf, int outcount,
int MPI_Waitall(int count, MPI_Request *array_of_requests,
MPI_Status *array_of_statuses);
int MPI_Waitany(int count, MPI_Request *array_of_requests,
int *index, MPI_Status *status);
int MPI_Wait(MPI_Request *request, MPI_Status *status);
int MPI_Waitsome(int incount, MPI_Request *array_of_requests,
int *outcount, int *array_of_indices,
int MPI_Win_c2f(MPI_Win win);
int MPI_Win_call_errhandler(MPI_Win win, int errorcode);
int MPI_Win_complete(MPI_Win win);
int MPI_Win_create(void *base, MPI_Aint size, int disp_unit,
MPI_Info info, MPI_Comm comm, MPI_Win *win);
int MPI_Win_create_errhandler(MPI_Win_errhandler_function *function,
int MPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
MPI_Win_delete_attr_function *win_delete_attr_fn,
int *win_keyval, void *extra_state);
int MPI_Win_delete_attr(MPI_Win win, int win_keyval);
MPI_Win MPI_Win_f2c(int win);
int MPI_Win_fence(int assert, MPI_Win win);
int MPI_Win_free(MPI_Win *win);
int MPI_Win_free_keyval(int *win_keyval);
int MPI_Win_get_attr(MPI_Win win, int win_keyval,
int MPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int MPI_Win_get_group(MPI_Win win, MPI_Group *group);
int MPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int MPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int MPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int MPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int MPI_Win_set_name(MPI_Win win, char *win_name);
int MPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int MPI_Win_test(MPI_Win win, int *flag);
int MPI_Win_unlock(int rank, MPI_Win win);
int MPI_Win_wait(MPI_Win win);
double MPI_Wtick(void);
double MPI_Wtime(void);
int PMPI_Abort(MPI_Comm comm, int errorcode);
int PMPI_Accumulate(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Add_error_class(int *errorclass);
int PMPI_Add_error_code(int errorclass, int *errorcode);
int PMPI_Add_error_string(int errorcode, char *string);
int PMPI_Address(void *location, MPI_Aint *address)
int PMPI_Allgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iallgather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Allgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iallgatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Alloc_mem(MPI_Aint size, MPI_Info info,
void *baseptr);
int PMPI_Allreduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Iallreduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Alltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Ialltoall(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Alltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int PMPI_Ialltoallv(void *sendbuf, int *sendcounts, int *sdispls,
int PMPI_Alltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
MPI_Comm comm);
int PMPI_Ialltoallw(void *sendbuf, int *sendcounts, int *sdispls, MPI_Datatype *sendtypes,
int PMPI_Attr_delete(MPI_Comm comm, int keyval)
int PMPI_Attr_get(MPI_Comm comm, int keyval, void *attribute_val, int *flag)
int PMPI_Dist_graph_create(MPI_Comm comm_old, int n, int nodes[],
int PMPI_Dist_graph_create_adjacent(MPI_Comm comm_old,
int outdegree,
int destinations[],
int destweights[],
int PMPI_Dist_graph_neighbors(MPI_Comm comm, int maxindegree,
int maxoutdegree,
int destinations[],
int destweights[]);
int PMPI_Dist_graph_neighbors_count(MPI_Comm comm,
int *inneighbors,
int *outneighbors,
int *weighted);
int PMPI_Attr_put(MPI_Comm comm, int keyval, void *attribute_val)
int PMPI_Barrier(MPI_Comm comm);
int PMPI_Ibarrier(MPI_Comm comm, MPI_Request *request);
int PMPI_Bcast(void *buffer, int count, MPI_Datatype datatype,
int PMPI_Ibcast(void *buffer, int count, MPI_Datatype datatype,
int PMPI_Bsend(void *buf, int count, MPI_Datatype datatype,
int PMPI_Bsend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Buffer_attach(void *buffer, int size);
int PMPI_Buffer_detach(void *buffer, int *size);
int PMPI_Cancel(MPI_Request *request);
int PMPI_Cart_coords(MPI_Comm comm, int rank, int maxdims, int *coords);
int PMPI_Cart_create(MPI_Comm old_comm, int ndims, int *dims,
int PMPI_Cart_get(MPI_Comm comm, int maxdims, int *dims,
int PMPI_Cart_map(MPI_Comm comm, int ndims, int *dims,
int PMPI_Cart_rank(MPI_Comm comm, int *coords, int *rank);
int PMPI_Cart_shift(MPI_Comm comm, int direction, int disp,
int PMPI_Cart_sub(MPI_Comm comm, int *remain_dims, MPI_Comm *new_comm);
int PMPI_Cartdim_get(MPI_Comm comm, int *ndims);
int PMPI_Close_port(char *port_name);
int PMPI_Comm_accept(char *port_name, MPI_Info info, int root,
int PMPI_Comm_c2f(MPI_Comm comm);
int PMPI_Comm_call_errhandler(MPI_Comm comm, int errorcode);
int PMPI_Comm_compare(MPI_Comm comm1, MPI_Comm comm2, int *result);
int PMPI_Comm_connect(char *port_name, MPI_Info info, int root,
int PMPI_Comm_create_errhandler(MPI_Comm_errhandler_function *function,
int PMPI_Comm_create_keyval(MPI_Comm_copy_attr_function *comm_copy_attr_fn,
int PMPI_Comm_create(MPI_Comm comm, MPI_Group group, MPI_Comm *newcomm);
int PMPI_Comm_delete_attr(MPI_Comm comm, int comm_keyval);
int PMPI_Comm_disconnect(MPI_Comm *comm);
int PMPI_Comm_dup(MPI_Comm comm, MPI_Comm *newcomm);
MPI_Comm PMPI_Comm_f2c(int comm);
int PMPI_Comm_free_keyval(int *comm_keyval);
int PMPI_Comm_free(MPI_Comm *comm);
int PMPI_Comm_get_attr(MPI_Comm comm, int comm_keyval,
int PMPI_Comm_get_errhandler(MPI_Comm comm, MPI_Errhandler *erhandler);
int PMPI_Comm_get_name(MPI_Comm comm, char *comm_name, int *resultlen);
int PMPI_Comm_get_parent(MPI_Comm *parent);
int PMPI_Comm_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Comm_join(int fd, MPI_Comm *intercomm);
int PMPI_Comm_rank(MPI_Comm comm, int *rank);
int PMPI_Comm_remote_group(MPI_Comm comm, MPI_Group *group);
int PMPI_Comm_remote_size(MPI_Comm comm, int *size);
int PMPI_Comm_set_attr(MPI_Comm comm, int comm_keyval, void *attribute_val);
int PMPI_Comm_set_errhandler(MPI_Comm comm, MPI_Errhandler errhandler);
int PMPI_Comm_set_name(MPI_Comm comm, char *comm_name);
int PMPI_Comm_size(MPI_Comm comm, int *size);
int PMPI_Comm_spawn(char *command, char **argv, int maxprocs, MPI_Info info,
int PMPI_Comm_spawn_multiple(int count, char **array_of_commands, char ***array_of_argv,
int PMPI_Comm_split(MPI_Comm comm, int color, int key, MPI_Comm *newcomm);
int PMPI_Comm_test_inter(MPI_Comm comm, int *flag);
int PMPI_Dims_create(int nnodes, int ndims, int *dims);
int PMPI_Errhandler_c2f(MPI_Errhandler errhandler);
int PMPI_Errhandler_create(MPI_Handler_function *function,
MPI_Errhandler PMPI_Errhandler_f2c(int errhandler);
int PMPI_Errhandler_free(MPI_Errhandler *errhandler);
int PMPI_Errhandler_get(MPI_Comm comm, MPI_Errhandler *errhandler)
int PMPI_Errhandler_set(MPI_Comm comm, MPI_Errhandler errhandler)
int PMPI_Error_class(int errorcode, int *errorclass);
int PMPI_Error_string(int errorcode, char *string, int *resultlen);
int PMPI_Exscan(void *sendbuf, void *recvbuf, int count,
int PMPI_Iexscan(void *sendbuf, void *recvbuf, int count,
int PMPI_File_c2f(MPI_File file);
MPI_File PMPI_File_f2c(int file);
int PMPI_File_call_errhandler(MPI_File fh, int errorcode);
int PMPI_File_create_errhandler(MPI_File_errhandler_function *function,
int PMPI_File_set_errhandler( MPI_File file, MPI_Errhandler errhandler);
int PMPI_File_get_errhandler( MPI_File file, MPI_Errhandler *errhandler);
int PMPI_File_open(MPI_Comm comm, char *filename, int amode,
int PMPI_File_close(MPI_File *fh);
int PMPI_File_delete(char *filename, MPI_Info info);
int PMPI_File_set_size(MPI_File fh, MPI_Offset size);
int PMPI_File_preallocate(MPI_File fh, MPI_Offset size);
int PMPI_File_get_size(MPI_File fh, MPI_Offset *size);
int PMPI_File_get_group(MPI_File fh, MPI_Group *group);
int PMPI_File_get_amode(MPI_File fh, int *amode);
int PMPI_File_set_info(MPI_File fh, MPI_Info info);
int PMPI_File_get_info(MPI_File fh, MPI_Info *info_used);
int PMPI_File_set_view(MPI_File fh, MPI_Offset disp, MPI_Datatype etype,
int PMPI_File_get_view(MPI_File fh, MPI_Offset *disp,
int PMPI_File_read_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at_all(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_iread_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_iwrite_at(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read(MPI_File fh, void *buf, int count,
int PMPI_File_read_all(MPI_File fh, void *buf, int count,
int PMPI_File_write(MPI_File fh, void *buf, int count,
int PMPI_File_write_all(MPI_File fh, void *buf, int count,
int PMPI_File_iread(MPI_File fh, void *buf, int count,
int PMPI_File_iwrite(MPI_File fh, void *buf, int count,
int PMPI_File_seek(MPI_File fh, MPI_Offset offset, int whence);
int PMPI_File_get_position(MPI_File fh, MPI_Offset *offset);
int PMPI_File_get_byte_offset(MPI_File fh, MPI_Offset offset,
MPI_Offset *disp);
int PMPI_File_read_shared(MPI_File fh, void *buf, int count,
int PMPI_File_write_shared(MPI_File fh, void *buf, int count,
int PMPI_File_iread_shared(MPI_File fh, void *buf, int count,
int PMPI_File_iwrite_shared(MPI_File fh, void *buf, int count,
int PMPI_File_read_ordered(MPI_File fh, void *buf, int count,
int PMPI_File_write_ordered(MPI_File fh, void *buf, int count,
int PMPI_File_seek_shared(MPI_File fh, MPI_Offset offset, int whence);
int PMPI_File_get_position_shared(MPI_File fh, MPI_Offset *offset);
int PMPI_File_read_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_read_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_at_all_begin(MPI_File fh, MPI_Offset offset, void *buf,
int PMPI_File_write_at_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_read_all_begin(MPI_File fh, void *buf, int count,
int PMPI_File_read_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_all_begin(MPI_File fh, void *buf, int count,
int PMPI_File_write_all_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_read_ordered_begin(MPI_File fh, void *buf, int count,
int PMPI_File_read_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_write_ordered_begin(MPI_File fh, void *buf, int count,
int PMPI_File_write_ordered_end(MPI_File fh, void *buf, MPI_Status *status);
int PMPI_File_get_type_extent(MPI_File fh, MPI_Datatype datatype,
MPI_Aint *extent);
int PMPI_File_set_atomicity(MPI_File fh, int flag);
int PMPI_File_get_atomicity(MPI_File fh, int *flag);
int PMPI_File_sync(MPI_File fh);
int PMPI_Finalize(void);
int PMPI_Finalized(int *flag);
int PMPI_Free_mem(void *base);
int PMPI_Gather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Igather(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Gatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Igatherv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Get_address(void *location, MPI_Aint *address);
int PMPI_Get_count(MPI_Status *status, MPI_Datatype datatype, int *count);
int PMPI_Get_elements(MPI_Status *status, MPI_Datatype datatype,
int *count);
int PMPI_Get(void *origin_addr, int origin_count,
int PMPI_Get_processor_name(char *name, int *resultlen);
int PMPI_Get_version(int *version, int *subversion);
int PMPI_Graph_create(MPI_Comm comm_old, int nnodes, int *index,
int PMPI_Graph_get(MPI_Comm comm, int maxindex, int maxedges,
int PMPI_Graph_map(MPI_Comm comm, int nnodes, int *index, int *edges,
int *newrank);
int PMPI_Graph_neighbors_count(MPI_Comm comm, int rank, int *nneighbors);
int PMPI_Graph_neighbors(MPI_Comm comm, int rank, int maxneighbors,
int *neighbors);
int PMPI_Graphdims_get(MPI_Comm comm, int *nnodes, int *nedges);
int PMPI_Grequest_complete(MPI_Request request);
int PMPI_Grequest_start(MPI_Grequest_query_function *query_fn,
int PMPI_Group_c2f(MPI_Group group);
int PMPI_Group_compare(MPI_Group group1, MPI_Group group2, int *result);
int PMPI_Group_difference(MPI_Group group1, MPI_Group group2,
int PMPI_Group_excl(MPI_Group group, int n, int *ranks,
MPI_Group PMPI_Group_f2c(int group);
int PMPI_Group_free(MPI_Group *group);
int PMPI_Group_incl(MPI_Group group, int n, int *ranks,
int PMPI_Group_intersection(MPI_Group group1, MPI_Group group2,
int PMPI_Group_range_excl(MPI_Group group, int n, int ranges[][3],
int PMPI_Group_range_incl(MPI_Group group, int n, int ranges[][3],
int PMPI_Group_rank(MPI_Group group, int *rank);
int PMPI_Group_size(MPI_Group group, int *size);
int PMPI_Group_translate_ranks(MPI_Group group1, int n, int *ranks1,
int PMPI_Group_union(MPI_Group group1, MPI_Group group2,
int PMPI_Ibsend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Improbe(int source, int tag, MPI_Comm comm,
int PMPI_Imrecv(void *buf, int count, MPI_Datatype type,
int PMPI_Info_c2f(MPI_Info info);
int PMPI_Info_create(MPI_Info *info);
int PMPI_Info_delete(MPI_Info info, char *key);
int PMPI_Info_dup(MPI_Info info, MPI_Info *newinfo);
MPI_Info PMPI_Info_f2c(int info);
int PMPI_Info_free(MPI_Info *info);
int PMPI_Info_get(MPI_Info info, char *key, int valuelen,
int PMPI_Info_get_nkeys(MPI_Info info, int *nkeys);
int PMPI_Info_get_nthkey(MPI_Info info, int n, char *key);
int PMPI_Info_get_valuelen(MPI_Info info, char *key, int *valuelen,
int *flag);
int PMPI_Info_set(MPI_Info info, char *key, char *value);
int PMPI_Init(int *argc, char ***argv);
int PMPI_Initialized(int *flag);
int PMPI_Init_thread(int *argc, char ***argv, int required,
int *provided);
int PMPI_Intercomm_create(MPI_Comm local_comm, int local_leader,
int PMPI_Intercomm_merge(MPI_Comm intercomm, int high,
int PMPI_Iprobe(int source, int tag, MPI_Comm comm, int *flag,
int PMPI_Irecv(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Irsend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Isend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Issend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Is_thread_main(int *flag);
int PMPI_Keyval_create(MPI_Copy_function *copy_fn,
int PMPI_Keyval_free(int *keyval)
int PMPI_Lookup_name(char *service_name, MPI_Info info, char *port_name);
int PMPI_Message_c2f(MPI_Message message);
MPI_Message PMPI_Message_f2c(int message);
int PMPI_Mprobe(int source, int tag, MPI_Comm comm,
int PMPI_Mrecv(void *buf, int count, MPI_Datatype type,
int PMPI_Op_c2f(MPI_Op op);
int PMPI_Op_commutative(MPI_Op op, int *commute);
int PMPI_Op_create(MPI_User_function *function, int commute, MPI_Op *op);
int PMPI_Open_port(MPI_Info info, char *port_name);
MPI_Op PMPI_Op_f2c(int op);
int PMPI_Op_free(MPI_Op *op);
int PMPI_Pack_external(char *datarep, void *inbuf, int incount,
int PMPI_Pack_external_size(char *datarep, int incount,
int PMPI_Pack(void *inbuf, int incount, MPI_Datatype datatype,
int PMPI_Pack_size(int incount, MPI_Datatype datatype, MPI_Comm comm,
int *size);
int PMPI_Pcontrol(const int level, ...);
int PMPI_Probe(int source, int tag, MPI_Comm comm, MPI_Status *status);
int PMPI_Publish_name(char *service_name, MPI_Info info,
char *port_name);
int PMPI_Put(void *origin_addr, int origin_count, MPI_Datatype origin_datatype,
int PMPI_Query_thread(int *provided);
int PMPI_Recv_init(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Recv(void *buf, int count, MPI_Datatype datatype, int source,
int PMPI_Reduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Ireduce(void *sendbuf, void *recvbuf, int count,
int PMPI_Reduce_local(void *inbuf, void *inoutbuf, int count,
MPI_Datatype datatype, MPI_Op);
int PMPI_Reduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int PMPI_Ireduce_scatter(void *sendbuf, void *recvbuf, int *recvcounts,
int PMPI_Reduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Ireduce_scatter_block(void *sendbuf, void *recvbuf, int recvcount,
int PMPI_Register_datarep(char *datarep,
void *extra_state);
int PMPI_Request_c2f(MPI_Request request);
MPI_Request PMPI_Request_f2c(int request);
int PMPI_Request_free(MPI_Request *request);
int PMPI_Request_get_status(MPI_Request request, int *flag,
int PMPI_Rsend(void *ibuf, int count, MPI_Datatype datatype, int dest,
int PMPI_Rsend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Scan(void *sendbuf, void *recvbuf, int count,
int PMPI_Iscan(void *sendbuf, void *recvbuf, int count,
int PMPI_Scatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Iscatter(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Scatterv(void *sendbuf, int *sendcounts, int *displs,
int PMPI_Iscatterv(void *sendbuf, int *sendcounts, int *displs,
int PMPI_Send_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Send(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Sendrecv(void *sendbuf, int sendcount, MPI_Datatype sendtype,
int PMPI_Sendrecv_replace(void * buf, int count, MPI_Datatype datatype,
int PMPI_Ssend_init(void *buf, int count, MPI_Datatype datatype,
int PMPI_Ssend(void *buf, int count, MPI_Datatype datatype, int dest,
int PMPI_Start(MPI_Request *request);
int PMPI_Startall(int count, MPI_Request *array_of_requests);
int PMPI_Status_c2f(MPI_Status *c_status, int *f_status);
int PMPI_Status_f2c(int *f_status, MPI_Status *c_status);
int PMPI_Status_set_cancelled(MPI_Status *status, int flag);
int PMPI_Status_set_elements(MPI_Status *status, MPI_Datatype datatype,
int count);
int PMPI_Testall(int count, MPI_Request array_of_requests[], int *flag,
int PMPI_Testany(int count, MPI_Request array_of_requests[], int *index, int *flag, MPI_Status *status);
int PMPI_Test(MPI_Request *request, int *flag, MPI_Status *status);
int PMPI_Test_cancelled(MPI_Status *status, int *flag);
int PMPI_Testsome(int incount, MPI_Request array_of_requests[],
int PMPI_Topo_test(MPI_Comm comm, int *status);
int PMPI_Type_c2f(MPI_Datatype datatype);
int PMPI_Type_commit(MPI_Datatype *type);
int PMPI_Type_contiguous(int count, MPI_Datatype oldtype,
int PMPI_Type_create_darray(int size, int rank, int ndims,
int PMPI_Type_create_f90_complex(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_integer(int r, MPI_Datatype *newtype);
int PMPI_Type_create_f90_real(int p, int r, MPI_Datatype *newtype);
int PMPI_Type_create_hindexed(int count, int array_of_blocklengths[],
int PMPI_Type_create_hvector(int count, int blocklength, MPI_Aint stride,
int PMPI_Type_create_keyval(MPI_Type_copy_attr_function *type_copy_attr_fn,
int PMPI_Type_create_indexed_block(int count, int blocklength,
int PMPI_Type_create_struct(int count, int array_of_block_lengths[],
int PMPI_Type_create_subarray(int ndims, int size_array[], int subsize_array[],
int PMPI_Type_create_resized(MPI_Datatype oldtype, MPI_Aint lb,
int PMPI_Type_delete_attr(MPI_Datatype type, int type_keyval);
int PMPI_Type_dup(MPI_Datatype type, MPI_Datatype *newtype);
int PMPI_Type_extent(MPI_Datatype type, MPI_Aint *extent)
int PMPI_Type_free(MPI_Datatype *type);
int PMPI_Type_free_keyval(int *type_keyval);
MPI_Datatype PMPI_Type_f2c(int datatype);
int PMPI_Type_get_attr(MPI_Datatype type, int type_keyval,
int PMPI_Type_get_contents(MPI_Datatype mtype, int max_integers,
int PMPI_Type_get_envelope(MPI_Datatype type, int *num_integers,
int *combiner);
int PMPI_Type_get_extent(MPI_Datatype type, MPI_Aint *lb,
MPI_Aint *extent);
int PMPI_Type_get_name(MPI_Datatype type, char *type_name,
int *resultlen);
int PMPI_Type_get_true_extent(MPI_Datatype datatype, MPI_Aint *true_lb,
int PMPI_Type_hindexed(int count, int array_of_blocklengths[],
int PMPI_Type_hvector(int count, int blocklength, MPI_Aint stride,
int PMPI_Type_indexed(int count, int array_of_blocklengths[],
int PMPI_Type_lb(MPI_Datatype type, MPI_Aint *lb)
int PMPI_Type_match_size(int typeclass, int size, MPI_Datatype *type);
int PMPI_Type_set_attr(MPI_Datatype type, int type_keyval,
void *attr_val);
int PMPI_Type_set_name(MPI_Datatype type, char *type_name);
int PMPI_Type_size(MPI_Datatype type, int *size);
int PMPI_Type_struct(int count, int array_of_blocklengths[],
int PMPI_Type_ub(MPI_Datatype mtype, MPI_Aint *ub)
int PMPI_Type_vector(int count, int blocklength, int stride,
int PMPI_Unpack(void *inbuf, int insize, int *position,
MPI_Comm comm);
int PMPI_Unpublish_name(char *service_name, MPI_Info info,
char *port_name);
int PMPI_Unpack_external (char *datarep, void *inbuf, MPI_Aint insize,
int PMPI_Waitall(int count, MPI_Request *array_of_requests,
int PMPI_Waitany(int count, MPI_Request *array_of_requests,
int PMPI_Wait(MPI_Request *request, MPI_Status *status);
int PMPI_Waitsome(int incount, MPI_Request *array_of_requests,
int PMPI_Win_c2f(MPI_Win win);
int PMPI_Win_call_errhandler(MPI_Win win, int errorcode);
int PMPI_Win_complete(MPI_Win win);
int PMPI_Win_create(void *base, MPI_Aint size, int disp_unit,
int PMPI_Win_create_errhandler(MPI_Win_errhandler_function *function,
int PMPI_Win_create_keyval(MPI_Win_copy_attr_function *win_copy_attr_fn,
int PMPI_Win_delete_attr(MPI_Win win, int win_keyval);
MPI_Win PMPI_Win_f2c(int win);
int PMPI_Win_fence(int assert, MPI_Win win);
int PMPI_Win_free(MPI_Win *win);
int PMPI_Win_free_keyval(int *win_keyval);
int PMPI_Win_get_attr(MPI_Win win, int win_keyval,
int PMPI_Win_get_errhandler(MPI_Win win, MPI_Errhandler *errhandler);
int PMPI_Win_get_group(MPI_Win win, MPI_Group *group);
int PMPI_Win_get_name(MPI_Win win, char *win_name, int *resultlen);
int PMPI_Win_lock(int lock_type, int rank, int assert, MPI_Win win);
int PMPI_Win_post(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_set_attr(MPI_Win win, int win_keyval, void *attribute_val);
int PMPI_Win_set_errhandler(MPI_Win win, MPI_Errhandler errhandler);
int PMPI_Win_set_name(MPI_Win win, char *win_name);
int PMPI_Win_start(MPI_Group group, int assert, MPI_Win win);
int PMPI_Win_test(MPI_Win win, int *flag);
int PMPI_Win_unlock(int rank, MPI_Win win);
int PMPI_Win_wait(MPI_Win win);
double PMPI_Wtick(void);
double PMPI_Wtime(void);
#line 2281 "/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu/mpi.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c"
int ompi_major = 1;
int ompi_minor = 6;
int ompi_release = 3;
Defined "HAVE_OMPI_MAJOR_VERSION" to "1"
Defined "HAVE_OMPI_MINOR_VERSION" to "6"
Defined "HAVE_OMPI_RELEASE_VERSION" to "3"
Checking for functions [MPI_Alltoallw] in library [] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
/* Override any gcc2 internal prototype to avoid an error. */
char MPI_Alltoallw();
static void _check_MPI_Alltoallw() { MPI_Alltoallw(); }
int main() {
_check_MPI_Alltoallw();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Checking for functions [MPI_Type_create_indexed_block] in library [] []
Pushing language C
Successful compile:
Source:
char MPI_Type_create_indexed_block();
static void _check_MPI_Type_create_indexed_block() { MPI_Type_create_indexed_block(); }
int main() {
_check_MPI_Type_create_indexed_block();;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "HAVE_MPI_ALLTOALLW" to "1"
Checking for functions [MPI_Win_create] in library [] []
Pushing language C
Successful compile:
Source:
char MPI_Win_create();
static void _check_MPI_Win_create() { MPI_Win_create(); }
int main() {
_check_MPI_Win_create();;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "HAVE_MPI_WIN_CREATE" to "1"
Defined "HAVE_MPI_REPLACE" to "1"
Checking for functions [MPI_Comm_spawn MPI_Type_get_envelope MPI_Type_get_extent MPI_Type_dup MPI_Init_thread MPI_Iallreduce MPI_Ibarrier MPI_Finalized MPI_Exscan] in library [] []
Pushing language C
Successful compile:
Source:
char MPI_Comm_spawn();
static void _check_MPI_Comm_spawn() { MPI_Comm_spawn(); }
char MPI_Type_get_envelope();
static void _check_MPI_Type_get_envelope() { MPI_Type_get_envelope(); }
char MPI_Type_get_extent();
static void _check_MPI_Type_get_extent() { MPI_Type_get_extent(); }
char MPI_Type_dup();
static void _check_MPI_Type_dup() { MPI_Type_dup(); }
char MPI_Init_thread();
static void _check_MPI_Init_thread() { MPI_Init_thread(); }
char MPI_Iallreduce();
static void _check_MPI_Iallreduce() { MPI_Iallreduce(); }
char MPI_Ibarrier();
static void _check_MPI_Ibarrier() { MPI_Ibarrier(); }
char MPI_Finalized();
static void _check_MPI_Finalized() { MPI_Finalized(); }
char MPI_Exscan();
static void _check_MPI_Exscan() { MPI_Exscan(); }
int main() {
_check_MPI_Comm_spawn();
_check_MPI_Type_get_envelope();
_check_MPI_Type_get_extent();
_check_MPI_Type_dup();
_check_MPI_Init_thread();
_check_MPI_Iallreduce();
_check_MPI_Ibarrier();
_check_MPI_Finalized();
_check_MPI_Exscan();;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "HAVE_MPI_COMM_SPAWN" to "1"
Defined "HAVE_MPI_TYPE_GET_ENVELOPE" to "1"
Defined "HAVE_MPI_TYPE_GET_EXTENT" to "1"
Defined "HAVE_MPI_TYPE_DUP" to "1"
Defined "HAVE_MPI_INIT_THREAD" to "1"
Defined "HAVE_MPI_IALLREDUCE" to "1"
Defined "HAVE_MPI_IBARRIER" to "1"
Defined "HAVE_MPI_FINALIZED" to "1"
Defined "HAVE_MPI_EXSCAN" to "1"
Checking for functions [MPIX_Iallreduce] in library [] []
Pushing language C
Successful compile:
Source:
char MPIX_Iallreduce();
static void _check_MPIX_Iallreduce() { MPIX_Iallreduce(); }
int main() {
_check_MPIX_Iallreduce();;
return 0;
Pushing language C
Popping language C
Possible ERROR while running linker: exit code 256
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_MPIX_Iallreduce':
conftest.c:(.text+0x4): undefined reference to `MPIX_Iallreduce'
Popping language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c
Possible ERROR while running compiler:
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.c", line 6: warning: variable "combiner" was declared but never referenced
int combiner = MPI_COMBINER_DUP;;
Source:
#include <mpi.h>
int main() {
return 0;
Defined "HAVE_MPI_COMBINER_DUP" to "1"
stderr:
int combiner = MPI_COMBINER_CONTIGUOUS;;
Source:
#include <mpi.h>
int main() {
return 0;
Defined "HAVE_MPI_COMBINER_CONTIGUOUS" to "1"
Checking for functions [MPIDI_CH3I_sock_set] in library [] []
Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_set();
static void _check_MPIDI_CH3I_sock_set() { MPIDI_CH3I_sock_set(); }
int main() {
_check_MPIDI_CH3I_sock_set();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_set':
conftest.c:(.text+0x4): undefined reference to `MPIDI_CH3I_sock_set'
Popping language C
Checking for functions [MPIDI_CH3I_sock_fixed_nbc_progress] in library [] []
Pushing language C
Successful compile:
Source:
char MPIDI_CH3I_sock_fixed_nbc_progress();
static void _check_MPIDI_CH3I_sock_fixed_nbc_progress() { MPIDI_CH3I_sock_fixed_nbc_progress(); }
int main() {
_check_MPIDI_CH3I_sock_fixed_nbc_progress();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_MPIDI_CH3I_sock_fixed_nbc_progress':
conftest.c:(.text+0x4): undefined reference to `MPIDI_CH3I_sock_fixed_nbc_progress'
Popping language C
TEST checkSharedLibrary from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:130)
TESTING: checkSharedLibrary from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:130)
Sets flag indicating if MPI libraries are shared or not and
determines if MPI libraries CANNOT be used by shared libraries
TEST configureMPIEXEC from config.packages.MPI(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/MPI.py:143)
TESTING: configureMPIEXEC from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:143)
Checking for mpiexec
Checking for program /opt/FJSVtclang/check/mpiexec...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpiexec...found
Defined make macro "MPIEXEC" to "mpiexec"
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int init(int argc, char *argv[]) {
int isInitialized;
MPI_Init(&argc, &argv);
MPI_Initialized(&isInitialized);
return (int) isInitialized;
Pushing language C
Popping language C
Executing: /usr/bin/ar cr /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/libconftest.a /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/conftest.o ; /usr/bin/ranlib /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI/libconftest.a
Successful compile:
Source:
#include <mpi.h>
#ifdef __cplusplus
extern "C"
#endif
int checkInit(void) {
int isInitialized;
if (isInitialized) MPI_Finalize();
Pushing language C
Popping language C
Successful compile:
Source:
#include <stdio.h>
#include <stdlib.h>
#ifdef PETSC_HAVE_DLFCN_H
#include <dlfcn.h>
#endif
int main() {
int argc = 1;
char *argv[2] = {(char *) "conftest", NULL};
void *lib;
int (*init)(int, char **);
int (*checkInit)(void);
lib = dlopen("/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/lib1.a", RTLD_LAZY);
if (!lib) {
fprintf(stderr, "Could not open lib1.so: %s\n", dlerror());
exit(1);
init = (int (*)(int, char **)) dlsym(lib, "init");
if (!init) {
fprintf(stderr, "Could not find initialization function\n");
exit(1);
if (!(*init)(argc, argv)) {
fprintf(stderr, "Could not initialize library\n");
exit(1);
lib = dlopen("/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/lib2.a", RTLD_LAZY);
if (!lib) {
fprintf(stderr, "Could not open lib2.so: %s\n", dlerror());
exit(1);
checkInit = (int (*)(void)) dlsym(lib, "checkInit");
if (!checkInit) {
fprintf(stderr, "Could not find initialization check function\n");
exit(1);
if (!(*checkInit)()) {
fprintf(stderr, "Did not link with shared library\n");
exit(2);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest to see if it can be run
Executing: mpiexec /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest
ERROR while running executable: Could not execute "mpiexec /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest":
[ERR.] PLE 0015 plexec cannot execute as sequential job.
Library was not shared
Popping language C
TEST alternateConfigureLibrary from config.packages.tetgen(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.tetgen(config/BuildSystem/config/package.py:630)
Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.yaml(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.yaml(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.ctetgen(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.ctetgen(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.sprng(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.sprng(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.ssl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/ssl.py:23)
TESTING: configureLibrary from config.packages.ssl(config/BuildSystem/config/packages/ssl.py:23)
Checking for a functional ssl
Checking for library in Compiler specific search SSL: []
TEST check from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [SSLv23_method] in library [] []
Pushing language C
Successful compile:
Source:
char SSLv23_method();
static void _check_SSLv23_method() { SSLv23_method(); }
int main() {
_check_SSLv23_method();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_SSLv23_method':
conftest.c:(.text+0x4): undefined reference to `SSLv23_method'
Popping language C
Checking for library in Compiler specific search SSL: ['libssl.a', 'libcrypto.a']
Checking for functions [SSLv23_method] in library ['libssl.a', 'libcrypto.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lssl -lcrypto -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_LIBSSL" to "1"
Defined "HAVE_LIBCRYPTO" to "1"
Popping language C
Checking for headers Compiler specific search SSL: []
Pushing language C
TEST checkInclude from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['openssl/ssl.h'] in []
Checking include with compiler flags var CPPFLAGS []
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/e_os2.h"
#line 1 "/usr/include/openssl/opensslconf.h"
#line 1 "/usr/include/openssl/opensslconf-sparc64.h"
#line 57 "/usr/include/openssl/opensslconf-sparc64.h"
#line 69 "/usr/include/openssl/opensslconf-sparc64.h"
#line 115 "/usr/include/openssl/opensslconf-sparc64.h"
#line 132 "/usr/include/openssl/opensslconf-sparc64.h"
#line 142 "/usr/include/openssl/opensslconf-sparc64.h"
#line 180 "/usr/include/openssl/opensslconf-sparc64.h"
#line 188 "/usr/include/openssl/opensslconf-sparc64.h"
#line 205 "/usr/include/openssl/opensslconf-sparc64.h"
#line 212 "/usr/include/openssl/opensslconf-sparc64.h"
#line 26 "/usr/include/openssl/opensslconf.h"
#line 33 "/usr/include/openssl/opensslconf.h"
#line 57 "/usr/include/openssl/e_os2.h"
#line 128 "/usr/include/openssl/e_os2.h"
#line 137 "/usr/include/openssl/e_os2.h"
#line 151 "/usr/include/openssl/e_os2.h"
#line 165 "/usr/include/openssl/e_os2.h"
#line 206 "/usr/include/openssl/e_os2.h"
#line 229 "/usr/include/openssl/e_os2.h"
#line 264 "/usr/include/openssl/e_os2.h"
#line 288 "/usr/include/openssl/e_os2.h"
#line 174 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/comp.h"
#line 1 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 26 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef int wchar_t;
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 34 "/usr/include/stdlib.h"
#line 95 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) ;
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
extern long long int atoll (const char *__nptr)
extern double strtod (const char * __nptr,
char ** __endptr)
extern float strtof (const char * __nptr,
char ** __endptr) ;
extern long double strtold (const char * __nptr,
char ** __endptr)
extern long int strtol (const char * __nptr,
char ** __endptr, int __base)
extern unsigned long int strtoul (const char * __nptr,
extern long long int strtoq (const char * __nptr,
extern unsigned long long int strtouq (const char * __nptr,
extern long long int strtoll (const char * __nptr,
extern unsigned long long int strtoull (const char * __nptr,
#line 274 "/usr/include/stdlib.h"
#line 305 "/usr/include/stdlib.h"
extern char *l64a (long int __n) ;
extern long int a64l (const char *__s)
#line 1 "/usr/include/sys/types.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 28 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 32 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
#line 419 "/usr/include/time.h"
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 35 "/usr/include/sys/select.h"
typedef __sigset_t sigset_t;
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 45 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 221 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 271 "/usr/include/sys/types.h"
#line 321 "/usr/include/stdlib.h"
extern long int random (void) ;
extern void srandom (unsigned int __seed) ;
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) ;
extern char *setstate (char *__statebuf) ;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data * __buf,
int32_t * __result) ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char * __statebuf,
size_t __statelen,
struct random_data * __buf)
extern int setstate_r (char * __statebuf,
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
extern int rand_r (unsigned int *__seed) ;
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3]) ;
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) ;
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
unsigned long long int __a;
extern int drand48_r (struct drand48_data * __buffer,
double * __result) ;
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data * __buffer,
long int * __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data * __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) ;
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
extern void free (void *__ptr) ;
extern void cfree (void *__ptr) ;
#line 1 "/usr/include/alloca.h"
#line 23 "/usr/include/alloca.h"
#line 26 "/usr/include/alloca.h"
extern void *alloca (size_t __size) ;
#line 498 "/usr/include/stdlib.h"
extern void *valloc (size_t __size) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) ;
extern int atexit (void (*__func) (void)) ;
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) ;
extern void _Exit (int __status) ;
extern char *getenv (const char *__name) ;
extern char *__secure_getenv (const char *__name)
extern int putenv (char *__string) ;
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) ;
extern int clearenv (void) ;
extern char *mktemp (char *__template) ;
extern int mkstemp (char *__template) ;
#line 607 "/usr/include/stdlib.h"
extern char *mkdtemp (char *__template) ;
#line 638 "/usr/include/stdlib.h"
extern int system (const char *__command) ;
#line 655 "/usr/include/stdlib.h"
extern char *realpath (const char * __name,
char * __resolved) ;
typedef int (*__compar_fn_t) (const void *, const void *);
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) ;
extern int abs (int __x) ;
extern long int labs (long int __x) ;
extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
extern lldiv_t lldiv (long long int __numer,
long long int __denom)
extern char *ecvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *fcvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *gcvt (double __value, int __ndigit, char *__buf)
extern char *qecvt (long double __value, int __ndigit,
int * __decpt, int * __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int * __decpt,
int * __sign, char * __buf,
size_t __len) ;
extern int fcvt_r (double __value, int __ndigit, int * __decpt,
size_t __len) ;
extern int qecvt_r (long double __value, int __ndigit,
int * __decpt, int * __sign,
char * __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) ;
extern int mbtowc (wchar_t * __pwc,
const char * __s, size_t __n) ;
extern int wctomb (char *__s, wchar_t __wchar) ;
extern size_t mbstowcs (wchar_t * __pwcs,
extern size_t wcstombs (char * __s,
const wchar_t * __pwcs, size_t __n)
extern int rpmatch (const char *__response) ;
#line 820 "/usr/include/stdlib.h"
extern int posix_openpt (int __oflag) ;
#line 851 "/usr/include/stdlib.h"
#line 862 "/usr/include/stdlib.h"
extern int getloadavg (double __loadavg[], int __nelem)
#line 879 "/usr/include/stdlib.h"
#line 121 "/usr/include/openssl/crypto.h"
#line 123 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/stdio.h"
#line 29 "/usr/include/stdio.h"
#line 35 "/usr/include/stdio.h"
struct _IO_FILE;
typedef struct _IO_FILE FILE;
typedef struct _IO_FILE __FILE;
#line 1 "/usr/include/libio.h"
#line 1 "/usr/include/_G_config.h"
#line 16 "/usr/include/_G_config.h"
#line 1 "/usr/include/wchar.h"
typedef unsigned int wint_t;
#line 53 "/usr/include/wchar.h"
#line 64 "/usr/include/wchar.h"
#line 74 "/usr/include/wchar.h"
typedef struct
int __count;
union
wint_t __wch;
char __wchb[4];
} __value;
} __mbstate_t;
#line 841 "/usr/include/wchar.h"
#line 21 "/usr/include/_G_config.h"
typedef struct
__off_t __pos;
__mbstate_t __state;
} _G_fpos_t;
typedef struct
__off64_t __pos;
} _G_fpos64_t;
#line 52 "/usr/include/_G_config.h"
typedef int _G_int16_t ;
typedef int _G_int32_t ;
typedef unsigned int _G_uint16_t ;
typedef unsigned int _G_uint32_t ;
#line 74 "/usr/include/_G_config.h"
#line 33 "/usr/include/libio.h"
#line 49 "/usr/include/libio.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stdarg.h"
typedef void *va_list;
#line 27 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stdarg.h"
#line 38 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stdarg.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stdarg.h"
#line 54 "/usr/include/libio.h"
#line 73 "/usr/include/libio.h"
#line 88 "/usr/include/libio.h"
#line 104 "/usr/include/libio.h"
#line 113 "/usr/include/libio.h"
#line 139 "/usr/include/libio.h"
#line 149 "/usr/include/libio.h"
#line 168 "/usr/include/libio.h"
struct _IO_jump_t; struct _IO_FILE;
#line 180 "/usr/include/libio.h"
typedef void _IO_lock_t;
struct _IO_marker {
struct _IO_marker *_next;
struct _IO_FILE *_sbuf;
int _pos;
#line 203 "/usr/include/libio.h"
enum __codecvt_result
__codecvt_ok,
__codecvt_partial,
__codecvt_error,
__codecvt_noconv
#line 270 "/usr/include/libio.h"
struct _IO_FILE {
int _flags;
char* _IO_read_ptr;
char* _IO_read_end;
char* _IO_read_base;
char* _IO_write_base;
char* _IO_write_ptr;
char* _IO_write_end;
char* _IO_buf_base;
char* _IO_buf_end;
char *_IO_save_base;
char *_IO_backup_base;
char *_IO_save_end;
struct _IO_marker *_markers;
struct _IO_FILE *_chain;
int _fileno;
int _flags2;
__off_t _old_offset;
unsigned short _cur_column;
signed char _vtable_offset;
char _shortbuf[1];
_IO_lock_t *_lock;
#line 319 "/usr/include/libio.h"
__off64_t _offset;
#line 328 "/usr/include/libio.h"
void *__pad1;
void *__pad2;
void *__pad3;
void *__pad4;
size_t __pad5;
int _mode;
char _unused2[15 * sizeof (int) - 4 * sizeof (void *) - sizeof (size_t)];
typedef struct _IO_FILE _IO_FILE;
struct _IO_FILE_plus;
extern struct _IO_FILE_plus _IO_2_1_stdin_;
extern struct _IO_FILE_plus _IO_2_1_stdout_;
extern struct _IO_FILE_plus _IO_2_1_stderr_;
#line 358 "/usr/include/libio.h"
typedef __ssize_t __io_read_fn (void *__cookie, char *__buf, size_t __nbytes);
typedef __ssize_t __io_write_fn (void *__cookie, const char *__buf,
size_t __n);
typedef int __io_seek_fn (void *__cookie, __off64_t *__pos, int __w);
typedef int __io_close_fn (void *__cookie);
#line 410 "/usr/include/libio.h"
extern int __underflow (_IO_FILE *);
extern int __uflow (_IO_FILE *);
extern int __overflow (_IO_FILE *, int);
#line 442 "/usr/include/libio.h"
#line 454 "/usr/include/libio.h"
extern int _IO_getc (_IO_FILE *__fp);
extern int _IO_putc (int __c, _IO_FILE *__fp);
extern int _IO_feof (_IO_FILE *__fp) ;
extern int _IO_ferror (_IO_FILE *__fp) ;
extern int _IO_peekc_locked (_IO_FILE *__fp);
extern void _IO_flockfile (_IO_FILE *) ;
extern void _IO_funlockfile (_IO_FILE *) ;
extern int _IO_ftrylockfile (_IO_FILE *) ;
#line 487 "/usr/include/libio.h"
extern int _IO_vfscanf (_IO_FILE * , const char * ,
va_list, int *);
extern int _IO_vfprintf (_IO_FILE *, const char *,
va_list);
extern __ssize_t _IO_padn (_IO_FILE *, int, __ssize_t);
extern size_t _IO_sgetn (_IO_FILE *, void *, size_t);
extern __off64_t _IO_seekoff (_IO_FILE *, __off64_t, int, int);
extern __off64_t _IO_seekpos (_IO_FILE *, __off64_t, int);
extern void _IO_free_backup_area (_IO_FILE *) ;
#line 544 "/usr/include/libio.h"
#line 76 "/usr/include/stdio.h"
#line 87 "/usr/include/stdio.h"
typedef _G_fpos_t fpos_t;
#line 1 "/usr/include/bits/stdio_lim.h"
#line 142 "/usr/include/stdio.h"
extern struct _IO_FILE *stdin;
extern struct _IO_FILE *stdout;
extern struct _IO_FILE *stderr;
extern int remove (const char *__filename) ;
extern int rename (const char *__old, const char *__new) ;
extern FILE *tmpfile (void) ;
#line 182 "/usr/include/stdio.h"
extern char *tmpnam (char *__s) ;
extern char *tmpnam_r (char *__s) ;
extern char *tempnam (const char *__dir, const char *__pfx)
extern int fclose (FILE *__stream);
extern int fflush (FILE *__stream);
extern int fflush_unlocked (FILE *__stream);
#line 243 "/usr/include/stdio.h"
extern FILE *fopen (const char * __filename,
const char * __modes) ;
extern FILE *freopen (const char * __filename,
const char * __modes,
FILE * __stream) ;
#line 274 "/usr/include/stdio.h"
#line 282 "/usr/include/stdio.h"
extern FILE *fdopen (int __fd, const char *__modes) ;
#line 304 "/usr/include/stdio.h"
extern void setbuf (FILE * __stream, char * __buf) ;
extern int setvbuf (FILE * __stream, char * __buf,
int __modes, size_t __n) ;
extern void setbuffer (FILE * __stream, char * __buf,
size_t __size) ;
extern void setlinebuf (FILE *__stream) ;
extern int fprintf (FILE * __stream,
const char * __format, ...);
extern int printf (const char * __format, ...);
extern int sprintf (char * __s,
const char * __format, ...) ;
extern int vfprintf (FILE * __s, const char * __format,
va_list __arg);
extern int vprintf (const char * __format, va_list __arg);
extern int vsprintf (char * __s, const char * __format,
va_list __arg) ;
extern int snprintf (char * __s, size_t __maxlen,
extern int vsnprintf (char * __s, size_t __maxlen,
#line 398 "/usr/include/stdio.h"
extern int fscanf (FILE * __stream,
extern int scanf (const char * __format, ...) ;
extern int sscanf (const char * __s,
#line 432 "/usr/include/stdio.h"
extern int __isoc99_fscanf (FILE * __stream,
extern int __isoc99_scanf (const char * __format, ...) ;
extern int __isoc99_sscanf (const char * __s,
extern int vfscanf (FILE * __s, const char * __format,
va_list __arg)
extern int vscanf (const char * __format, va_list __arg)
extern int vsscanf (const char * __s,
#line 488 "/usr/include/stdio.h"
extern int __isoc99_vfscanf (FILE * __s,
va_list __arg) ;
extern int __isoc99_vscanf (const char * __format,
va_list __arg) ;
extern int __isoc99_vsscanf (const char * __s,
va_list __arg) ;
extern int fgetc (FILE *__stream);
extern int getc (FILE *__stream);
extern int getchar (void);
extern int getc_unlocked (FILE *__stream);
extern int getchar_unlocked (void);
extern int fgetc_unlocked (FILE *__stream);
extern int fputc (int __c, FILE *__stream);
extern int putc (int __c, FILE *__stream);
extern int putchar (int __c);
extern int fputc_unlocked (int __c, FILE *__stream);
extern int putc_unlocked (int __c, FILE *__stream);
extern int putchar_unlocked (int __c);
extern int getw (FILE *__stream);
extern int putw (int __w, FILE *__stream);
extern char *fgets (char * __s, int __n, FILE * __stream)
extern char *gets (char *__s) ;
#line 623 "/usr/include/stdio.h"
#line 653 "/usr/include/stdio.h"
extern int fputs (const char * __s, FILE * __stream);
extern int puts (const char *__s);
extern int ungetc (int __c, FILE *__stream);
extern size_t fread (void * __ptr, size_t __size,
size_t __n, FILE * __stream) ;
extern size_t fwrite (const void * __ptr, size_t __size,
size_t __n, FILE * __s) ;
#line 700 "/usr/include/stdio.h"
extern size_t fread_unlocked (void * __ptr, size_t __size,
extern size_t fwrite_unlocked (const void * __ptr, size_t __size,
extern int fseek (FILE *__stream, long int __off, int __whence);
extern long int ftell (FILE *__stream) ;
extern void rewind (FILE *__stream);
extern int fseeko (FILE *__stream, __off_t __off, int __whence);
extern __off_t ftello (FILE *__stream) ;
#line 762 "/usr/include/stdio.h"
extern int fgetpos (FILE * __stream, fpos_t * __pos);
extern int fsetpos (FILE *__stream, const fpos_t *__pos);
#line 786 "/usr/include/stdio.h"
#line 794 "/usr/include/stdio.h"
extern void clearerr (FILE *__stream) ;
extern int feof (FILE *__stream) ;
extern int ferror (FILE *__stream) ;
extern void clearerr_unlocked (FILE *__stream) ;
extern int feof_unlocked (FILE *__stream) ;
extern int ferror_unlocked (FILE *__stream) ;
extern void perror (const char *__s);
#line 1 "/usr/include/bits/sys_errlist.h"
extern int sys_nerr;
extern const char *const sys_errlist[];
#line 825 "/usr/include/stdio.h"
extern int fileno (FILE *__stream) ;
extern int fileno_unlocked (FILE *__stream) ;
extern FILE *popen (const char *__command, const char *__modes) ;
extern int pclose (FILE *__stream);
extern char *ctermid (char *__s) ;
#line 878 "/usr/include/stdio.h"
extern void flockfile (FILE *__stream) ;
extern int ftrylockfile (FILE *__stream) ;
extern void funlockfile (FILE *__stream) ;
#line 901 "/usr/include/stdio.h"
#line 913 "/usr/include/stdio.h"
#line 126 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/openssl/stack.h"
typedef struct stack_st {
int num;
char **data;
int sorted;
int num_alloc;
int (*comp) (const char *const *, const char *const *);
} STACK;
int sk_num(const STACK *);
char *sk_value(const STACK *, int);
char *sk_set(STACK *, int, char *);
STACK *sk_new(int (*cmp) (const char *const *, const char *const *));
STACK *sk_new_null(void);
void sk_free(STACK *);
void sk_pop_free(STACK * st, void (*func) (void *));
int sk_insert(STACK * sk, char *data, int where);
char *sk_delete(STACK * st, int loc);
char *sk_delete_ptr(STACK * st, char *p);
int sk_find(STACK * st, char *data);
int sk_find_ex(STACK * st, char *data);
int sk_push(STACK * st, char *data);
int sk_unshift(STACK * st, char *data);
char *sk_shift(STACK * st);
char *sk_pop(STACK * st);
void sk_zero(STACK * st);
int (*sk_set_cmp_func(STACK * sk, int (*c) (const char *const *,
const char *const *)))
STACK *sk_dup(STACK * st);
void sk_sort(STACK * st);
int sk_is_sorted(const STACK * st);
#line 129 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/openssl/safestack.h"
#line 158 "/usr/include/openssl/safestack.h"
#line 207 "/usr/include/openssl/safestack.h"
#line 247 "/usr/include/openssl/safestack.h"
#line 269 "/usr/include/openssl/safestack.h"
#line 291 "/usr/include/openssl/safestack.h"
#line 313 "/usr/include/openssl/safestack.h"
#line 335 "/usr/include/openssl/safestack.h"
#line 357 "/usr/include/openssl/safestack.h"
#line 379 "/usr/include/openssl/safestack.h"
#line 401 "/usr/include/openssl/safestack.h"
#line 423 "/usr/include/openssl/safestack.h"
#line 445 "/usr/include/openssl/safestack.h"
#line 467 "/usr/include/openssl/safestack.h"
#line 489 "/usr/include/openssl/safestack.h"
#line 511 "/usr/include/openssl/safestack.h"
#line 533 "/usr/include/openssl/safestack.h"
#line 555 "/usr/include/openssl/safestack.h"
#line 577 "/usr/include/openssl/safestack.h"
#line 599 "/usr/include/openssl/safestack.h"
#line 621 "/usr/include/openssl/safestack.h"
#line 643 "/usr/include/openssl/safestack.h"
#line 665 "/usr/include/openssl/safestack.h"
#line 687 "/usr/include/openssl/safestack.h"
#line 709 "/usr/include/openssl/safestack.h"
#line 731 "/usr/include/openssl/safestack.h"
#line 753 "/usr/include/openssl/safestack.h"
#line 775 "/usr/include/openssl/safestack.h"
#line 797 "/usr/include/openssl/safestack.h"
#line 819 "/usr/include/openssl/safestack.h"
#line 841 "/usr/include/openssl/safestack.h"
#line 863 "/usr/include/openssl/safestack.h"
#line 885 "/usr/include/openssl/safestack.h"
#line 907 "/usr/include/openssl/safestack.h"
#line 929 "/usr/include/openssl/safestack.h"
#line 951 "/usr/include/openssl/safestack.h"
#line 973 "/usr/include/openssl/safestack.h"
#line 995 "/usr/include/openssl/safestack.h"
#line 1017 "/usr/include/openssl/safestack.h"
#line 1039 "/usr/include/openssl/safestack.h"
#line 1061 "/usr/include/openssl/safestack.h"
#line 1083 "/usr/include/openssl/safestack.h"
#line 1105 "/usr/include/openssl/safestack.h"
#line 1127 "/usr/include/openssl/safestack.h"
#line 1149 "/usr/include/openssl/safestack.h"
#line 1171 "/usr/include/openssl/safestack.h"
#line 1193 "/usr/include/openssl/safestack.h"
#line 1215 "/usr/include/openssl/safestack.h"
#line 1237 "/usr/include/openssl/safestack.h"
#line 1259 "/usr/include/openssl/safestack.h"
#line 1281 "/usr/include/openssl/safestack.h"
#line 1303 "/usr/include/openssl/safestack.h"
#line 1325 "/usr/include/openssl/safestack.h"
#line 1347 "/usr/include/openssl/safestack.h"
#line 1369 "/usr/include/openssl/safestack.h"
#line 1391 "/usr/include/openssl/safestack.h"
#line 1413 "/usr/include/openssl/safestack.h"
#line 1435 "/usr/include/openssl/safestack.h"
#line 1457 "/usr/include/openssl/safestack.h"
#line 1479 "/usr/include/openssl/safestack.h"
#line 1501 "/usr/include/openssl/safestack.h"
#line 1523 "/usr/include/openssl/safestack.h"
#line 1545 "/usr/include/openssl/safestack.h"
#line 1567 "/usr/include/openssl/safestack.h"
#line 1589 "/usr/include/openssl/safestack.h"
#line 1611 "/usr/include/openssl/safestack.h"
#line 1633 "/usr/include/openssl/safestack.h"
#line 1655 "/usr/include/openssl/safestack.h"
#line 1677 "/usr/include/openssl/safestack.h"
#line 1699 "/usr/include/openssl/safestack.h"
#line 1721 "/usr/include/openssl/safestack.h"
#line 1743 "/usr/include/openssl/safestack.h"
#line 1765 "/usr/include/openssl/safestack.h"
#line 1787 "/usr/include/openssl/safestack.h"
#line 1796 "/usr/include/openssl/safestack.h"
#line 1805 "/usr/include/openssl/safestack.h"
#line 1814 "/usr/include/openssl/safestack.h"
#line 1823 "/usr/include/openssl/safestack.h"
#line 1832 "/usr/include/openssl/safestack.h"
#line 1841 "/usr/include/openssl/safestack.h"
#line 1850 "/usr/include/openssl/safestack.h"
#line 1859 "/usr/include/openssl/safestack.h"
#line 1868 "/usr/include/openssl/safestack.h"
#line 1877 "/usr/include/openssl/safestack.h"
#line 1886 "/usr/include/openssl/safestack.h"
#line 1895 "/usr/include/openssl/safestack.h"
#line 1904 "/usr/include/openssl/safestack.h"
#line 1913 "/usr/include/openssl/safestack.h"
#line 1922 "/usr/include/openssl/safestack.h"
#line 1931 "/usr/include/openssl/safestack.h"
#line 1940 "/usr/include/openssl/safestack.h"
#line 1949 "/usr/include/openssl/safestack.h"
#line 1958 "/usr/include/openssl/safestack.h"
#line 1967 "/usr/include/openssl/safestack.h"
#line 1976 "/usr/include/openssl/safestack.h"
#line 1985 "/usr/include/openssl/safestack.h"
#line 130 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/openssl/opensslv.h"
#line 36 "/usr/include/openssl/opensslv.h"
#line 131 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/openssl/ossl_typ.h"
#line 59 "/usr/include/openssl/ossl_typ.h"
#line 79 "/usr/include/openssl/ossl_typ.h"
typedef struct asn1_string_st ASN1_INTEGER;
typedef struct asn1_string_st ASN1_ENUMERATED;
typedef struct asn1_string_st ASN1_BIT_STRING;
typedef struct asn1_string_st ASN1_OCTET_STRING;
typedef struct asn1_string_st ASN1_PRINTABLESTRING;
typedef struct asn1_string_st ASN1_T61STRING;
typedef struct asn1_string_st ASN1_IA5STRING;
typedef struct asn1_string_st ASN1_GENERALSTRING;
typedef struct asn1_string_st ASN1_UNIVERSALSTRING;
typedef struct asn1_string_st ASN1_BMPSTRING;
typedef struct asn1_string_st ASN1_UTCTIME;
typedef struct asn1_string_st ASN1_TIME;
typedef struct asn1_string_st ASN1_GENERALIZEDTIME;
typedef struct asn1_string_st ASN1_VISIBLESTRING;
typedef struct asn1_string_st ASN1_UTF8STRING;
typedef int ASN1_BOOLEAN;
typedef int ASN1_NULL;
#line 106 "/usr/include/openssl/ossl_typ.h"
typedef struct bignum_st BIGNUM;
typedef struct bignum_ctx BN_CTX;
typedef struct bn_blinding_st BN_BLINDING;
typedef struct bn_mont_ctx_st BN_MONT_CTX;
typedef struct bn_recp_ctx_st BN_RECP_CTX;
typedef struct bn_gencb_st BN_GENCB;
typedef struct buf_mem_st BUF_MEM;
typedef struct evp_cipher_st EVP_CIPHER;
typedef struct evp_cipher_ctx_st EVP_CIPHER_CTX;
typedef struct env_md_st EVP_MD;
typedef struct env_md_ctx_st EVP_MD_CTX;
typedef struct evp_pkey_st EVP_PKEY;
typedef struct dh_st DH;
typedef struct dh_method DH_METHOD;
typedef struct dsa_st DSA;
typedef struct dsa_method DSA_METHOD;
typedef struct rsa_st RSA;
typedef struct rsa_meth_st RSA_METHOD;
typedef struct rand_meth_st RAND_METHOD;
typedef struct ecdh_method ECDH_METHOD;
typedef struct ecdsa_method ECDSA_METHOD;
typedef struct x509_st X509;
typedef struct X509_algor_st X509_ALGOR;
typedef struct X509_crl_st X509_CRL;
typedef struct X509_name_st X509_NAME;
typedef struct x509_store_st X509_STORE;
typedef struct x509_store_ctx_st X509_STORE_CTX;
typedef struct ssl_st SSL;
typedef struct ssl_ctx_st SSL_CTX;
typedef struct v3_ext_ctx X509V3_CTX;
typedef struct conf_st CONF;
typedef struct store_st STORE;
typedef struct store_method_st STORE_METHOD;
typedef struct ui_st UI;
typedef struct ui_method_st UI_METHOD;
typedef struct st_ERR_FNS ERR_FNS;
typedef struct engine_st ENGINE;
typedef struct X509_POLICY_NODE_st X509_POLICY_NODE;
typedef struct X509_POLICY_LEVEL_st X509_POLICY_LEVEL;
typedef struct X509_POLICY_TREE_st X509_POLICY_TREE;
typedef struct X509_POLICY_CACHE_st X509_POLICY_CACHE;
typedef struct crypto_ex_data_st CRYPTO_EX_DATA;
typedef int CRYPTO_EX_new (void *parent, void *ptr, CRYPTO_EX_DATA *ad,
int idx, long argl, void *argp);
typedef void CRYPTO_EX_free (void *parent, void *ptr, CRYPTO_EX_DATA *ad,
typedef int CRYPTO_EX_dup (CRYPTO_EX_DATA *to, CRYPTO_EX_DATA *from,
void *from_d, int idx, long argl, void *argp);
typedef struct ocsp_req_ctx_st OCSP_REQ_CTX;
typedef struct ocsp_response_st OCSP_RESPONSE;
typedef struct ocsp_responder_id_st OCSP_RESPID;
#line 132 "/usr/include/openssl/crypto.h"
#line 1 "/usr/include/openssl/symhacks.h"
#line 59 "/usr/include/openssl/symhacks.h"
#line 401 "/usr/include/openssl/symhacks.h"
#line 434 "/usr/include/openssl/symhacks.h"
#line 142 "/usr/include/openssl/crypto.h"
#line 173 "/usr/include/openssl/crypto.h"
typedef struct openssl_item_st {
int code;
void *value;
size_t value_size;
size_t *value_length;
} OPENSSL_ITEM;
#line 233 "/usr/include/openssl/crypto.h"
#line 259 "/usr/include/openssl/crypto.h"
typedef struct {
int references;
struct CRYPTO_dynlock_value *data;
} CRYPTO_dynlock;
typedef struct bio_st BIO_dummy;
struct crypto_ex_data_st {
STACK *sk;
int dummy;
typedef struct crypto_ex_data_func_st {
long argl;
void *argp;
CRYPTO_EX_new *new_func;
CRYPTO_EX_free *free_func;
CRYPTO_EX_dup *dup_func;
} CRYPTO_EX_DATA_FUNCS;
#line 338 "/usr/include/openssl/crypto.h"
void CRYPTO_malloc_debug_init(void);
int CRYPTO_mem_ctrl(int mode);
int CRYPTO_is_mem_check_on(void);
#line 387 "/usr/include/openssl/crypto.h"
const char *SSLeay_version(int type);
unsigned long SSLeay(void);
int OPENSSL_issetugid(void);
typedef struct st_CRYPTO_EX_DATA_IMPL CRYPTO_EX_DATA_IMPL;
const CRYPTO_EX_DATA_IMPL *CRYPTO_get_ex_data_implementation(void);
int CRYPTO_set_ex_data_implementation(const CRYPTO_EX_DATA_IMPL *i);
int CRYPTO_ex_data_new_class(void);
int CRYPTO_get_ex_new_index(int class_index, long argl, void *argp,
CRYPTO_EX_new *new_func, CRYPTO_EX_dup *dup_func,
CRYPTO_EX_free *free_func);
int CRYPTO_new_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_dup_ex_data(int class_index, CRYPTO_EX_DATA *to,
CRYPTO_EX_DATA *from);
void CRYPTO_free_ex_data(int class_index, void *obj, CRYPTO_EX_DATA *ad);
int CRYPTO_set_ex_data(CRYPTO_EX_DATA *ad, int idx, void *val);
void *CRYPTO_get_ex_data(const CRYPTO_EX_DATA *ad, int idx);
void CRYPTO_cleanup_all_ex_data(void);
int CRYPTO_get_new_lockid(char *name);
int CRYPTO_num_locks(void);
void CRYPTO_lock(int mode, int type, const char *file, int line);
void CRYPTO_set_locking_callback(void (*func) (int mode, int type,
const char *file, int line));
void (*CRYPTO_get_locking_callback(void)) (int mode, int type,
void CRYPTO_set_add_lock_callback(int (*func)
(int *num, int mount, int type,
int (*CRYPTO_get_add_lock_callback(void)) (int *num, int mount, int type,
void CRYPTO_set_id_callback(unsigned long (*func) (void));
unsigned long (*CRYPTO_get_id_callback(void)) (void);
unsigned long CRYPTO_thread_id(void);
const char *CRYPTO_get_lock_name(int type);
int CRYPTO_add_lock(int *pointer, int amount, int type, const char *file,
int line);
void int_CRYPTO_set_do_dynlock_callback(void (*do_dynlock_cb)
int CRYPTO_get_new_dynlockid(void);
void CRYPTO_destroy_dynlockid(int i);
struct CRYPTO_dynlock_value *CRYPTO_get_dynlock_value(int i);
void CRYPTO_set_dynlock_create_callback(struct CRYPTO_dynlock_value
*(*dyn_create_function) (const char
*file,
int line));
void CRYPTO_set_dynlock_lock_callback(void (*dyn_lock_function)
(int mode,
struct CRYPTO_dynlock_value *l,
void CRYPTO_set_dynlock_destroy_callback(void (*dyn_destroy_function)
(struct CRYPTO_dynlock_value *l,
*(*CRYPTO_get_dynlock_create_callback(void)) (const char *file, int line);
void (*CRYPTO_get_dynlock_lock_callback(void)) (int mode,
*l, const char *file,
int line);
void (*CRYPTO_get_dynlock_destroy_callback(void)) (struct CRYPTO_dynlock_value
int line);
int CRYPTO_set_mem_functions(void *(*m) (size_t), void *(*r) (void *, size_t),
void (*f) (void *));
int CRYPTO_set_locked_mem_functions(void *(*m) (size_t),
void (*free_func) (void *));
int CRYPTO_set_mem_ex_functions(void *(*m) (size_t, const char *, int),
void *(*r) (void *, size_t, const char *,
int), void (*f) (void *));
int CRYPTO_set_locked_mem_ex_functions(void *(*m) (size_t, const char *, int),
int CRYPTO_set_mem_debug_functions(void (*m)
(void *, int, const char *, int, int),
void (*r) (void *, void *, int,
void (*f) (void *, int), void (*so) (long),
long (*go) (void));
void CRYPTO_set_mem_info_functions(int (*push_info_fn)
(const char *info, const char *file,
int line), int (*pop_info_fn) (void),
int (*remove_all_info_fn) (void));
void CRYPTO_get_mem_functions(void *(**m) (size_t),
void *(**r) (void *, size_t),
void (**f) (void *));
void CRYPTO_get_locked_mem_functions(void *(**m) (size_t),
void CRYPTO_get_mem_ex_functions(void *(**m) (size_t, const char *, int),
void *(**r) (void *, size_t, const char *,
int), void (**f) (void *));
void CRYPTO_get_locked_mem_ex_functions(void
void CRYPTO_get_mem_debug_functions(void (**m)
void (**r) (void *, void *, int,
void (**f) (void *, int),
void (**so) (long), long (**go) (void));
void *CRYPTO_malloc_locked(int num, const char *file, int line);
void CRYPTO_free_locked(void *);
void *CRYPTO_malloc(int num, const char *file, int line);
char *CRYPTO_strdup(const char *str, const char *file, int line);
void CRYPTO_free(void *);
void *CRYPTO_realloc(void *addr, int num, const char *file, int line);
void *CRYPTO_realloc_clean(void *addr, int old_num, int num, const char *file,
int line);
void *CRYPTO_remalloc(void *addr, int num, const char *file, int line);
void OPENSSL_cleanse(void *ptr, size_t len);
void CRYPTO_set_mem_debug_options(long bits);
long CRYPTO_get_mem_debug_options(void);
int CRYPTO_push_info_(const char *info, const char *file, int line);
int CRYPTO_pop_info(void);
int CRYPTO_remove_all_info(void);
void CRYPTO_dbg_malloc(void *addr, int num, const char *file, int line,
int before_p);
void CRYPTO_dbg_realloc(void *addr1, void *addr2, int num, const char *file,
int line, int before_p);
void CRYPTO_dbg_free(void *addr, int before_p);
void CRYPTO_dbg_set_options(long bits);
long CRYPTO_dbg_get_options(void);
int CRYPTO_dbg_push_info(const char *info, const char *file, int line);
int CRYPTO_dbg_pop_info(void);
int CRYPTO_dbg_remove_all_info(void);
void CRYPTO_mem_leaks_fp(FILE *);
void CRYPTO_mem_leaks(struct bio_st *bio);
typedef void *CRYPTO_MEM_LEAK_CB (unsigned long, const char *, int, int,
void *);
void CRYPTO_mem_leaks_cb(CRYPTO_MEM_LEAK_CB *cb);
void OpenSSLDie(const char *file, int line, const char *assertion);
unsigned long *OPENSSL_ia32cap_loc(void);
int OPENSSL_isservice(void);
#line 633 "/usr/include/openssl/crypto.h"
void OPENSSL_init(void);
int CRYPTO_memcmp(const void *a, const void *b, size_t len);
void ERR_load_CRYPTO_strings(void);
#line 673 "/usr/include/openssl/crypto.h"
#line 6 "/usr/include/openssl/comp.h"
typedef struct comp_ctx_st COMP_CTX;
typedef struct comp_method_st {
int type;
const char *name;
int (*init) (COMP_CTX *ctx);
void (*finish) (COMP_CTX *ctx);
int (*compress) (COMP_CTX *ctx,
unsigned char *out, unsigned int olen,
unsigned char *in, unsigned int ilen);
int (*expand) (COMP_CTX *ctx,
long (*ctrl) (void);
long (*callback_ctrl) (void);
} COMP_METHOD;
struct comp_ctx_st {
COMP_METHOD *meth;
unsigned long compress_in;
unsigned long compress_out;
unsigned long expand_in;
unsigned long expand_out;
CRYPTO_EX_DATA ex_data;
COMP_CTX *COMP_CTX_new(COMP_METHOD *meth);
void COMP_CTX_free(COMP_CTX *ctx);
int COMP_compress_block(COMP_CTX *ctx, unsigned char *out, int olen,
unsigned char *in, int ilen);
int COMP_expand_block(COMP_CTX *ctx, unsigned char *out, int olen,
COMP_METHOD *COMP_rle(void);
COMP_METHOD *COMP_zlib(void);
void COMP_zlib_cleanup(void);
void ERR_load_COMP_strings(void);
#line 177 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/bio.h"
#line 63 "/usr/include/openssl/bio.h"
#line 19 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stdarg.h"
#line 68 "/usr/include/openssl/bio.h"
#line 99 "/usr/include/openssl/bio.h"
#line 127 "/usr/include/openssl/bio.h"
#line 141 "/usr/include/openssl/bio.h"
#line 155 "/usr/include/openssl/bio.h"
#line 178 "/usr/include/openssl/bio.h"
typedef struct bio_st BIO;
void BIO_set_flags(BIO *b, int flags);
int BIO_test_flags(const BIO *b, int flags);
void BIO_clear_flags(BIO *b, int flags);
#line 221 "/usr/include/openssl/bio.h"
#line 258 "/usr/include/openssl/bio.h"
long (*BIO_get_callback(const BIO *b)) (struct bio_st *, int, const char *,
int, long, long);
void BIO_set_callback(BIO *b,
long (*callback) (struct bio_st *, int, const char *,
int, long, long));
char *BIO_get_callback_arg(const BIO *b);
void BIO_set_callback_arg(BIO *b, char *arg);
const char *BIO_method_name(const BIO *b);
int BIO_method_type(const BIO *b);
typedef void bio_info_cb (struct bio_st *, int, const char *, int, long,
long);
typedef struct bio_method_st {
int type;
const char *name;
int (*bwrite) (BIO *, const char *, int);
int (*bread) (BIO *, char *, int);
int (*bputs) (BIO *, const char *);
int (*bgets) (BIO *, char *, int);
long (*ctrl) (BIO *, int, long, void *);
int (*create) (BIO *);
int (*destroy) (BIO *);
long (*callback_ctrl) (BIO *, int, bio_info_cb *);
} BIO_METHOD;
#line 309 "/usr/include/openssl/bio.h"
struct bio_st {
BIO_METHOD *method;
long (*callback) (struct bio_st *, int, const char *, int, long, long);
char *cb_arg;
int init;
int shutdown;
int flags;
int retry_reason;
int num;
void *ptr;
struct bio_st *next_bio;
struct bio_st *prev_bio;
int references;
unsigned long num_read;
unsigned long num_write;
typedef struct bio_f_buffer_ctx_struct {
int ibuf_size;
int obuf_size;
char *ibuf;
int ibuf_len;
int ibuf_off;
char *obuf;
int obuf_len;
int obuf_off;
} BIO_F_BUFFER_CTX;
#line 363 "/usr/include/openssl/bio.h"
#line 404 "/usr/include/openssl/bio.h"
#line 418 "/usr/include/openssl/bio.h"
#line 431 "/usr/include/openssl/bio.h"
#line 495 "/usr/include/openssl/bio.h"
#line 511 "/usr/include/openssl/bio.h"
#line 537 "/usr/include/openssl/bio.h"
size_t BIO_ctrl_pending(BIO *b);
size_t BIO_ctrl_wpending(BIO *b);
size_t BIO_ctrl_get_write_guarantee(BIO *b);
size_t BIO_ctrl_get_read_request(BIO *b);
int BIO_ctrl_reset_read_request(BIO *b);
#line 574 "/usr/include/openssl/bio.h"
int BIO_set_ex_data(BIO *bio, int idx, void *data);
void *BIO_get_ex_data(BIO *bio, int idx);
int BIO_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
unsigned long BIO_number_read(BIO *bio);
unsigned long BIO_number_written(BIO *bio);
#line 594 "/usr/include/openssl/bio.h"
BIO_METHOD *BIO_s_file(void);
BIO *BIO_new_file(const char *filename, const char *mode);
BIO *BIO_new_fp(FILE *stream, int close_flag);
BIO *BIO_new(BIO_METHOD *type);
int BIO_set(BIO *a, BIO_METHOD *type);
int BIO_free(BIO *a);
void BIO_vfree(BIO *a);
int BIO_read(BIO *b, void *data, int len);
int BIO_gets(BIO *bp, char *buf, int size);
int BIO_write(BIO *b, const void *data, int len);
int BIO_puts(BIO *bp, const char *buf);
int BIO_indent(BIO *b, int indent, int max);
long BIO_ctrl(BIO *bp, int cmd, long larg, void *parg);
long BIO_callback_ctrl(BIO *b, int cmd,
void (*fp) (struct bio_st *, int, const char *, int,
long, long));
char *BIO_ptr_ctrl(BIO *bp, int cmd, long larg);
long BIO_int_ctrl(BIO *bp, int cmd, long larg, int iarg);
BIO *BIO_push(BIO *b, BIO *append);
BIO *BIO_pop(BIO *b);
void BIO_free_all(BIO *a);
BIO *BIO_find_type(BIO *b, int bio_type);
BIO *BIO_next(BIO *b);
BIO *BIO_get_retry_BIO(BIO *bio, int *reason);
int BIO_get_retry_reason(BIO *bio);
BIO *BIO_dup_chain(BIO *in);
int BIO_nread0(BIO *bio, char **buf);
int BIO_nread(BIO *bio, char **buf, int num);
int BIO_nwrite0(BIO *bio, char **buf);
int BIO_nwrite(BIO *bio, char **buf, int num);
long BIO_debug_callback(BIO *bio, int cmd, const char *argp, int argi,
long argl, long ret);
BIO_METHOD *BIO_s_mem(void);
BIO *BIO_new_mem_buf(void *buf, int len);
BIO_METHOD *BIO_s_socket(void);
BIO_METHOD *BIO_s_connect(void);
BIO_METHOD *BIO_s_accept(void);
BIO_METHOD *BIO_s_fd(void);
BIO_METHOD *BIO_s_log(void);
BIO_METHOD *BIO_s_bio(void);
BIO_METHOD *BIO_s_null(void);
BIO_METHOD *BIO_f_null(void);
BIO_METHOD *BIO_f_buffer(void);
BIO_METHOD *BIO_f_nbio_test(void);
BIO_METHOD *BIO_s_datagram(void);
int BIO_sock_should_retry(int i);
int BIO_sock_non_fatal_error(int error);
int BIO_dgram_non_fatal_error(int error);
int BIO_fd_should_retry(int i);
int BIO_fd_non_fatal_error(int error);
int BIO_dump_cb(int (*cb) (const void *data, size_t len, void *u),
void *u, const char *s, int len);
int BIO_dump_indent_cb(int (*cb) (const void *data, size_t len, void *u),
void *u, const char *s, int len, int indent);
int BIO_dump(BIO *b, const char *bytes, int len);
int BIO_dump_indent(BIO *b, const char *bytes, int len, int indent);
int BIO_dump_fp(FILE *fp, const char *s, int len);
int BIO_dump_indent_fp(FILE *fp, const char *s, int len, int indent);
struct hostent *BIO_gethostbyname(const char *name);
int BIO_sock_error(int sock);
int BIO_socket_ioctl(int fd, long type, void *arg);
int BIO_socket_nbio(int fd, int mode);
int BIO_get_port(const char *str, unsigned short *port_ptr);
int BIO_get_host_ip(const char *str, unsigned char *ip);
int BIO_get_accept_socket(char *host_port, int mode);
int BIO_accept(int sock, char **ip_port);
int BIO_sock_init(void);
void BIO_sock_cleanup(void);
int BIO_set_tcp_ndelay(int sock, int turn_on);
BIO *BIO_new_socket(int sock, int close_flag);
BIO *BIO_new_dgram(int fd, int close_flag);
BIO *BIO_new_fd(int fd, int close_flag);
BIO *BIO_new_connect(char *host_port);
BIO *BIO_new_accept(char *host_port);
int BIO_new_bio_pair(BIO **bio1, size_t writebuf1,
BIO **bio2, size_t writebuf2);
void BIO_copy_next_retry(BIO *b);
int BIO_printf(BIO *bio, const char *format, ...)
int BIO_vprintf(BIO *bio, const char *format, va_list args)
int BIO_snprintf(char *buf, size_t n, const char *format, ...)
int BIO_vsnprintf(char *buf, size_t n, const char *format, va_list args)
void ERR_load_BIO_strings(void);
#line 776 "/usr/include/openssl/bio.h"
#line 807 "/usr/include/openssl/bio.h"
#line 180 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/x509.h"
#line 68 "/usr/include/openssl/x509.h"
#line 436 "/usr/include/openssl/symhacks.h"
#line 69 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/buffer.h"
typedef long ptrdiff_t;
#line 69 "/usr/include/openssl/buffer.h"
struct buf_mem_st {
int length;
char *data;
int max;
BUF_MEM *BUF_MEM_new(void);
void BUF_MEM_free(BUF_MEM *a);
int BUF_MEM_grow(BUF_MEM *str, int len);
int BUF_MEM_grow_clean(BUF_MEM *str, int len);
char *BUF_strdup(const char *str);
char *BUF_strndup(const char *str, size_t siz);
void *BUF_memdup(const void *data, size_t siz);
size_t BUF_strlcpy(char *dst, const char *src, size_t siz);
size_t BUF_strlcat(char *dst, const char *src, size_t siz);
void ERR_load_BUF_strings(void);
#line 111 "/usr/include/openssl/buffer.h"
#line 71 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/evp.h"
#line 67 "/usr/include/openssl/evp.h"
#line 73 "/usr/include/openssl/evp.h"
#line 1 "/usr/include/openssl/objects.h"
#line 1 "/usr/include/openssl/obj_mac.h"
#line 66 "/usr/include/openssl/objects.h"
#line 963 "/usr/include/openssl/objects.h"
#line 1 "/usr/include/openssl/asn1.h"
#line 30 "/usr/include/time.h"
#line 40 "/usr/include/time.h"
#line 43 "/usr/include/bits/time.h"
#line 44 "/usr/include/time.h"
typedef __clock_t clock_t;
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
struct sigevent;
#line 179 "/usr/include/time.h"
extern clock_t clock (void) ;
extern time_t time (time_t *__timer) ;
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) ;
extern size_t strftime (char * __s, size_t __maxsize,
const struct tm * __tp) ;
#line 212 "/usr/include/time.h"
#line 227 "/usr/include/time.h"
extern struct tm *gmtime (const time_t *__timer) ;
extern struct tm *localtime (const time_t *__timer) ;
extern struct tm *gmtime_r (const time_t * __timer,
struct tm * __tp) ;
extern struct tm *localtime_r (const time_t * __timer,
struct tm * __tp) ;
extern char *asctime (const struct tm *__tp) ;
extern char *ctime (const time_t *__timer) ;
extern char *asctime_r (const struct tm * __tp,
char * __buf) ;
extern char *ctime_r (const time_t * __timer,
char * __buf) ;
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) ;
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) ;
extern time_t timegm (struct tm *__tp) ;
extern time_t timelocal (struct tm *__tp) ;
extern int dysize (int __year) ;
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
extern int timer_create (clockid_t __clock_id,
struct sigevent * __evp,
timer_t * __timerid) ;
extern int timer_delete (timer_t __timerid) ;
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec * __value,
struct itimerspec * __ovalue) ;
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) ;
#line 400 "/usr/include/time.h"
#line 415 "/usr/include/time.h"
#line 63 "/usr/include/openssl/asn1.h"
#line 64 "/usr/include/openssl/asn1.h"
#line 71 "/usr/include/openssl/asn1.h"
#line 1 "/usr/include/openssl/bn.h"
#line 76 "/usr/include/openssl/bn.h"
#line 119 "/usr/include/openssl/bn.h"
#line 143 "/usr/include/openssl/bn.h"
#line 169 "/usr/include/openssl/bn.h"
#line 200 "/usr/include/openssl/bn.h"
#line 223 "/usr/include/openssl/bn.h"
#line 246 "/usr/include/openssl/bn.h"
#line 268 "/usr/include/openssl/bn.h"
#line 288 "/usr/include/openssl/bn.h"
#line 299 "/usr/include/openssl/bn.h"
struct bignum_st {
unsigned long *d;
int top;
int dmax;
int neg;
int flags;
struct bn_mont_ctx_st {
int ri;
BIGNUM RR;
BIGNUM N;
BIGNUM Ni;
unsigned long n0;
int flags;
struct bn_recp_ctx_st {
BIGNUM N;
BIGNUM Nr;
int num_bits;
int shift;
int flags;
struct bn_gencb_st {
unsigned int ver;
void *arg;
union {
void (*cb_1) (int, int, void *);
int (*cb_2) (int, int, BN_GENCB *);
} cb;
int BN_GENCB_call(BN_GENCB *cb, int a, int b);
#line 387 "/usr/include/openssl/bn.h"
#line 397 "/usr/include/openssl/bn.h"
#line 410 "/usr/include/openssl/bn.h"
const BIGNUM *BN_value_one(void);
char *BN_options(void);
BN_CTX *BN_CTX_new(void);
void BN_CTX_init(BN_CTX *c);
void BN_CTX_free(BN_CTX *c);
void BN_CTX_start(BN_CTX *ctx);
BIGNUM *BN_CTX_get(BN_CTX *ctx);
void BN_CTX_end(BN_CTX *ctx);
int BN_rand(BIGNUM *rnd, int bits, int top, int bottom);
int BN_pseudo_rand(BIGNUM *rnd, int bits, int top, int bottom);
int BN_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_pseudo_rand_range(BIGNUM *rnd, const BIGNUM *range);
int BN_num_bits(const BIGNUM *a);
int BN_num_bits_word(unsigned long);
BIGNUM *BN_new(void);
void BN_init(BIGNUM *);
void BN_clear_free(BIGNUM *a);
BIGNUM *BN_copy(BIGNUM *a, const BIGNUM *b);
void BN_swap(BIGNUM *a, BIGNUM *b);
BIGNUM *BN_bin2bn(const unsigned char *s, int len, BIGNUM *ret);
int BN_bn2bin(const BIGNUM *a, unsigned char *to);
BIGNUM *BN_mpi2bn(const unsigned char *s, int len, BIGNUM *ret);
int BN_bn2mpi(const BIGNUM *a, unsigned char *to);
int BN_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_usub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_uadd(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
int BN_sqr(BIGNUM *r, const BIGNUM *a, BN_CTX *ctx);
void BN_set_negative(BIGNUM *b, int n);
int BN_div(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m, const BIGNUM *d,
BN_CTX *ctx);
int BN_nnmod(BIGNUM *r, const BIGNUM *m, const BIGNUM *d, BN_CTX *ctx);
int BN_mod_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m,
BN_CTX *ctx);
int BN_mod_add_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
const BIGNUM *m);
int BN_mod_sub(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m,
BN_CTX *ctx);
int BN_mod_sub_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
const BIGNUM *m);
int BN_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, const BIGNUM *m,
BN_CTX *ctx);
int BN_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1(BIGNUM *r, const BIGNUM *a, const BIGNUM *m, BN_CTX *ctx);
int BN_mod_lshift1_quick(BIGNUM *r, const BIGNUM *a, const BIGNUM *m);
int BN_mod_lshift(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m,
BN_CTX *ctx);
int BN_mod_lshift_quick(BIGNUM *r, const BIGNUM *a, int n, const BIGNUM *m);
unsigned long BN_mod_word(const BIGNUM *a, unsigned long w);
unsigned long BN_div_word(BIGNUM *a, unsigned long w);
int BN_mul_word(BIGNUM *a, unsigned long w);
int BN_add_word(BIGNUM *a, unsigned long w);
int BN_sub_word(BIGNUM *a, unsigned long w);
int BN_set_word(BIGNUM *a, unsigned long w);
unsigned long BN_get_word(const BIGNUM *a);
int BN_cmp(const BIGNUM *a, const BIGNUM *b);
void BN_free(BIGNUM *a);
int BN_is_bit_set(const BIGNUM *a, int n);
int BN_lshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_lshift1(BIGNUM *r, const BIGNUM *a);
int BN_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_mod_exp_mont(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
const BIGNUM *m, BN_CTX *ctx, BN_MONT_CTX *m_ctx);
int BN_mod_exp_mont_consttime(BIGNUM *rr, const BIGNUM *a, const BIGNUM *p,
BN_MONT_CTX *in_mont);
int BN_mod_exp_mont_word(BIGNUM *r, unsigned long a, const BIGNUM *p,
int BN_mod_exp2_mont(BIGNUM *r, const BIGNUM *a1, const BIGNUM *p1,
const BIGNUM *a2, const BIGNUM *p2, const BIGNUM *m,
int BN_mod_exp_simple(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_mask_bits(BIGNUM *a, int n);
int BN_print_fp(FILE *fp, const BIGNUM *a);
int BN_print(BIO *fp, const BIGNUM *a);
int BN_reciprocal(BIGNUM *r, const BIGNUM *m, int len, BN_CTX *ctx);
int BN_rshift(BIGNUM *r, const BIGNUM *a, int n);
int BN_rshift1(BIGNUM *r, const BIGNUM *a);
void BN_clear(BIGNUM *a);
BIGNUM *BN_dup(const BIGNUM *a);
int BN_ucmp(const BIGNUM *a, const BIGNUM *b);
int BN_set_bit(BIGNUM *a, int n);
int BN_clear_bit(BIGNUM *a, int n);
char *BN_bn2hex(const BIGNUM *a);
char *BN_bn2dec(const BIGNUM *a);
int BN_hex2bn(BIGNUM **a, const char *str);
int BN_dec2bn(BIGNUM **a, const char *str);
int BN_gcd(BIGNUM *r, const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
int BN_kronecker(const BIGNUM *a, const BIGNUM *b, BN_CTX *ctx);
BIGNUM *BN_mod_inverse(BIGNUM *ret,
const BIGNUM *a, const BIGNUM *n, BN_CTX *ctx);
BIGNUM *BN_mod_sqrt(BIGNUM *ret,
void BN_consttime_swap(unsigned long swap, BIGNUM *a, BIGNUM *b, int nwords);
BIGNUM *BN_generate_prime(BIGNUM *ret, int bits, int safe,
const BIGNUM *add, const BIGNUM *rem,
void (*callback) (int, int, void *), void *cb_arg);
int BN_is_prime(const BIGNUM *p, int nchecks,
BN_CTX *ctx, void *cb_arg);
int BN_is_prime_fasttest(const BIGNUM *p, int nchecks,
void (*callback) (int, int, void *), BN_CTX *ctx,
void *cb_arg, int do_trial_division);
int BN_generate_prime_ex(BIGNUM *ret, int bits, int safe, const BIGNUM *add,
const BIGNUM *rem, BN_GENCB *cb);
int BN_is_prime_ex(const BIGNUM *p, int nchecks, BN_CTX *ctx, BN_GENCB *cb);
int BN_is_prime_fasttest_ex(const BIGNUM *p, int nchecks, BN_CTX *ctx,
int do_trial_division, BN_GENCB *cb);
int BN_X931_generate_Xpq(BIGNUM *Xp, BIGNUM *Xq, int nbits, BN_CTX *ctx);
int BN_X931_derive_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2,
const BIGNUM *Xp, const BIGNUM *Xp1,
const BIGNUM *Xp2, const BIGNUM *e, BN_CTX *ctx,
BN_GENCB *cb);
int BN_X931_generate_prime_ex(BIGNUM *p, BIGNUM *p1, BIGNUM *p2, BIGNUM *Xp1,
BIGNUM *Xp2, const BIGNUM *Xp, const BIGNUM *e,
BN_MONT_CTX *BN_MONT_CTX_new(void);
void BN_MONT_CTX_init(BN_MONT_CTX *ctx);
int BN_mod_mul_montgomery(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
BN_MONT_CTX *mont, BN_CTX *ctx);
int BN_from_montgomery(BIGNUM *r, const BIGNUM *a,
void BN_MONT_CTX_free(BN_MONT_CTX *mont);
int BN_MONT_CTX_set(BN_MONT_CTX *mont, const BIGNUM *mod, BN_CTX *ctx);
BN_MONT_CTX *BN_MONT_CTX_copy(BN_MONT_CTX *to, BN_MONT_CTX *from);
BN_MONT_CTX *BN_MONT_CTX_set_locked(BN_MONT_CTX **pmont, int lock,
BN_BLINDING *BN_BLINDING_new(const BIGNUM *A, const BIGNUM *Ai, BIGNUM *mod);
void BN_BLINDING_free(BN_BLINDING *b);
int BN_BLINDING_update(BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_convert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_invert(BIGNUM *n, BN_BLINDING *b, BN_CTX *ctx);
int BN_BLINDING_convert_ex(BIGNUM *n, BIGNUM *r, BN_BLINDING *b, BN_CTX *);
int BN_BLINDING_invert_ex(BIGNUM *n, const BIGNUM *r, BN_BLINDING *b,
BN_CTX *);
unsigned long BN_BLINDING_get_thread_id(const BN_BLINDING *);
void BN_BLINDING_set_thread_id(BN_BLINDING *, unsigned long);
unsigned long BN_BLINDING_get_flags(const BN_BLINDING *);
void BN_BLINDING_set_flags(BN_BLINDING *, unsigned long);
BN_BLINDING *BN_BLINDING_create_param(BN_BLINDING *b,
const BIGNUM *e, BIGNUM *m, BN_CTX *ctx,
int (*bn_mod_exp) (BIGNUM *r,
const BIGNUM *a,
const BIGNUM *p,
const BIGNUM *m,
BN_CTX *ctx,
BN_MONT_CTX *m_ctx),
void BN_set_params(int mul, int high, int low, int mont);
int BN_get_params(int which);
void BN_RECP_CTX_init(BN_RECP_CTX *recp);
BN_RECP_CTX *BN_RECP_CTX_new(void);
void BN_RECP_CTX_free(BN_RECP_CTX *recp);
int BN_RECP_CTX_set(BN_RECP_CTX *recp, const BIGNUM *rdiv, BN_CTX *ctx);
int BN_mod_mul_reciprocal(BIGNUM *r, const BIGNUM *x, const BIGNUM *y,
BN_RECP_CTX *recp, BN_CTX *ctx);
int BN_mod_exp_recp(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int BN_div_recp(BIGNUM *dv, BIGNUM *rem, const BIGNUM *m,
int BN_GF2m_add(BIGNUM *r, const BIGNUM *a, const BIGNUM *b);
int BN_GF2m_mod(BIGNUM *r, const BIGNUM *a, const BIGNUM *p);
int BN_GF2m_mod_mul(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqr(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_GF2m_mod_inv(BIGNUM *r, const BIGNUM *b, const BIGNUM *p, BN_CTX *ctx);
int BN_GF2m_mod_div(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
BN_CTX *ctx);
int BN_GF2m_mod_solve_quad(BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
BN_CTX *ctx);
int BN_GF2m_mod_arr(BIGNUM *r, const BIGNUM *a, const unsigned int p[]);
int BN_GF2m_mod_mul_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
const unsigned int p[], BN_CTX *ctx);
int BN_GF2m_mod_sqr_arr(BIGNUM *r, const BIGNUM *a, const unsigned int p[],
BN_CTX *ctx);
int BN_GF2m_mod_inv_arr(BIGNUM *r, const BIGNUM *b, const unsigned int p[],
BN_CTX *ctx);
int BN_GF2m_mod_div_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_exp_arr(BIGNUM *r, const BIGNUM *a, const BIGNUM *b,
int BN_GF2m_mod_sqrt_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_mod_solve_quad_arr(BIGNUM *r, const BIGNUM *a,
int BN_GF2m_poly2arr(const BIGNUM *a, unsigned int p[], int max);
int BN_GF2m_arr2poly(const unsigned int p[], BIGNUM *a);
int BN_nist_mod_192(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_224(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_256(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_384(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
int BN_nist_mod_521(BIGNUM *r, const BIGNUM *a, const BIGNUM *p, BN_CTX *ctx);
const BIGNUM *BN_get0_nist_prime_192(void);
const BIGNUM *BN_get0_nist_prime_224(void);
const BIGNUM *BN_get0_nist_prime_256(void);
const BIGNUM *BN_get0_nist_prime_384(void);
const BIGNUM *BN_get0_nist_prime_521(void);
BIGNUM *bn_expand2(BIGNUM *a, int words);
BIGNUM *bn_dup_expand(const BIGNUM *a, int words);
#line 796 "/usr/include/openssl/bn.h"
#line 815 "/usr/include/openssl/bn.h"
unsigned long bn_mul_add_words(unsigned long *rp, const unsigned long *ap, int num,
unsigned long w);
unsigned long bn_mul_words(unsigned long *rp, const unsigned long *ap, int num, unsigned long w);
void bn_sqr_words(unsigned long *rp, const unsigned long *ap, int num);
unsigned long bn_div_words(unsigned long h, unsigned long l, unsigned long d);
unsigned long bn_add_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,
int num);
unsigned long bn_sub_words(unsigned long *rp, const unsigned long *ap, const unsigned long *bp,
int num);
BIGNUM *get_rfc2409_prime_768(BIGNUM *bn);
BIGNUM *get_rfc2409_prime_1024(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_1536(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_2048(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_3072(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_4096(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_6144(BIGNUM *bn);
BIGNUM *get_rfc3526_prime_8192(BIGNUM *bn);
int BN_bntest_rand(BIGNUM *rnd, int bits, int top, int bottom);
void ERR_load_BN_strings(void);
#line 892 "/usr/include/openssl/bn.h"
#line 913 "/usr/include/openssl/bn.h"
#line 75 "/usr/include/openssl/asn1.h"
#line 132 "/usr/include/openssl/asn1.h"
#line 152 "/usr/include/openssl/asn1.h"
#line 161 "/usr/include/openssl/asn1.h"
struct X509_algor_st;
typedef struct asn1_ctx_st {
unsigned char *p;
int eos;
int error;
int inf;
int tag;
int xclass;
long slen;
unsigned char *max;
unsigned char *q;
unsigned char **pp;
int line;
} ASN1_CTX;
typedef struct asn1_const_ctx_st {
const unsigned char *p;
int eos;
int error;
int inf;
int tag;
int xclass;
long slen;
const unsigned char *max;
const unsigned char *q;
const unsigned char **pp;
int line;
} ASN1_const_CTX;
typedef struct asn1_object_st {
const char *sn, *ln;
int nid;
int length;
unsigned char *data;
int flags;
} ASN1_OBJECT;
typedef struct asn1_string_st {
int length;
int type;
long flags;
} ASN1_STRING;
typedef struct ASN1_ENCODING_st {
unsigned char *enc;
long len;
int modified;
} ASN1_ENCODING;
typedef struct asn1_string_table_st {
int nid;
long minsize;
long maxsize;
unsigned long mask;
unsigned long flags;
} ASN1_STRING_TABLE;
#line 287 "/usr/include/openssl/asn1.h"
typedef struct ASN1_TEMPLATE_st ASN1_TEMPLATE;
typedef struct ASN1_ITEM_st ASN1_ITEM;
typedef struct ASN1_TLC_st ASN1_TLC;
typedef struct ASN1_VALUE_st ASN1_VALUE;
#line 349 "/usr/include/openssl/asn1.h"
typedef void *d2i_of_void(void * *,const unsigned char * *,long); typedef int i2d_of_void(void *,unsigned char * *);
typedef const ASN1_ITEM ASN1_ITEM_EXP;
#line 430 "/usr/include/openssl/asn1.h"
#line 509 "/usr/include/openssl/asn1.h"
typedef struct asn1_type_st {
int type;
union {
char *ptr;
ASN1_BOOLEAN boolean;
ASN1_STRING *asn1_string;
ASN1_OBJECT *object;
ASN1_INTEGER *integer;
ASN1_ENUMERATED *enumerated;
ASN1_BIT_STRING *bit_string;
ASN1_OCTET_STRING *octet_string;
ASN1_PRINTABLESTRING *printablestring;
ASN1_T61STRING *t61string;
ASN1_IA5STRING *ia5string;
ASN1_GENERALSTRING *generalstring;
ASN1_BMPSTRING *bmpstring;
ASN1_UNIVERSALSTRING *universalstring;
ASN1_UTCTIME *utctime;
ASN1_GENERALIZEDTIME *generalizedtime;
ASN1_VISIBLESTRING *visiblestring;
ASN1_UTF8STRING *utf8string;
ASN1_STRING *set;
ASN1_STRING *sequence;
ASN1_VALUE *asn1_value;
} value;
} ASN1_TYPE;
typedef struct asn1_method_st {
i2d_of_void *i2d;
d2i_of_void *d2i;
void *(*create) (void);
void (*destroy) (void *);
} ASN1_METHOD;
typedef struct asn1_header_st {
ASN1_OCTET_STRING *header;
void *data;
ASN1_METHOD *meth;
} ASN1_HEADER;
typedef struct BIT_STRING_BITNAME_st {
int bitnum;
const char *lname;
const char *sname;
} BIT_STRING_BITNAME;
#line 584 "/usr/include/openssl/asn1.h"
#line 591 "/usr/include/openssl/asn1.h"
#line 598 "/usr/include/openssl/asn1.h"
#line 611 "/usr/include/openssl/asn1.h"
#line 627 "/usr/include/openssl/asn1.h"
#line 634 "/usr/include/openssl/asn1.h"
#line 648 "/usr/include/openssl/asn1.h"
#line 656 "/usr/include/openssl/asn1.h"
#line 664 "/usr/include/openssl/asn1.h"
#line 674 "/usr/include/openssl/asn1.h"
#line 684 "/usr/include/openssl/asn1.h"
#line 696 "/usr/include/openssl/asn1.h"
#line 722 "/usr/include/openssl/asn1.h"
#line 732 "/usr/include/openssl/asn1.h"
#line 742 "/usr/include/openssl/asn1.h"
#line 752 "/usr/include/openssl/asn1.h"
#line 762 "/usr/include/openssl/asn1.h"
ASN1_TYPE *ASN1_TYPE_new(void); void ASN1_TYPE_free(ASN1_TYPE *a); ASN1_TYPE *d2i_ASN1_TYPE(ASN1_TYPE * *a, const unsigned char * *in, long len); int i2d_ASN1_TYPE(ASN1_TYPE *a, unsigned char * *out); extern const ASN1_ITEM ASN1_ANY_it;
int ASN1_TYPE_get(ASN1_TYPE *a);
void ASN1_TYPE_set(ASN1_TYPE *a, int type, void *value);
int ASN1_TYPE_set1(ASN1_TYPE *a, int type, const void *value);
int ASN1_TYPE_cmp(const ASN1_TYPE *a, const ASN1_TYPE *b);
ASN1_OBJECT *ASN1_OBJECT_new(void);
void ASN1_OBJECT_free(ASN1_OBJECT *a);
int i2d_ASN1_OBJECT(ASN1_OBJECT *a, unsigned char **pp);
ASN1_OBJECT *c2i_ASN1_OBJECT(ASN1_OBJECT **a, const unsigned char **pp,
long length);
ASN1_OBJECT *d2i_ASN1_OBJECT(ASN1_OBJECT **a, const unsigned char **pp,
long length);
extern const ASN1_ITEM ASN1_OBJECT_it;
ASN1_STRING *ASN1_STRING_new(void);
void ASN1_STRING_free(ASN1_STRING *a);
ASN1_STRING *ASN1_STRING_dup(ASN1_STRING *a);
ASN1_STRING *ASN1_STRING_type_new(int type);
int ASN1_STRING_cmp(ASN1_STRING *a, ASN1_STRING *b);
int ASN1_STRING_set(ASN1_STRING *str, const void *data, int len);
void ASN1_STRING_set0(ASN1_STRING *str, void *data, int len);
int ASN1_STRING_length(ASN1_STRING *x);
void ASN1_STRING_length_set(ASN1_STRING *x, int n);
int ASN1_STRING_type(ASN1_STRING *x);
unsigned char *ASN1_STRING_data(ASN1_STRING *x);
ASN1_BIT_STRING *ASN1_BIT_STRING_new(void); void ASN1_BIT_STRING_free(ASN1_BIT_STRING *a); ASN1_BIT_STRING *d2i_ASN1_BIT_STRING(ASN1_BIT_STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_BIT_STRING(ASN1_BIT_STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_BIT_STRING_it;
int i2c_ASN1_BIT_STRING(ASN1_BIT_STRING *a, unsigned char **pp);
ASN1_BIT_STRING *c2i_ASN1_BIT_STRING(ASN1_BIT_STRING **a,
const unsigned char **pp, long length);
int ASN1_BIT_STRING_set(ASN1_BIT_STRING *a, unsigned char *d, int length);
int ASN1_BIT_STRING_set_bit(ASN1_BIT_STRING *a, int n, int value);
int ASN1_BIT_STRING_get_bit(ASN1_BIT_STRING *a, int n);
int ASN1_BIT_STRING_name_print(BIO *out, ASN1_BIT_STRING *bs,
BIT_STRING_BITNAME *tbl, int indent);
int ASN1_BIT_STRING_num_asc(char *name, BIT_STRING_BITNAME *tbl);
int ASN1_BIT_STRING_set_asc(ASN1_BIT_STRING *bs, char *name, int value,
int i2d_ASN1_BOOLEAN(int a, unsigned char **pp);
int d2i_ASN1_BOOLEAN(int *a, const unsigned char **pp, long length);
ASN1_INTEGER *ASN1_INTEGER_new(void); void ASN1_INTEGER_free(ASN1_INTEGER *a); ASN1_INTEGER *d2i_ASN1_INTEGER(ASN1_INTEGER * *a, const unsigned char * *in, long len); int i2d_ASN1_INTEGER(ASN1_INTEGER *a, unsigned char * *out); extern const ASN1_ITEM ASN1_INTEGER_it;
int i2c_ASN1_INTEGER(ASN1_INTEGER *a, unsigned char **pp);
ASN1_INTEGER *c2i_ASN1_INTEGER(ASN1_INTEGER **a, const unsigned char **pp,
long length);
ASN1_INTEGER *d2i_ASN1_UINTEGER(ASN1_INTEGER **a, const unsigned char **pp,
long length);
ASN1_INTEGER *ASN1_INTEGER_dup(ASN1_INTEGER *x);
int ASN1_INTEGER_cmp(ASN1_INTEGER *x, ASN1_INTEGER *y);
ASN1_ENUMERATED *ASN1_ENUMERATED_new(void); void ASN1_ENUMERATED_free(ASN1_ENUMERATED *a); ASN1_ENUMERATED *d2i_ASN1_ENUMERATED(ASN1_ENUMERATED * *a, const unsigned char * *in, long len); int i2d_ASN1_ENUMERATED(ASN1_ENUMERATED *a, unsigned char * *out); extern const ASN1_ITEM ASN1_ENUMERATED_it;
int ASN1_UTCTIME_check(ASN1_UTCTIME *a);
ASN1_UTCTIME *ASN1_UTCTIME_set(ASN1_UTCTIME *s, time_t t);
int ASN1_UTCTIME_set_string(ASN1_UTCTIME *s, const char *str);
int ASN1_UTCTIME_cmp_time_t(const ASN1_UTCTIME *s, time_t t);
int ASN1_GENERALIZEDTIME_check(ASN1_GENERALIZEDTIME *a);
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_set(ASN1_GENERALIZEDTIME *s,
time_t t);
int ASN1_GENERALIZEDTIME_set_string(ASN1_GENERALIZEDTIME *s, const char *str);
ASN1_OCTET_STRING *ASN1_OCTET_STRING_new(void); void ASN1_OCTET_STRING_free(ASN1_OCTET_STRING *a); ASN1_OCTET_STRING *d2i_ASN1_OCTET_STRING(ASN1_OCTET_STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_OCTET_STRING(ASN1_OCTET_STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_OCTET_STRING_it;
ASN1_OCTET_STRING *ASN1_OCTET_STRING_dup(ASN1_OCTET_STRING *a);
int ASN1_OCTET_STRING_cmp(ASN1_OCTET_STRING *a, ASN1_OCTET_STRING *b);
int ASN1_OCTET_STRING_set(ASN1_OCTET_STRING *str, const unsigned char *data,
int len);
ASN1_VISIBLESTRING *ASN1_VISIBLESTRING_new(void); void ASN1_VISIBLESTRING_free(ASN1_VISIBLESTRING *a); ASN1_VISIBLESTRING *d2i_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING * *a, const unsigned char * *in, long len); int i2d_ASN1_VISIBLESTRING(ASN1_VISIBLESTRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_VISIBLESTRING_it;
ASN1_UNIVERSALSTRING *ASN1_UNIVERSALSTRING_new(void); void ASN1_UNIVERSALSTRING_free(ASN1_UNIVERSALSTRING *a); ASN1_UNIVERSALSTRING *d2i_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING * *a, const unsigned char * *in, long len); int i2d_ASN1_UNIVERSALSTRING(ASN1_UNIVERSALSTRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_UNIVERSALSTRING_it;
ASN1_UTF8STRING *ASN1_UTF8STRING_new(void); void ASN1_UTF8STRING_free(ASN1_UTF8STRING *a); ASN1_UTF8STRING *d2i_ASN1_UTF8STRING(ASN1_UTF8STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_UTF8STRING(ASN1_UTF8STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_UTF8STRING_it;
ASN1_NULL *ASN1_NULL_new(void); void ASN1_NULL_free(ASN1_NULL *a); ASN1_NULL *d2i_ASN1_NULL(ASN1_NULL * *a, const unsigned char * *in, long len); int i2d_ASN1_NULL(ASN1_NULL *a, unsigned char * *out); extern const ASN1_ITEM ASN1_NULL_it;
ASN1_BMPSTRING *ASN1_BMPSTRING_new(void); void ASN1_BMPSTRING_free(ASN1_BMPSTRING *a); ASN1_BMPSTRING *d2i_ASN1_BMPSTRING(ASN1_BMPSTRING * *a, const unsigned char * *in, long len); int i2d_ASN1_BMPSTRING(ASN1_BMPSTRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_BMPSTRING_it;
int UTF8_getc(const unsigned char *str, int len, unsigned long *val);
int UTF8_putc(unsigned char *str, int len, unsigned long value);
ASN1_STRING *ASN1_PRINTABLE_new(void); void ASN1_PRINTABLE_free(ASN1_STRING *a); ASN1_STRING *d2i_ASN1_PRINTABLE(ASN1_STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_PRINTABLE(ASN1_STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_PRINTABLE_it;
ASN1_STRING *DIRECTORYSTRING_new(void); void DIRECTORYSTRING_free(ASN1_STRING *a); ASN1_STRING *d2i_DIRECTORYSTRING(ASN1_STRING * *a, const unsigned char * *in, long len); int i2d_DIRECTORYSTRING(ASN1_STRING *a, unsigned char * *out); extern const ASN1_ITEM DIRECTORYSTRING_it;
ASN1_STRING *DISPLAYTEXT_new(void); void DISPLAYTEXT_free(ASN1_STRING *a); ASN1_STRING *d2i_DISPLAYTEXT(ASN1_STRING * *a, const unsigned char * *in, long len); int i2d_DISPLAYTEXT(ASN1_STRING *a, unsigned char * *out); extern const ASN1_ITEM DISPLAYTEXT_it;
ASN1_PRINTABLESTRING *ASN1_PRINTABLESTRING_new(void); void ASN1_PRINTABLESTRING_free(ASN1_PRINTABLESTRING *a); ASN1_PRINTABLESTRING *d2i_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING * *a, const unsigned char * *in, long len); int i2d_ASN1_PRINTABLESTRING(ASN1_PRINTABLESTRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_PRINTABLESTRING_it;
ASN1_T61STRING *ASN1_T61STRING_new(void); void ASN1_T61STRING_free(ASN1_T61STRING *a); ASN1_T61STRING *d2i_ASN1_T61STRING(ASN1_T61STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_T61STRING(ASN1_T61STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_T61STRING_it;
ASN1_IA5STRING *ASN1_IA5STRING_new(void); void ASN1_IA5STRING_free(ASN1_IA5STRING *a); ASN1_IA5STRING *d2i_ASN1_IA5STRING(ASN1_IA5STRING * *a, const unsigned char * *in, long len); int i2d_ASN1_IA5STRING(ASN1_IA5STRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_IA5STRING_it;
ASN1_GENERALSTRING *ASN1_GENERALSTRING_new(void); void ASN1_GENERALSTRING_free(ASN1_GENERALSTRING *a); ASN1_GENERALSTRING *d2i_ASN1_GENERALSTRING(ASN1_GENERALSTRING * *a, const unsigned char * *in, long len); int i2d_ASN1_GENERALSTRING(ASN1_GENERALSTRING *a, unsigned char * *out); extern const ASN1_ITEM ASN1_GENERALSTRING_it;
ASN1_UTCTIME *ASN1_UTCTIME_new(void); void ASN1_UTCTIME_free(ASN1_UTCTIME *a); ASN1_UTCTIME *d2i_ASN1_UTCTIME(ASN1_UTCTIME * *a, const unsigned char * *in, long len); int i2d_ASN1_UTCTIME(ASN1_UTCTIME *a, unsigned char * *out); extern const ASN1_ITEM ASN1_UTCTIME_it;
ASN1_GENERALIZEDTIME *ASN1_GENERALIZEDTIME_new(void); void ASN1_GENERALIZEDTIME_free(ASN1_GENERALIZEDTIME *a); ASN1_GENERALIZEDTIME *d2i_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME * *a, const unsigned char * *in, long len); int i2d_ASN1_GENERALIZEDTIME(ASN1_GENERALIZEDTIME *a, unsigned char * *out); extern const ASN1_ITEM ASN1_GENERALIZEDTIME_it;
ASN1_TIME *ASN1_TIME_new(void); void ASN1_TIME_free(ASN1_TIME *a); ASN1_TIME *d2i_ASN1_TIME(ASN1_TIME * *a, const unsigned char * *in, long len); int i2d_ASN1_TIME(ASN1_TIME *a, unsigned char * *out); extern const ASN1_ITEM ASN1_TIME_it;
extern const ASN1_ITEM ASN1_OCTET_STRING_NDEF_it;
ASN1_TIME *ASN1_TIME_set(ASN1_TIME *s, time_t t);
int ASN1_TIME_check(ASN1_TIME *t);
ASN1_GENERALIZEDTIME *ASN1_TIME_to_generalizedtime(ASN1_TIME *t, ASN1_GENERALIZEDTIME
**out);
int i2d_ASN1_SET(STACK * a, unsigned char **pp,
i2d_of_void *i2d, int ex_tag, int ex_class, int is_set);
STACK *d2i_ASN1_SET(STACK ** a, const unsigned char **pp, long length,
d2i_of_void *d2i, void (*free_func) (void *),
int ex_tag, int ex_class);
int i2a_ASN1_INTEGER(BIO *bp, ASN1_INTEGER *a);
int a2i_ASN1_INTEGER(BIO *bp, ASN1_INTEGER *bs, char *buf, int size);
int i2a_ASN1_ENUMERATED(BIO *bp, ASN1_ENUMERATED *a);
int a2i_ASN1_ENUMERATED(BIO *bp, ASN1_ENUMERATED *bs, char *buf, int size);
int i2a_ASN1_OBJECT(BIO *bp, ASN1_OBJECT *a);
int a2i_ASN1_STRING(BIO *bp, ASN1_STRING *bs, char *buf, int size);
int i2a_ASN1_STRING(BIO *bp, ASN1_STRING *a, int type);
int i2t_ASN1_OBJECT(char *buf, int buf_len, ASN1_OBJECT *a);
int a2d_ASN1_OBJECT(unsigned char *out, int olen, const char *buf, int num);
ASN1_OBJECT *ASN1_OBJECT_create(int nid, unsigned char *data, int len,
const char *sn, const char *ln);
int ASN1_INTEGER_set(ASN1_INTEGER *a, long v);
long ASN1_INTEGER_get(ASN1_INTEGER *a);
ASN1_INTEGER *BN_to_ASN1_INTEGER(BIGNUM *bn, ASN1_INTEGER *ai);
BIGNUM *ASN1_INTEGER_to_BN(ASN1_INTEGER *ai, BIGNUM *bn);
int ASN1_ENUMERATED_set(ASN1_ENUMERATED *a, long v);
long ASN1_ENUMERATED_get(ASN1_ENUMERATED *a);
ASN1_ENUMERATED *BN_to_ASN1_ENUMERATED(BIGNUM *bn, ASN1_ENUMERATED *ai);
BIGNUM *ASN1_ENUMERATED_to_BN(ASN1_ENUMERATED *ai, BIGNUM *bn);
int ASN1_PRINTABLE_type(const unsigned char *s, int max);
int i2d_ASN1_bytes(ASN1_STRING *a, unsigned char **pp, int tag, int xclass);
ASN1_STRING *d2i_ASN1_bytes(ASN1_STRING **a, const unsigned char **pp,
long length, int Ptag, int Pclass);
unsigned long ASN1_tag2bit(int tag);
ASN1_STRING *d2i_ASN1_type_bytes(ASN1_STRING **a, const unsigned char **pp,
long length, int type);
int asn1_Finish(ASN1_CTX *c);
int asn1_const_Finish(ASN1_const_CTX *c);
int ASN1_get_object(const unsigned char **pp, long *plength, int *ptag,
int *pclass, long omax);
int ASN1_check_infinite_end(unsigned char **p, long len);
int ASN1_const_check_infinite_end(const unsigned char **p, long len);
void ASN1_put_object(unsigned char **pp, int constructed, int length,
int ASN1_put_eoc(unsigned char **pp);
int ASN1_object_size(int constructed, int length, int tag);
void *ASN1_dup(i2d_of_void *i2d, d2i_of_void *d2i, char *x);
void *ASN1_item_dup(const ASN1_ITEM *it, void *x);
void *ASN1_d2i_fp(void *(*xnew) (void), d2i_of_void *d2i, FILE *in, void **x);
void *ASN1_item_d2i_fp(const ASN1_ITEM *it, FILE *in, void *x);
int ASN1_i2d_fp(i2d_of_void *i2d, FILE *out, void *x);
int ASN1_item_i2d_fp(const ASN1_ITEM *it, FILE *out, void *x);
int ASN1_STRING_print_ex_fp(FILE *fp, ASN1_STRING *str, unsigned long flags);
int ASN1_STRING_to_UTF8(unsigned char **out, ASN1_STRING *in);
void *ASN1_d2i_bio(void *(*xnew) (void), d2i_of_void *d2i, BIO *in, void **x);
void *ASN1_item_d2i_bio(const ASN1_ITEM *it, BIO *in, void *x);
int ASN1_i2d_bio(i2d_of_void *i2d, BIO *out, unsigned char *x);
int ASN1_item_i2d_bio(const ASN1_ITEM *it, BIO *out, void *x);
int ASN1_UTCTIME_print(BIO *fp, ASN1_UTCTIME *a);
int ASN1_GENERALIZEDTIME_print(BIO *fp, ASN1_GENERALIZEDTIME *a);
int ASN1_TIME_print(BIO *fp, ASN1_TIME *a);
int ASN1_STRING_print(BIO *bp, ASN1_STRING *v);
int ASN1_STRING_print_ex(BIO *out, ASN1_STRING *str, unsigned long flags);
int ASN1_parse(BIO *bp, const unsigned char *pp, long len, int indent);
int ASN1_parse_dump(BIO *bp, const unsigned char *pp, long len, int indent,
int dump);
const char *ASN1_tag2str(int tag);
int i2d_ASN1_HEADER(ASN1_HEADER * a, unsigned char **pp);
ASN1_HEADER *d2i_ASN1_HEADER(ASN1_HEADER ** a, const unsigned char **pp,
long length);
ASN1_HEADER *ASN1_HEADER_new(void);
void ASN1_HEADER_free(ASN1_HEADER * a);
int ASN1_UNIVERSALSTRING_to_string(ASN1_UNIVERSALSTRING *s);
ASN1_METHOD *X509_asn1_meth(void);
ASN1_METHOD *RSAPrivateKey_asn1_meth(void);
ASN1_METHOD *ASN1_IA5STRING_asn1_meth(void);
ASN1_METHOD *ASN1_BIT_STRING_asn1_meth(void);
int ASN1_TYPE_set_octetstring(ASN1_TYPE *a, unsigned char *data, int len);
int ASN1_TYPE_get_octetstring(ASN1_TYPE *a, unsigned char *data, int max_len);
int ASN1_TYPE_set_int_octetstring(ASN1_TYPE *a, long num,
int ASN1_TYPE_get_int_octetstring(ASN1_TYPE *a, long *num,
STACK *ASN1_seq_unpack(const unsigned char *buf, int len,
d2i_of_void *d2i, void (*free_func) (void *));
unsigned char *ASN1_seq_pack(STACK * safes, i2d_of_void *i2d,
unsigned char **buf, int *len);
void *ASN1_unpack_string(ASN1_STRING *oct, d2i_of_void *d2i);
void *ASN1_item_unpack(ASN1_STRING *oct, const ASN1_ITEM *it);
ASN1_STRING *ASN1_pack_string(void *obj, i2d_of_void *i2d,
ASN1_OCTET_STRING **oct);
ASN1_STRING *ASN1_item_pack(void *obj, const ASN1_ITEM *it,
void ASN1_STRING_set_default_mask(unsigned long mask);
int ASN1_STRING_set_default_mask_asc(const char *p);
unsigned long ASN1_STRING_get_default_mask(void);
int ASN1_mbstring_copy(ASN1_STRING **out, const unsigned char *in, int len,
int inform, unsigned long mask);
int ASN1_mbstring_ncopy(ASN1_STRING **out, const unsigned char *in, int len,
int inform, unsigned long mask,
long minsize, long maxsize);
ASN1_STRING *ASN1_STRING_set_by_NID(ASN1_STRING **out,
const unsigned char *in, int inlen,
int inform, int nid);
ASN1_STRING_TABLE *ASN1_STRING_TABLE_get(int nid);
int ASN1_STRING_TABLE_add(int, long, long, unsigned long, unsigned long);
void ASN1_STRING_TABLE_cleanup(void);
ASN1_VALUE *ASN1_item_new(const ASN1_ITEM *it);
void ASN1_item_free(ASN1_VALUE *val, const ASN1_ITEM *it);
ASN1_VALUE *ASN1_item_d2i(ASN1_VALUE **val, const unsigned char **in,
long len, const ASN1_ITEM *it);
int ASN1_item_i2d(ASN1_VALUE *val, unsigned char **out, const ASN1_ITEM *it);
int ASN1_item_ndef_i2d(ASN1_VALUE *val, unsigned char **out,
void ASN1_add_oid_module(void);
ASN1_TYPE *ASN1_generate_nconf(char *str, CONF *nconf);
ASN1_TYPE *ASN1_generate_v3(char *str, X509V3_CTX *cnf);
typedef int asn1_output_data_fn(BIO *out, BIO *data, ASN1_VALUE *val,
int flags, const ASN1_ITEM *it);
int int_smime_write_ASN1(BIO *bio, ASN1_VALUE *val, BIO *data, int flags,
int ctype_nid, int econt_nid,
STACK *mdalgs,
asn1_output_data_fn * data_fn, const ASN1_ITEM *it);
ASN1_VALUE *SMIME_read_ASN1(BIO *bio, BIO **bcont, const ASN1_ITEM *it);
void ERR_load_ASN1_strings(void);
#line 1222 "/usr/include/openssl/asn1.h"
#line 1339 "/usr/include/openssl/asn1.h"
#line 966 "/usr/include/openssl/objects.h"
#line 973 "/usr/include/openssl/objects.h"
typedef struct obj_name_st {
int type;
int alias;
const char *name;
const char *data;
} OBJ_NAME;
int OBJ_NAME_init(void);
int OBJ_NAME_new_index(unsigned long (*hash_func) (const char *),
int (*cmp_func) (const char *, const char *),
void (*free_func) (const char *, int, const char *));
const char *OBJ_NAME_get(const char *name, int type);
int OBJ_NAME_add(const char *name, int type, const char *data);
int OBJ_NAME_remove(const char *name, int type);
void OBJ_NAME_cleanup(int type);
void OBJ_NAME_do_all(int type, void (*fn) (const OBJ_NAME *, void *arg),
void *arg);
void OBJ_NAME_do_all_sorted(int type,
void *arg);
ASN1_OBJECT *OBJ_dup(const ASN1_OBJECT *o);
ASN1_OBJECT *OBJ_nid2obj(int n);
const char *OBJ_nid2ln(int n);
const char *OBJ_nid2sn(int n);
int OBJ_obj2nid(const ASN1_OBJECT *o);
ASN1_OBJECT *OBJ_txt2obj(const char *s, int no_name);
int OBJ_obj2txt(char *buf, int buf_len, const ASN1_OBJECT *a, int no_name);
int OBJ_txt2nid(const char *s);
int OBJ_ln2nid(const char *s);
int OBJ_sn2nid(const char *s);
int OBJ_cmp(const ASN1_OBJECT *a, const ASN1_OBJECT *b);
const char *OBJ_bsearch(const char *key, const char *base, int num, int size,
int (*cmp) (const void *, const void *));
const char *OBJ_bsearch_ex(const char *key, const char *base, int num,
int size, int (*cmp) (const void *, const void *),
int flags);
int OBJ_new_nid(int num);
int OBJ_add_object(const ASN1_OBJECT *obj);
int OBJ_create(const char *oid, const char *sn, const char *ln);
void OBJ_cleanup(void);
int OBJ_create_objects(BIO *in);
void ERR_load_OBJ_strings(void);
#line 1047 "/usr/include/openssl/objects.h"
#line 99 "/usr/include/openssl/evp.h"
#line 111 "/usr/include/openssl/evp.h"
#line 122 "/usr/include/openssl/evp.h"
struct evp_pkey_st {
int type;
int save_type;
int references;
union {
char *ptr;
struct rsa_st *rsa;
struct dsa_st *dsa;
struct dh_st *dh;
} pkey;
int save_parameters;
STACK *attributes;
#line 219 "/usr/include/openssl/evp.h"
struct env_md_st {
int type;
int pkey_type;
int md_size;
int (*init) (EVP_MD_CTX *ctx);
int (*update) (EVP_MD_CTX *ctx, const void *data, size_t count);
int (*final) (EVP_MD_CTX *ctx, unsigned char *md);
int (*copy) (EVP_MD_CTX *to, const EVP_MD_CTX *from);
int (*cleanup) (EVP_MD_CTX *ctx);
int (*sign) (int type, const unsigned char *m, unsigned int m_length,
unsigned char *sigret, unsigned int *siglen, void *key);
int (*verify) (int type, const unsigned char *m, unsigned int m_length,
const unsigned char *sigbuf, unsigned int siglen,
void *key);
int required_pkey_type[5];
int block_size;
int ctx_size;
typedef int evp_sign_method(int type, const unsigned char *m,
unsigned int m_length, unsigned char *sigret,
typedef int evp_verify_method(int type, const unsigned char *m,
unsigned int siglen, void *key);
typedef struct {
EVP_MD_CTX *mctx;
void *key;
} EVP_MD_SVCTX;
#line 274 "/usr/include/openssl/evp.h"
#line 288 "/usr/include/openssl/evp.h"
struct env_md_ctx_st {
const EVP_MD *digest;
ENGINE *engine;
void *md_data;
#line 309 "/usr/include/openssl/evp.h"
#line 318 "/usr/include/openssl/evp.h"
struct evp_cipher_st {
int nid;
int block_size;
int key_len;
int iv_len;
int (*init) (EVP_CIPHER_CTX *ctx, const unsigned char *key,
const unsigned char *iv, int enc);
int (*do_cipher) (EVP_CIPHER_CTX *ctx, unsigned char *out,
const unsigned char *in, unsigned int inl);
int (*cleanup) (EVP_CIPHER_CTX *);
int ctx_size;
int (*set_asn1_parameters) (EVP_CIPHER_CTX *, ASN1_TYPE *);
int (*get_asn1_parameters) (EVP_CIPHER_CTX *, ASN1_TYPE *);
int (*ctrl) (EVP_CIPHER_CTX *, int type, int arg, void *ptr);
void *app_data;
#line 357 "/usr/include/openssl/evp.h"
#line 389 "/usr/include/openssl/evp.h"
typedef struct evp_cipher_info_st {
const EVP_CIPHER *cipher;
unsigned char iv[16];
} EVP_CIPHER_INFO;
struct evp_cipher_ctx_st {
ENGINE *engine;
int encrypt;
int buf_len;
unsigned char oiv[16];
unsigned char buf[32];
int num;
void *app_data;
int key_len;
void *cipher_data;
int final_used;
int block_mask;
unsigned char final[32];
typedef struct evp_Encode_Ctx_st {
int num;
int length;
unsigned char enc_data[80];
int line_num;
int expect_nl;
} EVP_ENCODE_CTX;
typedef int (EVP_PBE_KEYGEN) (EVP_CIPHER_CTX *ctx, const char *pass,
int passlen, ASN1_TYPE *param,
const EVP_CIPHER *cipher, const EVP_MD *md,
int en_de);
#line 467 "/usr/include/openssl/evp.h"
int EVP_MD_type(const EVP_MD *md);
int EVP_MD_pkey_type(const EVP_MD *md);
int EVP_MD_size(const EVP_MD *md);
int EVP_MD_block_size(const EVP_MD *md);
const EVP_MD *EVP_MD_CTX_md(const EVP_MD_CTX *ctx);
int EVP_CIPHER_nid(const EVP_CIPHER *cipher);
int EVP_CIPHER_block_size(const EVP_CIPHER *cipher);
int EVP_CIPHER_key_length(const EVP_CIPHER *cipher);
int EVP_CIPHER_iv_length(const EVP_CIPHER *cipher);
unsigned long EVP_CIPHER_flags(const EVP_CIPHER *cipher);
const EVP_CIPHER *EVP_CIPHER_CTX_cipher(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_nid(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_block_size(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_key_length(const EVP_CIPHER_CTX *ctx);
int EVP_CIPHER_CTX_iv_length(const EVP_CIPHER_CTX *ctx);
void *EVP_CIPHER_CTX_get_app_data(const EVP_CIPHER_CTX *ctx);
void EVP_CIPHER_CTX_set_app_data(EVP_CIPHER_CTX *ctx, void *data);
unsigned long EVP_CIPHER_CTX_flags(const EVP_CIPHER_CTX *ctx);
#line 512 "/usr/include/openssl/evp.h"
#line 523 "/usr/include/openssl/evp.h"
int EVP_Cipher(EVP_CIPHER_CTX *c,
unsigned char *out, const unsigned char *in, unsigned int inl);
#line 535 "/usr/include/openssl/evp.h"
void EVP_MD_CTX_init(EVP_MD_CTX *ctx);
int EVP_MD_CTX_cleanup(EVP_MD_CTX *ctx);
EVP_MD_CTX *EVP_MD_CTX_create(void);
void EVP_MD_CTX_destroy(EVP_MD_CTX *ctx);
int EVP_MD_CTX_copy_ex(EVP_MD_CTX *out, const EVP_MD_CTX *in);
void EVP_MD_CTX_set_flags(EVP_MD_CTX *ctx, int flags);
void EVP_MD_CTX_clear_flags(EVP_MD_CTX *ctx, int flags);
int EVP_MD_CTX_test_flags(const EVP_MD_CTX *ctx, int flags);
int EVP_DigestInit_ex(EVP_MD_CTX *ctx, const EVP_MD *type, ENGINE *impl);
int EVP_DigestUpdate(EVP_MD_CTX *ctx, const void *d, size_t cnt);
int EVP_DigestFinal_ex(EVP_MD_CTX *ctx, unsigned char *md, unsigned int *s);
int EVP_Digest(const void *data, size_t count,
unsigned char *md, unsigned int *size, const EVP_MD *type,
ENGINE *impl);
int EVP_MD_CTX_copy(EVP_MD_CTX *out, const EVP_MD_CTX *in);
int EVP_DigestInit(EVP_MD_CTX *ctx, const EVP_MD *type);
int EVP_DigestFinal(EVP_MD_CTX *ctx, unsigned char *md, unsigned int *s);
int EVP_read_pw_string(char *buf, int length, const char *prompt, int verify);
void EVP_set_pw_prompt(const char *prompt);
char *EVP_get_pw_prompt(void);
int EVP_BytesToKey(const EVP_CIPHER *type, const EVP_MD *md,
const unsigned char *salt, const unsigned char *data,
int datal, int count, unsigned char *key,
unsigned char *iv);
void EVP_CIPHER_CTX_set_flags(EVP_CIPHER_CTX *ctx, int flags);
void EVP_CIPHER_CTX_clear_flags(EVP_CIPHER_CTX *ctx, int flags);
int EVP_CIPHER_CTX_test_flags(const EVP_CIPHER_CTX *ctx, int flags);
int EVP_EncryptInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
const unsigned char *key, const unsigned char *iv);
int EVP_EncryptInit_ex(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
ENGINE *impl, const unsigned char *key,
int EVP_EncryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl,
const unsigned char *in, int inl);
int EVP_EncryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_EncryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_DecryptInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
int EVP_DecryptInit_ex(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
int EVP_DecryptUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl,
int EVP_DecryptFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_DecryptFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
const unsigned char *key, const unsigned char *iv,
int enc);
int EVP_CipherInit_ex(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *cipher,
int EVP_CipherUpdate(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl,
int EVP_CipherFinal(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_CipherFinal_ex(EVP_CIPHER_CTX *ctx, unsigned char *outm, int *outl);
int EVP_SignFinal(EVP_MD_CTX *ctx, unsigned char *md, unsigned int *s,
EVP_PKEY *pkey);
int EVP_VerifyFinal(EVP_MD_CTX *ctx, const unsigned char *sigbuf,
unsigned int siglen, EVP_PKEY *pkey);
int EVP_OpenInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *type,
const unsigned char *ek, int ekl, const unsigned char *iv,
EVP_PKEY *priv);
int EVP_OpenFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
int EVP_SealInit(EVP_CIPHER_CTX *ctx, const EVP_CIPHER *type,
unsigned char **ek, int *ekl, unsigned char *iv,
EVP_PKEY **pubk, int npubk);
int EVP_SealFinal(EVP_CIPHER_CTX *ctx, unsigned char *out, int *outl);
void EVP_EncodeInit(EVP_ENCODE_CTX *ctx);
void EVP_EncodeUpdate(EVP_ENCODE_CTX *ctx, unsigned char *out, int *outl,
void EVP_EncodeFinal(EVP_ENCODE_CTX *ctx, unsigned char *out, int *outl);
int EVP_EncodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_DecodeInit(EVP_ENCODE_CTX *ctx);
int EVP_DecodeUpdate(EVP_ENCODE_CTX *ctx, unsigned char *out, int *outl,
int EVP_DecodeFinal(EVP_ENCODE_CTX *ctx, unsigned
int EVP_DecodeBlock(unsigned char *t, const unsigned char *f, int n);
void EVP_CIPHER_CTX_init(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_cleanup(EVP_CIPHER_CTX *a);
EVP_CIPHER_CTX *EVP_CIPHER_CTX_new(void);
void EVP_CIPHER_CTX_free(EVP_CIPHER_CTX *a);
int EVP_CIPHER_CTX_set_key_length(EVP_CIPHER_CTX *x, int keylen);
int EVP_CIPHER_CTX_set_padding(EVP_CIPHER_CTX *c, int pad);
int EVP_CIPHER_CTX_ctrl(EVP_CIPHER_CTX *ctx, int type, int arg, void *ptr);
int EVP_CIPHER_CTX_rand_key(EVP_CIPHER_CTX *ctx, unsigned char *key);
BIO_METHOD *BIO_f_md(void);
BIO_METHOD *BIO_f_base64(void);
BIO_METHOD *BIO_f_cipher(void);
BIO_METHOD *BIO_f_reliable(void);
void BIO_set_cipher(BIO *b, const EVP_CIPHER *c, const unsigned char *k,
const unsigned char *i, int enc);
const EVP_MD *EVP_md_null(void);
const EVP_MD *EVP_md2(void);
const EVP_MD *EVP_md4(void);
const EVP_MD *EVP_md5(void);
const EVP_MD *EVP_sha(void);
const EVP_MD *EVP_sha1(void);
const EVP_MD *EVP_dss(void);
const EVP_MD *EVP_dss1(void);
const EVP_MD *EVP_ecdsa(void);
const EVP_MD *EVP_sha224(void);
const EVP_MD *EVP_sha256(void);
const EVP_MD *EVP_sha384(void);
const EVP_MD *EVP_sha512(void);
const EVP_MD *EVP_ripemd160(void);
const EVP_CIPHER *EVP_enc_null(void);
const EVP_CIPHER *EVP_des_ecb(void);
const EVP_CIPHER *EVP_des_ede(void);
const EVP_CIPHER *EVP_des_ede3(void);
const EVP_CIPHER *EVP_des_ede_ecb(void);
const EVP_CIPHER *EVP_des_ede3_ecb(void);
const EVP_CIPHER *EVP_des_cfb64(void);
const EVP_CIPHER *EVP_des_cfb1(void);
const EVP_CIPHER *EVP_des_cfb8(void);
const EVP_CIPHER *EVP_des_ede_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb64(void);
const EVP_CIPHER *EVP_des_ede3_cfb1(void);
const EVP_CIPHER *EVP_des_ede3_cfb8(void);
const EVP_CIPHER *EVP_des_ofb(void);
const EVP_CIPHER *EVP_des_ede_ofb(void);
const EVP_CIPHER *EVP_des_ede3_ofb(void);
const EVP_CIPHER *EVP_des_cbc(void);
const EVP_CIPHER *EVP_des_ede_cbc(void);
const EVP_CIPHER *EVP_des_ede3_cbc(void);
const EVP_CIPHER *EVP_desx_cbc(void);
#line 716 "/usr/include/openssl/evp.h"
const EVP_CIPHER *EVP_rc4(void);
const EVP_CIPHER *EVP_rc4_40(void);
const EVP_CIPHER *EVP_rc2_ecb(void);
const EVP_CIPHER *EVP_rc2_cbc(void);
const EVP_CIPHER *EVP_rc2_40_cbc(void);
const EVP_CIPHER *EVP_rc2_64_cbc(void);
const EVP_CIPHER *EVP_rc2_cfb64(void);
const EVP_CIPHER *EVP_rc2_ofb(void);
const EVP_CIPHER *EVP_bf_ecb(void);
const EVP_CIPHER *EVP_bf_cbc(void);
const EVP_CIPHER *EVP_bf_cfb64(void);
const EVP_CIPHER *EVP_bf_ofb(void);
const EVP_CIPHER *EVP_cast5_ecb(void);
const EVP_CIPHER *EVP_cast5_cbc(void);
const EVP_CIPHER *EVP_cast5_cfb64(void);
const EVP_CIPHER *EVP_cast5_ofb(void);
const EVP_CIPHER *EVP_aes_128_ecb(void);
const EVP_CIPHER *EVP_aes_128_cbc(void);
const EVP_CIPHER *EVP_aes_128_cfb1(void);
const EVP_CIPHER *EVP_aes_128_cfb8(void);
const EVP_CIPHER *EVP_aes_128_cfb128(void);
const EVP_CIPHER *EVP_aes_128_ofb(void);
const EVP_CIPHER *EVP_aes_192_ecb(void);
const EVP_CIPHER *EVP_aes_192_cbc(void);
const EVP_CIPHER *EVP_aes_192_cfb1(void);
const EVP_CIPHER *EVP_aes_192_cfb8(void);
const EVP_CIPHER *EVP_aes_192_cfb128(void);
const EVP_CIPHER *EVP_aes_192_ofb(void);
const EVP_CIPHER *EVP_aes_256_ecb(void);
const EVP_CIPHER *EVP_aes_256_cbc(void);
const EVP_CIPHER *EVP_aes_256_cfb1(void);
const EVP_CIPHER *EVP_aes_256_cfb8(void);
const EVP_CIPHER *EVP_aes_256_cfb128(void);
const EVP_CIPHER *EVP_aes_256_ofb(void);
#line 797 "/usr/include/openssl/evp.h"
#line 805 "/usr/include/openssl/evp.h"
void OPENSSL_add_all_algorithms_noconf(void);
void OPENSSL_add_all_algorithms_conf(void);
#line 816 "/usr/include/openssl/evp.h"
void OpenSSL_add_all_ciphers(void);
void OpenSSL_add_all_digests(void);
int EVP_add_cipher(const EVP_CIPHER *cipher);
int EVP_add_digest(const EVP_MD *digest);
const EVP_CIPHER *EVP_get_cipherbyname(const char *name);
const EVP_MD *EVP_get_digestbyname(const char *name);
void EVP_cleanup(void);
int EVP_PKEY_decrypt(unsigned char *dec_key,
const unsigned char *enc_key, int enc_key_len,
EVP_PKEY *private_key);
int EVP_PKEY_encrypt(unsigned char *enc_key,
const unsigned char *key, int key_len,
EVP_PKEY *pub_key);
int EVP_PKEY_type(int type);
int EVP_PKEY_bits(EVP_PKEY *pkey);
int EVP_PKEY_size(EVP_PKEY *pkey);
int EVP_PKEY_assign(EVP_PKEY *pkey, int type, char *key);
struct rsa_st;
int EVP_PKEY_set1_RSA(EVP_PKEY *pkey, struct rsa_st *key);
struct rsa_st *EVP_PKEY_get1_RSA(EVP_PKEY *pkey);
struct dsa_st;
int EVP_PKEY_set1_DSA(EVP_PKEY *pkey, struct dsa_st *key);
struct dsa_st *EVP_PKEY_get1_DSA(EVP_PKEY *pkey);
struct dh_st;
int EVP_PKEY_set1_DH(EVP_PKEY *pkey, struct dh_st *key);
struct dh_st *EVP_PKEY_get1_DH(EVP_PKEY *pkey);
EVP_PKEY *EVP_PKEY_new(void);
void EVP_PKEY_free(EVP_PKEY *pkey);
EVP_PKEY *d2i_PublicKey(int type, EVP_PKEY **a, const unsigned char **pp,
long length);
int i2d_PublicKey(EVP_PKEY *a, unsigned char **pp);
EVP_PKEY *d2i_PrivateKey(int type, EVP_PKEY **a, const unsigned char **pp,
long length);
EVP_PKEY *d2i_AutoPrivateKey(EVP_PKEY **a, const unsigned char **pp,
long length);
int i2d_PrivateKey(EVP_PKEY *a, unsigned char **pp);
int EVP_PKEY_copy_parameters(EVP_PKEY *to, const EVP_PKEY *from);
int EVP_PKEY_missing_parameters(const EVP_PKEY *pkey);
int EVP_PKEY_save_parameters(EVP_PKEY *pkey, int mode);
int EVP_PKEY_cmp_parameters(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_PKEY_cmp(const EVP_PKEY *a, const EVP_PKEY *b);
int EVP_CIPHER_type(const EVP_CIPHER *ctx);
int EVP_CIPHER_param_to_asn1(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_asn1_to_param(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_set_asn1_iv(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int EVP_CIPHER_get_asn1_iv(EVP_CIPHER_CTX *c, ASN1_TYPE *type);
int PKCS5_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
ASN1_TYPE *param, const EVP_CIPHER *cipher,
const EVP_MD *md, int en_de);
int PKCS5_PBKDF2_HMAC_SHA1(const char *pass, int passlen,
const unsigned char *salt, int saltlen, int iter,
int keylen, unsigned char *out);
int PKCS5_v2_PBE_keyivgen(EVP_CIPHER_CTX *ctx, const char *pass, int passlen,
void PKCS5_PBE_add(void);
int EVP_PBE_CipherInit(ASN1_OBJECT *pbe_obj, const char *pass, int passlen,
ASN1_TYPE *param, EVP_CIPHER_CTX *ctx, int en_de);
int EVP_PBE_alg_add(int nid, const EVP_CIPHER *cipher, const EVP_MD *md,
EVP_PBE_KEYGEN *keygen);
void EVP_PBE_cleanup(void);
#line 922 "/usr/include/openssl/evp.h"
void EVP_add_alg_module(void);
void ERR_load_EVP_strings(void);
#line 978 "/usr/include/openssl/evp.h"
#line 1032 "/usr/include/openssl/evp.h"
#line 74 "/usr/include/openssl/x509.h"
#line 81 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/rsa.h"
#line 72 "/usr/include/openssl/rsa.h"
struct rsa_meth_st {
const char *name;
int (*rsa_pub_enc) (int flen, const unsigned char *from,
unsigned char *to, RSA *rsa, int padding);
int (*rsa_pub_dec) (int flen, const unsigned char *from,
int (*rsa_priv_enc) (int flen, const unsigned char *from,
int (*rsa_priv_dec) (int flen, const unsigned char *from,
int (*rsa_mod_exp) (BIGNUM *r0, const BIGNUM *I, RSA *rsa, BN_CTX *ctx);
int (*bn_mod_exp) (BIGNUM *r, const BIGNUM *a, const BIGNUM *p,
int (*init) (RSA *rsa);
int (*finish) (RSA *rsa);
int flags;
char *app_data;
int (*rsa_sign) (int type,
const RSA *rsa);
int (*rsa_verify) (int dtype, const unsigned char *m,
unsigned int m_length, unsigned char *sigbuf,
unsigned int siglen, const RSA *rsa);
int (*rsa_keygen) (RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
struct rsa_st {
int pad;
long version;
const RSA_METHOD *meth;
ENGINE *engine;
BIGNUM *n;
BIGNUM *e;
BIGNUM *d;
BIGNUM *p;
BIGNUM *q;
BIGNUM *dmp1;
BIGNUM *dmq1;
BIGNUM *iqmp;
int references;
int flags;
BN_MONT_CTX *_method_mod_n;
BN_MONT_CTX *_method_mod_p;
BN_MONT_CTX *_method_mod_q;
char *bignum_data;
BN_BLINDING *blinding;
BN_BLINDING *mt_blinding;
#line 258 "/usr/include/openssl/rsa.h"
RSA *RSA_new(void);
RSA *RSA_new_method(ENGINE *engine);
int RSA_size(const RSA *);
RSA *RSA_generate_key(int bits, unsigned long e, void
int RSA_generate_key_ex(RSA *rsa, int bits, BIGNUM *e, BN_GENCB *cb);
int RSA_X931_derive_ex(RSA *rsa, BIGNUM *p1, BIGNUM *p2, BIGNUM *q1,
BIGNUM *q2, const BIGNUM *Xp1, const BIGNUM *Xp2,
const BIGNUM *Xp, const BIGNUM *Xq1, const BIGNUM *Xq2,
const BIGNUM *Xq, const BIGNUM *e, BN_GENCB *cb);
int RSA_X931_generate_key_ex(RSA *rsa, int bits, const BIGNUM *e,
BN_GENCB *cb);
int RSA_check_key(const RSA *);
int RSA_public_encrypt(int flen, const unsigned char *from,
int RSA_private_encrypt(int flen, const unsigned char *from,
int RSA_public_decrypt(int flen, const unsigned char *from,
int RSA_private_decrypt(int flen, const unsigned char *from,
void RSA_free(RSA *r);
int RSA_up_ref(RSA *r);
int RSA_flags(const RSA *r);
void RSA_set_default_method(const RSA_METHOD *meth);
const RSA_METHOD *RSA_get_default_method(void);
const RSA_METHOD *RSA_get_method(const RSA *rsa);
int RSA_set_method(RSA *rsa, const RSA_METHOD *meth);
int RSA_memory_lock(RSA *r);
const RSA_METHOD *RSA_PKCS1_SSLeay(void);
const RSA_METHOD *RSA_null_method(void);
RSA *d2i_RSAPublicKey(RSA * *a, const unsigned char * *in, long len); int i2d_RSAPublicKey(const RSA *a, unsigned char * *out); extern const ASN1_ITEM RSAPublicKey_it;
RSA *d2i_RSAPrivateKey(RSA * *a, const unsigned char * *in, long len); int i2d_RSAPrivateKey(const RSA *a, unsigned char * *out); extern const ASN1_ITEM RSAPrivateKey_it;
int RSA_print_fp(FILE *fp, const RSA *r, int offset);
int RSA_print(BIO *bp, const RSA *r, int offset);
int i2d_RSA_NET(const RSA *a, unsigned char **pp,
int (*cb) (char *buf, int len, const char *prompt,
int verify), int sgckey);
RSA *d2i_RSA_NET(RSA **a, const unsigned char **pp, long length,
int i2d_Netscape_RSA(const RSA *a, unsigned char **pp,
int verify));
RSA *d2i_Netscape_RSA(RSA **a, const unsigned char **pp, long length,
int verify));
int RSA_sign(int type, const unsigned char *m, unsigned int m_length,
unsigned char *sigret, unsigned int *siglen, RSA *rsa);
int RSA_verify(int type, const unsigned char *m, unsigned int m_length,
unsigned char *sigbuf, unsigned int siglen, RSA *rsa);
int RSA_sign_ASN1_OCTET_STRING(int type,
RSA *rsa);
int RSA_verify_ASN1_OCTET_STRING(int type, const unsigned char *m,
int RSA_blinding_on(RSA *rsa, BN_CTX *ctx);
void RSA_blinding_off(RSA *rsa);
BN_BLINDING *RSA_setup_blinding(RSA *rsa, BN_CTX *ctx);
int RSA_padding_add_PKCS1_type_1(unsigned char *to, int tlen,
const unsigned char *f, int fl);
int RSA_padding_check_PKCS1_type_1(unsigned char *to, int tlen,
const unsigned char *f, int fl,
int rsa_len);
int RSA_padding_add_PKCS1_type_2(unsigned char *to, int tlen,
int RSA_padding_check_PKCS1_type_2(unsigned char *to, int tlen,
int rsa_len);
int PKCS1_MGF1(unsigned char *mask, long len, const unsigned char *seed,
long seedlen, const EVP_MD *dgst);
int RSA_padding_add_PKCS1_OAEP(unsigned char *to, int tlen,
const unsigned char *p, int pl);
int RSA_padding_check_PKCS1_OAEP(unsigned char *to, int tlen,
const unsigned char *f, int fl, int rsa_len,
int RSA_padding_add_SSLv23(unsigned char *to, int tlen,
int RSA_padding_check_SSLv23(unsigned char *to, int tlen,
const unsigned char *f, int fl, int rsa_len);
int RSA_padding_add_none(unsigned char *to, int tlen, const unsigned char *f,
int fl);
int RSA_padding_check_none(unsigned char *to, int tlen,
int RSA_padding_add_X931(unsigned char *to, int tlen, const unsigned char *f,
int fl);
int RSA_padding_check_X931(unsigned char *to, int tlen,
int RSA_X931_hash_id(int nid);
int RSA_verify_PKCS1_PSS(RSA *rsa, const unsigned char *mHash,
const EVP_MD *Hash, const unsigned char *EM,
int sLen);
int RSA_padding_add_PKCS1_PSS(RSA *rsa, unsigned char *EM,
const unsigned char *mHash, const EVP_MD *Hash,
int sLen);
int RSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int RSA_set_ex_data(RSA *r, int idx, void *arg);
void *RSA_get_ex_data(const RSA *r, int idx);
RSA *RSAPublicKey_dup(RSA *rsa);
RSA *RSAPrivateKey_dup(RSA *rsa);
void ERR_load_RSA_strings(void);
#line 475 "/usr/include/openssl/rsa.h"
#line 521 "/usr/include/openssl/rsa.h"
#line 88 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/dsa.h"
#line 1 "/usr/include/openssl/e_os2.h"
#line 1 "/usr/include/openssl/opensslconf.h"
#line 1 "/usr/include/openssl/opensslconf-sparc64.h"
#line 57 "/usr/include/openssl/opensslconf-sparc64.h"
#line 69 "/usr/include/openssl/opensslconf-sparc64.h"
#line 115 "/usr/include/openssl/opensslconf-sparc64.h"
#line 132 "/usr/include/openssl/opensslconf-sparc64.h"
#line 142 "/usr/include/openssl/opensslconf-sparc64.h"
#line 180 "/usr/include/openssl/opensslconf-sparc64.h"
#line 188 "/usr/include/openssl/opensslconf-sparc64.h"
#line 205 "/usr/include/openssl/opensslconf-sparc64.h"
#line 212 "/usr/include/openssl/opensslconf-sparc64.h"
#line 26 "/usr/include/openssl/opensslconf.h"
#line 33 "/usr/include/openssl/opensslconf.h"
#line 57 "/usr/include/openssl/e_os2.h"
#line 69 "/usr/include/openssl/dsa.h"
#line 1 "/usr/include/openssl/dh.h"
#line 63 "/usr/include/openssl/dh.h"
#line 75 "/usr/include/openssl/dh.h"
struct dh_method {
const char *name;
int (*generate_key) (DH *dh);
int (*compute_key) (unsigned char *key, const BIGNUM *pub_key, DH *dh);
int (*bn_mod_exp) (const DH *dh, BIGNUM *r, const BIGNUM *a,
const BIGNUM *p, const BIGNUM *m, BN_CTX *ctx,
int (*init) (DH *dh);
int (*finish) (DH *dh);
int flags;
char *app_data;
int (*generate_params) (DH *dh, int prime_len, int generator,
BN_GENCB *cb);
struct dh_st {
int pad;
int version;
BIGNUM *p;
BIGNUM *g;
long length;
BIGNUM *pub_key;
BIGNUM *priv_key;
int flags;
BN_MONT_CTX *method_mont_p;
BIGNUM *q;
BIGNUM *j;
unsigned char *seed;
int seedlen;
BIGNUM *counter;
int references;
CRYPTO_EX_DATA ex_data;
const DH_METHOD *meth;
ENGINE *engine;
#line 173 "/usr/include/openssl/dh.h"
const DH_METHOD *DH_OpenSSL(void);
void DH_set_default_method(const DH_METHOD *meth);
const DH_METHOD *DH_get_default_method(void);
int DH_set_method(DH *dh, const DH_METHOD *meth);
DH *DH_new_method(ENGINE *engine);
DH *DH_new(void);
void DH_free(DH *dh);
int DH_up_ref(DH *dh);
int DH_size(const DH *dh);
int DH_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int DH_set_ex_data(DH *d, int idx, void *arg);
void *DH_get_ex_data(DH *d, int idx);
DH *DH_generate_parameters(int prime_len, int generator,
int DH_generate_parameters_ex(DH *dh, int prime_len, int generator,
BN_GENCB *cb);
int DH_check(const DH *dh, int *codes);
int DH_check_pub_key(const DH *dh, const BIGNUM *pub_key, int *codes);
int DH_generate_key(DH *dh);
int DH_compute_key(unsigned char *key, const BIGNUM *pub_key, DH *dh);
DH *d2i_DHparams(DH **a, const unsigned char **pp, long length);
int i2d_DHparams(const DH *a, unsigned char **pp);
int DHparams_print_fp(FILE *fp, const DH *x);
int DHparams_print(BIO *bp, const DH *x);
void ERR_load_DH_strings(void);
#line 240 "/usr/include/openssl/dh.h"
#line 84 "/usr/include/openssl/dsa.h"
typedef struct DSA_SIG_st {
BIGNUM *r;
BIGNUM *s;
} DSA_SIG;
struct dsa_method {
const char *name;
DSA_SIG *(*dsa_do_sign) (const unsigned char *dgst, int dlen, DSA *dsa);
int (*dsa_sign_setup) (DSA *dsa, BN_CTX *ctx_in, BIGNUM **kinvp,
BIGNUM **rp);
int (*dsa_do_verify) (const unsigned char *dgst, int dgst_len,
DSA_SIG *sig, DSA *dsa);
int (*dsa_mod_exp) (DSA *dsa, BIGNUM *rr, BIGNUM *a1, BIGNUM *p1,
BIGNUM *a2, BIGNUM *p2, BIGNUM *m, BN_CTX *ctx,
int (*bn_mod_exp) (DSA *dsa, BIGNUM *r, BIGNUM *a, const BIGNUM *p,
int (*init) (DSA *dsa);
int (*finish) (DSA *dsa);
int flags;
char *app_data;
int (*dsa_paramgen) (DSA *dsa, int bits,
unsigned char *seed, int seed_len,
int *counter_ret, unsigned long *h_ret,
BN_GENCB *cb);
int (*dsa_keygen) (DSA *dsa);
struct dsa_st {
int pad;
long version;
int write_params;
BIGNUM *p;
BIGNUM *q;
BIGNUM *g;
BIGNUM *pub_key;
BIGNUM *priv_key;
BIGNUM *kinv;
BIGNUM *r;
int flags;
int references;
const DSA_METHOD *meth;
ENGINE *engine;
#line 193 "/usr/include/openssl/dsa.h"
DSA_SIG *DSA_SIG_new(void);
void DSA_SIG_free(DSA_SIG *a);
int i2d_DSA_SIG(const DSA_SIG *a, unsigned char **pp);
DSA_SIG *d2i_DSA_SIG(DSA_SIG **v, const unsigned char **pp, long length);
DSA_SIG *DSA_do_sign(const unsigned char *dgst, int dlen, DSA *dsa);
int DSA_do_verify(const unsigned char *dgst, int dgst_len,
const DSA_METHOD *DSA_OpenSSL(void);
void DSA_set_default_method(const DSA_METHOD *);
const DSA_METHOD *DSA_get_default_method(void);
int DSA_set_method(DSA *dsa, const DSA_METHOD *);
DSA *DSA_new(void);
DSA *DSA_new_method(ENGINE *engine);
void DSA_free(DSA *r);
int DSA_up_ref(DSA *r);
int DSA_size(const DSA *);
int DSA_sign_setup(DSA *dsa, BN_CTX *ctx_in, BIGNUM **kinvp, BIGNUM **rp);
int DSA_sign(int type, const unsigned char *dgst, int dlen,
unsigned char *sig, unsigned int *siglen, DSA *dsa);
int DSA_verify(int type, const unsigned char *dgst, int dgst_len,
const unsigned char *sigbuf, int siglen, DSA *dsa);
int DSA_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int DSA_set_ex_data(DSA *d, int idx, void *arg);
void *DSA_get_ex_data(DSA *d, int idx);
DSA *d2i_DSAPublicKey(DSA **a, const unsigned char **pp, long length);
DSA *d2i_DSAPrivateKey(DSA **a, const unsigned char **pp, long length);
DSA *d2i_DSAparams(DSA **a, const unsigned char **pp, long length);
DSA *DSA_generate_parameters(int bits,
int *counter_ret, unsigned long *h_ret, void
int DSA_generate_parameters_ex(DSA *dsa, int bits,
BN_GENCB *cb);
int DSA_generate_key(DSA *a);
int i2d_DSAPublicKey(const DSA *a, unsigned char **pp);
int i2d_DSAPrivateKey(const DSA *a, unsigned char **pp);
int i2d_DSAparams(const DSA *a, unsigned char **pp);
int DSAparams_print(BIO *bp, const DSA *x);
int DSA_print(BIO *bp, const DSA *x, int off);
int DSAparams_print_fp(FILE *fp, const DSA *x);
int DSA_print_fp(FILE *bp, const DSA *x, int off);
DH *DSA_dup_DH(const DSA *r);
void ERR_load_DSA_strings(void);
#line 313 "/usr/include/openssl/dsa.h"
#line 322 "/usr/include/openssl/dsa.h"
#line 91 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/sha.h"
#line 63 "/usr/include/openssl/sha.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "/usr/include/openssl/sha.h"
#line 92 "/usr/include/openssl/sha.h"
#line 99 "/usr/include/openssl/sha.h"
typedef struct SHAstate_st {
unsigned int h0, h1, h2, h3, h4;
unsigned int Nl, Nh;
unsigned int data[16];
unsigned int num;
} SHA_CTX;
int SHA_Init(SHA_CTX *c);
int SHA_Update(SHA_CTX *c, const void *data, size_t len);
int SHA_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA(const unsigned char *d, size_t n, unsigned char *md);
void SHA_Transform(SHA_CTX *c, const unsigned char *data);
int SHA1_Init(SHA_CTX *c);
int SHA1_Update(SHA_CTX *c, const void *data, size_t len);
int SHA1_Final(unsigned char *md, SHA_CTX *c);
unsigned char *SHA1(const unsigned char *d, size_t n, unsigned char *md);
void SHA1_Transform(SHA_CTX *c, const unsigned char *data);
typedef struct SHA256state_st {
unsigned int h[8];
unsigned int num, md_len;
} SHA256_CTX;
int SHA224_Init(SHA256_CTX *c);
int SHA224_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA224_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA224(const unsigned char *d, size_t n, unsigned char *md);
int SHA256_Init(SHA256_CTX *c);
int SHA256_Update(SHA256_CTX *c, const void *data, size_t len);
int SHA256_Final(unsigned char *md, SHA256_CTX *c);
unsigned char *SHA256(const unsigned char *d, size_t n, unsigned char *md);
void SHA256_Transform(SHA256_CTX *c, const unsigned char *data);
#line 175 "/usr/include/openssl/sha.h"
typedef struct SHA512state_st {
unsigned long h[8];
unsigned long Nl, Nh;
union {
unsigned long d[16];
unsigned char p[(16*8)];
} u;
} SHA512_CTX;
int SHA384_Init(SHA512_CTX *c);
int SHA384_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA384_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA384(const unsigned char *d, size_t n, unsigned char *md);
int SHA512_Init(SHA512_CTX *c);
int SHA512_Update(SHA512_CTX *c, const void *data, size_t len);
int SHA512_Final(unsigned char *md, SHA512_CTX *c);
unsigned char *SHA512(const unsigned char *d, size_t n, unsigned char *md);
void SHA512_Transform(SHA512_CTX *c, const unsigned char *data);
#line 99 "/usr/include/openssl/x509.h"
#line 112 "/usr/include/openssl/x509.h"
#line 127 "/usr/include/openssl/x509.h"
typedef struct X509_objects_st {
int nid;
int (*a2i) (void);
int (*i2a) (void);
} X509_OBJECTS;
struct X509_algor_st {
ASN1_OBJECT *algorithm;
ASN1_TYPE *parameter;
typedef STACK X509_ALGORS;
typedef struct X509_val_st {
ASN1_TIME *notBefore;
ASN1_TIME *notAfter;
} X509_VAL;
typedef struct X509_pubkey_st {
X509_ALGOR *algor;
ASN1_BIT_STRING *public_key;
EVP_PKEY *pkey;
} X509_PUBKEY;
typedef struct X509_sig_st {
X509_ALGOR *algor;
ASN1_OCTET_STRING *digest;
} X509_SIG;
typedef struct X509_name_entry_st {
ASN1_STRING *value;
int set;
int size;
} X509_NAME_ENTRY;
struct X509_name_st {
STACK *entries;
int modified;
BUF_MEM *bytes;
unsigned long hash;
typedef struct X509_extension_st {
ASN1_BOOLEAN critical;
ASN1_OCTET_STRING *value;
} X509_EXTENSION;
typedef STACK X509_EXTENSIONS;
typedef struct x509_attributes_st {
int single;
union {
char *ptr;
STACK *set;
ASN1_TYPE *single;
} value;
} X509_ATTRIBUTE;
typedef struct X509_req_info_st {
ASN1_ENCODING enc;
ASN1_INTEGER *version;
X509_NAME *subject;
X509_PUBKEY *pubkey;
STACK *attributes;
} X509_REQ_INFO;
typedef struct X509_req_st {
X509_REQ_INFO *req_info;
X509_ALGOR *sig_alg;
ASN1_BIT_STRING *signature;
int references;
} X509_REQ;
typedef struct x509_cinf_st {
ASN1_INTEGER *serialNumber;
X509_ALGOR *signature;
X509_NAME *issuer;
X509_VAL *validity;
X509_NAME *subject;
X509_PUBKEY *key;
ASN1_BIT_STRING *issuerUID;
ASN1_BIT_STRING *subjectUID;
STACK *extensions;
ASN1_ENCODING enc;
} X509_CINF;
typedef struct x509_cert_aux_st {
STACK *trust;
STACK *reject;
ASN1_UTF8STRING *alias;
ASN1_OCTET_STRING *keyid;
STACK *other;
} X509_CERT_AUX;
struct x509_st {
X509_CINF *cert_info;
int valid;
int references;
char *name;
long ex_pathlen;
long ex_pcpathlen;
unsigned long ex_flags;
unsigned long ex_kusage;
unsigned long ex_xkusage;
unsigned long ex_nscert;
ASN1_OCTET_STRING *skid;
struct AUTHORITY_KEYID_st *akid;
X509_POLICY_CACHE *policy_cache;
unsigned char sha1_hash[20];
X509_CERT_AUX *aux;
typedef struct x509_trust_st {
int trust;
int flags;
int (*check_trust) (struct x509_trust_st *, X509 *, int);
char *name;
int arg1;
void *arg2;
} X509_TRUST;
typedef struct x509_cert_pair_st {
X509 *forward;
X509 *reverse;
} X509_CERT_PAIR;
#line 319 "/usr/include/openssl/x509.h"
#line 349 "/usr/include/openssl/x509.h"
#line 362 "/usr/include/openssl/x509.h"
#line 410 "/usr/include/openssl/x509.h"
typedef struct X509_revoked_st {
ASN1_TIME *revocationDate;
STACK *extensions;
int sequence;
} X509_REVOKED;
typedef struct X509_crl_info_st {
X509_NAME *issuer;
ASN1_TIME *lastUpdate;
ASN1_TIME *nextUpdate;
STACK *revoked;
STACK *extensions;
ASN1_ENCODING enc;
} X509_CRL_INFO;
struct X509_crl_st {
X509_CRL_INFO *crl;
int references;
typedef struct private_key_st {
int version;
X509_ALGOR *enc_algor;
ASN1_OCTET_STRING *enc_pkey;
EVP_PKEY *dec_pkey;
int key_length;
char *key_data;
int key_free;
EVP_CIPHER_INFO cipher;
int references;
} X509_PKEY;
typedef struct X509_info_st {
X509 *x509;
X509_CRL *crl;
X509_PKEY *x_pkey;
EVP_CIPHER_INFO enc_cipher;
int enc_len;
char *enc_data;
int references;
} X509_INFO;
typedef struct Netscape_spkac_st {
ASN1_IA5STRING *challenge;
} NETSCAPE_SPKAC;
typedef struct Netscape_spki_st {
NETSCAPE_SPKAC *spkac;
X509_ALGOR *sig_algor;
} NETSCAPE_SPKI;
typedef struct Netscape_certificate_sequence {
ASN1_OBJECT *type;
STACK *certs;
} NETSCAPE_CERT_SEQUENCE;
typedef struct PBEPARAM_st {
ASN1_OCTET_STRING *salt;
ASN1_INTEGER *iter;
} PBEPARAM;
typedef struct PBE2PARAM_st {
X509_ALGOR *keyfunc;
X509_ALGOR *encryption;
} PBE2PARAM;
typedef struct PBKDF2PARAM_st {
ASN1_TYPE *salt;
ASN1_INTEGER *iter;
ASN1_INTEGER *keylength;
X509_ALGOR *prf;
} PBKDF2PARAM;
typedef struct pkcs8_priv_key_info_st {
int broken;
X509_ALGOR *pkeyalg;
ASN1_TYPE *pkey;
STACK *attributes;
} PKCS8_PRIV_KEY_INFO;
#line 1 "/usr/include/openssl/x509_vfy.h"
#line 66 "/usr/include/openssl/x509_vfy.h"
#line 71 "/usr/include/openssl/x509_vfy.h"
#line 1 "/usr/include/openssl/lhash.h"
#line 67 "/usr/include/openssl/lhash.h"
typedef struct lhash_node_st {
void *data;
struct lhash_node_st *next;
unsigned long hash;
} LHASH_NODE;
typedef int (*LHASH_COMP_FN_TYPE) (const void *, const void *);
typedef unsigned long (*LHASH_HASH_FN_TYPE) (const void *);
typedef void (*LHASH_DOALL_FN_TYPE) (void *);
typedef void (*LHASH_DOALL_ARG_FN_TYPE) (void *, void *);
#line 109 "/usr/include/openssl/lhash.h"
#line 119 "/usr/include/openssl/lhash.h"
#line 128 "/usr/include/openssl/lhash.h"
#line 138 "/usr/include/openssl/lhash.h"
typedef struct lhash_st {
LHASH_NODE **b;
LHASH_COMP_FN_TYPE comp;
LHASH_HASH_FN_TYPE hash;
unsigned int num_nodes;
unsigned int num_alloc_nodes;
unsigned int p;
unsigned int pmax;
unsigned long up_load;
unsigned long down_load;
unsigned long num_items;
unsigned long num_expands;
unsigned long num_expand_reallocs;
unsigned long num_contracts;
unsigned long num_contract_reallocs;
unsigned long num_hash_calls;
unsigned long num_comp_calls;
unsigned long num_insert;
unsigned long num_replace;
unsigned long num_delete;
unsigned long num_no_delete;
unsigned long num_retrieve;
unsigned long num_retrieve_miss;
unsigned long num_hash_comps;
int error;
} LHASH;
LHASH *lh_new(LHASH_HASH_FN_TYPE h, LHASH_COMP_FN_TYPE c);
void lh_free(LHASH *lh);
void *lh_insert(LHASH *lh, void *data);
void *lh_delete(LHASH *lh, const void *data);
void *lh_retrieve(LHASH *lh, const void *data);
void lh_doall(LHASH *lh, LHASH_DOALL_FN_TYPE func);
void lh_doall_arg(LHASH *lh, LHASH_DOALL_ARG_FN_TYPE func, void *arg);
unsigned long lh_strhash(const char *c);
unsigned long lh_num_items(const LHASH *lh);
void lh_stats(const LHASH *lh, FILE *out);
void lh_node_stats(const LHASH *lh, FILE *out);
void lh_node_usage_stats(const LHASH *lh, FILE *out);
void lh_stats_bio(const LHASH *lh, BIO *out);
void lh_node_stats_bio(const LHASH *lh, BIO *out);
void lh_node_usage_stats_bio(const LHASH *lh, BIO *out);
#line 73 "/usr/include/openssl/x509_vfy.h"
#line 1 "/usr/include/openssl/symhacks.h"
#line 436 "/usr/include/openssl/symhacks.h"
#line 77 "/usr/include/openssl/x509_vfy.h"
typedef struct x509_hash_dir_st {
int num_dirs;
char **dirs;
int *dirs_type;
int num_dirs_alloced;
} X509_HASH_DIR_CTX;
typedef struct x509_file_st {
int num_paths;
int num_alloced;
char **paths;
int *path_type;
} X509_CERT_FILE_CTX;
typedef struct x509_object_st {
int type;
union {
char *ptr;
X509 *x509;
X509_CRL *crl;
EVP_PKEY *pkey;
} data;
} X509_OBJECT;
typedef struct x509_lookup_st X509_LOOKUP;
typedef struct x509_lookup_method_st {
const char *name;
int (*new_item) (X509_LOOKUP *ctx);
void (*free) (X509_LOOKUP *ctx);
int (*init) (X509_LOOKUP *ctx);
int (*shutdown) (X509_LOOKUP *ctx);
int (*ctrl) (X509_LOOKUP *ctx, int cmd, const char *argc, long argl,
char **ret);
int (*get_by_subject) (X509_LOOKUP *ctx, int type, X509_NAME *name,
X509_OBJECT *ret);
int (*get_by_issuer_serial) (X509_LOOKUP *ctx, int type, X509_NAME *name,
ASN1_INTEGER *serial, X509_OBJECT *ret);
int (*get_by_fingerprint) (X509_LOOKUP *ctx, int type,
unsigned char *bytes, int len,
X509_OBJECT *ret);
int (*get_by_alias) (X509_LOOKUP *ctx, int type, char *str, int len,
X509_OBJECT *ret);
} X509_LOOKUP_METHOD;
typedef struct X509_VERIFY_PARAM_st {
char *name;
time_t check_time;
unsigned long inh_flags;
int purpose;
int trust;
int depth;
STACK *policies;
} X509_VERIFY_PARAM;
struct x509_store_st {
int cache;
STACK *objs;
STACK *get_cert_methods;
X509_VERIFY_PARAM *param;
int (*verify) (X509_STORE_CTX *ctx);
int (*verify_cb) (int ok, X509_STORE_CTX *ctx);
int (*get_issuer) (X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
int (*check_issued) (X509_STORE_CTX *ctx, X509 *x, X509 *issuer);
int (*check_revocation) (X509_STORE_CTX *ctx);
int (*get_crl) (X509_STORE_CTX *ctx, X509_CRL **crl, X509 *x);
int (*check_crl) (X509_STORE_CTX *ctx, X509_CRL *crl);
int (*cert_crl) (X509_STORE_CTX *ctx, X509_CRL *crl, X509 *x);
int (*cleanup) (X509_STORE_CTX *ctx);
int references;
int X509_STORE_set_depth(X509_STORE *store, int depth);
struct x509_lookup_st {
int init;
int skip;
X509_LOOKUP_METHOD *method;
char *method_data;
X509_STORE *store_ctx;
struct x509_store_ctx_st {
X509_STORE *ctx;
int current_method;
X509 *cert;
STACK *untrusted;
STACK *crls;
void *other_ctx;
int (*check_policy) (X509_STORE_CTX *ctx);
int valid;
int last_untrusted;
STACK *chain;
X509_POLICY_TREE *tree;
int explicit_policy;
int error_depth;
int error;
X509 *current_cert;
X509 *current_issuer;
X509_CRL *current_crl;
void X509_STORE_CTX_set_depth(X509_STORE_CTX *ctx, int depth);
#line 330 "/usr/include/openssl/x509_vfy.h"
#line 344 "/usr/include/openssl/x509_vfy.h"
int X509_OBJECT_idx_by_subject(STACK *h, int type,
X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_by_subject(STACK *h,
int type, X509_NAME *name);
X509_OBJECT *X509_OBJECT_retrieve_match(STACK *h,
X509_OBJECT *x);
void X509_OBJECT_up_ref_count(X509_OBJECT *a);
void X509_OBJECT_free_contents(X509_OBJECT *a);
X509_STORE *X509_STORE_new(void);
void X509_STORE_free(X509_STORE *v);
int X509_STORE_set_flags(X509_STORE *ctx, unsigned long flags);
int X509_STORE_set_purpose(X509_STORE *ctx, int purpose);
int X509_STORE_set_trust(X509_STORE *ctx, int trust);
int X509_STORE_set1_param(X509_STORE *ctx, X509_VERIFY_PARAM *pm);
X509_STORE_CTX *X509_STORE_CTX_new(void);
int X509_STORE_CTX_get1_issuer(X509 **issuer, X509_STORE_CTX *ctx, X509 *x);
void X509_STORE_CTX_free(X509_STORE_CTX *ctx);
int X509_STORE_CTX_init(X509_STORE_CTX *ctx, X509_STORE *store,
X509 *x509, STACK *chain);
void X509_STORE_CTX_trusted_stack(X509_STORE_CTX *ctx, STACK *sk);
void X509_STORE_CTX_cleanup(X509_STORE_CTX *ctx);
X509_LOOKUP *X509_STORE_add_lookup(X509_STORE *v, X509_LOOKUP_METHOD *m);
X509_LOOKUP_METHOD *X509_LOOKUP_hash_dir(void);
X509_LOOKUP_METHOD *X509_LOOKUP_file(void);
int X509_STORE_add_cert(X509_STORE *ctx, X509 *x);
int X509_STORE_add_crl(X509_STORE *ctx, X509_CRL *x);
int X509_STORE_get_by_subject(X509_STORE_CTX *vs, int type, X509_NAME *name,
X509_OBJECT *ret);
int X509_LOOKUP_ctrl(X509_LOOKUP *ctx, int cmd, const char *argc,
long argl, char **ret);
int X509_load_cert_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_crl_file(X509_LOOKUP *ctx, const char *file, int type);
int X509_load_cert_crl_file(X509_LOOKUP *ctx, const char *file, int type);
X509_LOOKUP *X509_LOOKUP_new(X509_LOOKUP_METHOD *method);
void X509_LOOKUP_free(X509_LOOKUP *ctx);
int X509_LOOKUP_init(X509_LOOKUP *ctx);
int X509_LOOKUP_by_subject(X509_LOOKUP *ctx, int type, X509_NAME *name,
X509_OBJECT *ret);
int X509_LOOKUP_by_issuer_serial(X509_LOOKUP *ctx, int type, X509_NAME *name,
int X509_LOOKUP_by_fingerprint(X509_LOOKUP *ctx, int type,
X509_OBJECT *ret);
int X509_LOOKUP_by_alias(X509_LOOKUP *ctx, int type, char *str, int len,
X509_OBJECT *ret);
int X509_LOOKUP_shutdown(X509_LOOKUP *ctx);
int X509_STORE_load_locations(X509_STORE *ctx,
const char *file, const char *dir);
int X509_STORE_set_default_paths(X509_STORE *ctx);
int X509_STORE_CTX_get_ex_new_index(long argl, void *argp,
int X509_STORE_CTX_set_ex_data(X509_STORE_CTX *ctx, int idx, void *data);
void *X509_STORE_CTX_get_ex_data(X509_STORE_CTX *ctx, int idx);
int X509_STORE_CTX_get_error(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_error(X509_STORE_CTX *ctx, int s);
int X509_STORE_CTX_get_error_depth(X509_STORE_CTX *ctx);
X509 *X509_STORE_CTX_get_current_cert(X509_STORE_CTX *ctx);
STACK *X509_STORE_CTX_get_chain(X509_STORE_CTX *ctx);
STACK *X509_STORE_CTX_get1_chain(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set_cert(X509_STORE_CTX *c, X509 *x);
void X509_STORE_CTX_set_chain(X509_STORE_CTX *c, STACK *sk);
void X509_STORE_CTX_set0_crls(X509_STORE_CTX *c, STACK *sk);
int X509_STORE_CTX_set_purpose(X509_STORE_CTX *ctx, int purpose);
int X509_STORE_CTX_set_trust(X509_STORE_CTX *ctx, int trust);
int X509_STORE_CTX_purpose_inherit(X509_STORE_CTX *ctx, int def_purpose,
int purpose, int trust);
void X509_STORE_CTX_set_flags(X509_STORE_CTX *ctx, unsigned long flags);
void X509_STORE_CTX_set_time(X509_STORE_CTX *ctx, unsigned long flags,
time_t t);
void X509_STORE_CTX_set_verify_cb(X509_STORE_CTX *ctx,
int (*verify_cb) (int, X509_STORE_CTX *));
X509_POLICY_TREE *X509_STORE_CTX_get0_policy_tree(X509_STORE_CTX *ctx);
int X509_STORE_CTX_get_explicit_policy(X509_STORE_CTX *ctx);
X509_VERIFY_PARAM *X509_STORE_CTX_get0_param(X509_STORE_CTX *ctx);
void X509_STORE_CTX_set0_param(X509_STORE_CTX *ctx, X509_VERIFY_PARAM *param);
int X509_STORE_CTX_set_default(X509_STORE_CTX *ctx, const char *name);
X509_VERIFY_PARAM *X509_VERIFY_PARAM_new(void);
void X509_VERIFY_PARAM_free(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_inherit(X509_VERIFY_PARAM *to,
const X509_VERIFY_PARAM *from);
int X509_VERIFY_PARAM_set1(X509_VERIFY_PARAM *to,
int X509_VERIFY_PARAM_set1_name(X509_VERIFY_PARAM *param, const char *name);
int X509_VERIFY_PARAM_set_flags(X509_VERIFY_PARAM *param,
int X509_VERIFY_PARAM_clear_flags(X509_VERIFY_PARAM *param,
unsigned long X509_VERIFY_PARAM_get_flags(X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_set_purpose(X509_VERIFY_PARAM *param, int purpose);
int X509_VERIFY_PARAM_set_trust(X509_VERIFY_PARAM *param, int trust);
void X509_VERIFY_PARAM_set_depth(X509_VERIFY_PARAM *param, int depth);
void X509_VERIFY_PARAM_set_time(X509_VERIFY_PARAM *param, time_t t);
int X509_VERIFY_PARAM_add0_policy(X509_VERIFY_PARAM *param,
ASN1_OBJECT *policy);
int X509_VERIFY_PARAM_set1_policies(X509_VERIFY_PARAM *param,
STACK *policies);
int X509_VERIFY_PARAM_get_depth(const X509_VERIFY_PARAM *param);
int X509_VERIFY_PARAM_add0_table(X509_VERIFY_PARAM *param);
const X509_VERIFY_PARAM *X509_VERIFY_PARAM_lookup(const char *name);
void X509_VERIFY_PARAM_table_cleanup(void);
int X509_policy_check(X509_POLICY_TREE **ptree, int *pexplicit_policy,
STACK *certs,
STACK *policy_oids, unsigned int flags);
void X509_policy_tree_free(X509_POLICY_TREE *tree);
int X509_policy_tree_level_count(const X509_POLICY_TREE *tree);
X509_POLICY_LEVEL *X509_policy_tree_get0_level(const X509_POLICY_TREE *tree,
int i);
STACK *X509_policy_tree_get0_policies(const
X509_POLICY_TREE
*tree);
STACK *X509_policy_tree_get0_user_policies(const
X509_POLICY_TREE
*tree);
int X509_policy_level_node_count(X509_POLICY_LEVEL *level);
X509_POLICY_NODE *X509_policy_level_get0_node(X509_POLICY_LEVEL *level,
int i);
const ASN1_OBJECT *X509_policy_node_get0_policy(const X509_POLICY_NODE *node);
STACK *X509_policy_node_get0_qualifiers(const
X509_POLICY_NODE
*node);
const X509_POLICY_NODE *X509_policy_node_get0_parent(const X509_POLICY_NODE
*node);
#line 545 "/usr/include/openssl/x509.h"
#line 1 "/usr/include/openssl/pkcs7.h"
#line 65 "/usr/include/openssl/pkcs7.h"
#line 67 "/usr/include/openssl/pkcs7.h"
typedef struct pkcs7_issuer_and_serial_st {
X509_NAME *issuer;
ASN1_INTEGER *serial;
} PKCS7_ISSUER_AND_SERIAL;
typedef struct pkcs7_signer_info_st {
PKCS7_ISSUER_AND_SERIAL *issuer_and_serial;
X509_ALGOR *digest_alg;
STACK *auth_attr;
X509_ALGOR *digest_enc_alg;
ASN1_OCTET_STRING *enc_digest;
STACK *unauth_attr;
EVP_PKEY *pkey;
} PKCS7_SIGNER_INFO;
typedef struct pkcs7_recip_info_st {
X509_ALGOR *key_enc_algor;
ASN1_OCTET_STRING *enc_key;
X509 *cert;
} PKCS7_RECIP_INFO;
typedef struct pkcs7_signed_st {
STACK *md_algs;
STACK *cert;
STACK *crl;
STACK *signer_info;
struct pkcs7_st *contents;
} PKCS7_SIGNED;
typedef struct pkcs7_enc_content_st {
ASN1_OBJECT *content_type;
X509_ALGOR *algorithm;
ASN1_OCTET_STRING *enc_data;
} PKCS7_ENC_CONTENT;
typedef struct pkcs7_enveloped_st {
STACK *recipientinfo;
PKCS7_ENC_CONTENT *enc_data;
} PKCS7_ENVELOPE;
typedef struct pkcs7_signedandenveloped_st {
STACK *md_algs;
STACK *cert;
STACK *crl;
STACK *signer_info;
} PKCS7_SIGN_ENVELOPE;
typedef struct pkcs7_digest_st {
X509_ALGOR *md;
} PKCS7_DIGEST;
typedef struct pkcs7_encrypted_st {
} PKCS7_ENCRYPT;
typedef struct pkcs7_st {
unsigned char *asn1;
long length;
int state;
int detached;
ASN1_OBJECT *type;
union {
char *ptr;
ASN1_OCTET_STRING *data;
PKCS7_SIGNED *sign;
PKCS7_ENVELOPE *enveloped;
PKCS7_SIGN_ENVELOPE *signed_and_enveloped;
PKCS7_DIGEST *digest;
PKCS7_ENCRYPT *encrypted;
ASN1_TYPE *other;
} d;
} PKCS7;
#line 218 "/usr/include/openssl/pkcs7.h"
#line 235 "/usr/include/openssl/pkcs7.h"
#line 252 "/usr/include/openssl/pkcs7.h"
#line 264 "/usr/include/openssl/pkcs7.h"
PKCS7_ISSUER_AND_SERIAL *PKCS7_ISSUER_AND_SERIAL_new(void); void PKCS7_ISSUER_AND_SERIAL_free(PKCS7_ISSUER_AND_SERIAL *a); PKCS7_ISSUER_AND_SERIAL *d2i_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL * *a, const unsigned char * *in, long len); int i2d_PKCS7_ISSUER_AND_SERIAL(PKCS7_ISSUER_AND_SERIAL *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_ISSUER_AND_SERIAL_it;
int PKCS7_ISSUER_AND_SERIAL_digest(PKCS7_ISSUER_AND_SERIAL *data,
const EVP_MD *type, unsigned char *md,
unsigned int *len);
PKCS7 *d2i_PKCS7_fp(FILE *fp, PKCS7 **p7);
int i2d_PKCS7_fp(FILE *fp, PKCS7 *p7);
PKCS7 *PKCS7_dup(PKCS7 *p7);
PKCS7 *d2i_PKCS7_bio(BIO *bp, PKCS7 **p7);
int i2d_PKCS7_bio(BIO *bp, PKCS7 *p7);
PKCS7_SIGNER_INFO *PKCS7_SIGNER_INFO_new(void); void PKCS7_SIGNER_INFO_free(PKCS7_SIGNER_INFO *a); PKCS7_SIGNER_INFO *d2i_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO * *a, const unsigned char * *in, long len); int i2d_PKCS7_SIGNER_INFO(PKCS7_SIGNER_INFO *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_SIGNER_INFO_it;
PKCS7_RECIP_INFO *PKCS7_RECIP_INFO_new(void); void PKCS7_RECIP_INFO_free(PKCS7_RECIP_INFO *a); PKCS7_RECIP_INFO *d2i_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO * *a, const unsigned char * *in, long len); int i2d_PKCS7_RECIP_INFO(PKCS7_RECIP_INFO *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_RECIP_INFO_it;
PKCS7_SIGNED *PKCS7_SIGNED_new(void); void PKCS7_SIGNED_free(PKCS7_SIGNED *a); PKCS7_SIGNED *d2i_PKCS7_SIGNED(PKCS7_SIGNED * *a, const unsigned char * *in, long len); int i2d_PKCS7_SIGNED(PKCS7_SIGNED *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_SIGNED_it;
PKCS7_ENC_CONTENT *PKCS7_ENC_CONTENT_new(void); void PKCS7_ENC_CONTENT_free(PKCS7_ENC_CONTENT *a); PKCS7_ENC_CONTENT *d2i_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT * *a, const unsigned char * *in, long len); int i2d_PKCS7_ENC_CONTENT(PKCS7_ENC_CONTENT *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_ENC_CONTENT_it;
PKCS7_ENVELOPE *PKCS7_ENVELOPE_new(void); void PKCS7_ENVELOPE_free(PKCS7_ENVELOPE *a); PKCS7_ENVELOPE *d2i_PKCS7_ENVELOPE(PKCS7_ENVELOPE * *a, const unsigned char * *in, long len); int i2d_PKCS7_ENVELOPE(PKCS7_ENVELOPE *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_ENVELOPE_it;
PKCS7_SIGN_ENVELOPE *PKCS7_SIGN_ENVELOPE_new(void); void PKCS7_SIGN_ENVELOPE_free(PKCS7_SIGN_ENVELOPE *a); PKCS7_SIGN_ENVELOPE *d2i_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE * *a, const unsigned char * *in, long len); int i2d_PKCS7_SIGN_ENVELOPE(PKCS7_SIGN_ENVELOPE *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_SIGN_ENVELOPE_it;
PKCS7_DIGEST *PKCS7_DIGEST_new(void); void PKCS7_DIGEST_free(PKCS7_DIGEST *a); PKCS7_DIGEST *d2i_PKCS7_DIGEST(PKCS7_DIGEST * *a, const unsigned char * *in, long len); int i2d_PKCS7_DIGEST(PKCS7_DIGEST *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_DIGEST_it;
PKCS7_ENCRYPT *PKCS7_ENCRYPT_new(void); void PKCS7_ENCRYPT_free(PKCS7_ENCRYPT *a); PKCS7_ENCRYPT *d2i_PKCS7_ENCRYPT(PKCS7_ENCRYPT * *a, const unsigned char * *in, long len); int i2d_PKCS7_ENCRYPT(PKCS7_ENCRYPT *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_ENCRYPT_it;
PKCS7 *PKCS7_new(void); void PKCS7_free(PKCS7 *a); PKCS7 *d2i_PKCS7(PKCS7 * *a, const unsigned char * *in, long len); int i2d_PKCS7(PKCS7 *a, unsigned char * *out); extern const ASN1_ITEM PKCS7_it;
extern const ASN1_ITEM PKCS7_ATTR_SIGN_it;
extern const ASN1_ITEM PKCS7_ATTR_VERIFY_it;
int i2d_PKCS7_NDEF(PKCS7 *a, unsigned char * *out);
long PKCS7_ctrl(PKCS7 *p7, int cmd, long larg, char *parg);
int PKCS7_set_type(PKCS7 *p7, int type);
int PKCS7_set0_type_other(PKCS7 *p7, int type, ASN1_TYPE *other);
int PKCS7_set_content(PKCS7 *p7, PKCS7 *p7_data);
int PKCS7_SIGNER_INFO_set(PKCS7_SIGNER_INFO *p7i, X509 *x509, EVP_PKEY *pkey,
int PKCS7_add_signer(PKCS7 *p7, PKCS7_SIGNER_INFO *p7i);
int PKCS7_add_certificate(PKCS7 *p7, X509 *x509);
int PKCS7_add_crl(PKCS7 *p7, X509_CRL *x509);
int PKCS7_content_new(PKCS7 *p7, int nid);
int PKCS7_dataVerify(X509_STORE *cert_store, X509_STORE_CTX *ctx,
BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_signatureVerify(BIO *bio, PKCS7 *p7, PKCS7_SIGNER_INFO *si,
X509 *x509);
BIO *PKCS7_dataInit(PKCS7 *p7, BIO *bio);
int PKCS7_dataFinal(PKCS7 *p7, BIO *bio);
BIO *PKCS7_dataDecode(PKCS7 *p7, EVP_PKEY *pkey, BIO *in_bio, X509 *pcert);
PKCS7_SIGNER_INFO *PKCS7_add_signature(PKCS7 *p7, X509 *x509,
EVP_PKEY *pkey, const EVP_MD *dgst);
X509 *PKCS7_cert_from_signer_info(PKCS7 *p7, PKCS7_SIGNER_INFO *si);
int PKCS7_set_digest(PKCS7 *p7, const EVP_MD *md);
STACK *PKCS7_get_signer_info(PKCS7 *p7);
PKCS7_RECIP_INFO *PKCS7_add_recipient(PKCS7 *p7, X509 *x509);
int PKCS7_add_recipient_info(PKCS7 *p7, PKCS7_RECIP_INFO *ri);
int PKCS7_RECIP_INFO_set(PKCS7_RECIP_INFO *p7i, X509 *x509);
int PKCS7_set_cipher(PKCS7 *p7, const EVP_CIPHER *cipher);
PKCS7_ISSUER_AND_SERIAL *PKCS7_get_issuer_and_serial(PKCS7 *p7, int idx);
ASN1_OCTET_STRING *PKCS7_digest_from_attributes(STACK *sk);
int PKCS7_add_signed_attribute(PKCS7_SIGNER_INFO *p7si, int nid, int type,
void *data);
int PKCS7_add_attribute(PKCS7_SIGNER_INFO *p7si, int nid, int atrtype,
void *value);
ASN1_TYPE *PKCS7_get_attribute(PKCS7_SIGNER_INFO *si, int nid);
ASN1_TYPE *PKCS7_get_signed_attribute(PKCS7_SIGNER_INFO *si, int nid);
int PKCS7_set_signed_attributes(PKCS7_SIGNER_INFO *p7si,
STACK *sk);
int PKCS7_set_attributes(PKCS7_SIGNER_INFO *p7si,
STACK *sk);
PKCS7 *PKCS7_sign(X509 *signcert, EVP_PKEY *pkey, STACK *certs,
BIO *data, int flags);
int PKCS7_verify(PKCS7 *p7, STACK *certs, X509_STORE *store,
BIO *indata, BIO *out, int flags);
STACK *PKCS7_get0_signers(PKCS7 *p7, STACK *certs,
int flags);
PKCS7 *PKCS7_encrypt(STACK *certs, BIO *in, const EVP_CIPHER *cipher,
int flags);
int PKCS7_decrypt(PKCS7 *p7, EVP_PKEY *pkey, X509 *cert, BIO *data,
int flags);
int PKCS7_add_attrib_smimecap(PKCS7_SIGNER_INFO *si,
STACK *cap);
STACK *PKCS7_get_smimecap(PKCS7_SIGNER_INFO *si);
int PKCS7_simple_smimecap(STACK *sk, int nid, int arg);
int SMIME_write_PKCS7(BIO *bio, PKCS7 *p7, BIO *data, int flags);
PKCS7 *SMIME_read_PKCS7(BIO *bio, BIO **bcont);
int SMIME_crlf_copy(BIO *in, BIO *out, int flags);
int SMIME_text(BIO *in, BIO *out);
void ERR_load_PKCS7_strings(void);
#line 398 "/usr/include/openssl/pkcs7.h"
#line 446 "/usr/include/openssl/pkcs7.h"
#line 546 "/usr/include/openssl/x509.h"
#line 695 "/usr/include/openssl/x509.h"
#line 709 "/usr/include/openssl/x509.h"
const char *X509_verify_cert_error_string(long n);
int X509_verify(X509 *a, EVP_PKEY *r);
int X509_REQ_verify(X509_REQ *a, EVP_PKEY *r);
int X509_CRL_verify(X509_CRL *a, EVP_PKEY *r);
int NETSCAPE_SPKI_verify(NETSCAPE_SPKI *a, EVP_PKEY *r);
NETSCAPE_SPKI *NETSCAPE_SPKI_b64_decode(const char *str, int len);
char *NETSCAPE_SPKI_b64_encode(NETSCAPE_SPKI *x);
EVP_PKEY *NETSCAPE_SPKI_get_pubkey(NETSCAPE_SPKI *x);
int NETSCAPE_SPKI_set_pubkey(NETSCAPE_SPKI *x, EVP_PKEY *pkey);
int NETSCAPE_SPKI_print(BIO *out, NETSCAPE_SPKI *spki);
int X509_signature_print(BIO *bp, X509_ALGOR *alg, ASN1_STRING *sig);
int X509_sign(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_REQ_sign(X509_REQ *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_CRL_sign(X509_CRL *x, EVP_PKEY *pkey, const EVP_MD *md);
int NETSCAPE_SPKI_sign(NETSCAPE_SPKI *x, EVP_PKEY *pkey, const EVP_MD *md);
int X509_pubkey_digest(const X509 *data, const EVP_MD *type,
unsigned char *md, unsigned int *len);
int X509_digest(const X509 *data, const EVP_MD *type,
int X509_CRL_digest(const X509_CRL *data, const EVP_MD *type,
int X509_REQ_digest(const X509_REQ *data, const EVP_MD *type,
int X509_NAME_digest(const X509_NAME *data, const EVP_MD *type,
X509 *d2i_X509_fp(FILE *fp, X509 **x509);
int i2d_X509_fp(FILE *fp, X509 *x509);
X509_CRL *d2i_X509_CRL_fp(FILE *fp, X509_CRL **crl);
int i2d_X509_CRL_fp(FILE *fp, X509_CRL *crl);
X509_REQ *d2i_X509_REQ_fp(FILE *fp, X509_REQ **req);
int i2d_X509_REQ_fp(FILE *fp, X509_REQ *req);
RSA *d2i_RSAPrivateKey_fp(FILE *fp, RSA **rsa);
int i2d_RSAPrivateKey_fp(FILE *fp, RSA *rsa);
RSA *d2i_RSAPublicKey_fp(FILE *fp, RSA **rsa);
int i2d_RSAPublicKey_fp(FILE *fp, RSA *rsa);
RSA *d2i_RSA_PUBKEY_fp(FILE *fp, RSA **rsa);
int i2d_RSA_PUBKEY_fp(FILE *fp, RSA *rsa);
DSA *d2i_DSA_PUBKEY_fp(FILE *fp, DSA **dsa);
int i2d_DSA_PUBKEY_fp(FILE *fp, DSA *dsa);
DSA *d2i_DSAPrivateKey_fp(FILE *fp, DSA **dsa);
int i2d_DSAPrivateKey_fp(FILE *fp, DSA *dsa);
X509_SIG *d2i_PKCS8_fp(FILE *fp, X509_SIG **p8);
int i2d_PKCS8_fp(FILE *fp, X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_fp(FILE *fp,
PKCS8_PRIV_KEY_INFO **p8inf);
int i2d_PKCS8_PRIV_KEY_INFO_fp(FILE *fp, PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_fp(FILE *fp, EVP_PKEY *key);
int i2d_PrivateKey_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_fp(FILE *fp, EVP_PKEY **a);
int i2d_PUBKEY_fp(FILE *fp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_fp(FILE *fp, EVP_PKEY **a);
X509 *d2i_X509_bio(BIO *bp, X509 **x509);
int i2d_X509_bio(BIO *bp, X509 *x509);
X509_CRL *d2i_X509_CRL_bio(BIO *bp, X509_CRL **crl);
int i2d_X509_CRL_bio(BIO *bp, X509_CRL *crl);
X509_REQ *d2i_X509_REQ_bio(BIO *bp, X509_REQ **req);
int i2d_X509_REQ_bio(BIO *bp, X509_REQ *req);
RSA *d2i_RSAPrivateKey_bio(BIO *bp, RSA **rsa);
int i2d_RSAPrivateKey_bio(BIO *bp, RSA *rsa);
RSA *d2i_RSAPublicKey_bio(BIO *bp, RSA **rsa);
int i2d_RSAPublicKey_bio(BIO *bp, RSA *rsa);
RSA *d2i_RSA_PUBKEY_bio(BIO *bp, RSA **rsa);
int i2d_RSA_PUBKEY_bio(BIO *bp, RSA *rsa);
DSA *d2i_DSA_PUBKEY_bio(BIO *bp, DSA **dsa);
int i2d_DSA_PUBKEY_bio(BIO *bp, DSA *dsa);
DSA *d2i_DSAPrivateKey_bio(BIO *bp, DSA **dsa);
int i2d_DSAPrivateKey_bio(BIO *bp, DSA *dsa);
X509_SIG *d2i_PKCS8_bio(BIO *bp, X509_SIG **p8);
int i2d_PKCS8_bio(BIO *bp, X509_SIG *p8);
PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO_bio(BIO *bp,
int i2d_PKCS8_PRIV_KEY_INFO_bio(BIO *bp, PKCS8_PRIV_KEY_INFO *p8inf);
int i2d_PKCS8PrivateKeyInfo_bio(BIO *bp, EVP_PKEY *key);
int i2d_PrivateKey_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PrivateKey_bio(BIO *bp, EVP_PKEY **a);
int i2d_PUBKEY_bio(BIO *bp, EVP_PKEY *pkey);
EVP_PKEY *d2i_PUBKEY_bio(BIO *bp, EVP_PKEY **a);
X509 *X509_dup(X509 *x509);
X509_ATTRIBUTE *X509_ATTRIBUTE_dup(X509_ATTRIBUTE *xa);
X509_EXTENSION *X509_EXTENSION_dup(X509_EXTENSION *ex);
X509_CRL *X509_CRL_dup(X509_CRL *crl);
X509_REQ *X509_REQ_dup(X509_REQ *req);
X509_ALGOR *X509_ALGOR_dup(X509_ALGOR *xn);
int X509_ALGOR_set0(X509_ALGOR *alg, ASN1_OBJECT *aobj, int ptype,
void *pval);
void X509_ALGOR_get0(ASN1_OBJECT **paobj, int *pptype, void **ppval,
X509_ALGOR *algor);
int X509_ALGOR_cmp(const X509_ALGOR *a, const X509_ALGOR *b);
X509_NAME *X509_NAME_dup(X509_NAME *xn);
X509_NAME_ENTRY *X509_NAME_ENTRY_dup(X509_NAME_ENTRY *ne);
int X509_cmp_time(ASN1_TIME *s, time_t *t);
int X509_cmp_current_time(ASN1_TIME *s);
ASN1_TIME *X509_time_adj(ASN1_TIME *s, long adj, time_t *t);
ASN1_TIME *X509_gmtime_adj(ASN1_TIME *s, long adj);
const char *X509_get_default_cert_area(void);
const char *X509_get_default_cert_dir(void);
const char *X509_get_default_cert_file(void);
const char *X509_get_default_cert_dir_env(void);
const char *X509_get_default_cert_file_env(void);
const char *X509_get_default_private_dir(void);
X509_REQ *X509_to_X509_REQ(X509 *x, EVP_PKEY *pkey, const EVP_MD *md);
X509 *X509_REQ_to_X509(X509_REQ *r, int days, EVP_PKEY *pkey);
X509_ALGOR *X509_ALGOR_new(void); void X509_ALGOR_free(X509_ALGOR *a); X509_ALGOR *d2i_X509_ALGOR(X509_ALGOR * *a, const unsigned char * *in, long len); int i2d_X509_ALGOR(X509_ALGOR *a, unsigned char * *out); extern const ASN1_ITEM X509_ALGOR_it;
X509_ALGORS *d2i_X509_ALGORS(X509_ALGORS * *a, const unsigned char * *in, long len); int i2d_X509_ALGORS(X509_ALGORS *a, unsigned char * *out); extern const ASN1_ITEM X509_ALGORS_it;
X509_VAL *X509_VAL_new(void); void X509_VAL_free(X509_VAL *a); X509_VAL *d2i_X509_VAL(X509_VAL * *a, const unsigned char * *in, long len); int i2d_X509_VAL(X509_VAL *a, unsigned char * *out); extern const ASN1_ITEM X509_VAL_it;
X509_PUBKEY *X509_PUBKEY_new(void); void X509_PUBKEY_free(X509_PUBKEY *a); X509_PUBKEY *d2i_X509_PUBKEY(X509_PUBKEY * *a, const unsigned char * *in, long len); int i2d_X509_PUBKEY(X509_PUBKEY *a, unsigned char * *out); extern const ASN1_ITEM X509_PUBKEY_it;
int X509_PUBKEY_set(X509_PUBKEY **x, EVP_PKEY *pkey);
EVP_PKEY *X509_PUBKEY_get(X509_PUBKEY *key);
int X509_get_pubkey_parameters(EVP_PKEY *pkey, STACK *chain);
int i2d_PUBKEY(EVP_PKEY *a, unsigned char **pp);
EVP_PKEY *d2i_PUBKEY(EVP_PKEY **a, const unsigned char **pp, long length);
int i2d_RSA_PUBKEY(RSA *a, unsigned char **pp);
RSA *d2i_RSA_PUBKEY(RSA **a, const unsigned char **pp, long length);
int i2d_DSA_PUBKEY(DSA *a, unsigned char **pp);
DSA *d2i_DSA_PUBKEY(DSA **a, const unsigned char **pp, long length);
X509_SIG *X509_SIG_new(void); void X509_SIG_free(X509_SIG *a); X509_SIG *d2i_X509_SIG(X509_SIG * *a, const unsigned char * *in, long len); int i2d_X509_SIG(X509_SIG *a, unsigned char * *out); extern const ASN1_ITEM X509_SIG_it;
X509_REQ_INFO *X509_REQ_INFO_new(void); void X509_REQ_INFO_free(X509_REQ_INFO *a); X509_REQ_INFO *d2i_X509_REQ_INFO(X509_REQ_INFO * *a, const unsigned char * *in, long len); int i2d_X509_REQ_INFO(X509_REQ_INFO *a, unsigned char * *out); extern const ASN1_ITEM X509_REQ_INFO_it;
X509_REQ *X509_REQ_new(void); void X509_REQ_free(X509_REQ *a); X509_REQ *d2i_X509_REQ(X509_REQ * *a, const unsigned char * *in, long len); int i2d_X509_REQ(X509_REQ *a, unsigned char * *out); extern const ASN1_ITEM X509_REQ_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_new(void); void X509_ATTRIBUTE_free(X509_ATTRIBUTE *a); X509_ATTRIBUTE *d2i_X509_ATTRIBUTE(X509_ATTRIBUTE * *a, const unsigned char * *in, long len); int i2d_X509_ATTRIBUTE(X509_ATTRIBUTE *a, unsigned char * *out); extern const ASN1_ITEM X509_ATTRIBUTE_it;
X509_ATTRIBUTE *X509_ATTRIBUTE_create(int nid, int atrtype, void *value);
X509_EXTENSION *X509_EXTENSION_new(void); void X509_EXTENSION_free(X509_EXTENSION *a); X509_EXTENSION *d2i_X509_EXTENSION(X509_EXTENSION * *a, const unsigned char * *in, long len); int i2d_X509_EXTENSION(X509_EXTENSION *a, unsigned char * *out); extern const ASN1_ITEM X509_EXTENSION_it;
X509_EXTENSIONS *d2i_X509_EXTENSIONS(X509_EXTENSIONS * *a, const unsigned char * *in, long len); int i2d_X509_EXTENSIONS(X509_EXTENSIONS *a, unsigned char * *out); extern const ASN1_ITEM X509_EXTENSIONS_it;
X509_NAME_ENTRY *X509_NAME_ENTRY_new(void); void X509_NAME_ENTRY_free(X509_NAME_ENTRY *a); X509_NAME_ENTRY *d2i_X509_NAME_ENTRY(X509_NAME_ENTRY * *a, const unsigned char * *in, long len); int i2d_X509_NAME_ENTRY(X509_NAME_ENTRY *a, unsigned char * *out); extern const ASN1_ITEM X509_NAME_ENTRY_it;
X509_NAME *X509_NAME_new(void); void X509_NAME_free(X509_NAME *a); X509_NAME *d2i_X509_NAME(X509_NAME * *a, const unsigned char * *in, long len); int i2d_X509_NAME(X509_NAME *a, unsigned char * *out); extern const ASN1_ITEM X509_NAME_it;
int X509_NAME_set(X509_NAME **xn, X509_NAME *name);
X509_CINF *X509_CINF_new(void); void X509_CINF_free(X509_CINF *a); X509_CINF *d2i_X509_CINF(X509_CINF * *a, const unsigned char * *in, long len); int i2d_X509_CINF(X509_CINF *a, unsigned char * *out); extern const ASN1_ITEM X509_CINF_it;
X509 *X509_new(void); void X509_free(X509 *a); X509 *d2i_X509(X509 * *a, const unsigned char * *in, long len); int i2d_X509(X509 *a, unsigned char * *out); extern const ASN1_ITEM X509_it;
X509_CERT_AUX *X509_CERT_AUX_new(void); void X509_CERT_AUX_free(X509_CERT_AUX *a); X509_CERT_AUX *d2i_X509_CERT_AUX(X509_CERT_AUX * *a, const unsigned char * *in, long len); int i2d_X509_CERT_AUX(X509_CERT_AUX *a, unsigned char * *out); extern const ASN1_ITEM X509_CERT_AUX_it;
X509_CERT_PAIR *X509_CERT_PAIR_new(void); void X509_CERT_PAIR_free(X509_CERT_PAIR *a); X509_CERT_PAIR *d2i_X509_CERT_PAIR(X509_CERT_PAIR * *a, const unsigned char * *in, long len); int i2d_X509_CERT_PAIR(X509_CERT_PAIR *a, unsigned char * *out); extern const ASN1_ITEM X509_CERT_PAIR_it;
int X509_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int X509_set_ex_data(X509 *r, int idx, void *arg);
void *X509_get_ex_data(X509 *r, int idx);
int i2d_X509_AUX(X509 *a, unsigned char **pp);
X509 *d2i_X509_AUX(X509 **a, const unsigned char **pp, long length);
int X509_alias_set1(X509 *x, unsigned char *name, int len);
int X509_keyid_set1(X509 *x, unsigned char *id, int len);
unsigned char *X509_alias_get0(X509 *x, int *len);
unsigned char *X509_keyid_get0(X509 *x, int *len);
int (*X509_TRUST_set_default(int (*trust) (int, X509 *, int))) (int, X509 *,
int);
int X509_TRUST_set(int *t, int trust);
int X509_add1_trust_object(X509 *x, ASN1_OBJECT *obj);
int X509_add1_reject_object(X509 *x, ASN1_OBJECT *obj);
void X509_trust_clear(X509 *x);
void X509_reject_clear(X509 *x);
X509_REVOKED *X509_REVOKED_new(void); void X509_REVOKED_free(X509_REVOKED *a); X509_REVOKED *d2i_X509_REVOKED(X509_REVOKED * *a, const unsigned char * *in, long len); int i2d_X509_REVOKED(X509_REVOKED *a, unsigned char * *out); extern const ASN1_ITEM X509_REVOKED_it;
X509_CRL_INFO *X509_CRL_INFO_new(void); void X509_CRL_INFO_free(X509_CRL_INFO *a); X509_CRL_INFO *d2i_X509_CRL_INFO(X509_CRL_INFO * *a, const unsigned char * *in, long len); int i2d_X509_CRL_INFO(X509_CRL_INFO *a, unsigned char * *out); extern const ASN1_ITEM X509_CRL_INFO_it;
X509_CRL *X509_CRL_new(void); void X509_CRL_free(X509_CRL *a); X509_CRL *d2i_X509_CRL(X509_CRL * *a, const unsigned char * *in, long len); int i2d_X509_CRL(X509_CRL *a, unsigned char * *out); extern const ASN1_ITEM X509_CRL_it;
int X509_CRL_add0_revoked(X509_CRL *crl, X509_REVOKED *rev);
X509_PKEY *X509_PKEY_new(void);
void X509_PKEY_free(X509_PKEY *a);
int i2d_X509_PKEY(X509_PKEY *a, unsigned char **pp);
X509_PKEY *d2i_X509_PKEY(X509_PKEY **a, const unsigned char **pp,
long length);
NETSCAPE_SPKI *NETSCAPE_SPKI_new(void); void NETSCAPE_SPKI_free(NETSCAPE_SPKI *a); NETSCAPE_SPKI *d2i_NETSCAPE_SPKI(NETSCAPE_SPKI * *a, const unsigned char * *in, long len); int i2d_NETSCAPE_SPKI(NETSCAPE_SPKI *a, unsigned char * *out); extern const ASN1_ITEM NETSCAPE_SPKI_it;
NETSCAPE_SPKAC *NETSCAPE_SPKAC_new(void); void NETSCAPE_SPKAC_free(NETSCAPE_SPKAC *a); NETSCAPE_SPKAC *d2i_NETSCAPE_SPKAC(NETSCAPE_SPKAC * *a, const unsigned char * *in, long len); int i2d_NETSCAPE_SPKAC(NETSCAPE_SPKAC *a, unsigned char * *out); extern const ASN1_ITEM NETSCAPE_SPKAC_it;
NETSCAPE_CERT_SEQUENCE *NETSCAPE_CERT_SEQUENCE_new(void); void NETSCAPE_CERT_SEQUENCE_free(NETSCAPE_CERT_SEQUENCE *a); NETSCAPE_CERT_SEQUENCE *d2i_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE * *a, const unsigned char * *in, long len); int i2d_NETSCAPE_CERT_SEQUENCE(NETSCAPE_CERT_SEQUENCE *a, unsigned char * *out); extern const ASN1_ITEM NETSCAPE_CERT_SEQUENCE_it;
X509_INFO *X509_INFO_new(void);
void X509_INFO_free(X509_INFO *a);
char *X509_NAME_oneline(X509_NAME *a, char *buf, int size);
int ASN1_verify(i2d_of_void *i2d, X509_ALGOR *algor1,
ASN1_BIT_STRING *signature, char *data, EVP_PKEY *pkey);
int ASN1_digest(i2d_of_void *i2d, const EVP_MD *type, char *data,
int ASN1_sign(i2d_of_void *i2d, X509_ALGOR *algor1,
X509_ALGOR *algor2, ASN1_BIT_STRING *signature,
char *data, EVP_PKEY *pkey, const EVP_MD *type);
int ASN1_item_digest(const ASN1_ITEM *it, const EVP_MD *type, void *data,
int ASN1_item_verify(const ASN1_ITEM *it, X509_ALGOR *algor1,
ASN1_BIT_STRING *signature, void *data, EVP_PKEY *pkey);
int ASN1_item_sign(const ASN1_ITEM *it, X509_ALGOR *algor1,
X509_ALGOR *algor2, ASN1_BIT_STRING *signature, void *data,
int X509_set_version(X509 *x, long version);
int X509_set_serialNumber(X509 *x, ASN1_INTEGER *serial);
ASN1_INTEGER *X509_get_serialNumber(X509 *x);
int X509_set_issuer_name(X509 *x, X509_NAME *name);
X509_NAME *X509_get_issuer_name(X509 *a);
int X509_set_subject_name(X509 *x, X509_NAME *name);
X509_NAME *X509_get_subject_name(X509 *a);
int X509_set_notBefore(X509 *x, ASN1_TIME *tm);
int X509_set_notAfter(X509 *x, ASN1_TIME *tm);
int X509_set_pubkey(X509 *x, EVP_PKEY *pkey);
EVP_PKEY *X509_get_pubkey(X509 *x);
ASN1_BIT_STRING *X509_get0_pubkey_bitstr(const X509 *x);
int X509_certificate_type(X509 *x, EVP_PKEY *pubkey );
int X509_REQ_set_version(X509_REQ *x, long version);
int X509_REQ_set_subject_name(X509_REQ *req, X509_NAME *name);
int X509_REQ_set_pubkey(X509_REQ *x, EVP_PKEY *pkey);
EVP_PKEY *X509_REQ_get_pubkey(X509_REQ *req);
int X509_REQ_extension_nid(int nid);
int *X509_REQ_get_extension_nids(void);
void X509_REQ_set_extension_nids(int *nids);
STACK *X509_REQ_get_extensions(X509_REQ *req);
int X509_REQ_add_extensions_nid(X509_REQ *req, STACK *exts,
int nid);
int X509_REQ_add_extensions(X509_REQ *req, STACK *exts);
int X509_REQ_get_attr_count(const X509_REQ *req);
int X509_REQ_get_attr_by_NID(const X509_REQ *req, int nid, int lastpos);
int X509_REQ_get_attr_by_OBJ(const X509_REQ *req, ASN1_OBJECT *obj,
int lastpos);
X509_ATTRIBUTE *X509_REQ_get_attr(const X509_REQ *req, int loc);
X509_ATTRIBUTE *X509_REQ_delete_attr(X509_REQ *req, int loc);
int X509_REQ_add1_attr(X509_REQ *req, X509_ATTRIBUTE *attr);
int X509_REQ_add1_attr_by_OBJ(X509_REQ *req,
const ASN1_OBJECT *obj, int type,
const unsigned char *bytes, int len);
int X509_REQ_add1_attr_by_NID(X509_REQ *req,
int nid, int type,
int X509_REQ_add1_attr_by_txt(X509_REQ *req,
const char *attrname, int type,
int X509_CRL_set_version(X509_CRL *x, long version);
int X509_CRL_set_issuer_name(X509_CRL *x, X509_NAME *name);
int X509_CRL_set_lastUpdate(X509_CRL *x, ASN1_TIME *tm);
int X509_CRL_set_nextUpdate(X509_CRL *x, ASN1_TIME *tm);
int X509_CRL_sort(X509_CRL *crl);
int X509_REVOKED_set_serialNumber(X509_REVOKED *x, ASN1_INTEGER *serial);
int X509_REVOKED_set_revocationDate(X509_REVOKED *r, ASN1_TIME *tm);
int X509_REQ_check_private_key(X509_REQ *x509, EVP_PKEY *pkey);
int X509_check_private_key(X509 *x509, EVP_PKEY *pkey);
int X509_issuer_and_serial_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_and_serial_hash(X509 *a);
int X509_issuer_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_issuer_name_hash(X509 *a);
int X509_subject_name_cmp(const X509 *a, const X509 *b);
unsigned long X509_subject_name_hash(X509 *x);
int X509_cmp(const X509 *a, const X509 *b);
int X509_NAME_cmp(const X509_NAME *a, const X509_NAME *b);
unsigned long X509_NAME_hash(X509_NAME *x);
int X509_CRL_cmp(const X509_CRL *a, const X509_CRL *b);
int X509_print_ex_fp(FILE *bp, X509 *x, unsigned long nmflag,
unsigned long cflag);
int X509_print_fp(FILE *bp, X509 *x);
int X509_CRL_print_fp(FILE *bp, X509_CRL *x);
int X509_REQ_print_fp(FILE *bp, X509_REQ *req);
int X509_NAME_print_ex_fp(FILE *fp, X509_NAME *nm, int indent,
int X509_NAME_print(BIO *bp, X509_NAME *name, int obase);
int X509_NAME_print_ex(BIO *out, X509_NAME *nm, int indent,
int X509_print_ex(BIO *bp, X509 *x, unsigned long nmflag,
int X509_print(BIO *bp, X509 *x);
int X509_ocspid_print(BIO *bp, X509 *x);
int X509_CERT_AUX_print(BIO *bp, X509_CERT_AUX *x, int indent);
int X509_CRL_print(BIO *bp, X509_CRL *x);
int X509_REQ_print_ex(BIO *bp, X509_REQ *x, unsigned long nmflag,
int X509_REQ_print(BIO *bp, X509_REQ *req);
int X509_NAME_entry_count(X509_NAME *name);
int X509_NAME_get_text_by_NID(X509_NAME *name, int nid, char *buf, int len);
int X509_NAME_get_text_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj,
int X509_NAME_get_index_by_NID(X509_NAME *name, int nid, int lastpos);
int X509_NAME_get_index_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj,
int lastpos);
X509_NAME_ENTRY *X509_NAME_get_entry(X509_NAME *name, int loc);
X509_NAME_ENTRY *X509_NAME_delete_entry(X509_NAME *name, int loc);
int X509_NAME_add_entry(X509_NAME *name, X509_NAME_ENTRY *ne,
int loc, int set);
int X509_NAME_add_entry_by_OBJ(X509_NAME *name, ASN1_OBJECT *obj, int type,
unsigned char *bytes, int len, int loc,
int set);
int X509_NAME_add_entry_by_NID(X509_NAME *name, int nid, int type,
int set);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_txt(X509_NAME_ENTRY **ne,
const char *field, int type,
int len);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_NID(X509_NAME_ENTRY **ne, int nid,
int type, unsigned char *bytes,
int len);
int X509_NAME_add_entry_by_txt(X509_NAME *name, const char *field, int type,
const unsigned char *bytes, int len, int loc,
int set);
X509_NAME_ENTRY *X509_NAME_ENTRY_create_by_OBJ(X509_NAME_ENTRY **ne,
int len);
int X509_NAME_ENTRY_set_object(X509_NAME_ENTRY *ne, ASN1_OBJECT *obj);
int X509_NAME_ENTRY_set_data(X509_NAME_ENTRY *ne, int type,
ASN1_OBJECT *X509_NAME_ENTRY_get_object(X509_NAME_ENTRY *ne);
ASN1_STRING *X509_NAME_ENTRY_get_data(X509_NAME_ENTRY *ne);
int X509v3_get_ext_count(const STACK *x);
int X509v3_get_ext_by_NID(const STACK *x,
int X509v3_get_ext_by_OBJ(const STACK *x,
ASN1_OBJECT *obj, int lastpos);
int X509v3_get_ext_by_critical(const STACK *x,
int crit, int lastpos);
X509_EXTENSION *X509v3_get_ext(const STACK *x, int loc);
X509_EXTENSION *X509v3_delete_ext(STACK *x, int loc);
STACK *X509v3_add_ext(STACK **x,
X509_EXTENSION *ex, int loc);
int X509_get_ext_count(X509 *x);
int X509_get_ext_by_NID(X509 *x, int nid, int lastpos);
int X509_get_ext_by_OBJ(X509 *x, ASN1_OBJECT *obj, int lastpos);
int X509_get_ext_by_critical(X509 *x, int crit, int lastpos);
X509_EXTENSION *X509_get_ext(X509 *x, int loc);
X509_EXTENSION *X509_delete_ext(X509 *x, int loc);
int X509_add_ext(X509 *x, X509_EXTENSION *ex, int loc);
void *X509_get_ext_d2i(X509 *x, int nid, int *crit, int *idx);
int X509_add1_ext_i2d(X509 *x, int nid, void *value, int crit,
int X509_CRL_get_ext_count(X509_CRL *x);
int X509_CRL_get_ext_by_NID(X509_CRL *x, int nid, int lastpos);
int X509_CRL_get_ext_by_OBJ(X509_CRL *x, ASN1_OBJECT *obj, int lastpos);
int X509_CRL_get_ext_by_critical(X509_CRL *x, int crit, int lastpos);
X509_EXTENSION *X509_CRL_get_ext(X509_CRL *x, int loc);
X509_EXTENSION *X509_CRL_delete_ext(X509_CRL *x, int loc);
int X509_CRL_add_ext(X509_CRL *x, X509_EXTENSION *ex, int loc);
void *X509_CRL_get_ext_d2i(X509_CRL *x, int nid, int *crit, int *idx);
int X509_CRL_add1_ext_i2d(X509_CRL *x, int nid, void *value, int crit,
int X509_REVOKED_get_ext_count(X509_REVOKED *x);
int X509_REVOKED_get_ext_by_NID(X509_REVOKED *x, int nid, int lastpos);
int X509_REVOKED_get_ext_by_OBJ(X509_REVOKED *x, ASN1_OBJECT *obj,
int lastpos);
int X509_REVOKED_get_ext_by_critical(X509_REVOKED *x, int crit, int lastpos);
X509_EXTENSION *X509_REVOKED_get_ext(X509_REVOKED *x, int loc);
X509_EXTENSION *X509_REVOKED_delete_ext(X509_REVOKED *x, int loc);
int X509_REVOKED_add_ext(X509_REVOKED *x, X509_EXTENSION *ex, int loc);
void *X509_REVOKED_get_ext_d2i(X509_REVOKED *x, int nid, int *crit, int *idx);
int X509_REVOKED_add1_ext_i2d(X509_REVOKED *x, int nid, void *value, int crit,
X509_EXTENSION *X509_EXTENSION_create_by_NID(X509_EXTENSION **ex,
int nid, int crit,
ASN1_OCTET_STRING *data);
X509_EXTENSION *X509_EXTENSION_create_by_OBJ(X509_EXTENSION **ex,
ASN1_OBJECT *obj, int crit,
int X509_EXTENSION_set_object(X509_EXTENSION *ex, ASN1_OBJECT *obj);
int X509_EXTENSION_set_critical(X509_EXTENSION *ex, int crit);
int X509_EXTENSION_set_data(X509_EXTENSION *ex, ASN1_OCTET_STRING *data);
ASN1_OBJECT *X509_EXTENSION_get_object(X509_EXTENSION *ex);
ASN1_OCTET_STRING *X509_EXTENSION_get_data(X509_EXTENSION *ne);
int X509_EXTENSION_get_critical(X509_EXTENSION *ex);
int X509at_get_attr_count(const STACK *x);
int X509at_get_attr_by_NID(const STACK *x, int nid,
int lastpos);
int X509at_get_attr_by_OBJ(const STACK *sk,
X509_ATTRIBUTE *X509at_get_attr(const STACK *x, int loc);
X509_ATTRIBUTE *X509at_delete_attr(STACK *x, int loc);
STACK *X509at_add1_attr(STACK **x,
STACK *X509at_add1_attr_by_OBJ(STACK
**x, const ASN1_OBJECT *obj,
int type,
int len);
STACK *X509at_add1_attr_by_NID(STACK
**x, int nid, int type,
int len);
STACK *X509at_add1_attr_by_txt(STACK
**x, const char *attrname,
int type,
int len);
void *X509at_get0_data_by_OBJ(STACK *x, ASN1_OBJECT *obj,
int lastpos, int type);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_NID(X509_ATTRIBUTE **attr, int nid,
int atrtype, const void *data,
int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_OBJ(X509_ATTRIBUTE **attr,
int len);
X509_ATTRIBUTE *X509_ATTRIBUTE_create_by_txt(X509_ATTRIBUTE **attr,
const char *atrname, int type,
int len);
int X509_ATTRIBUTE_set1_object(X509_ATTRIBUTE *attr, const ASN1_OBJECT *obj);
int X509_ATTRIBUTE_set1_data(X509_ATTRIBUTE *attr, int attrtype,
const void *data, int len);
void *X509_ATTRIBUTE_get0_data(X509_ATTRIBUTE *attr, int idx, int atrtype,
void *data);
int X509_ATTRIBUTE_count(X509_ATTRIBUTE *attr);
ASN1_OBJECT *X509_ATTRIBUTE_get0_object(X509_ATTRIBUTE *attr);
ASN1_TYPE *X509_ATTRIBUTE_get0_type(X509_ATTRIBUTE *attr, int idx);
int EVP_PKEY_get_attr_count(const EVP_PKEY *key);
int EVP_PKEY_get_attr_by_NID(const EVP_PKEY *key, int nid, int lastpos);
int EVP_PKEY_get_attr_by_OBJ(const EVP_PKEY *key, ASN1_OBJECT *obj,
int lastpos);
X509_ATTRIBUTE *EVP_PKEY_get_attr(const EVP_PKEY *key, int loc);
X509_ATTRIBUTE *EVP_PKEY_delete_attr(EVP_PKEY *key, int loc);
int EVP_PKEY_add1_attr(EVP_PKEY *key, X509_ATTRIBUTE *attr);
int EVP_PKEY_add1_attr_by_OBJ(EVP_PKEY *key,
int EVP_PKEY_add1_attr_by_NID(EVP_PKEY *key,
int nid, int type,
int EVP_PKEY_add1_attr_by_txt(EVP_PKEY *key,
int X509_verify_cert(X509_STORE_CTX *ctx);
X509 *X509_find_by_issuer_and_serial(STACK *sk, X509_NAME *name,
X509 *X509_find_by_subject(STACK *sk, X509_NAME *name);
PBEPARAM *PBEPARAM_new(void); void PBEPARAM_free(PBEPARAM *a); PBEPARAM *d2i_PBEPARAM(PBEPARAM * *a, const unsigned char * *in, long len); int i2d_PBEPARAM(PBEPARAM *a, unsigned char * *out); extern const ASN1_ITEM PBEPARAM_it;
PBE2PARAM *PBE2PARAM_new(void); void PBE2PARAM_free(PBE2PARAM *a); PBE2PARAM *d2i_PBE2PARAM(PBE2PARAM * *a, const unsigned char * *in, long len); int i2d_PBE2PARAM(PBE2PARAM *a, unsigned char * *out); extern const ASN1_ITEM PBE2PARAM_it;
PBKDF2PARAM *PBKDF2PARAM_new(void); void PBKDF2PARAM_free(PBKDF2PARAM *a); PBKDF2PARAM *d2i_PBKDF2PARAM(PBKDF2PARAM * *a, const unsigned char * *in, long len); int i2d_PBKDF2PARAM(PBKDF2PARAM *a, unsigned char * *out); extern const ASN1_ITEM PBKDF2PARAM_it;
X509_ALGOR *PKCS5_pbe_set(int alg, int iter, unsigned char *salt,
int saltlen);
X509_ALGOR *PKCS5_pbe2_set(const EVP_CIPHER *cipher, int iter,
unsigned char *salt, int saltlen);
PKCS8_PRIV_KEY_INFO *PKCS8_PRIV_KEY_INFO_new(void); void PKCS8_PRIV_KEY_INFO_free(PKCS8_PRIV_KEY_INFO *a); PKCS8_PRIV_KEY_INFO *d2i_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO * *a, const unsigned char * *in, long len); int i2d_PKCS8_PRIV_KEY_INFO(PKCS8_PRIV_KEY_INFO *a, unsigned char * *out); extern const ASN1_ITEM PKCS8_PRIV_KEY_INFO_it;
EVP_PKEY *EVP_PKCS82PKEY(PKCS8_PRIV_KEY_INFO *p8);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8(EVP_PKEY *pkey);
PKCS8_PRIV_KEY_INFO *EVP_PKEY2PKCS8_broken(EVP_PKEY *pkey, int broken);
PKCS8_PRIV_KEY_INFO *PKCS8_set_broken(PKCS8_PRIV_KEY_INFO *p8, int broken);
int X509_check_trust(X509 *x, int id, int flags);
int X509_TRUST_get_count(void);
X509_TRUST *X509_TRUST_get0(int idx);
int X509_TRUST_get_by_id(int id);
int X509_TRUST_add(int id, int flags, int (*ck) (X509_TRUST *, X509 *, int),
char *name, int arg1, void *arg2);
void X509_TRUST_cleanup(void);
int X509_TRUST_get_flags(X509_TRUST *xp);
char *X509_TRUST_get0_name(X509_TRUST *xp);
int X509_TRUST_get_trust(X509_TRUST *xp);
void ERR_load_X509_strings(void);
#line 1308 "/usr/include/openssl/x509.h"
#line 1333 "/usr/include/openssl/x509.h"
#line 184 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/pem.h"
#line 63 "/usr/include/openssl/pem.h"
#line 1 "/usr/include/openssl/pem2.h"
#line 72 "/usr/include/openssl/pem.h"
#line 97 "/usr/include/openssl/pem.h"
#line 106 "/usr/include/openssl/pem.h"
#line 113 "/usr/include/openssl/pem.h"
#line 138 "/usr/include/openssl/pem.h"
typedef struct PEM_Encode_Seal_st {
EVP_ENCODE_CTX encode;
EVP_MD_CTX md;
EVP_CIPHER_CTX cipher;
} PEM_ENCODE_SEAL_CTX;
typedef struct pem_recip_st {
char *name;
X509_NAME *dn;
int cipher;
int key_enc;
} PEM_USER;
typedef struct pem_ctx_st {
int type;
struct {
int version;
int mode;
} proc_type;
char *domain;
struct {
int cipher;
} DEK_info;
PEM_USER *originator;
int num_recipient;
PEM_USER **recipient;
STACK *x509_chain;
EVP_MD *md;
int md_enc;
int md_len;
char *md_data;
EVP_CIPHER *dec;
int key_len;
unsigned char *key;
int data_enc;
int data_len;
unsigned char *data;
} PEM_CTX;
#line 221 "/usr/include/openssl/pem.h"
#line 230 "/usr/include/openssl/pem.h"
#line 239 "/usr/include/openssl/pem.h"
#line 248 "/usr/include/openssl/pem.h"
#line 259 "/usr/include/openssl/pem.h"
#line 270 "/usr/include/openssl/pem.h"
#line 281 "/usr/include/openssl/pem.h"
#line 290 "/usr/include/openssl/pem.h"
#line 299 "/usr/include/openssl/pem.h"
#line 309 "/usr/include/openssl/pem.h"
#line 319 "/usr/include/openssl/pem.h"
#line 361 "/usr/include/openssl/pem.h"
#line 541 "/usr/include/openssl/pem.h"
typedef int pem_password_cb (char *buf, int size, int rwflag, void *userdata);
int PEM_get_EVP_CIPHER_INFO(char *header, EVP_CIPHER_INFO *cipher);
int PEM_do_header(EVP_CIPHER_INFO *cipher, unsigned char *data, long *len,
pem_password_cb *callback, void *u);
int PEM_read_bio(BIO *bp, char **name, char **header,
unsigned char **data, long *len);
int PEM_write_bio(BIO *bp, const char *name, char *hdr, unsigned char *data,
long len);
int PEM_bytes_read_bio(unsigned char **pdata, long *plen, char **pnm,
const char *name, BIO *bp, pem_password_cb *cb,
void *u);
void *PEM_ASN1_read_bio(d2i_of_void *d2i, const char *name, BIO *bp, void **x,
pem_password_cb *cb, void *u);
int PEM_ASN1_write_bio(i2d_of_void *i2d, const char *name, BIO *bp, char *x,
const EVP_CIPHER *enc, unsigned char *kstr, int klen,
STACK *PEM_X509_INFO_read_bio(BIO *bp, STACK *sk,
int PEM_X509_INFO_write_bio(BIO *bp, X509_INFO *xi, EVP_CIPHER *enc,
pem_password_cb *cd, void *u);
int PEM_read(FILE *fp, char **name, char **header,
int PEM_write(FILE *fp, char *name, char *hdr, unsigned char *data, long len);
void *PEM_ASN1_read(d2i_of_void *d2i, const char *name, FILE *fp, void **x,
int PEM_ASN1_write(i2d_of_void *i2d, const char *name, FILE *fp,
char *x, const EVP_CIPHER *enc, unsigned char *kstr,
int klen, pem_password_cb *callback, void *u);
STACK *PEM_X509_INFO_read(FILE *fp, STACK *sk,
int PEM_SealInit(PEM_ENCODE_SEAL_CTX *ctx, EVP_CIPHER *type,
EVP_MD *md_type, unsigned char **ek, int *ekl,
unsigned char *iv, EVP_PKEY **pubk, int npubk);
void PEM_SealUpdate(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *out, int *outl,
unsigned char *in, int inl);
int PEM_SealFinal(PEM_ENCODE_SEAL_CTX *ctx, unsigned char *sig, int *sigl,
unsigned char *out, int *outl, EVP_PKEY *priv);
void PEM_SignInit(EVP_MD_CTX *ctx, EVP_MD *type);
void PEM_SignUpdate(EVP_MD_CTX *ctx, unsigned char *d, unsigned int cnt);
int PEM_SignFinal(EVP_MD_CTX *ctx, unsigned char *sigret,
unsigned int *siglen, EVP_PKEY *pkey);
int PEM_def_callback(char *buf, int num, int w, void *key);
void PEM_proc_type(char *buf, int type);
void PEM_dek_info(char *buf, const char *type, int len, char *str);
#line 619 "/usr/include/openssl/pem.h"
X509 *PEM_read_bio_X509(BIO *bp, X509 * *x, pem_password_cb *cb, void *u); X509 *PEM_read_X509(FILE *fp, X509 * *x, pem_password_cb *cb, void *u); int PEM_write_bio_X509(BIO *bp, X509 *x); int PEM_write_X509(FILE *fp, X509 *x);
X509 *PEM_read_bio_X509_AUX(BIO *bp, X509 * *x, pem_password_cb *cb, void *u); X509 *PEM_read_X509_AUX(FILE *fp, X509 * *x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_AUX(BIO *bp, X509 *x); int PEM_write_X509_AUX(FILE *fp, X509 *x);
X509_CERT_PAIR *PEM_read_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR * *x, pem_password_cb *cb, void *u); X509_CERT_PAIR *PEM_read_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR * *x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CERT_PAIR(BIO *bp, X509_CERT_PAIR *x); int PEM_write_X509_CERT_PAIR(FILE *fp, X509_CERT_PAIR *x);
X509_REQ *PEM_read_bio_X509_REQ(BIO *bp, X509_REQ * *x, pem_password_cb *cb, void *u); X509_REQ *PEM_read_X509_REQ(FILE *fp, X509_REQ * *x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_REQ(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ(FILE *fp, X509_REQ *x);
int PEM_write_bio_X509_REQ_NEW(BIO *bp, X509_REQ *x); int PEM_write_X509_REQ_NEW(FILE *fp, X509_REQ *x);
X509_CRL *PEM_read_bio_X509_CRL(BIO *bp, X509_CRL * *x, pem_password_cb *cb, void *u); X509_CRL *PEM_read_X509_CRL(FILE *fp, X509_CRL * *x, pem_password_cb *cb, void *u); int PEM_write_bio_X509_CRL(BIO *bp, X509_CRL *x); int PEM_write_X509_CRL(FILE *fp, X509_CRL *x);
PKCS7 *PEM_read_bio_PKCS7(BIO *bp, PKCS7 * *x, pem_password_cb *cb, void *u); PKCS7 *PEM_read_PKCS7(FILE *fp, PKCS7 * *x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS7(BIO *bp, PKCS7 *x); int PEM_write_PKCS7(FILE *fp, PKCS7 *x);
NETSCAPE_CERT_SEQUENCE *PEM_read_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE * *x, pem_password_cb *cb, void *u); NETSCAPE_CERT_SEQUENCE *PEM_read_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE * *x, pem_password_cb *cb, void *u); int PEM_write_bio_NETSCAPE_CERT_SEQUENCE(BIO *bp, NETSCAPE_CERT_SEQUENCE *x); int PEM_write_NETSCAPE_CERT_SEQUENCE(FILE *fp, NETSCAPE_CERT_SEQUENCE *x);
X509_SIG *PEM_read_bio_PKCS8(BIO *bp, X509_SIG * *x, pem_password_cb *cb, void *u); X509_SIG *PEM_read_PKCS8(FILE *fp, X509_SIG * *x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8(BIO *bp, X509_SIG *x); int PEM_write_PKCS8(FILE *fp, X509_SIG *x);
PKCS8_PRIV_KEY_INFO *PEM_read_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO * *x, pem_password_cb *cb, void *u); PKCS8_PRIV_KEY_INFO *PEM_read_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO * *x, pem_password_cb *cb, void *u); int PEM_write_bio_PKCS8_PRIV_KEY_INFO(BIO *bp, PKCS8_PRIV_KEY_INFO *x); int PEM_write_PKCS8_PRIV_KEY_INFO(FILE *fp, PKCS8_PRIV_KEY_INFO *x);
RSA *PEM_read_bio_RSAPrivateKey(BIO *bp, RSA * *x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPrivateKey(FILE *fp, RSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPrivateKey(BIO *bp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_RSAPrivateKey(FILE *fp, RSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
RSA *PEM_read_bio_RSAPublicKey(BIO *bp, RSA * *x, pem_password_cb *cb, void *u); RSA *PEM_read_RSAPublicKey(FILE *fp, RSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_RSAPublicKey(BIO *bp, const RSA *x); int PEM_write_RSAPublicKey(FILE *fp, const RSA *x);
RSA *PEM_read_bio_RSA_PUBKEY(BIO *bp, RSA * *x, pem_password_cb *cb, void *u); RSA *PEM_read_RSA_PUBKEY(FILE *fp, RSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_RSA_PUBKEY(BIO *bp, RSA *x); int PEM_write_RSA_PUBKEY(FILE *fp, RSA *x);
DSA *PEM_read_bio_DSAPrivateKey(BIO *bp, DSA * *x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAPrivateKey(FILE *fp, DSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAPrivateKey(BIO *bp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_DSAPrivateKey(FILE *fp, DSA *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
DSA *PEM_read_bio_DSA_PUBKEY(BIO *bp, DSA * *x, pem_password_cb *cb, void *u); DSA *PEM_read_DSA_PUBKEY(FILE *fp, DSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_DSA_PUBKEY(BIO *bp, DSA *x); int PEM_write_DSA_PUBKEY(FILE *fp, DSA *x);
DSA *PEM_read_bio_DSAparams(BIO *bp, DSA * *x, pem_password_cb *cb, void *u); DSA *PEM_read_DSAparams(FILE *fp, DSA * *x, pem_password_cb *cb, void *u); int PEM_write_bio_DSAparams(BIO *bp, const DSA *x); int PEM_write_DSAparams(FILE *fp, const DSA *x);
DH *PEM_read_bio_DHparams(BIO *bp, DH * *x, pem_password_cb *cb, void *u); DH *PEM_read_DHparams(FILE *fp, DH * *x, pem_password_cb *cb, void *u); int PEM_write_bio_DHparams(BIO *bp, const DH *x); int PEM_write_DHparams(FILE *fp, const DH *x);
EVP_PKEY *PEM_read_bio_PrivateKey(BIO *bp, EVP_PKEY * *x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PrivateKey(FILE *fp, EVP_PKEY * *x, pem_password_cb *cb, void *u); int PEM_write_bio_PrivateKey(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u); int PEM_write_PrivateKey(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc, unsigned char *kstr, int klen, pem_password_cb *cb, void *u);
EVP_PKEY *PEM_read_bio_PUBKEY(BIO *bp, EVP_PKEY * *x, pem_password_cb *cb, void *u); EVP_PKEY *PEM_read_PUBKEY(FILE *fp, EVP_PKEY * *x, pem_password_cb *cb, void *u); int PEM_write_bio_PUBKEY(BIO *bp, EVP_PKEY *x); int PEM_write_PUBKEY(FILE *fp, EVP_PKEY *x);
int PEM_write_bio_PKCS8PrivateKey_nid(BIO *bp, EVP_PKEY *x, int nid,
int PEM_write_bio_PKCS8PrivateKey(BIO *, EVP_PKEY *, const EVP_CIPHER *,
char *, int, pem_password_cb *, void *);
int i2d_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_bio(BIO *bp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_bio(BIO *bp, EVP_PKEY **x, pem_password_cb *cb,
void *u);
int i2d_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc,
int i2d_PKCS8PrivateKey_nid_fp(FILE *fp, EVP_PKEY *x, int nid,
int PEM_write_PKCS8PrivateKey_nid(FILE *fp, EVP_PKEY *x, int nid,
EVP_PKEY *d2i_PKCS8PrivateKey_fp(FILE *fp, EVP_PKEY **x, pem_password_cb *cb,
void *u);
int PEM_write_PKCS8PrivateKey(FILE *fp, EVP_PKEY *x, const EVP_CIPHER *enc,
char *kstr, int klen, pem_password_cb *cd,
void *u);
void ERR_load_PEM_strings(void);
#line 715 "/usr/include/openssl/pem.h"
#line 733 "/usr/include/openssl/pem.h"
#line 190 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/hmac.h"
#line 1 "/usr/include/openssl/opensslconf.h"
#line 1 "/usr/include/openssl/opensslconf-sparc64.h"
#line 57 "/usr/include/openssl/opensslconf-sparc64.h"
#line 69 "/usr/include/openssl/opensslconf-sparc64.h"
#line 115 "/usr/include/openssl/opensslconf-sparc64.h"
#line 132 "/usr/include/openssl/opensslconf-sparc64.h"
#line 142 "/usr/include/openssl/opensslconf-sparc64.h"
#line 180 "/usr/include/openssl/opensslconf-sparc64.h"
#line 188 "/usr/include/openssl/opensslconf-sparc64.h"
#line 205 "/usr/include/openssl/opensslconf-sparc64.h"
#line 212 "/usr/include/openssl/opensslconf-sparc64.h"
#line 26 "/usr/include/openssl/opensslconf.h"
#line 33 "/usr/include/openssl/opensslconf.h"
#line 62 "/usr/include/openssl/hmac.h"
typedef struct hmac_ctx_st {
const EVP_MD *md;
EVP_MD_CTX md_ctx;
EVP_MD_CTX i_ctx;
EVP_MD_CTX o_ctx;
unsigned int key_length;
unsigned char key[128];
} HMAC_CTX;
void HMAC_CTX_init(HMAC_CTX *ctx);
void HMAC_CTX_cleanup(HMAC_CTX *ctx);
void HMAC_Init(HMAC_CTX *ctx, const void *key, int len, const EVP_MD *md);
void HMAC_Init_ex(HMAC_CTX *ctx, const void *key, int len,
const EVP_MD *md, ENGINE *impl);
void HMAC_Update(HMAC_CTX *ctx, const unsigned char *data, size_t len);
void HMAC_Final(HMAC_CTX *ctx, unsigned char *md, unsigned int *len);
unsigned char *HMAC(const EVP_MD *evp_md, const void *key, int key_len,
const unsigned char *d, size_t n, unsigned char *md,
unsigned int *md_len);
void HMAC_CTX_set_flags(HMAC_CTX *ctx, unsigned long flags);
#line 191 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/kssl.h"
#line 68 "/usr/include/openssl/kssl.h"
#line 193 "/usr/include/openssl/ssl.h"
#line 195 "/usr/include/openssl/ssl.h"
#line 218 "/usr/include/openssl/ssl.h"
#line 230 "/usr/include/openssl/ssl.h"
#line 237 "/usr/include/openssl/ssl.h"
#line 245 "/usr/include/openssl/ssl.h"
#line 262 "/usr/include/openssl/ssl.h"
#line 304 "/usr/include/openssl/ssl.h"
typedef struct ssl_st *ssl_crock_st;
typedef struct tls_session_ticket_ext_st TLS_SESSION_TICKET_EXT;
typedef struct ssl_cipher_st {
int valid;
const char *name;
unsigned long id;
unsigned long algorithms;
unsigned long algo_strength;
unsigned long algorithm2;
int strength_bits;
int alg_bits;
unsigned long mask;
unsigned long mask_strength;
} SSL_CIPHER;
typedef int (*tls_session_ticket_ext_cb_fn)(SSL *s, const unsigned char *data, int len, void *arg);
typedef int (*tls_session_secret_cb_fn)(SSL *s, void *secret, int *secret_len, STACK *peer_ciphers, SSL_CIPHER **cipher, void *arg);
typedef struct ssl_method_st {
int version;
int (*ssl_new) (SSL *s);
void (*ssl_clear) (SSL *s);
void (*ssl_free) (SSL *s);
int (*ssl_accept) (SSL *s);
int (*ssl_connect) (SSL *s);
int (*ssl_read) (SSL *s, void *buf, int len);
int (*ssl_peek) (SSL *s, void *buf, int len);
int (*ssl_write) (SSL *s, const void *buf, int len);
int (*ssl_shutdown) (SSL *s);
int (*ssl_renegotiate) (SSL *s);
int (*ssl_renegotiate_check) (SSL *s);
long (*ssl_get_message) (SSL *s, int st1, int stn, int mt, long
max, int *ok);
int (*ssl_read_bytes) (SSL *s, int type, unsigned char *buf, int len,
int peek);
int (*ssl_write_bytes) (SSL *s, int type, const void *buf_, int len);
int (*ssl_dispatch_alert) (SSL *s);
long (*ssl_ctrl) (SSL *s, int cmd, long larg, void *parg);
long (*ssl_ctx_ctrl) (SSL_CTX *ctx, int cmd, long larg, void *parg);
SSL_CIPHER *(*get_cipher_by_char) (const unsigned char *ptr);
int (*put_cipher_by_char) (const SSL_CIPHER *cipher, unsigned char *ptr);
int (*ssl_pending) (const SSL *s);
int (*num_ciphers) (void);
SSL_CIPHER *(*get_cipher) (unsigned ncipher);
struct ssl_method_st *(*get_ssl_method) (int version);
long (*get_timeout) (void);
struct ssl3_enc_method *ssl3_enc;
int (*ssl_version) (void);
long (*ssl_callback_ctrl) (SSL *s, int cb_id, void (*fp) (void));
long (*ssl_ctx_callback_ctrl) (SSL_CTX *s, int cb_id, void (*fp) (void));
} SSL_METHOD;
typedef struct ssl_session_st {
int ssl_version;
unsigned int key_arg_length;
unsigned char key_arg[8];
int master_key_length;
unsigned char master_key[48];
unsigned int session_id_length;
unsigned char session_id[32];
unsigned int sid_ctx_length;
unsigned char sid_ctx[32];
int not_resumable;
struct sess_cert_st *sess_cert;
X509 *peer;
long verify_result;
int references;
long timeout;
long time;
int compress_meth;
SSL_CIPHER *cipher;
unsigned long cipher_id;
STACK *ciphers;
CRYPTO_EX_DATA ex_data;
struct ssl_session_st *prev, *next;
char *tlsext_hostname;
unsigned char *tlsext_tick;
size_t tlsext_ticklen;
long tlsext_tick_lifetime_hint;
} SSL_SESSION;
#line 499 "/usr/include/openssl/ssl.h"
#line 608 "/usr/include/openssl/ssl.h"
#line 623 "/usr/include/openssl/ssl.h"
void SSL_CTX_set_msg_callback(SSL_CTX *ctx,
void (*cb) (int write_p, int version,
int content_type, const void *buf,
size_t len, SSL *ssl, void *arg));
void SSL_set_msg_callback(SSL *ssl,
typedef int (*GEN_SESSION_CB) (const SSL *ssl, unsigned char *id,
unsigned int *id_len);
typedef struct ssl_comp_st {
int id;
const char *name;
COMP_METHOD *method;
} SSL_COMP;
struct ssl_ctx_st {
SSL_METHOD *method;
STACK *cipher_list;
STACK *cipher_list_by_id;
struct x509_store_st *cert_store;
struct lhash_st *sessions;
unsigned long session_cache_size;
struct ssl_session_st *session_cache_head;
struct ssl_session_st *session_cache_tail;
int session_cache_mode;
long session_timeout;
int (*new_session_cb) (struct ssl_st *ssl, SSL_SESSION *sess);
void (*remove_session_cb) (struct ssl_ctx_st *ctx, SSL_SESSION *sess);
SSL_SESSION *(*get_session_cb) (struct ssl_st *ssl,
unsigned char *data, int len, int *copy);
struct {
int sess_connect;
int sess_connect_renegotiate;
int sess_connect_good;
int sess_accept;
int sess_accept_renegotiate;
int sess_accept_good;
int sess_miss;
int sess_timeout;
int sess_cache_full;
int sess_hit;
int sess_cb_hit;
} stats;
int references;
int (*app_verify_callback) (X509_STORE_CTX *, void *);
void *app_verify_arg;
pem_password_cb *default_passwd_callback;
void *default_passwd_callback_userdata;
int (*client_cert_cb) (SSL *ssl, X509 **x509, EVP_PKEY **pkey);
int (*app_gen_cookie_cb) (SSL *ssl, unsigned char *cookie,
unsigned int *cookie_len);
int (*app_verify_cookie_cb) (SSL *ssl, unsigned char *cookie,
unsigned int cookie_len);
const EVP_MD *rsa_md5;
const EVP_MD *md5;
const EVP_MD *sha1;
STACK *extra_certs;
STACK *comp_methods;
void (*info_callback) (const SSL *ssl, int type, int val);
STACK *client_CA;
unsigned long options;
unsigned long mode;
long max_cert_list;
struct cert_st *cert;
int read_ahead;
void (*msg_callback) (int write_p, int version, int content_type,
const void *buf, size_t len, SSL *ssl, void *arg);
void *msg_callback_arg;
int verify_mode;
int (*default_verify_callback) (int ok, X509_STORE_CTX *ctx);
GEN_SESSION_CB generate_session_id;
int quiet_shutdown;
ENGINE *client_cert_engine;
int (*tlsext_servername_callback) (SSL *, int *, void *);
void *tlsext_servername_arg;
unsigned char tlsext_tick_key_name[16];
unsigned char tlsext_tick_hmac_key[16];
unsigned char tlsext_tick_aes_key[16];
int (*tlsext_ticket_key_cb) (SSL *ssl,
unsigned char *name, unsigned char *iv,
EVP_CIPHER_CTX *ectx,
HMAC_CTX *hctx, int enc);
int (*tlsext_status_cb) (SSL *ssl, void *arg);
void *tlsext_status_arg;
struct lhash_st *SSL_CTX_sessions(SSL_CTX *ctx);
#line 879 "/usr/include/openssl/ssl.h"
void SSL_CTX_sess_set_new_cb(SSL_CTX *ctx,
SSL_SESSION *sess));
int (*SSL_CTX_sess_get_new_cb(SSL_CTX *ctx)) (struct ssl_st *ssl,
SSL_SESSION *sess);
void SSL_CTX_sess_set_remove_cb(SSL_CTX *ctx,
*ctx,
SSL_SESSION
*sess));
void (*SSL_CTX_sess_get_remove_cb(SSL_CTX *ctx)) (struct ssl_ctx_st *ctx,
SSL_SESSION *sess);
void SSL_CTX_sess_set_get_cb(SSL_CTX *ctx,
*ssl,
unsigned char
*data, int len,
int *copy));
SSL_SESSION *(*SSL_CTX_sess_get_get_cb(SSL_CTX *ctx)) (struct ssl_st *ssl,
unsigned char *Data,
void SSL_CTX_set_info_callback(SSL_CTX *ctx,
void (*cb) (const SSL *ssl, int type,
int val));
void (*SSL_CTX_get_info_callback(SSL_CTX *ctx)) (const SSL *ssl, int type,
int val);
void SSL_CTX_set_client_cert_cb(SSL_CTX *ctx,
EVP_PKEY **pkey));
int (*SSL_CTX_get_client_cert_cb(SSL_CTX *ctx)) (SSL *ssl, X509 **x509,
EVP_PKEY **pkey);
int SSL_CTX_set_client_cert_engine(SSL_CTX *ctx, ENGINE *e);
void SSL_CTX_set_cookie_generate_cb(SSL_CTX *ctx,
unsigned char
*cookie,
unsigned int
*cookie_len));
void SSL_CTX_set_cookie_verify_cb(SSL_CTX *ctx,
unsigned char
*cookie,
unsigned int
cookie_len));
struct ssl_st {
int version;
int type;
SSL_METHOD *method;
BIO *rbio;
BIO *wbio;
BIO *bbio;
#line 966 "/usr/include/openssl/ssl.h"
int rwstate;
int in_handshake;
int (*handshake_func) (SSL *);
int server;
int new_session;
int quiet_shutdown;
int shutdown;
int state;
int rstate;
BUF_MEM *init_buf;
void *init_msg;
int init_num;
int init_off;
unsigned char *packet;
unsigned int packet_length;
struct ssl2_state_st *s2;
struct ssl3_state_st *s3;
struct dtls1_state_st *d1;
int read_ahead;
int hit;
STACK *cipher_list;
EVP_CIPHER_CTX *enc_read_ctx;
const EVP_MD *read_hash;
COMP_CTX *expand;
EVP_CIPHER_CTX *enc_write_ctx;
const EVP_MD *write_hash;
COMP_CTX *compress;
SSL_SESSION *session;
int verify_mode;
int (*verify_callback) (int ok, X509_STORE_CTX *ctx);
int error;
int error_code;
SSL_CTX *ctx;
int debug;
long verify_result;
STACK *client_CA;
int references;
unsigned long mode;
long max_cert_list;
int first_packet;
int client_version;
void (*tlsext_debug_cb) (SSL *s, int client_server, int type,
void *tlsext_debug_arg;
int servername_done;
int tlsext_status_type;
int tlsext_status_expected;
STACK *tlsext_ocsp_ids;
X509_EXTENSIONS *tlsext_ocsp_exts;
unsigned char *tlsext_ocsp_resp;
int tlsext_ocsp_resplen;
int tlsext_ticket_expected;
TLS_SESSION_TICKET_EXT *tlsext_session_ticket;
tls_session_ticket_ext_cb_fn tls_session_ticket_ext_cb;
void *tls_session_ticket_ext_cb_arg;
tls_session_secret_cb_fn tls_session_secret_cb;
void *tls_session_secret_cb_arg;
SSL_CTX *initial_ctx;
#line 1 "/usr/include/openssl/ssl2.h"
#line 83 "/usr/include/openssl/ssl2.h"
#line 103 "/usr/include/openssl/ssl2.h"
#line 119 "/usr/include/openssl/ssl2.h"
#line 156 "/usr/include/openssl/ssl2.h"
typedef struct ssl2_state_st {
int three_byte_header;
int clear_text;
int escape;
int ssl2_rollback;
unsigned int wnum;
int wpend_tot;
const unsigned char *wpend_buf;
int wpend_off;
int wpend_len;
int wpend_ret;
int rbuf_left;
int rbuf_offs;
unsigned char *rbuf;
unsigned char *wbuf;
unsigned char *write_ptr;
unsigned int padding;
unsigned int rlength;
int ract_data_length;
unsigned int wlength;
int wact_data_length;
unsigned char *ract_data;
unsigned char *wact_data;
unsigned char *mac_data;
unsigned char *read_key;
unsigned char *write_key;
unsigned int challenge_length;
unsigned char challenge[32];
unsigned int conn_id_length;
unsigned char conn_id[16];
unsigned int key_material_length;
unsigned char key_material[24 * 2];
unsigned long read_sequence;
unsigned long write_sequence;
struct {
unsigned int cert_type;
unsigned int cert_length;
unsigned int csl;
unsigned int clear;
unsigned int enc;
unsigned char ccl[32];
unsigned int cipher_spec_length;
unsigned int clen;
unsigned int rlen;
} tmp;
} SSL2_STATE;
#line 236 "/usr/include/openssl/ssl2.h"
#line 257 "/usr/include/openssl/ssl2.h"
#line 1147 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/ssl3.h"
#line 1 "/usr/include/openssl/ssl.h"
#line 126 "/usr/include/openssl/ssl3.h"
#line 1 "/usr/include/openssl/pq_compat.h"
#line 64 "/usr/include/openssl/pq_compat.h"
#line 110 "/usr/include/openssl/pq_compat.h"
#line 124 "/usr/include/openssl/pq_compat.h"
#line 140 "/usr/include/openssl/pq_compat.h"
#line 151 "/usr/include/openssl/pq_compat.h"
#line 127 "/usr/include/openssl/ssl3.h"
#line 154 "/usr/include/openssl/ssl3.h"
#line 161 "/usr/include/openssl/ssl3.h"
#line 168 "/usr/include/openssl/ssl3.h"
#line 184 "/usr/include/openssl/ssl3.h"
#line 196 "/usr/include/openssl/ssl3.h"
#line 203 "/usr/include/openssl/ssl3.h"
#line 214 "/usr/include/openssl/ssl3.h"
#line 221 "/usr/include/openssl/ssl3.h"
#line 228 "/usr/include/openssl/ssl3.h"
#line 247 "/usr/include/openssl/ssl3.h"
#line 254 "/usr/include/openssl/ssl3.h"
#line 270 "/usr/include/openssl/ssl3.h"
#line 280 "/usr/include/openssl/ssl3.h"
#line 308 "/usr/include/openssl/ssl3.h"
typedef struct ssl3_record_st {
int type;
unsigned int length;
unsigned int off;
unsigned char *input;
unsigned char *comp;
unsigned long epoch;
unsigned long seq_num;
} SSL3_RECORD;
typedef struct ssl3_buffer_st {
unsigned char *buf;
size_t len;
int offset;
int left;
} SSL3_BUFFER;
#line 362 "/usr/include/openssl/ssl3.h"
typedef struct ssl3_state_st {
long flags;
int delay_buf_pop_ret;
unsigned char read_sequence[8];
unsigned char read_mac_secret[64];
unsigned char write_sequence[8];
unsigned char write_mac_secret[64];
unsigned char server_random[32];
unsigned char client_random[32];
int need_empty_fragments;
int empty_fragment_done;
SSL3_BUFFER rbuf;
SSL3_BUFFER wbuf;
SSL3_RECORD rrec;
SSL3_RECORD wrec;
unsigned char alert_fragment[2];
unsigned int alert_fragment_len;
unsigned char handshake_fragment[4];
unsigned int handshake_fragment_len;
unsigned int wnum;
int wpend_tot;
int wpend_type;
int wpend_ret;
EVP_MD_CTX finish_dgst1;
EVP_MD_CTX finish_dgst2;
int change_cipher_spec;
int warn_alert;
int fatal_alert;
int alert_dispatch;
unsigned char send_alert[2];
int renegotiate;
int total_renegotiations;
int num_renegotiations;
int in_read_app_data;
struct {
unsigned char cert_verify_md[64 * 2];
unsigned char finish_md[64 * 2];
int finish_md_len;
unsigned char peer_finish_md[64 * 2];
int peer_finish_md_len;
unsigned long message_size;
int message_type;
SSL_CIPHER *new_cipher;
DH *dh;
int next_state;
int reuse_message;
int cert_req;
int ctype_num;
char ctype[7];
STACK *ca_names;
int use_rsa_tmp;
int key_block_length;
unsigned char *key_block;
const EVP_CIPHER *new_sym_enc;
const EVP_MD *new_hash;
const SSL_COMP *new_compression;
int cert_request;
} tmp;
unsigned char previous_client_finished[64];
unsigned char previous_client_finished_len;
unsigned char previous_server_finished[64];
unsigned char previous_server_finished_len;
int send_connection_binding;
} SSL3_STATE;
#line 507 "/usr/include/openssl/ssl3.h"
#line 520 "/usr/include/openssl/ssl3.h"
#line 529 "/usr/include/openssl/ssl3.h"
#line 554 "/usr/include/openssl/ssl3.h"
#line 565 "/usr/include/openssl/ssl3.h"
#line 574 "/usr/include/openssl/ssl3.h"
#line 588 "/usr/include/openssl/ssl3.h"
#line 600 "/usr/include/openssl/ssl3.h"
#line 1148 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/tls1.h"
#line 122 "/usr/include/openssl/tls1.h"
#line 129 "/usr/include/openssl/tls1.h"
#line 140 "/usr/include/openssl/tls1.h"
const char *SSL_get_servername(const SSL *s, const int type);
int SSL_get_servername_type(const SSL *s);
#line 226 "/usr/include/openssl/tls1.h"
#line 235 "/usr/include/openssl/tls1.h"
#line 242 "/usr/include/openssl/tls1.h"
#line 250 "/usr/include/openssl/tls1.h"
#line 257 "/usr/include/openssl/tls1.h"
#line 265 "/usr/include/openssl/tls1.h"
#line 314 "/usr/include/openssl/tls1.h"
#line 322 "/usr/include/openssl/tls1.h"
#line 329 "/usr/include/openssl/tls1.h"
#line 368 "/usr/include/openssl/tls1.h"
#line 375 "/usr/include/openssl/tls1.h"
#line 383 "/usr/include/openssl/tls1.h"
#line 392 "/usr/include/openssl/tls1.h"
#line 412 "/usr/include/openssl/tls1.h"
#line 462 "/usr/include/openssl/tls1.h"
unsigned short length;
void *data;
#line 1149 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/dtls1.h"
#line 1 "/usr/include/openssl/pqueue.h"
#line 1 "/usr/include/string.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 27 "/usr/include/string.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 34 "/usr/include/string.h"
extern void *memcpy (void * __dest,
const void * __src, size_t __n)
extern void *memmove (void *__dest, const void *__src, size_t __n)
extern void *memccpy (void * __dest, const void * __src,
int __c, size_t __n)
extern void *memset (void *__s, int __c, size_t __n) ;
extern int memcmp (const void *__s1, const void *__s2, size_t __n)
extern void *memchr (const void *__s, int __c, size_t __n)
#line 80 "/usr/include/string.h"
extern char *strcpy (char * __dest, const char * __src)
extern char *strncpy (char * __dest,
const char * __src, size_t __n)
extern char *strcat (char * __dest, const char * __src)
extern char *strncat (char * __dest, const char * __src,
size_t __n) ;
extern int strcmp (const char *__s1, const char *__s2)
extern int strncmp (const char *__s1, const char *__s2, size_t __n)
extern int strcoll (const char *__s1, const char *__s2)
extern size_t strxfrm (char * __dest,
#line 127 "/usr/include/string.h"
extern char *strdup (const char *__s)
#line 164 "/usr/include/string.h"
extern char *strchr (const char *__s, int __c)
extern char *strrchr (const char *__s, int __c)
#line 180 "/usr/include/string.h"
extern size_t strcspn (const char *__s, const char *__reject)
extern size_t strspn (const char *__s, const char *__accept)
extern char *strpbrk (const char *__s, const char *__accept)
extern char *strstr (const char *__haystack, const char *__needle)
extern char *strtok (char * __s, const char * __delim)
extern char *__strtok_r (char * __s,
const char * __delim,
char ** __save_ptr)
extern char *strtok_r (char * __s, const char * __delim,
char ** __save_ptr)
#line 238 "/usr/include/string.h"
extern size_t strlen (const char *__s)
#line 252 "/usr/include/string.h"
extern char *strerror (int __errnum) ;
extern int __xpg_strerror_r (int __errnum, char *__buf, size_t __buflen)
#line 285 "/usr/include/string.h"
extern void __bzero (void *__s, size_t __n) ;
extern void bcopy (const void *__src, void *__dest, size_t __n)
extern void bzero (void *__s, size_t __n) ;
extern int bcmp (const void *__s1, const void *__s2, size_t __n)
extern char *index (const char *__s, int __c)
extern char *rindex (const char *__s, int __c)
extern int ffs (int __i) ;
#line 329 "/usr/include/string.h"
extern int strcasecmp (const char *__s1, const char *__s2)
extern int strncasecmp (const char *__s1, const char *__s2, size_t __n)
#line 350 "/usr/include/string.h"
extern char *strsep (char ** __stringp,
#line 396 "/usr/include/string.h"
#line 431 "/usr/include/string.h"
#line 66 "/usr/include/openssl/pqueue.h"
typedef struct _pqueue *pqueue;
typedef struct _pitem {
unsigned long priority;
void *data;
struct _pitem *next;
} pitem;
typedef struct _pitem *piterator;
pitem *pitem_new(unsigned long priority, void *data);
void pitem_free(pitem *item);
pqueue pqueue_new(void);
void pqueue_free(pqueue pq);
pitem *pqueue_insert(pqueue pq, pitem *item);
pitem *pqueue_peek(pqueue pq);
pitem *pqueue_pop(pqueue pq);
pitem *pqueue_find(pqueue pq, unsigned long priority);
pitem *pqueue_iterator(pqueue pq);
pitem *pqueue_next(piterator *iter);
void pqueue_print(pqueue pq);
int pqueue_size(pqueue pq);
#line 65 "/usr/include/openssl/dtls1.h"
#line 1 "/usr/include/sys/time.h"
#line 24 "/usr/include/sys/time.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
#line 30 "/usr/include/sys/time.h"
#line 52 "/usr/include/sys/time.h"
struct timezone
int tz_minuteswest;
int tz_dsttime;
typedef struct timezone * __timezone_ptr_t;
extern int gettimeofday (struct timeval * __tv,
__timezone_ptr_t __tz) ;
extern int settimeofday (const struct timeval *__tv,
const struct timezone *__tz)
extern int adjtime (const struct timeval *__delta,
struct timeval *__olddelta) ;
enum __itimer_which
ITIMER_REAL = 0,
ITIMER_VIRTUAL = 1,
ITIMER_PROF = 2
struct itimerval
struct timeval it_interval;
struct timeval it_value;
typedef int __itimer_which_t;
extern int getitimer (__itimer_which_t __which,
struct itimerval *__value) ;
extern int setitimer (__itimer_which_t __which,
const struct itimerval * __new,
struct itimerval * __old) ;
extern int utimes (const char *__file, const struct timeval __tvp[2])
extern int lutimes (const char *__file, const struct timeval __tvp[2])
extern int futimes (int __fd, const struct timeval __tvp[2]) ;
#line 159 "/usr/include/sys/time.h"
#line 190 "/usr/include/sys/time.h"
#line 76 "/usr/include/openssl/dtls1.h"
typedef struct dtls1_bitmap_st {
unsigned long map;
unsigned long length;
unsigned long max_seq_num;
} DTLS1_BITMAP;
struct dtls1_retransmit_state {
COMP_CTX *compress;
unsigned short epoch;
struct hm_header_st {
unsigned char type;
unsigned long msg_len;
unsigned short seq;
unsigned long frag_off;
unsigned long frag_len;
unsigned int is_ccs;
struct dtls1_retransmit_state saved_retransmit_state;
struct ccs_header_st {
unsigned char type;
unsigned short seq;
struct dtls1_timeout_st {
unsigned int read_timeouts;
unsigned int write_timeouts;
unsigned int num_alerts;
typedef struct record_pqueue_st {
pqueue q;
} record_pqueue;
typedef struct hm_fragment_st {
struct hm_header_st msg_header;
unsigned char *fragment;
unsigned char *reassembly;
} hm_fragment;
typedef struct dtls1_state_st {
unsigned int send_cookie;
unsigned char cookie[256];
unsigned char rcvd_cookie[256];
unsigned int cookie_len;
unsigned short r_epoch;
unsigned short w_epoch;
DTLS1_BITMAP bitmap;
DTLS1_BITMAP next_bitmap;
unsigned short handshake_write_seq;
unsigned short next_handshake_write_seq;
unsigned short handshake_read_seq;
unsigned char last_write_sequence[8];
record_pqueue unprocessed_rcds;
record_pqueue processed_rcds;
pqueue buffered_messages;
pqueue sent_messages;
record_pqueue buffered_app_data;
unsigned int listen;
unsigned int mtu;
struct hm_header_st w_msg_hdr;
struct hm_header_st r_msg_hdr;
struct dtls1_timeout_st timeout;
struct timeval next_timeout;
unsigned short timeout_duration;
unsigned char handshake_fragment[12];
unsigned int retransmitting;
unsigned int change_cipher_spec_ok;
} DTLS1_STATE;
typedef struct dtls1_record_data_st {
SSL3_BUFFER rbuf;
SSL3_RECORD rrec;
} DTLS1_RECORD_DATA;
#line 1150 "/usr/include/openssl/ssl.h"
#line 1 "/usr/include/openssl/ssl23.h"
#line 1151 "/usr/include/openssl/ssl.h"
#line 1163 "/usr/include/openssl/ssl.h"
#line 1179 "/usr/include/openssl/ssl.h"
#line 1193 "/usr/include/openssl/ssl.h"
#line 1201 "/usr/include/openssl/ssl.h"
size_t SSL_get_finished(const SSL *s, void *buf, size_t count);
size_t SSL_get_peer_finished(const SSL *s, void *buf, size_t count);
#line 1239 "/usr/include/openssl/ssl.h"
#line 1252 "/usr/include/openssl/ssl.h"
#line 1265 "/usr/include/openssl/ssl.h"
#line 1286 "/usr/include/openssl/ssl.h"
#line 1310 "/usr/include/openssl/ssl.h"
#line 1325 "/usr/include/openssl/ssl.h"
#line 1333 "/usr/include/openssl/ssl.h"
#line 1341 "/usr/include/openssl/ssl.h"
#line 1362 "/usr/include/openssl/ssl.h"
#line 1369 "/usr/include/openssl/ssl.h"
#line 1382 "/usr/include/openssl/ssl.h"
#line 1392 "/usr/include/openssl/ssl.h"
#line 1412 "/usr/include/openssl/ssl.h"
#line 1421 "/usr/include/openssl/ssl.h"
#line 1430 "/usr/include/openssl/ssl.h"
#line 1439 "/usr/include/openssl/ssl.h"
BIO_METHOD *BIO_f_ssl(void);
BIO *BIO_new_ssl(SSL_CTX *ctx, int client);
BIO *BIO_new_ssl_connect(SSL_CTX *ctx);
BIO *BIO_new_buffer_ssl_connect(SSL_CTX *ctx);
int BIO_ssl_copy_session_id(BIO *to, BIO *from);
void BIO_ssl_shutdown(BIO *ssl_bio);
int SSL_CTX_set_cipher_list(SSL_CTX *, const char *str);
SSL_CTX *SSL_CTX_new(SSL_METHOD *meth);
void SSL_CTX_free(SSL_CTX *);
long SSL_CTX_set_timeout(SSL_CTX *ctx, long t);
long SSL_CTX_get_timeout(const SSL_CTX *ctx);
X509_STORE *SSL_CTX_get_cert_store(const SSL_CTX *);
void SSL_CTX_set_cert_store(SSL_CTX *, X509_STORE *);
int SSL_want(const SSL *s);
int SSL_clear(SSL *s);
void SSL_CTX_flush_sessions(SSL_CTX *ctx, long tm);
SSL_CIPHER *SSL_get_current_cipher(const SSL *s);
int SSL_CIPHER_get_bits(const SSL_CIPHER *c, int *alg_bits);
char *SSL_CIPHER_get_version(const SSL_CIPHER *c);
const char *SSL_CIPHER_get_name(const SSL_CIPHER *c);
int SSL_get_fd(const SSL *s);
int SSL_get_rfd(const SSL *s);
int SSL_get_wfd(const SSL *s);
const char *SSL_get_cipher_list(const SSL *s, int n);
char *SSL_get_shared_ciphers(const SSL *s, char *buf, int len);
int SSL_get_read_ahead(const SSL *s);
int SSL_pending(const SSL *s);
int SSL_set_fd(SSL *s, int fd);
int SSL_set_rfd(SSL *s, int fd);
int SSL_set_wfd(SSL *s, int fd);
void SSL_set_bio(SSL *s, BIO *rbio, BIO *wbio);
BIO *SSL_get_rbio(const SSL *s);
BIO *SSL_get_wbio(const SSL *s);
int SSL_set_cipher_list(SSL *s, const char *str);
void SSL_set_read_ahead(SSL *s, int yes);
int SSL_get_verify_mode(const SSL *s);
int SSL_get_verify_depth(const SSL *s);
int (*SSL_get_verify_callback(const SSL *s)) (int, X509_STORE_CTX *);
void SSL_set_verify(SSL *s, int mode,
int (*callback) (int ok, X509_STORE_CTX *ctx));
void SSL_set_verify_depth(SSL *s, int depth);
int SSL_use_RSAPrivateKey(SSL *ssl, RSA *rsa);
int SSL_use_RSAPrivateKey_ASN1(SSL *ssl, unsigned char *d, long len);
int SSL_use_PrivateKey(SSL *ssl, EVP_PKEY *pkey);
int SSL_use_PrivateKey_ASN1(int pk, SSL *ssl, const unsigned char *d,
long len);
int SSL_use_certificate(SSL *ssl, X509 *x);
int SSL_use_certificate_ASN1(SSL *ssl, const unsigned char *d, int len);
int SSL_use_RSAPrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_PrivateKey_file(SSL *ssl, const char *file, int type);
int SSL_use_certificate_file(SSL *ssl, const char *file, int type);
int SSL_CTX_use_RSAPrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_PrivateKey_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_file(SSL_CTX *ctx, const char *file, int type);
int SSL_CTX_use_certificate_chain_file(SSL_CTX *ctx, const char *file);
STACK *SSL_load_client_CA_file(const char *file);
int SSL_add_file_cert_subjects_to_stack(STACK *stackCAs,
const char *file);
int SSL_add_dir_cert_subjects_to_stack(STACK *stackCAs,
const char *dir);
void SSL_load_error_strings(void);
const char *SSL_state_string(const SSL *s);
const char *SSL_rstate_string(const SSL *s);
const char *SSL_state_string_long(const SSL *s);
const char *SSL_rstate_string_long(const SSL *s);
long SSL_SESSION_get_time(const SSL_SESSION *s);
long SSL_SESSION_set_time(SSL_SESSION *s, long t);
long SSL_SESSION_get_timeout(const SSL_SESSION *s);
long SSL_SESSION_set_timeout(SSL_SESSION *s, long t);
void SSL_copy_session_id(SSL *to, const SSL *from);
SSL_SESSION *SSL_SESSION_new(void);
unsigned long SSL_SESSION_hash(const SSL_SESSION *a);
int SSL_SESSION_cmp(const SSL_SESSION *a, const SSL_SESSION *b);
const unsigned char *SSL_SESSION_get_id(const SSL_SESSION *s,
unsigned int *len);
int SSL_SESSION_print_fp(FILE *fp, const SSL_SESSION *ses);
int SSL_SESSION_print(BIO *fp, const SSL_SESSION *ses);
void SSL_SESSION_free(SSL_SESSION *ses);
int i2d_SSL_SESSION(SSL_SESSION *in, unsigned char **pp);
int SSL_set_session(SSL *to, SSL_SESSION *session);
int SSL_CTX_add_session(SSL_CTX *s, SSL_SESSION *c);
int SSL_CTX_remove_session(SSL_CTX *, SSL_SESSION *c);
int SSL_CTX_set_generate_session_id(SSL_CTX *, GEN_SESSION_CB);
int SSL_set_generate_session_id(SSL *, GEN_SESSION_CB);
int SSL_has_matching_session_id(const SSL *ssl, const unsigned char *id,
unsigned int id_len);
SSL_SESSION *d2i_SSL_SESSION(SSL_SESSION **a, const unsigned char **pp,
long length);
X509 *SSL_get_peer_certificate(const SSL *s);
STACK *SSL_get_peer_cert_chain(const SSL *s);
int SSL_CTX_get_verify_mode(const SSL_CTX *ctx);
int SSL_CTX_get_verify_depth(const SSL_CTX *ctx);
int (*SSL_CTX_get_verify_callback(const SSL_CTX *ctx)) (int,
X509_STORE_CTX *);
void SSL_CTX_set_verify(SSL_CTX *ctx, int mode,
int (*callback) (int, X509_STORE_CTX *));
void SSL_CTX_set_verify_depth(SSL_CTX *ctx, int depth);
void SSL_CTX_set_cert_verify_callback(SSL_CTX *ctx,
int (*cb) (X509_STORE_CTX *, void *),
void *arg);
int SSL_CTX_use_RSAPrivateKey(SSL_CTX *ctx, RSA *rsa);
int SSL_CTX_use_RSAPrivateKey_ASN1(SSL_CTX *ctx, const unsigned char *d,
long len);
int SSL_CTX_use_PrivateKey(SSL_CTX *ctx, EVP_PKEY *pkey);
int SSL_CTX_use_PrivateKey_ASN1(int pk, SSL_CTX *ctx,
const unsigned char *d, long len);
int SSL_CTX_use_certificate(SSL_CTX *ctx, X509 *x);
int SSL_CTX_use_certificate_ASN1(SSL_CTX *ctx, int len,
const unsigned char *d);
void SSL_CTX_set_default_passwd_cb(SSL_CTX *ctx, pem_password_cb *cb);
void SSL_CTX_set_default_passwd_cb_userdata(SSL_CTX *ctx, void *u);
int SSL_CTX_check_private_key(const SSL_CTX *ctx);
int SSL_check_private_key(const SSL *ctx);
int SSL_CTX_set_session_id_context(SSL_CTX *ctx, const unsigned char *sid_ctx,
unsigned int sid_ctx_len);
SSL *SSL_new(SSL_CTX *ctx);
int SSL_set_session_id_context(SSL *ssl, const unsigned char *sid_ctx,
int SSL_CTX_set_purpose(SSL_CTX *s, int purpose);
int SSL_set_purpose(SSL *s, int purpose);
int SSL_CTX_set_trust(SSL_CTX *s, int trust);
int SSL_set_trust(SSL *s, int trust);
void SSL_free(SSL *ssl);
int SSL_accept(SSL *ssl);
int SSL_connect(SSL *ssl);
int SSL_read(SSL *ssl, void *buf, int num);
int SSL_peek(SSL *ssl, void *buf, int num);
int SSL_write(SSL *ssl, const void *buf, int num);
long SSL_ctrl(SSL *ssl, int cmd, long larg, void *parg);
long SSL_callback_ctrl(SSL *, int, void (*)(void));
long SSL_CTX_ctrl(SSL_CTX *ctx, int cmd, long larg, void *parg);
long SSL_CTX_callback_ctrl(SSL_CTX *, int, void (*)(void));
int SSL_get_error(const SSL *s, int ret_code);
const char *SSL_get_version(const SSL *s);
int SSL_CTX_set_ssl_version(SSL_CTX *ctx, SSL_METHOD *meth);
SSL_METHOD *SSLv2_method(void);
SSL_METHOD *SSLv2_server_method(void);
SSL_METHOD *SSLv2_client_method(void);
SSL_METHOD *SSLv3_method(void);
SSL_METHOD *SSLv3_server_method(void);
SSL_METHOD *SSLv3_client_method(void);
SSL_METHOD *SSLv23_method(void);
SSL_METHOD *SSLv23_server_method(void);
SSL_METHOD *SSLv23_client_method(void);
SSL_METHOD *TLSv1_method(void);
SSL_METHOD *TLSv1_server_method(void);
SSL_METHOD *TLSv1_client_method(void);
SSL_METHOD *DTLSv1_method(void);
SSL_METHOD *DTLSv1_server_method(void);
SSL_METHOD *DTLSv1_client_method(void);
STACK *SSL_get_ciphers(const SSL *s);
int SSL_do_handshake(SSL *s);
int SSL_renegotiate(SSL *s);
int SSL_renegotiate_pending(SSL *s);
int SSL_shutdown(SSL *s);
SSL_METHOD *SSL_get_ssl_method(SSL *s);
int SSL_set_ssl_method(SSL *s, SSL_METHOD *method);
const char *SSL_alert_type_string_long(int value);
const char *SSL_alert_type_string(int value);
const char *SSL_alert_desc_string_long(int value);
const char *SSL_alert_desc_string(int value);
void SSL_set_client_CA_list(SSL *s, STACK *name_list);
void SSL_CTX_set_client_CA_list(SSL_CTX *ctx, STACK *name_list);
STACK *SSL_get_client_CA_list(const SSL *s);
STACK *SSL_CTX_get_client_CA_list(const SSL_CTX *s);
int SSL_add_client_CA(SSL *ssl, X509 *x);
int SSL_CTX_add_client_CA(SSL_CTX *ctx, X509 *x);
void SSL_set_connect_state(SSL *s);
void SSL_set_accept_state(SSL *s);
long SSL_get_default_timeout(const SSL *s);
int SSL_library_init(void);
char *SSL_CIPHER_description(const SSL_CIPHER *, char *buf, int size);
STACK *SSL_dup_CA_list(STACK *sk);
SSL *SSL_dup(SSL *ssl);
X509 *SSL_get_certificate(const SSL *ssl);
struct evp_pkey_st *SSL_get_privatekey(SSL *ssl);
void SSL_CTX_set_quiet_shutdown(SSL_CTX *ctx, int mode);
int SSL_CTX_get_quiet_shutdown(const SSL_CTX *ctx);
void SSL_set_quiet_shutdown(SSL *ssl, int mode);
int SSL_get_quiet_shutdown(const SSL *ssl);
void SSL_set_shutdown(SSL *ssl, int mode);
int SSL_get_shutdown(const SSL *ssl);
int SSL_version(const SSL *ssl);
int SSL_CTX_set_default_verify_paths(SSL_CTX *ctx);
int SSL_CTX_load_verify_locations(SSL_CTX *ctx, const char *CAfile,
const char *CApath);
SSL_SESSION *SSL_get_session(const SSL *ssl);
SSL_SESSION *SSL_get1_session(SSL *ssl);
SSL_CTX *SSL_get_SSL_CTX(const SSL *ssl);
SSL_CTX *SSL_set_SSL_CTX(SSL *ssl, SSL_CTX *ctx);
void SSL_set_info_callback(SSL *ssl,
void (*cb) (const SSL *ssl, int type, int val));
void (*SSL_get_info_callback(const SSL *ssl)) (const SSL *ssl, int type,
int val);
int SSL_state(const SSL *ssl);
void SSL_set_verify_result(SSL *ssl, long v);
long SSL_get_verify_result(const SSL *ssl);
int SSL_set_ex_data(SSL *ssl, int idx, void *data);
void *SSL_get_ex_data(const SSL *ssl, int idx);
int SSL_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
CRYPTO_EX_dup *dup_func, CRYPTO_EX_free *free_func);
int SSL_SESSION_set_ex_data(SSL_SESSION *ss, int idx, void *data);
void *SSL_SESSION_get_ex_data(const SSL_SESSION *ss, int idx);
int SSL_SESSION_get_ex_new_index(long argl, void *argp,
int SSL_CTX_set_ex_data(SSL_CTX *ssl, int idx, void *data);
void *SSL_CTX_get_ex_data(const SSL_CTX *ssl, int idx);
int SSL_CTX_get_ex_new_index(long argl, void *argp, CRYPTO_EX_new *new_func,
int SSL_get_ex_data_X509_STORE_CTX_idx(void);
#line 1734 "/usr/include/openssl/ssl.h"
#line 1749 "/usr/include/openssl/ssl.h"
void SSL_CTX_set_tmp_rsa_callback(SSL_CTX *ctx,
RSA *(*cb) (SSL *ssl, int is_export,
int keylength));
void SSL_set_tmp_rsa_callback(SSL *ssl,
int keylength));
void SSL_CTX_set_tmp_dh_callback(SSL_CTX *ctx,
DH *(*dh) (SSL *ssl, int is_export,
int keylength));
void SSL_set_tmp_dh_callback(SSL *ssl,
int keylength));
const COMP_METHOD *SSL_get_current_compression(SSL *s);
const COMP_METHOD *SSL_get_current_expansion(SSL *s);
const char *SSL_COMP_get_name(const COMP_METHOD *comp);
STACK *SSL_COMP_get_compression_methods(void);
int SSL_COMP_add_compression_method(int id, COMP_METHOD *cm);
#line 1782 "/usr/include/openssl/ssl.h"
int SSL_set_session_ticket_ext(SSL *s, void *ext_data, int ext_len);
int SSL_set_session_ticket_ext_cb(SSL *s, tls_session_ticket_ext_cb_fn cb,void *arg);
int SSL_set_session_secret_cb(SSL *s, tls_session_secret_cb_fn tls_session_secret_cb, void *arg);
void ERR_load_SSL_strings(void);
#line 1998 "/usr/include/openssl/ssl.h"
#line 2257 "/usr/include/openssl/ssl.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Found header files ['openssl/ssl.h'] in []
Popping language C
TEST checkSharedLibrary from config.packages.ssl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.ssl(config/BuildSystem/config/package.py:626)
By default we don't care about checking if the library is shared
Popping language C
Not a clone of PETSc, don't need Lgrind
Pushing language C
TEST configureLibrary from config.packages.valgrind(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:572)
TESTING: configureLibrary from config.packages.valgrind(config/BuildSystem/config/package.py:572)
Find an installation and check if it can work with PETSc
Checking for a functional valgrind
Not checking for library in Compiler specific search VALGRIND: [] because no functions given to check for
TEST check from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
No functions to check for in library [] []
Checking for headers Compiler specific search VALGRIND: []
Pushing language C
TEST checkInclude from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['valgrind/valgrind.h'] in []
Checking include with compiler flags var CPPFLAGS []
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "valgrind/valgrind.h"
#include <valgrind/valgrind.h>
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".
Source:
#include "confdefs.h"
#include "conffix.h"
Preprocess stderr before filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "valgrind/valgrind.h"
Preprocess stderr after filtering:"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c", line 3: error: cannot open source file "valgrind/valgrind.h" #include <valgrind/valgrind.h> ^1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c".:
Popping language C
Not checking for library in Package specific search directory VALGRIND: [] because no functions given to check for
Checking for headers Package specific search directory VALGRIND: ['/usr/local/include']
Pushing language C
Checking for header files ['valgrind/valgrind.h'] in ['/usr/local/include']
Checking include with compiler flags var CPPFLAGS ['/usr/local/include']
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/usr/local/include /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
stdout:
Source:
Popping language C
Pushing language C
stdout:
stdout:
Source:
Popping language C
Checking for headers Package specific search directory VALGRIND: ['/opt/local/include']
Pushing language C
Checking for header files ['valgrind/valgrind.h'] in ['/opt/local/include']
Checking include with compiler flags var CPPFLAGS ['/opt/local/include']
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/opt/local/include /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
stdout:
Source:
Popping language C
VALGRIND: DirPath not found.. skipping: /opt/local/lib64
Executing: uname -s
stdout: Linux
It appears you do not have valgrind installed on your system.
We HIGHLY recommend you install it from www.valgrind.org
Or install valgrind-devel or equivalent using your package manager.
Then rerun ./configure
Popping language C
TEST alternateConfigureLibrary from config.packages.pami(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.pami(config/BuildSystem/config/package.py:630)
Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.PARTY(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.PARTY(config/BuildSystem/config/package.py:630)
Not a clone of PETSc or no Fortran, don't need Sowing
TEST alternateConfigureLibrary from config.packages.p4est(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.p4est(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.tchem(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.tchem(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.cgns(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.cgns(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.fftw(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.fftw(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.Chaco(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Chaco(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.Mathematica(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Mathematica(config/BuildSystem/config/package.py:630)
TEST locateC2html from config.packages.c2html(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/c2html.py:33)
TESTING: locateC2html from config.packages.c2html(config/BuildSystem/config/packages/c2html.py:33)
Looking for default C2html executable
Checking for program /opt/FJSVtclang/check/c2html...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/c2html...not found
Checking for program /opt/kusu/bin/c2html...not found
Checking for program /opt/kusu/sbin/c2html...not found
Checking for program /usr/pgsql-9.0/bin/c2html...not found
Checking for program /usr/local/bin/c2html...not found
Checking for program /bin/c2html...not found
Checking for program /usr/bin/c2html...not found
Checking for program /home/hp150306/t00196/bin/c2html...not found
Checking for program /home/hp150306/t00196/shortcut/c2html...not found
Checking for program /opt/FJSVxosmmm/sbin/c2html...not found
Checking for program /home/hp150306/t00196/c2html...not found
Checking for program /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/bin/win32fe/c2html...not found
TEST alternateConfigureLibrary from config.packages.Numpy(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Numpy(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.mpi4py(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/mpi4py.py:70)
TESTING: alternateConfigureLibrary from config.packages.mpi4py(config/BuildSystem/config/packages/mpi4py.py:70)
Defined make rule "mpi4py-build" with dependencies "" and code []
Defined make rule "mpi4py-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.petsc4py(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/petsc4py.py:103)
TESTING: alternateConfigureLibrary from config.packages.petsc4py(config/BuildSystem/config/packages/petsc4py.py:103)
Defined make rule "petsc4py-build" with dependencies "" and code []
Defined make rule "petsc4py-install" with dependencies "" and code []
TEST alternateConfigureLibrary from config.packages.Matlab(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/Matlab.py:35)
TESTING: alternateConfigureLibrary from config.packages.Matlab(config/BuildSystem/config/packages/Matlab.py:35)
TEST alternateConfigureLibrary from config.packages.MatlabEngine(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.MatlabEngine(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.opengl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.opengl(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.glut(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.glut(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.opengles(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.opengles(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.boost(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.boost(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.PTScotch(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.PTScotch(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.hwloc(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:572)
TESTING: configureLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:572)
Checking for a functional hwloc
Checking for library in Compiler specific search HWLOC: []
Checking for functions [hwloc_topology_init] in library [] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char hwloc_topology_init();
static void _check_hwloc_topology_init() { hwloc_topology_init(); }
int main() {
_check_hwloc_topology_init();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Possible ERROR while running linker: exit code 256
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_hwloc_topology_init':
conftest.c:(.text+0x4): undefined reference to `hwloc_topology_init'
Popping language C
Checking for library in Compiler specific search HWLOC: ['libhwloc.a']
Checking for functions [hwloc_topology_init] in library ['libhwloc.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lhwloc -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
/usr/bin/ld: cannot find -lhwloc
Popping language C
Checking for library in Compiler specific search HWLOC: ['libhwloc.a', 'libxml2.a']
Checking for functions [hwloc_topology_init] in library ['libhwloc.a', 'libxml2.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lhwloc -lxml2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/usr/local/lib/libhwloc.a']
Contents: ['bin', 'etc', 'games', 'include', 'lib', 'lib64', 'libexec', 'sbin', 'share', 'src']
Checking for functions [hwloc_topology_init] in library ['/usr/local/lib/libhwloc.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lhwloc -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/usr/local/lib/libhwloc.a', 'libxml2.a']
Checking for functions [hwloc_topology_init] in library ['/usr/local/lib/libhwloc.a', 'libxml2.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lhwloc -lxml2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/usr/local/lib64/libhwloc.a']
Checking for functions [hwloc_topology_init] in library ['/usr/local/lib64/libhwloc.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lhwloc -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/usr/local/lib64/libhwloc.a', 'libxml2.a']
Checking for functions [hwloc_topology_init] in library ['/usr/local/lib64/libhwloc.a', 'libxml2.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lhwloc -lxml2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/opt/local/lib/libhwloc.a']
Contents: ['bin', 'conf', 'gcc', 'gcc-4.8.1', 'include', 'lib', 'Python-2.7.3', 'Python-2.7.3.omp', 'share', 'sparc64-unknown-linux-gnu', 'openjdk7u45', 'mpiJava', 'mpigcc', 'GCC_4.6.3']
Checking for functions [hwloc_topology_init] in library ['/opt/local/lib/libhwloc.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/opt/local/lib -L/opt/local/lib -lhwloc -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory HWLOC: ['/opt/local/lib/libhwloc.a', 'libxml2.a']
Checking for functions [hwloc_topology_init] in library ['/opt/local/lib/libhwloc.a', 'libxml2.a'] []
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/opt/local/lib -L/opt/local/lib -lhwloc -lxml2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
HWLOC: DirPath not found.. skipping: /opt/local/lib64
TEST checkSharedLibrary from config.packages.hwloc(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.hwloc(config/BuildSystem/config/package.py:626)
Popping language C
TEST alternateConfigureLibrary from config.packages.hdf5(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.hdf5(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.netcdf(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.netcdf(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.MOAB(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.MOAB(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.netcdf-cxx(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.netcdf-cxx(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.exodusii(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.exodusii(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.X(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:572)
TESTING: configureLibrary from config.packages.X(config/BuildSystem/config/package.py:572)
Checking for a functional X
Checking for library in Compiler specific search X: []
Checking for functions [XSetWMName] in library [] []
Pushing language C
Successful compile:
Source:
char XSetWMName();
static void _check_XSetWMName() { XSetWMName(); }
int main() {
_check_XSetWMName();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_XSetWMName':
conftest.c:(.text+0x4): undefined reference to `XSetWMName'
Popping language C
Checking for library in Compiler specific search X: ['libX11.a']
Checking for functions [XSetWMName] in library ['libX11.a'] []
Pushing language C
Successful compile:
Source:
char XSetWMName();
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -lX11 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
/usr/bin/ld: cannot find -lX11
Popping language C
X: SearchDir DirPath not found.. skipping: /opt/X11
X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.5.sdk/usr/X11
X: SearchDir DirPath not found.. skipping: /Developer/SDKs/MacOSX10.4u.sdk/usr/X11R6
X: SearchDir DirPath not found.. skipping: /usr/X11
X: SearchDir DirPath not found.. skipping: /usr/X11R6
X: SearchDir DirPath not found.. skipping: /usr/X11R5
X: SearchDir DirPath not found.. skipping: /usr/X11R4
X: SearchDir DirPath not found.. skipping: /usr/local/X11
X: SearchDir DirPath not found.. skipping: /usr/local/X11R6
X: SearchDir DirPath not found.. skipping: /usr/local/X11R5
X: SearchDir DirPath not found.. skipping: /usr/local/X11R4
X: SearchDir DirPath not found.. skipping: /usr/X386
X: SearchDir DirPath not found.. skipping: /usr/x386
X: SearchDir DirPath not found.. skipping: /usr/XFree86/X11
Checking for library in Package specific search directory X: ['/usr/local/lib/libX11.a']
Checking for functions [XSetWMName] in library ['/usr/local/lib/libX11.a'] []
Pushing language C
Successful compile:
Source:
char XSetWMName();
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lX11 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
Checking for library in Package specific search directory X: ['/usr/local/lib64/libX11.a']
Checking for functions [XSetWMName] in library ['/usr/local/lib64/libX11.a'] []
Pushing language C
Successful compile:
Source:
char XSetWMName();
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/usr/local/lib64 -L/usr/local/lib64 -lX11 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stderr:
Popping language C
X: SearchDir DirPath not found.. skipping: /usr/local/x11r5
X: SearchDir DirPath not found.. skipping: /usr/lpp/Xamples
X: SearchDir DirPath not found.. skipping: /usr/openwin
X: SearchDir DirPath not found.. skipping: /usr/openwin/share
TEST checkSharedLibrary from config.packages.X(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.X(config/BuildSystem/config/package.py:626)
Popping language C
TEST alternateConfigureLibrary from config.packages.Triangle(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Triangle(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.afterimage(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.afterimage(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.openmp(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/openmp.py:15)
TESTING: configureLibrary from config.packages.openmp(config/BuildSystem/config/packages/openmp.py:15)
Checks for -fopenmp compiler flag
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Added C compiler flag -Kopenmp
Popping language C
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -X9 -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Added FC compiler flag -Kopenmp
Popping language FC
Pushing language Cxx
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Added Cxx compiler flag -Kopenmp
Popping language Cxx
TEST checkSharedLibrary from config.packages.openmp(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.openmp(config/BuildSystem/config/package.py:626)
Popping language C
TEST alternateConfigureLibrary from config.packages.saws(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.saws(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.pthread(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/pthread.py:19)
TESTING: configureLibrary from config.packages.pthread(config/BuildSystem/config/packages/pthread.py:19)
Checks for pthread_barrier_t, cpu_set_t, and sys/sysctl.h
Checking for a functional pthread
Checking for library in Compiler specific search PTHREAD: []
Checking for functions [pthread_create] in library [] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
char pthread_create();
static void _check_pthread_create() { pthread_create(); }
int main() {
_check_pthread_create();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Checking for headers Compiler specific search PTHREAD: []
Pushing language C
Checking for header files ['pthread.h'] in []
stdout:
#line 1 "/usr/include/pthread.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 24 "/usr/include/pthread.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 25 "/usr/include/pthread.h"
#line 1 "/usr/include/sched.h"
#line 24 "/usr/include/sched.h"
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 27 "/usr/include/sched.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 30 "/usr/include/sched.h"
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 419 "/usr/include/time.h"
#line 33 "/usr/include/sched.h"
#line 1 "/usr/include/bits/sched.h"
#line 36 "/usr/include/bits/sched.h"
#line 64 "/usr/include/bits/sched.h"
struct sched_param
int __sched_priority;
extern int clone (int (*__fn) (void *__arg), void *__child_stack,
int __flags, void *__arg, ...) ;
extern int unshare (int __flags) ;
extern int sched_getcpu (void) ;
struct __sched_param
typedef unsigned long int __cpu_mask;
typedef struct
__cpu_mask __bits[1024 / (8 * sizeof (__cpu_mask))];
} cpu_set_t;
#line 146 "/usr/include/bits/sched.h"
#line 164 "/usr/include/bits/sched.h"
#line 174 "/usr/include/bits/sched.h"
extern int __sched_cpucount (size_t __setsize, const cpu_set_t *__setp)
extern cpu_set_t *__sched_cpualloc (size_t __count) ;
extern void __sched_cpufree (cpu_set_t *__set) ;
#line 36 "/usr/include/sched.h"
extern int sched_setparam (__pid_t __pid, const struct sched_param *__param)
extern int sched_getparam (__pid_t __pid, struct sched_param *__param) ;
extern int sched_setscheduler (__pid_t __pid, int __policy,
const struct sched_param *__param) ;
extern int sched_getscheduler (__pid_t __pid) ;
extern int sched_yield (void) ;
extern int sched_get_priority_max (int __algorithm) ;
extern int sched_get_priority_min (int __algorithm) ;
extern int sched_rr_get_interval (__pid_t __pid, struct timespec *__t) ;
#line 117 "/usr/include/sched.h"
#line 26 "/usr/include/pthread.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 30 "/usr/include/time.h"
#line 40 "/usr/include/time.h"
#line 43 "/usr/include/bits/time.h"
#line 44 "/usr/include/time.h"
typedef __clock_t clock_t;
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
struct tm
int tm_sec;
int tm_min;
int tm_hour;
int tm_mday;
int tm_mon;
int tm_year;
int tm_wday;
int tm_yday;
int tm_isdst;
long int tm_gmtoff;
const char *tm_zone;
struct itimerspec
struct timespec it_interval;
struct timespec it_value;
struct sigevent;
typedef __pid_t pid_t;
extern clock_t clock (void) ;
extern time_t time (time_t *__timer) ;
extern double difftime (time_t __time1, time_t __time0)
extern time_t mktime (struct tm *__tp) ;
extern size_t strftime (char * __s, size_t __maxsize,
const char * __format,
const struct tm * __tp) ;
#line 212 "/usr/include/time.h"
#line 227 "/usr/include/time.h"
extern struct tm *gmtime (const time_t *__timer) ;
extern struct tm *localtime (const time_t *__timer) ;
extern struct tm *gmtime_r (const time_t * __timer,
struct tm * __tp) ;
extern struct tm *localtime_r (const time_t * __timer,
struct tm * __tp) ;
extern char *asctime (const struct tm *__tp) ;
extern char *ctime (const time_t *__timer) ;
extern char *asctime_r (const struct tm * __tp,
char * __buf) ;
extern char *ctime_r (const time_t * __timer,
char * __buf) ;
extern char *__tzname[2];
extern int __daylight;
extern long int __timezone;
extern char *tzname[2];
extern void tzset (void) ;
extern int daylight;
extern long int timezone;
extern int stime (const time_t *__when) ;
extern time_t timegm (struct tm *__tp) ;
extern time_t timelocal (struct tm *__tp) ;
extern int dysize (int __year) ;
extern int nanosleep (const struct timespec *__requested_time,
struct timespec *__remaining);
extern int clock_getres (clockid_t __clock_id, struct timespec *__res) ;
extern int clock_gettime (clockid_t __clock_id, struct timespec *__tp) ;
extern int clock_settime (clockid_t __clock_id, const struct timespec *__tp)
extern int clock_nanosleep (clockid_t __clock_id, int __flags,
const struct timespec *__req,
struct timespec *__rem);
extern int clock_getcpuclockid (pid_t __pid, clockid_t *__clock_id) ;
extern int timer_create (clockid_t __clock_id,
struct sigevent * __evp,
timer_t * __timerid) ;
extern int timer_delete (timer_t __timerid) ;
extern int timer_settime (timer_t __timerid, int __flags,
const struct itimerspec * __value,
struct itimerspec * __ovalue) ;
extern int timer_gettime (timer_t __timerid, struct itimerspec *__value)
extern int timer_getoverrun (timer_t __timerid) ;
#line 400 "/usr/include/time.h"
#line 415 "/usr/include/time.h"
#line 27 "/usr/include/pthread.h"
#line 1 "/usr/include/signal.h"
#line 30 "/usr/include/signal.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 34 "/usr/include/signal.h"
#line 46 "/usr/include/signal.h"
typedef __sigset_t sigset_t;
#line 401 "/usr/include/signal.h"
#line 30 "/usr/include/pthread.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 31 "/usr/include/pthread.h"
#line 1 "/usr/include/bits/setjmp.h"
#line 28 "/usr/include/bits/setjmp.h"
typedef struct __sparc64_jmp_buf
struct __sparc64_jmp_buf *uc_link;
unsigned long uc_flags;
unsigned long uc_sigmask;
struct __sparc64_jmp_buf_mcontext
unsigned long mc_gregs[53];
unsigned long mc_fp;
unsigned long mc_i7;
struct __sparc64_jmp_buf_fpu
union
unsigned int sregs[512];
unsigned long dregs[256];
long double qregs[128];
} mcfpu_fpregs;
unsigned long mcfpu_fsr;
unsigned long mcfpu_fprs;
unsigned long mcfpu_gsr;
unsigned long mcfpu_xasr;
void *mcfpu_fq;
unsigned char mcfpu_qcnt;
unsigned char mcfpu_qentsz;
unsigned char mcfpu_enab;
} mc_fpregs;
} uc_mcontext;
} __jmp_buf[1];
#line 70 "/usr/include/bits/setjmp.h"
#line 32 "/usr/include/pthread.h"
#line 33 "/usr/include/pthread.h"
enum
PTHREAD_CREATE_JOINABLE,
PTHREAD_CREATE_DETACHED
enum
PTHREAD_MUTEX_TIMED_NP,
PTHREAD_MUTEX_RECURSIVE_NP,
PTHREAD_MUTEX_ERRORCHECK_NP,
PTHREAD_MUTEX_ADAPTIVE_NP
#line 63 "/usr/include/pthread.h"
#line 74 "/usr/include/pthread.h"
#line 85 "/usr/include/pthread.h"
#line 111 "/usr/include/pthread.h"
enum
PTHREAD_RWLOCK_PREFER_READER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NP,
PTHREAD_RWLOCK_PREFER_WRITER_NONRECURSIVE_NP,
PTHREAD_RWLOCK_DEFAULT_NP = PTHREAD_RWLOCK_PREFER_READER_NP
#line 144 "/usr/include/pthread.h"
enum
PTHREAD_INHERIT_SCHED,
PTHREAD_EXPLICIT_SCHED
enum
PTHREAD_SCOPE_SYSTEM,
PTHREAD_SCOPE_PROCESS
enum
PTHREAD_PROCESS_PRIVATE,
PTHREAD_PROCESS_SHARED
struct _pthread_cleanup_buffer
void (*__routine) (void *);
void *__arg;
int __canceltype;
struct _pthread_cleanup_buffer *__prev;
enum
PTHREAD_CANCEL_ENABLE,
PTHREAD_CANCEL_DISABLE
enum
PTHREAD_CANCEL_DEFERRED,
PTHREAD_CANCEL_ASYNCHRONOUS
extern int pthread_create (pthread_t * __newthread,
const pthread_attr_t * __attr,
void *(*__start_routine) (void *),
void * __arg) ;
extern void pthread_exit (void *__retval) ;
extern int pthread_join (pthread_t __th, void **__thread_return);
#line 258 "/usr/include/pthread.h"
extern int pthread_detach (pthread_t __th) ;
extern pthread_t pthread_self (void) ;
extern int pthread_equal (pthread_t __thread1, pthread_t __thread2) ;
extern int pthread_attr_init (pthread_attr_t *__attr) ;
extern int pthread_attr_destroy (pthread_attr_t *__attr)
extern int pthread_attr_getdetachstate (const pthread_attr_t *__attr,
int *__detachstate)
extern int pthread_attr_setdetachstate (pthread_attr_t *__attr,
int __detachstate)
extern int pthread_attr_getguardsize (const pthread_attr_t *__attr,
size_t *__guardsize)
extern int pthread_attr_setguardsize (pthread_attr_t *__attr,
size_t __guardsize)
extern int pthread_attr_getschedparam (const pthread_attr_t *
__attr,
struct sched_param * __param)
extern int pthread_attr_setschedparam (pthread_attr_t * __attr,
__param) ;
extern int pthread_attr_getschedpolicy (const pthread_attr_t *
__attr, int * __policy)
extern int pthread_attr_setschedpolicy (pthread_attr_t *__attr, int __policy)
extern int pthread_attr_getinheritsched (const pthread_attr_t *
__attr, int * __inherit)
extern int pthread_attr_setinheritsched (pthread_attr_t *__attr,
int __inherit)
extern int pthread_attr_getscope (const pthread_attr_t * __attr,
int * __scope)
extern int pthread_attr_setscope (pthread_attr_t *__attr, int __scope)
extern int pthread_attr_getstackaddr (const pthread_attr_t *
__attr, void ** __stackaddr)
extern int pthread_attr_setstackaddr (pthread_attr_t *__attr,
void *__stackaddr)
extern int pthread_attr_getstacksize (const pthread_attr_t *
__attr, size_t * __stacksize)
extern int pthread_attr_setstacksize (pthread_attr_t *__attr,
size_t __stacksize)
extern int pthread_attr_getstack (const pthread_attr_t * __attr,
void ** __stackaddr,
extern int pthread_attr_setstack (pthread_attr_t *__attr, void *__stackaddr,
size_t __stacksize) ;
#line 407 "/usr/include/pthread.h"
extern int pthread_setschedparam (pthread_t __target_thread, int __policy,
extern int pthread_getschedparam (pthread_t __target_thread,
int * __policy,
extern int pthread_setschedprio (pthread_t __target_thread, int __prio)
#line 435 "/usr/include/pthread.h"
#line 455 "/usr/include/pthread.h"
extern int pthread_once (pthread_once_t *__once_control,
void (*__init_routine) (void)) ;
extern int pthread_setcancelstate (int __state, int *__oldstate);
extern int pthread_setcanceltype (int __type, int *__oldtype);
extern int pthread_cancel (pthread_t __th);
extern void pthread_testcancel (void);
typedef struct
struct
__jmp_buf __cancel_jmp_buf;
int __mask_was_saved;
} __cancel_jmp_buf[1];
void *__pad[4];
} __pthread_unwind_buf_t ;
struct __pthread_cleanup_frame
void (*__cancel_routine) (void *);
void *__cancel_arg;
int __do_it;
int __cancel_type;
#line 629 "/usr/include/pthread.h"
#line 652 "/usr/include/pthread.h"
extern void __pthread_register_cancel (__pthread_unwind_buf_t *__buf)
#line 663 "/usr/include/pthread.h"
extern void __pthread_unregister_cancel (__pthread_unwind_buf_t *__buf)
#line 701 "/usr/include/pthread.h"
extern void __pthread_unwind_next (__pthread_unwind_buf_t *__buf)
struct __jmp_buf_tag;
extern int __sigsetjmp (struct __jmp_buf_tag *__env, int __savemask) ;
extern int pthread_mutex_init (pthread_mutex_t *__mutex,
const pthread_mutexattr_t *__mutexattr)
extern int pthread_mutex_destroy (pthread_mutex_t *__mutex)
extern int pthread_mutex_trylock (pthread_mutex_t *__mutex)
extern int pthread_mutex_lock (pthread_mutex_t *__mutex)
extern int pthread_mutex_timedlock (pthread_mutex_t * __mutex,
__abstime) ;
extern int pthread_mutex_unlock (pthread_mutex_t *__mutex)
#line 761 "/usr/include/pthread.h"
extern int pthread_mutexattr_init (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_destroy (pthread_mutexattr_t *__attr)
extern int pthread_mutexattr_getpshared (const pthread_mutexattr_t *
__attr,
int * __pshared)
extern int pthread_mutexattr_setpshared (pthread_mutexattr_t *__attr,
int __pshared)
#line 827 "/usr/include/pthread.h"
#line 839 "/usr/include/pthread.h"
extern int pthread_rwlock_init (pthread_rwlock_t * __rwlock,
const pthread_rwlockattr_t *
__attr) ;
extern int pthread_rwlock_destroy (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_rdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_tryrdlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedrdlock (pthread_rwlock_t * __rwlock,
__abstime) ;
extern int pthread_rwlock_wrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_trywrlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlock_timedwrlock (pthread_rwlock_t * __rwlock,
__abstime) ;
extern int pthread_rwlock_unlock (pthread_rwlock_t *__rwlock)
extern int pthread_rwlockattr_init (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_destroy (pthread_rwlockattr_t *__attr)
extern int pthread_rwlockattr_getpshared (const pthread_rwlockattr_t *
__attr,
int * __pshared)
extern int pthread_rwlockattr_setpshared (pthread_rwlockattr_t *__attr,
int __pshared)
extern int pthread_rwlockattr_getkind_np (const pthread_rwlockattr_t *
__attr,
int * __pref)
extern int pthread_rwlockattr_setkind_np (pthread_rwlockattr_t *__attr,
int __pref) ;
extern int pthread_cond_init (pthread_cond_t * __cond,
const pthread_condattr_t *
__cond_attr) ;
extern int pthread_cond_destroy (pthread_cond_t *__cond)
extern int pthread_cond_signal (pthread_cond_t *__cond)
extern int pthread_cond_broadcast (pthread_cond_t *__cond)
extern int pthread_cond_wait (pthread_cond_t * __cond,
pthread_mutex_t * __mutex)
extern int pthread_cond_timedwait (pthread_cond_t * __cond,
__abstime) ;
extern int pthread_condattr_init (pthread_condattr_t *__attr)
extern int pthread_condattr_destroy (pthread_condattr_t *__attr)
extern int pthread_condattr_getpshared (const pthread_condattr_t *
__attr,
int * __pshared)
extern int pthread_condattr_setpshared (pthread_condattr_t *__attr,
int __pshared) ;
extern int pthread_condattr_getclock (const pthread_condattr_t *
__attr,
__clockid_t * __clock_id)
extern int pthread_condattr_setclock (pthread_condattr_t *__attr,
__clockid_t __clock_id)
extern int pthread_spin_init (pthread_spinlock_t *__lock, int __pshared)
extern int pthread_spin_destroy (pthread_spinlock_t *__lock)
extern int pthread_spin_lock (pthread_spinlock_t *__lock)
extern int pthread_spin_trylock (pthread_spinlock_t *__lock)
extern int pthread_spin_unlock (pthread_spinlock_t *__lock)
extern int pthread_barrier_init (pthread_barrier_t * __barrier,
const pthread_barrierattr_t *
__attr, unsigned int __count)
extern int pthread_barrier_destroy (pthread_barrier_t *__barrier)
extern int pthread_barrier_wait (pthread_barrier_t *__barrier)
extern int pthread_barrierattr_init (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_destroy (pthread_barrierattr_t *__attr)
extern int pthread_barrierattr_getpshared (const pthread_barrierattr_t *
__attr,
int * __pshared)
extern int pthread_barrierattr_setpshared (pthread_barrierattr_t *__attr,
int __pshared)
extern int pthread_key_create (pthread_key_t *__key,
void (*__destr_function) (void *))
extern int pthread_key_delete (pthread_key_t __key) ;
extern void *pthread_getspecific (pthread_key_t __key) ;
extern int pthread_setspecific (pthread_key_t __key,
const void *__pointer) ;
extern int pthread_getcpuclockid (pthread_t __thread_id,
__clockid_t *__clock_id)
extern int pthread_atfork (void (*__prepare) (void),
void (*__parent) (void),
void (*__child) (void)) ;
#line 1116 "/usr/include/pthread.h"
Found header files ['pthread.h'] in []
Popping language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c
Possible ERROR while running compiler:
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c", line 6: warning: variable "a" was declared but never referenced
pthread_barrier_t *a;
Source:
#include <pthread.h>
int main() {
return 0;
Defined "HAVE_PTHREAD_BARRIER_T" to "1"
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c
stderr:
cpu_set_t *a;
Source:
#include <sched.h>
int main() {
cpu_set_t *a;
return 0;
Defined "HAVE_SCHED_CPU_SET_T" to "1"
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c"
#line 1 "/usr/include/sys/sysctl.h"
#line 23 "/usr/include/sys/sysctl.h"
#line 25 "/usr/include/sys/sysctl.h"
#line 43 "/usr/include/sys/sysctl.h"
#line 1 "/usr/include/linux/sysctl.h"
#line 1 "/usr/include/linux/kernel.h"
#line 29 "/usr/include/linux/sysctl.h"
#line 1 "/usr/include/linux/types.h"
#line 30 "/usr/include/linux/sysctl.h"
struct file;
struct completion;
struct __sysctl_args {
int *name;
int nlen;
void *oldval;
size_t *oldlenp;
void *newval;
size_t newlen;
unsigned long __unused[4];
enum
CTL_KERN=1,
CTL_VM=2,
CTL_NET=3,
CTL_PROC=4,
CTL_FS=5,
CTL_DEBUG=6,
CTL_DEV=7,
CTL_BUS=8,
CTL_ABI=9,
CTL_CPU=10,
CTL_ARLAN=254,
CTL_S390DBF=5677,
CTL_SUNRPC=7249,
CTL_PM=9899,
CTL_FRV=9898,
enum
CTL_BUS_ISA=1
enum
INOTIFY_MAX_USER_INSTANCES=1,
INOTIFY_MAX_USER_WATCHES=2,
INOTIFY_MAX_QUEUED_EVENTS=3
enum
KERN_OSTYPE=1,
KERN_OSRELEASE=2,
KERN_OSREV=3,
KERN_VERSION=4,
KERN_SECUREMASK=5,
KERN_PROF=6,
KERN_NODENAME=7,
KERN_DOMAINNAME=8,
KERN_PANIC=15,
KERN_REALROOTDEV=16,
KERN_SPARC_REBOOT=21,
KERN_CTLALTDEL=22,
KERN_PRINTK=23,
KERN_NAMETRANS=24,
KERN_PPC_HTABRECLAIM=25,
KERN_PPC_ZEROPAGED=26,
KERN_PPC_POWERSAVE_NAP=27,
KERN_MODPROBE=28,
KERN_SG_BIG_BUFF=29,
KERN_ACCT=30,
KERN_PPC_L2CR=31,
KERN_RTSIGNR=32,
KERN_RTSIGMAX=33,
KERN_SHMMAX=34,
KERN_MSGMAX=35,
KERN_MSGMNB=36,
KERN_MSGPOOL=37,
KERN_SYSRQ=38,
KERN_MAX_THREADS=39,
KERN_RANDOM=40,
KERN_SHMALL=41,
KERN_MSGMNI=42,
KERN_SEM=43,
KERN_SPARC_STOP_A=44,
KERN_SHMMNI=45,
KERN_OVERFLOWUID=46,
KERN_OVERFLOWGID=47,
KERN_SHMPATH=48,
KERN_HOTPLUG=49,
KERN_IEEE_EMULATION_WARNINGS=50,
KERN_S390_USER_DEBUG_LOGGING=51,
KERN_CORE_USES_PID=52,
KERN_TAINTED=53,
KERN_CADPID=54,
KERN_PIDMAX=55,
KERN_CORE_PATTERN=56,
KERN_PANIC_ON_OOPS=57,
KERN_HPPA_PWRSW=58,
KERN_HPPA_UNALIGNED=59,
KERN_PRINTK_RATELIMIT=60,
KERN_PRINTK_RATELIMIT_BURST=61,
KERN_PTY=62,
KERN_NGROUPS_MAX=63,
KERN_SPARC_SCONS_PWROFF=64,
KERN_HZ_TIMER=65,
KERN_UNKNOWN_NMI_PANIC=66,
KERN_BOOTLOADER_TYPE=67,
KERN_RANDOMIZE=68,
KERN_SETUID_DUMPABLE=69,
KERN_SPIN_RETRY=70,
KERN_ACPI_VIDEO_FLAGS=71,
KERN_IA64_UNALIGNED=72,
KERN_COMPAT_LOG=73,
KERN_MAX_LOCK_DEPTH=74,
KERN_NMI_WATCHDOG=75,
KERN_PANIC_ON_NMI=76,
enum
VM_UNUSED1=1,
VM_UNUSED2=2,
VM_UNUSED3=3,
VM_UNUSED4=4,
VM_OVERCOMMIT_MEMORY=5,
VM_UNUSED5=6,
VM_UNUSED7=7,
VM_UNUSED8=8,
VM_UNUSED9=9,
VM_PAGE_CLUSTER=10,
VM_DIRTY_BACKGROUND=11,
VM_DIRTY_RATIO=12,
VM_DIRTY_WB_CS=13,
VM_DIRTY_EXPIRE_CS=14,
VM_NR_PDFLUSH_THREADS=15,
VM_OVERCOMMIT_RATIO=16,
VM_PAGEBUF=17,
VM_HUGETLB_PAGES=18,
VM_SWAPPINESS=19,
VM_LOWMEM_RESERVE_RATIO=20,
VM_MIN_FREE_KBYTES=21,
VM_MAX_MAP_COUNT=22,
VM_LAPTOP_MODE=23,
VM_BLOCK_DUMP=24,
VM_HUGETLB_GROUP=25,
VM_VFS_CACHE_PRESSURE=26,
VM_LEGACY_VA_LAYOUT=27,
VM_SWAP_TOKEN_TIMEOUT=28,
VM_DROP_PAGECACHE=29,
VM_PERCPU_PAGELIST_FRACTION=30,
VM_ZONE_RECLAIM_MODE=31,
VM_MIN_UNMAPPED=32,
VM_PANIC_ON_OOM=33,
VM_VDSO_ENABLED=34,
VM_MIN_SLAB=35,
VM_MPG_CTL=36,
enum mpg_proc_type {
MPG_CTL_TOTAL_BYTES = 1,
enum
NET_CORE=1,
NET_ETHER=2,
NET_802=3,
NET_UNIX=4,
NET_IPV4=5,
NET_IPX=6,
NET_ATALK=7,
NET_NETROM=8,
NET_AX25=9,
NET_BRIDGE=10,
NET_ROSE=11,
NET_IPV6=12,
NET_X25=13,
NET_TR=14,
NET_DECNET=15,
NET_ECONET=16,
NET_SCTP=17,
NET_LLC=18,
NET_NETFILTER=19,
NET_DCCP=20,
NET_IRDA=412,
enum
RANDOM_POOLSIZE=1,
RANDOM_ENTROPY_COUNT=2,
RANDOM_READ_THRESH=3,
RANDOM_WRITE_THRESH=4,
RANDOM_BOOT_ID=5,
RANDOM_UUID=6
enum
PTY_MAX=1,
PTY_NR=2
enum
BUS_ISA_MEM_BASE=1,
BUS_ISA_PORT_BASE=2,
BUS_ISA_PORT_SHIFT=3
enum
NET_CORE_WMEM_MAX=1,
NET_CORE_RMEM_MAX=2,
NET_CORE_WMEM_DEFAULT=3,
NET_CORE_RMEM_DEFAULT=4,
NET_CORE_MAX_BACKLOG=6,
NET_CORE_FASTROUTE=7,
NET_CORE_MSG_COST=8,
NET_CORE_MSG_BURST=9,
NET_CORE_OPTMEM_MAX=10,
NET_CORE_HOT_LIST_LENGTH=11,
NET_CORE_DIVERT_VERSION=12,
NET_CORE_NO_CONG_THRESH=13,
NET_CORE_NO_CONG=14,
NET_CORE_LO_CONG=15,
NET_CORE_MOD_CONG=16,
NET_CORE_DEV_WEIGHT=17,
NET_CORE_SOMAXCONN=18,
NET_CORE_BUDGET=19,
NET_CORE_AEVENT_ETIME=20,
NET_CORE_AEVENT_RSEQTH=21,
NET_CORE_WARNINGS=22,
enum
NET_UNIX_DESTROY_DELAY=1,
NET_UNIX_DELETE_DELAY=2,
NET_UNIX_MAX_DGRAM_QLEN=3,
enum
NET_NF_CONNTRACK_MAX=1,
NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
NET_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
NET_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
NET_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
NET_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
NET_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
NET_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
NET_NF_CONNTRACK_UDP_TIMEOUT=10,
NET_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
NET_NF_CONNTRACK_ICMP_TIMEOUT=12,
NET_NF_CONNTRACK_GENERIC_TIMEOUT=13,
NET_NF_CONNTRACK_BUCKETS=14,
NET_NF_CONNTRACK_LOG_INVALID=15,
NET_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
NET_NF_CONNTRACK_TCP_LOOSE=17,
NET_NF_CONNTRACK_TCP_BE_LIBERAL=18,
NET_NF_CONNTRACK_TCP_MAX_RETRANS=19,
NET_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
NET_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
NET_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
NET_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
NET_NF_CONNTRACK_COUNT=27,
NET_NF_CONNTRACK_ICMPV6_TIMEOUT=28,
NET_NF_CONNTRACK_FRAG6_TIMEOUT=29,
NET_NF_CONNTRACK_FRAG6_LOW_THRESH=30,
NET_NF_CONNTRACK_FRAG6_HIGH_THRESH=31,
NET_NF_CONNTRACK_CHECKSUM=32,
enum
NET_IPV4_FORWARD=8,
NET_IPV4_DYNADDR=9,
NET_IPV4_CONF=16,
NET_IPV4_NEIGH=17,
NET_IPV4_ROUTE=18,
NET_IPV4_FIB_HASH=19,
NET_IPV4_NETFILTER=20,
NET_IPV4_TCP_TIMESTAMPS=33,
NET_IPV4_TCP_WINDOW_SCALING=34,
NET_IPV4_TCP_SACK=35,
NET_IPV4_TCP_RETRANS_COLLAPSE=36,
NET_IPV4_DEFAULT_TTL=37,
NET_IPV4_AUTOCONFIG=38,
NET_IPV4_NO_PMTU_DISC=39,
NET_IPV4_TCP_SYN_RETRIES=40,
NET_IPV4_IPFRAG_HIGH_THRESH=41,
NET_IPV4_IPFRAG_LOW_THRESH=42,
NET_IPV4_IPFRAG_TIME=43,
NET_IPV4_TCP_MAX_KA_PROBES=44,
NET_IPV4_TCP_KEEPALIVE_TIME=45,
NET_IPV4_TCP_KEEPALIVE_PROBES=46,
NET_IPV4_TCP_RETRIES1=47,
NET_IPV4_TCP_RETRIES2=48,
NET_IPV4_TCP_FIN_TIMEOUT=49,
NET_IPV4_IP_MASQ_DEBUG=50,
NET_TCP_SYNCOOKIES=51,
NET_TCP_STDURG=52,
NET_TCP_RFC1337=53,
NET_TCP_SYN_TAILDROP=54,
NET_TCP_MAX_SYN_BACKLOG=55,
NET_IPV4_LOCAL_PORT_RANGE=56,
NET_IPV4_ICMP_ECHO_IGNORE_ALL=57,
NET_IPV4_ICMP_ECHO_IGNORE_BROADCASTS=58,
NET_IPV4_ICMP_SOURCEQUENCH_RATE=59,
NET_IPV4_ICMP_DESTUNREACH_RATE=60,
NET_IPV4_ICMP_TIMEEXCEED_RATE=61,
NET_IPV4_ICMP_PARAMPROB_RATE=62,
NET_IPV4_ICMP_ECHOREPLY_RATE=63,
NET_IPV4_ICMP_IGNORE_BOGUS_ERROR_RESPONSES=64,
NET_IPV4_IGMP_MAX_MEMBERSHIPS=65,
NET_TCP_TW_RECYCLE=66,
NET_IPV4_ALWAYS_DEFRAG=67,
NET_IPV4_TCP_KEEPALIVE_INTVL=68,
NET_IPV4_INET_PEER_THRESHOLD=69,
NET_IPV4_INET_PEER_MINTTL=70,
NET_IPV4_INET_PEER_MAXTTL=71,
NET_IPV4_INET_PEER_GC_MINTIME=72,
NET_IPV4_INET_PEER_GC_MAXTIME=73,
NET_TCP_ORPHAN_RETRIES=74,
NET_TCP_ABORT_ON_OVERFLOW=75,
NET_TCP_SYNACK_RETRIES=76,
NET_TCP_MAX_ORPHANS=77,
NET_TCP_MAX_TW_BUCKETS=78,
NET_TCP_FACK=79,
NET_TCP_REORDERING=80,
NET_TCP_ECN=81,
NET_TCP_DSACK=82,
NET_TCP_MEM=83,
NET_TCP_WMEM=84,
NET_TCP_RMEM=85,
NET_TCP_APP_WIN=86,
NET_TCP_ADV_WIN_SCALE=87,
NET_IPV4_NONLOCAL_BIND=88,
NET_IPV4_ICMP_RATELIMIT=89,
NET_IPV4_ICMP_RATEMASK=90,
NET_TCP_TW_REUSE=91,
NET_TCP_FRTO=92,
NET_TCP_LOW_LATENCY=93,
NET_IPV4_IPFRAG_SECRET_INTERVAL=94,
NET_IPV4_IGMP_MAX_MSF=96,
NET_TCP_NO_METRICS_SAVE=97,
NET_TCP_DEFAULT_WIN_SCALE=105,
NET_TCP_MODERATE_RCVBUF=106,
NET_TCP_TSO_WIN_DIVISOR=107,
NET_TCP_BIC_BETA=108,
NET_IPV4_ICMP_ERRORS_USE_INBOUND_IFADDR=109,
NET_TCP_CONG_CONTROL=110,
NET_TCP_ABC=111,
NET_IPV4_IPFRAG_MAX_DIST=112,
NET_TCP_MTU_PROBING=113,
NET_TCP_BASE_MSS=114,
NET_IPV4_TCP_WORKAROUND_SIGNED_WINDOWS=115,
NET_TCP_DMA_COPYBREAK=116,
NET_TCP_SLOW_START_AFTER_IDLE=117,
NET_CIPSOV4_CACHE_ENABLE=118,
NET_CIPSOV4_CACHE_BUCKET_SIZE=119,
NET_CIPSOV4_RBM_OPTFMT=120,
NET_CIPSOV4_RBM_STRICTVALID=121,
NET_TCP_AVAIL_CONG_CONTROL=122,
NET_TCP_ALLOWED_CONG_CONTROL=123,
NET_TCP_MAX_SSTHRESH=124,
NET_TCP_FRTO_RESPONSE=125,
enum {
NET_IPV4_ROUTE_FLUSH=1,
NET_IPV4_ROUTE_MIN_DELAY=2,
NET_IPV4_ROUTE_MAX_DELAY=3,
NET_IPV4_ROUTE_GC_THRESH=4,
NET_IPV4_ROUTE_MAX_SIZE=5,
NET_IPV4_ROUTE_GC_MIN_INTERVAL=6,
NET_IPV4_ROUTE_GC_TIMEOUT=7,
NET_IPV4_ROUTE_GC_INTERVAL=8,
NET_IPV4_ROUTE_REDIRECT_LOAD=9,
NET_IPV4_ROUTE_REDIRECT_NUMBER=10,
NET_IPV4_ROUTE_REDIRECT_SILENCE=11,
NET_IPV4_ROUTE_ERROR_COST=12,
NET_IPV4_ROUTE_ERROR_BURST=13,
NET_IPV4_ROUTE_GC_ELASTICITY=14,
NET_IPV4_ROUTE_MTU_EXPIRES=15,
NET_IPV4_ROUTE_MIN_PMTU=16,
NET_IPV4_ROUTE_MIN_ADVMSS=17,
NET_IPV4_ROUTE_SECRET_INTERVAL=18,
NET_IPV4_ROUTE_GC_MIN_INTERVAL_MS=19,
enum
NET_PROTO_CONF_ALL=-2,
NET_PROTO_CONF_DEFAULT=-3
enum
NET_IPV4_CONF_FORWARDING=1,
NET_IPV4_CONF_MC_FORWARDING=2,
NET_IPV4_CONF_PROXY_ARP=3,
NET_IPV4_CONF_ACCEPT_REDIRECTS=4,
NET_IPV4_CONF_SECURE_REDIRECTS=5,
NET_IPV4_CONF_SEND_REDIRECTS=6,
NET_IPV4_CONF_SHARED_MEDIA=7,
NET_IPV4_CONF_RP_FILTER=8,
NET_IPV4_CONF_ACCEPT_SOURCE_ROUTE=9,
NET_IPV4_CONF_BOOTP_RELAY=10,
NET_IPV4_CONF_LOG_MARTIANS=11,
NET_IPV4_CONF_TAG=12,
NET_IPV4_CONF_ARPFILTER=13,
NET_IPV4_CONF_MEDIUM_ID=14,
NET_IPV4_CONF_NOXFRM=15,
NET_IPV4_CONF_NOPOLICY=16,
NET_IPV4_CONF_FORCE_IGMP_VERSION=17,
NET_IPV4_CONF_ARP_ANNOUNCE=18,
NET_IPV4_CONF_ARP_IGNORE=19,
NET_IPV4_CONF_PROMOTE_SECONDARIES=20,
NET_IPV4_CONF_ARP_ACCEPT=21,
__NET_IPV4_CONF_MAX
enum
NET_IPV4_NF_CONNTRACK_MAX=1,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_SENT=2,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_SYN_RECV=3,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_ESTABLISHED=4,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_FIN_WAIT=5,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE_WAIT=6,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_LAST_ACK=7,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_TIME_WAIT=8,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_CLOSE=9,
NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT=10,
NET_IPV4_NF_CONNTRACK_UDP_TIMEOUT_STREAM=11,
NET_IPV4_NF_CONNTRACK_ICMP_TIMEOUT=12,
NET_IPV4_NF_CONNTRACK_GENERIC_TIMEOUT=13,
NET_IPV4_NF_CONNTRACK_BUCKETS=14,
NET_IPV4_NF_CONNTRACK_LOG_INVALID=15,
NET_IPV4_NF_CONNTRACK_TCP_TIMEOUT_MAX_RETRANS=16,
NET_IPV4_NF_CONNTRACK_TCP_LOOSE=17,
NET_IPV4_NF_CONNTRACK_TCP_BE_LIBERAL=18,
NET_IPV4_NF_CONNTRACK_TCP_MAX_RETRANS=19,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_CLOSED=20,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_WAIT=21,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_COOKIE_ECHOED=22,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_ESTABLISHED=23,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_SENT=24,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_RECD=25,
NET_IPV4_NF_CONNTRACK_SCTP_TIMEOUT_SHUTDOWN_ACK_SENT=26,
NET_IPV4_NF_CONNTRACK_COUNT=27,
NET_IPV4_NF_CONNTRACK_CHECKSUM=28,
enum {
NET_IPV6_CONF=16,
NET_IPV6_NEIGH=17,
NET_IPV6_ROUTE=18,
NET_IPV6_ICMP=19,
NET_IPV6_BINDV6ONLY=20,
NET_IPV6_IP6FRAG_HIGH_THRESH=21,
NET_IPV6_IP6FRAG_LOW_THRESH=22,
NET_IPV6_IP6FRAG_TIME=23,
NET_IPV6_IP6FRAG_SECRET_INTERVAL=24,
NET_IPV6_MLD_MAX_MSF=25,
enum {
NET_IPV6_ROUTE_FLUSH=1,
NET_IPV6_ROUTE_GC_THRESH=2,
NET_IPV6_ROUTE_MAX_SIZE=3,
NET_IPV6_ROUTE_GC_MIN_INTERVAL=4,
NET_IPV6_ROUTE_GC_TIMEOUT=5,
NET_IPV6_ROUTE_GC_INTERVAL=6,
NET_IPV6_ROUTE_GC_ELASTICITY=7,
NET_IPV6_ROUTE_MTU_EXPIRES=8,
NET_IPV6_ROUTE_MIN_ADVMSS=9,
NET_IPV6_ROUTE_GC_MIN_INTERVAL_MS=10
enum {
NET_IPV6_FORWARDING=1,
NET_IPV6_HOP_LIMIT=2,
NET_IPV6_MTU=3,
NET_IPV6_ACCEPT_RA=4,
NET_IPV6_ACCEPT_REDIRECTS=5,
NET_IPV6_AUTOCONF=6,
NET_IPV6_DAD_TRANSMITS=7,
NET_IPV6_RTR_SOLICITS=8,
NET_IPV6_RTR_SOLICIT_INTERVAL=9,
NET_IPV6_RTR_SOLICIT_DELAY=10,
NET_IPV6_USE_TEMPADDR=11,
NET_IPV6_TEMP_VALID_LFT=12,
NET_IPV6_TEMP_PREFERED_LFT=13,
NET_IPV6_REGEN_MAX_RETRY=14,
NET_IPV6_MAX_DESYNC_FACTOR=15,
NET_IPV6_MAX_ADDRESSES=16,
NET_IPV6_FORCE_MLD_VERSION=17,
NET_IPV6_ACCEPT_RA_DEFRTR=18,
NET_IPV6_ACCEPT_RA_PINFO=19,
NET_IPV6_ACCEPT_RA_RTR_PREF=20,
NET_IPV6_RTR_PROBE_INTERVAL=21,
NET_IPV6_ACCEPT_RA_RT_INFO_MAX_PLEN=22,
NET_IPV6_PROXY_NDP=23,
NET_IPV6_ACCEPT_SOURCE_ROUTE=25,
__NET_IPV6_MAX
enum {
NET_IPV6_ICMP_RATELIMIT=1
enum {
NET_NEIGH_MCAST_SOLICIT=1,
NET_NEIGH_UCAST_SOLICIT=2,
NET_NEIGH_APP_SOLICIT=3,
NET_NEIGH_RETRANS_TIME=4,
NET_NEIGH_REACHABLE_TIME=5,
NET_NEIGH_DELAY_PROBE_TIME=6,
NET_NEIGH_GC_STALE_TIME=7,
NET_NEIGH_UNRES_QLEN=8,
NET_NEIGH_PROXY_QLEN=9,
NET_NEIGH_ANYCAST_DELAY=10,
NET_NEIGH_PROXY_DELAY=11,
NET_NEIGH_LOCKTIME=12,
NET_NEIGH_GC_INTERVAL=13,
NET_NEIGH_GC_THRESH1=14,
NET_NEIGH_GC_THRESH2=15,
NET_NEIGH_GC_THRESH3=16,
NET_NEIGH_RETRANS_TIME_MS=17,
NET_NEIGH_REACHABLE_TIME_MS=18,
__NET_NEIGH_MAX
enum {
NET_DCCP_DEFAULT=1,
enum {
NET_IPX_PPROP_BROADCASTING=1,
NET_IPX_FORWARDING=2
enum {
NET_LLC2=1,
NET_LLC_STATION=2,
enum {
NET_LLC2_TIMEOUT=1,
enum {
NET_LLC_STATION_ACK_TIMEOUT=1,
enum {
NET_LLC2_ACK_TIMEOUT=1,
NET_LLC2_P_TIMEOUT=2,
NET_LLC2_REJ_TIMEOUT=3,
NET_LLC2_BUSY_TIMEOUT=4,
enum {
NET_ATALK_AARP_EXPIRY_TIME=1,
NET_ATALK_AARP_TICK_TIME=2,
NET_ATALK_AARP_RETRANSMIT_LIMIT=3,
NET_ATALK_AARP_RESOLVE_TIME=4
enum {
NET_NETROM_DEFAULT_PATH_QUALITY=1,
NET_NETROM_OBSOLESCENCE_COUNT_INITIALISER=2,
NET_NETROM_NETWORK_TTL_INITIALISER=3,
NET_NETROM_TRANSPORT_TIMEOUT=4,
NET_NETROM_TRANSPORT_MAXIMUM_TRIES=5,
NET_NETROM_TRANSPORT_ACKNOWLEDGE_DELAY=6,
NET_NETROM_TRANSPORT_BUSY_DELAY=7,
NET_NETROM_TRANSPORT_REQUESTED_WINDOW_SIZE=8,
NET_NETROM_TRANSPORT_NO_ACTIVITY_TIMEOUT=9,
NET_NETROM_ROUTING_CONTROL=10,
NET_NETROM_LINK_FAILS_COUNT=11,
NET_NETROM_RESET=12
enum {
NET_AX25_IP_DEFAULT_MODE=1,
NET_AX25_DEFAULT_MODE=2,
NET_AX25_BACKOFF_TYPE=3,
NET_AX25_CONNECT_MODE=4,
NET_AX25_STANDARD_WINDOW=5,
NET_AX25_EXTENDED_WINDOW=6,
NET_AX25_T1_TIMEOUT=7,
NET_AX25_T2_TIMEOUT=8,
NET_AX25_T3_TIMEOUT=9,
NET_AX25_IDLE_TIMEOUT=10,
NET_AX25_N2=11,
NET_AX25_PACLEN=12,
NET_AX25_PROTOCOL=13,
NET_AX25_DAMA_SLAVE_TIMEOUT=14
enum {
NET_ROSE_RESTART_REQUEST_TIMEOUT=1,
NET_ROSE_CALL_REQUEST_TIMEOUT=2,
NET_ROSE_RESET_REQUEST_TIMEOUT=3,
NET_ROSE_CLEAR_REQUEST_TIMEOUT=4,
NET_ROSE_ACK_HOLD_BACK_TIMEOUT=5,
NET_ROSE_ROUTING_CONTROL=6,
NET_ROSE_LINK_FAIL_TIMEOUT=7,
NET_ROSE_MAX_VCS=8,
NET_ROSE_WINDOW_SIZE=9,
NET_ROSE_NO_ACTIVITY_TIMEOUT=10
enum {
NET_X25_RESTART_REQUEST_TIMEOUT=1,
NET_X25_CALL_REQUEST_TIMEOUT=2,
NET_X25_RESET_REQUEST_TIMEOUT=3,
NET_X25_CLEAR_REQUEST_TIMEOUT=4,
NET_X25_ACK_HOLD_BACK_TIMEOUT=5,
NET_X25_FORWARD=6
enum
NET_TR_RIF_TIMEOUT=1
enum {
NET_DECNET_NODE_TYPE = 1,
NET_DECNET_NODE_ADDRESS = 2,
NET_DECNET_NODE_NAME = 3,
NET_DECNET_DEFAULT_DEVICE = 4,
NET_DECNET_TIME_WAIT = 5,
NET_DECNET_DN_COUNT = 6,
NET_DECNET_DI_COUNT = 7,
NET_DECNET_DR_COUNT = 8,
NET_DECNET_DST_GC_INTERVAL = 9,
NET_DECNET_CONF = 10,
NET_DECNET_NO_FC_MAX_CWND = 11,
NET_DECNET_MEM = 12,
NET_DECNET_RMEM = 13,
NET_DECNET_WMEM = 14,
NET_DECNET_DEBUG_LEVEL = 255
enum {
NET_DECNET_CONF_LOOPBACK = -2,
NET_DECNET_CONF_DDCMP = -3,
NET_DECNET_CONF_PPP = -4,
NET_DECNET_CONF_X25 = -5,
NET_DECNET_CONF_GRE = -6,
NET_DECNET_CONF_ETHER = -7
enum {
NET_DECNET_CONF_DEV_PRIORITY = 1,
NET_DECNET_CONF_DEV_T1 = 2,
NET_DECNET_CONF_DEV_T2 = 3,
NET_DECNET_CONF_DEV_T3 = 4,
NET_DECNET_CONF_DEV_FORWARDING = 5,
NET_DECNET_CONF_DEV_BLKSIZE = 6,
NET_DECNET_CONF_DEV_STATE = 7
enum {
NET_SCTP_RTO_INITIAL = 1,
NET_SCTP_RTO_MIN = 2,
NET_SCTP_RTO_MAX = 3,
NET_SCTP_RTO_ALPHA = 4,
NET_SCTP_RTO_BETA = 5,
NET_SCTP_VALID_COOKIE_LIFE = 6,
NET_SCTP_ASSOCIATION_MAX_RETRANS = 7,
NET_SCTP_PATH_MAX_RETRANS = 8,
NET_SCTP_MAX_INIT_RETRANSMITS = 9,
NET_SCTP_HB_INTERVAL = 10,
NET_SCTP_PRESERVE_ENABLE = 11,
NET_SCTP_MAX_BURST = 12,
NET_SCTP_ADDIP_ENABLE = 13,
NET_SCTP_PRSCTP_ENABLE = 14,
NET_SCTP_SNDBUF_POLICY = 15,
NET_SCTP_SACK_TIMEOUT = 16,
NET_SCTP_RCVBUF_POLICY = 17,
enum {
NET_BRIDGE_NF_CALL_ARPTABLES = 1,
NET_BRIDGE_NF_CALL_IPTABLES = 2,
NET_BRIDGE_NF_CALL_IP6TABLES = 3,
NET_BRIDGE_NF_FILTER_VLAN_TAGGED = 4,
NET_BRIDGE_NF_FILTER_PPPOE_TAGGED = 5,
enum {
NET_IRDA_DISCOVERY=1,
NET_IRDA_DEVNAME=2,
NET_IRDA_DEBUG=3,
NET_IRDA_FAST_POLL=4,
NET_IRDA_DISCOVERY_SLOTS=5,
NET_IRDA_DISCOVERY_TIMEOUT=6,
NET_IRDA_SLOT_TIMEOUT=7,
NET_IRDA_MAX_BAUD_RATE=8,
NET_IRDA_MIN_TX_TURN_TIME=9,
NET_IRDA_MAX_TX_DATA_SIZE=10,
NET_IRDA_MAX_TX_WINDOW=11,
NET_IRDA_MAX_NOREPLY_TIME=12,
NET_IRDA_WARN_NOREPLY_TIME=13,
NET_IRDA_LAP_KEEPALIVE_TIME=14,
enum
FS_NRINODE=1,
FS_STATINODE=2,
FS_MAXINODE=3,
FS_NRDQUOT=4,
FS_MAXDQUOT=5,
FS_NRFILE=6,
FS_MAXFILE=7,
FS_DENTRY=8,
FS_NRSUPER=9,
FS_MAXSUPER=10,
FS_OVERFLOWUID=11,
FS_OVERFLOWGID=12,
FS_LEASES=13,
FS_DIR_NOTIFY=14,
FS_LEASE_TIME=15,
FS_DQSTATS=16,
FS_XFS=17,
FS_AIO_NR=18,
FS_AIO_MAX_NR=19,
FS_INOTIFY=20,
FS_OCFS2=988,
enum {
FS_DQ_LOOKUPS = 1,
FS_DQ_DROPS = 2,
FS_DQ_READS = 3,
FS_DQ_WRITES = 4,
FS_DQ_CACHE_HITS = 5,
FS_DQ_ALLOCATED = 6,
FS_DQ_FREE = 7,
FS_DQ_SYNCS = 8,
FS_DQ_WARNINGS = 9,
enum {
DEV_CDROM=1,
DEV_HWMON=2,
DEV_PARPORT=3,
DEV_RAID=4,
DEV_MAC_HID=5,
DEV_SCSI=6,
DEV_IPMI=7,
enum {
DEV_CDROM_INFO=1,
DEV_CDROM_AUTOCLOSE=2,
DEV_CDROM_AUTOEJECT=3,
DEV_CDROM_DEBUG=4,
DEV_CDROM_LOCK=5,
DEV_CDROM_CHECK_MEDIA=6
enum {
DEV_PARPORT_DEFAULT=-3
enum {
DEV_RAID_SPEED_LIMIT_MIN=1,
DEV_RAID_SPEED_LIMIT_MAX=2
enum {
DEV_PARPORT_DEFAULT_TIMESLICE=1,
DEV_PARPORT_DEFAULT_SPINTIME=2
enum {
DEV_PARPORT_SPINTIME=1,
DEV_PARPORT_BASE_ADDR=2,
DEV_PARPORT_IRQ=3,
DEV_PARPORT_DMA=4,
DEV_PARPORT_MODES=5,
DEV_PARPORT_DEVICES=6,
DEV_PARPORT_AUTOPROBE=16
enum {
DEV_PARPORT_DEVICES_ACTIVE=-3,
enum {
DEV_PARPORT_DEVICE_TIMESLICE=1,
enum {
DEV_MAC_HID_KEYBOARD_SENDS_LINUX_KEYCODES=1,
DEV_MAC_HID_KEYBOARD_LOCK_KEYCODES=2,
DEV_MAC_HID_MOUSE_BUTTON_EMULATION=3,
DEV_MAC_HID_MOUSE_BUTTON2_KEYCODE=4,
DEV_MAC_HID_MOUSE_BUTTON3_KEYCODE=5,
DEV_MAC_HID_ADB_MOUSE_SENDS_KEYCODES=6
enum {
DEV_SCSI_LOGGING_LEVEL=1,
enum {
DEV_IPMI_POWEROFF_POWERCYCLE=1,
enum
ABI_DEFHANDLER_COFF=1,
ABI_DEFHANDLER_ELF=2,
ABI_DEFHANDLER_LCALL7=3,
ABI_DEFHANDLER_LIBCSO=4,
ABI_TRACE=5,
ABI_FAKE_UTSNAME=6,
#line 45 "/usr/include/sys/sysctl.h"
#line 63 "/usr/include/sys/sysctl.h"
extern int sysctl (int *__name, int __nlen, void *__oldval,
size_t *__oldlenp, void *__newval, size_t __newlen) ;
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread/conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Defined "HAVE_SYS_SYSCTL_H" to "1"
TEST checkSharedLibrary from config.packages.pthread(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.pthread(config/BuildSystem/config/package.py:626)
By default we don't care about checking if the library is shared
Popping language C
TEST alternateConfigureLibrary from config.packages.mpe(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.mpe(config/BuildSystem/config/package.py:630)
Called if --with-packagename=0; does nothing by default
TEST alternateConfigureLibrary from config.packages.papi(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.papi(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.scientificpython(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.scientificpython(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.fiat(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.fiat(config/BuildSystem/config/package.py:630)
TEST configureScalarType from PETSc.options.scalarTypes(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/scalarTypes.py:37)
TESTING: configureScalarType from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:37)
Choose between real and complex numbers
Defined "USE_SCALAR_REAL" to "1"
Scalar type is real
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double b = 2.0; int a = isnormal(b);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Possible ERROR while running linker: exit code 256
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes/conftest.o: In function `main':
conftest.c:(.text+0x2c): undefined reference to `isnormal'
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isnan(b);
return 0;
Pushing language C
Popping language C
Defined "HAVE_ISNAN" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0; int a = isinf(b);
return 0;
Pushing language C
Popping language C
Defined "HAVE_ISINF" to "1"
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0;int a = _isnan(b);
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x2c): undefined reference to `_isnan'
Successful compile:
Source:
#include <math.h>
int main() {
double b = 2.0;int a = _finite(b);
return 0;
Pushing language C
Popping language C
stderr:
conftest.c:(.text+0x2c): undefined reference to `_finite'
Popping language C
TEST configurePrecision from PETSc.options.scalarTypes(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/scalarTypes.py:77)
TESTING: configurePrecision from PETSc.options.scalarTypes(config/PETSc/options/scalarTypes.py:77)
Set the default real number precision for PETSc objects
Defined "USE_REAL_DOUBLE" to "1"
Defined make macro "PETSC_SCALAR_SIZE" to "64"
Precision is double
TEST alternateConfigureLibrary from config.packages.opencl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.opencl(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.viennacl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.viennacl(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.cuda(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.cuda(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.cusp(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.cusp(config/BuildSystem/config/package.py:630)
TEST locateCMake from config.packages.cmake(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/cmake.py:32)
TESTING: locateCMake from config.packages.cmake(config/BuildSystem/config/packages/cmake.py:32)
Looking for default CMake executable
Checking for program /opt/FJSVtclang/check/cmake...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/cmake...not found
Checking for program /opt/kusu/bin/cmake...not found
Checking for program /opt/kusu/sbin/cmake...not found
Checking for program /usr/pgsql-9.0/bin/cmake...not found
Checking for program /usr/local/bin/cmake...not found
Checking for program /bin/cmake...not found
Checking for program /usr/bin/cmake...not found
Checking for program /home/hp150306/t00196/bin/cmake...not found
Checking for program /home/hp150306/t00196/shortcut/cmake...not found
Checking for program /opt/FJSVxosmmm/sbin/cmake...not found
Checking for program /home/hp150306/t00196/cmake...not found
Checking for program /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/bin/win32fe/cmake...not found
TEST alternateConfigureLibrary from config.packages.metis(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.metis(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.parmetis(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.parmetis(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.Zoltan(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Zoltan(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.fblaslapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.fblaslapack(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.f2cblaslapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.f2cblaslapack(config/BuildSystem/config/package.py:630)
TEST configureLibrary from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:333)
TESTING: configureLibrary from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:333)
Checking for a functional BLAS and LAPACK in User specified BLAS/LAPACK library
TEST checkLib from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:100)
TESTING: checkLib from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:100)
Checking for BLAS and LAPACK symbols
Checking for functions [ddot_] in library ['-SSL2'] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char ddot_();
static void _check_ddot_() { ddot_(); }
int main() {
_check_ddot_();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -SSL2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Checking for functions [dgetrs_] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char dgetrs_();
static void _check_dgetrs_() { dgetrs_(); }
int main() {
_check_dgetrs_();;
return 0;
Pushing language C
Popping language C
Popping language C
Checking for functions [dgeev_] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char dgeev_();
static void _check_dgeev_() { dgeev_(); }
int main() {
_check_dgeev_();;
return 0;
Pushing language C
Popping language C
Popping language C
Found Fortran mangling on BLAS/LAPACK which is underscore
Defined "BLASLAPACK_UNDERSCORE" to "1"
TEST check64BitBLASIndices from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:466)
TESTING: check64BitBLASIndices from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:466)
Check for and use 64bit integer blas
TEST checkESSL from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:396)
TESTING: checkESSL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:396)
Check for the IBM ESSL library
Checking for functions [iessl] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char iessl();
static void _check_iessl() { iessl(); }
int main() {
_check_iessl();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_iessl':
conftest.c:(.text+0x4): undefined reference to `iessl'
Popping language C
TEST checkPESSL from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:408)
TESTING: checkPESSL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:408)
Check for the IBM PESSL library - and error out - if used instead of ESSL
Checking for functions [ipessl] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char ipessl();
static void _check_ipessl() { ipessl(); }
int main() {
_check_ipessl();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_ipessl':
conftest.c:(.text+0x4): undefined reference to `ipessl'
Popping language C
TEST checkMKL from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:402)
TESTING: checkMKL from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:402)
Check for Intel MKL library
Checking for functions [mkl_set_num_threads] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char mkl_set_num_threads();
static void _check_mkl_set_num_threads() { mkl_set_num_threads(); }
int main() {
_check_mkl_set_num_threads();;
return 0;
Pushing language C
Popping language C
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o: In function `_check_mkl_set_num_threads':
conftest.c:(.text+0x4): undefined reference to `mkl_set_num_threads'
Popping language C
TEST checkMissing from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:431)
TESTING: checkMissing from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:431)
Check for missing LAPACK routines
Checking for functions [dtrsen_ dgerfs_ dgges_ dtgsen_ dgesvd_ dgetrf_ dgetrs_ dgeev_ dgelss_ dsyev_ dsyevx_ dsygv_ dsygvx_ dpotrf_ dpotrs_ dstebz_ dpttrf_ dpttrs_ dstein_ dorgqr_ dgeqrf_ dgesv_ dhseqr_ dsteqr_] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char dtrsen_();
static void _check_dtrsen_() { dtrsen_(); }
char dgerfs_();
static void _check_dgerfs_() { dgerfs_(); }
char dgges_();
static void _check_dgges_() { dgges_(); }
char dtgsen_();
static void _check_dtgsen_() { dtgsen_(); }
char dgesvd_();
static void _check_dgesvd_() { dgesvd_(); }
char dgetrf_();
static void _check_dgetrf_() { dgetrf_(); }
char dgetrs_();
char dgeev_();
char dgelss_();
static void _check_dgelss_() { dgelss_(); }
char dsyev_();
static void _check_dsyev_() { dsyev_(); }
char dsyevx_();
static void _check_dsyevx_() { dsyevx_(); }
char dsygv_();
static void _check_dsygv_() { dsygv_(); }
char dsygvx_();
static void _check_dsygvx_() { dsygvx_(); }
char dpotrf_();
static void _check_dpotrf_() { dpotrf_(); }
char dpotrs_();
static void _check_dpotrs_() { dpotrs_(); }
char dstebz_();
static void _check_dstebz_() { dstebz_(); }
char dpttrf_();
static void _check_dpttrf_() { dpttrf_(); }
char dpttrs_();
static void _check_dpttrs_() { dpttrs_(); }
char dstein_();
static void _check_dstein_() { dstein_(); }
char dorgqr_();
static void _check_dorgqr_() { dorgqr_(); }
char dgeqrf_();
static void _check_dgeqrf_() { dgeqrf_(); }
char dgesv_();
static void _check_dgesv_() { dgesv_(); }
char dhseqr_();
static void _check_dhseqr_() { dhseqr_(); }
char dsteqr_();
static void _check_dsteqr_() { dsteqr_(); }
int main() {
_check_dtrsen_();
_check_dgerfs_();
_check_dgges_();
_check_dtgsen_();
_check_dgesvd_();
_check_dgetrf_();
_check_dgetrs_();
_check_dgeev_();
_check_dgelss_();
_check_dsyev_();
_check_dsyevx_();
_check_dsygv_();
_check_dsygvx_();
_check_dpotrf_();
_check_dpotrs_();
_check_dstebz_();
_check_dpttrf_();
_check_dpttrs_();
_check_dstein_();
_check_dorgqr_();
_check_dgeqrf_();
_check_dgesv_();
_check_dhseqr_();
_check_dsteqr_();;
return 0;
Pushing language C
Popping language C
Popping language C
TEST checklsame from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:444)
TESTING: checklsame from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:444)
Do the BLAS/LAPACK libraries have a valid lsame() function with correction binding. Lion and xcode 4.2 do not
Checking for functions [lsame_] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char lsame_();
static void _check_lsame_() { lsame_(); }
int main() {
_check_lsame_();;
return 0;
Pushing language C
Popping language C
Popping language C
TEST checksdotreturnsdouble from config.packages.BlasLapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/packages/BlasLapack.py:501)
TESTING: checksdotreturnsdouble from config.packages.BlasLapack(config/BuildSystem/config/packages/BlasLapack.py:501)
Determines if BLAS sdot routine returns a float or a double
Checking if sdot() returns a float or a double
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest.c
Successful compile:
Source:
#include <sys/types.h>
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
FILE *output = fopen("runtimetestoutput","w");
extern float sdot_(int*,float*,int *,float*,int*);
float x1[1] = {3.0};
int one1 = 1;
float sdotresult = sdot_(&one1,x1,&one1,x1,&one1);
fprintf(output, " '--known-sdot-returns-double=%d',\n",(sdotresult != 9.0));
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest.o -SSL2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack/conftest
Popping language C
Checking if snrm() returns a float or a double
Pushing language C
Successful compile:
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stdio.h>
#include <stddef.h>
#endif
int main() {
extern float snrm2_(int*,float*,int*);
float x2[1] = {3.0};
int one2 = 1;
float normresult = snrm2_(&one2,x2,&one2);
fprintf(output, " '--known-snrm2-returns-double=%d',\n",(normresult != 3.0));
return 0;
Pushing language C
Popping language C
Popping language C
TEST alternateConfigureLibrary from config.packages.SuperLU_MT(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.SuperLU_MT(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.pARMS(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.pARMS(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.SuiteSparse(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.SuiteSparse(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.ml(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.ml(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.spai(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.spai(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.mkl_cpardiso(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.mkl_cpardiso(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.sundials(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.sundials(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.elemental(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.elemental(config/BuildSystem/config/package.py:630)
TEST configureRegression from PETSc.Regression(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Regression.py:33)
TESTING: configureRegression from PETSc.Regression(config/PETSc/Regression.py:33)
Output a file listing the jobs that should be run by the PETSc buildtest
Defined make macro "TEST_RUNS" to "C Fortran SSL OPENMP Cxx F90 F90_NoComplex F2003 Fortran_NoComplex C_NoComplex"
TEST alternateConfigureLibrary from config.packages.PaStiX(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.PaStiX(config/BuildSystem/config/package.py:630)
Pushing language C
TEST configureLibrary from config.packages.scalapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:572)
TESTING: configureLibrary from config.packages.scalapack(config/BuildSystem/config/package.py:572)
Find an installation and check if it can work with PETSc
Checking for a functional scalapack
Checking for library in User specified SCALAPACK libraries: ['-SCALAPACK']
TEST check from config.libraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/libraries.py:146)
TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:146)
Checks that the library "libName" contains "funcs", and if it does defines HAVE_LIB"libName"
- libDir may be a list of directories
- libName may be a list of library names
Checking for functions [pssytrd_] in library ['-SCALAPACK'] ['-SSL2']
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
char pssytrd_();
static void _check_pssytrd_() { pssytrd_(); }
int main() {
_check_pssytrd_();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -SCALAPACK -SSL2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Checking for headers User specified SCALAPACK libraries: []
TEST checkSharedLibrary from config.packages.scalapack(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.scalapack(config/BuildSystem/config/package.py:626)
Popping language C
TEST alternateConfigureLibrary from config.packages.MUMPS(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.MUMPS(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.mkl_pardiso(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.mkl_pardiso(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.SuperLU_DIST(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.SuperLU_DIST(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.SuperLU(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.SuperLU(config/BuildSystem/config/package.py:630)
TEST alternateConfigureLibrary from config.packages.Chombo(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Chombo(config/BuildSystem/config/package.py:630)
Checking for functions [dgels_] in library ['-SSL2'] []
Pushing language C
Successful compile:
Source:
char dgels_();
static void _check_dgels_() { dgels_(); }
int main() {
_check_dgels_();;
return 0;
Pushing language C
Popping language C
Popping language C
Found dgels() in Lapack library as needed by hypre
Pushing language C
TEST configureLibrary from config.packages.hypre(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:572)
TESTING: configureLibrary from config.packages.hypre(config/BuildSystem/config/package.py:572)
Checking for a functional hypre
Checking for library in User specified root directory HYPRE: ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib/libHYPRE.a', '-ltrtmetcpp', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-L/opt/FJSVxosmmm/lib64', '-lmpi_cxx', '-lfjdemgl', '-lstd_mt', '-lpthread', '-lstdc++']
Contents: ['lib', 'include']
Checking for functions [HYPRE_IJMatrixCreate] in library ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib/libHYPRE.a', '-ltrtmetcpp', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-L/opt/FJSVxosmmm/lib64', '-lmpi_cxx', '-lfjdemgl', '-lstd_mt', '-lpthread', '-lstdc++'] ['-SSL2']
Pushing language C
Successful compile:
Source:
char HYPRE_IJMatrixCreate();
static void _check_HYPRE_IJMatrixCreate() { HYPRE_IJMatrixCreate(); }
int main() {
_check_HYPRE_IJMatrixCreate();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -SSL2 -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "HAVE_LIBHYPRE" to "1"
Defined "HAVE_LIBTRTMETCPP" to "1"
Defined "HAVE_LIBMPI_CXX" to "1"
Defined "HAVE_LIBFJDEMGL" to "1"
Defined "HAVE_LIBSTD_MT" to "1"
Defined "HAVE_LIBPTHREAD" to "1"
Defined "HAVE_LIBSTDC__" to "1"
Popping language C
Checking for headers User specified root directory HYPRE: ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include']
Pushing language C
TEST checkInclude from config.headers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/headers.py:86)
TESTING: checkInclude from config.headers(config/BuildSystem/config/headers.py:86)
Checks if a particular include file can be found along particular include paths
Checking for header files ['HYPRE.h'] in ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include']
Checking include with compiler flags var CPPFLAGS ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include', '/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu']
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
#line 1 "/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include/HYPRE.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers/conftest.c"
Found header files ['HYPRE.h'] in ['/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include']
Popping language C
TEST checkSharedLibrary from config.packages.hypre(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:626)
TESTING: checkSharedLibrary from config.packages.hypre(config/BuildSystem/config/package.py:626)
Popping language C
TEST alternateConfigureLibrary from config.packages.Trilinos(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/package.py:630)
TESTING: alternateConfigureLibrary from config.packages.Trilinos(config/BuildSystem/config/package.py:630)
TEST configureRTLDDefault from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:774)
TESTING: configureRTLDDefault from PETSc.Configure(config/PETSc/Configure.py:774)
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 4: error: identifier "RTLD_DEFAULT" is undefined
void *ptr = RTLD_DEFAULT;
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c".
Source:
#include <dlfcn.h>
int main() {
return 0;
TEST configurePrefetch from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:624)
TESTING: configurePrefetch from PETSc.Configure(config/PETSc/Configure.py:624)
Sees if there are any prefetch functions supported
Executing: uname -s
stdout: Linux
Pushing language C
Possible ERROR while running compiler: exit code 1024
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 3: catastrophic error: cannot open source file "xmmintrin.h"
#include <xmmintrin.h>
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c".
Compilation terminated.
Source:
int main() {
void *v = 0;_mm_prefetch((const char*)v,_MM_HINT_NTA);
return 0;
Compile failed inside link
stderr:
Source:
int main() {
void *v = 0;_mm_prefetch(v,_MM_HINT_NTA);
return 0;
Successful compile:
Source:
int main() {
void *v = 0;__builtin_prefetch(v,0,0);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Defined "Prefetch(a,b,c)" to "__builtin_prefetch((a),(b),(c))"
Defined "PREFETCH_HINT_NTA" to "0"
Defined "PREFETCH_HINT_T0" to "3"
Defined "PREFETCH_HINT_T1" to "2"
Defined "PREFETCH_HINT_T2" to "1"
Popping language C
TEST configureUnused from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:685)
TESTING: configureUnused from PETSc.Configure(config/PETSc/Configure.py:685)
Sees if __attribute((unused)) is supported
Pushing language C
Successful compile:
Source:
__attribute((unused)) static int myfunc(__attribute((unused)) void *name){ return 1;}
int main() {
int i = 0;
int j = myfunc(&i);
typedef void* atype;
__attribute((unused)) atype a;
return 0;
Pushing language C
Popping language C
Defined "UNUSED" to "__attribute((unused))"
Popping language C
TEST configureDeprecated from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:703)
TESTING: configureDeprecated from PETSc.Configure(config/PETSc/Configure.py:703)
Check if __attribute((deprecated)) is supported
Pushing language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 3: warning: function "myfunc" was declared but never referenced
__attribute((deprecated)) static int myfunc(void) { return 1;}
Source:
int main() {
return 0;
Defined "DEPRECATED(why)" to "__attribute((deprecated))"
Popping language C
TEST configureIsatty from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:697)
TESTING: configureIsatty from PETSc.Configure(config/PETSc/Configure.py:697)
Check if the Unix C function isatty() works correctly
Actually just assumes it does not work correctly on batch systems
Defined "USE_ISATTY" to "1"
TEST configureExpect from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:723)
TESTING: configureExpect from PETSc.Configure(config/PETSc/Configure.py:723)
Sees if the __builtin_expect directive is supported
Pushing language C
Successful compile:
Source:
int main() {
if (__builtin_expect(0,1)) return 1;;
return 0;
Pushing language C
Popping language C
Defined "HAVE_BUILTIN_EXPECT" to "1"
Popping language C
TEST configureFunctionName from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:730)
TESTING: configureFunctionName from PETSc.Configure(config/PETSc/Configure.py:730)
Sees if the compiler supports __func__ or a variant. Falls back
on __FUNCT__ which PETSc source defines, but most users do not, thus
stack traces through user code are better when the compiler's
variant is used.
Pushing language C
Successful compile:
Source:
int main() {
if (__func__[0] != 'm') return 1;;
return 0;
Pushing language C
Popping language C
Popping language C
Defined "FUNCTION_NAME_C" to "__func__"
Pushing language Cxx
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language Cxx
Defined "FUNCTION_NAME_CXX" to "__func__"
TEST configureIntptrt from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:752)
TESTING: configureIntptrt from PETSc.Configure(config/PETSc/Configure.py:752)
Determine what to use for uintptr_t
Pushing language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 6: warning: variable "i" was declared but never referenced
int x; uintptr_t i = (uintptr_t)&x;;
Source:
#include <stdint.h>
int main() {
return 0;
Defined "UINTPTR_T" to "uintptr_t"
Popping language C
TEST configureSolaris from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:779)
TESTING: configureSolaris from PETSc.Configure(config/PETSc/Configure.py:779)
Solaris specific stuff
TEST configureLinux from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:792)
TESTING: configureLinux from PETSc.Configure(config/PETSc/Configure.py:792)
Linux specific stuff
Defined "HAVE_DOUBLE_ALIGN_MALLOC" to "1"
TEST configureWin32 from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:798)
TESTING: configureWin32 from PETSc.Configure(config/PETSc/Configure.py:798)
Win32 non-cygwin specific stuff
Checking for functions [GetComputerName] in library ['Kernel32.lib'] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c", line 4: catastrophic error: cannot open source file "Windows.h"
#include <Windows.h>
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c".
Source:
static void _check_GetComputerName() { GetComputerName(NULL,NULL);; }
int main() {
_check_GetComputerName();;
return 0;
Popping language C
Checking for functions [GetComputerName] in library ['kernel32'] []
Pushing language C
stderr:
Source:
int main() {
return 0;
Popping language C
Checking for functions [GetUserName] in library ['Advapi32.lib'] []
Pushing language C
stderr:
Source:
static void _check_GetUserName() { GetUserName(NULL,NULL);; }
int main() {
_check_GetUserName();;
return 0;
Popping language C
Checking for functions [GetUserName] in library ['advapi32'] []
Pushing language C
stderr:
Source:
int main() {
return 0;
Popping language C
Checking for functions [GetDC] in library ['User32.lib'] []
Pushing language C
stderr:
Source:
static void _check_GetDC() { GetDC(0);; }
int main() {
_check_GetDC();;
return 0;
Popping language C
Checking for functions [GetDC] in library ['user32'] []
Pushing language C
stderr:
Source:
int main() {
_check_GetDC();;
return 0;
Popping language C
Checking for functions [CreateCompatibleDC] in library ['Gdi32.lib'] []
Pushing language C
stderr:
Source:
static void _check_CreateCompatibleDC() { CreateCompatibleDC(0);; }
int main() {
_check_CreateCompatibleDC();;
return 0;
Popping language C
Checking for functions [CreateCompatibleDC] in library ['gdi32'] []
Pushing language C
stderr:
Source:
int main() {
return 0;
Popping language C
Checking for type: int32_t
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types/conftest.c", line 13: warning: variable "a" was declared but never referenced
int32_t a;;
Source:
#if STDC_HEADERS
#include <stdlib.h>
#include <stddef.h>
#endif
int main() {
int32_t a;;
return 0;
int32_t found
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 6: warning: variable "u" was declared but never referenced
uid_t u;
Source:
int main() {
uid_t u;
return 0;
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 8: warning: variable "a" was declared but never referenced
int a=R_OK;
Source:
#if defined(PETSC_HAVE_UNISTD_H)
#include <unistd.h>
#endif
int main() {
int a=R_OK;
return 0;
Pushing language C
Popping language C
Successful compile:
Source:
#include <sys/stat.h>
int main() {
int a=0;
if (S_ISDIR(a)){}
return 0;
Pushing language C
Popping language C
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure/conftest.c", line 3: catastrophic error: cannot open source file "Windows.h"
Source:
int main() {
LARGE_INTEGER a;
DWORD b=a.u.HighPart;
return 0;
stderr:
Source:
#include <fcntl.h>
int main() {
int flags = O_BINARY;;
return 0;
Defined "PATH_SEPARATOR" to "':'"
Defined "REPLACE_DIR_SEPARATOR" to "'\\'"
Defined "DIR_SEPARATOR" to "'/'"
Defined "DIR" to ""/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3""
TEST configureCygwinBrokenPipe from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:868)
TESTING: configureCygwinBrokenPipe from PETSc.Configure(config/PETSc/Configure.py:868)
Cygwin version <= 1.7.18 had issues with pipes and long commands invoked from gnu-make
http://cygwin.com/ml/cygwin/2013-05/msg00340.html
Executing: uname -s
stdout: Linux
TEST configureDefaultArch from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:884)
TESTING: configureDefaultArch from PETSc.Configure(config/PETSc/Configure.py:884)
TEST configureScript from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:901)
TESTING: configureScript from PETSc.Configure(config/PETSc/Configure.py:901)
Output a script in the conf directory which will reproduce the configuration
TEST configureInstall from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:938)
TESTING: configureInstall from PETSc.Configure(config/PETSc/Configure.py:938)
Setup the directories for installation
Defined make rule "shared_install" with dependencies "" and code ['- at echo "Now to install the libraries do:"', '- at echo "make PETSC_DIR=${PETSC_DIR} PETSC_ARCH=${PETSC_ARCH} install"', '- at echo "========================================="']
TEST configureGCOV from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:950)
TESTING: configureGCOV from PETSc.Configure(config/PETSc/Configure.py:950)
TEST configureFortranFlush from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:955)
TESTING: configureFortranFlush from PETSc.Configure(config/PETSc/Configure.py:955)
Checking for functions [flush_] in library [''] []
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.closure -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.compilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.headers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.cacheDetails -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.atomics -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.functions -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.featureTestMacros -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.utilities.missing -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.MPI -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.pthread -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.options.scalarTypes -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.packages.BlasLapack -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.types -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/PETSc.Configure -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.c
Successful compile:
Source:
char flush_();
static void _check_flush_() { flush_(); }
int main() {
_check_flush_();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest -Xg -O0 -Kopenmp /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-bEGQBD/config.libraries/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language C
Defined "HAVE_FLUSH" to "1"
TEST configureAtoll from PETSc.Configure(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/Configure.py:680)
TESTING: configureAtoll from PETSc.Configure(config/PETSc/Configure.py:680)
Checks if atoll exists
Successful compile:
Source:
#define _POSIX_C_SOURCE 200112L
#include <stdlib.h>
int main() {
long v = atoll("25");
return 0;
Pushing language C
Popping language C
Defined "HAVE_ATOLL" to "1"
Defined make rule "remote" with dependencies "" and code []
Defined make rule "remoteclean" with dependencies "" and code []
Pushing language C
Defined make macro "CC_FLAGS" to "-Xg -O0 -Kopenmp "
Popping language C
Defined make macro "CXX_FLAGS" to "-Xg -O0 -Kopenmp "
Defined make macro "CPP_FLAGS" to ""
Pushing language C
Defined make macro "PCC" to "mpifcc"
Defined make macro "PCC_FLAGS" to "-Xg -O0 -Kopenmp "
Popping language C
Defined make macro "CC_SUFFIX" to "o"
Pushing language C
Defined make macro "PCC_LINKER" to "mpifcc"
Defined make macro "PCC_LINKER_FLAGS" to " -Xg -O0 -Kopenmp"
Popping language C
Defined make macro "CC_LINKER_SUFFIX" to ""
Pushing language FC
Defined "HAVE_FORTRAN" to "1"
Defined make macro "FPP_FLAGS" to ""
Defined make macro "FC_FLAGS" to "-X9 -O0 -Kopenmp "
Popping language FC
Defined make macro "FC_SUFFIX" to "o"
Pushing language FC
Executing: mpifrt -V
Defined make macro "FC_LINKER" to "mpifrt"
Defined make macro "FC_LINKER_FLAGS" to " -X9 -O0 -Kopenmp"
Popping language FC
Defined make macro "FC_MODULE_FLAG" to "-I"
Defined make macro "FC_MODULE_OUTPUT_FLAG" to "-M"
Pushing language C
Defined make macro "SL_LINKER" to "mpifcc"
Defined make macro "SL_LINKER_FLAGS" to "${PCC_LINKER_FLAGS}"
Popping language C
Defined make macro "SL_LINKER_SUFFIX" to ""
Defined "SLSUFFIX" to """"
Defined make macro "SL_LINKER_LIBS" to "${PETSC_EXTERNAL_LIB_BASIC}"
Defined make macro "PETSC_LANGUAGE" to "CONLY"
Defined make macro "PETSC_SCALAR" to "real"
Defined make macro "PETSC_PRECISION" to "double"
Executing: CC -VV
Defined "USE_SOCKET_VIEWER" to "1"
Successful compile:
Source:
#include <sys/socket.h>
int main() {
setsockopt(0,SOL_SOCKET,SO_REUSEADDR,0,0);
return 0;
Defined "HAVE_SO_REUSEADDR" to "1"
Defined "HAVE_HYPRE" to "1"
Defined make macro "HYPRE_LIB" to "-Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++"
Defined make macro "HYPRE_INCLUDE" to "-I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include"
Defined make macro "SCALAPACK_LIB" to "-SCALAPACK"
Defined make macro "SCALAPACK_INCLUDE" to ""
Defined "HAVE_BLASLAPACK" to "1"
Defined make macro "BLASLAPACK_LIB" to "-SSL2"
Defined make macro "BLASLAPACK_INCLUDE" to ""
Defined "HAVE_PTHREAD" to "1"
Defined make macro "PTHREAD_LIB" to ""
Defined make macro "PTHREAD_INCLUDE" to ""
Defined "HAVE_OPENMP" to "1"
Defined make macro "OPENMP_LIB" to ""
Defined make macro "OPENMP_INCLUDE" to ""
Defined "HAVE_SSL" to "1"
Defined make macro "SSL_LIB" to "-lssl -lcrypto"
Defined make macro "SSL_INCLUDE" to ""
Defined "HAVE_MPI" to "1"
Defined make macro "MPI_LIB" to ""
Defined make macro "MPI_INCLUDE" to "-I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu"
Defined make macro "PETSC_WITH_EXTERNAL_LIB" to "-L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/lib -lpetsc -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -SCALAPACK -SSL2 -lssl -lcrypto -ltrtmetcpp -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl "
Defined make macro "PETSC_EXTERNAL_LIB_BASIC" to "-Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -SCALAPACK -SSL2 -lssl -lcrypto -ltrtmetcpp -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl "
Defined make macro "PETSC_CC_INCLUDES" to "-I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/include -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/include -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu"
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Defined make macro "PETSC_FC_INCLUDES" to "-I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/include -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/include -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu"
Defined make macro "DESTDIR" to "/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug"
Defined "LIB_DIR" to ""/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug/lib""
Defined make macro "LIBNAME" to "${INSTALL_LIB_DIR}/libpetsc.${AR_LIB_SUFFIX}"
Defined make macro "SHLIBS" to "libpetsc"
Defined make macro "PETSC_LIB_BASIC" to "-lpetsc"
Defined make macro "PETSC_KSP_LIB_BASIC" to "-lpetsc"
Defined make macro "PETSC_TS_LIB_BASIC" to "-lpetsc"
Defined make macro "PETSC_TAO_LIB_BASIC" to "-lpetsc"
Defined "USE_SINGLE_LIBRARY" to "1"
Defined make macro "PETSC_SYS_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_VEC_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_MAT_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_DM_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_KSP_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_SNES_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_TS_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_TAO_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_CHARACTERISTIC_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_LIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "PETSC_CONTRIB" to "${PETSC_WITH_EXTERNAL_LIB}"
Defined make macro "CONFIGURE_OPTIONS" to "--with-cc=mpifcc --with-cxx=mpiFCC --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS=\"-Xg -O0\" --CXX=mpiFCC --CXXFLAGS=\"-Xg -O0\" --FC=mpifrt --FFLAGS=\"-X9 -O0\" --LD_SHARED= --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0 --with-hypre=1 --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4"
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Skipping cmakeboot due to old python version: (2, 6, 2, 'final', 0)
Pushing language C
Popping language C
Pushing language FC
Popping language FC
**** petsc-3.6.3_patch_debug/lib/petsc/conf/petscvariables ****
FC_DEFINE_FLAG = -D
FAST_AR_FLAGS = Scq
AR_FLAGS = cr
FC_MODULE_OUTPUT_FLAG = -M
PETSC_LANGUAGE = CONLY
FC_LINKER_FLAGS = -X9 -O0 -Kopenmp
LIBNAME = ${INSTALL_LIB_DIR}/libpetsc.${AR_LIB_SUFFIX}
SL_LINKER = mpifcc
CC_FLAGS = -Xg -O0 -Kopenmp
PETSC_LIB = ${PETSC_WITH_EXTERNAL_LIB}
PETSC_PRECISION = double
OPENMP_LIB =
FC_FLAGS = -X9 -O0 -Kopenmp
BLASLAPACK_LIB = -SSL2
PETSC_MAT_LIB = ${PETSC_WITH_EXTERNAL_LIB}
PCC = mpifcc
SL_LINKER_LIBS = ${PETSC_EXTERNAL_LIB_BASIC}
MPI_LIB =
SSL_LIB = -lssl -lcrypto
PETSC_EXTERNAL_LIB_BASIC = -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -SCALAPACK -SSL2 -lssl -lcrypto -ltrtmetcpp -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
SL_LINKER_FLAGS = ${PCC_LINKER_FLAGS}
CC_SUFFIX = o
OPENMP_INCLUDE =
SCALAPACK_INCLUDE =
SHLIBS = libpetsc
CONFIGURE_OPTIONS = --with-cc=mpifcc --with-cxx=mpiFCC --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS=\"-Xg -O0\" --CXX=mpiFCC --CXXFLAGS=\"-Xg -O0\" --FC=mpifrt --FFLAGS=\"-X9 -O0\" --LD_SHARED= --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0 --with-hypre=1 --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
PETSC_CHARACTERISTIC_LIB = ${PETSC_WITH_EXTERNAL_LIB}
PTHREAD_LIB =
PETSC_SCALAR = real
PETSC_FC_INCLUDES = -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/include -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/include -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
CPP_FLAGS =
PETSC_KSP_LIB_BASIC = -lpetsc
FPP_FLAGS =
HYPRE_INCLUDE = -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include
FC_LINKER = mpifrt
HYPRE_LIB = -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++
PETSC_KSP_LIB = ${PETSC_WITH_EXTERNAL_LIB}
CXX_FLAGS = -Xg -O0 -Kopenmp
PETSC_LIB_BASIC = -lpetsc
PCC_LINKER_FLAGS = -Xg -O0 -Kopenmp
SSL_INCLUDE =
PETSC_CONTRIB = ${PETSC_WITH_EXTERNAL_LIB}
PETSC_CC_INCLUDES = -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/include -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/include -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
PCC_LINKER = mpifcc
PETSC_SYS_LIB = ${PETSC_WITH_EXTERNAL_LIB}
PCC_FLAGS = -Xg -O0 -Kopenmp
PTHREAD_INCLUDE =
PETSC_TS_LIB = ${PETSC_WITH_EXTERNAL_LIB}
PETSC_TAO_LIB_BASIC = -lpetsc
BLASLAPACK_INCLUDE =
PETSC_TS_LIB_BASIC = -lpetsc
PETSC_VEC_LIB = ${PETSC_WITH_EXTERNAL_LIB}
CC_LINKER_SUFFIX =
SL_LINKER_SUFFIX =
PETSC_DM_LIB = ${PETSC_WITH_EXTERNAL_LIB}
DESTDIR = /home/hp150306/t00196/lib/petsc-3.6.3_patch_debug
FC_MODULE_FLAG = -I
SCALAPACK_LIB = -SCALAPACK
PETSC_WITH_EXTERNAL_LIB = -L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_patch_debug/lib -lpetsc -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -SCALAPACK -SSL2 -lssl -lcrypto -ltrtmetcpp -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
PETSC_TAO_LIB = ${PETSC_WITH_EXTERNAL_LIB}
MPI_INCLUDE = -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
FC_SUFFIX = o
PETSC_SNES_LIB = ${PETSC_WITH_EXTERNAL_LIB}
SHELL = /bin/sh
GREP = /bin/grep
MV = /bin/mv
PYTHON = /usr/bin/python
MKDIR = /bin/mkdir -p
SEDINPLACE = /bin/sed -i
SED = /bin/sed
DIFF = /usr/bin/diff -w
GZIP = /bin/gzip
RM = /bin/rm -f
CP = /bin/cp
CC_LINKER_SLFLAG = -Wl,-rpath,
CC = mpifcc
RANLIB = /usr/bin/ranlib
DYNAMICLINKER = mpifcc
CXX = mpiFCC
FC = mpifrt
CXXCPP = mpiFCC -E
FC_LINKER_SLFLAG = -Wl,-rpath,
CPP = mpifcc -E
AR_LIB_SUFFIX = a
LD_SHARED = /usr/bin/ar
AR = /usr/bin/ar
DIR = /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
PETSC_INDEX_SIZE = 32
OMAKE = /usr/bin/gmake --no-print-directory
MAKE_IS_GNUMAKE = 1
MAKE_NP = 7
OMAKE_PRINTDIR = /usr/bin/gmake --print-directory
MPIEXEC = mpiexec
PETSC_SCALAR_SIZE = 64
BUILDSHAREDLIB = no
DSYMUTIL = true
TEST_RUNS = C Fortran SSL OPENMP Cxx F90 F90_NoComplex F2003 Fortran_NoComplex C_NoComplex
**** petsc-3.6.3_patch_debug/lib/petsc/conf/petscrules ****
shared_install:
remoteclean:
remote:
libc: ${LIBNAME}(${OBJSC})
libcxx: ${LIBNAME}(${OBJSCXX})
libcu: ${LIBNAME}(${OBJSCU})
libf: ${OBJSF}
-${AR} ${AR_FLAGS} ${LIBNAME} ${OBJSF}
.F.a:
${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<
-${AR} ${AR_FLAGS} ${LIBNAME} $*.o
-${RM} $*.o
.f.o .f90.o .f95.o:
${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<
.f.a:
${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<
-${RM} $*.o
.F.o .F90.o .F95.o:
${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<
shared_arch:
petsc4py-build:
petsc4py-install:
mpi4py-build:
mpi4py-install:
**** petsc-3.6.3_patch_debug/include/petscconf.h ****
#if !defined(INCLUDED_UNKNOWN)
#define INCLUDED_UNKNOWN
#ifndef IS_COLORING_MAX
#define IS_COLORING_MAX 65535
#endif
#ifndef STDC_HEADERS
#define STDC_HEADERS 1
#endif
#ifndef MPIU_COLORING_VALUE
#define MPIU_COLORING_VALUE MPI_UNSIGNED_SHORT
#endif
#ifndef PETSC_UINTPTR_T
#define PETSC_UINTPTR_T uintptr_t
#endif
#ifndef PETSC_HAVE_PTHREAD
#define PETSC_HAVE_PTHREAD 1
#endif
#ifndef PETSC_HAVE_OPENMP
#define PETSC_HAVE_OPENMP 1
#endif
#ifndef PETSC_DEPRECATED
#define PETSC_DEPRECATED(why) __attribute((deprecated))
#endif
#ifndef PETSC_REPLACE_DIR_SEPARATOR
#define PETSC_REPLACE_DIR_SEPARATOR '\\'
#endif
#ifndef PETSC_HAVE_SO_REUSEADDR
#define PETSC_HAVE_SO_REUSEADDR 1
#endif
#ifndef PETSC_HAVE_MPI
#define PETSC_HAVE_MPI 1
#endif
#ifndef PETSC_PREFETCH_HINT_T2
#define PETSC_PREFETCH_HINT_T2 1
#endif
#ifndef PETSC_PREFETCH_HINT_T0
#define PETSC_PREFETCH_HINT_T0 3
#endif
#ifndef PETSC_PREFETCH_HINT_T1
#define PETSC_PREFETCH_HINT_T1 2
#endif
#ifndef PETSC_USE_SOCKET_VIEWER
#define PETSC_USE_SOCKET_VIEWER 1
#endif
#ifndef PETSC_DIR
#define PETSC_DIR "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3"
#endif
#ifndef PETSC_HAVE_SSL
#define PETSC_HAVE_SSL 1
#endif
#ifndef PETSC_HAVE_HYPRE
#define PETSC_HAVE_HYPRE 1
#endif
#ifndef PETSC_LIB_DIR
#define PETSC_LIB_DIR "/home/hp150306/t00196/lib/petsc-3.6.3_patch_debug/lib"
#endif
#ifndef PETSC_HAVE_FORTRAN
#define PETSC_HAVE_FORTRAN 1
#endif
#ifndef PETSC_USE_ISATTY
#define PETSC_USE_ISATTY 1
#endif
#ifndef PETSC_SLSUFFIX
#define PETSC_SLSUFFIX ""
#endif
#ifndef PETSC_FUNCTION_NAME_CXX
#define PETSC_FUNCTION_NAME_CXX __func__
#endif
#ifndef PETSC_HAVE_FLUSH
#define PETSC_HAVE_FLUSH 1
#endif
#ifndef PETSC_HAVE_ATOLL
#define PETSC_HAVE_ATOLL 1
#endif
#ifndef PETSC_HAVE_DOUBLE_ALIGN_MALLOC
#define PETSC_HAVE_DOUBLE_ALIGN_MALLOC 1
#endif
#ifndef PETSC_UNUSED
#define PETSC_UNUSED __attribute((unused))
#endif
#define PETSC_FUNCTION_NAME_C __func__
#endif
#ifndef PETSC_USE_SINGLE_LIBRARY
#define PETSC_USE_SINGLE_LIBRARY 1
#endif
#ifndef PETSC_HAVE_BUILTIN_EXPECT
#define PETSC_HAVE_BUILTIN_EXPECT 1
#endif
#ifndef PETSC_DIR_SEPARATOR
#define PETSC_DIR_SEPARATOR '/'
#endif
#ifndef PETSC_PATH_SEPARATOR
#define PETSC_PATH_SEPARATOR ':'
#endif
#ifndef PETSC_PREFETCH_HINT_NTA
#define PETSC_PREFETCH_HINT_NTA 0
#endif
#ifndef PETSC_Prefetch
#define PETSC_Prefetch(a,b,c) __builtin_prefetch((a),(b),(c))
#endif
#ifndef PETSC_HAVE_BLASLAPACK
#define PETSC_HAVE_BLASLAPACK 1
#endif
#ifndef PETSC_HAVE_GZIP
#define PETSC_HAVE_GZIP 1
#endif
#ifndef PETSC_HAVE_STRING_H
#define PETSC_HAVE_STRING_H 1
#endif
#ifndef PETSC_HAVE_SYS_TYPES_H
#define PETSC_HAVE_SYS_TYPES_H 1
#endif
#ifndef PETSC_HAVE_ENDIAN_H
#define PETSC_HAVE_ENDIAN_H 1
#endif
#ifndef PETSC_HAVE_SYS_PROCFS_H
#define PETSC_HAVE_SYS_PROCFS_H 1
#endif
#ifndef PETSC_HAVE_DLFCN_H
#define PETSC_HAVE_DLFCN_H 1
#endif
#ifndef PETSC_HAVE_SCHED_H
#define PETSC_HAVE_SCHED_H 1
#endif
#ifndef PETSC_HAVE_STDINT_H
#define PETSC_HAVE_STDINT_H 1
#endif
#ifndef PETSC_HAVE_LINUX_KERNEL_H
#define PETSC_HAVE_LINUX_KERNEL_H 1
#endif
#ifndef PETSC_HAVE_TIME_H
#define PETSC_HAVE_TIME_H 1
#endif
#ifndef PETSC_HAVE_MATH_H
#define PETSC_HAVE_MATH_H 1
#endif
#ifndef PETSC_TIME_WITH_SYS_TIME
#define PETSC_TIME_WITH_SYS_TIME 1
#endif
#ifndef PETSC_HAVE_SYS_PARAM_H
#define PETSC_HAVE_SYS_PARAM_H 1
#endif
#ifndef PETSC_HAVE_PTHREAD_H
#define PETSC_HAVE_PTHREAD_H 1
#endif
#ifndef PETSC_HAVE_UNISTD_H
#define PETSC_HAVE_UNISTD_H 1
#endif
#ifndef PETSC_HAVE_STDLIB_H
#define PETSC_HAVE_STDLIB_H 1
#endif
#ifndef PETSC_HAVE_SYS_WAIT_H
#define PETSC_HAVE_SYS_WAIT_H 1
#endif
#ifndef PETSC_HAVE_SETJMP_H
#define PETSC_HAVE_SETJMP_H 1
#endif
#ifndef PETSC_HAVE_LIMITS_H
#define PETSC_HAVE_LIMITS_H 1
#endif
#ifndef PETSC_HAVE_SYS_UTSNAME_H
#define PETSC_HAVE_SYS_UTSNAME_H 1
#endif
#ifndef PETSC_HAVE_NETINET_IN_H
#define PETSC_HAVE_NETINET_IN_H 1
#endif
#ifndef PETSC_HAVE_SYS_SOCKET_H
#define PETSC_HAVE_SYS_SOCKET_H 1
#endif
#ifndef PETSC_HAVE_FLOAT_H
#define PETSC_HAVE_FLOAT_H 1
#endif
#ifndef PETSC_HAVE_SEARCH_H
#define PETSC_HAVE_SEARCH_H 1
#endif
#ifndef PETSC_HAVE_SYS_RESOURCE_H
#define PETSC_HAVE_SYS_RESOURCE_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIMES_H
#define PETSC_HAVE_SYS_TIMES_H 1
#endif
#ifndef PETSC_HAVE_NETDB_H
#define PETSC_HAVE_NETDB_H 1
#endif
#ifndef PETSC_HAVE_MALLOC_H
#define PETSC_HAVE_MALLOC_H 1
#endif
#ifndef PETSC_HAVE_PWD_H
#define PETSC_HAVE_PWD_H 1
#endif
#ifndef PETSC_HAVE_FCNTL_H
#define PETSC_HAVE_FCNTL_H 1
#endif
#ifndef PETSC_HAVE_STRINGS_H
#define PETSC_HAVE_STRINGS_H 1
#endif
#ifndef PETSC_HAVE_SYS_SYSINFO_H
#define PETSC_HAVE_SYS_SYSINFO_H 1
#endif
#ifndef PETSC_HAVE_SYS_TIME_H
#define PETSC_HAVE_SYS_TIME_H 1
#endif
#ifndef PETSC_USING_F90
#define PETSC_USING_F90 1
#endif
#ifndef PETSC_USING_F2003
#define PETSC_USING_F2003 1
#endif
#ifndef PETSC_HAVE_RTLD_NOW
#define PETSC_HAVE_RTLD_NOW 1
#endif
#ifndef PETSC_HAVE_RTLD_LOCAL
#define PETSC_HAVE_RTLD_LOCAL 1
#endif
#ifndef PETSC_HAVE_RTLD_LAZY
#define PETSC_HAVE_RTLD_LAZY 1
#endif
#ifndef PETSC_C_STATIC_INLINE
#define PETSC_C_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_FORTRAN_UNDERSCORE
#define PETSC_HAVE_FORTRAN_UNDERSCORE 1
#endif
#ifndef PETSC_HAVE_CXX_NAMESPACE
#define PETSC_HAVE_CXX_NAMESPACE 1
#endif
#ifndef PETSC_HAVE_RTLD_GLOBAL
#define PETSC_HAVE_RTLD_GLOBAL 1
#endif
#ifndef PETSC_C_RESTRICT
#define PETSC_C_RESTRICT __restrict__
#endif
#ifndef PETSC_CXX_RESTRICT
#define PETSC_CXX_RESTRICT __restrict__
#endif
#ifndef PETSC_CXX_STATIC_INLINE
#define PETSC_CXX_STATIC_INLINE static inline
#endif
#ifndef PETSC_HAVE_F90_2PTR_ARG
#define PETSC_HAVE_F90_2PTR_ARG 1
#endif
#ifndef PETSC_HAVE_LIBZ
#define PETSC_HAVE_LIBZ 1
#endif
#ifndef PETSC_HAVE_LIBDL
#define PETSC_HAVE_LIBDL 1
#endif
#ifndef PETSC_HAVE_LIBSTDC__
#define PETSC_HAVE_LIBSTDC__ 1
#endif
#ifndef PETSC_HAVE_LIBPTHREAD
#define PETSC_HAVE_LIBPTHREAD 1
#endif
#ifndef PETSC_HAVE_LIBCRYPTO
#define PETSC_HAVE_LIBCRYPTO 1
#endif
#ifndef PETSC_HAVE_FENV_H
#define PETSC_HAVE_FENV_H 1
#endif
#ifndef PETSC_HAVE_LIBHYPRE
#define PETSC_HAVE_LIBHYPRE 1
#endif
#ifndef PETSC_HAVE_LOG2
#define PETSC_HAVE_LOG2 1
#endif
#ifndef PETSC_HAVE_LIBSTD_MT
#define PETSC_HAVE_LIBSTD_MT 1
#endif
#ifndef PETSC_HAVE_LIBMPI_CXX
#define PETSC_HAVE_LIBMPI_CXX 1
#endif
#ifndef PETSC_HAVE_ERF
#define PETSC_HAVE_ERF 1
#endif
#ifndef PETSC_HAVE_LIBSSL
#define PETSC_HAVE_LIBSSL 1
#endif
#ifndef PETSC_HAVE_LIBTRTMETCPP
#define PETSC_HAVE_LIBTRTMETCPP 1
#endif
#ifndef PETSC_HAVE_TGAMMA
#define PETSC_HAVE_TGAMMA 1
#endif
#ifndef PETSC_HAVE_LIBFJDEMGL
#define PETSC_HAVE_LIBFJDEMGL 1
#endif
#ifndef PETSC_ARCH
#define PETSC_ARCH "petsc-3.6.3_patch_debug"
#endif
#ifndef PETSC_CLANGUAGE_C
#define PETSC_CLANGUAGE_C 1
#endif
#ifndef PETSC_USE_ERRORCHECKING
#define PETSC_USE_ERRORCHECKING 1
#endif
#ifndef PETSC_WORDS_BIGENDIAN
#define PETSC_WORDS_BIGENDIAN 1
#endif
#ifndef PETSC_BITS_PER_BYTE
#define PETSC_BITS_PER_BYTE 8
#endif
#ifndef PETSC_SIZEOF_MPI_FINT
#define PETSC_SIZEOF_MPI_FINT 4
#endif
#ifndef PETSC_SIZEOF_VOID_P
#define PETSC_SIZEOF_VOID_P 8
#endif
#ifndef PETSC_RETSIGTYPE
#define PETSC_RETSIGTYPE void
#endif
#ifndef PETSC_HAVE_CXX_COMPLEX
#define PETSC_HAVE_CXX_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_LONG
#define PETSC_SIZEOF_LONG 8
#endif
#ifndef PETSC_USE_FORTRANKIND
#define PETSC_USE_FORTRANKIND 1
#endif
#ifndef PETSC_SIZEOF_SIZE_T
#define PETSC_SIZEOF_SIZE_T 8
#endif
#ifndef PETSC_HAVE_SIGINFO_T
#define PETSC_HAVE_SIGINFO_T 1
#endif
#ifndef PETSC_SIZEOF_CHAR
#define PETSC_SIZEOF_CHAR 1
#endif
#ifndef PETSC_SIZEOF_DOUBLE
#define PETSC_SIZEOF_DOUBLE 8
#endif
#ifndef PETSC_SIZEOF_FLOAT
#define PETSC_SIZEOF_FLOAT 4
#endif
#ifndef PETSC_HAVE_C99_COMPLEX
#define PETSC_HAVE_C99_COMPLEX 1
#endif
#ifndef PETSC_SIZEOF_INT
#define PETSC_SIZEOF_INT 4
#endif
#ifndef PETSC_SIZEOF_LONG_LONG
#define PETSC_SIZEOF_LONG_LONG 8
#endif
#ifndef PETSC_SIZEOF_MPI_COMM
#define PETSC_SIZEOF_MPI_COMM 8
#endif
#ifndef PETSC_SIZEOF_SHORT
#define PETSC_SIZEOF_SHORT 2
#endif
#ifndef PETSC_HAVE_STRCASECMP
#define PETSC_HAVE_STRCASECMP 1
#endif
#ifndef PETSC_HAVE_GET_NPROCS
#define PETSC_HAVE_GET_NPROCS 1
#endif
#ifndef PETSC_HAVE_POPEN
#define PETSC_HAVE_POPEN 1
#endif
#ifndef PETSC_HAVE_SIGSET
#define PETSC_HAVE_SIGSET 1
#endif
#ifndef PETSC_HAVE_GETWD
#define PETSC_HAVE_GETWD 1
#endif
#ifndef PETSC_HAVE_VSNPRINTF
#define PETSC_HAVE_VSNPRINTF 1
#endif
#ifndef PETSC_HAVE_TIMES
#define PETSC_HAVE_TIMES 1
#endif
#ifndef PETSC_HAVE_DLSYM
#define PETSC_HAVE_DLSYM 1
#endif
#ifndef PETSC_HAVE_SNPRINTF
#define PETSC_HAVE_SNPRINTF 1
#endif
#ifndef PETSC_HAVE_GETHOSTBYNAME
#define PETSC_HAVE_GETHOSTBYNAME 1
#endif
#ifndef PETSC_HAVE_GETCWD
#define PETSC_HAVE_GETCWD 1
#endif
#ifndef PETSC_HAVE_DLERROR
#define PETSC_HAVE_DLERROR 1
#endif
#ifndef PETSC_HAVE_FORK
#define PETSC_HAVE_FORK 1
#endif
#ifndef PETSC_HAVE_RAND
#define PETSC_HAVE_RAND 1
#endif
#ifndef PETSC_HAVE_GETTIMEOFDAY
#define PETSC_HAVE_GETTIMEOFDAY 1
#endif
#ifndef PETSC_HAVE_DLCLOSE
#define PETSC_HAVE_DLCLOSE 1
#endif
#ifndef PETSC_HAVE_UNAME
#define PETSC_HAVE_UNAME 1
#endif
#ifndef PETSC_HAVE_GETHOSTNAME
#define PETSC_HAVE_GETHOSTNAME 1
#endif
#ifndef PETSC_HAVE_MKSTEMP
#define PETSC_HAVE_MKSTEMP 1
#endif
#ifndef PETSC_HAVE_SIGACTION
#define PETSC_HAVE_SIGACTION 1
#endif
#ifndef PETSC_HAVE_DRAND48
#define PETSC_HAVE_DRAND48 1
#endif
#ifndef PETSC_HAVE_MEMALIGN
#define PETSC_HAVE_MEMALIGN 1
#endif
#ifndef PETSC_HAVE_VA_COPY
#define PETSC_HAVE_VA_COPY 1
#endif
#ifndef PETSC_HAVE_CLOCK
#define PETSC_HAVE_CLOCK 1
#endif
#ifndef PETSC_HAVE_ACCESS
#define PETSC_HAVE_ACCESS 1
#endif
#ifndef PETSC_HAVE_SIGNAL
#define PETSC_HAVE_SIGNAL 1
#endif
#ifndef PETSC_HAVE_USLEEP
#define PETSC_HAVE_USLEEP 1
#endif
#ifndef PETSC_HAVE_GETRUSAGE
#define PETSC_HAVE_GETRUSAGE 1
#endif
#ifndef PETSC_HAVE_VFPRINTF
#define PETSC_HAVE_VFPRINTF 1
#endif
#ifndef PETSC_HAVE_NANOSLEEP
#define PETSC_HAVE_NANOSLEEP 1
#endif
#ifndef PETSC_HAVE_GETDOMAINNAME
#define PETSC_HAVE_GETDOMAINNAME 1
#endif
#define PETSC_HAVE_TIME 1
#endif
#ifndef PETSC_HAVE_LSEEK
#define PETSC_HAVE_LSEEK 1
#endif
#ifndef PETSC_HAVE_SOCKET
#define PETSC_HAVE_SOCKET 1
#endif
#ifndef PETSC_HAVE_SYSINFO
#define PETSC_HAVE_SYSINFO 1
#endif
#ifndef PETSC_HAVE_READLINK
#define PETSC_HAVE_READLINK 1
#endif
#ifndef PETSC_HAVE_REALPATH
#define PETSC_HAVE_REALPATH 1
#endif
#ifndef PETSC_HAVE_DLOPEN
#define PETSC_HAVE_DLOPEN 1
#endif
#ifndef PETSC_HAVE_MEMMOVE
#define PETSC_HAVE_MEMMOVE 1
#endif
#ifndef PETSC_SIGNAL_CAST
#define PETSC_SIGNAL_CAST
#endif
#ifndef PETSC_HAVE_SLEEP
#define PETSC_HAVE_SLEEP 1
#endif
#ifndef PETSC_HAVE_VPRINTF
#define PETSC_HAVE_VPRINTF 1
#endif
#ifndef PETSC_HAVE_BZERO
#define PETSC_HAVE_BZERO 1
#endif
#ifndef PETSC_HAVE_GETPAGESIZE
#define PETSC_HAVE_GETPAGESIZE 1
#endif
#ifndef PETSC_CPU_RELAX
#define PETSC_CPU_RELAX() __asm__ __volatile__ ("":::"memory")
#endif
#ifndef PETSC_BLASLAPACK_UNDERSCORE
#define PETSC_BLASLAPACK_UNDERSCORE 1
#endif
#ifndef PETSC_HAVE_MPI_F90MODULE
#define PETSC_HAVE_MPI_F90MODULE 1
#endif
#ifndef PETSC_HAVE_MPI_IALLREDUCE
#define PETSC_HAVE_MPI_IALLREDUCE 1
#endif
#ifndef PETSC_HAVE_OMPI_MINOR_VERSION
#define PETSC_HAVE_OMPI_MINOR_VERSION 6
#endif
#ifndef PETSC_HAVE_MPI_IN_PLACE
#define PETSC_HAVE_MPI_IN_PLACE 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_C2F
#define PETSC_HAVE_MPI_COMM_C2F 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_CONTIGUOUS
#define PETSC_HAVE_MPI_COMBINER_CONTIGUOUS 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_EXTENT
#define PETSC_HAVE_MPI_TYPE_GET_EXTENT 1
#endif
#ifndef PETSC_HAVE_MPI_WIN_CREATE
#define PETSC_HAVE_MPI_WIN_CREATE 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_DUP
#define PETSC_HAVE_MPI_TYPE_DUP 1
#endif
#ifndef PETSC_HAVE_MPI_INIT_THREAD
#define PETSC_HAVE_MPI_INIT_THREAD 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_F2C
#define PETSC_HAVE_MPI_COMM_F2C 1
#endif
#ifndef PETSC_HAVE_MPI_TYPE_GET_ENVELOPE
#define PETSC_HAVE_MPI_TYPE_GET_ENVELOPE 1
#endif
#ifndef PETSC_HAVE_MPI_ALLTOALLW
#define PETSC_HAVE_MPI_ALLTOALLW 1
#endif
#ifndef PETSC_HAVE_OMPI_MAJOR_VERSION
#define PETSC_HAVE_OMPI_MAJOR_VERSION 1
#endif
#ifndef PETSC_HAVE_MPIIO
#define PETSC_HAVE_MPIIO 1
#endif
#ifndef PETSC_HAVE_MPI_COMM_SPAWN
#define PETSC_HAVE_MPI_COMM_SPAWN 1
#endif
#ifndef PETSC_HAVE_MPI_FINT
#define PETSC_HAVE_MPI_FINT 1
#endif
#ifndef PETSC_HAVE_MPI_IBARRIER
#define PETSC_HAVE_MPI_IBARRIER 1
#endif
#ifndef PETSC_HAVE_MPI_FINALIZED
#define PETSC_HAVE_MPI_FINALIZED 1
#endif
#ifndef PETSC_HAVE_OMPI_RELEASE_VERSION
#define PETSC_HAVE_OMPI_RELEASE_VERSION 3
#endif
#ifndef PETSC_HAVE_MPI_REPLACE
#define PETSC_HAVE_MPI_REPLACE 1
#endif
#ifndef PETSC_HAVE_MPI_EXSCAN
#define PETSC_HAVE_MPI_EXSCAN 1
#endif
#ifndef PETSC_HAVE_MPI_COMBINER_DUP
#define PETSC_HAVE_MPI_COMBINER_DUP 1
#endif
#ifndef PETSC_USE_INFO
#define PETSC_USE_INFO 1
#endif
#ifndef PETSC_Alignx
#define PETSC_Alignx(a,b)
#endif
#ifndef PETSC_USE_BACKWARD_LOOP
#define PETSC_USE_BACKWARD_LOOP 1
#endif
#ifndef PETSC_USE_DEBUG
#define PETSC_USE_DEBUG 1
#endif
#ifndef PETSC_IS_COLOR_VALUE_TYPE_SIZE
#define PETSC_IS_COLOR_VALUE_TYPE_SIZE PETSC_SIZEOF_SHORT
#endif
#ifndef PETSC_USE_LOG
#define PETSC_USE_LOG 1
#endif
#define PETSC_IS_COLOR_VALUE_TYPE short
#endif
#ifndef PETSC_USE_CTABLE
#define PETSC_USE_CTABLE 1
#endif
#ifndef PETSC_MEMALIGN
#define PETSC_MEMALIGN 16
#endif
#ifndef PETSC_USE_FORTRAN_INTERFACES
#define PETSC_USE_FORTRAN_INTERFACES 1
#endif
#ifndef PETSC_USE_SCALAR_REAL
#define PETSC_USE_SCALAR_REAL 1
#endif
#ifndef PETSC_HAVE_ISINF
#define PETSC_HAVE_ISINF 1
#endif
#ifndef PETSC_HAVE_ISNAN
#define PETSC_HAVE_ISNAN 1
#endif
#ifndef PETSC_USE_REAL_DOUBLE
#define PETSC_USE_REAL_DOUBLE 1
#endif
#ifndef PETSC_HAVE_DYNAMIC_LIBRARIES
#define PETSC_HAVE_DYNAMIC_LIBRARIES 1
#endif
#ifndef PETSC_HAVE_SHARED_LIBRARIES
#define PETSC_HAVE_SHARED_LIBRARIES 1
#endif
#ifndef PETSC__GNU_SOURCE
#define PETSC__GNU_SOURCE 1
#endif
#ifndef PETSC__BSD_SOURCE
#define PETSC__BSD_SOURCE 1
#endif
#ifndef PETSC__DEFAULT_SOURCE
#define PETSC__DEFAULT_SOURCE 1
#endif
#ifndef PETSC_LEVEL1_DCACHE_LINESIZE
#define PETSC_LEVEL1_DCACHE_LINESIZE 32
#endif
#ifndef PETSC_LEVEL1_DCACHE_SIZE
#define PETSC_LEVEL1_DCACHE_SIZE 32768
#endif
#ifndef PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT
#define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
#endif
#ifndef PETSC_USE_PROC_FOR_SIZE
#define PETSC_USE_PROC_FOR_SIZE 1
#endif
#ifndef PETSC_HAVE_SCHED_CPU_SET_T
#define PETSC_HAVE_SCHED_CPU_SET_T 1
#endif
#ifndef PETSC_HAVE_PTHREAD_BARRIER_T
#define PETSC_HAVE_PTHREAD_BARRIER_T 1
#endif
#ifndef PETSC_HAVE_SYS_SYSCTL_H
#define PETSC_HAVE_SYS_SYSCTL_H 1
#endif
#endif
**** petsc-3.6.3_patch_debug/include/petscfix.h ****
#if defined(__cplusplus)
extern "C" {
#else
#endif
#endif
Configure Actions
These are the actions performed by configure on the filesystem
PETSc:
Build : Set default architecture to petsc-3.6.3_patch_debug in lib/petsc/conf/petscvariables
File creation : Created petsc-3.6.3_patch_debug/lib/petsc/conf/reconfigure-petsc-3.6.3_patch_debug.py for automatic reconfiguration
Framework:
File creation : Created makefile configure header petsc-3.6.3_patch_debug/lib/petsc/conf/petscvariables
File creation : Created makefile configure header petsc-3.6.3_patch_debug/lib/petsc/conf/petscrules
File creation : Created configure header petsc-3.6.3_patch_debug/include/petscconf.h
File creation : Created C specific configure header petsc-3.6.3_patch_debug/include/petscfix.h
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Compilers:
C Compiler: mpifcc -Xg -O0 -Kopenmp
C++ Compiler: mpiFCC -Xg -O0 -Kopenmp
Fortran Compiler: mpifrt -X9 -O0 -Kopenmp
Linkers:
Static linker: /usr/bin/ar cr
Dynamic linker: mpifcc -shared -Xg -O0 -Kopenmp
make:
BLAS/LAPACK: -SSL2
MPI:
Includes: -I/opt/FJSVtclang/GM-1.2.0-20/include/mpi/fujitsu
pthread:
hypre:
Includes: -I/home/hp150306/t00196/lib/hypre-2.10.0b-p4/include
Library: -Wl,-rpath,/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -L/home/hp150306/t00196/lib/hypre-2.10.0b-p4/lib -lHYPRE -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++
openmp:
scalapack:
Library: -SCALAPACK
Arch:
ssl:
Library: -lssl -lcrypto
PETSc:
PETSC_ARCH: petsc-3.6.3_patch_debug
PETSC_DIR: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Clanguage: C
Integer size: 32
Memory alignment: 16
Scalar type: real
Precision: double
shared libraries: disabled
xxx=========================================================================xxx
Configure stage complete. Now build PETSc libraries with (gnumake build):
make PETSC_DIR=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 PETSC_ARCH=petsc-3.6.3_patch_debug all
Finishing Configure Run at Thu Jun 2 10:43:37 2016
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language FC
Popping language FC
Starting Configure Run at Thu May 26 15:51:50 2016
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc=mpifcc --with-cxx=mpiFCC --with-fc=mpifrt --with-64-bit-pointers=1 --CC=mpifcc --CFLAGS="-Xg -O0" --CXX=mpiFCC --CXXFLAGS="-Xg -O0" --FC=mpifrt --FFLAGS="-X9 -O0" --LD_SHARED= --LDDFLAGS= --with-openmp=1 --with-mpiexec=mpiexec --known-endian=big --with-shared-libraries=0 --with-blas-lapack-lib=-SSL2 --with-scalapack-lib=-SCALAPACK --prefix=/home/hp150306/t00196/lib/petsc-3.6.3_debug --with-fortran-interfaces=1 --with-debugging=1 --useThreads=0 --with-hypre=1 --with-hypre-dir=/home/hp150306/t00196/lib/hypre-2.10.0b-p4
Working directory: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Machine platform:
('Linux', 'o05-037', '2.6.25.8', '#1 SMP Wed Jan 6 11:32:25 JST 2016', 's64fx', 's64fx')
Python version:
2.6.2 (r262:71600, Dec 20 2011, 15:18:11)
[GCC 4.2.4]
Pushing language C
Popping language C
Pushing language FC
Popping language FC
TEST configureExternalPackagesDir from config.framework(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/framework.py:832)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:832)
TEST configureDebuggers from config.utilities.debuggers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
Find a default debugger and determine its arguments
Checking for program /opt/FJSVtclang/check/gdb...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/gdb...not found
Checking for program /opt/kusu/bin/gdb...not found
Checking for program /opt/kusu/sbin/gdb...not found
Checking for program /usr/pgsql-9.0/bin/gdb...not found
Checking for program /usr/local/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /home/hp150306/t00196/bin/gdb...not found
Checking for program /home/hp150306/t00196/shortcut/gdb...not found
Checking for program /opt/FJSVxosmmm/sbin/gdb...not found
Checking for program /home/hp150306/t00196/gdb...not found
Checking for program /opt/FJSVtclang/check/dbx...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/dbx...not found
Checking for program /opt/kusu/bin/dbx...not found
Checking for program /opt/kusu/sbin/dbx...not found
Checking for program /usr/pgsql-9.0/bin/dbx...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /home/hp150306/t00196/bin/dbx...not found
Checking for program /home/hp150306/t00196/shortcut/dbx...not found
Checking for program /opt/FJSVxosmmm/sbin/dbx...not found
Checking for program /home/hp150306/t00196/dbx...not found
Checking for program /opt/FJSVtclang/check/xdb...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/xdb...not found
Checking for program /opt/kusu/bin/xdb...not found
Checking for program /opt/kusu/sbin/xdb...not found
Checking for program /usr/pgsql-9.0/bin/xdb...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /home/hp150306/t00196/bin/xdb...not found
Checking for program /home/hp150306/t00196/shortcut/xdb...not found
Checking for program /opt/FJSVxosmmm/sbin/xdb...not found
Checking for program /home/hp150306/t00196/xdb...not found
Checking for program /opt/FJSVtclang/check/dsymutil...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/dsymutil...not found
Checking for program /opt/kusu/bin/dsymutil...not found
Checking for program /opt/kusu/sbin/dsymutil...not found
Checking for program /usr/pgsql-9.0/bin/dsymutil...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...not found
Checking for program /home/hp150306/t00196/bin/dsymutil...not found
Checking for program /home/hp150306/t00196/shortcut/dsymutil...not found
Checking for program /opt/FJSVxosmmm/sbin/dsymutil...not found
Checking for program /home/hp150306/t00196/dsymutil...not found
Defined make macro "DSYMUTIL" to "true"
TEST configureGit from config.sourceControl(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
Find the Git executable
Checking for program /opt/FJSVtclang/check/git...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/git...not found
Checking for program /opt/kusu/bin/git...not found
Checking for program /opt/kusu/sbin/git...not found
Checking for program /usr/pgsql-9.0/bin/git...not found
Checking for program /usr/local/bin/git...not found
Checking for program /bin/git...not found
Checking for program /usr/bin/git...not found
Checking for program /home/hp150306/t00196/bin/git...not found
Checking for program /home/hp150306/t00196/shortcut/git...not found
Checking for program /opt/FJSVxosmmm/sbin/git...not found
Checking for program /home/hp150306/t00196/git...not found
TEST configureCLanguage from PETSc.options.languages(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
Choose whether to compile the PETSc library using a C or C++ compiler
C language is C
Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
Checks PETSC_DIR and sets if not set
Version Information:
#define PETSC_VERSION_RELEASE 1
#define PETSC_VERSION_MAJOR 3
#define PETSC_VERSION_MINOR 6
#define PETSC_VERSION_SUBMINOR 3
#define PETSC_VERSION_PATCH 0
#define PETSC_VERSION_DATE "Dec, 03, 2015"
#define PETSC_VERSION_GIT "v3.6.2-37-g6fc57b5"
#define PETSC_VERSION_DATE_GIT "2015-12-03 23:02:05 -0600"
#define PETSC_VERSION_(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
#define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
Defined make macro "DIR" to "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3"
TEST getDatafilespath from PETSc.options.dataFilesPath(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/arch.py:25)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:25)
Checks PETSC_ARCH and sets if not set
Defined "ARCH" to ""petsc-3.6.3_debug""
TEST setInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:74)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:74)
TEST cleanInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:67)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:67)
TEST configureInstallDir from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:51)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:51)
Makes installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
Changed persistence directory to /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-3.6.3_debug/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/installDir.py:87)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:87)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1538)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1538)
**** printenv ****
Timezone_ntp_server1=10.0.160.15
Timezone_ntp_server2=10.0.160.1
DEPOT_REPOS_ROOT=/depot/repos
NII_PARENTIPS=10.231.4.65;10.0.4.95
PJM_O_WORKDIR=/volume2/home/hp150306/t00196/source/petsc-3.6.3
NII_PGID=
DEPOT_AUTOINST_ROOT=/depot/repos/instconf
InstallerServeNFS=1
CFMBaseDir=/opt/kusu/cfm
OMPI_CKPTCONFIG=0x00
PJM_O_SHELL=/bin/bash
MANPATH=:/opt/kusu/man
Timezone_utc=0
Timezone_zone=Asia/Tokyo
KUSU_TMP=/tmp
root_password_auth=off
PYTHONPATH=/opt/primitive/lib64/python2.6/site-packages:/opt/primitive/lib/python2.6/site-packages:/opt/primitive/lib64/python2.4/site-packages:/opt/primitive/lib/python2.4/site-packages:/opt/kusu/lib64/python:/opt/kusu/lib/python:
KUSU_ROOT=/opt/kusu
PublicDNSZone=k
NII_PEERIP=0
DEPOT_DOCS_ROOT=/depot/www/kits
NII_HAGROUP=,
InstNum=
TUNING_XINET_MAX_CLIENTS=100
PIXIE_ROOT=/tftpboot/kusu
Keyboard=jp106
NII_PARENTIP=10.224.0.128
PJM_JOBID=5203527
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:bd=40;33;01:cd=40;33;01:or=01;05;37;41:mi=01;05;37;41:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.bz=00;31:*.tz=00;31:*.rpm=00;31:*.cpio=00;31:*.jpg=00;35:*.gif=00;35:*.bmp=00;35:*.xbm=00;35:*.xpm=00;35:*.png=00;35:*.tif=00;35:
Env_base=K-1.2.0-20-1
DB_POOLER_MAX_CLIENTS=32768
snmp_trap_receivers=
NII_NGTYPE=compute-diskless
PJM_DPREFIX=#PJM
LMGRD_PATH=
PJM_O_PATH=/usr/lib64/qt-3.3/bin:/opt/local/openssh/bin:/opt/FJSVtclang/check:/opt/FJSVtclang/GM-1.2.0-20/bin:/opt/FJSVtclang/1.2.0/util/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/bin/SU/bin:/opt/local/gfarm/bin:/opt/local/Python-2.7.3/bin:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut
SYSLOG_SERVER=disabled
passwordless_root_on_compute=on
SHLVL=1
NII_NICDEF0=tofu0|10.231.4.97|255.224.0.0|10.224.0.0|-tofu0|10.255.255.254|0||02:00:10:08:02:c3|provision
PETSC_ARCH=petsc-3.6.3_debug
KUSU_LOGFILE=/var/log/kusu/kusu.log
NII_NID=10970
CFM_SERVICE=multicast
MODULESHOME=/usr/share/Modules
KUSU_MAXLOGNUM=10
NII_INSTALLERS=10.224.0.128
PRIMITIVE_ROOT=/opt/primitive
DEPOT_CONTRIB_ROOT=/depot/contrib
MULTICAST_ADDR=239.0.0.98
NII_HOSTNAME=o05-037
PrimaryInstaller=cs01p03
MASTER_UUID=KUSU
NII_BOOTNIC=tofu0
TMPDIR=./
MODULEPATH=/usr/share/Modules/modulefiles:/etc/modulefiles:
NII_NFSROOTSERVER=10.224.0.128
NII_BOOTIP=10.231.4.97
dns1=127.0.0.1
InstallerServeDNS=1
FJPNCKPT_CONFIG=0x00
KUSUSNMPD_LOG_SIZE=5000
KUSU_MAXLOGSIZE=10485760
PROVISION=KUSU
InstallerServeDHCP=1
ssh_port=22
TUNING_ENABLED=1
LM_LICENSE_FILE=
PJM_JOBNAME=STDIN
LD_LIBRARY_PATH=/opt/FJSVpxtof/sparc64fx/lib64:/opt/FJSVtclang/GM-1.2.0-20/lib64:/opt/FJSVpnavi/sparc64fx/lib64:/opt/FJSVXosSclib/lib64
Timezone_ntp_server=10.0.160.14
KUSU_DIST_ARCH=s64fx
G_BROKEN_FILENAMES=1
_=./configure
DEPOT_REPOS_SCRIPTS=/depot/repos/custom_scripts
NII_REPO=/repos/1002
TOFU_HOME=/opt/FJSVpxtof/sparc64fx
Language=en_US
KusuAuthScheme=files
PGBOUNCER_LOG_SIZE=100
KUSU_DHCP_TIMEOUT=120
InstallerServeNTP=1
NII_OSTYPE=xtcos-1.3-sparc64fx
PJM_O_HOST=fe01p04
KUSU_DB_ENGINE=postgres
NII_REPOID=1002
KUSU_LOGLEVEL=DEBUG
NII_INSTALLTYPE=diskless
NII_SNMPD=10.224.0.128
NII_NGID=18
KUSU_HEARTBEAT_INTERFACE=bond0
PJM_JOBDIR=/volume2/home/hp150306/t00196/source/petsc-3.6.3
DEPOT_REPOS_POST=/depot/repos/post_scripts
DB_POOLER_POOL_SIZE=50000
ssh_old_port=22
NII_DBSERVERPORT=6432
DB_POOLER_PORT=6432
PJM_O_LOGNAME=t00196
PATH=/opt/FJSVtclang/check:/opt/FJSVtclang/GM-1.2.0-20/bin:/opt/kusu/bin:/opt/kusu/sbin:/usr/pgsql-9.0/bin:/usr/local/bin:/bin:/usr/bin:/home/hp150306/t00196/bin:/home/hp150306/t00196/shortcut:/opt/FJSVxosmmm/sbin
PJM_ENVIRONMENT=INTERACT
NII_DBSERVERIP=10.0.160.20
TERM=xterm
KUSU_INSTALLER_GW=10.1.161.254
DNSZone=k
PRESERVE_NODE_IP=1
PJM_O_HOME=/home/hp150306/t00196
CFM_PROTOCOL=broadcast
NII_NFSROOTOPTS=rw,hard,intr,nolock,async,dev,exec,suid
DEPOT_UPDATES_ROOT=/depot/updates
NII_EXTRAID=k-comp_0x03100035
MPI_HOME=/opt/FJSVtclang/GM-1.2.0-20
InstallerServeNIS=0
TUNING_TFTP_MAX_CLIENTS=100
DEPOT_IMAGES_ROOT=/depot/images
KUSU_EVENT_LOGFILE=/var/log/kusu/kusu-events.log
DB_POOLER_ENABLED=1
TUNING_SSH_MAX_CLIENTS=200
NII_NFSROOTPATH=/export/nfsroot/o05-037
LOADEDMODULES=
DEPOT_KITS_ROOT=/depot/kits
PJM_O_MAIL=/var/spool/mail/t00196
KUSU_VERSION=2.1
PWD=/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
PJM_O_LANG=en_US.UTF-8
TEST resetEnvCompilers from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1545)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1545)
TEST checkEnvCompilers from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1575)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1575)
TEST checkMPICompilerOverride from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1510)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1510)
Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1529)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1529)
OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:402)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:402)
Determine the compiler vendor
Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:412)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:412)
Initialize the compiler and linker flags
Pushing language C
Initialized CFLAGS to -Xg -O0
Initialized LDFLAGS to
Popping language C
Initialized CUDAFLAGS to
Pushing language Cxx
Initialized CXXFLAGS to -Xg -O0
Initialized CXX_CXXFLAGS to
Popping language Cxx
Pushing language FC
Initialized FFLAGS to -X9 -O0
Popping language FC
Initialized CPPFLAGS to
Initialized CUDAPPFLAGS to
Initialized CXXCPPFLAGS to
Initialized CC_LINKER_FLAGS to []
Initialized CXX_LINKER_FLAGS to []
Initialized FC_LINKER_FLAGS to []
Initialized CUDAC_LINKER_FLAGS to []
Initialized sharedLibraryFlags to []
Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:538)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:538)
Locate a functional C compiler
Checking for program /opt/FJSVtclang/check/mpifcc...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpifcc...found
Defined make macro "CC" to "mpifcc"
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest
Popping language C
TEST checkCPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:571)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:571)
Locate a functional C preprocessor
Defined make macro "CPP" to "mpifcc -E"
Pushing language C
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/c99.pre"
#pragma unknown_control_flow(_setjmp)
#pragma unknown_control_flow(__setjmp)
#pragma unknown_control_flow(__sigsetjmp)
#pragma unknown_control_flow(vfork)
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c"
#line 1 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 1 "/usr/include/features.h"
#line 115 "/usr/include/features.h"
#line 138 "/usr/include/features.h"
#line 147 "/usr/include/features.h"
#line 169 "/usr/include/features.h"
#line 179 "/usr/include/features.h"
#line 208 "/usr/include/features.h"
#line 247 "/usr/include/features.h"
#line 299 "/usr/include/features.h"
#line 331 "/usr/include/features.h"
#line 1 "/usr/include/sys/cdefs.h"
#line 60 "/usr/include/sys/cdefs.h"
#line 96 "/usr/include/sys/cdefs.h"
#line 111 "/usr/include/sys/cdefs.h"
#line 121 "/usr/include/sys/cdefs.h"
#line 149 "/usr/include/sys/cdefs.h"
#line 166 "/usr/include/sys/cdefs.h"
#line 198 "/usr/include/sys/cdefs.h"
#line 234 "/usr/include/sys/cdefs.h"
#line 264 "/usr/include/sys/cdefs.h"
#line 287 "/usr/include/sys/cdefs.h"
#line 318 "/usr/include/sys/cdefs.h"
#line 328 "/usr/include/sys/cdefs.h"
#line 359 "/usr/include/sys/cdefs.h"
#line 1 "/usr/include/bits/wordsize.h"
#line 361 "/usr/include/sys/cdefs.h"
#line 393 "/usr/include/sys/cdefs.h"
#line 336 "/usr/include/features.h"
#line 1 "/usr/include/gnu/stubs.h"
#line 5 "/usr/include/gnu/stubs.h"
#line 1 "/usr/include/gnu/stubs-64.h"
#line 10 "/usr/include/gnu/stubs.h"
#line 360 "/usr/include/features.h"
#line 50 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 26 "/usr/include/stdlib.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef unsigned long size_t;
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
typedef int wchar_t;
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 34 "/usr/include/stdlib.h"
#line 95 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
extern size_t __ctype_get_mb_cur_max (void) ;
extern double atof (const char *__nptr)
extern int atoi (const char *__nptr)
extern long int atol (const char *__nptr)
extern long long int atoll (const char *__nptr)
extern double strtod (const char * __nptr,
char ** __endptr)
extern float strtof (const char * __nptr,
char ** __endptr) ;
extern long double strtold (const char * __nptr,
char ** __endptr)
extern long int strtol (const char * __nptr,
char ** __endptr, int __base)
extern unsigned long int strtoul (const char * __nptr,
extern long long int strtoq (const char * __nptr,
extern unsigned long long int strtouq (const char * __nptr,
extern long long int strtoll (const char * __nptr,
extern unsigned long long int strtoull (const char * __nptr,
#line 274 "/usr/include/stdlib.h"
#line 305 "/usr/include/stdlib.h"
extern char *l64a (long int __n) ;
extern long int a64l (const char *__s)
#line 1 "/usr/include/sys/types.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 28 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/types.h"
#line 28 "/usr/include/bits/types.h"
#line 29 "/usr/include/bits/types.h"
typedef unsigned char __u_char;
typedef unsigned short int __u_short;
typedef unsigned int __u_int;
typedef unsigned long int __u_long;
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef signed short int __int16_t;
typedef unsigned short int __uint16_t;
typedef signed int __int32_t;
typedef unsigned int __uint32_t;
typedef signed long int __int64_t;
typedef unsigned long int __uint64_t;
typedef long int __quad_t;
typedef unsigned long int __u_quad_t;
#line 68 "/usr/include/bits/types.h"
#line 126 "/usr/include/bits/types.h"
#line 1 "/usr/include/bits/typesizes.h"
#line 61 "/usr/include/bits/typesizes.h"
#line 132 "/usr/include/bits/types.h"
typedef unsigned long int __dev_t;
typedef unsigned int __uid_t;
typedef unsigned int __gid_t;
typedef unsigned long int __ino_t;
typedef unsigned long int __ino64_t;
typedef unsigned int __mode_t;
typedef unsigned int __nlink_t;
typedef long int __off_t;
typedef long int __off64_t;
typedef int __pid_t;
typedef struct { int __val[2]; } __fsid_t;
typedef long int __clock_t;
typedef unsigned long int __rlim_t;
typedef unsigned long int __rlim64_t;
typedef unsigned int __id_t;
typedef long int __time_t;
typedef unsigned int __useconds_t;
typedef int __suseconds_t;
typedef int __daddr_t;
typedef long int __swblk_t;
typedef int __key_t;
typedef int __clockid_t;
typedef void * __timer_t;
typedef long int __blksize_t;
typedef long int __blkcnt_t;
typedef long int __blkcnt64_t;
typedef unsigned long int __fsblkcnt_t;
typedef unsigned long int __fsblkcnt64_t;
typedef unsigned long int __fsfilcnt_t;
typedef unsigned long int __fsfilcnt64_t;
typedef long int __ssize_t;
typedef __off64_t __loff_t;
typedef __quad_t *__qaddr_t;
typedef char *__caddr_t;
typedef long int __intptr_t;
typedef unsigned int __socklen_t;
#line 32 "/usr/include/sys/types.h"
typedef __u_char u_char;
typedef __u_short u_short;
typedef __u_int u_int;
typedef __u_long u_long;
typedef __quad_t quad_t;
typedef __u_quad_t u_quad_t;
typedef __fsid_t fsid_t;
typedef __loff_t loff_t;
typedef __ino_t ino_t;
#line 60 "/usr/include/sys/types.h"
typedef __dev_t dev_t;
typedef __gid_t gid_t;
typedef __mode_t mode_t;
typedef __nlink_t nlink_t;
typedef __uid_t uid_t;
typedef __off_t off_t;
#line 98 "/usr/include/sys/types.h"
typedef __pid_t pid_t;
typedef __id_t id_t;
typedef __ssize_t ssize_t;
typedef __daddr_t daddr_t;
typedef __caddr_t caddr_t;
typedef __key_t key_t;
#line 1 "/usr/include/time.h"
#line 34 "/usr/include/time.h"
#line 53 "/usr/include/time.h"
#line 69 "/usr/include/time.h"
typedef __time_t time_t;
typedef __clockid_t clockid_t;
typedef __timer_t timer_t;
#line 129 "/usr/include/time.h"
#line 419 "/usr/include/time.h"
#line 134 "/usr/include/sys/types.h"
#line 145 "/usr/include/sys/types.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/stddef.h"
#line 148 "/usr/include/sys/types.h"
typedef unsigned long int ulong;
typedef unsigned short int ushort;
typedef unsigned int uint;
typedef char int8_t;
typedef short int int16_t;
typedef int int32_t;
typedef long int int64_t;
typedef unsigned char u_int8_t;
typedef unsigned short int u_int16_t;
typedef unsigned int u_int32_t;
typedef unsigned long int u_int64_t;
typedef int register_t;
#line 213 "/usr/include/sys/types.h"
#line 1 "/usr/include/endian.h"
#line 23 "/usr/include/endian.h"
#line 1 "/usr/include/bits/endian.h"
#line 38 "/usr/include/endian.h"
#line 51 "/usr/include/endian.h"
#line 218 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/select.h"
#line 26 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/select.h"
#line 32 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/sigset.h"
typedef int __sig_atomic_t;
typedef struct
unsigned long int __val[(1024 / (8 * sizeof (unsigned long int)))];
} __sigset_t;
#line 35 "/usr/include/sys/select.h"
typedef __sigset_t sigset_t;
#line 85 "/usr/include/time.h"
#line 97 "/usr/include/time.h"
#line 109 "/usr/include/time.h"
struct timespec
__time_t tv_sec;
long int tv_nsec;
#line 45 "/usr/include/sys/select.h"
#line 1 "/usr/include/bits/time.h"
#line 60 "/usr/include/bits/time.h"
struct timeval
__time_t tv_sec;
__suseconds_t tv_usec;
#line 47 "/usr/include/sys/select.h"
typedef __suseconds_t suseconds_t;
typedef long int __fd_mask;
typedef struct
__fd_mask __fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
typedef __fd_mask fd_mask;
extern int select (int __nfds, fd_set * __readfds,
fd_set * __writefds,
fd_set * __exceptfds,
struct timeval * __timeout);
extern int pselect (int __nfds, fd_set * __readfds,
const struct timespec * __timeout,
const __sigset_t * __sigmask);
#line 221 "/usr/include/sys/types.h"
#line 1 "/usr/include/sys/sysmacros.h"
#line 25 "/usr/include/sys/sysmacros.h"
extern unsigned int gnu_dev_major (unsigned long long int __dev)
extern unsigned int gnu_dev_minor (unsigned long long int __dev)
extern unsigned long long int gnu_dev_makedev (unsigned int __major,
unsigned int __minor)
#line 62 "/usr/include/sys/sysmacros.h"
#line 224 "/usr/include/sys/types.h"
typedef __blkcnt_t blkcnt_t;
typedef __fsblkcnt_t fsblkcnt_t;
typedef __fsfilcnt_t fsfilcnt_t;
#line 260 "/usr/include/sys/types.h"
#line 1 "/usr/include/bits/pthreadtypes.h"
#line 25 "/usr/include/bits/pthreadtypes.h"
#line 47 "/usr/include/bits/pthreadtypes.h"
typedef unsigned long int pthread_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
typedef struct __pthread_internal_list
struct __pthread_internal_list *__prev;
struct __pthread_internal_list *__next;
} __pthread_list_t;
#line 73 "/usr/include/bits/pthreadtypes.h"
typedef union
struct __pthread_mutex_s
int __lock;
unsigned int __count;
int __owner;
unsigned int __nusers;
int __kind;
int __spins;
__pthread_list_t __list;
#line 102 "/usr/include/bits/pthreadtypes.h"
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
} pthread_mutexattr_t;
typedef union
struct
int __lock;
unsigned int __futex;
unsigned long long int __total_seq;
unsigned long long int __wakeup_seq;
unsigned long long int __woken_seq;
void *__mutex;
unsigned int __nwaiters;
unsigned int __broadcast_seq;
} __data;
char __size[48];
long long int __align;
} pthread_cond_t;
typedef union
char __size[4];
int __align;
} pthread_condattr_t;
typedef unsigned int pthread_key_t;
typedef int pthread_once_t;
typedef union
struct
int __lock;
unsigned int __nr_readers;
unsigned int __readers_wakeup;
unsigned int __writer_wakeup;
unsigned int __nr_readers_queued;
unsigned int __nr_writers_queued;
int __writer;
int __shared;
unsigned long int __pad1;
unsigned long int __pad2;
unsigned int __flags;
} __data;
#line 188 "/usr/include/bits/pthreadtypes.h"
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
} pthread_rwlockattr_t;
typedef volatile int pthread_spinlock_t;
typedef union
char __size[32];
long int __align;
} pthread_barrier_t;
typedef union
char __size[4];
int __align;
} pthread_barrierattr_t;
#line 271 "/usr/include/sys/types.h"
#line 321 "/usr/include/stdlib.h"
extern long int random (void) ;
extern void srandom (unsigned int __seed) ;
extern char *initstate (unsigned int __seed, char *__statebuf,
size_t __statelen) ;
extern char *setstate (char *__statebuf) ;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
extern int random_r (struct random_data * __buf,
int32_t * __result) ;
extern int srandom_r (unsigned int __seed, struct random_data *__buf)
extern int initstate_r (unsigned int __seed, char * __statebuf,
size_t __statelen,
struct random_data * __buf)
extern int setstate_r (char * __statebuf,
extern int rand (void) ;
extern void srand (unsigned int __seed) ;
extern int rand_r (unsigned int *__seed) ;
extern double drand48 (void) ;
extern double erand48 (unsigned short int __xsubi[3]) ;
extern long int lrand48 (void) ;
extern long int nrand48 (unsigned short int __xsubi[3])
extern long int mrand48 (void) ;
extern long int jrand48 (unsigned short int __xsubi[3])
extern void srand48 (long int __seedval) ;
extern unsigned short int *seed48 (unsigned short int __seed16v[3])
extern void lcong48 (unsigned short int __param[7]) ;
struct drand48_data
unsigned short int __x[3];
unsigned short int __old_x[3];
unsigned short int __c;
unsigned short int __init;
unsigned long long int __a;
extern int drand48_r (struct drand48_data * __buffer,
double * __result) ;
extern int erand48_r (unsigned short int __xsubi[3],
extern int lrand48_r (struct drand48_data * __buffer,
long int * __result)
extern int nrand48_r (unsigned short int __xsubi[3],
extern int mrand48_r (struct drand48_data * __buffer,
extern int jrand48_r (unsigned short int __xsubi[3],
extern int srand48_r (long int __seedval, struct drand48_data *__buffer)
extern int seed48_r (unsigned short int __seed16v[3],
struct drand48_data *__buffer) ;
extern int lcong48_r (unsigned short int __param[7],
extern void *malloc (size_t __size) ;
extern void *calloc (size_t __nmemb, size_t __size)
extern void *realloc (void *__ptr, size_t __size)
extern void free (void *__ptr) ;
extern void cfree (void *__ptr) ;
#line 1 "/usr/include/alloca.h"
#line 23 "/usr/include/alloca.h"
#line 26 "/usr/include/alloca.h"
extern void *alloca (size_t __size) ;
#line 498 "/usr/include/stdlib.h"
extern void *valloc (size_t __size) ;
extern int posix_memalign (void **__memptr, size_t __alignment, size_t __size)
extern void abort (void) ;
extern int atexit (void (*__func) (void)) ;
extern int on_exit (void (*__func) (int __status, void *__arg), void *__arg)
extern void exit (int __status) ;
extern void _Exit (int __status) ;
extern char *getenv (const char *__name) ;
extern char *__secure_getenv (const char *__name)
extern int putenv (char *__string) ;
extern int setenv (const char *__name, const char *__value, int __replace)
extern int unsetenv (const char *__name) ;
extern int clearenv (void) ;
extern char *mktemp (char *__template) ;
extern int mkstemp (char *__template) ;
#line 607 "/usr/include/stdlib.h"
extern char *mkdtemp (char *__template) ;
#line 638 "/usr/include/stdlib.h"
extern int system (const char *__command) ;
#line 655 "/usr/include/stdlib.h"
extern char *realpath (const char * __name,
char * __resolved) ;
typedef int (*__compar_fn_t) (const void *, const void *);
extern void *bsearch (const void *__key, const void *__base,
size_t __nmemb, size_t __size, __compar_fn_t __compar)
extern void qsort (void *__base, size_t __nmemb, size_t __size,
__compar_fn_t __compar) ;
extern int abs (int __x) ;
extern long int labs (long int __x) ;
extern long long int llabs (long long int __x)
extern div_t div (int __numer, int __denom)
extern ldiv_t ldiv (long int __numer, long int __denom)
extern lldiv_t lldiv (long long int __numer,
long long int __denom)
extern char *ecvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *fcvt (double __value, int __ndigit, int * __decpt,
int * __sign) ;
extern char *gcvt (double __value, int __ndigit, char *__buf)
extern char *qecvt (long double __value, int __ndigit,
int * __decpt, int * __sign)
extern char *qfcvt (long double __value, int __ndigit,
extern char *qgcvt (long double __value, int __ndigit, char *__buf)
extern int ecvt_r (double __value, int __ndigit, int * __decpt,
int * __sign, char * __buf,
size_t __len) ;
extern int fcvt_r (double __value, int __ndigit, int * __decpt,
size_t __len) ;
extern int qecvt_r (long double __value, int __ndigit,
int * __decpt, int * __sign,
char * __buf, size_t __len)
extern int qfcvt_r (long double __value, int __ndigit,
extern int mblen (const char *__s, size_t __n) ;
extern int mbtowc (wchar_t * __pwc,
const char * __s, size_t __n) ;
extern int wctomb (char *__s, wchar_t __wchar) ;
extern size_t mbstowcs (wchar_t * __pwcs,
extern size_t wcstombs (char * __s,
const wchar_t * __pwcs, size_t __n)
extern int rpmatch (const char *__response) ;
#line 820 "/usr/include/stdlib.h"
extern int posix_openpt (int __oflag) ;
#line 851 "/usr/include/stdlib.h"
#line 862 "/usr/include/stdlib.h"
extern int getloadavg (double __loadavg[], int __nelem)
#line 879 "/usr/include/stdlib.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
Popping language C
TEST checkCUDACompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:612)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:612)
Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:652)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:652)
Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:764)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:764)
Locate a functional Cxx compiler
Checking for program /opt/FJSVtclang/check/mpiFCC...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpiFCC...found
Defined make macro "CXX" to "mpiFCC"
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
TEST checkCxxPreprocessor from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:802)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:802)
Locate a functional Cxx preprocessor
Defined make macro "CXXCPP" to "mpiFCC -E"
Executing: mpiFCC -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/FCC.pre"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc"
extern "C" {
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_prolog.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 33 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/features.h"
#line 161 "/usr/include/sys/cdefs.h"
#line 354 "/usr/include/sys/cdefs.h"
#line 59 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_stlport_version.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl_user_config.h"
#line 74 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 90 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 28 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 49 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat.h"
#line 95 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_site_config.h"
#line 30 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_site_config.h"
#line 99 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 18 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 28 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_fujitsu.h"
#line 53 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 128 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stlcomp.h"
#line 102 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_confix.h"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/config/stl_confix.h"
#line 111 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 121 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 185 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 196 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 262 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 276 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 297 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 305 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 313 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 321 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 338 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 351 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 372 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 417 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 468 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 496 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 507 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 517 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 542 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 556 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 565 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace std { }
namespace __std_alias = std;
#line 623 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 643 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 688 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace stlp_priv {
using namespace std;
#line 713 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
namespace stlport = std;
namespace _STL = std;
#line 758 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 784 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 817 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 857 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 871 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 890 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 921 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 936 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 957 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 994 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1022 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1035 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1060 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1091 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1104 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1114 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1148 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1197 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1219 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 1237 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config.h"
#line 19 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_prolog.h"
#line 25 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 25 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 35 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 24 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 42 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 54 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 64 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 72 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/../stddef.h"
#line 38 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
#line 52 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stddef.h"
extern "C" {
#line 1 "/usr/include/bits/waitflags.h"
#line 43 "/usr/include/stdlib.h"
#line 1 "/usr/include/bits/waitstatus.h"
#line 66 "/usr/include/bits/waitstatus.h"
union wait
int w_status;
struct
#line 79 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_retcode:8;
unsigned int __w_coredump:1;
unsigned int __w_termsig:7;
} __wait_terminated;
struct
#line 93 "/usr/include/bits/waitstatus.h"
unsigned int:16;
unsigned int __w_stopsig:8;
unsigned int __w_stopval:8;
} __wait_stopped;
#line 44 "/usr/include/stdlib.h"
#line 57 "/usr/include/stdlib.h"
#line 75 "/usr/include/stdlib.h"
#line 83 "/usr/include/stdlib.h"
typedef struct
int quot;
int rem;
} div_t;
typedef struct
long int quot;
long int rem;
} ldiv_t;
typedef struct
long long int quot;
long long int rem;
} lldiv_t;
char ** __endptr)
char ** __endptr) ;
char ** __endptr)
extern "C" {
#line 57 "/usr/include/sys/types.h"
typedef __ino64_t ino64_t;
#line 95 "/usr/include/sys/types.h"
typedef __off64_t off64_t;
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
#line 22 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
typedef __clock_t clock_t;
#line 30 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/time.h"
typedef __useconds_t useconds_t;
typedef struct
} __sigset_t;
struct timespec
__time_t tv_sec;
long int tv_nsec;
struct timeval
__time_t tv_sec;
typedef struct
__fd_mask fds_bits[1024 / (8 * sizeof (__fd_mask))];
} fd_set;
extern "C" {
typedef __blksize_t blksize_t;
typedef __blkcnt64_t blkcnt64_t;
typedef __fsblkcnt64_t fsblkcnt64_t;
typedef __fsfilcnt64_t fsfilcnt64_t;
typedef union
char __size[56];
long int __align;
} pthread_attr_t;
} __pthread_list_t;
typedef union
int __lock;
int __owner;
int __kind;
int __spins;
} __data;
char __size[40];
long int __align;
} pthread_mutex_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
void *__mutex;
} __data;
char __size[48];
} pthread_cond_t;
typedef union
char __size[4];
int __align;
typedef union
struct
int __lock;
int __writer;
int __shared;
} __data;
char __size[56];
long int __align;
} pthread_rwlock_t;
typedef union
char __size[8];
long int __align;
typedef union
char __size[32];
long int __align;
typedef union
char __size[4];
int __align;
struct random_data
int32_t *fptr;
int32_t *rptr;
int32_t *state;
int rand_type;
int rand_deg;
int rand_sep;
int32_t *end_ptr;
size_t __statelen,
struct drand48_data
extern "C" {
#line 604 "/usr/include/stdlib.h"
extern int mkstemp64 (char *__template) ;
int * __sign) ;
int * __sign) ;
size_t __len) ;
size_t __len) ;
extern int getsubopt (char ** __optionp,
char *const * __tokens,
char ** __valuep)
extern void setkey (const char *__key) ;
extern int grantpt (int __fd) ;
extern int unlockpt (int __fd) ;
extern char *ptsname (int __fd) ;
#line 31 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 47 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
namespace std {
using ::div_t;
using ::ldiv_t;
using ::size_t;
using ::abs;
using ::div;
using ::abort;
using ::getenv;
using ::mblen;
using ::mbtowc;
using ::system;
using ::bsearch;
using ::atexit;
using ::exit;
using ::calloc;
using ::free;
using ::malloc;
using ::realloc;
using ::atof;
using ::atoi;
using ::atol;
using ::mbstowcs;
using ::strtod;
using ::strtol;
using ::strtoul;
using ::wcstombs;
using ::wctomb;
using ::qsort;
using ::labs;
using ::ldiv;
using ::llabs;
using ::lldiv_t;
using ::lldiv;
#line 103 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
using ::rand;
using ::srand;
#line 116 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
namespace std {
inline long abs(long __x) { return ::labs(__x); }
inline ldiv_t div(long __x, long __y) { return ::ldiv(__x, __y); }
#line 166 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 1 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 27 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 53 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_config_compat_post.h"
#line 20 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 41 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/stl/_epilog.h"
#line 170 "//opt/FJSVtclang/GM-1.2.0-20/bin/../include/c++/std/cstdlib"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc"
TEST checkFortranCompiler from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:919)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:919)
Locate a functional Fortran compiler
Checking for program /opt/FJSVtclang/check/mpifrt...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/mpifrt...found
Defined make macro "FC" to "mpifrt"
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Popping language FC
TEST checkFortranComments from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:940)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:940)
Make sure fortran comment "!" works
Pushing language FC
Successful compile:
Source:
! comment
program main
end
Fortran comments can use ! in column 1
Popping language FC
TEST checkPIC from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1003)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1003)
Determine the PIC option for each compiler
- There needs to be a test that checks that the functionality is actually working
Skip checking PIC options on user request
TEST checkLargeFileIO from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1036)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1036)
TEST checkArchiver from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1135)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1135)
Check that the archiver exists and can make a library usable by the compiler
Pushing language C
Executing: ar -V
stdout:
GNU ar 2.17
Copyright 2005 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License. This program has absolutely no warranty.
Executing: ar -V
stdout:
GNU ar 2.17
Defined make macro "FAST_AR_FLAGS" to "Scq"
Successful compile:
Source:
int foo(int a) {
return a+1;
Checking for program /opt/FJSVtclang/check/ar...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/ar...not found
Checking for program /opt/kusu/bin/ar...not found
Checking for program /opt/kusu/sbin/ar...not found
Checking for program /usr/pgsql-9.0/bin/ar...not found
Checking for program /usr/local/bin/ar...not found
Checking for program /bin/ar...not found
Checking for program /usr/bin/ar...found
Defined make macro "AR" to "/usr/bin/ar"
Checking for program /opt/FJSVtclang/check/ranlib...not found
Checking for program /opt/FJSVtclang/GM-1.2.0-20/bin/ranlib...not found
Checking for program /opt/kusu/bin/ranlib...not found
Checking for program /opt/kusu/sbin/ranlib...not found
Checking for program /usr/pgsql-9.0/bin/ranlib...not found
Checking for program /usr/local/bin/ranlib...not found
Checking for program /bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconf1.a /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: '-c': No such file
Ranlib is not functional with your archiver. Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
GNU ar 2.17
Executing: ar -V
stdout:
GNU ar 2.17
Successful compile:
Source:
int foo(int a) {
return a+1;
Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconf1.a
Successful compile:
Source:
extern int foo(int);
int main() {
int b = foo(1); if (b);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -lconf1
Defined make macro "AR_FLAGS" to "cr"
Defined make macro "AR_LIB_SUFFIX" to "a"
Popping language C
TEST checkSharedLinker from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1246)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1246)
Check that the linker can produce shared libraries
Pushing language C
Popping language C
Pushing language FC
Popping language FC
Checking shared linker /usr/bin/ar using flags []
Defined make macro "LD_SHARED" to "/usr/bin/ar"
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("hello");
return 0;}
Pushing language C
Popping language C
Executing: /usr/bin/ar cr /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconftest.a /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o ; /usr/bin/ranlib /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconftest.a
Successful compile:
Source:
int foo(void);
int main() {
int ret = foo();
if(ret);;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -L/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -lconftest
Using shared linker /usr/bin/ar with flags [] and library extension a
Executing: uname -s
stdout: Linux
TEST checkSharedLinkerPaths from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1324)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1324)
Determine the shared linker path options
- IRIX: -rpath
- Linux, OSF: -Wl,-rpath,
- Solaris: -R
- FreeBSD: -Wl,-R,
Pushing language C
Executing: uname -s
stdout: Linux
Executing: mpifcc -V
Trying C linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Valid C linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Popping language C
Executing: uname -s
stdout: Linux
Trying Cxx linker flag -Wl,-rpath,
Successful compile:
Source:
int main() {
return 0;
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Valid Cxx linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Pushing language FC
Executing: uname -s
stdout: Linux
Trying FC linker flag -Wl,-rpath,
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3 -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o
Valid FC linker flag -Wl,-rpath,/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3
Popping language FC
TEST checkLibC from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1359)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1359)
Test whether we need to explicitly include libc in shared linking
- Mac OSX requires an explicit reference to libc for shared linking
TEST checkDynamicLinker from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1408)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1408)
Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers
Executing: mpifcc -E -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conftest.c
stdout:
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/confdefs.h"
#line 2 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conftest.c"
#line 1 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conffix.h"
#line 3 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conftest.c"
#line 1 "/usr/include/dlfcn.h"
#line 25 "/usr/include/dlfcn.h"
#line 27 "/usr/include/dlfcn.h"
#line 1 "/usr/include/bits/dlfcn.h"
#line 30 "/usr/include/dlfcn.h"
#line 52 "/usr/include/dlfcn.h"
extern void *dlopen (const char *__file, int __mode) ;
extern int dlclose (void *__handle) ;
extern void *dlsym (void * __handle,
const char * __name) ;
#line 80 "/usr/include/dlfcn.h"
extern char *dlerror (void) ;
#line 188 "/usr/include/dlfcn.h"
#line 4 "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.headers/conftest.c"
Defined "HAVE_DLFCN_H" to "1"
Checking for functions [dlopen dlsym dlclose] in library ['dl'] []
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries/conftest.c
Successful compile:
Source:
/* Override any gcc2 internal prototype to avoid an error. */
char dlopen();
static void _check_dlopen() { dlopen(); }
char dlsym();
static void _check_dlsym() { dlsym(); }
char dlclose();
static void _check_dlclose() { dlclose(); }
int main() {
_check_dlopen();
_check_dlsym();
_check_dlclose();;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries/conftest.o -ldl
Defined "HAVE_LIBDL" to "1"
Popping language C
Adding ['dl'] to LIBS
Executing: uname -s
stdout: Linux
Checking dynamic linker /usr/bin/ar using flags []
Defined make macro "DYNAMICLINKER" to "/usr/bin/ar"
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
#include <stdio.h>
int foo(void) {printf("test");return 0;}
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language FC
Popping language FC
Pushing language C
Popping language C
Executing: /usr/bin/ar -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconftest.so /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ldl
stderr:
/usr/bin/ar: no operation specified
Checking dynamic linker mpifcc using flags ['-shared']
Defined make macro "DYNAMICLINKER" to "mpifcc"
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -shared -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ldl
Valid C linker flag -shared
Successful compile:
Source:
#include <stdio.h>
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconftest.so -shared -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ldl
Successful compile:
Source:
#include<dlfcn.h>
int main() {
void *handle = dlopen("/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/libconftest.so", 0);
int (*foo)(void) = (int (*)(void)) dlsym(handle, "foo");
if (!foo) {
printf("Could not load symbol\n");
return -1;
if ((*foo)()) {
printf("Invalid return from foo()\n");
return -1;
if (dlclose(handle)) {
printf("Could not close library\n");
return -1;
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ldl
Using dynamic linker mpifcc with flags ['-shared'] and library extension so
TEST output from config.setCompilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/setCompilers.py:1454)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1454)
Output module data as defines and substitutions
Substituting "CC" with "mpifcc"
Substituting "CFLAGS" with "-Xg -O0"
Defined make macro "CC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "CPP" with "mpifcc -E"
Substituting "CPPFLAGS" with ""
Substituting "CXX" with "mpiFCC"
Substituting "CXX_CXXFLAGS" with ""
Substituting "CXXFLAGS" with "-Xg -O0"
Substituting "CXX_LINKER_SLFLAG" with "-Wl,-rpath,"
Substituting "CXXCPP" with "mpiFCC -E"
Substituting "CXXCPPFLAGS" with ""
Substituting "FC" with "mpifrt"
Substituting "FFLAGS" with "-X9 -O0"
Defined make macro "FC_LINKER_SLFLAG" to "-Wl,-rpath,"
Substituting "LDFLAGS" with ""
Substituting "LIBS" with "-ldl "
Substituting "SHARED_LIBRARY_FLAG" with ""
Executing: uname -s
stdout: Linux
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
Checks whether shared libraries should be used, for which you must
- Specify --with-shared-libraries
- Have found a working shared linker
Defines PETSC_USE_SHARED_LIBRARIES if they are used
Defined make rule "shared_arch" with dependencies "" and code []
Defined make macro "BUILDSHAREDLIB" to "no"
Defined "HAVE_SHARED_LIBRARIES" to "1"
Shared libraries - disabled
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:96)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:96)
Checks whether dynamic loading is available (with dlfcn.h and libdl)
Defined "HAVE_DYNAMIC_LIBRARIES" to "1"
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/sharedLibraries.py:102)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:102)
Defines PETSC_SERIALIZE_FUNCTIONS if they are used
Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilerFlags.py:71)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:71)
Get the default compiler flags
Pushing language C
Executing: mpifcc --version
Ignoring default options which were overridden using --CFLAGS -Xg -O0
Optimization options found in CFLAGS. Skipping setting defaults
Popping language C
Executing: mpiFCC --version
Ignoring default options which were overridden using --CXXFLAGS -Xg -O0
Optimization options found in CXXFLAGS. Skipping setting defaults
Pushing language FC
Executing: mpifrt --version
Ignoring default options which were overridden using --FFLAGS -X9 -O0
Optimization options found in FFLAGS. Skipping setting defaults
Popping language FC
TEST configureDebugging from PETSc.options.debugging(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
Defined "USE_ERRORCHECKING" to "1"
Executing: mpifcc --help
TEST checkRestrict from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:137)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:137)
Check for the C/CXX restrict keyword
Pushing language C
All intermediate test results are stored in /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.c
Possible ERROR while running compiler: exit code 512
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.c", line 5: error: expected a ";"
float * restrict x;;
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.c", line 5: warning: variable "restrict" was declared but never referenced
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.c".
Source:
int main() {
return 0;
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.c", line 5: warning: variable "x" was declared but never referenced
float * __restrict__ x;;
Source:
int main() {
return 0;
compilers: Set C restrict keyword to __restrict__
Defined "C_RESTRICT" to " __restrict__"
Popping language C
TEST checkCFormatting from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:310)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:310)
Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:108)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:108)
Check for C keyword: static inline
Pushing language C
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
return 0;
compilers: Set C StaticInline keyword to static inline
Popping language C
Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:321)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:321)
Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LAZY);
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ldl
Defined "HAVE_RTLD_LAZY" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_NOW);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_NOW" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_LOCAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_LOCAL" to "1"
Successful compile:
Source:
#include <dlfcn.h>
char *libname;
int main() {
dlopen(libname, RTLD_GLOBAL);
return 0;
Pushing language C
Popping language C
Defined "HAVE_RTLD_GLOBAL" to "1"
TEST checkCLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:164)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:164)
Determines the libraries needed to link with C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest -### -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ldl
stdout:
/usr/bin/ld --eh-frame-hdr -m elf64_sparc -YP,/usr/lib64 -dynamic-linker /lib64/ld-linux.so.2 /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4 -u__metInit -ltrtmet -ltrtmet_c -Qy -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lm -lnsl -lutil //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64 -u_xfdb_Init -ltrtfdb -lfjrtcl -ltrtth -L/usr/lib64 -lmpg -lmpgpthread -lpapi -lrt -lelf -ldl -lgcc_s -lgcc -lc -lgcc_s -lgcc -lc /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o -L/opt/FJSVxosmmm/lib64 /usr/lib64/crtn.o
//opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2 -ir-strip /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest
Popping language C
compilers: Checking arg /usr/bin/ld
compilers: Unknown arg /usr/bin/ld
compilers: Checking arg --eh-frame-hdr
compilers: Unknown arg --eh-frame-hdr
compilers: Checking arg -m
compilers: Unknown arg -m
compilers: Checking arg elf64_sparc
compilers: Unknown arg elf64_sparc
compilers: Checking arg -YP,/usr/lib64
compilers: Unknown arg -YP,/usr/lib64
compilers: Checking arg -dynamic-linker
compilers: Unknown arg -dynamic-linker
compilers: Checking arg /lib64/ld-linux.so.2
compilers: Unknown arg /lib64/ld-linux.so.2
compilers: Checking arg /usr/lib64/crt1.o
compilers: Unknown arg /usr/lib64/crt1.o
compilers: Checking arg /usr/lib64/crti.o
compilers: Unknown arg /usr/lib64/crti.o
compilers: Checking arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o
compilers: Unknown arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o
compilers: Checking arg -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4
compilers: Unknown arg -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4
compilers: Checking arg -u__metInit
compilers: Unknown arg -u__metInit
compilers: Checking arg -ltrtmet
compilers: Found library : -ltrtmet
compilers: Checking arg -ltrtmet_c
compilers: Found library : -ltrtmet_c
compilers: Checking arg -Qy
compilers: Unknown arg -Qy
compilers: Checking arg -o
compilers: Unknown arg -o
compilers: Checking arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest
compilers: Unknown arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest
compilers: Checking arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o
compilers: Unknown arg /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o
compilers: Checking arg -ldl
compilers: Found library : -ldl
compilers: Checking arg -L/opt/FJSVpxtof/sparc64fx/lib64
compilers: Found library directory: -L/opt/FJSVpxtof/sparc64fx/lib64
compilers: Checking arg -L/opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Found library directory: -L/opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Checking arg -lmpi
compilers: Found library : -lmpi
compilers: Checking arg -ltofucom
compilers: Found library : -ltofucom
compilers: Checking arg -ltofutop
compilers: Found library : -ltofutop
compilers: Checking arg -lnsl
compilers: Found library : -lnsl
compilers: Checking arg -lutil
compilers: Found library : -lutil
compilers: Checking arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o
compilers: Unknown arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o
compilers: Checking arg -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds
compilers: Unknown arg -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds
compilers: Checking arg -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64
compilers: Found library directory: -L//opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Checking arg -u_xfdb_Init
compilers: Unknown arg -u_xfdb_Init
compilers: Checking arg -ltrtfdb
compilers: Found library : -ltrtfdb
compilers: Checking arg -lfjrtcl
compilers: Found library : -lfjrtcl
compilers: Checking arg -ltrtth
compilers: Found library : -ltrtth
compilers: Checking arg -L/usr/lib64
compilers: Checking arg -lmpg
compilers: Found library : -lmpg
compilers: Checking arg -lmpgpthread
compilers: Found library : -lmpgpthread
compilers: Checking arg -lpapi
compilers: Found library : -lpapi
compilers: Checking arg -lrt
compilers: Found library : -lrt
compilers: Checking arg -lelf
compilers: Found library : -lelf
compilers: Checking arg -lgcc_s
compilers: Found library : -lgcc_s
compilers: Skipping system library: -lgcc
compilers: Checking arg -lc
compilers: Skipping system library: -lc
compilers: Checking arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o
compilers: Unknown arg /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o
compilers: Checking arg -L/opt/FJSVxosmmm/lib64
compilers: Found library directory: -L/opt/FJSVxosmmm/lib64
compilers: Checking arg /usr/lib64/crtn.o
compilers: Unknown arg /usr/lib64/crtn.o
compilers: Checking arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2
compilers: Unknown arg //opt/FJSVtclang/GM-1.2.0-20/bin/../lib/aopt2
compilers: Checking arg -ir-strip
compilers: Unknown arg -ir-strip
compilers: Libraries needed to link C code with another linker: ['-ltrtmet', '-ltrtmet_c', '-ldl', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-lmpi', '-ltofucom', '-ltofutop', '-lnsl', '-lutil', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-ltrtfdb', '-lfjrtcl', '-ltrtth', '-lmpg', '-lmpgpthread', '-lpapi', '-lrt', '-lelf', '-lgcc_s', '-L/opt/FJSVxosmmm/lib64']
compilers: Check that C libraries can be used from Fortran
Pushing language FC
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
/usr/bin/ld: cannot find -lpetsc-ufod4vtr9mqHvKIQiVAm
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Testing executable /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest to see if it can be run
Executing: /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest
Popping language FC
TEST checkDependencyGenerationFlag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1328)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1328)
Check if -MMD works for dependency generation, and add it if it does
Pushing language C
Trying C compiler flag -MMD -MP
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Rejected C compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying C compiler flag -xMMD
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying C compiler flag -qmakedep=gcc
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
stderr:
fcc: warning: -qmakedep=gcc is unrecognized option. This option is passed to the linker.
Source:
int main() {
return 0;
Rejecting compiler flag -qmakedep=gcc due to
Rejected C compiler flag -qmakedep=gcc
Trying C compiler flag -MD
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
return 0;
Rejected C compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Popping language C
Pushing language Cxx
Trying Cxx compiler flag -MMD -MP
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying Cxx compiler flag -xMMD
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying Cxx compiler flag -qmakedep=gcc
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
stderr:
FCC: warning: -qmakedep=gcc is unrecognized option. This option is passed to the linker.
Source:
int main() {
return 0;
Rejected Cxx compiler flag -qmakedep=gcc
Trying Cxx compiler flag -MD
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -Xg -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Successful compile:
Source:
int main() {
return 0;
Rejected Cxx compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Popping language Cxx
Pushing language FC
Trying FC compiler flag -MMD -MP
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 -MMD -MP /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MMD -MP because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 -MMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -xMMD
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 -xMMD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -xMMD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -qmakedep=gcc
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 -qmakedep=gcc /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
stderr:
frt: warning: -qmakedep=gcc cannot be specified.
Source:
program main
end
Rejected FC compiler flag -qmakedep=gcc because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Trying FC compiler flag -MD
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -X9 -O0 -MD /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
end
Rejected FC compiler flag -MD because no dependency file (/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.d) was generated
Popping language FC
TEST checkC99Flag from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:1372)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1372)
Check for -std=c99 or equivalent flag
Pushing language C
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c", line 10: error: expected an expression
for (int i=0; i<2; i++){
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c", line 10: error: identifier "i" is undefined
2 errors detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c".
Source:
int main() {
int x[2],y;
y = 5;
// c++ comment
int j = 2;
x[i] = i*j*y;
return 0;
Rejecting compiler flag due to nonzero status from link
PETSc Error: No output file produced
Executing: mpifcc -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.libraries -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 -std=c99 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c", line 6: warning: variable "x" was set but never used
int x[2],y;
Source:
int main() {
int x[2],y;
y = 5;
// c++ comment
int j = 2;
x[i] = i*j*y;
return 0;
Accepted C99 compile flag: -std=c99
Popping language C
Executing: mpiFCC --help
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.cc
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.cc", line 5: error: expected a ";"
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.cc", line 5: warning: variable "restrict" was declared but never referenced
1 error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.cc".
Source:
int main() {
return 0;
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.cc", line 5: warning: variable "x" was declared but never referenced
Source:
int main() {
return 0;
compilers: Set Cxx restrict keyword to __restrict__
Defined "CXX_RESTRICT" to " __restrict__"
TEST checkCxxNamespace from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:359)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:359)
Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
return 0;
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
return 0;
compilers: C++ has namespaces
Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:334)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:334)
Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.c
Successful compile:
Source:
int main() {
class somename { int i; };;
return 0;
Added Cxx compiler flag
TEST checkCxxStaticInline from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:122)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:122)
Check for C++ keyword: static inline
Successful compile:
Source:
int main() {
foo(1);;
return 0;
compilers: Set Cxx StaticInline keyword to static inline
Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:413)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:413)
Determines the libraries needed to link with C++
Successful compile:
Source:
int main() {
return 0;
Pushing language CXX
Popping language CXX
Executing: mpiFCC -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest -### -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
stdout:
/usr/bin/ld --eh-frame-hdr -m elf64_sparc -YP,/usr/lib64 -dynamic-linker /lib64/ld-linux.so.2 /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtbegin.o -YP,/usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4 -u__metInit -ltrtmetcpp -ltrtmet_c -Qy -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi_cxx -lmpi -ltofucom -ltofutop -lm -lnsl -lutil //opt/FJSVtclang/GM-1.2.0-20/bin/../lib64/fjrtprof.o -T//opt/FJSVtclang/GM-1.2.0-20/bin/../util/lib/data-256mb.lds -L//opt/FJSVtclang/GM-1.2.0-20/bin/../lib64 -lfjdemgl -u_xfdb_Init -ltrtfdb -lfjrtcl -ltrtth -L/usr/lib64 -lstd_mt -lmpg -lmpgpthread -lpthread -lpapi -lm -lrt -lelf -ldl -lstdc++ -lgcc_s -lgcc -lc -lgcc_s -lgcc -lc /usr/lib64/gcc/sparc64-unknown-linux-gnu/4.2.4/crtend.o -L/opt/FJSVxosmmm/lib64 /usr/lib64/crtn.o
compilers: Checking arg -ltrtmetcpp
compilers: Found library: -ltrtmetcpp
compilers: Found library: -ltrtmet_c
Library already in C list so skipping in C++
compilers: Found library: -ldl
compilers: Found library: -lmpi
compilers: Found library: -ltofucom
compilers: Found library: -ltofutop
compilers: Found library: -lnsl
compilers: Found library: -lutil
compilers: Checking arg -L//opt/FJSVtclang/GM-1.2.0-20/lib64
compilers: Found library: -ltrtfdb
compilers: Found library: -lfjrtcl
compilers: Found library: -ltrtth
compilers: Found library: -lmpg
compilers: Found library: -lmpgpthread
compilers: Found library: -lpapi
compilers: Found library: -lrt
compilers: Found library: -lelf
compilers: Found library: -lgcc_s
compilers: Checking arg -lmpi_cxx
compilers: Found library: -lmpi_cxx
compilers: Checking arg -lfjdemgl
compilers: Found library: -lfjdemgl
compilers: Checking arg -lstd_mt
compilers: Found library: -lstd_mt
compilers: Checking arg -lpthread
compilers: Found library: -lpthread
compilers: Checking arg -lstdc++
compilers: Found library: -lstdc++
compilers: Libraries needed to link Cxx code with another linker: ['-ltrtmetcpp', '-L/opt/FJSVpxtof/sparc64fx/lib64', '-L/opt/FJSVtclang/GM-1.2.0-20/lib64', '-L//opt/FJSVtclang/GM-1.2.0-20/lib64', '-L/opt/FJSVxosmmm/lib64', '-lmpi_cxx', '-lfjdemgl', '-lstd_mt', '-lpthread', '-lstdc++']
compilers: Check that Cxx libraries can be used from C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Popping language C
compilers: Check that Cxx libraries can be used from Fortran
Pushing language FC
Successful compile:
Source:
program main
end
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmetcpp -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -L/opt/FJSVxosmmm/lib64 -lmpi_cxx -lfjdemgl -lstd_mt -lpthread -lstdc++ -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Popping language FC
TEST checkCxx11 from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:374)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:374)
Determine the option needed to support the C++11 dialect
We auto-detect C++11 if the compiler supports it without options,
otherwise we require with-cxx-dialect=C++11 to try adding flags to
support it.
Executing: mpiFCC -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc
Possible ERROR while running compiler: exit code 1024
stderr:
"/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc", line 4: catastrophic error: cannot open source file "random"
#include <random>
1 catastrophic error detected in the compilation of "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.cc".
Compilation terminated.
Source:
#include <random>
template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
std::random_device rd;
std::mt19937 mt(rd());
std::normal_distribution<double> dist(0,1);
const double x = dist(mt);
return 0;
#include <random>
TEST checkFortranTypeSizes from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:572)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:572)
Check whether real*8 is supported and suggest flags which will allow support
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.F
stderr:
Fortran diagnostic messages: program name(main)
jwd2006i-i "/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.F", line 2: 'variable' is declared but never referenced.
Source:
program main
real*8 variable
end
Popping language FC
TEST checkFortranNameMangling from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:631)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:631)
Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
Pushing language C
Successful compile:
Source:
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1chk()
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/confc.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
compilers: Fortran name mangling is underscore
Defined "HAVE_FORTRAN_UNDERSCORE" to "1"
TEST checkFortranNameManglingDouble from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:668)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:668)
Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
Pushing language C
Successful compile:
Source:
void d1_chk__(void){return;}
Popping language C
Pushing language FC
Successful compile:
Source:
program main
call d1_chk()
end
Pushing language FC
Popping language FC
stderr:
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o: In function `MAIN__':
conftest.F:(.text+0x30): undefined reference to `d1_chk_'
/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o:(.data+0x0): undefined reference to `d1_chk_'
Popping language FC
TEST checkFortranPreprocessor from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:678)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:678)
Determine if Fortran handles preprocessing properly
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef dummy
fooey
#endif
end
Added FC compiler flag
Popping language FC
compilers: Fortran uses CPP preprocessor
TEST checkFortranDefineCompilerOption from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:699)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:699)
Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
Pushing language FC
Executing: mpifrt -c -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers -I/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers -X9 -O0 -DTesting /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.F
Successful compile:
Source:
program main
#define dummy
dummy
#ifndef Testing
fooey
#endif
end
Defined make macro "FC_DEFINE_FLAG" to "-D"
Popping language FC
compilers: Fortran uses -D for defining macro
TEST checkFortranLibraries from config.compilers(/.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/config/BuildSystem/config/compilers.py:716)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:716)
Substitutes for FLIBS the libraries needed to link with Fortran
This macro is intended to be used in those situations when it is
necessary to mix, e.g. C++ and Fortran 77, source code into a single
program or shared library.
For example, if object files from a C++ and Fortran 77 compiler must
be linked together, then the C++ compiler/linker must be used for
linking (since special C++-ish things need to happen at link time
like calling global constructors, instantiating templates, enabling
exception support, etc.).
However, the Fortran 77 intrinsic and run-time libraries must be
linked in as well, but the C++ compiler/linker does not know how to
add these Fortran 77 libraries.
This code was translated from the autoconf macro which was packaged in
its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
However, nearly all of this macro came from the OCTAVE_FLIBS macro in
octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
for writing this extremely useful macro.
Pushing language FC
Executing: mpifrt -V
Successful compile:
Source:
program main
end
Pushing language FC
Popping language FC
Executing: mpifrt -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest -v -X9 -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.compilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Popping language FC
compilers: Libraries needed to link Fortran code with the C linker: []
compilers: Libraries needed to link Fortran main with the C linker: []
compilers: Check that Fortran libraries can be used from C
Pushing language C
Successful compile:
Source:
int main() {
return 0;
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Executing: mpifcc -o /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest -Xg -O0 /.global/volume2/home/hp150306/t00196/source/petsc-3.6.3/petsc-x3RW_Z/config.setCompilers/conftest.o -ltrtmet -ltrtmet_c -ldl -L/opt/FJSVpxtof/sparc64fx/lib64 -L/opt/FJSVtclang/GM-1.2.0-20/lib64 -lmpi -ltofucom -ltofutop -lnsl -lutil -L//opt/FJSVtclang/GM-1.2.0-20/lib64 -ltrtfdb -lfjrtcl -ltrtth -lmpg -lmpgpthread -lpapi -lrt -lelf -lgcc_s -L/opt/FJSVxosmmm/lib64 -ldl -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
Successful compile:
Source:
int main() {
return 0;
Pushing language C
Popping language C
Popping language C
compilers: Check that Fortran libraries can be used from C++
