[petsc-users] (no subject)
Thu Jun 2 09:39:55 CDT 2016
On Thu, Jun 2, 2016 at 9:12 AM, neok m4700 <neok.m4700 at gmail.com> wrote:
> Hi,
> I built petsc 3.7.1 and petsc4py 3.7.0 (with openmpi 1.10.2) and ran the
> examples in the demo directory.
I believe this was fixed in 'master':
https://bitbucket.org/petsc/petsc/commits/00c67f3b09c0bcda06af5ed306d845d9138e5003
Is it possible to try this?
    Matt
> $ python test_mat_ksp.py
> => runs as expected (serial)
> $ mpiexec -np 2 python test_mat_ksp.py
> => fails with the following output:
> Traceback (most recent call last):
>   File "<...>/demo/kspsolve/test_mat_ksp.py", line 15, in <module>
>     execfile('petsc-ksp.py')
>   File "<...>/demo/kspsolve/test_mat_ksp.py", line 6, in execfile
>     try: exec(fh.read()+"\n", globals, locals)
>   File "<string>", line 15, in <module>
>   File "PETSc/KSP.pyx", line 384, in petsc4py.PETSc.KSP.solve
> (src/petsc4py.PETSc.c:153555)
> petsc4py.PETSc.Error: error code 92
> [0] KSPSolve() line 599 in <...>/src/ksp/ksp/interface/itfunc.c
> [0] KSPSetUp() line 390 in <...>/src/ksp/ksp/interface/itfunc.c
> [0] PCSetUp() line 968 in <...>/src/ksp/pc/interface/precon.c
> [0] PCSetUp_ICC() line 21 in <...>/src/ksp/pc/impls/factor/icc/icc.c
> [0] MatGetFactor() line 4240 in<...>/src/mat/interface/matrix.c
> [0] You cannot overwrite this option since that will conflict with other
> previously set options
> [0] Could not locate solver package (null). Perhaps you must ./configure
> with --download-(null)
> Primary job  terminated normally, but 1 process returned
> a non-zero exit code.. Per user-direction, the job has been aborted.
> mpirun detected that one or more processes exited with non-zero status,
> thus causing
> the job to be terminated. The first process to do so was:
>   Process name: [[23110,1],0]
>   Exit code:    1
> What have I done wrong ?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160602/7f52e41e/attachment.html>
