[petsc-users] PCFIELDSPLIT question
Hom Nath Gharti
hng.email at gmail.com
Tue Feb 9 09:31:36 CST 2016
Thanks a lot Matt!
Were you referring to
http://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex62.c.html
I do not see any statements related to PCFieldSplit there. Am I
missing something here?
Hom Nath
On Tue, Feb 9, 2016 at 10:19 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 9, 2016 at 9:10 AM, Hom Nath Gharti <hng.email at gmail.com> wrote:
>> Thank you so much Barry!
>> For my small test case, with -pc_fieldsplit_block_size 4, the program
>> runs, although the answer was not correct. At least now I get
>> something to look upon. I am using PCFieldSplitSetIS to set the
>> fields. Do I still need to use -pc_fieldsplit_block_size?
> No, this is only for co-located discretizations.
>> In my case each grid point may have different variable sets. For
>> example, the grid point in the solid region has displacement and
>> gravity potential: ux, uy, uz, and \phi. Whereas the grid point in the
>> fluid region has scalar potential, pressure and gravity potential:
>> \chi, p, and \phi. And the solid-fluid interface has all of them. Do
>> you think I can still use PCFIELDSPLIT in this situation?
> We have examples, like SNES ex62, which do exactly this.
> Thanks,
> Matt
>> Best,
>> Hom Nath
>> On Mon, Feb 8, 2016 at 2:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> > In this case you need to provide two pieces of information to the
>> > PCFIELDSPLIT. What we call the "block size" or bs which is the number of
>> > "basic fields" in the problem. For example if at each grid point you have
>> > x-velocity, y-velocity, and pressure the block size is 3. The second is you
>> > need to tell PCFIELDSPLIT what "basic fields" are in each split you want to
>> > use.
>> > In your case you can do this with -pc_fieldsplit_block_size 4.
>> > (Note if you use a DM to define your problem the PCFIELDSPLIT will
>> > automatically get the bs from the DM so you do not need to provide it.
>> > Similarly if you set a block size on your Mat the PCFIELDSPLIT will use that
>> > so you don't need to set it).
>> > Then use -pc_fieldsplit_0_fields 0,1 to indicate your first split is
>> > the 0 and 1 basic fields and -pc_fieldsplit_1_fields 2,3 to indicate the
>> > second split is the 2 and 3 basic fields.
>> > (By default if you do not provide this then PCFIELDSPLIT will use bs
>> > splits (4 in your case) one for each basic field.
>> > Barry
>> >> On Feb 8, 2016, at 11:20 AM, Hom Nath Gharti <hng.email at gmail.com>
>> >> wrote:
>> >> Hi Matt, Hi all,
>> >> I am trying to have some feel for PCFIELDSPLIT testing on a very small
>> >> matrix (attached below). I have 4 degrees of freedoms. I use 4
>> >> processors. I want to split 4 dofs into two fields each having two
>> >> dofs. I don't know whether this my be a problem for petsc. When I use
>> >> the command:
>> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_view
>> >> It runs fine.
>> >> But when I want to use field split options using the command:
>> >> srun -n 4 ./xtestfs -ksp_monitor -ksp_type fgmres -pc_type fieldsplit
>> >> -fieldsplit_0_ksp_type gmres -fieldsplit_0_pc_type bjacobi
>> >> -fieldsplit_1_pc_type jacobi
>> >> I get the following error message:
>> >> [0]PETSC ERROR: Petsc has generated inconsistent data
>> >> [0]PETSC ERROR: Unhandled case, must have at least two fields, not 1
>> >> [0]PETSC ERROR: See
>> >> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> >> shooting.
>> >> [0]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>> >> [0]PETSC ERROR: /tigress/hgharti/test/testfs/./xtestfs on a
>> >> arch-linux2-c-debug named tiger-r11n1 by hgharti Mon Feb 8 11:40:03
>> >> 2016
>> >> [0]PETSC ERROR: Configure options
>> >> --with-blas-lapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64/
>> >> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
>> >> --with-mpiexec=mpiexec --with-debugging=1 --download-scalapack
>> >> --download-mumps --download-pastix --download-superlu
>> >> --download-superlu_dist --download-metis --download-parmetis
>> >> --download-ptscotch --download-hypre
>> >> [0]PETSC ERROR: #1 PCFieldSplitSetDefaults() line 469 in
>> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>> >> [0]PETSC ERROR: #2 PCSetUp_FieldSplit() line 486 in
>> >> [0]PETSC ERROR: #3 PCSetUp() line 983 in
>> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/pc/interface/precon.c
>> >> [0]PETSC ERROR: #4 KSPSetUp() line 332 in
>> >> /home/hgharti/lsoft/petsc-3.6.3-intel16-mpi5/src/ksp/ksp/interface/itfunc.c
>> >> [0]PETSC ERROR: #5 KSPSolve() line 546 in
>> >> WARNING! There are options you set that were not used!
>> >> WARNING! could be spelling mistake, etc!
>> >> Option left: name:-fieldsplit_0_ksp_type value: gmres
>> >> Option left: name:-fieldsplit_0_pc_type value: bjacobi
>> >> Option left: name:-fieldsplit_1_pc_type value: jacobi
>> >> forrtl: error (76): Abort trap signal
>> >> I tried several trials but could not fix the problem. Is it the
>> >> FORTRAN problem or am I doing something wrong? Any suggestions would
>> >> be greatly appreciated.
>> >> For your information I use:
>> >> PETSc-3.6.3
>> >> intel-16.0 compiler
>> >> intel-mpi-5.1.1
>> >> Program
>> >> Best,
>> >> Hom Nath
>> >> ! simple test case for PCFIELDSPLIT
>> >> program testfs
>> >> implicit none
>> >> #include "petsc/finclude/petscsys.h"
>> >> #include "petsc/finclude/petscvec.h"
>> >> #include "petsc/finclude/petscvec.h90"
>> >> #include "petsc/finclude/petscmat.h"
>> >> #include "petsc/finclude/petscksp.h"
>> >> #include "petsc/finclude/petscpc.h"
>> >> #include "petsc/finclude/petscviewer.h"
>> >> #include "petsc/finclude/petscviewer.h90"
>> >> Vec x,b,u
>> >> Mat A
>> >> KSP ksp
>> >> PC pc
>> >> PetscErrorCode ierr
>> >> PetscBool flg
>> >> PetscInt errcode,its,maxitr,myrank,nproc
>> >> PetscInt nedof,nelmt,ndof,nenod,ngdof,fixdof,nsparse,neq
>> >> PetscInt,allocatable :: krow_sparse(:),ggdof_elmt(:,:), &
>> >> inode_elmt(:,:)
>> >> PetscReal,allocatable :: storef(:,:),storekmat(:,:,:)
>> >> PetscInt gdof0(2),gdof1(2)
>> >> ! initialize MPI
>> >> call MPI_INIT(errcode)
>> >> if(errcode /= 0)stop 'ERROR: cannot initialize MPI!'
>> >> call MPI_COMM_RANK(MPI_COMM_WORLD,myrank,errcode)
>> >> if(errcode /= 0)stop 'ERROR: cannot find processor ID'
>> >> call MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,errcode)
>> >> if(errcode /= 0)stop 'ERROR: cannot find number of processors!'
>> >> ! define some parameters
>> >> ! 1D model with 4 elements. Each elements consits of 2 nodes. Node 0 is
>> >> fixed.
>> >> ! 1-----------2-----------3-----------4-----------5
>> >> nelmt=1 ! per processor
>> >> nenod=2 ! number of nodes per element
>> >> nedof=2 ! number of DOFs per element
>> >> ndof=2 ! number of DOFs
>> >> ngdof=4 ! total number of global DOFs
>> >> fixdof=1
>> >> if(myrank==0)then
>> >> neq=1 ! number of equations
>> >> nsparse=1
>> >> else
>> >> neq=2 ! number of equations
>> >> nsparse=4
>> >> endif
>> >> allocate(storef(nedof,nelmt),storekmat(nedof,nedof,nelmt),
>> >> ggdof_elmt(nedof,nelmt),inode_elmt(nenod,nelmt),krow_sparse(nsparse))
>> >> storef=0.0_8 ! local RHS vector
>> >> storekmat=0.0_8 ! local stiffness matrix
>> >> if(myrank==0)then
>> >> krow_sparse(:)=1
>> >> storef(:,1)=(/12.5000_8, 12.5000_8/)
>> >> storekmat(:,:,1) = reshape((/1.2333333332_8, 0.0166666667_8, &
>> >> 0.0166666667_8,
>> >> 1.2333333332_8/),(/nedof,nedof/))
>> >> inode_elmt(:,1) = (/1,2/)
>> >> ggdof_elmt(:,1) = (/0,1/) ! 0 because left node is fixed
>> >> elseif(myrank==1)then
>> >> krow_sparse(:)=(/1,1,2,2/)
>> >> 0.0166666667_8,
>> >> ggdof_elmt(:,1) = (/1,2/)
>> >> elseif(myrank==2)then
>> >> 0.0166666667_8,
>> >> ggdof_elmt(:,1) = (/2,3/)
>> >> elseif(myrank==3)then
>> >> storef(:,1)=(/12.5000_8, 22.5000_8/)
>> >> 0.0166666667_8,
>> >> ggdof_elmt(:,1) = (/3,4/)
>> >> endif
>> >> call petsc_initialize
>> >> call petsc_set_matrix
>> >> call petsc_set_vector
>> >> call petsc_solve
>> >> call petsc_finalize
>> >> ! deallocate
>> >> deallocate(storef,storekmat,ggdof_elmt,inode_elmt)
>> >> deallocate(krow_sparse)
>> >> contains
>> >> subroutine petsc_initialize()
>> >> implicit none
>> >> PetscInt :: istart,iend
>> >> PetscInt :: nzeros_max,nzeros_min
>> >> PetscReal :: atol,dtol,rtol
>> >> PetscInt,allocatable :: nzeros(:)
>> >> IS gdof0_is,gdof1_is
>> >> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>> >> call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-n',ngdof,flg,ierr)
>> >> ! count number of nonzeros per row
>> >> allocate(nzeros(neq))
>> >> nzeros=0
>> >> nzeros(krow_sparse)=nzeros(krow_sparse)+1
>> >> nzeros_max=maxval(nzeros)
>> >> nzeros_min=minval(nzeros)
>> >> ! create matrix
>> >> call MatCreate(PETSC_COMM_WORLD,A,ierr)
>> >> call MatSetType(A,MATMPIAIJ,ierr)
>> >> CHKERRQ(ierr)
>> >> call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,ngdof,ngdof,ierr)
>> >> CHKERRQ(ierr)
>> >> ! preallocation
>> >> call
>> >> MatMPIAIJSetPreallocation(A,nzeros_max,PETSC_NULL_INTEGER,nzeros_max, &
>> >> PETSC_NULL_INTEGER,ierr)
>> >> CHKERRQ(ierr)
>> >> call MatGetOwnershipRange(A,istart,iend,ierr)
>> >> CHKERRQ(ierr)
>> >> print*,'ownership:',myrank,istart,iend
>> >> ! create vector
>> >> call VecCreate(PETSC_COMM_WORLD,x,ierr)
>> >> call VecSetSizes(x,PETSC_DECIDE,ngdof,ierr)
>> >> call VecSetType(x,VECMPI,ierr)
>> >> call VecDuplicate(x,b,ierr)
>> >> call VecDuplicate(x,u,ierr)
>> >> ! get IS for split fields
>> >> gdof0=(/0,1/)
>> >> gdof1=(/2,3/)
>> >> call
>> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof0,PETSC_COPY_VALUES,gdof0_is,ierr)
>> >> CHKERRQ(ierr)
>> >> call
>> >> ISCreateGeneral(PETSC_COMM_WORLD,2,gdof1,PETSC_COPY_VALUES,gdof1_is,ierr)
>> >> CHKERRQ(ierr)
>> >> ! Create linear solver context
>> >> call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>> >> call KSPSetOperators(ksp,A,A,ierr)
>> >> call KSPGetPC(ksp,pc,ierr)
>> >> CHKERRQ(ierr)
>> >> ! split PC
>> >> call PCFieldSplitSetIS(pc,"0",gdof0_is,ierr);
>> >> CHKERRQ(ierr)
>> >> call ISDestroy(gdof0_is,ierr)
>> >> CHKERRQ(ierr)
>> >> call PCFieldSplitSetIS(pc,"1",gdof1_is,ierr);
>> >> CHKERRQ(ierr)
>> >> call ISDestroy(gdof1_is,ierr)
>> >> CHKERRQ(ierr)
>> >> rtol = 1.0d-6
>> >> atol = 1.0d-6
>> >> dtol = 1.0d10
>> >> maxitr = 1000
>> >> call KSPSetTolerances(ksp,rtol,atol,dtol,maxitr,ierr)
>> >> CHKERRQ(ierr)
>> >> call KSPSetFromOptions(ksp,ierr)
>> >> end subroutine petsc_initialize
>> >> subroutine petsc_set_matrix()
>> >> implicit none
>> >> integer :: i,i_elmt,j,ncount
>> >> integer :: ggdof(NEDOF),idof(NEDOF),igdof(NEDOF)
>> >> ! Set and assemble matrix.
>> >> call MatZeroEntries(A,ierr)
>> >> CHKERRQ(ierr)
>> >> do i_elmt=1,nelmt
>> >> ggdof(:)=ggdof_elmt(:,i_elmt)
>> >> ggdof(:)=ggdof(:)-1 ! petsc index starts from 0
>> >> ncount=0; idof=-1; igdof=-1
>> >> do i=1,NEDOF
>> >> do j=1,NEDOF
>> >> if(ggdof(i).ge.0.and.ggdof(j).ge.0)then
>> >> call MatSetValues(A,1,ggdof(i),1,ggdof(j),storekmat(i,j,i_elmt),
>> >> ADD_VALUES,ierr)
>> >> CHKERRQ(ierr)
>> >> endif
>> >> enddo
>> >> enddo
>> >> enddo
>> >> call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>> >> call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>> >> if(myrank==0)print*,'matrix setting & assembly complete!'
>> >> end subroutine petsc_set_matrix
>> >> subroutine petsc_set_vector()
>> >> implicit none
>> >> PetscScalar zero
>> >> integer :: i,i_elmt,ncount
>> >> ! set vector
>> >> zero=0.0_8
>> >> call VecSet(b,zero,ierr)
>> >> do i_elmt=1,nelmt
>> >> do i=1,NEDOF
>> >> if(ggdof(i).ge.0)then
>> >> call VecSetValues(b,1,ggdof(i),storef(i,i_elmt),ADD_VALUES,ierr);
>> >> CHKERRQ(ierr)
>> >> endif
>> >> enddo
>> >> enddo
>> >> ! assemble vector
>> >> call VecAssemblyBegin(b,ierr)
>> >> call VecAssemblyEnd(b,ierr)
>> >> if(myrank==0)print*,'vector setting & assembly complete!'
>> >> end subroutine petsc_set_vector
>> >> subroutine petsc_solve()
>> >> implicit none
>> >> PetscInt ireason
>> >> PetscScalar a_v(1)
>> >> PetscOffset a_i
>> >> PetscInt n
>> >> PetscReal,allocatable :: sdata(:)
>> >> call VecGetSize(b,n,ierr)
>> >> CHKERRQ(ierr)
>> >> allocate(sdata(n))
>> >> sdata=0.0_8
>> >> call VecGetArray(b,a_v,a_i,ierr)
>> >> CHKERRQ(ierr)
>> >> sdata(1:n)=a_v(a_i+1:a_i+n)
>> >> call VecRestoreArray(b,a_v,a_i,ierr)
>> >> CHKERRQ(ierr)
>> >> print*,'rhs:',sdata
>> >> call KSPSolve(ksp,b,x,ierr)
>> >> sdata=0.0_8
>> >> call VecGetArray(x,a_v,a_i,ierr)
>> >> CHKERRQ(ierr)
>> >> CHKERRQ(ierr)
>> >> print*,'solution:',sdata
>> >> ! Check convergence
>> >> call KSPGetConvergedReason(ksp,ireason,ierr)
>> >> if(myrank==0)print*,'converges reason',myrank,ireason
>> >> call KSPGetIterationNumber(ksp,its,ierr)
>> >> if(myrank==0)print*,'Iterations:',its
>> >> deallocate(sdata)
>> >> end subroutine petsc_solve
>> >> subroutine petsc_finalize()
>> >> implicit none
>> >> ! Free work space.
>> >> call VecDestroy(x,ierr)
>> >> call VecDestroy(u,ierr)
>> >> call VecDestroy(b,ierr)
>> >> call MatDestroy(A,ierr)
>> >> call KSPDestroy(ksp,ierr)
>> >> call PetscFinalize(ierr)
>> >> CHKERRQ(ierr)
>> >> end subroutine petsc_finalize
>> >> end program testfs
>> >> On Tue, Feb 2, 2016 at 4:54 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >>> On Tue, Feb 2, 2016 at 3:11 PM, Hom Nath Gharti <hng.email at gmail.com>
>> >>> wrote:
>> >>>> Thanks a lot. I will try.
>> >>> Also, if you send a small test case, we can run it and tell you the
>> >>> problem.
>> >>> Matt
>> >>>> Hom Nath
>> >>>> On Tue, Feb 2, 2016 at 4:02 PM, Matthew Knepley <knepley at gmail.com>
>> >>>> wrote:
>> >>>>> On Tue, Feb 2, 2016 at 3:01 PM, Hom Nath Gharti
>> >>>>> wrote:
>> >>>>>> Thanks again Matt. Unfortunately got the same errors with '0'. I
>> >>>>>> think
>> >>>>>> both are valid in Fortran.
>> >>>>> Then you will have to go in the debugger and see why its not
>> >>>>> creating 4
>> >>>>> splits, since this is exactly
>> >>>>> what it does in our tests. This is how all the SNES tests that I use
>> >>>>> work. I
>> >>>>> am sure its a Fortran
>> >>>>> problem.
>> >>>>> Thanks,
>> >>>>> Matt
>> >>>>>> Hom Nath
>> >>>>>> On Tue, Feb 2, 2016 at 3:42 PM, Matthew Knepley <knepley at gmail.com>
>> >>>>>> wrote:
>> >>>>>>> On Tue, Feb 2, 2016 at 2:35 PM, Hom Nath Gharti
>> >>>>>>> wrote:
>> >>>>>>>> Thank you so much Matt.
>> >>>>>>>> I now tried the following:
>> >>>>>>>> call PCFieldSplitSetIS(pc,"0",gdofu_is,ierr);
>> >>>>>>>> call ISDestroy(gdofu_is,ierr)
>> >>>>>>>> call PCFieldSplitSetIS(pc,"1",gdofchi_is,ierr);
>> >>>>>>>> call ISDestroy(gdofchi_is,ierr)
>> >>>>>>>> call PCFieldSplitSetIS(pc,"2",gdofp_is,ierr);
>> >>>>>>>> call ISDestroy(gdofp_is,ierr)
>> >>>>>>>> call PCFieldSplitSetIS(pc,"3",gdofphi_is,ierr);
>> >>>>>>>> call ISDestroy(gdofphi_is,ierr)
>> >>>>>>>> ! Amat changes in each time steps
>> >>>>>>>> call KSPSetOperators(ksp,Amat,Amat,ierr) !version >= 3.5.0
>> >>>>>>>> call KSPSolve(ksp,bvec,xvec,ierr)
>> >>>>>>> I am guessing that "0" is not a valid string for your Fortran
>> >>>>>>> compiler.
>> >>>>>>> Are
>> >>>>>>> you sure
>> >>>>>>> its not single quotes '0'?
>> >>>>>>> Matt
>> >>>>>>>> But I get the following error:
>> >>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>> >>>>>>>> not 1
>> >>>>>>>> [0]PETSC ERROR: See
>> >>>>>>>> shooting.
>> >>>>>>>> [0]PETSC ERROR:
>> >>>>>>>> /tigress/hgharti/gitwork/SPECFEM3D_GLOBEVSPP/./bin/xspecfem3D on
>> >>>>>>>> a
>> >>>>>>>> arch-linux2-c-debug named tiger-r3c1n7 by hgharti Tue Feb 2 15:
>> >>>>>>>> 29:30 2016
>> >>>>>>>> h-fc=mpif90 --with-mpiexec=mpiexec --with-debugging=1
>> >>>>>>>> --download-scalapack --download-mumps --download-pastix
>> >>>>>>>> --download-superlu --download-superlu_dist --download-metis
>> >>>>>>>> --download-parmetis --download-ptscotch --download-hypre
>> >>>>>>>> Am I missing something?
>> >>>>>>>> Thanks,
>> >>>>>>>> Hom Nath
>> >>>>>>>> On Tue, Feb 2, 2016 at 3:24 PM, Matthew Knepley
>> >>>>>>>> wrote:
>> >>>>>>>>> On Tue, Feb 2, 2016 at 2:20 PM, Hom Nath Gharti
>> >>>>>>>>> wrote:
>> >>>>>>>>>> Hi Matt, hi all,
>> >>>>>>>>>> I am trying to use PCFIELDSPLIT for my solver which consists of
>> >>>>>>>>>> 4
>> >>>>>>>>>> different variables, namely, u (displacement vector), \chi
>> >>>>>>>>>> (displacement potential), p(pressure), and \phi (gravity
>> >>>>>>>>>> potential).
>> >>>>>>>>>> My code segment looks like the following:
>> >>>>>>>>>> nsplit=4
>> >>>>>>>>>> call PCFieldSplitSetBlockSize(pc,nsplit,ierr);
>> >>>>>>>>> You do not need the statement above.
>> >>>>>>>>>> call PCFieldSplitGetSubKSP(pc,nsplit,subksp,ierr);
>> >>>>>>>>> These SetOperators() calls are wrong. I am not sure why you want
>> >>>>>>>>> them
>> >>>>>>>>> here.
>> >>>>>>>>> Also, that means you do not need the call above.
>> >>>>>>>>> Thanks,
>> >>>>>>>>> Matt
>> >>>>>>>>>> call KSPSetOperators(subksp(1),Amat,Amat,ierr);
>> >>>>>>>>>> call KSPSetOperators(subksp(2),Amat,Amat,ierr);
>> >>>>>>>>>> call KSPSetOperators(subksp(3),Amat,Amat,ierr);
>> >>>>>>>>>> call KSPSetOperators(subksp(4),Amat,Amat,ierr);
>> >>>>>>>>>> But I am getting the following error:
>> >>>>>>>>>> [79]PETSC ERROR: Null argument, when expecting valid pointer
>> >>>>>>>>>> [79]PETSC ERROR: Null Object: Parameter # 1
>> >>>>>>>>>> [79]PETSC ERROR: #1 KSPSetOperators() line 536 in
>> >>>>>>>>>> It looks like I am doing something wrong in "call
>> >>>>>>>>>> KSPSetOperators"
>> >>>>>>>>>> but
>> >>>>>>>>>> I could not figure that out.
>> >>>>>>>>>> Could anybody help me to fix this problem? I looked into almost
>> >>>>>>>>>> all
>> >>>>>>>>>> related examples but I could not really figure out the correct
>> >>>>>>>>>> steps
>> >>>>>>>>>> after "call PCFieldSplitSetIS".
>> >>>>>>>>>> Any help will be greatly appreciated.
>> >>>>>>>>>> Best,
>> >>>>>>>>>> Hom nath
>> >>>>>>>>>> On Sun, Jan 24, 2016 at 7:14 PM, Hom Nath Gharti
>> >>>>>>>>>> wrote:
>> >>>>>>>>>>> Thank you so much Matt! I will try.
>> >>>>>>>>>>> Hom Nath
>> >>>>>>>>>>> On Sun, Jan 24, 2016 at 6:26 AM, Matthew Knepley
>> >>>>>>>>>>> wrote:
>> >>>>>>>>>>>> On Fri, Jan 22, 2016 at 2:19 PM, Hom Nath Gharti
>> >>>>>>>>>>>> wrote:
>> >>>>>>>>>>>>> Dear all,
>> >>>>>>>>>>>>> I am new to PcFieldSplit.
>> >>>>>>>>>>>>> I have a matrix formed using MATMPIAIJ. Is it possible to
>> >>>>>>>>>>>>> use
>> >>>>>>>>>>>>> PCFIELDSPLIT operations in this type of matrix? Or does it
>> >>>>>>>>>>>>> have
>> >>>>>>>>>>>>> to
>> >>>>>>>>>>>>> be
>> >>>>>>>>>>>>> MATMPIBIJ or MATNEST format?
>> >>>>>>>>>>>> Yes, you can split AIJ.
>> >>>>>>>>>>>>> If possible for MATMPIAIJ, could anybody provide me a simple
>> >>>>>>>>>>>>> example
>> >>>>>>>>>>>>> or few steps? Variables in the equations are displacement
>> >>>>>>>>>>>>> vector,
>> >>>>>>>>>>>>> scalar potential and pressure.
>> >>>>>>>>>>>> If you do not have a collocated discretization, then you have
>> >>>>>>>>>>>> to
>> >>>>>>>>>>>> use
>> >>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/PCFieldSplitSetIS.html
>> >>>>>>>>>>>> Thanks,
>> >>>>>>>>>>>> Matt
>> >>>>>>>>>>>>> Thanks for help.
>> >>>>>>>>>>>>> Hom Nath
>> >>>>>>>>>>>> What most experimenters take for granted before they begin
>> >>>>>>>>>>>> their
>> >>>>>>>>>>>> experiments
>> >>>>>>>>>>>> is infinitely more interesting than any results to which
>> >>>>>>>>>>>> their
>> >>>>>>>>>>>> experiments
>> >>>>>>>>>>>> lead.
>> >>>>>>>>>>>> -- Norbert Wiener
>> >>>>>>>>> What most experimenters take for granted before they begin their
>> >>>>>>>>> experiments
>> >>>>>>>>> is infinitely more interesting than any results to which their
>> >>>>>>>>> experiments
>> >>>>>>>>> lead.
>> >>>>>>>>> -- Norbert Wiener
>> >>>>>>> experiments
>> >>>>>>> experiments
>> >>>>>>> lead.
>> >>>>>>> -- Norbert Wiener
>> >>>>> experiments
>> >>>>> experiments
>> >>>>> lead.
>> >>>>> -- Norbert Wiener
>> >>> experiments
>> >>> experiments
>> >>> lead.
>> >>> -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
