[petsc-users] petsc externalpackage directory
Tue Feb 2 19:32:57 CST 2016
> On Feb 2, 2016, at 7:00 PM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
>> Or you can copy the whole '$PETSC_ARCH/externalpackages' dir over to
>> this other machine [and place in the same location - for any
>> PETSC_ARCH you plan to use..]
> This sounds unreliable.
  In what way?
>  We used to have a unified externalpackages
> directory, but made it per-PETSC_ARCH partly to avoid dirty source trees
> causing incorrect builds (and so that configure could run in parallel
> for different PETSC_ARCH).
