[petsc-users] Error with SuperLU_DIST (mkl related?)
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Sat Dec 31 12:26:47 CST 2016
Ah ok, I see! Here look at the file name in the configure.log:
Install the project...
/usr/bin/cmake -P cmake_install.cmake
-- Install configuration: "DEBUG"
-- Installing: /opt/petsc-master_debug/lib/libsuperlu_dist.so.5.1.0
It is saying 5.1.0, but in fact you are right: it is 5.1.3 that is
downloaded!!! :)
And FWIW, the nighlty automatic compilation of PETSc starts within a
brand new and empty directory each night...
Thanks to both of you again! :)
Eric
Le 2016-12-31 à 13:17, Satish Balay a écrit :
> Trying to download git://https://github.com/xiaoyeli/superlu_dist for SUPERLU_DIST
> Executing: git clone https://github.com/xiaoyeli/superlu_dist /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/externalpackages/git.superlu_dist
> stdout: Cloning into '/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/externalpackages/git.superlu_dist'...
> Looking for SUPERLU_DIST at git.superlu_dist, hg.superlu_dist or a directory starting with ['superlu_dist']
> Found a copy of SUPERLU_DIST in git.superlu_dist
> Executing: ['git', 'rev-parse', '--git-dir']
> stdout: .git
> Executing: ['git', 'cat-file', '-e', 'v5.1.3^{commit}']
> Executing: ['git', 'rev-parse', 'v5.1.3']
> stdout: 7306f704c6c8d5113def649b76def3c8eb607690
> Executing: ['git', 'stash']
> stdout: No local changes to save
> Executing: ['git', 'clean', '-f', '-d', '-x']
> Executing: ['git', 'checkout', '-f', '7306f704c6c8d5113def649b76def3c8eb607690']
> Per log below - its using 5.1.3. Why did you think you got 5.1.0?
> Satish
> On Sat, 31 Dec 2016, Eric Chamberland wrote:
>> Hi,
>> ok I will test with 5.1.3 with the option you gave me
>> (--download-superlu_dit-commit=v5.1.3).
>> But from what you and Matthew said, I should have 5.1.3 with petsc-master, but
>> the last night log shows me library file name 5.1.0:
>> http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2016.12.31.02h00m01s_configure.log
>> So I am a bit confused: Why did I got 5.1.0 last night? (I use the
>> petsc-master tarball, is it the reason?)
>> Thanks,
>> Eric
>>>> Hi,
>>>> I am just starting to debug a bug encountered with and only with
>>>> SuperLU_Dist
>>>> combined with MKL on a 2 processes validation test.
>>>> (the same test works fine with MUMPS on 2 processes).
>>>> I just noticed that the SuperLU_Dist version installed by PETSc configure
>>>> script is 5.1.0 and the latest SuperLU_DIST is 5.1.3.
>>> If you use petsc-master - it will install 5.1.3 by default.
>>>> Before going further, I just want to ask:
>>>> Is there any specific reason to stick to 5.1.0?
>>> We don't usually upgrade externalpackage version in PETSc releases
>>> [unless its tested to work and fixes known bugs]. There could be API
>>> changes - or build changes that can potentially conflict.
>>> >From what I know - 5.1.3 should work with petsc-3.7 [it fixes a couple of
>>> bugs].
>>> You might be able to do the following with petsc-3.7 [with git
>>> externalpackage repos]
>>> --download-superlu_dist --download-superlu_dit-commit=v5.1.3
>>> Satish
>>>> Here is some more information:
>>>> On process 2 I have this printed in stdout:
>>>> Intel MKL ERROR: Parameter 6 was incorrect on entry to DTRSM .
>>>> and in stderr:
>>>> Test.ProblemeEFGen.opt: malloc.c:2369: sysmalloc: Assertion `(old_top ==
>>>> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
>>>> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
>>>> (old_size)
>>>>> = (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
>>>> fd_nextsize))+((2 *(sizeof(size_t))) - 1)) & ~((2 *(sizeof(size_t))) -
>>>> 1))) &&
>>>> ((old_top)->size & 0x1) && ((unsigned long) old_end & pagemask) == 0)'
>>>> failed.
>>>> [saruman:15771] *** Process received signal ***
>>>> This is the 7th call to KSPSolve in the same execution. Here is the last
>>>> KSPView:
>>>> KSP Object:(o_slin) 2 MPI processes
>>>> type: preonly
>>>> maximum iterations=10000, initial guess is zero
>>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>>> left preconditioning
>>>> using NONE norm type for convergence test
>>>> PC Object:(o_slin) 2 MPI processes
>>>> type: lu
>>>> LU: out-of-place factorization
>>>> tolerance for zero pivot 2.22045e-14
>>>> matrix ordering: natural
>>>> factor fill ratio given 0., needed 0.
>>>> Factored matrix follows:
>>>> Mat Object: 2 MPI processes
>>>> type: mpiaij
>>>> rows=382, cols=382
>>>> package used to perform factorization: superlu_dist
>>>> total: nonzeros=0, allocated nonzeros=0
>>>> total number of mallocs used during MatSetValues calls =0
>>>> SuperLU_DIST run parameters:
>>>> Process grid nprow 2 x npcol 1
>>>> Equilibrate matrix TRUE
>>>> Matrix input mode 1
>>>> Replace tiny pivots FALSE
>>>> Use iterative refinement FALSE
>>>> Processors in row 2 col partition 1
>>>> Row permutation LargeDiag
>>>> Column permutation METIS_AT_PLUS_A
>>>> Parallel symbolic factorization FALSE
>>>> Repeated factorization SamePattern
>>>> linear system matrix = precond matrix:
>>>> Mat Object: (o_slin) 2 MPI processes
>>>> type: mpiaij
>>>> rows=382, cols=382
>>>> total: nonzeros=4458, allocated nonzeros=4458
>>>> using I-node (on process 0) routines: found 109 nodes, limit used
>>>> is 5
>>>> I know this information is not enough to help debug, but I would like to
>>>> know
>>>> if PETSc guys will upgrade to 5.1.3 before trying to debug anything.
>>>> Thanks,
>>>> Eric
