[petsc-users] strange out memory issues or bus errors when increasing pb size
Fri Dec 16 08:56:40 CST 2016
> On Dec 16, 2016, at 8:45 AM, Aurelien Ponte <aurelien.ponte at ifremer.fr> wrote:
> Hi,
> I am inverting a 3D elliptical operator with petsc4py (3.4, petsc is 3.4.5)
> installed via conda: https://anaconda.org/sed-pro-inria/petsc4py
> I get systematic crashes (out of memory or bus error) when I reach a certain
> grid size (512 x 256 x 100) even though I maintain the same number of grid points per processor.
> I used up to 256 procs and got similar crashes.
> Browsing the internet indicates that using 64-bit-indices may be cure for
> such pb.
   Yes, this is the problem.
> It will take however a significant amount of effort for me to install
> petsc4py and petsc with this option.
   Hopefully another user knows an easy way to install petsc4py to use 64 bit indices
> I do not even know how to check whether
> my current versions of petsc4py and petsc was installed with it.
  It was not.
> Would you have any tips or recommendation about how I could address the issue ?
> Thanks,
> Aurelien
> Aurélien Ponte
> Tel: (+33) 2 98 22 40 73
> Fax: (+33) 2 98 22 44 96
> UMR 6523, IFREMER
> ZI de la Pointe du Diable
> CS 10070
> 29280 Plouzané
