[petsc-users] snes options for rough solution
Praveen C cpraveen at gmail.com
Tue Dec 13 00:12:06 CST 2016
On Tue, Dec 13, 2016 at 2:50 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 12, 2016 at 2:29 AM, Praveen C <cpraveen at gmail.com> wrote:
>> Hello Matt
>> I have attached the detailed output.
>> Fenics automatically computes Jacobian, so I think Jacobian should be
>> correct. I am not able to run the Fenics code without giving the Jacobian.
>> I am currently writing a C code where I can test this.
>> This equation is bit weird. Its like this
>> u_t = ( K u_x)_x
>> K = u / sqrt(u_x^2 + eps^2)
> I do not understand how to show parabolicity in this case. However, I have
> a more fundamental misunderstanding. In your code, I see
>   R0 = idt*(u-uold)*v*dx + K0*ux*vx*dx
> for the residual, which looks like
> R0 = u_t + K u_x
> to me. Where is the extra derivative you show above?
Hello Matt
vx is derivative of test function. So the last term is a second order
differential operator. The PDE in full looks like this
u_t = u_x^2/sqrt(u_x^2 + eps^2) + eps^2 * u * u_xx / (u_x^2 + eps^2)^1.5
With u > 0, the last term is parabolic. But numerically, I solve it in
divergence form.
Best
praveen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161213/8702e499/attachment.html>
