[petsc-users] local dimensions
Barry Smith
bsmith at mcs.anl.gov
Sun Dec 11 19:05:21 CST 2016
> On Dec 11, 2016, at 6:26 PM, Massoud Rezavand <msdrezavand at gmail.com> wrote:
> Sorry, I forgot to say that my computational domain is decomposed with a parallel library using MPI, and the particles are defined with a distributed vector. So, the entries of the matrix are basically from that distributed vector.
Then likely you should use the same distribution for matrix rows as you do for the vector.
Thus you can call VecGetLocalSize() and pass that local size in the preallocation for the matrix, you can also call VecGetOwnershipRange() to get the range of local rows in order to compute the preallocation for the matrix.
Barry
> Thanks,
> Massoud
> On Mon, Dec 12, 2016 at 1:21 AM, Massoud Rezavand <msdrezavand at gmail.com> wrote:
> Thanks,
> as I already discussed with you, the matrix is coming from SPH discretization, which is not fixed on a grid and is changing over time.
> On Mon, Dec 12, 2016 at 1:10 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Dec 11, 2016, at 6:04 PM, Massoud Rezavand <msdrezavand at gmail.com> wrote:
> > Thank you very much,
> > So, if I am using PetscSplitOwnership() and then MatGetOwnershipRange() to be prepared for preallocation, then MatSetSizes(A, local_size, local_size, N, N) should be called with the calculated local_size from PetscSplitOwnership() ?
> Confusion from the two responses. You cannot use MatGetOwnershipRange() for preallocation.
> Without preallocation:
> > > PetscInt local_size = PETSC_DECIDE;
> > > MatSetSizes(A, local_size, local_size, N, N);
> MatGetOwnershipRanges(...)
> With preallocation:
> > > 2)
> > > PetscSplitOwnership(PETSC_COMM_WORLD, &local_size, &N);
> > > MPI_Scan(&local_size, &end_row, 1, MPIU_INT, MPI_SUM, PETSC_COMM_WORLD);
> > > begin_row = end_row - local_size;
> MatMPIAIJSetPreallocation(.....).
> But note that normally if the matrix comes from a discretization on a grid you would not use either approach above. The parallel layout of the grid would determine the local sizes and you won't not obtain them with PetscSplitOwnership() or local_size = PETSC_DECIDE;
> Where is your matrix coming from?
> Barry
> > Thanks,
> > Massoud
> > On Mon, Dec 12, 2016 at 12:35 AM, Jed Brown <jed at jedbrown.org> wrote:
> > Massoud Rezavand <msdrezavand at gmail.com> writes:
> > > Dear PETSc team,
> > > What is the difference between the following two methods to get the local
> > > dimensions of a square matrix A? If they do the same, which one is
> > > recommended? Should I use MPI_Scan after both?
> > I would typically use 1 because it's fewer calls and automatically uses
> > the correct communicator. You can use MatGetOwnershipRange() instead of
> > manually using MPI_Scan.
> > > 1)
> > > 2)
> > > Thanks in advance,
> > > Massoud
