[petsc-users] Simultaneously compute Residual+Jacobian in SNES
Derek Gaston friedmud at gmail.com
Sun Dec 11 14:43:55 CST 2016
Thanks Barry - I'll try it and get back to you.
Matt: There are lots of cases where this could be a large savings.  Here
are a few examples:
1.  If you have automatic differentiation.  With my newest code, just
computing a residual computes the Jacobian as a side effect.  If you throw
away that Jacobian that's obviously a waste.  If you compute one residual
without computing the Jacobian (which isn't always possible, depending on
how you have your automatic differentiation setup) then you still have to
compute _another_ residual to compute the Jacobian... so you're directly
doing double the residual computations that are necessary.
2.  Anytime you have extremely expensive work to do "per element" that
would need to be done for both the residual and Jacobian.  A few examples:
  - Extremely complex, heavy shape function evaluation (think super high
order with first and second derivatives needing to be computed)
  - Extremely heavy material property computations that need to happen at
each quadrature point.  Think: multiscale.  Maybe you have an expensive
lower-length-scale solve to do at every quadrature point (yes, we've
actually done this).
  - MANY coupled variables (we've run thousands).  Each of those variables
needs to have value, gradient and (possibly) second derivatives computed at
every quadrature point.  These values are exactly the same for the residual
and Jacobian.
These cases could be so extreme that these heavy "element" calculations
actually dominate your residual/jacobian assembly time.  That would mean
that by computing the residual and Jacobian simultaneously you could
directly cut your assembly time in _half_.  That could be significant for
many applications.  In my current application that essentially cuts the
whole runtime of the application in half (runtime is very much assembly
dominated).
Derek
On Fri, Dec 9, 2016 at 3:11 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Dec 9, 2016 at 2:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Dec 9, 2016, at 1:50 PM, Derek Gaston <friedmud at gmail.com> wrote:
> > Oh man!  Sorry Barry!  I swear I looked around before I sent the email.
> I should have checked the FAQ a little more closely!
> > I can understand the reasoning in the FAQ... but I still wonder if it
> might not be useful to provide all three options (Function, Jacobian,
> FunctionJacobian).  In my case I could fill in each one to do the right
> thing.  That way PETSc could call the "FunctionJacobian" one when it knew
> it needed both
>    Derek,
>       The code literally never knows if it will need a Jacobian following
> the function evaluation, yes at the first function evaluation it will need
> the Jacobian unless the function norm is sufficiently small but after that
> it is only a question of probabilities (which it can't know) whether it
> will need the Jacobian.
> > (by default that could just farm out to the individual calls).  But you
> guys have definitely thought a lot more about this than I have.
> > So, do you still recommend what's suggested in the FAQ?  Save off the
> Jacobian computation during the residual computation and then use that when
> SNES asks for a Jacobian?
>    Yes, try it. I think you can get away with simply putting the new
> Jacobian matrix values into the same Jacobian matrix that is regularly used
> so there is no need to "stash the values" somewhere else and copy them over
> later.
>    I'd be interested in hearing how the performance works out, compute
> always or compute only when requested.
> Can anyone write down a simple model for a concrete algorithm where this
> is more efficient? I would like to see the high level reasoning.
>   Thanks,
>     Matt
>   Barry
> >  In the case of automatic differentiation this could make a pretty huge
> difference in time...
> > Derek
> > On Fri, Dec 9, 2016 at 1:49 PM Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Sorry the title in the FAQ is a bit tongue-in-check.
> >   http://www.mcs.anl.gov/petsc/documentation/faq.html#functionjacobian
> > > On Dec 9, 2016, at 12:45 PM, Derek Gaston <friedmud at gmail.com> wrote:
> > > Is there a way to tell SNES to simultaneously compute both the
> residual and the Jacobian in one callback?
> > > My code can compute both simultaneously and it will be more efficient
> (think FE where you can reuse the shape-functions, variables, material
> properties, etc. for both residual and Jacobian computation).  In addition,
> I also have automatic differentiation as an option which _definitely_
> computes both efficiently (and actually computes residuals, by themselves,
> much slower).
> > > I was thinking that I may just save off the Jacobian whenever the
> initial residual computation is asked for by SNES... and then just return
> that Jacobian when SNES asks for it.  This may be a bit dicey though as
> SNES can ask for residual computations at many different points during the
> solve.
> > > Thanks for any help!
> > > Derek
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161211/55496df7/attachment.html>
