[petsc-users] Running the same problem multiple time, but the matrix is not the same
Khai Pham
khaipham at utexas.edu
Thu Dec 8 14:52:24 CST 2016
Hello,
I have problem with matrix assembly for linear solver KSP. I run the the
same problem with 4 processors multiple time. Using flag
-mat_view ::ascii_matlab to view the matrix. The matrix outputs are not the
same during each run. Please see the attached file for the comparison
between two runs. I checked all the input for each processor as it calls to
MatSetValues ( indices of the matrix and values ) and it's consistent all
the time. I also checked the allocation information (with flag -info) and
it looks fine. Could you give me an advice how to deal with this issue?
Thanks !
Best,
Khai
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161208/1b7601f5/attachment-0001.html>
Name: Screenshot from 2016-12-08 15-40-29.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161208/1b7601f5/attachment-0001.png>
