[petsc-users] Question about Set-up of Full MG and its Output
frank hengjiew at uci.edu
Wed Dec 7 17:48:56 CST 2016
Hello,
Thank you. Now I am able to see the trace of MG.
I still have a question about the interpolation. I wan to get the matrix
of the default interpolation method and print it on terminal.
The code is as follow: ( KSP is already set by petsc options)
132   CALL KSPGetPC( ksp, pc, ierr )
133   CALL MATCreate( PETSC_COMM_WORLD, interpMat, ierr )
134   CALL MATSetType( interpMat, MATSEQAIJ, ierr )
135   CALL MATSetSizes( interpMat, i5, i5, i5, i5, ierr )
136   CALL MATSetUp( interpMat, ierr )
137   CALL PCMGGetInterpolation( pc, i1, interpMat, ierr )
138   CALL MatAssemblyBegin( interpMat, MAT_FINAL_ASSEMBLY, ierr )
139   CALL MatAssemblyEnd( interpMat, MAT_FINAL_ASSEMBLY, ierr )
140   CALL MatView( interpMat, PETSC_VIEWER_STDOUT_SELF, ierr )
The error massage is:
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Must call PCMGSetInterpolation() or PCMGSetRestriction()
Do I have to set the interpolation first? How can I just print the
default interpolation matrix?
I attached the option file.
Thank you.
Frank
On 12/06/2016 02:31 PM, Jed Brown wrote:
> frank <hengjiew at uci.edu> writes:
>> Dear all,
>> I am trying to use full MG to solve a 2D Poisson equation.
>> I want to set full MG as the solver and SOR as the smoother. Is the
>> following setup the proper way to do it?
>>    -ksp_type                    richardson
>>    -pc_type                      mg
>>    -pc_mg_type               full
>>    -mg_levels_ksp_type   richardson
>>    -mg_levels_pc_type    sor
>> The ksp_view shows the levels from the coarsest mesh to finest mesh in a
>> linear order.
> It is showing the solver configuration, not a trace of the cycle.
>> I was expecting sth like:  coarsest -> level1 -> coarsest -> level1 ->
>> level2 -> level1 -> coarsest -> ...
>> Is there a way to show exactly how the full MG proceeds?
> You could get a trace like this from
> -mg_coarse_ksp_converged_reason -mg_levels_ksp_converged_reason
> If you want to deliminate the iterations, you could add -ksp_monitor.
>> Also in the above example, I want to know what interpolation or
>> prolongation method is used from level1 to level2.
>> Can I get that info by adding some options? (not using PCMGGetInterpolation)
>> I attached the ksp_view info and my petsc options file.
>> Thank you.
>> Frank
>> Linear solve converged due to CONVERGED_RTOL iterations 3
>> KSP Object: 1 MPI processes
>>    type: richardson
>>      Richardson: damping factor=1.
>>    maximum iterations=10000
>>    tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
>>    left preconditioning
>>    using nonzero initial guess
>>    using UNPRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>>    type: mg
>>      MG: type is FULL, levels=6 cycles=v
>>        Using Galerkin computed coarse grid matrices
>>    Coarse grid solver -- level -------------------------------
>>      KSP Object: (mg_coarse_) 1 MPI processes
>>        type: preonly
>>        maximum iterations=10000, initial guess is zero
>>        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>        using NONE norm type for convergence test
>>      PC Object: (mg_coarse_) 1 MPI processes
>>        type: lu
>>          out-of-place factorization
>>          tolerance for zero pivot 2.22045e-14
>>          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>          matrix ordering: nd
>>          factor fill ratio given 0., needed 0.
>>            Factored matrix follows:
>>              Mat Object: 1 MPI processes
>>                type: superlu_dist
>>                rows=64, cols=64
>>                package used to perform factorization: superlu_dist
>>                total: nonzeros=0, allocated nonzeros=0
>>                total number of mallocs used during MatSetValues calls =0
>>                  SuperLU_DIST run parameters:
>>                    Process grid nprow 1 x npcol 1
>>                    Equilibrate matrix TRUE
>>                    Matrix input mode 0
>>                    Replace tiny pivots FALSE
>>                    Use iterative refinement FALSE
>>                    Processors in row 1 col partition 1
>>                    Row permutation LargeDiag
>>                    Column permutation METIS_AT_PLUS_A
>>                    Parallel symbolic factorization FALSE
>>                    Repeated factorization SamePattern
>>        linear system matrix = precond matrix:
>>          type: seqaij
>>          rows=64, cols=64
>>          total: nonzeros=576, allocated nonzeros=576
>>            not using I-node routines
>>    Down solver (pre-smoother) on level 1 -------------------------------
>>      KSP Object: (mg_levels_1_) 1 MPI processes
>>        type: richardson
>>      PC Object: (mg_levels_1_) 1 MPI processes
>>        type: sor
>>          SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
>>          type: seqaij
>>          rows=256, cols=256
>>          total: nonzeros=2304, allocated nonzeros=2304
>>    Up solver (post-smoother) same as down solver (pre-smoother)
>>    Down solver (pre-smoother) on level 2 -------------------------------
>>      KSP Object: (mg_levels_2_) 1 MPI processes
>>        type: richardson
>>      PC Object: (mg_levels_2_) 1 MPI processes
>>        type: sor
>>          type: seqaij
>>          rows=1024, cols=1024
>>          total: nonzeros=9216, allocated nonzeros=9216
>>    Down solver (pre-smoother) on level 3 -------------------------------
>>      KSP Object: (mg_levels_3_) 1 MPI processes
>>        type: richardson
>>      PC Object: (mg_levels_3_) 1 MPI processes
>>        type: sor
>>          type: seqaij
>>          rows=4096, cols=4096
>>          total: nonzeros=36864, allocated nonzeros=36864
>>    Down solver (pre-smoother) on level 4 -------------------------------
>>      KSP Object: (mg_levels_4_) 1 MPI processes
>>        type: richardson
>>      PC Object: (mg_levels_4_) 1 MPI processes
>>        type: sor
>>          type: seqaij
>>          rows=16384, cols=16384
>>          total: nonzeros=147456, allocated nonzeros=147456
>>    Down solver (pre-smoother) on level 5 -------------------------------
>>      KSP Object: (mg_levels_5_) 1 MPI processes
>>        type: richardson
>>      PC Object: (mg_levels_5_) 1 MPI processes
>>        type: sor
>>          type: seqaij
>>          rows=65536, cols=65536
>>          total: nonzeros=327680, allocated nonzeros=327680
>>            has attached null space
>>      type: seqaij
>> #PETSc Option Table entries:
>> -ksp_converged_reason
>> -ksp_initial_guess_nonzero yes
>> -ksp_norm_type unpreconditioned
>> -ksp_rtol 1e-7
>> -ksp_view
>> -mg_coarse_ksp_type preonly
>> -mg_coarse_pc_factor_mat_solver_package superlu_dist
>> -mg_coarse_pc_type lu
>> -mg_levels_ksp_max_it 1
>> -N 256
>> -options_left
>> -pc_mg_galerkin
>> -pc_mg_levels 6
>> -pc_mg_type full
>> -pc_type mg
>> -px 1
>> -py 1
>> #End of PETSc Option Table entries
>> There are no unused options.
>> -ksp_rtol        1e-7
>> -options_left
>> -ksp_view
>> -pc_type mg
>> -pc_mg_type full
>> -pc_mg_galerkin
>> -pc_mg_levels 6
-ksp_rtol        1e-7
-options_left
-ksp_view
-pc_type mg
-pc_mg_galerkin
-pc_mg_levels 6
