[petsc-users] GMRES with matrix-free method and preconditioning matrix for higher performance.
Wed Aug 31 07:46:42 CDT 2016
On Wed, Aug 31, 2016 at 7:34 AM, Choi Kyungjun <kyungjun.choi92 at gmail.com>
wrote:
> 2016-08-31 21:23 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>> On Wed, Aug 31, 2016 at 7:22 AM, Choi Kyungjun <kyungjun.choi92 at gmail.com
>> > wrote:
>>> Thank you very much again Matt.
>>> Just another simple question.
>>> 2016-08-31 20:00 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>> On Wed, Aug 31, 2016 at 5:46 AM, Choi Kyungjun <
>>>> kyungjun.choi92 at gmail.com> wrote:
>>>>> Thanks Matt.
>>>>> I really appreciate your help every time.
>>>>> I think I forgot mentioning code info again.
>>>>> 1)
>>>>> I'm working on 2-D/3-D Compressible Euler equation solver, which is
>>>>> completely hyperbolic system.
>>>> Okay, then MG is out. I would start by using a sparse direct solver,
>>>> like SuperLU. Then for parallelism
>>>> you could use ASM, and as the subsolver use SuperLU, so something like
>>>>   -ksp_type gmres -pc_type asm -sub_pc_type superlu
>>>> You could get more sophisticated by
>>>>   - Trying to have blocks bigger than 1 process and using SuperLU_dist
>>>>   - Splitting up the fields using PCFIELDSPLIT. There are indications
>>>> that solving one of the fields first
>>>>     can really help convergence. I am thinking of the work of David
>>>> Keyes and LuLu Liu on MSM methods.
>>> For the above part,
>>> It's not compatible with -snes_mf  command line option, is it?
>> No. I think MF is not a useful idea unless you have a preconditioning
>> matrix.
>>   Thanks,
>>      Matt
> But in order to use KSP context,
> I have to make my system matrix,  isn't it?
> Then what's the difference between having preconditioning matrix preA and
> making system matrix A?
The preA can be an _approximation_ to A, since MF A provides an accurate
matrix-vector product.
> Because  *-snes_mf* option requireed no system matrix and just computed
> the residual which felt very convenient.
> If is necessary to make my system matrix to use KSP - GMRES, as you
> recommended above, then I'll try.
The KSP does not need the matrix, but as I mentioned KSPes are not good
solvers. They are just for accelerating
solves. In general, good solvers need the matrix.
     Matt
> Thank  you very much.
> Kyungjun.
>>> I applied cmd line options like below
>>> *-snes_mf     -ksp_type  gmres     -pc_type asm     -sub_pc_type superlu
>>>     -snes_view     -snes_monitor     -ksp_monitor    -snes_converged_reason
>>>    -ksp_converged_reason*
>>> and my code flows like this
>>> *- call SNESCreate(PETSC_COMM_WORLD, Mixt%snes, ier)*
>>> *- call SNESSetFunction(Mixt%snes, Mixt%r, FormFunction, userctx, ier)*
>>> *- call SNESSetFromOptions(Mixt%snes, ier)*
>>> *- call SNESGetKSP(Mixt%snes, ksp, ier)*
>>> *- call KSPGetPC(ksp, pc, ier)*
>>> *- call KSPSetFromOptions(ksp, ier)*
>>> *- call PCSetFromOptions(pc, ier)*
>>>>> 2)
>>>>> And I'm trying to implement some implicit time scheme for convergence
>>>>> of my steady state problem.
>>>>> I used LUSGS implicit scheme before, but these days GMRES implicit
>>>>> scheme is popular for quadratic convergence characteristics.
>>>> I am not sure I understand here. Nothing about GMRES is quadratic.
>>>> However, Newton's method can be quadratic
>>>> if your initial guess is good, and GMRES could be part of a solver for
>>>> that.
>>>>> For implicit time scheme, it is just same as matrix inversion, so I
>>>>> started PETSc library for GMRES, which is one of the greatest mathematical
>>>>> library.
>>>>> 3)
>>>>> As I'm using different numerical convective flux scheme (e.g. Roe's
>>>>> FDS, AUSM, etc), it would be really time consuming to derive Jacobian
>>>>> matrix for each scheme.
>>>> Yes. However, the preconditioner matrix only needs to be approximate. I
>>>> think you should derive one for the easiest flux scheme and
>>>> always use that. The important thing is to couple the unknowns which
>>>> influence each other, rather than the precise method of influence.
>>>>   Thanks,
>>>>       Matt
>>>>> So I was fascinated by matrix-free method (I didn't completely
>>>>> understand this method back then), and I implemented GMRES with no
>>>>> preconditioning matrix with your help.
>>>>> After that, I wanted to ask you about any accelerating methods for my
>>>>> GMRES condition.
>>>>> I will try applying CHEBY preconditioner as you mentioned first (even
>>>>> if its performance wouldn't be that good).
>>>>> In order to constitute user-provided preconditioning matrix, could you
>>>>> tell me any similar examples?
>>>>> Thanks again.
>>>>> Your best,
>>>>> Kyungjun.
>>>>> 2016-08-31 19:07 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>> On Wed, Aug 31, 2016 at 3:49 AM, Choi Kyungjun <
>>>>>>> Dear Petsc.
>>>>>>> I am implementing Petsc library for my CFD flow code.
>>>>>>> Thanks to Matt, I got what I wanted last week.
>>>>>>> It was the GMRES with matrix-free method, no preconditioning matrix
>>>>>>> and command line options are below.
>>>>>>> *-snes_mf    -pc_type none    -..monitor   -..converged_reason*
>>>>>>> The solve worked, but performed very poorly.
>>>>>>> I learned that the efficiency of Krylov-subspace methods depends
>>>>>>> strongly depends on a good preconditioner.
>>>>>>> And in the Petsc manual, the matrix-free method is allowed only with
>>>>>>> no preconditioning, a user-provided preconditioner matrix, or a
>>>>>>> user-provided preconditioner shell.
>>>>>>> Here are my questions.
>>>>>>> 1) To improve the solver performance using GMRES, is there any way
>>>>>>> using snes_mf without preconditioning matrix?
>>>>>> Not really. The CHEBY preconditioner will work without an explicit
>>>>>> matrix, however its not great by itself.
>>>>>>> 2) For user-provided preconditioner matrix, I saw some example codes
>>>>>>> that provide approx. Jacobian matrix as preconditioner matrix. But this
>>>>>>> means that I should derive approx. Jacobian mat for system, am I right?
>>>>>> Yes.
>>>>>>> 3) I'd like to know which is the fastest way to solve with GMRES
>>>>>>> method. Could you tell me or let me know any other examples?
>>>>>> 1) The solve depends greatly on the physics/matrix you are using.
>>>>>> Without knowing that, we can't say anything. For example, is
>>>>>> the system elliptic? If so, then using Multigrid (MG) is generally a
>>>>>> good idea.
>>>>>> 2) In general, I think its a mistake to think of GMRES or any KSP as
>>>>>> a solver. We should think of them as accelerators for solvers,
>>>>>> as they were originally intended. For example, MG is a good solver
>>>>>> for elliptic CFD equations, as long as you somehow deal with
>>>>>> incompressibility. Then you can use GMRES to cleanup some things you
>>>>>> miss when implementing your MG solver.
>>>>>> 3) The best thing to do in this case is to look at the literature,
>>>>>> which is voluminous, and find the solver you want to implement. PETSc
>>>>>> really speeds up the actually implementation and testing.
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thank you very much for your help.
>>>>>>> Sincerely,
>>>>>>> Kyungjun.
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160831/484baa85/attachment.html>
