[petsc-users] strong-scaling vs weak-scaling
Matthew Knepley
knepley at gmail.com
Mon Aug 22 05:42:28 CDT 2016
On Sun, Aug 21, 2016 at 9:38 PM, Justin Chang <jychang48 at gmail.com> wrote:
> Hi all,
> This may or may not be a PETSc specific question but...
> I have seen some people claim that strong-scaling is harder to achieve
> than weak scaling (e.g., https://www.sharcnet.ca/help/index.php/Measuring_
> Parallel_Scaling_Performance) and generally speaking it makes sense -
> communication overhead increases with concurrency.
> However, we know that most PETSc solvers/applications are not only
> memory-bandwidth bound, but may not scale as well w.r.t. problem size as
> other solvers (e.g., ILU(0) may beat out GAMG for small elliptic problems
> but GAMG will eventually beat out ILU(0) for larger problems), so wouldn't
> weak-scaling not only be the more interesting but more difficult
> performance metric to achieve? Strong-scaling issues arise mostly from
> communication overhead but weak-scaling issues may come from that and also
> solver/algorithmic scalability w.r.t problem size (e.g., problem size N
> takes 10*T seconds to compute but problem size 2*N takes 50*T seconds to
> compute).
> In other words, if one were to propose or design a new algorithm/solver
> capable of handling large-scale problems, would it be equally if not more
> important to show the weak-scaling potential? Because if you really think
> about it, a "truly efficient" algorithm will be less likely to scale in the
> strong sense but computation time will be close to linearly proportional to
> problem size (hence better scaling in the weak-sense). It seems if I am
> trying to convince someone that a proposed computational framework is "high
> performing" without getting too deep into performance modeling, a poor
> parallel efficiency (arising due to good sequential efficiency) in the
> strong sense may not look promising.
It definitely depends on your point of view. However, I believe that the
point being made by people is twofold:
1) Weak scaling is relatively easy to game by making a serially
inefficient code.
2) Strong scaling involves reducing the serial fraction of your code to
get around the Amdahl limit. For most codes, I don't think
communication overhead even makes it on the table. Engineering for
this level of concurrency is not easy.
There is a related point:
3) Scientists often want to solve a particular problem rather than the
biggest problem a machine can fit in memory
For sophisticated algorithms that can handle real world problems, I don't
think weak scaling is easy either. However, for toy
problems it is, and since most CS types only deal with the Laplace equation
on a square, it does not look hard.
Matt
> Justin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160822/3fa9ef60/attachment.html>
