[petsc-users] Store and reuse the factor of matrix
Thu Aug 18 21:28:22 CDT 2016
On Thu, Aug 18, 2016 at 9:22 PM, Jinlei Shen <jshen25 at jhu.edu> wrote:
> ​Hi,
> I'm trying to implement modified newton method to solve the nonlinear
> finite element using petsc.
> As well known,  the advantage of modified newton is the Jacobian matrix is
> always same during the iteration, which means once the J is factorized at
> the first iteration, we can store the factors and avoid the factorization
> for next iteration if we use direct solver, e.g. super_lu. Therefore, the
> option FACTORED in SUPER_LU is quite useful.
> However, it looks like the option FACTORED is not available in
> SUPER_LU_DIST in petsc. I tried, and it shows 'unknown option'.
> Is there alternative way to use the same idea of FACTORED in petsc for
> super_lu?
> Also, I'm wondering whether iterative solver in PETSC is also able to
> apply the same strategy.
> In other words, in the problem where Jacobian is constant, only residue
> and solution vectors need to be updated, is there any way to take advantage
> of such same Jacobian pattern to expedite the computation using iterative
> solver?
> Thank you
> BTW, though using modified newton will increase the iteration number,
> however, in the case which is much more expensive to factorize the
> jacobian, more iterations will probably be worthwhile.
You can use
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagJacobian.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetLagPreconditioner.html#SNESSetLagPreconditioner
to get fine-grained control over this without writing any code.
   Matt
Bests,
> Jinlei
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160818/cc337ae7/attachment.html>
