[petsc-users] Question about using MatSNESMFWPSetComputeNormU
Thu Aug 18 14:23:52 CDT 2016
On Thu, Aug 18, 2016 at 2:14 PM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
> I called SNESView() at right above  call SNESSolve()   to check options
> that I applied.
Okay, I am not understanding what you want to do. Below, you have setup
SNES to
calculate the entire Jacobian using a finite-difference (FD) approximation.
This is the same
as using
  -snes_fd
I thought you wanted to use a matrix-free action for the Jacobian
  -snes_mf
and no preconditioner
  -pc_type none
although I have no idea what kind of a problem this would work for.
   Matt
> SNES Object: 1 MPI processes
>   type: newtonls
>   SNES has not been set up so information may be incomplete
>   maximum iterations=1, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-32, solution=1e-08
>   total number of linear solver iterations=0
>   total number of function evaluations=0
>   norm schedule ALWAYS
>   SNESLineSearch Object:   1 MPI processes
>     type: bt
>       interpolation: cubic
>       alpha=1.000000e-04
>     maxstep=1.000000e+08, minlambda=1.000000e-12
>     tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
>     maximum iterations=40
>   KSP Object:   1 MPI processes
>     type: gmres
>       GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>       GMRES: happy breakdown tolerance 1e-30
>     maximum iterations=10000
>     tolerances:  relative=0.001, absolute=1e-50, divergence=10000.
>     left preconditioning
>     using nonzero initial guess
>     using DEFAULT norm type for convergence test
>   PC Object:   1 MPI processes
>     type: none
>     PC has not been set up so information may be incomplete
>     linear system matrix = precond matrix:
>     Mat Object:     1 MPI processes
>       type: mffd
>       rows=64, cols=64
>         Matrix-free approximation:
>           err=1.49012e-08 (relative error in function evaluation)
>           The compute h routine has not yet been set
> And this is the whole error message
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: Mat type mffd
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.3, Jul, 24, 2016
> [0]PETSC ERROR: ./flus
>                                              � ��� on a arch-linux2-c-debug
> named ckj-System by ckj Fri Aug 19 04:09:56 2016
> [0]PETSC ERROR: Configure options --with-cc=icc --with-cxx=icpc
> --with-fc=ifort --with-mpi-include=/opt/intel/impi/
> 5.0.1.035/intel64/include --with-mpi-lib="-L/opt/intel//impi/
> 5.0.1.035/intel64/release -L/opt/intel//impi/5.0.1.035/intel64/lib
> -lmpifort -lmpi -lmpigi -ldl -lrt -lpthread" --with-blas-lapack-dir=/opt/intel/mkl
> --prefix=/opt/petsc/3.7.3
> [0]PETSC ERROR: #1 MatZeroEntries() line 5511 in
> /home/ckj/Repository/petsc-3.7.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: #2 SNESComputeJacobianDefault() line 65 in
> /home/ckj/Repository/petsc-3.7.3/src/snes/interface/snesj.c
> [0]PETSC ERROR: #3 oursnesjacobian() line 105 in
> /home/ckj/Repository/petsc-3.7.3/src/snes/interface/ftn-custom/zsnesf.c
> [0]PETSC ERROR: #4 SNESComputeJacobian() line 2312 in
> /home/ckj/Repository/petsc-3.7.3/src/snes/interface/snes.c
> [0]PETSC ERROR: #5 SNESSolve_NEWTONLS() line 228 in
> /home/ckj/Repository/petsc-3.7.3/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #6 SNESSolve() line 4005 in /home/ckj/Repository/petsc-3.
> I checked that the program got out of calling SNESSolve() after this error
> message.
> But I can't figure out the reason for this error.
> Best,
> Kyungjun
> 2016-08-19 4:05 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>> On Thu, Aug 18, 2016 at 2:03 PM, 최경준 <kyungjun.choi92 at gmail.com> wrote:
>>> I got stuck at FormJacobian stage.
>>> - call SNESComputeJacobianDefault(snes, v, J, pJ, FormResidual, ier)
>>>  --> J & pJ are same with A matrix-free matrix (input argument)
>>> with these kind of messages..
>> 1) Always give the ENTIRE error message
>> 2) As I said in the last two messages, you can only use this without a
>> preconditioner, so you need
>>   -pc_type none
>>     Matt
>>> Guess it's because I used A matrix-free matrix (which is mffd type) into
>>> pJ position.
>>> Is there any solution for this kind of situation?
>>> 2016-08-19 2:05 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>> On Thu, Aug 18, 2016 at 12:04 PM, 최경준 <kyungjun.choi92 at gmail.com>
>>>> wrote:
>>>>> Then in order not to use preconditioner,
>>>>> is it ok if I just put A matrix-free matrix (made from
>>>>> MatCreateSNESMF()) into the place where preA should be?
>>>> Yes, but again the solve will likely perform very poorly.
>>>>   Thanks,
>>>>      Matt
>>>>> The flow goes like this
>>>>> - call SNESCreate
>>>>> - call SNESSetFunction(snes, r, FormResidual, userctx, ier)
>>>>> - call MatCreateSNESMF(snes, A, ier)
>>>>> - call SNESSetJacobian(snes, A, A, FormJacobian, userctx, ier)
>>>>> - call SNESSetFromOptions()
>>>>> - call SNESGetKSP(snes, ksp, ier)
>>>>> - call KSPSetType(ksp, KSPGMRES, ier)
>>>>> - call KSPGetPC(ksp, pc, ier)
>>>>> - call PCSetType(pc, PCNONE, ier)
>>>>> - call KSPGMRESSetRestart(ksp, 30, ier)
>>>>> - call SNESSolve()
>>>>> and inside the FormJacobian routine
>>>>> - call SNESComputeJacobian(snes, v, J, pJ, userctx, ier)  --> J and pJ
>>>>> must be pointed with A and A.
>>>>> Thank you again,
>>>>> Kyungjun.
>>>>> 2016-08-19 1:44 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>> On Thu, Aug 18, 2016 at 11:42 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>> wrote:
>>>>>>> Thanks for your helpful answers.
>>>>>>> Here's another question...
>>>>>>> As I read some example PETSc codes, I noticed that there should be a
>>>>>>> preconditioning matrix (e.g. approx. jacobian matrix) when using
>>>>>>> MatCreateSNESMF().
>>>>>>> I mean,
>>>>>>> after calling MatCreateSNESMF(snes, A, ier),
>>>>>>> there should be another matrix preA(preconditioning matrix) to use
>>>>>>> SNESSetJacobian(snes, A, preA, FormJacobian, ctx, ier).
>>>>>>> 1) Is there any way that I can use matrix-free method without making
>>>>>>> preconditioning matrix?
>>>>>> Don't use a preconditioner. As you might expect, this does not often
>>>>>> work out well.
>>>>>>> 2) I have a reference code, and the code adopts
>>>>>>> MatFDColoringCreate()
>>>>>>> and finally uses
>>>>>>> SNESComputeJacobianDefaultColor() at FormJacobian stage.
>>>>>>> But I can't see the inside of the fdcolor and I'm curious of this
>>>>>>> mechanism. Can you explain this very briefly or tell me an example code
>>>>>>> that I can refer to. ( I think none of PETSc example code is using
>>>>>>> fdcolor..)
>>>>>> This is the default, so there is no need for all that code. We use
>>>>>> naive graph 2-coloring. I think there might be a review article by Alex
>>>>>> Pothen about that.
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> Best,
>>>>>>> Kyungjun.
>>>>>>> 2016-08-19 0:54 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>>>> On Thu, Aug 18, 2016 at 10:39 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> 1) I wanna know the difference between applying option with
>>>>>>>>> command line and within source code.
>>>>>>>>> From my experience, command line option helps set other default
>>>>>>>>> settings that I didn't applied, I guess.
>>>>>>>> The command line arguments are applied to an object when
>>>>>>>> *SetFromOptions() is called, so in this case
>>>>>>>> you want SNESSetFromOptions() on the solver. There should be no
>>>>>>>> difference from using the API.
>>>>>>>>> 2) I made a matrix-free matrix with MatCreateSNESMF function, and
>>>>>>>>> every time I check my snes context with SNESView,
>>>>>>>>>       type: mffd
>>>>>>>>>       rows=11616, cols=11616
>>>>>>>>> at the end of line shows there's no routine for computing h value.
>>>>>>>>> I used MatMFFDWPSetComputeNormU function, but it didn't work I
>>>>>>>>> think.
>>>>>>>>> Is it ok if I leave the h value that way? Or should I have to set
>>>>>>>>> h computing routine?
>>>>>>>> I am guessing you are calling the function on a different object
>>>>>>>> from the one that is viewed here.
>>>>>>>> However, there will always be a default function for computing h.
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> Kyungjun.
>>>>>>>>> 2016-08-18 23:18 GMT+09:00 Matthew Knepley <knepley at gmail.com>:
>>>>>>>>>> On Thu, Aug 18, 2016 at 8:35 AM, 최경준 <kyungjun.choi92 at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Hi, I'm trying to set my SNES matrix-free with Walker & Pernice
>>>>>>>>>>> way of computing h value.
>>>>>>>>>>> I found above command (MatSNESMFWPSetComputeNormU) but my
>>>>>>>>>>> fortran compiler couldn't fine any reference of that command.
>>>>>>>>>>> I checked Petsc changes log, but there weren't any mentions
>>>>>>>>>>> about that command.
>>>>>>>>>>> Should I have to include another specific header file?
>>>>>>>>>> We have this function
>>>>>>>>>>   http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpage
>>>>>>>>>> s/Mat/MatMFFDWPSetComputeNormU.html
>>>>>>>>>> but I would recommend using the command line option
>>>>>>>>>>   *-mat_mffd_compute_normu*
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>> Thank you always.
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160818/3591239b/attachment-0001.html>
