[petsc-users] dmplex with block size error
Rongliang Chen rongliang.chan at gmail.com
Thu Aug 18 05:49:11 CDT 2016
Hi Matt,
Thanks for your help. I will fix this first.
Best,
Rongliang
On 08/18/2016 06:08 PM, Matthew Knepley wrote:
> On Thu, Aug 18, 2016 at 5:05 AM, Rongliang Chen
> <rongliang.chan at gmail.com <mailto:rongliang.chan at gmail.com>> wrote:
>     Hi Matt,
>     The log of the valgrind is attached. When I run with valgrind, the
>     following error message comes up.
> The valgrind log says your code is writing over memory. Fix that first.
>    Matt
>     [1]PETSC ERROR: --------------------- Error Message
>     [1]PETSC ERROR: Arguments are incompatible
>     [1]PETSC ERROR: Cannot change block size 3670016 to 7
>     [1]PETSC ERROR: See
>     http://www.mcs.anl.gov/petsc/documentation/faq.html
>     <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
>     shooting.
>     [1]PETSC ERROR: Petsc Release Version 3.6.3, Dec, 03, 2015
>     [1]PETSC ERROR: ./fsi on a 64bit-debug named rlchen by rlchen Thu
>     Aug 18 17:59:43 2016
>     [1]PETSC ERROR: Configure options --download-blacs
>     --download-scalapack --download-metis --download-parmetis
>     --download-exodusii --download-netcdf --download-hdf5
>     --with-mpi-dir=/home/rlchen/soft/Program/mpich2-shared
>     --with-debugging=1 --download-fblaslapack --with-64-bit-indices
>     [1]PETSC ERROR: #1 PetscLayoutSetBlockSize() line 424 in
>     /home/rlchen/soft/petsc-3.6.3/src/vec/is/utils/pmap.c
>     [1]PETSC ERROR: #2 MatSetBlockSize() line 6920 in
>     /home/rlchen/soft/petsc-3.6.3/src/mat/interface/matrix.c
>     [1]PETSC ERROR: #3 MatXAIJSetPreallocation() line 282 in
>     /home/rlchen/soft/3D_fluid/FSI/Spmcs-v1.5/Fluid-petsc-3.6/src/application/Fluid/gcreate.c
>     Best regards,
>     Rongliang
>     On 08/18/2016 05:52 PM, Matthew Knepley wrote:
>>     Run with valgrind and send the log.
>>       Thanks,
>>          Matt
>>     On Thu, Aug 18, 2016 at 3:59 AM, Rongliang Chen
>>         Dear All,
>>         I try to use the block matrix (BAIJ) for the dmplex data
>>         structure with the option "-dm_mat_type baij" (the block size
>>         is 7). The code works fine when np = 1 but the following
>>         error comes up when np>1. And the code also works fine for
>>         np>1 if I set the block size to be 1. Any suggestions are
>>         highly appreciated.
>>         [1]PETSC ERROR: PetscMallocValidate: error detected at
>>         VecAXPY_Seq() line 89 in
>>         /home/rlchen/soft/petsc-3.6.3/src/vec/vec/impls/seq/bvec1.c
>>         [1]PETSC ERROR: Memory at address 0x1332571 is corrupted
>>         [1]PETSC ERROR: Probably write past beginning or end of array
>>         [1]PETSC ERROR: Last intact block allocated in
>>         PetscStrallocpy() line 188 in
>>         /home/rlchen/soft/petsc-3.6.3/src/sys/utils/str.c
>>         [1]PETSC ERROR: Memory corruption:
>>         http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>         <http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind>
>>         [1]PETSC ERROR:
>>         [1]PETSC ERROR: See
>>         trouble shooting.
>>         Thu Aug 18 16:42:34 2016
>>         [1]PETSC ERROR: #1 PetscMallocValidate() line 136 in
>>         /home/rlchen/soft/petsc-3.6.3/src/sys/memory/mtr.c
>>         [1]PETSC ERROR: #2 VecAXPY_Seq() line 89 in
>>         [1]PETSC ERROR: #3 VecAXPY() line 640 in
>>         /home/rlchen/soft/petsc-3.6.3/src/vec/vec/interface/rvector.c
>>         Best regards,
>>         Rongliang
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160818/6273836b/attachment.html>
